2006 Passat 3C Sedan diesel Climatronic issue
Shawa12002
Victoria, Australia
C?ID=370869
Hello all, this is my second post and the first question is how do I find my previous post after 3 weeks?
Now, I bought a passat diesel with a transmission fault. I have resolved the issue but apparently my climatronic system is not working. I went through the first auto-scan results before trans fix it was ok, but now zero.
the other weird thing is If I plug in a CC module it works but not properly. I have tried 4 other modules but non of them work. I have reason to believe I disturbed something. The unfortunate thing is I cannot find the pinout for my original 3 dial controller. I tried eWin but the module shown is the later one which is the cc one.
Can my CC climatronic module be coded or some adaptation be done for full functionality? I don't know how to create a url link to my images yet but I have attached links to similar modules. the one with 3 dials being my Og and the the 2 dial one being the
Or is there a procedure that I'm missing with my original module?
https://images.app.goo.gl/KwdX91EfRy8LEjeGA
https://images.app.goo.gl/57fqnKVk31hCxjwd9
Orignal Scan:
Self-Diagnosis Log
Tuesday,21,April,2020,19:50:43:41695
Page 5
VIN: WVWZZZ3CZ7P046973 License Plate:
Mileage: 144473 km
Date: 2020.04.16
Time: 07:49:29
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0667841377
Coding: 0015653
Shop #: WSC 00028 028 00001
VCID: 322814D0AD8DBE16C4-8066
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AH HW: 3C0 907 044 AH
Component: ClimatronicPQ46 050 0505
Revision: 00050005 Serial number: 00000000000000
VCID: 679EB58456CF0BBEA3-8032
Scan after trans fix:
Monday,25,May,2020,17:54:55:41695
VCDS Version: 20.4.0.1 (x64)  HEX-NET CB: 0.4508.4
VIN: WVWZZZ3CZ7P046973   License Plate: SCAN W ORIGINAL CONTROLLER
Mileage: 145010km-90105mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 76
VIN: WVWZZZ3CZ7P046973   Mileage: 145010km-90105miles
08-Auto HVAC -- Status: Cannot be reached 1100
Address 01: Engine        Labels: 03G-906-018-BKP.clb
   Part No SW: 03G 997 020 T    HW: 03G 906 018 CE
   Component: R4 2.0l PPD1.5 G    5159
   Revision: --H25---    Serial number: VWZCZ000000000
   Coding: 0000078
   Shop #: WSC 30024 959 101054
   VCID: 393A23FC70FB4D4E05-806C
005685 - Powertrain Data Bus
               P1635 - 009 - Missing Message from A/C Controller
                    Reset counter: 40
                    Mileage: 145016 km
                    Date: 2020.04.23
                    Time: 05:51:02
                    RPM: 768 /min
                    Torque: 32.0 Nm
                        0.00 %
                    Voltage: 13.79 V
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
Readiness: N/A
   Part No SW: 02E 300 042 S    HW: 02E 927 770 AE
   Component: GSG DSG         070 1127
   Revision: 04507000    Serial number: 00000607260992
   VCID: 2306E194E277279E3F-8076
   Coding: 0015653
   Part No SW: 3C0 937 049 J    HW: 3C0 937 049 J
   Component: Bordnetz-SG     H37 1301
   Revision: 00H37000    Serial number: 00000004316264
   Coding: E0808F0700041A00000A00000F00000000085D435C0000
   VCID: 302C1ED8A3818C06B2-8064
   Subsystem 1 - Part No: 3C2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00063445
   Shop #: WSC 00028
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     260706 014  1201
   Coding: 00208933
   Shop #: WSC 00028
                    Reset counter: 12
                    Mileage: 145016 km
                    Date: 2020.04.23
                    Time: 05:50:00
                    Voltage: 13.95 V
   Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
   Component: 16 AIRBAG VW8R  029 2521
   Revision: 10029000    Serial number: 003A3PDYSKKR
   Coding: 0012598
   VCID: 2E1000A0B9B59AF6A0-807A
   Subsystem 1 - Serial number: 6332MSME123C756EL
   Subsystem 2 - Serial number: 6342MSME123B0E5DL
   Subsystem 3 - Serial number: 6351HTS6PLL6CPN2F
   Subsystem 4 - Serial number: 6361HTS6VARQ8552
   Part No SW: 3C0 953 549 E    HW: 3C0 953 549 E
   Component: J0527               0015
   Revision: 00007000    Serial number: 3C5953507P
   Coding: 0001111
   Part No SW: 3C0 920 871     HW: 3C0 920 871
   Component: KOMBIINSTRUMENT VD1 1614
   Revision: X0006000    Serial number: 00000000000000
   Coding: 0007705
   Shop #: WSC 00921 001 1048576
   VCID: 618AAB9CB8EB758E6D-8034
Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 Q    HW: 3C0 907 951
   Component: J533  Gateway   H13 0172
   Revision:   H13       Serial number: 3620P10126061A
   Coding: FD807F0E000202000003
   Shop #: WSC 30024 959 101032
   VCID: 2F2E1DA4BEBF93FEAB-807A
                    Reset counter: 12
                    Mileage: 145016 km
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   Subsystem 1 - Part No: 3C0 905 861 F
   Component:    ELV          026 0380
   3C0905861F     ELV          026 0380
   Component: J386  TUER-SG FT    1124
   Revision: 12006001    Serial number: 00000514168804
   Coding: 0000693
   VCID: 3B3639F47AC77F5E17-806E
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.136 H07 1806
   VCID: 35222FCC5CE3A92EE1-8060
   Component:    KSG PQ46 ELV 042 0472
   Coding: 00910A0001860E763004941570085F0B007800
   Shop #: WSC 30024 959 88134
                    Reset counter: 12
                    Mileage: 145016 km
                    Date: 2020.04.23
                    Time: 05:50:08
   Component: J387  TUER-SG BT    1124
   Revision: 12006001    Serial number: 00000508968729
   Coding: 0000692
   VCID: 3C343AE87FC978661E-8068
   Revision:   013
   Coding: 0000012
   VCID: 210AEB9CF86B358E2D-8074
   Part No SW: 5K0 035 190     HW: 5K0 035 190
   Component: Radio RCD510  041 0167
   Revision: 00000001    Serial number: VWZ1Z3L5186785
   Coding: 0100040004
   VCID: 6288A4907DED6E9674-8036
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1113
   Revision: 11005001    Serial number: 00000000425747
   Coding: 0000144
   VCID: 3D3237EC64D3716E29-8068
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1113
   Revision: 11005001    Serial number: 00000000524430
   Coding: 0000144
   VCID: 3E3030E069D56A7630-806A
Address 76: Park Assist        Labels: 3C0-919-283.lbl
   Part No SW: 3C0 919 283 B    HW: 3C0 919 283 B
   Component: Parkhilfe 8-Kan 004 0011
   Revision: 00004000    Serial number: 82930622903028
   Coding: 0001014
   VCID: 281CF6B89B51C4C66A-807C
End----------(Elapsed Time: 01:36, VBatt start/end: 14.0V/14.0V)-----------
Address 01: DTCs cleared
Scan with my 2009 CC Climatronic module:
Monday,25,May,2020,18:06:01:41695
Chassis Type: 3C-VW46 (3C0)
   Coding: 0000078
Readiness: N/A
   Coding: 0015653
   Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000001002
   Shop #: WSC 00066 000 00187
   VCID: 7EB0F0E0E155AA7670-802A
13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                    Reset counter: 12
                    Mileage: 145016 km
                    Date: 2020.04.23
                    Time: 06:01:51
          B10A4 15 [009] - Open or Short to Plus
                    Reset counter: 12
                    Mileage: 145016 km
                    Date: 2020.04.23
                    Time: 06:01:51
   Coding: 00063445
   Shop #: WSC 00028
   Coding: 00208933
   Shop #: WSC 00028
   Coding: 0012598
   Coding: 0001111
   Coding: 0007705
   Coding: 0000693
   Coding: 0000692
   Revision:   013
   Coding: 0000012
   Coding: 0100040004
   Coding: 0000144
   Coding: 0000144
   Coding: 0001014
End----------(Elapsed Time: 01:19, VBatt start/end: 14.1V/14.1V)-----------
   Coding: 0000078
Readiness: N/A
   Coding: 0015653
   Revision: 00003001
   Coding: 0000001002
          U1111 00 [009] - -
                    Reset counter: 12
                    Mileage: 145016 km
                    Date: 2020.04.23
                    Time: 06:01:51
                    Reset counter: 12
                    Mileage: 145016 km
                    Date: 2020.04.23
                    Time: 06:01:51
   Coding: 00063445
   Shop #: WSC 00028
   Coding: 00208933
   Shop #: WSC 00028
   Coding: 0012598
   Coding: 0001111
   Coding: 0007705
   Coding: 0000693
   Coding: 0000692
   Revision:   013
   Coding: 0000012
   Coding: 0100040004
   Coding: 0000144
   Coding: 0000144
   Coding: 0001014
End----------(Elapsed Time: 01:20, VBatt start/end: 14.1V/14.1V)-----------
Click on your username, then in the popup that appears click on "View Forum Posts" ;)
