Evening RT
Another abs coding failure
ive attached the full scan, adv immo field eng field and cluster field as the car isnt with me no longer
tried a few combinations off my builders but no success
Auto scan
Immo
Instruments
Engine
Auto scan
Thursday,28,May,2020,19:16:42:12363
VCDS Version: 20.4.0.1 HEX-NET CB: 0.4508.4
Dealer/Shop Name: KB
Workshop Code: 444 12345 012345
VIN: VSSZZZ1PZ9R047270 License Plate: ND09ZXP
Mileage: 156460km-97219mi Repair Order:
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: VSSZZZ1PZ9R047270 Mileage: 156460km-97219miles
08-Auto HVAC -- Status: Cannot be reached 1100
17-Instruments -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 GQ HW: 03G 906 018 GQ
Component: R4 2.0l PPD1.2 G 4361
Revision: --H52--- Serial number: SEX7Z0I031D07Y
Coding: 0050072
Shop #: WSC 66565 257 00032
VCID: FAB88515B5EF9256CC-80AE
005488 - Engine Start Blocked by Immobilizer
P1570 - 008 - - Intermittent
Reset counter: 37
Torque: 0.0 Nm
0.00 %
Voltage: 11.75 V
Bin. Bits: 00011001
Bin. Bits: 00000000
Readiness: N/A
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Shop #: WSC 61398 001 1048576
VCID: F6A0912541F7F636A8-80A2
10 Faults Found:
Fault Status: 00100011
Fault Frequency: 19
Reset counter: 84
Mileage: 154964 km
Count: 16384
Count: 12800
Count: 69
Count: 52813
Count: 3
Fault Status: 00101100
Reset counter: 84
Mileage: 156074 km
Count: 3
Count: 12800
Count: 72
Count: 39936
Count: 1
Reset counter: 120
Count: 16384
Count: 12800
Count: 8208
Count: 43776
Count: 1
Count: 3328
Reset counter: 120
Count: 16384
Count: 12800
Count: 8211
Count: 43776
Count: 1
Count: 256
Reset counter: 120
Count: 16384
Count: 12288
Count: 8213
Count: 38656
Count: 1
Fault Status: 00100101
Reset counter: 79
Mileage: 267053 km
Count: 16391
Count: 8192
Count: 279
Count: 44032
Reset counter: 79
Mileage: 66051 km
Date: 2001.00.02
Time: 16:36:16
Count: 1800
Count: 83
Count: 21504
Count: 270
Count: 4864
Count: 17664
Count: 64
Count: 21505
Reset counter: 79
Date: 2030.00.00
Time: 18:03:10
Count: 1
Count: 5983
Count: 256
Count: 195
Count: 279
Count: 256
Count: 48504
Count: 288
Reset counter: 79
Mileage: 267053 km
Count: 16391
Count: 8192
Count: 166
Count: 44032
Fault Status: 01100101
Reset counter: 79
Mileage: 267053 km
Count: 16391
Count: 8192
Count: 291
Count: 44032
Address 08: Auto HVAC
Revision: 00H54000 Serial number: 00000005938742
Coding: 818A8F2F00041000431D00000000000000007F075C400000000000000000
Shop #: WSC 06403 785 00200
VCID: B3266831D205A31E4F-80E6
Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 111208 022 0601
Coding: 00056208
Shop #: WSC 06403
10 Faults Found:
Reset counter: 119
Mileage: 156308 km
Voltage: 10.90 V
Reset counter: 114
Mileage: 156365 km
Voltage: 12.30 V
Reset counter: 119
Mileage: 156360 km
Voltage: 11.10 V
Reset counter: 114
Mileage: 156365 km
Voltage: 12.10 V
Fault Status: 00101010
Reset counter: 119
Mileage: 131795 km
Voltage: 11.55 V
Reset counter: 119
Mileage: 131795 km
Voltage: 11.55 V
Reset counter: 119
Mileage: 156365 km
Voltage: 12.10 V
Reset counter: 114
Mileage: 156365 km
Voltage: 12.05 V
Reset counter: 119
Mileage: 156365 km
Voltage: 12.10 V
Reset counter: 114
Mileage: 156365 km
Voltage: 12.10 V
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__A03 VW10 HI 1815
Revision: 19013000 Serial number: 0039DP0F0WT/
Coding: 0012339
VCID: BB364011FA556B5E97-80EE
Subsystem 1 - Serial number: 6333FTS603110069
Subsystem 2 - Serial number: 6343FTS605130069
Subsystem 3 - Serial number: 6353ETS6BP1IV5KR
Subsystem 4 - Serial number: 6363ETS6O5HEV5KR
00532 - Supply Voltage B+
Reset counter: 83
Mileage: 149033 km
Time: 00:22:50
Reset counter: 119
Time Indication: 1
Veh. life cycle counter: 0
Part No SW: 1K0 953 549 BS HW: 1K0 953 549 BS
Component: J0527 752 0101
Coding: 0002042
VCID: 8444FBEDC72BD4A6A6-80D0
Component: E0221 001 0010
Part No: 1P0 920 947 G
Component: KOMBIINSTRUMENT VO3 1052
Coding: 0002401
Shop #: WSC 04768 067 57207
VCID: B73E5C21C67D4F3E73-80E2
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K08C0101DA
Coding: E9807F06000602000203
01304 - Radio
Reset counter: 80
Mileage: 156445 km
Time: 00:42:52
Reset counter: 79
Mileage: 156445 km
Time: 01:25:04
Reset counter: 119
Reset counter: 119
Component: IMMO VO3 1052
Shop #: WSC 24996 000 1048576
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1518
Revision: 71009005 Serial number: 00000254988612
Coding: 0004784
VCID: C0CC37FD93B30886C2-8094
Reset counter: 114
Reset counter: 82
Mileage: 156445 km
Reset counter: 119
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 142 2301
Revision: 00H15000
VCID: AA18755505CFE2D6FC-80FE
Fault Status: 00101101
Fault Frequency: 29
Reset counter: 94
Mileage: 156074 km
Time: 00:21:46
Voltage: 11.50 V
DD
Temperature: 7.0°C
Reset counter: 129
Voltage: 12.00 V
DD
Temperature: 15.0°C
Fault Status: 11100101
Battery Volts: 11.4 V
DD
Temperature: 16.0°C
Count: 3
Steering Angle: -23.84°
SteerAng Init
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 988000005283CC7F0006850560085F86107C00
VCID: 8346F8F1C225D39E9F-80D6
Subsystem 3 - Component: IRUE No Answer
Reset counter: 79
Mileage: 156445 km
Time: 01:25:04
Reset counter: 79
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1518
Revision: 71009005 Serial number: 00000505188717
Coding: 0004784
VCID: C1CA32F998B9018ECD-8094
01553 - Motor for Central Locking; Passenger Door (V57); Lock
Reset counter: 88
Mileage: 138912 km
Fault Status: 00111000
Reset counter: 103
Mileage: 130341 km
Reset counter: 82
Mileage: 156445 km
Reset counter: 119
Address 56: Radio
Part No SW: 1K0 959 703 AF HW: 1K0 959 795 S
Component: J388 TUER-SG HL 1401
Revision: 11006001 Serial number: 00000003604987
Coding: 0000144
VCID: F4A4AB2D978BE42696-80A0
Part No SW: 1K0 959 704 AF HW: 1K0 959 794 S
Component: J389 TUER-SG HR 1401
Revision: 11006001 Serial number: 00000003730275
Coding: 0000144
VCID: F5A296299CF1FD2EA1-80A0
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 5P0 862 335 B HW: 5P0 862 335 B
Component: FSE_2P5x H30 0110
Revision: 00000001 Serial number: 00000005059211
Coding: 0000555
VCID: B2286D352D1FAA1644-80E6
Reset counter: 119
01304 - Radio
Reset counter: 80
Mileage: 156445 km
Time: 00:01:11
End----------(Elapsed Time: 01:31, VBatt start/end: 12.7V/12.7V)-----------
Immo
Thursday,28,May,2020,19:58:05:12363
VIN: VSSZZZ1PZ9R047270 License Plate: LEON ADV IMMO
Control Module Part Number: 1P0 920 947 G
Component and/or Version: IMMO VO3 1052
Software Coding:
Work Shop Code: WSC 24996
Misc.
VCDS Info:
Instruments
Thursday,28,May,2020,19:59:12:12363
VIN: VSSZZZ1PZ9R047270 License Plate: LEON INST ADV
Component and/or Version: KOMBIINSTRUMENT VO3 1052
Software Coding: 0002401
Work Shop Code: WSC 04768
Flash Status
Programming Attempts: 0
Successful Attempts: 0
Programming Status: 00000000
Required Conditions: 00000000
Misc.
VCDS Info:
Engine
Thursday,28,May,2020,19:57:19:12363
VIN: VSSZZZ1PZ9R047270 License Plate: ENGINE LEON ADV
Address 01: Engine
Control Module Part Number: 03G 906 018 GQ
Component and/or Version: R4 2.0l PPD1.2 G 4361
Software Coding: 0050072
Work Shop Code: WSC 66565
Advanced Identification
Identification: SJ8-FST
Revision: --H52---
Date: 14.06.08
Test stand number: 0415
Manufacturer number: 0116
Flash Status
Programming Attempts: 2
Successful Attempts: 4
Misc.
Hardware number: 03G 906 018 GQ
Immo Challenge: 1C 40 22 AD
Car Info
Chassis Number: VSSZZZ1PZ9R047270
VCDS Info:
Readiness: No script available
