Golf mk5 2008 diesel cranks but won't start
Vasco Ferraz
Portugal
C?ID=288561
My car cranks but won't start.
Fuel level is about half but the fuel filter reservoir is empty.
So, I believe that the fuel sender might be broken and I might have ran out of fuel.
I filled the fuel filter reservoir and the tank with a total of about 6 litres.
I primed the fuel system using VCDS for more than 3 times 30 seconds each.
But the car still won't start :|
There are no codes.
Am I doing something wrong?
- Is 6 litres enough?
- Should I prime again the fuel?
- Should I open or close some valve/purge?
- Should I fill some injector hose with fuel?
Thursday,09,April,2020,17:37:50:51935
VCDS Version: 20.4.0.1 (x64)  HEX-NET CB: 0.4513.4
VIN: WVWZZZ1KZ8W245642   License Plate:
Mileage: 323750km-201168mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ8W245642   Mileage: 323750km-201168miles
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 056 J    HW: 03G 906 021 AB
   Component: R4 1,9L EDC G000SG  1785
   Revision: --H07---    Serial number: VWX7Z0H13N6913
   Coding: 0000071
   Shop #: WSC 01392 785 00200
   VCID: 2E10DD6AB9DD9AF6A0-807A
   Revision: 00H11001
   Coding: 0021121
   VCID: 73A60C1E127FF71E0F-8026
   Part No SW: 1K0 907 044 DD    HW: 1K0 907 044 DD
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: 6C9417624F4128E6CE-8038
   Revision: 00H54000    Serial number: 00000007943357
   Coding: F5890F270004150047140000140000001E097F071400010C000000000000
   Shop #: WSC 12345 785 00200
   VCID: 71AA06166863C50EFD-8024
   Component: Wischer 240108 021  0501
   Coding: 00038805
   Shop #: WSC 12345
   Component: RLS     150309 054  0402
   Coding: 00209069
   Shop #: WSC 12345
   Component: 37 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1SY2N8
   Coding: 0013111
   Shop #: WSC 01373 785 00200
   VCID: 3D32EA2664BB716E29-8068
   Subsystem 1 - Serial number: 6332MSME2B236864D
   Subsystem 2 - Serial number: 6342MSME3375054ED
   Subsystem 3 - Serial number: 6352QSME4C1B234BP
   Subsystem 4 - Serial number: 6362QSME4D56342DS
   Part No SW: 1K0 953 549 BP    HW: 1K0 953 549 BP
   Component: J0527           752 0100
   Coding: 0002022
   VCID: 014A56D658C3D58E0D-8054
   Part No SW: 1K0 920 874 M    HW: 1K0 920 874 M
   Component: KOMBIINSTRUMENT VDD 1220
   Revision: V0002000    Serial number: VWX7Z0H13N6913
   Coding: 0003103
   Shop #: WSC 01007 261 13533
   VCID: 373EF80E46875B3EF3-8062
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 010208F2000033
   Coding: E9807F064002020002
   VCID: 302CC312A3E98C06B2-8064
   Component: IMMO            VDD 1220
   Part No SW: 1T0 035 680 R    HW: 1T0 035 680 S
   Component: RNS-MID       H27 6276
   Revision: AB001001    Serial number: VWZ6Z743114052
   Coding: 0C000402040000010000
   Shop #: WSC 05314 123 00001
   VCID: 3D32EA26A4BB716E29-8068
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14  8477
   Component: Tuer-SG         006 1203
   Coding: 0000180
   VCID: 383CFB324B995446FA-806C
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: 3522F2065C8BA92EE1-8060
   Coding: 819002005103487F2D04040DF0084F06F0FC00
   Shop #: WSC 01007 261 88724
   VCID: 03465CDE42DFC79E1F-8056
   Component: Tuer-SG         006 1219
   Coding: 0000180
   VCID: 393AFE3670934D4E05-806C
00097 - Front Passengers Central Locking (Safe) Motor (V162)
   Component: Tuer-SG         006 1302
   Coding: 0000144
   Shop #: WSC 01392 785 1012552
   Component: Tuer-SG         006 1305
   Coding: 0000144
End----(Elapsed Time: 01:15, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Vasco Ferraz
Portugal
C?ID=288561
When cracking, after several seconds I get the low oil pressure warning.
First I ignored, but then the I checked the oil sensor level and it's 0.0mm ^^!
Checked visual and it's in fact very low but I changed oil 3000km ago.
Still no errors on the dash or VCDS.
Hey Vasco how are you?
You should know better please post an auto-scan..... :rolleyes:
Is engine speed RPM G28 and G40 observed in blocks when cranking?
Does car fire up with flammable liquid sprayed in intake?
Reactions: Jef
Jef
HQ
After you post the Auto-Scan... is there any chance the mechanical timing is off? Have you done a compression test?
Vasco Ferraz
Portugal
C?ID=288561
Hi Jack,
Yes, I observe the G28 about 300rpm. I won't find the G40 in the blocks.
This is diesel so I am not sure if I should use starting fluid on diesel engines.
Vasco Ferraz
Portugal
C?ID=288561
I changed the distribution 23000km ago. But it was done by a Bosch Car Service with Bosch material.
I didn't do a compression test.
Basics "Vasco FIX" JA JA BASICS! :rolleyes:
Do check timing & do perform a compression check & spray a little of the fluid too..........
Is intake or exhaust restricted?
Scan please.......damaged wiring?
Vasco Ferraz
Portugal
C?ID=288561
This is a PD engine:
"Note to PD (pumpe duese aka unit injectors) and CR (common rail) owners: The timing in PD and CR engines is determined electronically by the ECU. There is neither a need nor an ability to check timing on the PD or CR engines using a scan tool. There are no graphs published for the simple reason that the timing is set using a dedicated VAG locking tool when changing the timing belt :-) "
Meaning that I can only visual inspect the timing, right?
Meaning that I can only visual inspect the timing, right?​
Vasco Ferraz
Mechanical.........BASICS IN RTFB
Vasco Ferraz
Portugal
C?ID=288561
Jack,
Are you sure that this can't be a fuel air lock?
I am not 100% sure but I always do a trip reset at each fuel filling (always full filling).
At 100/110km/h, I do 1100km per deposit when the low fuel warning pops (average of 4.3L/100km).
This latest 3000km I changed my driving style and the average consumption is 5.7L/100km.
The trip shows 930km and I am 99.99% sure that I did a trip reset.
Another fact is that the fuel filter reservoir was empty.
Also, I can hear the fuel pump working when turning the key or performing the VCDS fuel priming procedure.
Jack,
How would I know, respectfully I'm not there....... :rolleyes:
Gauges and measuring devices it is time is it not, verify prime or manually bled with mighty vac?
Why did it loose prime and did you check for leaks or on suction side if sucking air?
Isolate zones with mighty vac and crimps yet?
Did you know that you can grind a vise grip smooth & so it doesn't damage hoses when crimping or insert a adapter jaw plates
Vasco Ferraz
Portugal
C?ID=288561
Jack,
Thank you so much for your help :)
What I was trying to say is that I believe that I ran out of fuel... drying all the lines.
I don't have such tools :|
My idea is to:
1) Add more 6 litres to the tank.
2) Unplug the intake fuel hose that connects to fuel filter housing to check if, when cranking, there is diesel being primed from the fuel tank.
3) If the above does not happen it means that there is air between the tank and the filter filter housing
4) So, I will remove the back seat to reach the fuel sender and fill the it with diesel.
5) Repeat number 2.
Does this makes sense?
Pinpointdiag
Scotland
C?ID=90374
So can I say that a golf with a PD engine has no high pressure fuel pump, the unit injectors are there own high pressure pumps. It will probably have 2 x low pressure pumps. One in the tank and one at the timing belt end of the rocker cover beside the fuel filter. If you run out of fuel it should self prime. If you have found the filter was empty then a pump or both pumps are not pumping or there’s a blockage in the line or filter. There is a feed and return pipe from the tank to the filter and a feed and return From the filter to the injectors inside the rocker cover. The filter top should have arrows to show which is which. First listen to both and make sure you can hear them running then if they are I would find the one that comes out of the filter to the cylinder head and using a extra bit of hose pointed in to a bucket find out if you have fuel flowing through the system. Or plumb in a piece of clear hose. Be very careful of potentially spilling fuel.
A pump can sound like it’s pumping but not actually pump. And if the tank pump works but the under hood pump doesn’t it can actually block the flow. Also of course the pumps need to start pumping when the engine starts to crank over not just when asked to with the scan tool or during priming.
If it had run out of fuel adding 6 Lts would be enough to get it running again.
All that is provided it’s a PD engine and not Common rail. And since you’ve said there are no fault codes.
Also as jack said you could spray some flammable spray like brake/carburettor cleaner (not easy start) into the air intake and provided there is good compression and no inlet or exhaust blockages it should start and run for as long as you keep adding a little fuel. If it runs from an external fuel supply like that it should be able to run with its own fuel supply. This can get a vehicle that has an air lock move the air bubble and then run on its own, older rotary high pressure pumps were bad for this.
However it’s possible to do some serious damage doing this and it should only be done with great care by some one who knows what there doing.
HTH
The PD indeed has a rotary HPP built in with combination of the vacuum pump on the cylinder head and driven by camshaft.
There can be a lift pump in tank, boost pump, than HPP and than each unit injector incorporates a high pressure helix within the injector and is limited by camshaft rocker stroke with lash, additional the delivery method of fuel to helix pool & is controlled by a solenoid on each.
https://www.google.com/url?sa=t&sou...FjAAegQIAxAC&usg=AOvVaw3GWlOC9ZRVV8xJa63-BlRH
Vasco Ferraz
Portugal
C?ID=288561
Hi Pinpointdiag,
Hi Jack,
I believe that Pinpointdiag is right, that is, PD engines does not have any high pressure fuel pump.
The high pressure is done at each unit injector (something around 1900 bar).
This PD engine has one lifter pump in the tank and (I believe!) another low pressure pump in the engine bay, like Jack said, connected to camshaft.
I believe this pump shares functionality with the servo brake enhancer -> I am talking about the tandem pump.
So, after all this discussion I am pointing for a faulty tandem pump :| But this is just a guess ^^!
Pinpointdiag
Scotland
C?ID=90374
Sorry, Jack is correct I was forgetting about the camshaft driven tandem pump. Not sure it produces high pressure though? 1bar at idle is it not.
Have a good look for the Electrical transfer pump. I think it will have one. It’s not obvious at first but if I remember correctly it’s in front of the filter on the right hand inner wing.
Should you not go back to school & RTFB, further sharpen your pencil, the 1 BAR you aforementioned is a requirement on return line for proper chiller function & because if fuel isn't circulated quickly out of head by HPP, the fuel will become too hot just between injectors due to helix and latent cylinder head temperature on feed from zyl 4 to 1?
Pinpointdiag
Scotland
C?ID=90374
So what is the maximum pressure of the tandem pump then.
