Hi Wonder if anyone can make sense of this Came in with handbrake stuck on
Full Scan from VCDS
Full Scan from VCDS
VCDS Version: 19.6.2.0 (x64)
VIN: WVWZZZAUZFW013374 License Plate:
Mileage: 113188km-70331mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F A9
VIN: WVWZZZAUZFW013374 Mileage: 113188km-70331miles
Address 01: Engine (J623-CUNA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 EP HW: 04L 907 309 A
Component: R4 2,0L EDC H22 7539
Revision: 81H22---
Coding: 01190012032505082000
ASAM Dataset: EV_ECM20TDI01104L906021EP 002008
ROD: EV_ECM20TDI01104L906021AE.rod
VCID: 77F601A1CE479FF796-8022
17158 - Databus
U1123 00 [047] - Received Error Message
Mileage: 113188 km
Date: 2019.12.06
Time: 09:37:53
Coolant temperature: 78 °C
Intake air temperature: 55 °C
Voltage terminal 30: 12.140 V
Drivetrain coordinator: brake fault status-Bits 0-7: 4
Drivetrain coordinator: brake function status-Bits 0-7: 0
Acceleration: 0.000 m/s²
U0428 00 [047] - -
Mileage: 113188 km
Date: 2019.12.06
Time: 00:00:15
Coolant temperature: 34 °C
Intake air temperature: 31 °C
Voltage terminal 30: 12.160 V
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 61334000000611
Coding: 01FA8AA13421096F037A060741C72980512C90C0608294F500600078C009
VCID: 458ABB69C42B3D67D4-8010
11 Faults Found:
0072 - Rear Left Wheel Speed Sensor
C101C 01 [137] - Electrical Failure
Reset counter: 73
Mileage: 113188 km
Date: 2019.12.09
Time: 03:04:36
0088 - Rear Right Wheel Speed Sensor
C101D 01 [137] - Electrical Failure
Reset counter: 73
Mileage: 113188 km
Date: 2019.12.09
Time: 03:04:36
0105 - ABS Hydraulic / Return Flow Pump
C1077 01 [008] - Electrical Failure
Reset counter: 113
Mileage: 113188 km
Date: 2019.12.09
Time: 03:34:58
0297 - Steering angle sensor
B1168 16 [137] - Voltage Too Low
Reset counter: 73
Mileage: 113188 km
Date: 2019.12.09
Time: 03:04:36
Reset counter: 73
Mileage: 113188 km
Date: 2019.12.09
Time: 03:04:45
32830 - Parking Brake Motors
C10E1 29 [137] - Signal Implausible
Reset counter: 73
Mileage: 113188 km
Date: 2019.12.09
Time: 03:04:36
32900 - Left Parking Brake Motor Voltage Supply
C100D 13 [137] - Electrical Malfunction
Reset counter: 73
Mileage: 113188 km
Date: 2019.12.09
Time: 03:04:36
32951 - Control Module for Electronic Parking Brake
C10E2 54 [137] - Missing Calibration / Basic Setting
Reset counter: 73
Mileage: 113188 km
Date: 2019.12.09
Time: 03:04:36
32977 - Function Restriction
C10C2 F0 [009] - Emergency Brakes not Available
Reset counter: 73
Mileage: 113188 km
Date: 2019.12.06
Time: 08:58:40
32992 - Control Module for Electric Parking Brake
C10E2 F0 [137] - RPM Sensor Implausble Signal
Reset counter: 73
Mileage: 113188 km
Date: 2019.12.09
Time: 03:04:36
32994 - Control Module for Electric Parking Brake
C10E2 F0 [009] - RPM Sensor Implausble Signal
Reset counter: 73
Mileage: 113188 km
Date: 2019.12.09
Time: 03:04:36
