Hello all. A bit past the point of frustration so I am hoping you all can help me with this retrofit.
2012 Volkswagen Jetta Sportwagen 2.5L SE
RNS510 (Revision E)
Purchased an OEM backup camera retrofit kit but I cant get it to work.
I did remove the camera cap.
I did select the backup camera option using VAG-COM. 'Back-Up Camera Low (without Control Module) installed' was my only option.
I did reset the radio using the <>* buttons after I selected the back up camera option.
I just get a black screen when I put it in reverse. I then checked and rewired the power and backup camera lights a few times just in case I made an error.
Voltmeter shows me 12V from the red power cable and 11.8V from the blue reverse light. This is measured at the rear camera where the connector plugs in when the vehicle is on and reverse lights on.
What I found odd was that my ground (brown wire) also shows me 12v when I check it. Some searches I conducted said this was normal but my father said I shouldn't see any voltage on a ground. I'm not an electrician though but I thought that was true as well. Should I see power on a ground wire? The ground wire is completely separated from the rest of the wires so if that's the problem it must be a short in the harness connector... I would think.
Here is the autoscan:
RNS510 (Revision E)
Thursday,06,February,2020,18:48:54:13723
VCDS Version: 19.6.2.0 (x64)
VIN: 3VWPP7AJ0CM690518 License Plate: ROSSTECH
Mileage: 108800km-67605mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 37 42 44 46 4F 52 56 62
72 77
VIN: 3VWPP7AJ0CM690518 Mileage: 108800km-67605miles
1C-Position Sensing -- Status: Cannot be reached 1100
2E-Media Player 3 -- Status: Malfunction 1010
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 CL HW: 07K 907 309 B
Component: 2,5l R5/4V G01 5860
Revision: T4H06--- Serial number:
Coding: 0000075
Shop #: WSC 55227 003 1048576
VCID: 7AD503F635EAC29FE9-802E
000262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 - 000 - Implausible Signal - Intermittent
Mileage: 108201 km
Date: 2014.06.25
Time: 05:10:17
RPM: 1578 /min
Load: 29.4 %
Speed: 78.0 km/h
Temperature: 83.0°C
Temperature: 24.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.097 V
049409 - No Communication with Transmission Control Module
U0101 - 000 - - Intermittent
Date: 2047.15.31
Time: 31:63:63
Load: 0.0 %
Temperature: 91.0°C
Temperature: 48.0°C
Voltage: 12.319 V
Part No SW: 09G 927 750 LM HW: 09G 927 750 LM
Component: AQ 250 6F 1919
Revision: 00H90000 Serial number:
Coding: 0000840
Shop #: WSC 00066 000 00000
VCID: 07336A027618AF77E6-8052
Fault Status: 00101101
Fault Frequency: 18
Reset counter: 34
Revision: 00H31001
Coding: 114B400C492B00FA881002E592210041B70000
VCID: 7DDF08EAE4C4F5A7CC-8028
Reset counter: 224
Mileage: 108201 km
Date: 2014.06.25
Time: 05:10:17
Count: 32768
Count: 4608
Count: 8193
Count: 50945
Count: 1277
Reset counter: 193
Mileage: 108809 km
Date: 2014.06.29
Time: 16:52:59
Count: 14
Count: 28672
Count: 8195
Count: 44288
Count: 503
Reset counter: 193
Mileage: 108167 km
Date: 2014.06.25
Time: 00:02:39
Count: 2
Count: 14
Count: 28672
Count: 16390
Count: 43008
Count: 501
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0404
Revision: 00001018
Coding: 0000001002
Shop #: WSC 00066 000 00119
VCID: 0021711E9B36984FA7-8054
Part No SW: 5K0 937 084 J HW: 5K0 937 084 J
Component: BCM PQ35 B 021 0064
Revision: BG021001
Coding: 2F380E1F802F3EC4008800C17000004449000086435D0D60648020200040
VCID: 3957DCFAB06C0987A0-806C
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 07041 26 0512
Coding: 009795
00059 - Terminal 30 for Interior Lighting
Fault Status: 00101011
Reset counter: 225
Term 15 Off
Voltage: 12.60 V
00061 - Footwell Lights
Fault Status: 00101010
Reset counter: 225
Mileage: 108386 km
Date: 2014.06.26
Time: 18:43:45
Term 15 Off
Voltage: 12.60 V
Reset counter: 233
Mileage: 108809 km
Date: 2014.06.29
Time: 16:53:01
Term 15 On
Voltage: 12.25 V
01565 - Luggage Compartment Light (W3)
Reset counter: 222
Mileage: 108167 km
Date: 2014.06.25
Time: 00:02:31
Term 15 On
Voltage: 11.90 V
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA1L6RD
Coding: 00003133
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3FA3B2E2A64827B79E-806A
Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--00003V3T00
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3572MSME7C5A146BZZZ6
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3582MSME2568146BZZZ.
Serial number: 3511HSME4248402BZZZG
Serial number: 3521HSME2C733B2BZZZX
Serial number: 35527SME341C092BZZZI
Serial number: 35627SME27433A2BZZZJ
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422LBN001ET
Coding: 188A140000
Shop #: WSC 00066 000 00185
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76CD17C6C9F2A6FF8D-8022
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Serial number: 0142205
Coding: 820000
0516 - Databus
Reset counter: 233
Mileage: 108809 km
Date: 2020.02.06
Time: 16:52:59
Part No SW: 5K0 920 972 B HW: 5K0 920 972 B
Component: KOMBI H03 0607
Coding: 270F01
VCID: 2F43E2A27628D7370E-807A
12648704 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 233
Mileage: 108809 km
Date: 2020.02.06
Time: 16:52:59
Part No SW: 7N0 907 530 P HW: 1K0 907 951
Component: J533 Gateway H40 1623
Revision: H40 Serial number: 26031201290052
Coding: 352002
Shop #: WSC 00066 123 12345
VCID: 3D5FC8EAA44435A78C-8068
Fault Status: 00110100
Reset counter: 233
Mileage: 108809 km
Date: 2014.06.29
Time: 16:52:59
01304 - Radio
Reset counter: 225
Mileage: 108365 km
Date: 2014.06.26
Time: 16:23:14
Fault Frequency: 111
Mileage: 108167 km
Date: 2014.06.25
Time: 00:00:02
00484 - Vehicle Position Recognition Control Module (J603)
Reset counter: 182
Mileage: 108166 km
Date: 2014.06.24
Time: 19:39:28
Fault Status: 01110100
Reset counter: 185
Mileage: 108386 km
Date: 2014.06.26
Time: 20:47:44
03272 - Control Module for Audio Interface
Reset counter: 225
Mileage: 108386 km
Date: 2014.06.26
Time: 17:51:05
Address 1C: Position Sensing
Component: IMMO H03 0607
VCID: 6AF533B68D4A721F19-803E
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7661973805
VCID: 29770CBA40CCB907D0-807C
01304 - Radio
Reset counter: 225
Mileage: 108365 km
Date: 2014.06.26
Time: 16:23:14
Part No SW: 3C0 035 684 J HW: 3C0 035 684 E
Component: RNS-MID H59 4366
Revision: AB001001 Serial number: VWZ6Z7L8240032
Coding: 04000442040000840005
VCID: 2A75F3B645CAB21FD9-807E
Component: NAR V12 8534
Reset counter: 193
Mileage: 108808 km
Reset counter: 233
Mileage: 108808 km
01523 - Microphone for Telephone (R38)
Fault Status: 01101011
Reset counter: 193
Mileage: 108809 km
Date: 2014.06.29
Time: 17:45:51
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0004333836
Coding: 0004B5
Shop #: WSC 01383 790 50316
VCID: 5B9B667252101B9792-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 008 1509
Serial number: 00000006521152
Coding: 000490
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 3753DAC246781FF756-8062
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1623
Coding: 050B0500
VCID: 6FC322A2BEA897374E-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H03 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H03 0220
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0004335466
Coding: 0004B4
VCID: 5C99656E571E1CAF9B-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 007 1509
Serial number: 00000006342257
Coding: 000490
67589 - Turn Signal in Exterior Mirror
B11FD 01 [009] - Electrical Failure
Reset counter: 180
Mileage: 102825 km
Date: 2019.11.27
Time: 13:40:05
Reset counter: 193
Mileage: 108808 km
Reset counter: 233
Mileage: 108808 km
Reset counter: 193
Mileage: 108809 km
Date: 2014.06.29
Time: 17:45:51
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661927999
Coding: 0A10040000010100
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 27730A825ED88F77C6-8072
0022 - Radio
U1066 00 [008] - No Communication
Reset counter: 225
Mileage: 108365 km
Date: 2020.02.03
Time: 16:23:09
End-------------------------(Elapsed Time: 02:33)--------------------------
