VW Golf MK5 Plus 1.6 FSi Engine Code BAG Fault Code P2295
nazdaq100
London, United Kingdom
C?ID=314050
Customer came in this evening with these faults especially P2295 comes back within a split second after clearing faults. I have also tried Engine OFF ignition ON (without Engine running) takes less then a second to pop up on faults.
Recently fully serviced with fuel filter air filter spark plugs, Also changed high pressure fuel pump from VW dealership!
Can you possibly tell us is there a fuse fault somewhere? (Short to Ground) where is this N276 located? What is the best way to narrow the problem down? check the wiring in fuse box any advise?
Saturday,22,February,2020,16:55:03:42869
VIN: WVWZZZ1KZ7W521169   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ7W521169   Mileage: 168260km-104551miles
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 906 056 DR    HW: Hardware No
   Component: MED9.5.10       G00 8803
   Revision: 66H08---    Serial number: VWZ7Z0F7059771
   Coding: 0000075
   Shop #: WSC 01392 785 00200
   VCID: 76B4177A94CD4AE7E39-8022
008853 - Fuel Pressure Regulator Valve (N276)
               P2295 - 002 - Short to Ground - MIL ON
                    Fault Status: 11100010
                    Mileage: 168186 km
                    Time: 11:31:33
                    RPM: 680 /min
                    Load: 23.9 %
                    Temperature: 84.0°C
008567 - Bank 1; System Too Lean off Idle
               P2177 - 001 -  - Intermittent
                    Fault Status: 00100001
                    Mileage: 168196 km
                    Time: 11:55:32
                    RPM: 1680 /min
                    Load: 56.8 %
                    Speed: 40.0 km/h
                    Temperature: 81.0°C
   Part No: 09G 927 750 BE
   Component: AQ 250 6F           0851
   Coding: 0000008
   VCID: 75B6107689CB41FFEA3-8020
Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
   Part No SW: 1K0 614 517 AC    HW: 1K0 614 517 AC
   Component: ESP FRONT MK60-AT   0102
   Revision: 00H14001
   Coding: 0021234
   Shop #: WSC 00004 210 90010
   VCID: 68884902CE79AC17615-803C
   Part No: 1K0 820 047 FH
   Component: Climatic PQ35   120 0606
   VCID: 6FBA221EEB977B2F20F-803A
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000005974171
   Coding: E48D0F2700041800000A00000F000000000859035C
   Shop #: WSC 01287 785 00200
   VCID: 2A0CF30A10F55E07B71-807E
   Subsystem 1 - Part No: 5M0 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 300606 020  0501
   Coding: 00038805
   Shop #: WSC 01287
   Subsystem 2 - Part No: 1K0 955 559 AD  Labels: 1K0-955-559-AF.CLB
   Component: RLS     290606 014  1201
   Coding: 06500389
   Shop #: WSC 01287
   Component: 1K AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0M72D7
   Coding: 0012619
   Shop #: WSC 01372 785 00200
   VCID: 3D26C856F17BD9BFE23-8068
   Subsystem 1 - Serial number: 6332MSME125C6832A
   Subsystem 2 - Serial number: 6342MSME12101F2C6
   Subsystem 3 - Serial number: 6351HSME0A3949114
   Subsystem 4 - Serial number: 6361HSME0A3F452EL
   Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
   Component: Lenksäulenmodul 035 0070
   Coding: 0010042
   VCID: 005871A2C6097457C95-8054
   Part No SW: 1K0 920 963 A    HW: 1K0 920 963 A
   Component: KOMBIINSTRUMENT VDD 1610
   Revision: V0003000    Serial number: VWZ7Z0F7059771
   Coding: 0003403
   Shop #: WSC 00581 067 57207
00771 - Fuel Level Sensor (G)
                    Fault Status: 00100011
                    Reset counter: 125
                    Mileage: 167658 km
                    Time: 11:24:14
                    Fault Status: 00101010
                    Reset counter: 110
                    Mileage: 167058 km
                    Time: 11:28:17
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 31001067010FFE
   Coding: 3F3F034007009003
   VCID: 2C00F5121A01403745D-8078
   Component: IMMO            VDD 1610
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 99887 km
                    Time: 10:50:28
   Component: Tuer-SG         005 0974
   Coding: 0000692
   VCID: 3828D942DE59FC97315-806C
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.069 H07 1806
   Shop #: WSC 00000 028 00001
   VCID: 3536D076C94B01FF2A3-8060
   Component:    KSG PQ35 G2  020 0202
   Coding: 019002005103087F2D04840570085FC690F8A0
   VCID: 03527EAED71F6F4FD47-8056
   Subsystem 2 - Component:       NGS No Answer
   Subsystem 3 - Component:      IRUE No Answer
00950 - Central Locking Motor - tailgate (V53); UNLOCK
                    Fault Status: 00100111
                    Reset counter: 135
                    Mileage: 167972 km
                    Time: 15:45:26
01134 - Alarm Horn (H12)
                    Fault Frequency: 7
                    Reset counter: 94
                    Mileage: 77152 km
                    Time: 10:58:04
                    Fault Frequency: 22
                    Reset counter: 94
00323 - Vehicle Inclination Sensor (G384)
                    Fault Frequency: 16
                    Reset counter: 94
   Coding: 0000692
   VCID: 392EDC46E553E59FCEB-806C
   Part No: 5M0 035 186 B
   Component: Radio GR0       019 0023
   Revision: 0001905S    Serial number: VWZ2Z2F1176968
   Coding: 0040400
   VCID: 2B02F60E1F0F470F4C7-807E
   Component: Tuer-SG         005 0914
   Coding: 0000144
   Shop #: WSC 01392 785 1012552
00934 - Electric Window Motor; Rear Left (V26)
00098 - Rear Left Central Locking (Safe) Motor (V163)
   Coding: 0000144
00935 - Electric Window Motor; Rear Right (V27)
End----------(Elapsed Time: 01:08, VBatt start/end: 12.6V/12.5V)-----------
I love FOD stories thank you OP but I live spiral wrap more to prevent it!
