Greetings from Amsterdam
Leon1978
NL
C?ID=160349
Hi all,
this is my first post here on the forum. I am a vcds user since 2012. Then I bought my first VAG car, a Audi A4 B7. Since one month now I've bought another car, it is a Seat Leon 5F. The autoscan is below:
Saturday,18,January,2020,14:43:25:21183
VCDS Version: 18.9.1.0 (x64)
VIN: VSSZZZ5FZGR026591   License Plate: GV-464-R
Mileage: 155796km-96807mi   Repair Order:
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F 69
VIN: VSSZZZ5FZGR026591   Mileage: 155796km-96807miles
Address 01: Engine (J623-CZEA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HF    HW: 04E 907 309 BJ
   Component: R4 1.4l TFS   H22 2326
   Revision: R6H22---
   Coding: 01190032242419080000
   Shop #: WSC 00049 770 00194
   ASAM Dataset: EV_ECM14TFS01104E906027HF 001004
   ROD: EV_ECM14TFS01104E906027HF.rod
   VCID: 6FED68D7B6CFB33234-803A
   CAN Converter 01:
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 61585000003131
   Coding: 20EE6A9224222972007C060941C4240456249400608224F200210070C002
   Shop #: WSC 00049 770 00199
   VCID: 4B95DC47E297AF1278-801E
   Part No SW: 5F0 907 044 H    HW: 5F0 907 044 H
   Component: Climatronic   H04 0911
   Revision: 00001K09
   Coding: 00000004200100011005000000101000
   Shop #: WSC 00049 770 00103
   VCID: 2B55BCC742578F1258-807E
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0173
   Serial number: 01061516803412
   Coding: 08020A42424102FB4BE44000400403281000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 0919264FA86BFD028A-805C
   Subsystem 1 - Part No SW: 5F1 955 119 A    HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 150508  041 0574
   Serial number:         150607064453
   Coding: 0BC5FD
   Component: RLHS  037 0059
   Serial number: S4Y15M06D24H21M51S36
   Coding: 00095D
203016 - Unlock Switch in Rear Lid Handle
          B140B 29 [008] - Signal Implausible
                    Fault Frequency: 25
                    Reset counter: 228
                    Mileage: 153901 km
                    Date: 2019.12.24
                    Time: 12:26:08
   Revision: --------    Serial number: 39311518102138
   Coding: 0031151101
   VCID: 4385F467CAC7675280-8016
   Part No SW: 3Q0 959 655 AS    HW: 3Q0 959 655 AS
   Component: Airbag VW20   013 0200
   Revision: --------    Serial number: 003SQPCUE5DR
   Coding: 98CCC000000000005C0000CC000800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 0F2D0857D60FD33254-805A
   Subsystem 1 - Part No SW: -----------    HW: 454 001 006 15
   Serial number: 3576U0000006507CA41A
   Subsystem 2 - Part No SW: -----------    HW: 454 001 006 15
   Serial number: 3586U00000092C01E419
   Subsystem 3 - Part No SW: -----------    HW: 454 800 607 15
   Serial number: 3516R6F5567070000007
   Subsystem 4 - Part No SW: -----------    HW: 454 803 006 15
   Serial number: 3526RF8D45407000000D
   Subsystem 5 - Part No SW: -----------    HW: 454 800 806 15
   Serial number: 3556V7DE42207000000D
   Part No SW: 5Q0 953 507 GD    HW: 5Q0 953 549 F
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 22061504400049
   Coding: 1400
   ROD: EV_SMLSKLOMQB_012_AU37.rod
   VCID: 7EF34593E1A5CABAAF-802A
   Part No SW: 5F0 920 873     HW: 5F0 920 873
   Component: KOMBI         303 6420
   Coding: 07A402002980000800086A001000000000000000
   VCID: 68DF03CB9321640A75-803C
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1223
   Revision: --------    Serial number: 0003697200
   Coding: 030100F42F085700EB0002C8080F00010001050000000000000000000000
   VCID: 75E15ABFD49389E2FE-8020
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Serial number: 000000000A0232040615
   Coding: 002000
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185703001506161468
   Serial number: 0000155769737
   Coding: 00100320DC00040000001000
   VCID: 479DE077FEFF4B725C-8012
   Serial number: 00000000000006502431
   Coding: 310000
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 8103
   Serial number: 0000155777673
   Coding: 00100320DE00040000001000
   VCID: 4683ED73F9F5527AA7-8012
   Serial number: 00000000000006446384
   Coding: 290000
   Coding: 048A000009000000
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
   Part No SW: 5QA 035 858     HW: 5QA 035 858
   Component: MU-S-ND-ER    H24 0241
   Serial number: SEZAZ2R0262782
   Coding: 04730001D70A000011111101008808002F0201D40120010046
   ASAM Dataset: EV_MUStd6C1TSAT 001015
   ROD: EV_MUStd6C1TSAT_SK25.rod
   VCID: 0407377B8F49A06AF9-8050
   Subsystem 1 - Part No SW: 5F0 919 604 A    HW: 5F0 919 604 A
   Component: ABTm_Std2_Nav  H43 1028
   Serial number: SEZ8Z9RFT005VX
   Subsystem 2 - Part No SW: 6P0 919 866 M    HW: -----------
   Component: ECE1 2017  --- 0730
   Part No SW: 5Q0 907 383 E    HW: 5Q0 907 383 B
   Component: Anhaenger     H14 0137
   Revision: 8C001002    Serial number: 0372823052
   Coding: 0100000202000000
   VCID: 3979968FB80B2D82DA-806C
656138 - Bulb for Right Tail Light on Trailer
          C10F4 15 [009] - Open or Short to Plus
                    Reset counter: 147
                    Mileage: 153901 km
                    Time: 00:00:00
End-------------------------(Elapsed Time: 04:14)--------------------------
Currently I am busy finding out what needs to be done to install a factory amplifier (5Q0035456A) in my car with the additional speakers. Currently I am not satisfied with the sound quality, so I want to change the speakers, add an amplifier, and a centre speaker and subwoofer. For that I need to couple the amplifier to the control unit. I think the connections are done through the quad connector and a MOST line. This will be my first project to this car.
greetings from the Netherlands
