2019 VW Jetta 1.4 TSI
ZNormT6
Indiana, USA
C?ID=319128
All stock 2019 Jetta SE with the 1.4L TSI engine, 8-speed gearbox and Cold weather package. It is a USA spec car made on 06/2019.
Tuesday,31,December,2019,00:33:37:34591
VIN: 3VWCB7BU4KM213210   License Plate:
Mileage: 2789km-1733mi   Repair Order:
Chassis Type: BU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 17 19 2B 3C 42 44 52 5F CA
VIN: 3VWCB7BU4KM213210   Mileage: 2789km-1733miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DJXA)       Labels: None
   Part No SW: 04E 906 024 C    HW: 04E 907 309 BT
   Component: R4 1.4l TSI   H20 6812
   Revision: D4H20000
   Coding: 012A001223241108F000
   Shop #: WSC 00066 790 00167
   ASAM Dataset: EV_ECM14TFS01104E906024C 002005
   ROD: EV_ECM14TFS01104E906024C.rod
   VCID: 211F1B27F1419BFFE69-8074
Address 02: Auto Trans (J217)       Labels: Redir Fail!
   Part No SW: 09S 927 158 R    HW: 09S 927 158
   Component: AISIN 8G30/18 301 3587
   Coding: 0100000100000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ300031 001008
   ROD: EV_TCMAQ300031_VW37.rod
   VCID: 4EC5909BD05F54870BB-801A
   Part No SW: 5Q0 614 517 EB    HW: 5Q0 614 517 BR
   Component: ESC           H82 0108
   Revision: 00000000    Serial number: 51299000001149
   Coding: 70FB6AA12021216FC5790201A0C3250E560484A34005A4701041F058D2824B0B0000000012121212B835351919323200
   VCID: 75B71F771549475FEA1-8020
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0512326787
   Coding: 132C0C0723
   VCID: 43D3B1AF0B1DA9EF945-8016
   Part No SW: 5GM 907 044 Q    HW: 5GM 907 044 Q
   Component: Climatronic   H04 2009
   Revision: 00001K04
   Coding: 01020014200118001004010C1211110E
   Shop #: WSC 00066 790 00384
   ASAM Dataset: EV_ACClimaBHBVW37X 006148
   VCID: 52FD84EBC46730672F3-8006
   Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
   Revision: --------    Serial number: C8642904190049
   Shop #: WSC 00066 790 00253
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7BA3094F336D112F9C5-802E
   Subsystem 1 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051 0205
   Serial number: S7Y19M04D11H00M28S10
   Coding: 0018EE
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 521 BK    HW: 5Q1 953 569 B
   Component: Lenks.Modul  H23 0170
   Serial number: 0300040620190C200873
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 3200008111FFC428949C810500301600000000000000000004
   VCID: 44D1B2B30E13AED7ADF-8010
   Part No SW: 5Q0 959 655 BM    HW: 5Q0 959 655 BM
   Component: AirbagVW21    005 0403
   Serial number: 003FGM031BG1
   Coding: 8CCCFC00000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 0C415A9366C32697A5F-8058
   Occupant Detection:
   Serial number: IBH00000000000BJXP49
   Coding: 303441
   Subsystem 2 - Part No SW: -----------    HW: 480 001 604 19
   Serial number: 35700000000F3831EA3T
   Subsystem 3 - Part No SW: -----------    HW: 480 001 604 19
   Serial number: 35800000000A7831EA3T
   Subsystem 4 - Part No SW: -----------    HW: 480 400 305 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001B2EE9B78741BN
   Subsystem 5 - Part No SW: -----------    HW: 480 400 305 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001B8EE9B785484S
   Subsystem 6 - Part No SW: -----------    HW: 480 400 505 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001B8F001353923V
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 505 19
   Component: FrontSensor_P  005 6149
   Serial number: 3560001B8F001352F55%
   Part No SW: 17A 920 840 A    HW: 17A 920 840 A
   Component: KOMBI         252 2700
   Coding: 09A5021A2388CF05028823095000000020000000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Fault Frequency: 11
                    Reset counter: 101
                    Mileage: 469 km
                    Date: 2019.11.09
                    Time: 11:03:26
   Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5366
   Serial number: 25051900841350
   Coding: 030100047F085708730002481C0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 6E85301B701F74872BB-803A
   Component: 0-01-0d-01-04
   Subsystem 2 - Part No SW: 5G0 959 442 AA    HW: 5G0 959 442 AA  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H18 0052
   Serial number: 33190000680030101439
   Coding: 2AFFFF
   Serial number: 2348716500
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000109953007
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313FEB67A1A12B7F769-8064
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 A    HW: 2Q0 907 686 A
   Component: HRE3_Kl15_Mst H05 0052
   Serial number: 00000514026608
   Coding: 5000C500
   ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
   ROD: EV_HREntryHellaGen3Kl15_001_VW37.rod
   VCID: 3829D64342DBFA37317-806C
   Part No SW: 5Q4 959 393 M    HW: 5Q4 959 393 F
   Component: TSG FS        006 0247
   Serial number: 50038914202424
   Coding: 00201B200000028000000000
   Shop #: WSC 01383 790 50316
   VCID: 4DC79797DD596F9F721-8018
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002547137
   Coding: 011000
   Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  172 1081
   Coding: 011F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 50F98EE3CA6B4277197-8004
   Part No SW: 5Q4 959 392 M    HW: 5Q4 959 392 F
   Component: TSG BFS       006 0247
   Serial number: 54038914300812
   Coding: 002013200000028000000000
   VCID: 4CC19A932643669765F-8018
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002548712
   Coding: 091000
   Part No SW: 17A 035 868     HW: 17A 035 868
   Component: MU-E--ER      695 8742
   Serial number: 27111800020442
   Coding: 02730100AA00000041220001001000009F0000D40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001041
   ROD: EV_MUEnt4CGen2LGE_VW37.rod
   VCID: 678B453F5FE5A5CF68D-8032
1548 - Function Restriction
          B2008 F0 [008] - due to Over-Temp Protection
          [Function restriction due to excessive-temperature protection (power stages)]
                    Reset counter: 83
                    Mileage: 1283 km
                    Date: 2019.12.11
                    Time: 15:38:56
                    Voltage terminal 30: 14.7 V
                    Temperature: audio amplifier-max.value: -50 °C
                    Temperature: audio amplifier-min.value: -50 °C
                    Temperature: audio amplifier-Current: 106 °C
   Part No SW: 4K0 907 594 AD    HW: 4K0 907 594
   Coding: 00800073710B
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 76B5187B084F4C47E3B-8022
End----------(Elapsed Time: 01:23, VBatt start/end: 12.4V/12.4V)-----------
alfa
Kiev, Ukraine
Reset counter: 83
Mileage: 1283 km
Date: 2019.12.11
Time: 15:38:56
ZNormT6
Indiana, USA
C?ID=319128
Yeah, that's just one of those random new car faults from it sitting on the dealership lot in the sun for weeks and weeks. Nothing is wrong with the vehicle.
