Good morning ladies and gentlemen,
I have a stock 2010 Golf TDI DSG. It does have a Polar FIS installed, a panzer plate and a dieselgeek P2015 intake flap repiar bracket.
Auto scan:
No recent repairs other than the VW emissions modification that was performed some time last year. Probably over a year ago at least. The OEM VW battery is from 8/15 but it my little Midtronics PBT-300 tester shows 800CA. The engine starts great.
We also have a Nissan leaf for around town and usually only use the TDI car for distant trips from Chapel Hill, NC to out of state (usually VA).
The problem at hand began about 3 weeks ago. It was raining here almost every day so I was driving this car to work instead of riding my ebike like I normally do. I got in the car on that Monday and was greeted with chimes and warnings for ABS/ESP and airbag. I thought no big deal I'll scan it later and see what's going on. Probably just low battery voltage since this car sits a lot. Car ran fine. No problems.
I drove it all week and never got around to scanning it. No problems.
The next weekend my wife takes the car to VA to visit her folks. I tell her about the lights and say it's no problem.
She calls me when she's 4 hrs into her 5 hour drive to tell me that while on a 50MPH road, the BRAKE light came on and began flashing and beeping. At the same time, the speed dropped to 20mph and engine rpm was 4000. She pulled over and shut the car off. After a while she got back in and it ran fine the rest of the way to her parents' place.
The car did basically this same thing 2 more times while she was up there (3 times total). She ended up drivng her dad's car back here to NC because she was afraid the TDI would either not make it home or endager her on I-95.
A few days later, her dad hauls the TDI down here with his suburban and hauls his car back.
I have driven it a number of times since with no issues though I did note that none of the wheels are able to report speed.
I will admit that this would be the first time I ever tried to observe wheel speed in the ABS controller so I don't know what (if anything) I am supposed to see in those MB's. Sometimes it would show me zeros and sometimes 65535.
Another thing that I will note is that while sitting in the drivers seat with the engine running, I notice that the transmission seems to want to lurch against the parking brake similar to what it does when you're performing the DSG basic settings adaptation AND that the little green light with the foot-on-brake icon is sort of flickering from time to time. When I observe the brake switch status in VCDS it does not show the same flicker so I don't think it is actually the switch's signal causing the flicker.
I have checked all fuses in the B panel, I have inspected wiring in the rain tray and as much of what I can see near the ABS module and each wheel. I see nary a sign of rodents living anywhere on the car.
Here is a small album of photos and videos I put together on google photos. I will add to it as I investigate further.
Thanks for your help!
-Robby
Auto scan:
Wednesday,01,July,2020,17:14:22:32736
VCDS Version: 18.9.1.0 (x64)
VIN: WVWDM7AJ4AW375250 License Plate:
Mileage: 172300km-107062mi Repair Order:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 55 56 62 65
72 77
VIN: WVWDM7AJ4AW375250 Mileage: 172300km-107062miles
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 K HW: 03L 906 022 TS
Component: R4 2.0l TDI G001AG 9983
Revision: 12H03--- Serial number:
Coding: 0050078
Shop #: WSC 49955 002 1048576
VCID: 3669D2C941389DFA37-8062
006480 - Radiator Fan (V7)
P1950 - 000 - Movement Restricted / Jammed - Intermittent
Fault Frequency: 31
Mileage: 169820 km
Date: 2014.07.20
Time: 18:26:56
RPM: 1978 /min
Speed: 101.0 km/h
Temperature: 3.6°C
Temperature: 86.4°C
Temperature: 2.7°C
Lambda: 86.8 %
Lambda: 0.0 %
Part No SW: 02E 300 052 T HW: 02E 927 770 AL
Component: GSG DSG AG6 511 9037
Revision: 51112 Serial number: 00001003170199
Coding: 0000024
VCID: 254B0585EC9EE6628E-8070
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B400C492900FF880D02E992190042310000
VCID: 7AF106F9F5A0B99A93-802E
7 Faults Found:
Fault Frequency: 7
Reset counter: 138
Mileage: 171521 km
Date: 2014.11.03
Time: 07:37:04
Count: 16391
Count: 15
Count: 4096
Count: 128
Count: 35584
Count: 1280
Count: 255
Count: 6400
Fault Status: 00100011
Reset counter: 138
Mileage: 172286 km
Date: 2014.11.18
Time: 22:00:10
Count: 3
Count: 4608
Count: 67
Count: 51213
Count: 1289
Count: 516
Reset counter: 98
Mileage: 171522 km
Date: 2014.11.03
Time: 07:38:38
Count: 1088
Count: 4608
Count: 83
Count: 51253
Count: 65534
Count: 65030
Reset counter: 98
Mileage: 172206 km
Date: 2014.11.18
Time: 08:57:33
Count: 3
Count: 4608
Count: 71
Count: 49768
Count: 1
Count: 2
Fault Frequency: 7
Reset counter: 98
Mileage: 171607 km
Count: 16387
Count: 14
Count: 4096
Count: 87
Count: 38912
Count: 1001
Count: 254
Count: 1280
Fault Status: 00101100
Reset counter: 98
Mileage: 172254 km
Date: 2014.11.18
Time: 09:26:47
Count: 7
Count: 4608
Count: 64
Count: 48896
Count: 65283
Fault Status: 01101100
Fault Frequency: 7
Reset counter: 98
Mileage: 171521 km
Count: 16386
Count: 14
Count: 4096
Count: 80
Count: 43008
Count: 1474
Count: 6912
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
ROD: EV_ClimaBasis_VW36.rod
VCID: 75EB15C5D4BED6E2FE-8020
13701888 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Fault Frequency: 30
Reset counter: 137
Mileage: 158078 km
Date: 2019.02.01
Time: 09:13:19
Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
Component: BCM PQ35 H+ 103 0578
Revision: 00103 AF
Coding: 67180A1A90272AC48088008160008D0441050086534D8560648020200000
VCID: 356BD5C59C3E96E23E-8060
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 24031 21 0512
Coding: 009795
Reset counter: 100
Mileage: 171014 km
Date: 2014.09.30
Time: 18:51:29
Term 15 Off
Voltage: 12.00 V
Term 50 Off
01516 - Terminal 30; Left
Fault Status: 00101011
Reset counter: 137
Mileage: 172280 km
Term 15 Off
Voltage: 12.45 V
Term 50 Off
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4D0AUE22
Coding: 00003031
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3973D9F5B8267282DA-806C
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--0005446Q00
Serial number: 3572MSME0D032251ZZZJ
Serial number: 3582MSME5A673350ZZZX
Serial number: 3512QSME3A0A523BZZZZ
Serial number: 3522QSME260A5318ZZZR
Serial number: 35527SME39153321ZZZ3
Serial number: 35627SME6C093221ZZZC
9483008 - Seat Occupied Recognition
B10B3 00 [137] - Function Restriction due to Implausible Message(s)
Fault Frequency: 12
Reset counter: 98
Mileage: 171521 km
Date: 2020.06.12
Time: 07:37:23
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0001632
VCID: 76E912C901B8DDFAF7-8022
Subsystem 1 - Part No: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H06 0022
Coding: 00000227
Part No SW: 5K0 920 970 Q HW: 5K0 920 970 Q
Component: KOMBI H03 0305
Coding: 270D00
VCID: 3C7DC0E1B71447AAC1-8068
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 260310F1000133
Coding: ED817F07001612000002
VCID: 69D349B5400602026A-803C
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223R8AB406
VCID: 7EF90AE9298895BAAF-802A
Component: IMMO H03 0305
VCID: 6AD136B98D00091A63-803E
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Revision: A1001003 Serial number: 7667911112
VCID: 264902895198ED7A87-8072
Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
Component: Tuer-SG 009 2139
Coding: 0001204
VCID: 336FEBDD524A88D210-8066
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
VCID: 3163E1D5A856BAC262-8064
01316 - ABS Control Module
013 - Check DTC Memory
Fault Status: 01101101
Fault Frequency: 23
Reset counter: 98
Mileage: 172304 km
Date: 2014.11.22
Time: 05:45:49
Voltage: 11.75 V
DD
Temperature: 30.0°C
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Component: Tuer-SG 009 2113
Coding: 0001204
VCID: 3261EED9AD5081DA1B-8066
00106 - Signal Central Locking SAVE/LOCK Passenger Side
Component: AFS-Steuergeraet 0142
Coding: 1446940
VCID: 346DE8C157448FEA09-8060
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0005
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0005
Coding: 00000022
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0035
Revision: -----20S Serial number: VWZ4Z7K1120605
Coding: 0100040004
VCID: 61C3519578364A42B2-8034
Reset counter: 31
Mileage: 158013 km
Date: 2013.06.23
Time: 00:07:52
Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012552
Address 65: Tire Pressure (J502) Labels:. 1K0-937-08x-65.clb
Component: RDK 103 0521
Coding: 018704
Shop #: WSC 25155 444 85637
Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
Coding: 0001168
VCID: 356BD5C55C3E96E23E-8060
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000330900915
Coding: 412100
VCID: 2A51F6B94580C91AA3-807E
End-------------------------(Elapsed Time: 02:43)--------------------------
-Robby
