VW Crafter eis
sergo
New Member
Serbia
hn1-013363 (2nd hand?)
Old eis sombody stolen from car not can not copy motorola.
Crafter eis new how to code with vcds .I can not login with 0000 .try to hold brake pedal.. wait 5 min....
i try with 50 chanel adaptation it say login need.
It can do on line only or sombody now procedure fro coding new eis.
And for elv adaptation is need or ?
thx a lot
PetrolDave
Westbury, UK
C?ID=1423
We'll need to see a full unedited VCDS Auto-Scan of your Crafter to understand what your problems are - see my sig for a link to a How-To
sergo
New Member
Serbia
i can not gave contact eis is new .It is crafter 2006 .Need information how to adapted eis new. i was think like old model login 00000 adaptation 50 chanel but can not login.
PetrolDave
Westbury, UK
C?ID=1423
This forum is to support owners/users of the VCDS diagnostic tool, so we need to see a VCDS Auto-Scan to be able to help you.
BTW what is eis? That means nothing to me...
sergo
New Member
Serbia
eis (electronic ignition switch) ok i must go 100 km to make auto scan
raf0468
C?ID=120244
crafter has a very similar or same immobilizer system platform as that is found on the mercedes sprinter, key,eis,elv, and engine ecu..
never had the opportunity to perform a task as yours on crafter but have done on the sprinter,
on the sprinter new eis ordered from dealer requires a green key , install eis and green key is prepared from dealer initiates the immobilizer data and programed in with scn coding with mercedes star diagnostic equipment..
crafter however dont use infared key it has a blade type so not sure what the setup is with them at vw dealer.
im sure if your using a donor used eis a good locksmith can extract key data from engine ecu and programme it to the new used eis, i dont think it will be possible with vcds..
ps.. anyone tell me where auto spell corection is in toolbar ,
