Hi there. First post aswell. Usually a lurker and researcher before posting.
So i have an A7 4G that came without the trailer hitch. Recently bought a house, realized i need to often move stuff around.
I Bought the kufatec wiring, got myself the control module, and have the trailer hitch ready to be installed.
Before installing anything i pulled all the wires and tried to code it, just to make sure i wouldnt get stuck.
I followed this guide: http://wiki.ross-tech.com/wiki/index.php/Trailer_Hitch_Retrofitting_(4F)
but im unsure how to code a few certain stuff.
Here is my original code of my vehicle before coding anything:
This is what i managed to code based on my knowledge:
engine 01: Byte 5 Bit 4
abs 03: didnt code anything
level control 34: byte 2 bit 0
parking aid 76: byte 0 bit 0-1: 02
rear view camera 6c: Byte 8 bit 0-7: 01
3c: didnt code anything
13: didnt code anything
Here is the log based on that:
I need some help with the other parts. What should i input. Because while entering those modules i didnt find any checkboxes like the other modules
As of right now ive put everything back to original state until ill do the convertion.
Wednesday,13,May,2020,16:35:32:56015
VCDS Version: 19.6.2.2 HEX-V2 CB: 0.4508.4
VIN: WAUZZZ4G1CN039757 License Plate:
Mileage: 151390km-94069mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 20 22 28 34 3B 3C 42
44 46 47 52 53 55 56 5F 62 6C 6D 72 82 85 8B 8E 8F 90
VIN: WAUZZZ4G1CN039757 Mileage: 151390km-94069miles
Address 01: Engine (J623-CDUC) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 401 F HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0004
Revision: 53H37---
Coding: 1A25401A046601020000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TDI0114G0907401F 001004
ROD: EV_ECM30TDI0114G0907401F.rod
VCID: 2615F141586AA1C7939-8072
Part No SW: 4G1 927 156 B HW: 0B5 927 156 F
Component: 0B5 30 TDIRdW H10 0006
Revision: --H10--- Serial number: 0000000941
ASAM Dataset: EV_TCMDL501 A02206
ROD: EV_TCMDL501.rod
VCID: 2C01036946869B9745D-8078
Part No SW: 4G0 907 379 G HW: 4G0 907 379 G
Component: ESP PREMIUM H09 0250
Coding: 27B6C703E46DE3C0DB00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004017
VCID: 3537260D95CCDA5F2A3-8060
Part No SW: 4H0 907 064 BP HW: 4H0 907 064 BP
Component: BCM2 2.0 H31 0330
Coding: 05AA2F00000000000000
VCID: 78A9EF39C2DEE737F15-802C
Part No SW: 4G0 820 043 K HW: 4G0 820 043 K
Component: KLIMA 4 ZONEN H11 0062
Serial number: 08081100040240
Coding: 361300783C
ASAM Dataset: EV_AirCondiComfoUDS 002033
VCID: 270BFC455F60B8CFA8F-8072
Part No SW: 4H0 907 063 BP HW: 4H0 907 063
Component: BCM1 2.0 H12 0111
Revision: 11012002 Serial number: 00000001418953
Coding: 0D07A01109768FE2E981008320001800CF9CC3082E080101000108452F01
VCID: 77ABEC05CFC0E84FF8F-8022
Component: WWS57X 110717 H35 0051
Serial number: 110719153753
Coding: 0045F7
Component: RLS H04 0003
Serial number: 11587830
Coding: 02562B
Subsystem 3 - Part No SW: 4G0 941 531 G HW: 4G0 941 531 G
Component: E1 - LDS H07 0044
Serial number: 14 07 2011 00000015
Subsystem 4 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A31 LED Mod1L H02 0002
Serial number: 00000000001908280778
Subsystem 5 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A27 LED Mod1R H02 0002
Serial number: 00000000001908280784
Component: AQ_Hum_Sensor H02 0002
Serial number: CE280DB5000000000001
Address 10: Park/Steer Assist (J791) Labels:| 4H0-919-475-7X5.clb
Part No SW: 4H0 919 475 M HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0025
Revision: -------- Serial number: 56261119403836
Coding: A82B04
ASAM Dataset: EV_EPHVA2CAU57X0000 002008
ROD: EV_EPHVA2CAU57X0000.rod
VCID: 3C213329B6E60B17D5D-8068
Part No SW: 4G0 907 561 HW: 4G0 907 561
Component: ACC3 H15 0160
Coding: 3E04010201
ASAM Dataset: EV_AdaptCruisContrAU57X 001003
ROD: EV_AdaptCruisContrAU57X_001.rod
VCID: 678BBC459FE078CF68F-8032
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG003L1V8
Coding: 30314530323130303038554A304C34473853
VCID: 3635210188CAD147239-8062
Serial number: 3575HRB404T0NLV28GMK
Serial number: 3585HRB405V0H9222OQQ
Serial number: 3515JRB405R0LCOQN1IH
Serial number: 3525JRB40570KOIA68CE
Serial number: 3554VRB405N0JL5IAP01
Serial number: 3564VRB405P0JL5I3HK9
Revision: -------- Serial number: 90372KGP000FI
Coding: 0000FC
VCID: 372B2C058F40284F38F-8062
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H07 0009
Serial number: 12 04 2011 11126394
Part No SW: 4G8 920 931 J HW: 4G8 920 931 J
Component: TDieRdwAcc H71 0375
Revision: 26181114 Serial number: 658040811593036
Coding: 13870102DF070008000100
ASAM Dataset: EV_RBD4K 004040
ROD: EV_RBD4K_AU57.rod
Address 18: Aux. Heat (J364) Labels:. 8R0-265-105.clb
Part No SW: 4H0 265 105 E HW: 4H0 265 105 E
Component: Standheizung H24 0250
Revision: 66006006 Serial number: 20110713222446
Coding: 5D3B00
VCID: 2411EB492ED653D78DD-8070
Part No SW: 4G0 907 468 E HW: 4G0 907 468 A
Component: J533--Gateway H08 0213
Revision: -------- Serial number: 00000000216671
Coding: 00CD077D00
ROD: EV_GatewUDS_AU57.rod
VCID: 323D1D1164A2CD670F1-8066
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650178326
Voltage stabilizer:
Serial number: 11211001925011200410
Part No SW: 8K0 857 511 E HW: 8K0 857 511 A
Component: FLA H04 0004
Revision: AA001002
Coding: 04019864747464545425363E
Shop #: WSC 06325 123 12345
VCID: 333318159B38C46F047-8066
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
Component: 4 Wheel Drive H14 0013
Serial number: 001407110001000
ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0062
Serial number: 07081100040387
Coding: 01
ASAM Dataset: EV_ClimaContrUnitRearUDS 002015
VCID: 2F3B14657790E08F60F-807A
Part No SW: 4G0 907 553 C HW: 4G0 907 553
Component: LUFE-DAEMPFER H17 0779
Coding: 008002
ROD: EV_AirSuspe_VW51.rod
VCID: 2B03007543889CAF4C7-807E
Part No SW: 4G0 907 637 C HW: 4G0 907 637 C
Component: SARA 6D red H02 0004
Revision: -------- Serial number: EJ1BPA3E004HSH0
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2E050961709AE9876B9-807A
Part No SW: 4G0 907 566 J HW: 4G0 907 566
Component: J769 SWA MasterH01 0030
Revision: 00H01000 Serial number: 6PZ 010 287-08
Coding: 0000107
VCID: 36352101844AD147239-8062
Subsystem 1 - Part No: 4G0 907 568 J
Component: J770 SWA Slave H01 0030
Subsystem 2 - Serial number: 6PZ 010 287-28
Subsystem 3 - Serial number: 5F15.07.1100H010003CZ21515ÿ
Subsystem 4 - Serial number: Z21515ÿ
Part No SW: 4G8 959 793 D HW: 4G8 959 793
Component: TSG FA H05 0212
Coding: 011F56225000628002080413
VCID: 41DF42DDD18466FF86B-8014
Part No SW: 4G0 909 144 AA HW: 4G0 909 144 G
Component: RCEPS H33 0013
Revision: 00001000 Serial number: 0029130003
Coding: 101101010000
ASAM Dataset: EV_RCEPS 009013
ROD: EV_RCEPS_009.rod
VCID: 6889BF7992FE77B7615-803C
Revision: 00002001 Serial number: 0155199225
Coding: 01000E2020B9B48583200A840E0100000000000000000000000000000000
Subsystem 1 - Part No SW: 7P5 959 591 HW: 4H0 959 591
Component: J245 PS40.033 H07 0006
Serial number: WOO1290025-
Coding: 001F00
Subsystem 2 - Part No SW: 4G0 947 135 F HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00000369549
Subsystem 3 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H09 0027
Serial number: WA101934000000419057
Part No SW: 4G0 035 223 B HW: 4G0 035 223 A
Component: BOSE G3 C7 H07 0130
Revision: CJ007000 Serial number: 00000000015068
Coding: 030000
VCID: 1C61D3A916A66B1735D-8048
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
Coding: 011F56225000628002080402
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000118178
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A0D05714C7285A7B71-807E
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 140403-0002-189
Coding: 11236F631002EB00
ROD: EV_HeadlRegulBasic.rod
VCID: 2D070E6D7D9C929F523-8078
Part No SW: 4G1 035 053 J HW: 4G1 035 053
Component: Radio U Basic H41 0133
Revision: AB001007 Serial number: 049G40BB011999
Coding: 010003010000000001
VCID: 2615F14158EAA1C7939-8072
Part No SW: 4G0 035 670 Q HW: 4G0 035 670
Component: H-BNT-EU H47 1034
Revision: -------- Serial number: 428HW0B7521018
Coding: 090100040003FFEF3D30CF3E00000003080001000000000000
VCID: 313F121D6124F67F76B-8064
Subsystem 1 - Part No: 8R0 060 884 FK
Component: EUR 2018/2019 2702
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB13012G81
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 A
Component: E380 BDT C7 H08 0204
Serial number: 90349KH50004I
Subsystem 4 - Part No: 8R0 060 961 B
Component: CD-Database 3371
03623 - Invalid Security/Release Code
Reset counter: 254
Mileage: 151390 km
Date: 2020.05.13
Time: 16:30:09
Hex Value: 0x0004
Hex Value: 0x000B
Count: 6
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010F14224000628002080002
VCID: 44D14BC9CE9673D7ADD-8010
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4H0 907 428 A HW: 7P6 907 441 D
Component: TopView H05 0150
Revision: 11001001 Serial number: 82330JF0100638
Coding: 0205000001010100000102000000
Shop #: WSC 19546 123 104857
ASAM Dataset: EV_CamerSysteTopViewAUDI 006025
ROD: EV_CamerSysteTopViewAUDI_005_AU64.rod
Part No SW: 4G8 959 107 N HW: 4G8 959 107 F
Component: HDSG-Modul H13 0039
Revision: 11013001 Serial number: 194100206
Coding: 0A3305C002
ASAM Dataset: EV_HDSGAu573 001014
ROD: EV_HDSGAu571.rod
VCID: 40D947D9DA0E6FF7895-8014
Component: TSG HR H04 0212
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4G8 919 604 D HW: 4G8 919 604 D
Component: HeadUpDisplay 007 0103
Coding: 4F0000
ASAM Dataset: EV_HUDContiC7 001020
ROD: EV_HUDContiC7.rod
VCID: 34311B099EB6C3571DD-8060
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H24 0034
Coding: EA060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 6597B64D65EC6ADF5A3-8030
Part No SW: 4G0 907 541 HW: 4G0 907 541
Coding: 3E04010201
ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
ROD: EV_AdaptCruisContr2AU57X_001.rod
Part No SW: 4G0 907 107 B HW: 4H0 907 107
Component: BV-SG H29 0034
Serial number: 000040182807117
Coding: 03C0BB1A1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 2517F64D256CAADF9A3-8070
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 0066E608031F037E070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 6FBBD465B710A08F20F-803A
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70B9D719AA2EBF77395-8024
End----(Elapsed Time: 02:35, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
Wednesday,13,May,2020,15:52:06:56015
VIN: WAUZZZ4G1CN039757 License Plate: BS89456
44 46 47 52 53 55 56 5F 62 69 6C 6D 72 82 85 8B 8E 8F 90
Revision: 53H37---
Coding: 1A25401A047601020000
Coding: 361300783C
Coding: 0045F7
Coding: 02562B
Coding: B82B04
Coding: 3E04010201
87552 - Control Module Incorrectly Coded
U1014 00 [009] - -
[FAULT_CIS_CONFIG_AAG]
Reset counter: 254
Mileage: 151390 km
Date: 2020.05.13
Time: 15:39:49
Control Module temperature: 13 °C
Voltage terminal 15: 11.936 V
Velocity_vehicle_reference: -0.01 m/s
Coding: 0000FC
Coding: 5D3B00
Coding: 00CD077D00
Voltage stabilizer:
5729 - No Communication with Towing System Control Module (J345)
U1003 00 [008] - -
Reset counter: 39
Mileage: 151390 km
Date: 2020.05.13
Time: 15:34:12
Voltage terminal 30: 11.9 V
Voltage terminal 15: 11.8 V
Control Module temperature: 21 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
Revision: AA001002
Coding: 01
Coding: 008002
267264 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 254
Time: 00:00:00
Coding: 0000107
Coding: 001F00
Coding: 030000
Reset counter: 254
Mileage: 151390 km
Date: 2020.05.13
Time: 15:34:14
Hex Value: 0x0004
Hex Value: 0x000B
Count: 6
Address 69: Trailer (J345) Labels:. 4G8-907-383-V1.clb
Part No SW: 4G8 907 383 HW: 4G8 907 383
Component: Anhaenger H11 0100
Revision: 5G001001 Serial number: 00000192806040
Coding: 0109080000000000
VCID: 71BFD21DA1A4B67F36B-8024
01316 - ABS Control Module
Reset counter: 39
Mileage: 72035 km
Date: 2016.05.28
Time: 02:45:46
02778 - Locking Bolt Contact Switch (F355)
Fault Status: 01101011
Reset counter: 157
Shop #: WSC 19546 000 1048576
Coding: 0A3305C002
Coding: 4F0000
Coding: EA060000
Coding: 3E04010201
U1014 00 [009] - -
Reset counter: 254
Mileage: 151390 km
Date: 2020.05.13
Time: 15:39:49
Voltage terminal 15: 11.910 V
Velocity_vehicle_reference: -0.00 m/s
ROD: EV_BC7.rod
ROD: EV_RGS_L.rod
ROD: EV_RGS_R.rod
End----(Elapsed Time: 02:39, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Wednesday,13,May,2020,16:18:49:56015
Revision: 53H37---
Coding: 361300783C
Coding: 0045F7
Coding: 02562B
Coding: AA2B04
Coding: 3E04010201
U1014 00 [009] - -
Reset counter: 254
Mileage: 151390 km
Date: 2020.05.13
Time: 16:10:21
Voltage terminal 15: 11.734 V
Coding: 0000FC
Coding: 5D3B00
Coding: 00CD077D00
Voltage stabilizer:
Revision: AA001002
Coding: 01
Coding: 008003
Coding: 0000107
Coding: 001F00
Coding: 030000
Reset counter: 254
Mileage: 151390 km
Date: 2020.05.13
Time: 16:10:22
Hex Value: 0x0004
Hex Value: 0x000B
Count: 6
Reset counter: 254
Mileage: 151390 km
Date: 2020.05.13
Time: 16:10:19
Coding: 0205000001010100010102000000
Coding: 0A3305C002
Coding: 4F0000
Coding: EA060000
Coding: 3E04010201
U1014 00 [009] - -
Reset counter: 254
Mileage: 151390 km
Date: 2020.05.13
Time: 16:10:21
Control Module temperature: 22 °C
Voltage terminal 15: 11.705 V
ROD: EV_BC7.rod
ROD: EV_RGS_L.rod
ROD: EV_RGS_R.rod
End----(Elapsed Time: 02:40, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
