2016 Passat SE
jettajim
C?ID=14954
Hi and thanks for any advice,
2016 Passat SE with Tech, 1.8L, ~51k miles. Bought the car new and never any issues until performing a simple battery change.
I changed the battery last week and have the following codes. I tried to clear them but they won't. I'm not an expert with VCDS-I use it once every few years at most. This morning while doing the Auto Scan, there was a high-pitched noise coming from the engine bay--like computers communicating. I had the hood opened to verify the sound location. This sound was not present a few days ago while doing the Auto Scan.
Can someone please point me in the right direction for the fix?
I appreciate the help!!
Sunday,23,February,2020,08:01:07:06624
VCDS Version: 19.6.2.2 (x64)
VIN: 1VWBS7A36GC048158   License Plate: 57880
Mileage: 93150km-57880mi   Repair Order: 02232020
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 25 2B 3C 42 44 46 4F 52 5F
          61 62 72 75
VIN: 1VWBS7A36GC048158   Mileage: 93150km-57880miles
Address 01: Engine (J623-CPKA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 906 071 AF    HW: 06K 907 425 C
   Component: R4 1.8l TFS   H13 2360
   Revision: --H13---
   Coding: 001A0092244400161000
   Shop #: WSC 09003 957 00200
   ASAM Dataset: EV_ECM18TFS02006K906071AF 001004
   ROD: EV_ECM18TFS02006K906071AF.rod
   VCID: 6FE77A93B684EC374C-803A
18876 - Cruise Control Switch (E45)
          P0568 00 [047] - Implausible Signal
                    Fault Frequency: 26
                    Mileage: 92651 km
                    Date: 2020.02.19
                    Time: 01:06:10
                    Coolant temperature: 82 °C
                    Intake air temperature: 63 °C
                    Voltage terminal 30: 12.285 V
                    ACC variants (coding): ACC
                    CCS Switch: CCS operating unit
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Control component verified: No
                    ACC variants: ACC
17801 - Coolant pump
          P194B 00 [109] - locked
                    Mileage: 92651 km
                    Date: 2020.02.19
                    Time: 01:08:34
                    Vehicle speed: 255 km/h
                    Coolant temperature: 81 °C
                    Voltage terminal 30: 12.167 V
                    Engine: operating status: ES
                    STATE_LS_SAE[1]: OL_CDN
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 99 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.968 V
                    FAC_TPS_1_SAE: 9.375000 %
                    FUP_H_SAE: 9830.0 kPa
19854 - Steering Column Control Module
          U0212 00 [047] - No Communications
                    Mileage: 92651 km
                    Date: 2020.02.19
                    Time: 01:06:10
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 84.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 19 min
                    STATE_ERR_ABC_PRED: 5
Address 02: Auto Trans (J217)       Labels:* 09G-927-749-V1.clb
   Part No SW: 09G 927 749 AN    HW: 09G 927 749 AN
   Component: AISIN AG6 G3  129 2969
   Coding: 000348
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW31.rod
   VCID: 050B383B8438C66796-8050
22615 - Steering Column Control Module
          U0212 00 [171] - No Communications
                    Reset counter: 212
                    Mileage: 92651 km
                    Engine speed: 0.0 /min
                    Transmission input speed: 0 /min
                    Transmission output speed: 0 /min
                    Engine torque: 0 Nm
                    Transmission fluid temperature: 72 °C
                    Accelerator position: 0.0 %
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
                    Lock Up Clutch: Open
                    Electrical Oil Pump target revolution: 65534 /min
                    Electrical Oil Pump actual revolution: 65279 /min
                    Engine Speed signal Current: 65279 /min
                    Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
                    Electrical Oil Pump target current: 65278 mA
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: C54BC0F549260002A30C03E99221004100F0F01A
   VCID: 75EB48FBDCD8D6E786-8020
                    Reset counter: 5
                    Mileage: 92651 km
                    Date: 2020.02.19
                    Time: 01:06:10
                    Count: 2
                    Count: 14
                    Count: 20480
                    Count: 16390
                    Count: 44544
                    Reset counter: 5
                    Mileage: 92979 km
                    Date: 2020.02.21
                    Time: 00:01:58
                    Count: 2
                    Count: 14
                    Count: 20480
                    Count: 297
                    Count: 44288
   Part No SW: 5K0 959 434 F    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 093 1202
   Revision: 00093000    Serial number: 0391507696
   Coding: 030C0C
   VCID: 387581CF834A6B8F5D-806C
   Part No SW: 561 907 044 AM    HW: 561 907 044 AM
   Component: Climatronic   H07 0910
   Revision: 00001K04
   Coding: 0050019002
   ROD: EV_ACClimaBHBVW411_VW41.rod
   VCID: 62C103A77556515FD3-8036
   Part No SW: 5K0 937 087 AJ    HW: 5K0 937 087 AJ
   Component: BCM PQ35 H+   122 0183
   Revision: BL122001
   Coding: EF200E1B982B08D4098804013400854800F1000645A00DB0E4806200AC70
   VCID: 7DFB50DBE4E88EA7CE-8028
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 300116 03  37  0059
   Coding: 0038DD
Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
   Part No SW: 7N0 907 572 B    HW: 7N0 907 572
   Component: ACC Bosch PQx H03 0120
   Serial number: 29011677110326
   Coding: 01001002FE0739
   ASAM Dataset: EV_ACCBEGVW361 001005
   ROD: EV_ACCBEGVW361_VW32.rod
   VCID: 356B88FB945896E746-8060
1058 - Databus
                    Reset counter: 4
                    Mileage: 92979 km
                    Date: 2020.02.21
                    Time: 00:01:59
                    Control Module temperature: 22 °C
                    Voltage terminal 15: 12.0 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1059 - Databus
                    Reset counter: 4
                    Mileage: 92979 km
                    Date: 2020.02.21
                    Time: 00:01:59
1043 - Automatic Distance Control
          B10E7 F0 [009] - Disconnected
                    Reset counter: 212
                    Mileage: 92651 km
                    Date: 2020.02.19
                    Time: 01:06:14
                    Control Module temperature: 59 °C
                    Voltage terminal 15: 12.2 V
0273 - Databus
                    Reset counter: 212
                    Mileage: 92651 km
                    Date: 2020.02.19
                    Time: 01:06:09
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    001 0207
   Serial number: 003RXM04EE5-
   Coding: 8CCCCC00000000005000001A020800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411_VW41.rod
   VCID: 63CF06A36A4C5857D8-8036
   Component: BF-Gewichtss.  H12 0021
   Serial number: IBH000000000004PKAT5
   Coding: 30324C
   Subsystem 2 - Part No SW: -----------    HW: 480 000 902 16
   Serial number: 35700000000CF485B81-
   Subsystem 3 - Part No SW: -----------    HW: 480 000 902 16
   Serial number: 358000000004547C191G
   Subsystem 4 - Part No SW: -----------    HW: 480 021 901 16
   Component: SideSensor_Dr  000 0148
   Serial number: 35100019B1E8F7F2B1DV
   Subsystem 5 - Part No SW: -----------    HW: 480 021 901 16
   Component: SideSensor_Pr  000 0148
   Serial number: 35200019B1E8F7F192DU
   Subsystem 6 - Part No SW: -----------    HW: 480 022 601 16
   Component: FrontSensor_D  000 0189
   Serial number: 35500019D1EA9B54684M
   Subsystem 7 - Part No SW: -----------    HW: 480 022 601 16
   Component: FrontSensor_P  000 0189
   Serial number: 35600019D1EA9B5587AV
                    Mileage: 92651 km
                    Date: 2020.02.19
                    Time: 01:06:10
   Part No SW: 1K5 953 521 CR    HW: 5K0 953 569 BF
   Component: LENKS.MODUL   018 0230
   Revision: FF010042    Serial number: 20160202201337
   Coding: 0002C40008
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 7F07AAD3E6E49CB7DC-802A
365080 - Controls in Steering Wheel
                    Reset counter: 221
                    Mileage: 93153 km
                    Date: 2020.02.23
                    Time: 19:47:52
Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
   Part No SW: 561 920 971     HW: 561 920 971
   Component: KOMBI         H04 1008
   Coding: 231E010000
   VCID: 58B5214F230A8B8FBD-800C
   Part No SW: 7N0 907 530 BG    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 J533  Gateway H56 16731673
   Revision:   H56       Serial number: 01031603010829
   Coding: 461010
   VCID: 76E94FF7C1DEDDFF8F-8022
No Faults Found
   Component: IMMO          H04 1008
   Coding: 000007
   VCID: 6AD16B878D66091F1B-803E
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 16000006656003
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3163BCEB6030BAC71A-8064
Address 3C: Lane Change (J1086)       Labels:. 5Q0-907-686.clb
   Component: HRE_Master    H12 0071
   Serial number: 0396640959
   Coding: 01011102
   ROD: EV_HREntryHella_VW27.rod
   VCID: 3C7D9DDFB77247AFB9-8068
No ASAM data for: "EV_HREntryHella" (VW41)
   Part No SW: 561 959 701 C    HW: 3C0 959 793 J
   Component: TUER-SG FT    002 0637
   Revision: 12100010    Serial number: 0010060535
   Coding: 0404BD
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1E39775701AE35BFB7-804A
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 C    HW: 561 959 811 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  022 1472
   Serial number: 14202746160229093954
131584 - Motor for Rear Window Regulator
          B11EE 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 212
                    Mileage: 92651 km
                    Date: 2020.02.19
                    Time: 01:06:09
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 311    3501
   Revision: 00H22000
   VCID: 397384CB70407287A2-806C
   Component: EZE_2         H56 1673
   Coding: 01030108
   VCID: 6FE77A93BE84EC374C-803A
   Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
   Component: J245 P05 9BA3  H08 0005
   Serial number: 53388786011534401999
   Coding: 181100
   Subsystem 2 - Part No SW: 561 919 204 C    HW: 561 919 204 C
   Component: Analoguhr  002 0002
   Part No SW: 561 959 702 C    HW: 3C0 959 792 J
   Component: TUER-SG BT    002 0637
   Revision: 14100010    Serial number: 0010295014
   Coding: 0405BC
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1F474A5306A43CB7BC-804A
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 C    HW: 561 959 812 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  022 1472
   Serial number: 14102747160322175737
                    Reset counter: 212
                    Mileage: 92651 km
                    Date: 2020.02.19
                    Time: 01:06:09
   Part No SW: 5C0 035 684     HW: 5C0 035 684
   Component: MU-S-NS-US    H22 0245
   Serial number: VWZAZ2S3726292
   Coding: 02140102FF00000051220001001808001F0100D400200105C6
   ROD: EV_MUStd4CTSAT_VW41.rod
   Subsystem 1 - Part No SW: 3G0 919 866 R    HW: -----------
   Component: NAR 2016  --- 0321
          B11CF 53 [009] - Deactivated
                    Reset counter: 212
                    Mileage: 92651 km
                    Date: 2020.02.19
                    Time: 01:07:36
                    Voltage terminal 30: 12.0 V
                    SDARS_tuner_status_2-Antenna current: 0 mA
                    SDARS_tuner_status_2-Reception quality: No_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 00
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 00
   Component: Batt.regelung H56 1673
   Coding: E1200859
   VCID: 71E37CEBA8B0FAC75A-8024
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0158
   Serial number: 000003554140547
   Coding: 02140102C24232107F1606000000
   ASAM Dataset: EV_OCULow 002010
   ROD: EV_OCULow_002.rod
   VCID: 142D157FFF626FEF11-8040
End-------------------------(Elapsed Time: 04:15)--------------------------
jettajim
C?ID=14954
More data:
There were no dash lights on prior to battery change
The rear passenger window did not always return to the close position
PetrolDave
Westbury, UK
C?ID=1423
I notice you have a module #61 for battery management, when you changed the battery did you tell this module with VCDS that you had changed the battery (by entering a different serial number)?
jettajim
C?ID=14954
PetrolDave,
No, I didn't know I had to do anything with VCDS after a battery change. I replaced it with an Interstate battery. What SN do I use?
PetrolDave
Westbury, UK
C?ID=1423
What SN do I use?
Just change one digit, any digit, from the value that's there - all the BEM needs to see is a different serial number for it to reset all it's power calculations and relearn for the new battery.
jettajim
C?ID=14954
I watched the Battery Coding video on Ross-Tech site. I don't have address 19 UDS. My channel 19 CAN was not like the one in the video. My address 61 had a Long Adaption 0A option with drop down box Battery Information/Replacement. Clicked on it and automatically went to channel 4. Had a 3 digit, 3 digit, 10 digit value. I increased the 10 digit value by 1, Test and Saved. Didn't change anything. Did a full scan, tried to clear codes but couldn't and took it for a 3 mile test drive. No change.
Thought maybe the multi-function steering wheel fuse was blown and did a search to locate it. During the search, I read about the clock spring. Cars with a bad clock spring experience the same issues I have; no horn, air bag light, buttons on wheel don't function. I do have the wrench on dash but need the steering wheel buttons to function in order to clear it. Wrench light was not on before battery change.
Maybe I need a longer test drive to work in AM?
This is my wife's car and she said the steering wheel as "clicking" the other day. This only happened once and was after the battery change. I thought it was the electro-mechanical steering?
Any other place to check?
Thanks, Jim
DV52
C?ID=194404
Jim: hmm........ I'm not an expert on the Passat, but relying solely on the hope that the dates in your autoscan can provide diagnostic insight - I note the following from your scan report:
Scan date= 2020.02.23
DTC dates:
Lots errors on 2020.02.19 -is this when you changed the Battery? Shirley not - were you up @ 01:06:10 hrs?
1 x DTC (module hex13) on 2020.02.21 (~ 00:02 hrs)
Have you tried clearing ALL DTCs and then repolling the modules to ascertain which errors remain?
