hi
i have transporter t5 but giving error wrong coding..
ESP MK25E1
LOG is attached thnks for helps
ESP MK25E1
Friday,28,February,2020,17:53:38:05288
VCDS Version: 19.6.2.2 (x64) HEX-NET CB: 0.4508.4
VIN: WV1ZZZ7HZ7H138736 License Plate: T5ABSCOD
Mileage: 586840km-364645mi Repair Order:
57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ7H138736 Mileage: 586840km-364645miles
Address 01: Engine Labels: 038-906-016-AXB.clb
Part No SW: 038 906 016 N HW: 028 101 185 5
Component: R4 1,9L EDC 0000SG 6209
Revision: 12345678 Serial number: XXXXXXXXXXXXXX
Coding: 0151031
Shop #: WSC 02744 790 00000
VCID: 9F0E61B74FA9F4B73C-5184
18044 - Powertrain Data Bus
P1636 - 000 - Missing Message from Airbag Controller
Torque: 106.0 Nm
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00000100
Torque: 0.0 Nm
Torque: 60.0 Nm
16566 - Fuel Temp. Sensor A (G81)
P0182 - 000 - Short to GND
Torque: 106.0 Nm
Load: 0.0 %
Voltage: 12.08 V
Temperature: 16.2°C
Temperature: 31.5°C
Temperature: 38.7°C
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 7H0-907-37x-ESP.lbl
Part No SW: 7H0 907 379 R HW: 7H0 907 379 R
Component: ESP MK25E1 0104
Revision: 00H31001
Coding: 0000557
Shop #: WSC 12345 389 45725
VCID: C4C4CEDB868FF76F41-5160
003 - Mechanical Failure
Fault Status: 01100011
Reset counter: 40
Mileage: 586844 km
Count: 128
Count: 4865
Count: 199
Count: 2049
Address 09: Cent. Elect. Labels:. 7H0-937-049.lbl
Part No: 7H0 937 049 T
Component: BORDNETZ SGVER 1.0 2001
Coding: 0000101
Shop #: WSC 02736 790 00000
VCID: C3C6CDC78381F05778-5160
008 - Implausible Signal
00538 - Reference Voltage
014 - Defective
Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl
Part No: 7H0 920 861 E
Coding: 00103
Shop #: WSC 00186
VCID: AE108C7368036D3F87-5160
WV1ZZZ7HZ7H138736 VWZ7Z0G5298927
49-00 - No Communications
01304 - Radio
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 02736
VCID: F0AC520BB2B73BCFD5-5160
01304 - Radio
Address 46: Central Conv. Labels: 7H0-959-433.lbl
Part No: 7H0 959 433 B
Component: C11 Komfortgerát 0004
Coding: 00025
Shop #: WSC 02736
VCID: B22898037C3B49DFE3-4B1E
End----------(Elapsed Time: 06:23, VBatt start/end: 12.5V/12.3V)-----------
