Hi there, I am new to this. Sons A6 developed no crank , all lights ignition worked etc. after ascertaining battery was okay, starter relays worked. Traced to corroded wire from starter to solenoid. After removing cv shaft, alternator and starter putting in new, no easy task. Upon starting loads of lack of communication to steering wheel. DONT BELEIVE I UNPLUGGED OR FAILED TO CONNECT ANYTHING, took out relays to ascertain they worked. I have no idea where to start, Could anything have been fried? ps steering does not lock, no high beams, no turn signals. It is like no communication at all to steering module, Why? How to fix? Any help would be appreciated, especially if I missed something simple?
Thursday,05,March,2020,17:53:26:63202
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUDH74F08N052435 License Plate:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 4F
52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUDH74F08N052435 Mileage: 256020km-159083miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
16-Steering wheel -- Status: Cannot be reached 1100
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F2 910 559 H HW: 4F1 907 559 E
Component: 3.2l V6 FSI 0040
Revision: --H21--- Serial number:
Coding: 01050109190F0120
Shop #: WSC 05811 444 999999
VCID: 313F1540AD2634AF76B-8064
005785 - Powertrain Data Bus
P1699 - 009 - Missing Message from Steering Wheel Electronics
Fault Frequency: 11
Reset counter: 40
Mileage: 255977 km
Date: 2007.05.16
Time: 13:21:10
RPM: 736 /min
Mass Air / Rev.: 163.5 mg/str
Temperature: 75.0°C
Idle
Voltage: 11.83 V
005672 - Powertrain Data Bus
P1628 - 009 - Missing Message from Steering Angle Sensor
Fault Frequency: 11
Reset counter: 40
Mileage: 255977 km
Date: 2007.05.16
Time: 13:21:10
RPM: 736 /min
Temperature: 75.0°C
Idle
Voltage: 11.83 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Fault Frequency: 9
Reset counter: 40
Mileage: 255977 km
Date: 2007.05.16
Time: 13:21:11
RPM: 704 /min
Mass Air / Rev.: 169.0 mg/str
Temperature: 75.0°C
Idle
Load: 23.9 %
001110 - EVAP System
P0456 - 006 - Very Small Leak Detected - Intermittent
Reset counter: 39
Mileage: 255977 km
Date: 2007.05.16
Time: 20:34:48
Lambda: -1.0 %
Temperature: 7.5°C
Temperature: 31.5°C
Speed: 49.0 km/h
Time: 128.0 s
Temperature: 672.0°C
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F5 910 156 HW: 09L 927 156 C
Component: AG6 09L 3.2 FSI USA 0010
Revision: --H03--- Serial number: 4368371
Shop #: WSC 02335 758 00200
VCID: 6597B110A96EA80F5A3-8030
049682 - Steering Column Control Module
U0212 - 000 - No Communications
Mileage: 256021 km
Date: 2007.05.17
Time: 07:42:59
049446 - No Communications with Steering Angle Sender (G85)
U0126 - 000 -
Mileage: 256021 km
Date: 2007.05.17
Time: 07:42:59
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0070
Coding: 0020895
VCID: 6695B61C5468A317539-8032
Reset counter: 109
Mileage: 256021 km
Date: 2007.05.17
Time: 07:42:59
Hex Value: 0x00C0
Hex Value: 0x4282
Hex Value: 0x001E
Hex Value: 0x43A4
Hex Value: 0x00FF
Part No SW: 4F0 910 852 A HW: 4F0 905 852 C
Component: FBSAUDIC6 ELVSG H01 0040
Revision: 09010701 Serial number: 10601600871279
Coding: 0000007
VCID: 2411EC14E2D491078DD-8070
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Component: FBSAUDIC6 KSG H27 0080
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 D HW: 4E0 035 729 A
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 361ES077515547
Coding: 0000003
Subsystem 2 - Serial number: 00000000867038
Subsystem 3 - Serial number: 0118.09.070000000100010652ÿ
Subsystem 4 - Serial number: 010652ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000053 Serial number: 00000030282543
Coding: 0524326
VCID: 1C61D4F4DAA4A9C735D-8048
Reset counter: 109
Mileage: 256021 km
Date: 2007.05.17
Time: 07:43:04
Voltage: 12.80 V
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H18 0250
Coding: 0113123
VCID: 30391044A62C3DA7795-8064
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00146221
Shop #: WSC 02335
Reset counter: 109
Mileage: 256020 km
Date: 2007.05.17
Time: 07:42:00
Address 0E: Media Player 1 (R192) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H15 0700
Revision: 00000000
VCID: 270BFB189FE27A1FA8F-8072
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 K HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0140
Revision: 00000000 Serial number: AUZ4Z7G0161513
Coding: 0000100
VCID: 2F3B1338BB12225F60F-807A
Reset counter: 109
Mileage: 256021 km
Date: 2007.05.17
Time: 07:43:11
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 6N AIRBAG AUDI8RH30 0300
Revision: 15H30000 Serial number: 00359D0G6V1+
Coding: 0013902
Shop #: WSC 02325 758 00200
VCID: 2A0D022C80F04777B71-807E
Subsystem 1 - Part No: 4F0 910 339 B
Component: BF-Gewichtsens. H03 0060
Subsystem 2 - Serial number: 6332CSME2233772F2
Subsystem 3 - Serial number: 6342CSME2E50251C3
Subsystem 4 - Serial number: 6352QSME3956292DQ
Subsystem 5 - Serial number: 6362QSME3B1B4C35S
Subsystem 6 - Serial number: 63734SME394E13372
Subsystem 7 - Serial number: 63834SME3E5A4C43E
01590 - Igniter for Battery Disconnect (N253)
Address 16: Steering wheel
Part No SW: 4F0 910 930 C HW: 4F0 920 983
Component: KOMBIINSTR. M73 H21 0240
Revision: 00700000 Serial number: 72X35UD97
Coding: 2129388
Shop #: WSC 19104 002 1048576
VCID: 2313EF08E7DA963FF47-8076
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B0782481FB
Coding: F5D5DE77707A0600
VCID: 2D070930B11E504F523-8078
Reset counter: 109
Mileage: 256021 km
Date: 2007.05.17
Time: 07:44:24
Reset counter: 109
Mileage: 256021 km
Date: 2007.05.17
Time: 07:44:25
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H46 0350
Revision: 00046006 Serial number: AUZ5ZBG3480896
VCID: 1869C8E42E9CC5E7115-804C
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 619FA500BD46C42FA6B-8034
Part No SW: 4E0 910 888 M HW: 4E0 919 887 M
Component: MNS US H51 1100
Revision: 00000000 Serial number: 341BV087505888
Shop #: WSC 08213 444 75013
VCID: 382928644E5CE5E7315-806C
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0210
Revision: 00000000 Serial number: —
Coding: 0051947
Shop #: WSC 02327 758 00200
VCID: 2C0104348A04594745D-8078
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H25 0200
Revision: 02000025 Serial number: 01066228540000
Coding: 4618269
Fault Frequency: 38
Reset counter: 109
Mileage: 255971 km
Date: 2007.05.16
Time: 12:00:04
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000048586
Coding: 0000026
VCID: 2517F110E9EE680F9A3-8070
Part No SW: 4F0 910 280 HW: 4F0 907 280 C
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000068869
Coding: 0002014
VCID: 5EE59EFC8C38FBD79B9-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0210
Revision: 00000000 Serial number: B
Coding: 0051947
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0005022
Shop #: WSC 02145 758 00200
VCID: 2019E004F6CC8D27E95-8074
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000016
VCID: 290FFD2085F64C6FBEB-807C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Fault Status: 11100100
Reset counter: 109
Mileage: 256024 km
Date: 2007.05.17
Time: 07:43:01
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Revision: 00000000 Serial number: 394IU077810253
VCID: 2E050E3CBC182B576B9-807A
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000137300
Component: von VA0 2805150215
Coding: 344630393135313035442056413032383035313530323135
Shop #: WSC 08213 444 58012
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0051754
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000600019764
Coding: 0062221
VCID: 221DEA0CF8C09F37FF1-8076
Reset counter: 108
Mileage: 255989 km
Date: 2007.05.16
Time: 20:45:31
(no units): 65.0
Voltage: 13.60 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000709170417
Shop #: WSC 12336 024 394758
VCID: 34311C54523401871DD-8060
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J7820MK
Coding: 1000304
VCID: 5DE799F0813EE0CF823-8008
Reset counter: 109
Mileage: 256021 km
Date: 2007.05.17
Time: 07:42:58
Reverse OFF
Count: 3
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0051754
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Revision: 00H09000 Serial number: 06240724200633
Coding: 0021206
VCID: 270BFB1893E27A1FA8F-8072
Part No SW: 4F0 910 336 E HW: 4E0 862 335
Component: Handyvorb2 H18 0950
Revision: 00000000 Serial number: 00000005007196
Coding: 0010900
End----------(Elapsed Time: 02:21, VBatt start/end: 13.3V/13.4V)-----------
hart.daniel64@gmail.com
Controller Software Versions:
ECU 1 = Engine 0040
ECU 2 = Auto Trans 0010
ECU 3 = ABS Brakes 0070
ECU 4 = Acc/Start Auth. 004
Sub ECU 4 > 1 = Acc/Start Auth. 500
Sub ECU 4 > 2 = Acc/Start Auth. 700
ECU 5 = Control Head 4140
Sub ECU 5 > 1 = Control Head 1006
ECU 6 = Auto HVAC 0020
ECU 7 = Cent. Elect. 0250
Sub ECU 7 > 1 = Cent. Elect. 0210
Sub ECU 7 > 2 = Cent. Elect. 0100
ECU 8 = Media Player 1 0700
ECU 9 = Digital Radio 0140
ECU 10 = Airbags 0300
Sub ECU 10 > 1 = Airbags 3006
ECU 11 =
ECU 12 = Instruments Labels:
ECU 13 = CAN Gateway 0060
ECU 14 = Media Player 2 0350
ECU 15 = Seat Mem. Drvr 0050
ECU 16 = Navigation 1100
ECU 17 = Door Elect, Driver
ECU 18 = Central Conv. 0200
Sub ECU 18 > 1 = Central Conv. 3130
ECU 19 = Sound System 0240
ECU 20 = Centr. Electr. II 0
ECU 21 = Door Elect, Pass. 0
ECU 22 = Parking Brake 0080
ECU 23 = Headlight Range 002
Sub ECU 23 > 1 = Headlight Range 100
Sub ECU 23 > 2 = Headlight Range 100
ECU 24 = Radio 0620
ECU 25 = Battery Regul. 0590
Sub ECU 25 > 1 = Battery Regul.
ECU 26 = Door, Rear Left 021
ECU 27 = Tire Pressure 0100
ECU 28 = Voice Control 0630
ECU 29 = Back-up Cam. 0050
ECU 30 = Door, Rear Right 02
ECU 31 = Park Assist 0060
ECU 32 = Telephone 0950
