Audi A4 Tfsi 1.8 petrol 2013
jerzy
C?ID=303197
Can anybody help, I have 1 Fault,on the Control Circuit for Coolant
bypass Valve its Open Circuit. where can I find it with pictures.Please
Saturday,22,February,2020,11:23:35:39116
VIN: WAUZZZ8K7DA222393   License Plate:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 62 72 77
VIN: WAUZZZ8K7DA222393   Mileage: 57720km-35865miles
Address 01: Engine (J623-CJEB)       Labels:. 06L-906-264-CJE.clb
   Part No SW: 8K0 906 264 A    HW: 8K0 906 264
   Component: 1.8l R4 TFSI  H07 0004
   Revision: --H07---
   Coding: 12030032242501022000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM18TFS0218K0906264A 001004
   ROD: EV_ECM18TFS0218K0906264A.rod
   VCID: 2F381AF68794C0BF60F-807A
15462 - Control Circuit for Coolant Bypass Valve
          P2681 00 [172] - Open Cricuit
                    Fault Frequency: 122
                    Mileage: 57598 km
                    Date: 2020.02.18
                    Time: 14:58:10
                    Engine speed: 1899.00 /min
                    Normed load value: 40.4 %
                    Vehicle speed: 42 km/h
                    Coolant temperature: 87 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 14.609 V
                    Engine: operating status: PL
                    Engine temp. management actuator: raw value: 1931
                    Engine temperature management actuator: stop open: 136
                    Engine temperature management actuator: after-run stop: 3950
                    RVC_SP: 119.50 °
                    RVC_AV: 120.00 °
                    RVCPWM: 0.000 %
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K5 927 155 Q    HW: 0AW 927 156 K
   Component: 0AW 18TFSIRdW H05 0001
   Revision: --H05---    Serial number: 0000000684
   Coding: 000002
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMVL381 A02432
   ROD: EV_TCMVL381.rod
   VCID: 46D65F52082E61F7B39-8012
   Part No SW: 8K0 907 379 CG    HW: 8K0 907 379 CG
   Component: ESP8 front    H09 0100
   Coding: 051544
   VCID: 005A894A6A0A8FC7C95-8054
   Part No SW: 8K0 907 064 GC    HW: 8K0 907 064 FC
   Component: BCM2 2.0      H12 0633
   Coding: 01B24040000000000000
   VCID: 77A8E2963FC4C87FF8F-8022
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0813000029141013
   Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
   Serial number: 2313000032152004
   Part No SW: 8K2 820 043 S    HW: 8K2 820 043 S
   Revision: D0000000    Serial number: 01050320132246
   Coding: 642402C000
   VCID: 392C24AE49501E0FCEB-806C
   Part No SW: 8K0 907 063 DC    HW: 8K0 907 063 DC
   Revision: 03016001    Serial number: 00000564626302
   Coding: 290000308034A7C00081000000001F1F001D460827080201000008004000020000000020000000
   VCID: 73B0D6862BBCA45FC47-8026
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 280213  H06 0080
   Serial number: SWF13020280144
   Coding: 00FD11
   Serial number: 21060597
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000103130458
   Serial number: D6184896000000000001
   Serial number: 003KFD98U90L
   Coding: 30534435363030303030554A3052384B3053
   Shop #: WSC 34713 001 1048576
   VCID: 48CA516A023A7787415-801C
   Serial number: 6334MSME76244B13B
   Serial number: 6344MSME7624377CM
   Serial number: 6352QSME3E290952L
   Serial number: 6362QSME7026336CH
   Serial number: 63732SME4D2C2948A
   Serial number: 63832SME512C57683
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20130311000987
   Coding: 000017
   VCID: 4FF87A76E7D4A0BF00F-801A
   Part No SW: 8K0 920 982 C    HW: 8K0 920 982 C
   Component: KOMBIINSTR.   H35 0556
   Revision: 00400000    Serial number: UVM59ZC3E
   Coding: 3386100002012600010000
   VCID: 3432159A6E32E3671DD-8060
   Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0055
   Revision: 1V070026    Serial number: 2641V13227818C
   Coding: 80CF07FF00
   VCID: 48CA516A02BA7787415-801C
   Serial number: 9342140103
   Serial number: 13064000332021200181
   Part No SW: 8K0 959 793 S    HW: 8K0 959 793 Q
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000054034523
   Coding: 011002204001410001
   VCID: 50FA790AFAEABF47195-8004
   Revision: 00001000    Serial number: 0004246404
   Coding: 100000000001
   Shop #: WSC 06334 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3432159A6EB2E3671DD-8060
   Revision: 00002001    Serial number: 0300466936
   Coding: 013B062220B90000803002368000000F
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8R0 035 223 G    HW: 8R0 035 223 E
   Component: DSP STD       H11 0460
   Revision: 00000000    Serial number: 00000000000001
   Coding: 0203010102
   VCID: 303A198A9A2ADF47795-8064
   Part No SW: 8K0 959 792 S    HW: 8K0 959 792 Q
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000054065080
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 00000001267433
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 382A21AA72DA0707315-806C
   Part No SW: 8R2 035 186 N    HW: 8R2 035 186 N
   Component: Concert3      H05 0470
   Revision: 00000002    Serial number: AUZ5Z6M1866122
   Coding: 0502008201028D00035B071000
   VCID: 41DC4C4E218046CF86B-8014
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
   Revision:             Serial number: 0000053951009
   Coding: 010002204001210001
   VCID: 46D65F5208AE61F7B39-8012
   Revision:             Serial number: 0000053952091
   Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005629881
   Coding: 0010320
   VCID: 3D2430BE5178222FE23-8068
End----------(Elapsed Time: 01:36, VBatt start/end: 12.5V/12.2V)-----------
The RTFB will have it and most likely a component finder when identified or searched in WD, no?
Did you try to search for " coolant bypass " yet online?
Maybe a review of SSP?
JPPSG
Jef
HQ
This looks to be for the N422, which may also be refereed to as the N82. It can be in a few different locations depending on the vehicle. I suspect this is close to the engine bay bulkhead and may look like this:
See if you can locate it and inspect the terminals. It seems these things can leak and rot out the terminals.
jerzy
C?ID=303197
thank you for the photo.
Jacek
Poland
C?ID=360566
