VW Touareg L2 - V6 3.0 TFSI - Model 2020
Baggeraar
Belgium
C?ID=365581
We are working on a new vehicle, transport mode is still activated.
VCDS software mentioned "No ROD file found" I presume this is the correct way to upload this?
FYI; we had the passenger side airbag switch disconnected; and the rear right tailgate light.
Thursday,02,January,2020,10:01:57:46447
VIN: WVGZZZCRZLD021107   License Plate:
Mileage: 12km-7mi   Repair Order:
Chassis Type: CR-VW53 (4N2)
Scan: 01 02 03 06 09 13 15 16 17 19 2B 36 3C 42 44 46 52 5F 65 69
          6C 74 81 A5 BB BC CF D6 D7
VIN: WVGZZZCRZLD021107   Mileage: 12km-7miles
74-Chassis Control -- Status: Malfunction 0010
Address 01: Engine (J623-DCBE)       Labels: None
   Part No SW: 760 907 559 G    HW: 06M 907 309 G
   Component: V6 3.0l TFSI  H11 0001
   Revision: B8H11000
   Coding: 292A4032257E050B35280000000400000000000000000000
   Shop #: WSC 31414 041 00001
   ASAM Dataset: EV_ECM30TFS011760907559G 001001
   ROD: N/A
   VCID: 270BFAFECF6642CFA8D-8072
No ASAM data for: "EV_ECM30TFS011760907559G" (VW53)
Readiness: 0010 0001
Address 02: Auto Trans (J217)       Labels:* Redir Fail!
   Part No SW: 760 927 158 M    HW: 0D5 927 156 N
   Component: 0D5  30TSIRdW H05 1002
   Revision: --H05---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002015
   ROD: EV_TCMALX52011.rod
   VCID: 2A0D03CADC747FA7B73-807E
   Part No SW: 4M6 907 379 AF    HW: 4M6 907 379
   Component: ESP9 Premium  H06 0857
   Coding: 25A715B730A40B97D69F4891188412EAE93AE9A4A80CD06B12184857975C97
   ASAM Dataset: EV_ESP9BOSCHCMP 004011
   ROD: EV_ESP9BOSCHCMP_VW53.rod
   VCID: 015F846601825CFFC69-8054
297728 - Transport Mode Active
          U1105 00 [040] - -
          [Transport_Mode_is_activated]
                    Mileage: 5 km
                    Date: 2019.11.28
                    Time: 13:27:13
   Part No SW: 4M6 959 760 B    HW: 4M6 959 760 B
   Component: MEM-BFS       009 0044
   Serial number: 00000396925118
   Coding: 0118B0000000A88188000101210100008900000707008F8F00000000215000
   Shop #: WSC 31414 044 00001
   ROD: EV_SCMPasseSideCONTIAU736_VW53.rod
   VCID: 3D2738963DFAF81FE21-8068
   Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
   Component: N477 VB1 BFSv  H04 0011
   Serial number: SJ8001271019402585A2
   Coding: BF2F00
   Part No SW: 4N0 907 063 KG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0691
   Coding: 07501143E1790009070D170858BE8041030B31100000009301100800B90476011BC5003B1257011000000100009320181800000001010100000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016_VW53.rod
   VCID: 7DA7F8967D7A381FA21-8028
   Subsystem 1 - Part No SW: 761 955 113     HW: 761 955 113
   Component: WIPER 161119  011 0420
   Serial number: VZ1SKA 1000295161119
   Serial number: 23890321X81A955555A0
   Coding: 02006D
   Light switch:
   Subsystem 3 - Part No SW: 761 941 633     HW: 761 941 633
   Component: E1 - LTM  H06 0054
   Serial number: 14S19.11.1900140473
   Subsystem 4 - Part No SW: 3G0 857 511 AL    HW: 3G0 857 511 AL
   Serial number: GX1CE109081920810379
   Interior Light Module:
   Subsystem 5 - Part No SW: 760 947 105 N    HW: 760 947 105 N
   Component: Dachelektroni  H32 0057
   Serial number: 00000960690000000000
   Part No SW: 760 907 561 C    HW: 760 907 561 A
   Component: LRR4R         H04 0333
   Coding: 32657FDA58000400000020A000000010051246484401009E00
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_VW53.rod
   VCID: 1C61D5128620911735F-8048
0110 - Transport Mode Active
          U1105 00 [008] - -
          [FAULT_SYC_TRANSPORTMODE_ACTIVE]
                    Reset counter: 40
                    Mileage: 5 km
                    Date: 2019.11.28
                    Time: 13:27:11
                    Control Module temperature: 40 °C
                    Voltage terminal 15: 12.3 V
                    Steering_angle-Data: -8.200 °
                    Yaw_rate-Data: 0.000 rad/s
                    adjustment_calculation: On
                    Misalignment angle: horiz: 0.033 °
                    Misalignment angle: horiz: fast algorithm: 0.003 °
                    Congestion pilot: status: OFF
                    Outside air temperature: 16.00 °C
                    Sensor blindness: radar: no blindness detected
   Part No SW: 4M0 959 655 R    HW: 4M0 959 655 R
   Component: AirbagVW31    H17 2730
   Serial number: 00327M00N91O
   Coding: 88CCC0C00C800000585400EF300D79A80065
   Shop #: WSC 31414 029 00001
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 4ACD634A7C345FA7573-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 001 311 19
   Serial number: 357000000009594CF14V
   Subsystem 2 - Part No SW: -----------    HW: 480 001 311 19
   Serial number: 3580000000039974C14M
   Subsystem 3 - Part No SW: -----------    HW: 480 031 511 19
   Component: SideSensor_Dr  002 0149
   Serial number: 351002C00540F8C05BEB
   Subsystem 4 - Part No SW: -----------    HW: 480 031 511 19
   Component: SideSensor_Pr  002 0149
   Serial number: 352002C00E8DDA605EDY
   Subsystem 5 - Part No SW: -----------    HW: 480 032 510 19
   Component: FrontSensor_D  002 0189
   Serial number: 355001C2495476403E64
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 480 032 510 19
   Component: FrontSensor_P  002 0189
   Serial number: 356001C2491276113BE2
   Pedestrian Protection Driver:
   Subsystem 7 - Part No SW: -----------    HW: 480 033 110 19
   Component: PedP_Sensor_D  002 014A
   Serial number: 228002C00E7D92812AFL
   Subsystem 8 - Part No SW: -----------    HW: 480 032 011 19
   Component: PedP_Sensor_P  002 014A
   Serial number: 229002C00E80D590CB8L
   Pedestrian Protection Center:
   Subsystem 9 - Part No SW: -----------    HW: 480 030 511 19
   Component: PedP_Sensor_C  002 014A
   Serial number: 230002C00E78D860FF9S
   Subsystem 10 - Part No SW: -----------    HW: 480 002 110 19
   Serial number: I0M000000001F57970CA
   Subsystem 11 - Part No SW: -----------    HW: 480 002 110 19
   Serial number: I0N000000008085970C4
9445397 - Key switch for deactivation of passenger-side airbag
          B1020 15 [137] - Open or Short to Plus
                    Mileage: 12 km
                    Time: 00:00:00
9446677 - Redundant signal path for airbag shut-off; passenger side
          B1025 15 [137] - Open or Short to Plus
                    Mileage: 12 km
                    Time: 00:00:00
   Part No SW: 760 953 507     HW: 760 953 507
   Component: Lenks.Modul   H03 0006
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 5AED930ACC942F27E73-800E
   Part No SW: 760 920 770 A    HW: 760 920 770 A
   Component: TBenRDW------ H07 0445
   Coding: 85A430C27E8C000800A8632EF0E06808E40000A0
   ASAM Dataset: EV_DashBoardAU65X 001017
   ROD: EV_DashBoardAU65X_VW53.rod
   VCID: 176BCA3E7F06F24F18D-8042
   Operating Unit Drive Mode Selection:
   Subsystem 1 - Part No SW: 760 927 531 G    HW: 760 927 531 G
   Component: E881 BedieFPA  001 0460
   Serial number: 000000091171SK4000DT
   Level control system control head:
   Subsystem 2 - Part No SW: 760 927 135 B    HW: 760 927 135 B
   Component: E281 BedieNiv  001 0110
   Serial number: 000000091171SK6000OJ
   Part No SW: 4N2 907 468 BL    HW: 4N2 907 468 AB
   Component: Gateway       H16 0063
   Revision: CM010002    Serial number: 028CM504819B18
   Coding: 0301000300000E405407000000DB0532589E000708000000037D078E10000100
   ASAM Dataset: EV_CGateCONTIAU491 004190
   ROD: EV_CGateCONTIAU491_004_VW53.rod
   VCID: 04518D721E9049D7EDF-8050
   Subsystem 1 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H18 0052
   Serial number: 39190002855760069422
   Coding: 2DFFFF
   Serial number: 5241373105
527872 - Transport Mode Active
          U1105 00 [008] - -
          [transport_mode_aktive]
                    Reset counter: 40
                    Mileage: 5 km
                    Date: 2019.11.28
                    Time: 13:27:12
131699 - Control unit for information electronics 1
          U1054 00 [008] - No Communication
          [Timeout_Node_0x73_DiagAdress_5F_ZR_High]
                    Reset counter: 40
                    Mileage: 9 km
                    Date: 2019.12.17
                    Time: 14:48:12
9458950 - Telematics Module
          U13EB 00 [008] - Flight mode activated
          [eCall_activation_service_mode]
                    Mileage: 5 km
                    Date: 2019.11.28
                    Time: 13:26:43
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 19000309542014
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW41.rod
   VCID: 34311DB20EB039571DF-8060
   Component: MEM-FS        009 0044
   Serial number: 00000396924857
   Coding: 011890000000A08188000101210100008900000707008F8F00000000215000
   ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
   Component: N475 VB1 FSv  H04 0011
   Serial number: SJ80012810194025834F
   Coding: BF2F00
Address 3C: Lane Change (J769)       Labels:* None
   Part No SW: 4N0 907 566 H    HW: 4N0 907 566 A
   Component: MRR_HR H16 0267
   Coding: 15D300
   ASAM Dataset: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651_VW53.rod
   VCID: 3B23368E23EEF62FDC5-806E
   Part No SW: 4M1 959 793 J    HW: 4M1 959 793 D
   Component: TSG FS002 0425
   Serial number: YE007SJB03338
   Coding: 003F9B00D000040000013090
   ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001018
   ROD: EV_DCU2DriveSideMAXHKLO_VW53.rod
   VCID: 46D5577A682CBBC7B3B-8012
   Part No SW: 4N0 909 144 E    HW: 4N0 909 144 C
   Component: EPS_MLBEVO2BS H22 0505
   Coding: B4040101000100
   ASAM Dataset: EV_EPSVWBSAU426 010017
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323D1BAAF4A437670F3-8066
   Part No SW: 4N0 907 064 DM    HW: 4N0 907 064 M
   Component: BCM2 MLBevo H15 0202
   Coding: 01340000A00000E87329A0041400400203000000004704502F04000000080030001F3144010000
   ASAM Dataset: EV_BCM2CONTIAU651 010009
   ROD: EV_BCM2CONTIAU651_010_VW53.rod
   Ignition key:
647940 - Bulb for Right Tail Light 2
          B12C1 15 [009] - Open or Short to Plus
                    Reset counter: 0
                    Mileage: 12 km
                    Time: 00:00:00
                    Supply voltages-Supply voltage: Terminal 30: 12.095 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.089 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.054 V
                    general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
                    general_additional_freeze_frame-coprocessor_spi_status: 00000000
                    general_additional_freeze_frame-dataflash_status: 00000000
                    general_additional_freeze_frame-interior_temperature: -50.0 °C
                    general_additional_freeze_frame-Operating_Status: 00000000 00000000
                    general_additional_freeze_frame-production_mode: not active
                    general_additional_freeze_frame-reset_cause: 00000000
                    general_additional_freeze_frame-Reset_counter: 0
                    general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
                    general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
                    general_additional_freeze_frame-subnetwork_status: 00000000 00000000
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 01 0A 10 04 60
                    general_additional_freeze_frame-Transport_Mode: not active
                    general_additional_freeze_frame-Vehicle speed: 0.00 km/h
                    light_freeze_frame: 00000000 00000000 00011100 01100001
   Part No SW: 4M1 959 792 J    HW: 4M1 959 792 D
   Component: TSG BFS002 0425
   Serial number: YE007SJ324379
   Coding: 003F9B00DC00040000013090
   ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001018
   ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
   VCID: 45D75076552AB0DFBA1-8010
   Part No SW: 760 035 154 A    HW: 760 035 154 A
   Component: MU-H-LND-EU   049 2648
   Coding: 02350601FF00000043110101C08808101F0100E401A004009F
   ASAM Dataset: EV_MUHigGen2pALPI 001001
   ROD: EV_MUHigGen2pALPI_VW53.rod
   VCID: 1079B1225AE82577597-8044
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H61 9214
   Serial number: VWZ6ZJW3220987
   Subsystem 2 - Part No: V03 959 805 HD
   Component: MIB2P_EU_Q218  0294
   Subsystem 3 - Part No: V03 959 800 EG
   Component: Gracenote2  1010
   Media socket:
1554 - Production Mode Active
          U1103 00 [008] - -
          [At least one P mode is active]
                    Reset counter: 40
                    Mileage: 5 km
                    Date: 2019.11.28
                    Time: 13:27:04
                    Voltage terminal 30: 12.4 V
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 3F0 907 273     HW: 4M0 907 273 B
   Component: RDKHUFVW536   H05 0003
   Serial number: 30000000028564
   ASAM Dataset: EV_RDKHUFVW536 002002
   ROD: EV_RDKHUFVW536.rod
   VCID: 6597B0F6F5EA90DF5A1-8030
   Part No SW: 4M0 907 383 G    HW: 4M0 907 383 B
   Component: Anhaenger     H33 0273
   Revision: 9A001003    Serial number: 0533427638
   Coding: 0110000202000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   VCID: 363527BA18CC2B4723B-8062
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 760 980 568     HW: 760 980 568
   Component: RVC Compact+  H09 0250
   Coding: 0135060121002000000048
   ASAM Dataset: EV_CamSysRVRVCARPANAMLBEv 001001
   ROD: EV_CamSysRVRVCARPANAMLBEv_VW53.rod
   VCID: 619FA4E6E1C2FCFFA69-8034
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4M0 907 777 S    HW: 4M0 907 777 B
   Component: Fahrwerk-SG   H37 1253
   Serial number: 2810190562
   Coding: 90504138F8
   ASAM Dataset: EV_ChassContrContiAU426 001004
   ROD: EV_ChassContrContiAU426.rod
   VCID: 49CF5C46793254BF5E9-801C
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130785142
   Coding: 303030
327744 - Loading Mode active
          P169A 00 [137] - -
                    Reset counter: 0
                    Mileage: 5 km
                    Date: 2019.11.28
                    Time: 13:26:29
                    Internal DTC: 643
   Part No SW: 761 713 041 B    HW: 4M1 713 041 G
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 19111156658899
   ROD: EV_GSMWaehlZFAU736.rod
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AQ    HW: 4N0 907 107 G
   Component: zFAS Var B    H09 0295
   Coding: 0402840000000000003806000090463419075600000000000000000000000000000000000000000000000000000000000000000000000000000040000000000000001004000000700000004000000000008040000020
   ASAM Dataset: EV_ZFASAU516 001007
   ROD: EV_ZFASAU516_VW53.rod
   VCID: 0E45AF5A40DC33874BB-805A
2114637 - Databus
          [LRR1_SensorHeader_LRR1_Fehler]
                    Fault Frequency: 22
                    Mileage: 5 km
                    Date: 2019.11.28
                    Time: 13:31:33
2117691 - Ethernet Databus
          U11C4 00 [008] - No Communications
          [Databus_Ethernet_no_communication]
                    Mileage: 9 km
                    Date: 2019.12.20
                    Time: 08:06:24
                    Ethernet signal quality: no link
2117692 - Control unit for information electronics 1
          [Databus_Ethernet_missing_PDU]
                    Mileage: 9 km
                    Date: 2019.12.20
                    Time: 08:06:24
4107 - Databus
          [reversibler_Fehler_im_ACC_System]
                    Fault Frequency: 25
                    Mileage: 5 km
                    Date: 2019.11.28
                    Time: 13:27:12
   Part No SW: 4M1 959 595 J    HW: 4M1 959 595 D
   Component: TSG HFS004 0425
   Serial number: YE007SJF0910A
   Coding: 003E93000000040000013080
   ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
   Component: TSG HBFS004 0425
   Serial number: YE007SJF0900A
   ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H16 0267
   Coding: 15D300
   ASAM Dataset: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651_VW53.rod
   Part No SW: 7P5 941 591 BJ    HW: 7P5 941 591 B
   Component: LED1L         H07 0011
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW27.rod
   VCID: 0557907615AA70DFFA1-8050
   Component: LED1R         H07 0011
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW53.rod
End----------(Elapsed Time: 02:06, VBatt start/end: 12.0V/12.0V)-----------
