Cold diagnosis front parking light/DRL Octavia2 RS 1K0937049N
FandaTDI
Czech Republic
C?ID=204559
can someone please help me to switch off the cold diagnosis in this BCM? At least front parking lights/DRL or at all.
I´ve tried so far (untickle) these:
Byte2 bit2 - "Cold lamp diagnosis active" - NOT WORKING
Byte19 bit1 - "C.D. Front parking lights active" - NOT WORKING
Byte18 and 19 no bit tickled - NOT WORKING
Why?
Is there any sw solution?
Adress 09: Central electronics        Labels:. 3C0-937-049-23-H.lbl
   Control unit SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Part: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001245642
   Coding: 01880F020004140000110D000000000000087F075C
   Workshop #: WSC 22616 074 17237
   VCID: 3A38DEE77570059FA8-806E
   Subsystem 1 - Control unit: 1Z1 955 119 A  Labels: SVO\1KX-955-119.CLB
   Part: Wischer SK351  012  0401
   Coding: 00065525
2 faults found.
02395 - parking light front right (M3)
            012 - electric circuit fault
02394 - parking light front left (M1)
as well as:
   Coding: 01880B020004140000110D0000000000000800005C
   Coding: 00065525
2 faults found.
Thanks
hadez16
C?ID=289891
You need VCP for this.
Not possible with VCDS.
I still hope that some day there will be any magic keystroke in VCDS to dowload and upload the PQ lighting configuration as raw hex values.. ;)
FandaTDI
Czech Republic
C?ID=204559
Thanks for the answer. I have VCP(original, but used just few times), is it there described well(in coding, adp,guided functions...)? Maybe doing adpmaps with vcds before and after can reveal it?(if it is in coding, a scan might be enough)
Spacewalker
C?ID=159607
For bordnetz - I never heard that VCP can do any trick
For BCM - yes ...but not bordnetz
for Bordnetz I only know people play with resistors inside
hadez16
C?ID=289891
You're right, sorry. I was too fast associating Octavia 2 with BCM......
