Seat Leon 5F Rear lights coding
Dp41n8w
C?ID=372411
Hello. Is it possible to code out the upper stripe from rear led lights? I found inner and outer light channel but I didnt saw oppertunity to code out "half of led" .
Saturday,07,March,2020,18:47:14:19148
Workshop Code: 358 14250 022663
VIN: VSSZZZ5FZFR119298   License Plate:  LEON ST
Mileage: 91104km-56609mi   Repair Order:
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 32 42 44 52 55 5F A9
VIN: VSSZZZ5FZFR119298   Mileage: 91104km-56609miles
Address 01: Engine (J623-CJXA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 E    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0099
   Revision: --H13---
   Coding: 0B1D00322424010B0000
   Shop #: WSC 00049 770 00123
   ASAM Dataset: EV_ECM20TFS0205G0906259E 001005
   ROD: EV_ECM20TFS0205G0906259E.rod
   VCID: 303910D78AA7FF47795-8064
16452 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
17178 - Databus
Readiness: 0010 0001
   Part No SW: 0D9 300 043 T    HW: 02E 927 770 AQ
   Component: DQ250-6A TVS  H53 9699
   Revision: 05853104    Serial number: TFK01501291930
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 2B0307BBA3819C9F4C7-807E
12 Faults Found:
21153 - Gear 1
          P072C 00 [002] - Not Selectable
21154 - Gear 2
          P072D 00 [002] - Not Selectable
21155 - Gear 3
          P072E 00 [002] - Not Selectable
21156 - Gear 4
          P072F 00 [002] - Not Selectable
21157 - Gear 5
          P073A 00 [002] - Not Selectable
21158 - Gear 6
          P073B 00 [002] - Not Selectable
21159 - Gear R
          P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
          P174A 00 [002] - Electrical malfunction
10732 - Valve 3 in Transmission Part 2
          P174E 00 [002] - Electrical malfunction
10657 - RPM Signal from ECU
          P0726 00 [002] - Implausible Signal
10906 - Cooling Oil Valve
          P179D 00 [002] - Electrical Malfunction
          P1734 00 [002] - -
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Component: ESC           H32 0385
   Revision: 00000000    Serial number: 60455000004722
   Coding: 19EE6B92542129750079060941CB6898D62A9400608216F6004100F1C006
   Shop #: WSC 00049 770 00197
   ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
   VCID: 47CB5B0B1F2958FF48F-8012
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 174
                    Mileage: 85835 km
                    Date: 2019.11.13
                    Time: 07:54:24
   Part No SW: 5F0 907 044 L    HW: 5F0 907 044 L
   Component: Climatronic   H04 0911
   Revision: 00001K09
   Coding: 02000004200100011005000000101000
   Shop #: WSC 00049 770 00106
   VCID: 2F3B13AB9799E0BF60F-807A
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011503803029
   Coding: 08001A46C24102F343E04000401C07281000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 005980177A87AFC7C95-8054
   Subsystem 1 - Part No SW: 5F1 955 119     HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 150120  041 0574
   Serial number:         150123195319
   Coding: 0BC5FD
   Component: RLHS  037 0059
   Serial number: S5Y15M02D14H06M19S16
   Coding: 00095D
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39391504001089
   Coding: 0031051011
   VCID: 3D2739E34DF5022FE23-8068
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H16 0115
   Serial number: 27011541350017
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 76B5E6CF28439177E39-8022
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0200
   Revision: --------    Serial number: 003P4P3SGT6A
   Coding: 98CCC000000000005C0000CC000800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F5B03EB0779D03FB0F-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 602 15
   Serial number: 3576U00000022954D314
   Subsystem 2 - Part No SW: -----------    HW: 454 000 602 15
   Serial number: 3586U000000BF054D31I
   Subsystem 3 - Part No SW: -----------    HW: 454 800 702 15
   Serial number: 3516R9A8CD605000000J
   Subsystem 4 - Part No SW: -----------    HW: 454 800 702 15
   Serial number: 3526RB111D605000000
   Subsystem 5 - Part No SW: -----------    HW: 454 802 501 15
   Serial number: 3556V599A9905000000K
   Part No SW: 5Q0 953 507 DF    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 09021504401571
   Coding: 1410
   VCID: 7DA7F9E30D75C22FA23-8028
   Part No SW: 5F0 920 862 F    HW: 5F0 920 862 F
   Component: KOMBI         202 4310
   Coding: 07AD11083980000800082A001000000000000000
   VCID: 2C0104A7A68F9BA745D-8078
   Revision: --------    Serial number: 09021510800040
   Coding: 030100F42F085900EF0002E99C0F00010001050000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 72BDDADF442B8D57CF1-8026
   Subsystem 2 - Part No SW: 5F0 959 537 A    HW: 5F0 959 537 A
   Serial number: 000000000A0450050115
   Coding: 012000
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185703001411210643
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8040
   Serial number: HA1-00002.12.14
   Coding: 0101
   ASAM Dataset: EV_LockElectHA1VW37X 001001
   ROD: EV_LockElectHA1VW37X.rod
   Part No SW: 5Q4 959 593 C    HW: 5Q4 959 593 B
   Component: TSG FS        009 0015
   Serial number: 0000137009888
   Coding: 00100320DE00040000001000
   VCID: 45D7510325254AEFBA3-8010
   Serial number: 00000000000005225344
   Coding: 310000
   Coding: 8103
   VCID: 372B2BCB6FC9287F38F-8062
22272 - Databus
          [KFC_MOTOR_11 Botschaft - CAN-Timeout]
                    Reset counter: 58
                    Mileage: 84535 km
                    Date: 2019.10.14
                    Time: 16:29:37
                    Motor status: 00
                    Supply voltage: 12.00 V
                    Temperature: 15.0 °C
                    KFC: 57
                    KFA: 00 00
                    Environmental conditions: 20
                    uioUdNotFilt_xdu16: 12.08 V
                    uAdSensI_SwitchedKl30_xdu16: 12.06 V
22528 - Databus
          [MOTOR_12 Botschaft - CAN-Timeout]
                    Reset counter: 58
                    Mileage: 84535 km
                    Date: 2019.10.14
                    Time: 16:37:20
                    Motor status: 00
                    Temperature: 16.0 °C
                    KFC: 58
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 12.05 V
                    uAdSensI_SwitchedKl30_xdu16: 12.04 V
   Part No SW: 5Q4 959 592 C    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0015
   Serial number: 0000136644661
   VCID: 44D14C072E1F73E7ADD-8010
   Serial number: 00000000000005208162
   Coding: 290000
   Coding: 0392030009000000
   VCID: 75B7E1C335459A6FEA3-8020
Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
   Part No SW: 5F0 035 824 A    HW: 5F0 035 824 A
   Component: MU-S--ER      041 0425
   Serial number: E1E01102153990
   Coding: 04730300FF0A000021110001000800002F0202040100010002
   ASAM Dataset: EV_MUStd6C3PASE 002029
   ROD: EV_MUStd6C3PASE.rod
   VCID: 221DEA9FD44B5DD7FF1-8076
   Subsystem 1 - Part No SW: 5F0 919 603 C    HW: 5F0 919 603 C
   Component: ABTminStdRdHG  H51 0022
   Serial number: SEZ8Z9PC3000CJ
   Part No SW: 5F0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0004
   Serial number: 150107200758
End----------(Elapsed Time: 01:33, VBatt start/end: 14.7V/14.7V)-----------
TBAx
C?ID=287144
Can you provide an adaption channel map of the BCM (09).
Just to understand you correctly: You want the part disabled, that goes off, when the indicator is on?
Dp41n8w
C?ID=372411
Yes I will give you adaption channel map as soon when the car arrives back to town :)
