2013 Passat Trendline TDI ABS Coding (MK60EC1)
TECHAUTO
CANADA
C?ID=93352
Swapped ABS module because of no communication, could someone please help with the procedure for coding in the new one?
Monday,11,May,2020,16:02:18:57402
VCDS Version: 20.4.0.1 (x64)
VIN: 1VWAN7A36DC063189   License Plate:
Mileage: 113690km-70643mi   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
VIN: 1VWAN7A36DC063189   Mileage: 113690km-70643miles
Address 01: Engine (J623-CKRA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 997 009 J    HW: 03L 907 309 S
   Component: R4 2.0l TDI   H21 9982
   Revision: 71H21---    Serial number:
   Coding: 001D0012842400000000
   Shop #: WSC 99909 999 00000
   ASAM Dataset: EV_ECM20TDI01103L997009J 004005
   ROD: EV_ECM20TDI01103L997009H.rod
   VCID: 3B7EC825B2859A5E17-806E
   Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 9436
   Revision: 05551213    Serial number: 00001207070035
   Shop #: WSC 09003 957 00200
   VCID: 244C1359E73BC5A646-8070
   Revision: 00H31001
   Shop #: WSC 00066 000 00000
   VCID: 7DFA063DE411546E69-8028
                    Reset counter: 88
                    Date: 2020.05.11
                    Time: 11:22:11
                    Count: 3
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 49664
                    Count: 7936
                    Fault Status: 01100101
                    Reset counter: 88
                    Mileage: 113697 km
                    Date: 2020.05.11
                    Time: 11:22:03
                    Count: 3
                    Count: 14
                    Count: 29184
                    Count: 279
                    Count: 49408
                    Count: 7936
                    Reset counter: 88
                    Mileage: 113697 km
                    Date: 2020.05.11
                    Time: 11:22:03
                    Count: 3
                    Count: 14
                    Count: 29184
                    Count: 295
                    Count: 49408
                    Count: 7936
   Part No SW: 561 907 044 M    HW: 561 907 044 M
   Component: Climatronic   H03 0404
   Revision: 00001K01
   Coding: 0030001002
   VCID: 21421A4D3029D08E2D-8074
   Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
   Component: BCM PQ35 H+   121 0168
   Revision: BL121001
   Coding: 6F200E18902B08D408880001160085480071008640801560648060000C70
   VCID: 74EC2319D75B152616-8020
                    Reset counter: 126
                        Term 15 Off
                    Voltage: 8.60 V
00956 - Key 2
                    Reset counter: 86
                    Mileage: 113697 km
                    Date: 2020.05.07
                    Time: 16:23:06
                        Term 15 On
                    Voltage: 11.75 V
01316 - ABS Control Module
                    Reset counter: 127
                    Mileage: 113697 km
                    Date: 2020.05.07
                    Time: 16:23:06
                        Term 15 On
                    Voltage: 11.70 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 86
                    Mileage: 113697 km
                    Date: 2020.05.07
                    Time: 16:27:24
                        Term 15 On
                    Voltage: 13.65 V
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   013 0809
   Serial number: 003ENM04PS8+
   Coding: 00003548
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FE62C75B67D36FEEB-803A
   Serial number: 6940000Y120000KY3K04
   Coding: 303045
   Serial number: 3572MSME716D0275ZZZY
   Serial number: 3582MSME2F645074ZZZ.
   Serial number: 3516KSME0323641FZZZN
   Serial number: 3526KSME6310721FZZZP
   Serial number: 3556LSME6E026E1EZZZ8
   Serial number: 3566LSME44566A1EZZZ2
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Revision: FF010041    Serial number: 20120912100218
   Coding: 088A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 76E81911C927073628-8022
   Component: E221__MFL-YVJ  H07 0022
   Coding: E20000
Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
   Part No SW: 561 920 870 C    HW: 561 920 870 C
   Component: KOMBI         H07 0705
   Coding: 331E01
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
   VCID: 193232AD1879884EE5-804C
   Part No SW: 7N0 907 530 T    HW: 7N0 907 530 K
   Component: J533  Gateway H40 1632
   Revision:   H40       Serial number: 05111101290746
   Coding: 461000
   VCID: 4182BACDD869F08E4D-8014
   Part No SW: 561 919 965     HW: 561 919 965
   Component: Kompass         002 0001
   Revision: 00002000    Serial number: 1829227R2YXB06
   VCID: 63CE5045A2B5829E7F-8036
   Component: IMMO          H07 0705
   VCID: 6AD03D618D9FD3D6BC-803E
   Part No SW: 561 959 701     HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0525
   Revision: 13110009    Serial number: 0005649573
   Coding: 0404F5
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BBE68A552C5BA5E37-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
          B11EC 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 128
                    Mileage: 113697 km
                    Date: 2020.05.11
                    Time: 10:37:25
67330 - Switch for Central Locking
          B122D 29 [008] - Signal Implausible
                    Reset counter: 127
                    Mileage: 113697 km
                    Date: 2020.05.11
                    Time: 10:54:01
          B11EE 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 87
                    Mileage: 113697 km
                    Date: 2020.05.11
                    Time: 10:37:25
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 290    3305
   Revision: 00H22000
   VCID: 3776D41546ADBE3EF3-8062
   Part No SW: 7N0 907 532     HW: 7N0 907 530 K
   Component: EZE_2         H40 1632
   Coding: 00000008
   VCID: 6FE62C75BE7D36FEEB-803A
   Subsystem 1 - Part No SW: 561 919 204 B    HW: 561 919 204 B
   Component: Analoguhr  008 0005
   Part No SW: 561 959 702     HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0525
   Revision: 15110009    Serial number: 0005558305
   Coding: 0404F4
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CBC6BB957CBBD663E-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
                    Reset counter: 87
                    Mileage: 113697 km
                    Date: 2020.05.11
                    Time: 10:37:30
   Part No SW: 1K0 035 164 D    HW: 1K0 035 164 D
   Component: LOW NAR       H02 0006
   Revision: -----06S    Serial number: VWZ4Z6M3451118
   Coding: 0500040002000B
   VCID: 234E10452235C29E3F-8076
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007663390184
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A70CD21BDBFA3560C-806E
End-------------------------(Elapsed Time: 02:41)--------------------------
DrPeter
16.4905° S, 151.7375° W
Just in case you do not have the ABS coding, based on the VIN should it should be as follows:
C54BC0F5492800FDA30C03EC92220042271000
We have a Ross-Tech forum post that explains the ABS Coding and the Basic Settings:
MK60EC1 ABS FAQ - In the "How-To's and Tips".
Hope this helps,
drpeter
