2006 Passat 2.0 TMPS
akitchens
C?ID=273674
I have had the low tire pressure light on the car for some time now. Even after checking the air and getting new tires, still giving me issues. So I went online to RockAuto and bought 4 new TPMS sensors and had discount tire install them. They told me they couldn’t learn them to the car cause it was not their product. So I took it home and used a TMPS tool I have to program. None of the tires found the 315mhz signal. Am I doing something wrong? I’ve tried pressing the ESP button and nothing happens.
Anyone have any good pointers?
Thank you
akitchens
C?ID=273674
Here is the Autoscan. I found how to disable the TPMS but I would like to fix the issue.
Thursday,23,April,2020,12:08:21:59102
VIN: WVWEK73CX6P187147   License Plate:
Mileage: 217450km-135117mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 65
          72
VIN: WVWEK73CX6P187147   Mileage: 217450km-135117miles
   Part No SW: 3C0 907 115 F    HW: 3C0 907 115 F
   Revision: --H14---    Serial number: VWZCZ000000000
   Coding: 0404010A19070160
   Shop #: WSC 25129 444 64221
   VCID: 2313E981D7DB95FFF45-8076
   Part No SW: 09G 927 750 HJ    HW: 09G 927 750 CJ
   Component: AQ 250 6F           1068
   Revision: 00H38000    Serial number:
   Coding: 0000072
   VCID: 0059860D660D6EE7C97-8054
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 Q    HW: 3C0 614 095 Q
   Component: ESP 440 C2     H015 0003
   Revision:  H015       Serial number: 0667269566
   Coding: 0013755
   Shop #: WSC 00028 028 00001
   VCID: 303916CD962D3E67797-8064
                    Fault Status: 00101101
                    Fault Frequency: 9
                    Reset counter: 60
                    Mileage: 217299 km
                    Date: 2020.03.24
                    Time: 18:05:55
   Part No: 1K0 820 047 EC
   Component: Climatic PQ35   090 0505
   VCID: 698FBBA975778FAF7E9-803C
   Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
   Revision: 00H52000    Serial number: 00000000602253
   Coding: 14058E234004150007140000001400000008730B5C0000
   VCID: 6B83C1A17F8B9DBF0C5-803E
   Subsystem 1 - Part No: 3C1 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer VW461 001   0101
   Coding: 00063445
                    Fault Status: 01101100
                    Reset counter: 28
                    Mileage: 216110 km
                    Date: 2020.01.27
                    Time: 10:36:00
                    Voltage: 12.60 V
00156 - Control Circuit for Windshield Washer Pump
                    Fault Status: 00101001
                    Fault Frequency: 23
                    Reset counter: 63
                    Mileage: 216110 km
                    Date: 2020.01.27
                    Time: 10:30:00
                    Voltage: 14.40 V
02399 - Control Circuit for Terminal 30 for Interior Illumination
                    Fault Status: 01111001
                    Reset counter: 28
                    Mileage: 216110 km
                    Date: 2020.01.27
                    Time: 10:36:00
                    Voltage: 12.45 V
00059 - Terminal 30 for Interior Lighting
                    Reset counter: 28
                    Mileage: 216110 km
                    Date: 2020.01.27
                    Time: 10:30:00
                    Voltage: 14.40 V
00975 - Heated Rear Window (Z1)
                    Fault Status: 00100110
                    Fault Frequency: 6
                    Reset counter: 49
                    Mileage: 216437 km
                    Date: 2020.02.15
                    Time: 06:50:00
                    Voltage: 14.15 V
   Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
   Component: SDAR XM         H03 0080
   Revision: 00000000    Serial number: AUZ4Z7E0040619
   VCID: 2B0301A1BF0B5DBF4C5-807E
                    Reset counter: 48
                    Mileage: 216110 km
                    Date: 2020.01.27
                    Time: 10:30:23
01304 - Radio
            008 - Implausible Signal
                    Fault Status: 01101000
                    Reset counter: 203
                    Mileage: 216110 km
                    Date: 2020.01.27
                    Time: 10:30:22
   Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
   Component: 0N AIRBAG VW8R  029 2521
   Revision: 10029000    Serial number: 003A3P0KBM6E
   Coding: 0012366
   VCID: 2E0508B58C1928976BB-807A
   Subsystem 1 - Part No: 3C0 959 339 A
   Component: BF-Gewichtsens. 006 0002
   Subsystem 2 - Serial number: 00000000031JXZ
   Subsystem 3 - Serial number: 0001.01.000000600000000000ˇÜ63
   Subsystem 4 - Serial number: 000000ˇÜ6332MSME102D0B143ˇÜ63
   Subsystem 5 - Serial number: D0B143ˇÜ6342MSME1039677FKˇÜ63
   Subsystem 6 - Serial number: 9677FKˇÜ6351HTS63IKAD6924ˇÜ63
   Subsystem 7 - Serial number: AD6924ˇÜ6361HTS63IKAT2U2 ˇÜ63
   Subsystem 8 - Serial number: AT2U2 ˇÜ63727TS61IKI6KR2SˇÜ63
   Subsystem 9 - Serial number: I6KR2SˇÜ63827TS64IK635L2$ˇ
   Subsystem 10 - Serial number: 635L2$ˇ
   Part No SW: 3C0 953 549 E    HW: 3C0 953 549 E
   Component: J0527               0015
   Revision: 00005000    Serial number: 3C5953507P
   Coding: 0002111
   Component: E0221           006 0080
   Part No SW: 3C0 920 970 R    HW: 3C0 920 970 R
   Component: KOMBIINSTRUMENT VD1 4240
   Revision: V0033000    Serial number: 00000000000000
   Coding: 0007205
   VCID: 333319C1673B057F045-8066
00771 - Fuel Level Sensor (G)
                    Fault Status: 00101010
                    Reset counter: 60
                    Mileage: 217313 km
                    Date: 2020.04.13
                    Time: 17:15:59
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Fault Frequency: 48
                    Mileage: 205145 km
                    Date: 2016.04.03
                    Time: 00:02:19
Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
   Revision: 00007000    Serial number: 0700C062181192
   Coding: 3FFD0E04D31002
   VCID: 211FE389CDC787EFE69-8074
01304 - Radio
                    Reset counter: 28
                    Mileage: 217429 km
                    Date: 2020.04.22
                    Time: 16:14:21
   Part No SW: 3C0 919 965     HW: 3C0 919 965
   Component: Kompass         005 0002
   Revision: 00005000    Serial number: 1166279TQDDX04
   VCID: 6D87CFB9419F938F121-8038
   Part No SW: 3C0 959 433 C    HW: 3C0 959 433 C
   Component:    IMMO         041 0364
   Revision: 00041000    Serial number: VWZCZ000000000
   Shop #: WSC 25129 444 54633
   VCID: 2A0D04A5B0F144B7B73-807E
   Subsystem 1 - Part No: 3C0 905 861 D
   Component:    ELV          024 0370
   3C0905861D     ELV          024 0370
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2801
   Coding: 0001205
   VCID: 363520D57449105723B-8062
   Part No: 1K1 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
00750 - Warning Lamp
                    Mileage: 6080 km
                    Temperature: 13.0∞C
                    Voltage: 12.50 V
                    Voltage: 12.30 V
   Component:    KSG PQ46 RDK 041 0213
   Coding: 1B910F8801862E521804141FF00A0F0E081800
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 209
                    Mileage: 216175 km
                    Date: 2020.01.31
                    Time: 18:47:41
   Part No: 1K0 959 702 K
   Coding: 0000004
   VCID: 372B2DD17343E95F38D-8062
   Revision:   013
   Coding: 0000013
Address 56: Radio
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2436
   Coding: 0000144
   VCID: 313F13C99D27376F769-8064
   Component:    RDK              0391
   Coding: 0100101
                    Reset counter: 204
                    Mileage: 216114 km
                    Date: 2020.01.29
                    Time: 15:52:31
00667 - Ambient Temperature Signal
                    Reset counter: 34
                    Mileage: 216819 km
                    Date: 2020.02.28
                    Time: 15:12:54
01487 - System Function Test
                    Fault Status: 01100101
                    Reset counter: 28
                    Mileage: 217458 km
                    Date: 2020.04.23
                    Time: 11:57:37
   Part No: 1K0 959 704 D
   Coding: 0000144
   VCID: 323D1CC598210C770F3-8066
End----------(Elapsed Time: 01:33, VBatt start/end: 12.1V/12.1V)-----------
Thursday,23,April,2020,12:46:14:59102
          72
   Coding: 0000072
   Coding: 0013755
                    Fault Frequency: 9
                    Reset counter: 60
                    Mileage: 217299 km
                    Date: 2020.03.24
                    Time: 18:05:55
   Coding: 00063445
                    Reset counter: 28
                    Mileage: 216110 km
                    Date: 2020.01.27
                    Time: 10:36:00
                    Voltage: 12.60 V
                    Fault Frequency: 23
                    Reset counter: 63
                    Mileage: 216110 km
                    Date: 2020.01.27
                    Time: 10:30:00
                    Voltage: 14.40 V
                    Reset counter: 28
                    Mileage: 216110 km
                    Date: 2020.01.27
                    Time: 10:36:00
                    Voltage: 12.45 V
                    Reset counter: 28
                    Mileage: 216110 km
                    Date: 2020.01.27
                    Time: 10:30:00
                    Voltage: 14.40 V
                    Fault Frequency: 6
                    Reset counter: 49
                    Mileage: 216437 km
                    Date: 2020.02.15
                    Time: 06:50:00
                    Voltage: 14.15 V
                    Reset counter: 48
                    Mileage: 216110 km
                    Date: 2020.01.27
                    Time: 10:30:23
01304 - Radio
                    Reset counter: 203
                    Mileage: 216110 km
                    Date: 2020.01.27
                    Time: 10:30:22
   Coding: 0012366
   Coding: 0002111
   Coding: 0007205
                    Reset counter: 60
                    Mileage: 217313 km
                    Date: 2020.04.13
                    Time: 17:15:59
            014 - Defective
                    Fault Frequency: 48
                    Mileage: 205145 km
                    Date: 2016.04.03
                    Time: 00:02:19
01304 - Radio
                    Reset counter: 28
                    Mileage: 217429 km
                    Date: 2020.04.22
                    Time: 16:14:21
                    Reset counter: 68
                    Mileage: 217458 km
                    Date: 2020.04.23
                    Time: 12:14:13
   Coding: 0001205
                    Mileage: 6080 km
                    Temperature: 13.0∞C
                    Voltage: 12.50 V
                    Voltage: 12.30 V
                    Reset counter: 209
                    Mileage: 216175 km
                    Date: 2020.01.31
                    Time: 18:47:41
   Coding: 0000004
   Revision:   013
   Coding: 0000013
Address 56: Radio
   Coding: 0000144
   Component:    RDK              0391
   Coding: 0100100
                    Fault Status: 00101110
                    Reset counter: 204
                    Mileage: 216114 km
                    Date: 2020.01.29
                    Time: 15:52:31
                    Reset counter: 204
                    Mileage: 216114 km
                    Date: 2020.01.29
                    Time: 15:52:31
   Coding: 0000144
End----------(Elapsed Time: 01:31, VBatt start/end: 12.1V/12.1V)-----------
Are Antennas reading proper?
Are you going to install genuine compatible sensors yet?
Did you know that un-checking the gateway and disabling the TPMS MIL safety system in cluster as a result is illegal in cars after year detailed in such documents at NHTSA? :rolleyes:
https://www.nhtsa.gov/sites/nhtsa.dot.gov/files/fmvss/TPMS-2005-FMVSS-No138.pdf
https://www.nhtsa.gov/sites/nhtsa.dot.gov/files/fmvss/TPMSfinalrule_6.pdf
DATES: Effective Date: This final rule is effective April 8, 2005, except for Subpart G of 49 CFRPart 585, which is effective September 1, 2005.
akitchens
C?ID=273674
This is my own car and I can disable if I want. When I use my TPMS scanner tool, it does not pick up any of the sensors. I tried on my Honda and it saw all 4 sensors. So I was thinking maybe there has to be something else.
I installed AC Delco sensors which had the 315mhz.
https://www.nhtsa.gov/interpretations/11-003978-tiajun09-std-138
akitchens
C?ID=273674
Why be an ass? Im just trying to get help.
You are failing to accept that help and engage in a comporting qualified repair process and are seeking to modify or use incompatible parts why?
Please see the RTFB and microfiche for proper information because your question is not VCDS related to circumvent that process.
http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
https://www.partslink24.com/partslink24/registration-data.action
http://wiki.ross-tech.com/wiki/index.php/01521
01521 - Sensor for Tire Pressure: Lower Limit Exceeded
Possible Symptoms
  • Malfunction Indicator Light (MIL) active
Possible Causes
  • Tire Pressure too Low
  • Tire Pressure Sensor(s) not installed
    • Winter Tires without Sensors
Possible Solutions
  • Check Tire Pressure
  • Check/Install Tire Pressure Sensors
01521 - Sensor for Tire Pressure: No Signal/Communication Possible Symptoms
Possible Causes
  • Tire Pressure Sensor(s) faulty
Possible Solutions
    • Check individual Sensors via Measuring Value Blocks (MVB)
Special Notes
  • On Systems without Position Recognition (e.g. 1K-chassis Golf/Jetta or or 3C-chassis Passat), raise or lower the pressure in one tire at a time and double check the Measuring Value Blocks (MVB) 001-012 (and 016) for changes. If you find one which does not change after raising or lowering the Pressure, you have most likely found the faulty Sensor.
    • Note: It may take up to 2 minutes before a pressure change is detected by the control module and displayed in the Measuring Value Block (MVB). To locate the individual Wheels it helps to make a note the Sensor Identification Number.
http://wiki.ross-tech.com/wiki/index.php/00667 00667 - Ambient Temperature Signal: Implausible Signal Possible Causes
  • Wiring and/or Connector(s) from/to Instrument Cluster (J285) faulty
  • Wiring and/or Connector(s) from/to Ambient Temperature Sensor (G17) faulty
  • Ambient Temperature Sensor (G17) faulty
Possible Solutions
  • Check Instrument Cluster (J285) for Fault Codes
  • Check Wiring and/or Connector(s) from/to Instrument Cluster (J285)
  • Check Wiring and/or Connector(s) from/to Ambient Temperature Sensor (G17)
  • Check/Replace Ambient Temperature Sensor (G17)
akitchens
C?ID=273674
Just because I’m not using VW sensors means I’m using incompatible parts? These stated they were for this Passat.
Do you want to argue compatibility issues or fix the car?
akitchens
C?ID=273674
I would love to fix it but how do we know these are not compatible
Any part which is not genuine here is considered a Fortune cookie I cant eat and I'm upset that there are not real Fortune cookies in my area!
Did you know this additionally based on your aforementioned information being well "VOID for Vagueness" ("VOV") like the laws you seem to dismiss too or lack of description, part numbers?
I really don't care to research it when I have seen post after post where other people remove the AFT and install the genuine, adapt them just fine & from IDK, this thing called experience maybe!
akitchens
C?ID=273674
I purchased part ACDELCO TPMS173K. So I guess these do not work as I thought they would. Im sorry for calling you an ass.
Would you know the original part numbers so I can get compatible ones?
Apology accepted........ :rolleyes:
Vehicle Identification No.WVWEK73CX6P187147
Modelpassat sedan
PA
Date of production16.03.2006
Model year2006
Sales type3C25K6
Engine CodeBPY
Transmission CodeHRN
I suggest you contact dealer to verify.......
PART NUMBERDESCRIPTION
1K0 907 253 DTyre pressure sensor
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PCWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation powertrains/platform parts0HGVehicle class differentiation -3C0-
Emission standard7GBEmission standard ULEV 2
Trailer hitch1D0Without trailer hitch
airbag4UBAirbag for NAR
Activated carbon canister/gasoline particulate filter1E4Activated carbon canister (ORVR) and siphoning device for fueling
Storage compartment packageQE2Storage compartment
Aerials8ZHAntenna for AM/FM reception, "diversity"
Exterior mirror adjustment6XNExterior mirrors, power-adjustable/ separately heated
Left exterior mirror5SHLeft exterior mirror, flat (US)
Right exterior mirror5RRRight exterior mirror, convex (US)
Drive type1X0Front-wheel drive
Multimedia/video/DVD/notebook connection9WCWithout "Multimedia" in vehicle
Equipment linesA8XUS comfort equipment
Rear brakes1KUDisc brakes in rear
batteriesJ1DBattery 380 A (72 Ah)
Front brakes1ZGDisc brakes in front (Geomet D)
Beverage holders4M5Beverage holders
Component sets for country-specific prescriptive standardsB0DComponent parts set, complying with vehicle type for USA (without California), various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ATElectronic stability control (ESC)
Owner's manuals0VMInformation kit in American English
Operating voltage9Z0Operating voltage 12 V
Heated washer nozzles9T0Without heated washer nozzles
CD-ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A9CD changer preparation (front)
General operating license additionsC08Operating permit, alteration
Roof rails/roof rack3S0Without roof rails/roof load rack
Roof insert/convertible top3FETilting and sliding glass sunroof with sunbshade
Shock absorption in rear1JARear shock absorption, basic version 1
Shock absorption in frontG07Shock absorption in front
Load-through hatch/ski bag3X2Load-through hatch
Tank filler neck for unleaded fuel/fuel type2G1Insert for the filling up of unleaded fuel
Installation differentiation for vehicle parts0ERInstallation differentiation for transmission AQ250 -- vehicle components --
Theft protection system7AGElectronic immobilizer with anti-theft alarm system (for USA)
Inserts5MADecorative inserts
Scuff plates7M0Plastic scuff plates in door apertures
Park distance control7X0Without park distance control
Electric interface for external useUF0Without electric interface
Differentiation for manufacturing process0FGMosel manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
Fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL0Without extended pedestrian protection measures
Headlight activation8K4Separate daytime running light -- NAR --
Parking brakeUH2Parking brake
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Transmission types/gear shift mechanisms0G7tiptronic
Weight category for rear axle0YDWeight range 4 installation control only, no requirement forecast
Weight category for front axleL03Suspension range 03 installation control only, no requirement forecast
Base engineT594-cylinder SI engine 2.0 l unit 06F.C
Tie down straps/net/pocket6M0Without tie down straps/net/pocket
cruise control system8T2Electronic cruise control system (CCS)
Sound insulation measures for outside noises2B0without additional exterior noise insulation
Garage door openerVC0without Garage door opener
Transmission specificationG1A6-speed automatic transmission
Speed alert system/speed limiter6Y9without cruise control system
Brackets3P0Without bracket for first aid kit and warning triangle
Rear seats3NURear bench seat, not split, split backrest, folding centre armrest
Heating system/air conditioning system9APClimatic air-conditioning system (semi-automatic)
Main headlamps8ESTwin headlamps for driving on the right, with integrated high beam (US design)
Customized installationFC0Without customized installation
Interior lighting in footwell6T1Interior lighting in footwell
Dashboard insertsU5CInstrument cluster, mph speedometer - USA -
Breakaway interior rearview mirror4L2Breakaway interior rearview mirror, dimming
headphone connection, rear8MAno headphone connection in rear
Body formsK8BNotchback
Luggage compartment floor covering6SELuggage compartment floor covering in flat needle-punched nonwoven
Cassette/CD storage compartment4W0without cassette / CD tray
Characteristic map cooling systemQS0Without electronic map cooling system
Child seatsQA0without child seat
Climate zones0Y4Cold and tropical climatic zones (US)
Compass/road sign displayQR1With compass
Seat ventilation/massage seat4D0Without seat ventilation/massage seat
Fuel filling volume1Z2Increase in initial standard fuel filling
Fuel systems1A2Fuel system for SI engine with direct injection (FSI)
Body measures5C1Body measures for increased safety requirements
Radiator grille6KARadiator grille
License plate carrier in rear6P2Rear license plate carrier (NAR)
License plate carrier in front6W3Front license plate carrier (small, NAR)
Paint preservation/transport protection5K5Transportation protective film (instead of paint preservation)
Paint finishFB0standard paint coating
Luggage/load compartment floor in rear3GAWithout luggage compartment floor
Country codesFE0Without country code (no DVD player in vehicle)
Steering system setupL0LLeft-hand drive
Reading lamp8S72 reading lights in front
Steering system1N3Speed-related variable steering assist (Servotronic)
Backrest release3H0Without backrest release for front seats
Load edge protection2P1Plastic loading edge protection
Lumbar support in backrests7P7Power-adjustable lumbar support for left front seat
steering wheels2ZMLeather-wrapped multi-function steering wheel
Loudspeaker installation8RM8 speakers (passive)
Headlight range control8Q0without beam length regulator
Center armrest6E3Center armrest in front
Multi-function display/trip computer9Q5Multi-function display with control
Center console3D3Center console
Engine cooling8Z6Hot country
Engine specificationD2L4-cylinder petrol engine 2.0 L/147 KW (16 V) Turbo FSI, homogeneous Basic engine is: T59/T61/TQ2/TU2/TD6/TN6
Vanity mirror on the left4SQLeft vanity mirror illuminated with cover and special mirror imprint (NAR)
Vanity mirror on the right4TQVanity mirror, right, illuminated, with cover and special mirror imprint (NAR)
Navigation system7Q0without navigation system
rear fog lamp8TAwitout rear fog lamp
Front fog lamps/additional headlamps8WAWithout fog lights
Wheel trims1NLTrims for alloy wheels
WheelsCA5Alloy wheels 7.5J x 17
Radios8USRadio "Premium" (double-size standard radio)
Smoker's/non-smoker's version9JANon smoker version
Tire pressure monitoring system7K4Tire pressure monitoring system 315 MHz High
umbrellaNS0Without umbrella(s)
tireHK1All-season tires 235/45 R17 97H xl (NAR)
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G1Space-saving spare wheel
Restraint systems in front4QQ3-point seat belts in front with pretensioner and height adjustment, US label
PLN2.0 "Le Mans" alloy wheel package
W232.0 Leather XM package
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/gearshift handle6Q2Gearshift knob/handle in leather
Special labels0SSLabels in English and French
Tail lamp assemblies8SLTaillight assemblies with diodes (LED) (for NAR)
Closing/opening mechanism tailgate/trunk lid/rear gate4E2Tailgate/trunk lid release from inside (electrically)
Seat in front, left3TFComfort seat in front, left
Seat in front, right3SFComfort seat, front right
Seat belt reminder9P7Visual and acoustic seat belt reminder, electric contact in buckle
Outer seat belts in rear3ZD3-point seat belts, outer rear with US label
Center seat belts in rear3C83-point seat belt, center rear with US label
seat coversN0XSeat trim covers in part-leather "Sports Grain"
Seat adjustment3L3Manual height adjustment for front seats
seat heater4A3seat heating for front seats separat controlable
Side lamps8F1Side-marker lamps
Voice control system/voice controlQH0without voice control
Side and rear windows4KCSide and rear windows in heat-insulating glass
Protective side molding4B4Protective side molding
Sun blind for rear/side windows3Y0without roller blind
Outlet7B312-volt outlet(s)
Bumper2JCComfort bumpers
Headlamp washer system8X0Without headlamp washer system
Intermittent windshield wiper control/ light/rain sensor8N4Windshield wiper intermittent control with potentiometer (four speeds)
Nameplate set0PKNameplate set "FSI"
Special alarm systems9A0Without taxi alarm system
Counterweights for steering wheels1Q1Mass damper for steering wheel, 26.5 Hz
Door and tailgate/trunk lid locking mechanism4K0Central locking w/ radio remote control and interior controls
Type-approval testing countries/ countries with specific requirementsB34Legal requirements for USA
Carrier frequency for remote control5D2Carrier frequency 315 MHz
Partition3CAwithout partition
Transport protectionNT1Transit coating (type 2)
Door and side trim panels3LJDoor and side trim panel in foam film, insert in leatherette
TV reception/digital radio receptionQV4Satellite radio reception USA
Installation parts for engines (engine mount system)1VGInstallation parts for four-cylinder engine
Front-end underbody cladding1SAWithout additional front underbody guard
Identification labels1EBwithout identification plate
First aid kit/warning triangle1T0Without first aid kit and warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Preparation for rotating beacon/siren combination9F0Without preparation for rotating beacon/siren combination
Telephone/telematics9W0Without car phone preparation/ installation
Additional warning lamps9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG0without service interval extension
Thermal energy storage system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield4GFWindshield in heat-insulating glass
Second battery/battery installation8FAwithout 2nd battery
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFront and rear floor mats
Decorative trims4ZBBright decorative trims
Additional child seat anchorage3B3Child seat anchors
Auxiliary heater9M0Without auxiliary heater/parking heater
akitchens
C?ID=273674
Thank you. And would you know why there is the word "Error" on my dash from the code provided?
Not sufficient information.......
Not sure this will work, did you know many report issues with this part number for installation at NHTSA?
TPMS Sensor
[FONT=&quot]Part Number: [/FONT]TPMS173K
Product Notes:
TPMS Sensor
All; 315 MHz; Multi-application Sensor; May Req universal TPMS scan tool to relearn sensor. Follow OE relearn procedure.
Per Vehicle: 4; Years: 2006-2010
https://parts-catalog.acdelco.com/catalog/catalog_search.php
They say it will work, maybe follow instructions on how in RTFB and request support?
If it doesn't you can go here okay?
https://www-odi.nhtsa.dot.gov/VehicleComplaint/
akitchens
C?ID=273674
Luckily Discount tire left the olds one in my car. So I ordered 4 of the same VW ones. We will see how that goes. My TPMS tool recognized 2 of the old sensors and none of the new
Well it seems history and experience are paying off with what usually is a wide spread consistent result, huh?
Dana
Western PA, USA
This page should add clarity to that system:
http://wiki.ross-tech.com/wiki/index.php/VW_Passat_(3C)_Tire_Pressure_Monitoring
More specifically, the VW TPMS Systems without Wheel Position Recognition link at the bottom:
http://wiki.ross-tech.com/wiki/index.php/VW_TPMS_Systems_without_Wheel_Position_Recognition
Ouch, I just noticed your TPMS tool can't locate them. If that's the case they probably aren't good sensors. Obtaining OE ones is best but we occasionally have shops report success with ones that are sourced 3rd party.
