Hi guys I have just noticed recently that my Convenience Consumers in the Car Menu selections is not showing anything....It just says (Function is currently not available)
Can anyone help please?
Current scan
A5 Adapmap...
BCM Adapmap...
Current scan
Thursday,26,December,2019,14:55:34:03210
VCDS Version: 19.6.2.0 HEX-V2 CB: 0.4508.4
Dealer/Shop Name: VCDS
Workshop Code: 444 03743 000001
VIN: WVWZZZ6RZFU042052 License Plate: SP15MDO-CONVENIENCE CONSUMERS FUNCTION IS CURRENTLY NOT AVAILABLE
Mileage: 131771km-81878mi Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 10 15 17 19 44 47 57 5F
VIN: WVWZZZ6RZFU042052 Mileage: 131771km-81878miles
47-Sound System -- Status: Cannot be reached 0100
57-TV Tuner -- Status: Cannot be reached 0100
Address 01: Engine (J623-CHYA) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 057 HW: 04C 907 309 J
Component: R3 1.0l MPI H23 8071
Revision: 31H23000
Coding: 01110052022401080000
Shop #: WSC 34575 001 1048576
ASAM Dataset: EV_ECM10MPI01104C906057 001012
ROD: EV_ECM10MPI01104C906057A.rod
VCID: 629DA9D494CF79B7BF3-8036
Readiness: 0000 0001
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 HW: 6R0 907 379 BA
Component: ESP9.0i H03 0002
Serial number: 08510702140901
Coding: 23DD2485492733C20914106E0053C42492CC90080005C7090C00
Shop #: WSC 03743 444 00001
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100015
VCID: 6C81C7EC660B3FC705F-8038
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 A HW: 6C0 820 045 A
Component: AC Manuell H02 0105
Serial number: 1408251B-0159
Coding: 200000001000100000
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 1D67DA28ED31064FC21-8048
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 A HW: 6C0 937 089
Component: BCM PQ26 Hi4R H06 0047
Serial number: 009458005500
Coding: 0300084042530A7B0BA44080B12707C800005B0257010000000000000000
ASAM Dataset: EV_BCMA0 004003
ROD: EV_MQBA0.rod
VCID: 2E050DE490978DD76BB-807A
Subsystem 1 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S2Y15M04D27H13M00S51
Coding: 0638DD
Drivers Door Control Module:
Subsystem 2 - Part No SW: 6R0 959 802 CH HW: 6R0 959 801 CF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 9610
Serial number: KU0KU030011550301321
Coding: 1400A1
Subsystem 3 - Part No SW: 6R0 959 801 CF HW: 6R0 959 802 CH Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 9610
Serial number: KU0KU003031550625640
Coding: 0400A1
Subsystem 4 - Part No SW: 6C0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY150640SRX
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000060144761
Subsystem 6 - Part No SW: 6R0 959 812 N HW: 6R0 959 812 N
Component: J389__TSG_HR 003 8610
Serial number: KU0KU015101442885103
Coding: 1400A0
Subsystem 7 - Part No SW: 6R0 959 811 N HW: 6R0 959 811 N
Component: J388__TSG_HL 003 8610
Serial number: KU0KU019091442622788
Coding: 0400A0
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39391510504043
Coding: 0031151041
ROD: EV_EPHVA18AU3700000_VW26.rod
VCID: 3D273AA84DF1664FE21-8068
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 A HW: 6C0 959 655 A
Component: VW20Airbag011 001 0330
Revision: -------- Serial number: 003LM004JBD7
Coding: 88C0C000000000005C000000008800000000
Shop #: WSC 31414 790 50316
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 313F169881A9922F769-8064
Subsystem 1 - Part No SW: ----------- HW: 410 820 808 14
Component: SideSensor_Df 151 0800
Serial number: 3575H009915C41F2101B
Subsystem 2 - Part No SW: ----------- HW: 410 820 808 14
Component: SideSensor_Pf 151 0800
Serial number: 3585H00B716376A1930G
Subsystem 3 - Part No SW: ----------- HW: 442 151 508 14
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00A116C1CE473EP
Subsystem 4 - Part No SW: ----------- HW: 442 151 508 14
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A009B16C1CE5E2D+
Part No SW: 6C0 920 940 A HW: 6C0 920 940 A
Component: KOMBI 211 0290
Coding: 232D09002180260001087A001000000000000000
VCID: 221DE9D4D44F39B7FF3-8076
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 HW: 6C0 937 089
Component: GW MQB A0 H06 0047
Revision: -------- Serial number: 009458005500
Coding: 030100046F0A640071000000000000010001000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 001001
ROD: EV_GatewA0Lear_001_VW26.rod
VCID: 6597B2C885E10E8F5A1-8030
Subsystem 1 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H06 0023
Serial number: 2181614230501676AD1B
Coding: 280000
Subsystem 2 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 61247F40302821697543
U1101 00 [009] - Active
Reset counter: 137
Mileage: 131746 km
Date: 2019.12.24
Time: 11:43:15
Supply voltage: Terminal 30: 11.4 V
Terminal 15: On
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C2 909 144 M HW: 6C2 909 144 D
Component: EPS_TRW_ALow 322 3211
Serial number: CE8M0038
Coding: 0007
ASAM Dataset: EV_SteerAssisUDSTRW 011021
ROD: EV_SteerAssisUDSTRW_011.rod
VCID: 33331C907BB5A03F045-8066
Address 47: Sound System
Address 57: TV Tuner
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 021 D HW: 3G0 035 021
Component: MU-H-LND-EU H33 0814
Serial number: A239I0E7507617
Coding: 02730001FF00000011111201008908002F0004D601208100FE
ASAM Dataset: EV_MUHig4CGen2HBAS 001115
VCID: 196FCE38F9197A6F2E9-804C
Subsystem 1 - Part No SW: 6C0 919 603 A HW: 6C0 919 603 A
Component: ABTm_Std2_Nav H53 1031
Serial number: VWZ8Z9SKX017MV
Subsystem 2 - Part No SW: V03 959 806 FN HW: -----------
Component: ECE 2020 --- 0184
Component: Gracenote---- --- 1010
8 Faults Found:
B201A 00 [009] - -
[Check software version management]
Reset counter: 141
Mileage: 131771 km
Date: 2019.12.26
Time: 14:42:26
Voltage terminal 30: 14.9 V
Status_Software_Version_Management-module_name: MDUV501/DUV
13697024 - Component Protection
U1100 00 [009] - No Basic Setting
[Anti-theft protection - component protection: no basic setting or basic setting incorrect]
Reset counter: 141
Mileage: 131771 km
Date: 2019.12.26
Time: 14:42:21
15361024 - Component Protection
[Anti-theft protection - component protection active (0xEA6400)]
Reset counter: 141
Mileage: 131771 km
Date: 2019.12.26
Time: 14:42:21
2571 - Navigation system
B126C F2 [009] - Navigation database not enabled
Reset counter: 141
Mileage: 131771 km
Date: 2019.12.26
Time: 14:42:20
U1111 00 [009] - -
Reset counter: 141
Mileage: 131771 km
Date: 2019.12.26
Time: 14:42:23
Voltage terminal 30: 15.0 V
BAP-BAP_Function_ID: 02
7201 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 141
Mileage: 131771 km
Date: 2019.12.26
Time: 14:42:23
7203 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Efficiency program (0x23) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 141
Mileage: 131771 km
Date: 2019.12.26
Time: 14:42:23
7206 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 141
Mileage: 131771 km
Date: 2019.12.26
Time: 14:42:23
End----------(Elapsed Time: 01:01, VBatt start/end: 14.6V/14.6V)-----------
A5 Adapmap...
;SW:3G0-035-021-D HW:3G0-035-021 --- Information Electr.
;Component:MU-H-LND-EU H33 0814, Coding:02730001FF00000011111201008908002F0004D601208100FE
;EV_MUHig4CGen2HBAS,001115,EV_MUHig4CGen2HBAS_VW37.rod
;Thursday,26,December,2019,14:55:59:03210
;VCDS Version: Release 19.6.2 Data version: 20190930 DS308.0
;VCID: 196FCE38F9197A6F2E9-804C
IDE00346-Summertime-automatic,Europe ,1
IDE00768-Country identification: country of sale,GB ,2
IDE00769-Number 1 for Info call,5E 06 A1 80 00 44 42 42 F4 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,5E 06 A1 80 00 44 42 42 F4 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00845-Wheel circ.,0 mm,2
IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module,No ,3
IDE01996-MAS00839-Installation list: specified installations-TV Tuner,Yes ,3
IDE01996-MAS00844-Installation list: specified installations-Radio,No ,3
IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module,Yes ,3
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1,Yes ,3
IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2,No ,3
IDE01996-MAS04300-Installation list: specified installations-DVD changer,No ,3
IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module,No ,3
IDE01996-SFT271943-Installation list: specified installations-Multimedia Operating Unit,No ,3
IDE01996-ENG154341-Installation list: specified installations-Reserved_8,No ,3
IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1,No ,3
IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2,No ,3
IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1,No ,3
IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2,No ,3
IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1,No ,3
IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2,No ,3
IDE02121-CD eject button,Enabled ,1
IDE02122-Developer mode,activated ,1
IDE02330-Number 2 for Info call,5E 07 91 94 16 05 45 84 55 F5 FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,5E 07 91 94 16 05 45 84 55 F5 FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,22 ,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,22 ,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,22 ,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,22 ,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,22 ,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,22 ,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,22 ,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,22 ,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,22 ,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,22 ,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,22 ,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,22 ,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,22 ,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,22 ,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,22 ,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,22 ,49
IDE02502-Confirmation of installation change,34 D7 ,2
IDE02506-MAS03229-Copy multimedia data-Data medium,On ,1
IDE02506-MAS03230-Copy multimedia data-Optical drive,OFF ,1
IDE02607-Wheel pulse,0 ,2
IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE03238-ENG117830-Parameter for connection transfer (UMTS)-1E_EcLo,0 ,8
IDE03238-ENG117831-Parameter for connection transfer (UMTS)-1E_RSCP,15 ,8
IDE03238-ENG117832-Parameter for connection transfer (UMTS)-1F_EcLo,0 ,8
IDE03238-ENG117833-Parameter for connection transfer (UMTS)-1F_RSCP,15 ,8
IDE03238-ENG122277-Parameter for connection transfer (UMTS)-2D_EcLo,0 ,8
IDE03238-ENG122278-Parameter for connection transfer (UMTS)-2D_RSCP,11 ,8
IDE03238-ENG122275-Parameter for connection transfer (UMTS)-3A_EcLo,0 ,8
IDE03238-ENG122276-Parameter for connection transfer (UMTS)-3A_RSCP,8 ,8
IDE03471-ENG117847-Vehicle configuration-advanced_range_display,OFF ,30
IDE03471-ENG249824-Vehicle configuration-AliBox,OFF ,30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing,OFF ,30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
IDE03471-ENG263540-Vehicle configuration-correction_e_mileage,0 ,30
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call,On ,30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,On ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,On ,30
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,OFF ,30
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,OFF ,30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
IDE03471-ENG261211-Vehicle configuration-internet_over_WLAN_default_setting,OFF ,30
IDE03471-ENG125049-Vehicle configuration-Joker_button_1,Not Present ,30
IDE03471-ENG125050-Vehicle configuration-Joker_button_2,Not Present ,30
IDE03471-ENG127492-Vehicle configuration-LGI,OFF ,30
IDE03471-ENG130246-Vehicle configuration-LTE_modul,activated ,30
IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30
IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,OFF ,30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_EU ,30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
IDE03471-ENG117843-Vehicle configuration-my_audi,On ,30
IDE03471-ENG117845-Vehicle configuration-online_dictation,On ,30
IDE03471-ENG127495-Vehicle configuration-online_media,On ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,On ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,On ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,On ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,On ,30
IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,On ,30
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit,OFF ,30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,only data service act. ,30
IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF ,30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi,OFF ,30
IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo,OFF ,30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.4 ,30
IDE03471-ENG117846-Vehicle configuration-remote_HMI,On ,30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,activated ,30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
IDE03471-ENG126143-Vehicle configuration-RVC_video_input,FBAS ,30
IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation,no restriction ,30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,REGION_EU ,30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch,Not Present ,30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi,activated ,30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,1 ,30
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold,OFF ,30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,OFF ,30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,OFF ,30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
IDE03471-ENG126994-Vehicle configuration-TPEG_availability,OFF ,30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,blocked ,30
IDE03471-ENG137647-Vehicle configuration-UOTA,OFF ,30
IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,On ,30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
IDE03471-ENG117836-Vehicle configuration-VZAPro,OFF ,30
IDE03471-ENG127494-Vehicle configuration-VZO,OFF ,30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,On ,30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On ,30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
IDE03580-Country code for mobile network,0 ,2
IDE03902-Automatic ring break diagnostic,No automatic start ,1
IDE04295-Bluetooth: Preferred connection profile for phone book data,PBAP ,1
IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,2 ,2
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,2 ,2
IDE04521-Sporadic ring break detection,Visual ,1
IDE04549-Telephone data services,On ,1
IDE04550-Bluetooth: Sniff mode,On ,1
IDE05111-Fee-based traffic information (TMC),32771 ,2
IDE06697-Audio management mute function,Muting of audio sources ,1
IDE07399-ENG142045-Engine type-Engine_type_adaption_1,Petrol ,1
IDE07399-ENG142046-Engine type-Engine_type_adaption_2,Petrol ,1
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,On ,1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,On ,1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,On ,1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,On ,1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
IDE09382-ENG125051-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 2G,0 ,16
IDE09382-ENG125052-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 3G,0 ,16
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128 ,40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,-128 ,40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128 ,40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128 ,40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128 ,40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128 ,40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128 ,40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128 ,40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128 ,40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128 ,40
IDE10480-MAS10742-Interface for external media: activation-Connection 2,activated ,4
IDE10604-Menu entries for mobile online services,not activated ,1
IDE10668-Internal SIM card: use,automatic ,1
IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold,37 dBµV,3
IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation,32 dB,3
IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo,15.0 s,3
IDE11105-Brand-specific display of connect application,de.audi.mmiconnect ,19
IDE11122-Country identification: country of sale HMI,-- ,2
IDE11153-ENG152487-Surroundings display: virtual camera positions-focallength,4294967295 ,330
IDE11153-ENG152487-Surroundings display: virtual camera positions-focallength,0 ,330
IDE11153-ENG152457-Surroundings display: virtual camera positions-Pitchangle,65535 ,330
IDE11153-ENG152457-Surroundings display: virtual camera positions-Pitchangle,0 ,330
IDE11153-ENG152445-Surroundings display: virtual camera positions-Rollangle,65535 ,330
IDE11153-ENG152445-Surroundings display: virtual camera positions-Rollangle,0 ,330
IDE11153-ENG147432-Surroundings display: virtual camera positions-xpos,32767 ,330
IDE11153-ENG147432-Surroundings display: virtual camera positions-xpos,0 ,330
IDE11153-ENG152451-Surroundings display: virtual camera positions-Yawangle,65535 ,330
IDE11153-ENG152451-Surroundings display: virtual camera positions-Yawangle,0 ,330
IDE11153-ENG147433-Surroundings display: virtual camera positions-ypos,32767 ,330
IDE11153-ENG147433-Surroundings display: virtual camera positions-ypos,0 ,330
IDE11153-ENG147434-Surroundings display: virtual camera positions-zpos,32767 ,330
IDE11153-ENG147434-Surroundings display: virtual camera positions-zpos,0 ,330
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked ,21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,21
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,21
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,21
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,21
IDE11638-Bluetooth Audio Codec,FF ,1
IDE12266-Follow on time for telephone,activated ,1
IDE12353-Configuration of traffic light online functions,On ,1
MAS00951-Bluetooth,On ,1
MAS03690-Telephone,Data & language service active ,1
MAS03782-WLAN,On ,1
ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off,OFF ,12
ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time,0.00 ms,12
ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off,OFF ,12
ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time,0.00 ms,12
ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off,OFF ,12
ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time,0.00 ms,12
ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off,OFF ,12
ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time,0.00 ms,12
ENG117920-Audio_Managment_Soundset_Menu,OFF ,1
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated ,60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not activated ,60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not activated ,60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not activated ,60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not activated ,60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated ,60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not activated ,60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated ,60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated ,60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not activated ,60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated ,60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated ,60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,not activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,not activated ,60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,not activated ,60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,activated ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,activated ,60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated ,60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated ,60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated ,60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated ,60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Terminal 15 ,64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Comfort data bus ,64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not activated ,64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Databus drivetrain ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Comfort data bus ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Databus drivetrain ,64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Comfort data bus ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,not activated ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,activated ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,Databus Infotainment ,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Comfort data bus ,64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated ,64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,not activated ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain ,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended ,64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Comfort data bus ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated ,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated ,64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Comfort data bus ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus ,64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus ,64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Comfort data bus ,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,not activated ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended ,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Databus drivetrain ,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,activated ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Comfort data bus ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Comfort data bus ,64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available ,8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Available ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available ,8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available ,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Comfort data bus ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain ,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,Not available ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort data bus ,8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,Not available ,8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Available ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,OFF ,10
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,OFF ,10
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,OFF ,10
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode,RLE ,10
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,resolution_1 ,10
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,OFF ,10
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon,0 ,10
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most,OFF ,10
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,RLE ,10
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,resolution_1 ,10
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,OFF ,10
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,OFF ,10
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1,0 ,6
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2,50 ,6
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3,100 ,6
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1,0 ,6
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2,50 ,6
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3,100 ,6
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,0 ,12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10 ,12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,100 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,150 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220 ,12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,253 ,12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,1 %,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,8 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,20 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,60 %,12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,100 %,12
ENG117911-ENG117768-FM_Delay_Adaption-Parameter_Adaption_FM_Delay,0 ms,3
ENG117911-ENG117769-FM_Delay_Adaption-Seamless_linking_automatic,On ,3
ENG141636-ENG142049-Key_code_monitoring-monitoring_keycode_0x00_0x07,FF ,32
ENG141636-ENG142050-Key_code_monitoring-monitoring_keycode_0x08_0x0F,FF ,32
ENG141636-ENG142051-Key_code_monitoring-monitoring_keycode_0x10_0x17,FF ,32
ENG141636-ENG142052-Key_code_monitoring-monitoring_keycode_0x18_0x1F,FF ,32
ENG141636-ENG142053-Key_code_monitoring-monitoring_keycode_0x20_0x27,FF ,32
ENG141636-ENG142054-Key_code_monitoring-monitoring_keycode_0x28_0x2F,FF ,32
ENG141636-ENG142055-Key_code_monitoring-monitoring_keycode_0x30_0x37,FF ,32
ENG141636-ENG142056-Key_code_monitoring-monitoring_keycode_0x38_0x3F,FF ,32
ENG141636-ENG142057-Key_code_monitoring-monitoring_keycode_0x40_0x47,FF ,32
ENG141636-ENG142058-Key_code_monitoring-monitoring_keycode_0x48_0x4F,FF ,32
ENG141636-ENG142059-Key_code_monitoring-monitoring_keycode_0x50_0x57,FF ,32
ENG141636-ENG142060-Key_code_monitoring-monitoring_keycode_0x58_0x5F,FF ,32
ENG141636-ENG142061-Key_code_monitoring-monitoring_keycode_0x60_0x67,FF ,32
ENG141636-ENG142062-Key_code_monitoring-monitoring_keycode_0x68_0x6F,FF ,32
ENG141636-ENG142063-Key_code_monitoring-monitoring_keycode_0x70_0x77,FF ,32
ENG141636-ENG142064-Key_code_monitoring-monitoring_keycode_0x78_0x7F,FF ,32
ENG141636-ENG142065-Key_code_monitoring-monitoring_keycode_0x80_0x87,FF ,32
ENG141636-ENG142066-Key_code_monitoring-monitoring_keycode_0x88_0x8F,FF ,32
ENG141636-ENG142067-Key_code_monitoring-monitoring_keycode_0x90_0x97,FF ,32
ENG141636-ENG142068-Key_code_monitoring-monitoring_keycode_0x98_0x9F,FF ,32
ENG141636-ENG142069-Key_code_monitoring-monitoring_keycode_0xA0_0xA7,FF ,32
ENG141636-ENG142070-Key_code_monitoring-monitoring_keycode_0xA8_0xAF,FF ,32
ENG141636-ENG142071-Key_code_monitoring-monitoring_keycode_0xB0_0xB7,FF ,32
ENG141636-ENG142072-Key_code_monitoring-monitoring_keycode_0xB8_0xBF,FF ,32
ENG141636-ENG142073-Key_code_monitoring-monitoring_keycode_0xC0_0xC7,FF ,32
ENG141636-ENG142074-Key_code_monitoring-monitoring_keycode_0xC8_0xCF,FF ,32
ENG141636-ENG142075-Key_code_monitoring-monitoring_keycode_0xD0_0xD7,FF ,32
ENG141636-ENG142076-Key_code_monitoring-monitoring_keycode_0xD8_0xDF,FF ,32
ENG141636-ENG142077-Key_code_monitoring-monitoring_keycode_0xE0_0xE7,FF ,32
ENG141636-ENG142078-Key_code_monitoring-monitoring_keycode_0xE8_0xEF,FF ,32
ENG141636-ENG142079-Key_code_monitoring-monitoring_keycode_0xF0_0xF7,FF ,32
ENG141636-ENG142080-Key_code_monitoring-monitoring_keycode_0xF8_0xFF,FF ,32
ENG107658-ENG126192-mobile phone voice control availability-apple_device,not installed ,1
ENG107658-ENG126193-mobile phone voice control availability-other_devices,not installed ,1
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,04 01 52 04 52 10 52 40 52 32 00 64 00 96 00 A4 01 C8 00 82 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 05 ,40
ENG117809-p_damping_Display,5 ms,1
ENG117808-p_HMI_Display,13 %,1
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN,0 ,3
ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit,0 km/h,3
Elapsed Time: 00:49
BCM Adapmap...
;SW:6C0-937-089-A HW:6C0-937-089 --- Cent. Elect.
;Component:BCM PQ26 Hi4R H06 0047, Coding:0300084042530A7B0BA44080B12707C800005B0257010000000000000000
;EV_BCMA0,004003,EV_MQBA0.rod
;Thursday,26,December,2019,14:57:01:03210
;VCDS Version: Release 19.6.2 Data version: 20190930 DS308.0
;VCID: 2E050DE490978DD76BB-807A
IDE00001-ENG130235-Production mode-Entry_control,not active ,3
IDE00001-ENG130233-Production mode-Exit_lights_Heading_time_15_s,not active ,3
IDE00001-ENG130234-Production mode-Window_regulator_kl_15_nr_2,not active ,3
IDE00001-ENG130231-Production mode-Window_regulator_nr_1,not active ,3
IDE00001-ENG130232-Production mode-Window_reversing_threshold,not active ,3
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,active ,9
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,9
IDE01268-ENG122992-Windshield wiper-Frontwischer Abtauposition,keine Abtaupostition ,9
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,9
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,9
IDE01268-ENG126573-Windshield wiper-Frontwischer_Serviceposition,active ,9
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,9
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,active ,9
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,activated ,9
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,9
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms,9
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms,9
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,9
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,9
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,0 ms,9
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,active ,9
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,active ,9
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,9
IDE01268-ENG122991-Windshield wiper-Wischer stop bei Motorstart,kein Wischerstopp ,9
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,9
IDE02152-Characteristics in production mode,0 ms,4
IDE02200-Component protection showroom mode,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,32
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,2
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,2
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,2
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,2
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,2
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,2
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,2
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,2
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl,not active ,2
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl,not active ,2
IDE02488-DWA Interior monitoring,100 %,1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,3
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active ,3
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active ,3
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,3
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,3
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,3
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,3
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,3
IDE02711-ENG126572-Rear Window Wiper-no_automativ_parking_after_kl15_on,not active ,3
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active ,3
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel,not enabled ,4
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,80 %,4
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,80 %,4
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,80 %,4
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,4
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,4
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,4
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.50 °,13
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,13
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,13
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,13
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C,13
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C,13
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,180 °,13
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C,13
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,120 °,13
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,13
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,13
IDE04923-ENG130187-Turn signal control-Blinkkontrolleuchte_fuer_Anhaenger,separate ,4
IDE04923-ENG130192-Turn signal control-Freilaufendes_Warnblinken,not active ,4
IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,4
IDE04923-ENG115854-Turn signal control-Komfortblinken_Blinkzyklen,5 ,4
IDE04923-ENG130186-Turn signal control-Signalprioritaet_fuer_Blinker,SMLS ,4
IDE04923-ENG126568-Turn signal control-Sonderfunktionen_2,not enabled ,4
IDE04923-ENG130191-Turn signal control-Warnblinken_bei_Verdeckentriegelung,not active ,4
IDE04923-ENG130188-Turn signal control-Warnblinktastersuchbeleuchtung_Aktivierung,Always active ,4
IDE04923-ENG130190-Turn signal control-Warnblinktastersuchbeleuchtung_Faktor,0.100 %,4
IDE04923-ENG130189-Turn signal control-Warnblinktastersuchbeleuchtung_Grundwert,3.0 %,4
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350.0 km/h,14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350.0 km/h,14
IDE04924-ENG126566-Driving light and parking light-beidseitiges_dauerparklicht,active ,14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integrated ,14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
IDE04924-ENG126567-Driving light and parking light-max_scheinwerfer_2limitieren,not active ,14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,255 km/h,14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
IDE04924-ENG126565-Driving light and parking light-standlicht_aus_bei_kl_s_aus_s_kontakt,active ,14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,5
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic ,5
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door ,5
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,0 ,5
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,72.0 ,5
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,5
IDE04926-ENG126569-Comfort illumination-lho_aktiviert,active ,5
IDE04926-ENG126570-Comfort illumination-lho_zeit,10 seconds ,5
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 seconds ,5
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,5
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung,35.0 °C,8
IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung,35.0 °C,8
IDE04927-ENG126613-Window heater-Aussenspiegelheizung,0.0 s,8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,time value ,8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,1
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,1
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,1
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,1
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,1
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,1
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,4
IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,4
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active ,4
IDE05142-ENG116706-Access control-Autounlock NAR,not active ,4
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active ,4
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active ,4
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,4
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,4
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,4
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,4
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,4
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,4
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,4
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,4
IDE05142-ENG115755-Access control-Notschließfunktion,active ,4
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,4
IDE05142-ENG115758-Access control-Valet Parking,not active ,4
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,4
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,4
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung ,4
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,4
IDE05145-ENG115014-Light configuration-BAP_Bitposition_0,34 ,560
IDE05145-ENG115033-Light configuration-BAP_Bitposition_1,3E ,560
IDE05145-ENG115186-Light configuration-BAP_Bitposition_10,00 ,560
IDE05145-ENG115189-Light configuration-BAP_Bitposition_11,00 ,560
IDE05145-ENG115208-Light configuration-BAP_Bitposition_12,38 ,560
IDE05145-ENG115226-Light configuration-BAP_Bitposition_13,42 ,560
IDE05145-ENG115229-Light configuration-BAP_Bitposition_14,00 ,560
IDE05145-ENG115248-Light configuration-BAP_Bitposition_15,00 ,560
IDE05145-ENG115267-Light configuration-BAP_Bitposition_16,00 ,560
IDE05145-ENG115286-Light configuration-BAP_Bitposition_17,00 ,560
IDE05145-ENG115305-Light configuration-BAP_Bitposition_18,08 ,560
IDE05145-ENG115324-Light configuration-BAP_Bitposition_19,18 ,560
IDE05145-ENG115052-Light configuration-BAP_Bitposition_2,35 ,560
IDE05145-ENG115343-Light configuration-BAP_Bitposition_20,09 ,560
IDE05145-ENG115362-Light configuration-BAP_Bitposition_21,19 ,560
IDE05145-ENG115381-Light configuration-BAP_Bitposition_22,29 ,560
IDE05145-ENG115400-Light configuration-BAP_Bitposition_23,0A ,560
IDE05145-ENG115419-Light configuration-BAP_Bitposition_24,1A ,560
IDE05145-ENG115438-Light configuration-BAP_Bitposition_25,00 ,560
IDE05145-ENG115457-Light configuration-BAP_Bitposition_26,0C ,560
IDE05145-ENG115476-Light configuration-BAP_Bitposition_27,00 ,560
IDE05145-ENG115495-Light configuration-BAP_Bitposition_28,1B ,560
IDE05145-ENG115514-Light configuration-BAP_Bitposition_29,00 ,560
IDE05145-ENG115071-Light configuration-BAP_Bitposition_3,3F ,560
IDE05145-ENG115533-Light configuration-BAP_Bitposition_30,00 ,560
IDE05145-ENG115552-Light configuration-BAP_Bitposition_31,00 ,560
IDE05145-ENG115571-Light configuration-BAP_Bitposition_32,00 ,560
IDE05145-ENG115590-Light configuration-BAP_Bitposition_33,00 ,560
IDE05145-ENG115609-Light configuration-BAP_Bitposition_34,00 ,560
IDE05145-ENG115090-Light configuration-BAP_Bitposition_4,3A ,560
IDE05145-ENG115108-Light configuration-BAP_Bitposition_5,44 ,560
IDE05145-ENG115111-Light configuration-BAP_Bitposition_6,36 ,560
IDE05145-ENG115130-Light configuration-BAP_Bitposition_7,40 ,560
IDE05145-ENG115149-Light configuration-BAP_Bitposition_8,37 ,560
IDE05145-ENG115168-Light configuration-BAP_Bitposition_9,41 ,560
IDE05145-ENG115018-Light configuration-Dimming_AB_0,100 ,560
IDE05145-ENG115037-Light configuration-Dimming_AB_1,100 ,560
IDE05145-ENG114999-Light configuration-Dimming_AB_10,0 ,560
IDE05145-ENG115193-Light configuration-Dimming_AB_11,100 ,560
IDE05145-ENG115212-Light configuration-Dimming_AB_12,100 ,560
IDE05145-ENG114958-Light configuration-Dimming_AB_13,100 ,560
IDE05145-ENG115233-Light configuration-Dimming_AB_14,100 ,560
IDE05145-ENG115252-Light configuration-Dimming_AB_15,100 ,560
IDE05145-ENG115271-Light configuration-Dimming_AB_16,100 ,560
IDE05145-ENG115290-Light configuration-Dimming_AB_17,100 ,560
IDE05145-ENG115309-Light configuration-Dimming_AB_18,100 ,560
IDE05145-ENG115328-Light configuration-Dimming_AB_19,100 ,560
IDE05145-ENG115056-Light configuration-Dimming_AB_2,100 ,560
IDE05145-ENG115347-Light configuration-Dimming_AB_20,100 ,560
IDE05145-ENG115366-Light configuration-Dimming_AB_21,100 ,560
IDE05145-ENG115385-Light configuration-Dimming_AB_22,100 ,560
IDE05145-ENG115404-Light configuration-Dimming_AB_23,60 ,560
IDE05145-ENG115423-Light configuration-Dimming_AB_24,60 ,560
IDE05145-ENG115442-Light configuration-Dimming_AB_25,100 ,560
IDE05145-ENG115461-Light configuration-Dimming_AB_26,100 ,560
IDE05145-ENG115480-Light configuration-Dimming_AB_27,100 ,560
IDE05145-ENG115499-Light configuration-Dimming_AB_28,100 ,560
IDE05145-ENG115518-Light configuration-Dimming_AB_29,100 ,560
IDE05145-ENG115075-Light configuration-Dimming_AB_3,100 ,560
IDE05145-ENG115537-Light configuration-Dimming_AB_30,100 ,560
IDE05145-ENG115556-Light configuration-Dimming_AB_31,0 ,560
IDE05145-ENG115575-Light configuration-Dimming_AB_32,0 ,560
IDE05145-ENG115594-Light configuration-Dimming_AB_33,0 ,560
IDE05145-ENG115613-Light configuration-Dimming_AB_34,0 ,560
IDE05145-ENG115094-Light configuration-Dimming_AB_4,100 ,560
IDE05145-ENG114977-Light configuration-Dimming_AB_5,100 ,560
IDE05145-ENG115115-Light configuration-Dimming_AB_6,100 ,560
IDE05145-ENG115134-Light configuration-Dimming_AB_7,100 ,560
IDE05145-ENG115153-Light configuration-Dimming_AB_8,100 ,560
IDE05145-ENG115172-Light configuration-Dimming_AB_9,100 ,560
IDE05145-ENG115022-Light configuration-Dimming_CD_0,0 ,560
IDE05145-ENG115041-Light configuration-Dimming_CD_1,0 ,560
IDE05145-ENG115003-Light configuration-Dimming_CD_10,0 ,560
IDE05145-ENG115197-Light configuration-Dimming_CD_11,0 ,560
IDE05145-ENG115216-Light configuration-Dimming_CD_12,0 ,560
IDE05145-ENG114962-Light configuration-Dimming_CD_13,0 ,560
IDE05145-ENG115237-Light configuration-Dimming_CD_14,0 ,560
IDE05145-ENG115256-Light configuration-Dimming_CD_15,0 ,560
IDE05145-ENG115275-Light configuration-Dimming_CD_16,0 ,560
IDE05145-ENG115294-Light configuration-Dimming_CD_17,0 ,560
IDE05145-ENG115313-Light configuration-Dimming_CD_18,0 ,560
IDE05145-ENG115332-Light configuration-Dimming_CD_19,0 ,560
IDE05145-ENG115060-Light configuration-Dimming_CD_2,0 ,560
IDE05145-ENG115351-Light configuration-Dimming_CD_20,0 ,560
IDE05145-ENG115370-Light configuration-Dimming_CD_21,0 ,560
IDE05145-ENG115389-Light configuration-Dimming_CD_22,0 ,560
IDE05145-ENG115408-Light configuration-Dimming_CD_23,0 ,560
IDE05145-ENG115427-Light configuration-Dimming_CD_24,0 ,560
IDE05145-ENG115446-Light configuration-Dimming_CD_25,0 ,560
IDE05145-ENG115465-Light configuration-Dimming_CD_26,0 ,560
IDE05145-ENG115484-Light configuration-Dimming_CD_27,0 ,560
IDE05145-ENG115503-Light configuration-Dimming_CD_28,0 ,560
IDE05145-ENG115522-Light configuration-Dimming_CD_29,0 ,560
IDE05145-ENG115079-Light configuration-Dimming_CD_3,0 ,560
IDE05145-ENG115541-Light configuration-Dimming_CD_30,0 ,560
IDE05145-ENG115560-Light configuration-Dimming_CD_31,0 ,560
IDE05145-ENG115579-Light configuration-Dimming_CD_32,0 ,560
IDE05145-ENG115598-Light configuration-Dimming_CD_33,0 ,560
IDE05145-ENG115617-Light configuration-Dimming_CD_34,0 ,560
IDE05145-ENG115098-Light configuration-Dimming_CD_4,0 ,560
IDE05145-ENG114981-Light configuration-Dimming_CD_5,0 ,560
IDE05145-ENG115119-Light configuration-Dimming_CD_6,0 ,560
IDE05145-ENG115138-Light configuration-Dimming_CD_7,0 ,560
IDE05145-ENG115157-Light configuration-Dimming_CD_8,0 ,560
IDE05145-ENG115176-Light configuration-Dimming_CD_9,0 ,560
IDE05145-ENG115023-Light configuration-Dimming_Direction_CD_0,maximize ,560
IDE05145-ENG115042-Light configuration-Dimming_Direction_CD_1,maximize ,560
IDE05145-ENG115004-Light configuration-Dimming_Direction_CD_10,maximize ,560
IDE05145-ENG115198-Light configuration-Dimming_Direction_CD_11,maximize ,560
IDE05145-ENG115217-Light configuration-Dimming_Direction_CD_12,maximize ,560
IDE05145-ENG114963-Light configuration-Dimming_Direction_CD_13,maximize ,560
IDE05145-ENG115238-Light configuration-Dimming_Direction_CD_14,maximize ,560
IDE05145-ENG115257-Light configuration-Dimming_Direction_CD_15,maximize ,560
IDE05145-ENG115276-Light configuration-Dimming_Direction_CD_16,maximize ,560
IDE05145-ENG115295-Light configuration-Dimming_Direction_CD_17,maximize ,560
IDE05145-ENG115314-Light configuration-Dimming_Direction_CD_18,maximize ,560
IDE05145-ENG115333-Light configuration-Dimming_Direction_CD_19,maximize ,560
IDE05145-ENG115061-Light configuration-Dimming_Direction_CD_2,maximize ,560
IDE05145-ENG115352-Light configuration-Dimming_Direction_CD_20,maximize ,560
IDE05145-ENG115371-Light configuration-Dimming_Direction_CD_21,maximize ,560
IDE05145-ENG115390-Light configuration-Dimming_Direction_CD_22,maximize ,560
IDE05145-ENG115409-Light configuration-Dimming_Direction_CD_23,maximize ,560
IDE05145-ENG115428-Light configuration-Dimming_Direction_CD_24,maximize ,560
IDE05145-ENG115447-Light configuration-Dimming_Direction_CD_25,maximize ,560
IDE05145-ENG115466-Light configuration-Dimming_Direction_CD_26,maximize ,560
IDE05145-ENG115485-Light configuration-Dimming_Direction_CD_27,maximize ,560
IDE05145-ENG115504-Light configuration-Dimming_Direction_CD_28,maximize ,560
IDE05145-ENG115523-Light configuration-Dimming_Direction_CD_29,maximize ,560
IDE05145-ENG115080-Light configuration-Dimming_Direction_CD_3,maximize ,560
IDE05145-ENG115542-Light configuration-Dimming_Direction_CD_30,maximize ,560
IDE05145-ENG115561-Light configuration-Dimming_Direction_CD_31,maximize ,560
IDE05145-ENG115580-Light configuration-Dimming_Direction_CD_32,maximize ,560
IDE05145-ENG115599-Light configuration-Dimming_Direction_CD_33,maximize ,560
IDE05145-ENG115618-Light configuration-Dimming_Direction_CD_34,maximize ,560
IDE05145-ENG115099-Light configuration-Dimming_Direction_CD_4,maximize ,560
IDE05145-ENG114982-Light configuration-Dimming_Direction_CD_5,maximize ,560
IDE05145-ENG115120-Light configuration-Dimming_Direction_CD_6,maximize ,560
IDE05145-ENG115139-Light configuration-Dimming_Direction_CD_7,maximize ,560
IDE05145-ENG115158-Light configuration-Dimming_Direction_CD_8,maximize ,560
IDE05145-ENG115177-Light configuration-Dimming_Direction_CD_9,maximize ,560
IDE05145-ENG115027-Light configuration-Dimming_Direction_EF_0,maximize ,560
IDE05145-ENG115046-Light configuration-Dimming_Direction_EF_1,maximize ,560
IDE05145-ENG115008-Light configuration-Dimming_Direction_EF_10,maximize ,560
IDE05145-ENG115202-Light configuration-Dimming_Direction_EF_11,maximize ,560
IDE05145-ENG115221-Light configuration-Dimming_Direction_EF_12,maximize ,560
IDE05145-ENG114967-Light configuration-Dimming_Direction_EF_13,maximize ,560
IDE05145-ENG115242-Light configuration-Dimming_Direction_EF_14,maximize ,560
IDE05145-ENG115261-Light configuration-Dimming_Direction_EF_15,maximize ,560
IDE05145-ENG115280-Light configuration-Dimming_Direction_EF_16,maximize ,560
IDE05145-ENG115299-Light configuration-Dimming_Direction_EF_17,maximize ,560
IDE05145-ENG115318-Light configuration-Dimming_Direction_EF_18,maximize ,560
IDE05145-ENG115337-Light configuration-Dimming_Direction_EF_19,maximize ,560
IDE05145-ENG115065-Light configuration-Dimming_Direction_EF_2,maximize ,560
IDE05145-ENG115356-Light configuration-Dimming_Direction_EF_20,maximize ,560
IDE05145-ENG115375-Light configuration-Dimming_Direction_EF_21,maximize ,560
IDE05145-ENG115394-Light configuration-Dimming_Direction_EF_22,maximize ,560
IDE05145-ENG115413-Light configuration-Dimming_Direction_EF_23,maximize ,560
IDE05145-ENG115432-Light configuration-Dimming_Direction_EF_24,maximize ,560
IDE05145-ENG115451-Light configuration-Dimming_Direction_EF_25,maximize ,560
IDE05145-ENG115470-Light configuration-Dimming_Direction_EF_26,maximize ,560
IDE05145-ENG115489-Light configuration-Dimming_Direction_EF_27,maximize ,560
IDE05145-ENG115508-Light configuration-Dimming_Direction_EF_28,maximize ,560
IDE05145-ENG115527-Light configuration-Dimming_Direction_EF_29,maximize ,560
IDE05145-ENG115084-Light configuration-Dimming_Direction_EF_3,maximize ,560
IDE05145-ENG115546-Light configuration-Dimming_Direction_EF_30,maximize ,560
IDE05145-ENG115565-Light configuration-Dimming_Direction_EF_31,maximize ,560
IDE05145-ENG115584-Light configuration-Dimming_Direction_EF_32,maximize ,560
IDE05145-ENG115603-Light configuration-Dimming_Direction_EF_33,maximize ,560
IDE05145-ENG115622-Light configuration-Dimming_Direction_EF_34,maximize ,560
IDE05145-ENG115103-Light configuration-Dimming_Direction_EF_4,maximize ,560
IDE05145-ENG114986-Light configuration-Dimming_Direction_EF_5,maximize ,560
IDE05145-ENG115124-Light configuration-Dimming_Direction_EF_6,maximize ,560
IDE05145-ENG115143-Light configuration-Dimming_Direction_EF_7,maximize ,560
IDE05145-ENG115162-Light configuration-Dimming_Direction_EF_8,maximize ,560
IDE05145-ENG115181-Light configuration-Dimming_Direction_EF_9,maximize ,560
IDE05145-ENG115031-Light configuration-Dimming_Direction_GH_0,maximize ,560
IDE05145-ENG115050-Light configuration-Dimming_Direction_GH_1,maximize ,560
IDE05145-ENG115012-Light configuration-Dimming_Direction_GH_10,maximize ,560
IDE05145-ENG115206-Light configuration-Dimming_Direction_GH_11,maximize ,560
IDE05145-ENG115225-Light configuration-Dimming_Direction_GH_12,maximize ,560
IDE05145-ENG114971-Light configuration-Dimming_Direction_GH_13,maximize ,560
IDE05145-ENG115246-Light configuration-Dimming_Direction_GH_14,maximize ,560
IDE05145-ENG115265-Light configuration-Dimming_Direction_GH_15,maximize ,560
IDE05145-ENG115284-Light configuration-Dimming_Direction_GH_16,maximize ,560
IDE05145-ENG115303-Light configuration-Dimming_Direction_GH_17,maximize ,560
IDE05145-ENG115322-Light configuration-Dimming_Direction_GH_18,maximize ,560
IDE05145-ENG115341-Light configuration-Dimming_Direction_GH_19,maximize ,560
IDE05145-ENG115069-Light configuration-Dimming_Direction_GH_2,maximize ,560
IDE05145-ENG115360-Light configuration-Dimming_Direction_GH_20,maximize ,560
IDE05145-ENG115379-Light configuration-Dimming_Direction_GH_21,maximize ,560
IDE05145-ENG115398-Light configuration-Dimming_Direction_GH_22,maximize ,560
IDE05145-ENG115417-Light configuration-Dimming_Direction_GH_23,maximize ,560
IDE05145-ENG115436-Light configuration-Dimming_Direction_GH_24,maximize ,560
IDE05145-ENG115455-Light configuration-Dimming_Direction_GH_25,maximize ,560
IDE05145-ENG115474-Light configuration-Dimming_Direction_GH_26,maximize ,560
IDE05145-ENG115493-Light configuration-Dimming_Direction_GH_27,maximize ,560
IDE05145-ENG115512-Light configuration-Dimming_Direction_GH_28,maximize ,560
IDE05145-ENG115531-Light configuration-Dimming_Direction_GH_29,maximize ,560
IDE05145-ENG115088-Light configuration-Dimming_Direction_GH_3,maximize ,560
IDE05145-ENG115550-Light configuration-Dimming_Direction_GH_30,maximize ,560
IDE05145-ENG115569-Light configuration-Dimming_Direction_GH_31,maximize ,560
IDE05145-ENG115588-Light configuration-Dimming_Direction_GH_32,maximize ,560
IDE05145-ENG115607-Light configuration-Dimming_Direction_GH_33,maximize ,560
IDE05145-ENG115626-Light configuration-Dimming_Direction_GH_34,maximize ,560
IDE05145-ENG115107-Light configuration-Dimming_Direction_GH_4,maximize ,560
IDE05145-ENG114990-Light configuration-Dimming_Direction_GH_5,maximize ,560
IDE05145-ENG115128-Light configuration-Dimming_Direction_GH_6,maximize ,560
IDE05145-ENG115147-Light configuration-Dimming_Direction_GH_7,maximize ,560
IDE05145-ENG115166-Light configuration-Dimming_Direction_GH_8,maximize ,560
IDE05145-ENG115185-Light configuration-Dimming_Direction_GH_9,maximize ,560
IDE05145-ENG115026-Light configuration-Dimming_EF_0,0 ,560
IDE05145-ENG115045-Light configuration-Dimming_EF_1,0 ,560
IDE05145-ENG115007-Light configuration-Dimming_EF_10,0 ,560
IDE05145-ENG115201-Light configuration-Dimming_EF_11,0 ,560
IDE05145-ENG115220-Light configuration-Dimming_EF_12,0 ,560
IDE05145-ENG114966-Light configuration-Dimming_EF_13,0 ,560
IDE05145-ENG115241-Light configuration-Dimming_EF_14,0 ,560
IDE05145-ENG115260-Light configuration-Dimming_EF_15,0 ,560
IDE05145-ENG115279-Light configuration-Dimming_EF_16,0 ,560
IDE05145-ENG115298-Light configuration-Dimming_EF_17,0 ,560
IDE05145-ENG115317-Light configuration-Dimming_EF_18,0 ,560
IDE05145-ENG115336-Light configuration-Dimming_EF_19,0 ,560
IDE05145-ENG115064-Light configuration-Dimming_EF_2,0 ,560
IDE05145-ENG115355-Light configuration-Dimming_EF_20,0 ,560
IDE05145-ENG115374-Light configuration-Dimming_EF_21,0 ,560
IDE05145-ENG115393-Light configuration-Dimming_EF_22,0 ,560
IDE05145-ENG115412-Light configuration-Dimming_EF_23,0 ,560
IDE05145-ENG115431-Light configuration-Dimming_EF_24,0 ,560
IDE05145-ENG115450-Light configuration-Dimming_EF_25,0 ,560
IDE05145-ENG115469-Light configuration-Dimming_EF_26,0 ,560
IDE05145-ENG115488-Light configuration-Dimming_EF_27,0 ,560
IDE05145-ENG115507-Light configuration-Dimming_EF_28,0 ,560
IDE05145-ENG115526-Light configuration-Dimming_EF_29,0 ,560
IDE05145-ENG115083-Light configuration-Dimming_EF_3,0 ,560
IDE05145-ENG115545-Light configuration-Dimming_EF_30,0 ,560
IDE05145-ENG115564-Light configuration-Dimming_EF_31,0 ,560
IDE05145-ENG115583-Light configuration-Dimming_EF_32,0 ,560
IDE05145-ENG115602-Light configuration-Dimming_EF_33,0 ,560
IDE05145-ENG115621-Light configuration-Dimming_EF_34,0 ,560
IDE05145-ENG115102-Light configuration-Dimming_EF_4,0 ,560
IDE05145-ENG114985-Light configuration-Dimming_EF_5,0 ,560
IDE05145-ENG115123-Light configuration-Dimming_EF_6,0 ,560
IDE05145-ENG115142-Light configuration-Dimming_EF_7,0 ,560
IDE05145-ENG115161-Light configuration-Dimming_EF_8,0 ,560
IDE05145-ENG115180-Light configuration-Dimming_EF_9,0 ,560
IDE05145-ENG115030-Light configuration-Dimming_GH_0,0 ,560
IDE05145-ENG115049-Light configuration-Dimming_GH_1,0 ,560
IDE05145-ENG115011-Light configuration-Dimming_GH_10,0 ,560
IDE05145-ENG115205-Light configuration-Dimming_GH_11,0 ,560
IDE05145-ENG115224-Light configuration-Dimming_GH_12,0 ,560
IDE05145-ENG114970-Light configuration-Dimming_GH_13,0 ,560
IDE05145-ENG115245-Light configuration-Dimming_GH_14,0 ,560
IDE05145-ENG115264-Light configuration-Dimming_GH_15,0 ,560
IDE05145-ENG115283-Light configuration-Dimming_GH_16,0 ,560
IDE05145-ENG115302-Light configuration-Dimming_GH_17,0 ,560
IDE05145-ENG115321-Light configuration-Dimming_GH_18,0 ,560
IDE05145-ENG115340-Light configuration-Dimming_GH_19,0 ,560
IDE05145-ENG115068-Light configuration-Dimming_GH_2,0 ,560
IDE05145-ENG115359-Light configuration-Dimming_GH_20,0 ,560
IDE05145-ENG115378-Light configuration-Dimming_GH_21,0 ,560
IDE05145-ENG115397-Light configuration-Dimming_GH_22,0 ,560
IDE05145-ENG115416-Light configuration-Dimming_GH_23,0 ,560
IDE05145-ENG115435-Light configuration-Dimming_GH_24,0 ,560
IDE05145-ENG115454-Light configuration-Dimming_GH_25,0 ,560
IDE05145-ENG115473-Light configuration-Dimming_GH_26,0 ,560
IDE05145-ENG115492-Light configuration-Dimming_GH_27,0 ,560
IDE05145-ENG115511-Light configuration-Dimming_GH_28,0 ,560
IDE05145-ENG115530-Light configuration-Dimming_GH_29,0 ,560
IDE05145-ENG115087-Light configuration-Dimming_GH_3,0 ,560
IDE05145-ENG115549-Light configuration-Dimming_GH_30,0 ,560
IDE05145-ENG115568-Light configuration-Dimming_GH_31,0 ,560
IDE05145-ENG115587-Light configuration-Dimming_GH_32,0 ,560
IDE05145-ENG115606-Light configuration-Dimming_GH_33,0 ,560
IDE05145-ENG115625-Light configuration-Dimming_GH_34,0 ,560
IDE05145-ENG115106-Light configuration-Dimming_GH_4,0 ,560
IDE05145-ENG114989-Light configuration-Dimming_GH_5,0 ,560
IDE05145-ENG115127-Light configuration-Dimming_GH_6,0 ,560
IDE05145-ENG115146-Light configuration-Dimming_GH_7,0 ,560
IDE05145-ENG115165-Light configuration-Dimming_GH_8,0 ,560
IDE05145-ENG115184-Light configuration-Dimming_GH_9,0 ,560
IDE05145-ENG115015-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_0,14 ,560
IDE05145-ENG115034-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_1,15 ,560
IDE05145-ENG115187-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_10,00 ,560
IDE05145-ENG115190-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_11,00 ,560
IDE05145-ENG115209-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_12,22 ,560
IDE05145-ENG115227-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_13,23 ,560
IDE05145-ENG115230-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_14,00 ,560
IDE05145-ENG115249-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_15,00 ,560
IDE05145-ENG115268-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_16,00 ,560
IDE05145-ENG115287-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_17,00 ,560
IDE05145-ENG115306-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_18,16 ,560
IDE05145-ENG115325-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_19,18 ,560
IDE05145-ENG115053-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_2,26 ,560
IDE05145-ENG115344-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_20,2B ,560
IDE05145-ENG115363-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_21,2D ,560
IDE05145-ENG115382-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_22,2C ,560
IDE05145-ENG115401-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_23,29 ,560
IDE05145-ENG115420-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_24,2A ,560
IDE05145-ENG115439-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_25,00 ,560
IDE05145-ENG115458-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_26,2E ,560
IDE05145-ENG115477-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_27,08 ,560
IDE05145-ENG115496-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_28,32 ,560
IDE05145-ENG115515-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_29,01 ,560
IDE05145-ENG115072-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_3,27 ,560
IDE05145-ENG115534-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_30,07 ,560
IDE05145-ENG115553-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_31,00 ,560
IDE05145-ENG115572-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_32,00 ,560
IDE05145-ENG115591-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_33,00 ,560
IDE05145-ENG115610-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_34,00 ,560
IDE05145-ENG115091-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_4,20 ,560
IDE05145-ENG115109-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_5,21 ,560
IDE05145-ENG115112-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_6,1A ,560
IDE05145-ENG115131-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_7,1B ,560
IDE05145-ENG115150-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_8,1C ,560
IDE05145-ENG115169-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_9,1D ,560
IDE05145-ENG115019-Light configuration-Light_Control_HD_AB_0,Always ,560
IDE05145-ENG115038-Light configuration-Light_Control_HD_AB_1,Always ,560
IDE05145-ENG115000-Light configuration-Light_Control_HD_AB_10,Always ,560
IDE05145-ENG115194-Light configuration-Light_Control_HD_AB_11,Always ,560
IDE05145-ENG115213-Light configuration-Light_Control_HD_AB_12,Always ,560
IDE05145-ENG114959-Light configuration-Light_Control_HD_AB_13,Always ,560
IDE05145-ENG115234-Light configuration-Light_Control_HD_AB_14,Always ,560
IDE05145-ENG115253-Light configuration-Light_Control_HD_AB_15,Always ,560
IDE05145-ENG115272-Light configuration-Light_Control_HD_AB_16,Always ,560
IDE05145-ENG115291-Light configuration-Light_Control_HD_AB_17,Always ,560
IDE05145-ENG115310-Light configuration-Light_Control_HD_AB_18,Always ,560
IDE05145-ENG115329-Light configuration-Light_Control_HD_AB_19,Always ,560
IDE05145-ENG115057-Light configuration-Light_Control_HD_AB_2,Always ,560
IDE05145-ENG115348-Light configuration-Light_Control_HD_AB_20,Always ,560
IDE05145-ENG115367-Light configuration-Light_Control_HD_AB_21,Always ,560
IDE05145-ENG115386-Light configuration-Light_Control_HD_AB_22,Always ,560
IDE05145-ENG115405-Light configuration-Light_Control_HD_AB_23,Always ,560
IDE05145-ENG115424-Light configuration-Light_Control_HD_AB_24,Always ,560
IDE05145-ENG115443-Light configuration-Light_Control_HD_AB_25,Always ,560
IDE05145-ENG115462-Light configuration-Light_Control_HD_AB_26,Always ,560
IDE05145-ENG115481-Light configuration-Light_Control_HD_AB_27,Always ,560
IDE05145-ENG115500-Light configuration-Light_Control_HD_AB_28,Always ,560
IDE05145-ENG115520-Light configuration-Light_Control_HD_AB_29,Always ,560
IDE05145-ENG115076-Light configuration-Light_Control_HD_AB_3,Always ,560
IDE05145-ENG115538-Light configuration-Light_Control_HD_AB_30,Always ,560
IDE05145-ENG115557-Light configuration-Light_Control_HD_AB_31,Always ,560
IDE05145-ENG115576-Light configuration-Light_Control_HD_AB_32,Always ,560
IDE05145-ENG115595-Light configuration-Light_Control_HD_AB_33,Always ,560
IDE05145-ENG115614-Light configuration-Light_Control_HD_AB_34,Always ,560
IDE05145-ENG115095-Light configuration-Light_Control_HD_AB_4,Always ,560
IDE05145-ENG114978-Light configuration-Light_Control_HD_AB_5,Always ,560
IDE05145-ENG115116-Light configuration-Light_Control_HD_AB_6,Always ,560
IDE05145-ENG115135-Light configuration-Light_Control_HD_AB_7,Always ,560
IDE05145-ENG115154-Light configuration-Light_Control_HD_AB_8,Always ,560
IDE05145-ENG115173-Light configuration-Light_Control_HD_AB_9,Always ,560
IDE05145-ENG115016-Light configuration-Light_Function_A_0,2 ,560
IDE05145-ENG115035-Light configuration-Light_Function_A_1,4 ,560
IDE05145-ENG114997-Light configuration-Light_Function_A_10,0 ,560
IDE05145-ENG115191-Light configuration-Light_Function_A_11,62 ,560
IDE05145-ENG115210-Light configuration-Light_Function_A_12,18 ,560
IDE05145-ENG114956-Light configuration-Light_Function_A_13,19 ,560
IDE05145-ENG115231-Light configuration-Light_Function_A_14,63 ,560
IDE05145-ENG115250-Light configuration-Light_Function_A_15,64 ,560
IDE05145-ENG115269-Light configuration-Light_Function_A_16,2 ,560
IDE05145-ENG115288-Light configuration-Light_Function_A_17,4 ,560
IDE05145-ENG115307-Light configuration-Light_Function_A_18,2 ,560
IDE05145-ENG115326-Light configuration-Light_Function_A_19,4 ,560
IDE05145-ENG115054-Light configuration-Light_Function_A_2,8 ,560
IDE05145-ENG115345-Light configuration-Light_Function_A_20,24 ,560
IDE05145-ENG115364-Light configuration-Light_Function_A_21,24 ,560
IDE05145-ENG115383-Light configuration-Light_Function_A_22,24 ,560
IDE05145-ENG115402-Light configuration-Light_Function_A_23,8 ,560
IDE05145-ENG115421-Light configuration-Light_Function_A_24,8 ,560
IDE05145-ENG115440-Light configuration-Light_Function_A_25,8 ,560
IDE05145-ENG115459-Light configuration-Light_Function_A_26,28 ,560
IDE05145-ENG115478-Light configuration-Light_Function_A_27,38 ,560
IDE05145-ENG115497-Light configuration-Light_Function_A_28,25 ,560
IDE05145-ENG115516-Light configuration-Light_Function_A_29,37 ,560
IDE05145-ENG115073-Light configuration-Light_Function_A_3,8 ,560
IDE05145-ENG115535-Light configuration-Light_Function_A_30,41 ,560
IDE05145-ENG115554-Light configuration-Light_Function_A_31,0 ,560
IDE05145-ENG115573-Light configuration-Light_Function_A_32,0 ,560
IDE05145-ENG115592-Light configuration-Light_Function_A_33,0 ,560
IDE05145-ENG115611-Light configuration-Light_Function_A_34,0 ,560
IDE05145-ENG115092-Light configuration-Light_Function_A_4,20 ,560
IDE05145-ENG114975-Light configuration-Light_Function_A_5,20 ,560
IDE05145-ENG115113-Light configuration-Light_Function_A_6,11 ,560
IDE05145-ENG115132-Light configuration-Light_Function_A_7,12 ,560
IDE05145-ENG115151-Light configuration-Light_Function_A_8,13 ,560
IDE05145-ENG115170-Light configuration-Light_Function_A_9,14 ,560
IDE05145-ENG115017-Light configuration-Light_Function_B_0,0 ,560
IDE05145-ENG115036-Light configuration-Light_Function_B_1,0 ,560
IDE05145-ENG114998-Light configuration-Light_Function_B_10,0 ,560
IDE05145-ENG115192-Light configuration-Light_Function_B_11,0 ,560
IDE05145-ENG115211-Light configuration-Light_Function_B_12,22 ,560
IDE05145-ENG114957-Light configuration-Light_Function_B_13,23 ,560
IDE05145-ENG115232-Light configuration-Light_Function_B_14,0 ,560
IDE05145-ENG115251-Light configuration-Light_Function_B_15,0 ,560
IDE05145-ENG115270-Light configuration-Light_Function_B_16,0 ,560
IDE05145-ENG115289-Light configuration-Light_Function_B_17,0 ,560
IDE05145-ENG115308-Light configuration-Light_Function_B_18,0 ,560
IDE05145-ENG115327-Light configuration-Light_Function_B_19,0 ,560
IDE05145-ENG115055-Light configuration-Light_Function_B_2,9 ,560
IDE05145-ENG115346-Light configuration-Light_Function_B_20,0 ,560
IDE05145-ENG115365-Light configuration-Light_Function_B_21,0 ,560
IDE05145-ENG115384-Light configuration-Light_Function_B_22,0 ,560
IDE05145-ENG115403-Light configuration-Light_Function_B_23,9 ,560
IDE05145-ENG115422-Light configuration-Light_Function_B_24,10 ,560
IDE05145-ENG115441-Light configuration-Light_Function_B_25,0 ,560
IDE05145-ENG115460-Light configuration-Light_Function_B_26,0 ,560
IDE05145-ENG115479-Light configuration-Light_Function_B_27,0 ,560
IDE05145-ENG115498-Light configuration-Light_Function_B_28,0 ,560
IDE05145-ENG115517-Light configuration-Light_Function_B_29,0 ,560
IDE05145-ENG115074-Light configuration-Light_Function_B_3,10 ,560
IDE05145-ENG115536-Light configuration-Light_Function_B_30,0 ,560
IDE05145-ENG115555-Light configuration-Light_Function_B_31,0 ,560
IDE05145-ENG115574-Light configuration-Light_Function_B_32,0 ,560
IDE05145-ENG115593-Light configuration-Light_Function_B_33,0 ,560
IDE05145-ENG115612-Light configuration-Light_Function_B_34,0 ,560
IDE05145-ENG115093-Light configuration-Light_Function_B_4,0 ,560
IDE05145-ENG114976-Light configuration-Light_Function_B_5,0 ,560
IDE05145-ENG115114-Light configuration-Light_Function_B_6,30 ,560
IDE05145-ENG115133-Light configuration-Light_Function_B_7,30 ,560
IDE05145-ENG115152-Light configuration-Light_Function_B_8,15 ,560
IDE05145-ENG115171-Light configuration-Light_Function_B_9,15 ,560
IDE05145-ENG115020-Light configuration-Light_Function_C_0,0 ,560
IDE05145-ENG115039-Light configuration-Light_Function_C_1,0 ,560
IDE05145-ENG115001-Light configuration-Light_Function_C_10,0 ,560
IDE05145-ENG115195-Light configuration-Light_Function_C_11,0 ,560
IDE05145-ENG115214-Light configuration-Light_Function_C_12,0 ,560
IDE05145-ENG114960-Light configuration-Light_Function_C_13,0 ,560
IDE05145-ENG115235-Light configuration-Light_Function_C_14,0 ,560
IDE05145-ENG115254-Light configuration-Light_Function_C_15,0 ,560
IDE05145-ENG115273-Light configuration-Light_Function_C_16,0 ,560
IDE05145-ENG115292-Light configuration-Light_Function_C_17,0 ,560
IDE05145-ENG115311-Light configuration-Light_Function_C_18,0 ,560
IDE05145-ENG115330-Light configuration-Light_Function_C_19,0 ,560
IDE05145-ENG115058-Light configuration-Light_Function_C_2,0 ,560
IDE05145-ENG115349-Light configuration-Light_Function_C_20,0 ,560
IDE05145-ENG115368-Light configuration-Light_Function_C_21,0 ,560
IDE05145-ENG115387-Light configuration-Light_Function_C_22,0 ,560
IDE05145-ENG115406-Light configuration-Light_Function_C_23,0 ,560
IDE05145-ENG115425-Light configuration-Light_Function_C_24,0 ,560
IDE05145-ENG115444-Light configuration-Light_Function_C_25,0 ,560
IDE05145-ENG115463-Light configuration-Light_Function_C_26,0 ,560
IDE05145-ENG115482-Light configuration-Light_Function_C_27,0 ,560
IDE05145-ENG115501-Light configuration-Light_Function_C_28,0 ,560
IDE05145-ENG115519-Light configuration-Light_Function_C_29,0 ,560
IDE05145-ENG115077-Light configuration-Light_Function_C_3,0 ,560
IDE05145-ENG115539-Light configuration-Light_Function_C_30,0 ,560
IDE05145-ENG115558-Light configuration-Light_Function_C_31,0 ,560
IDE05145-ENG115577-Light configuration-Light_Function_C_32,0 ,560
IDE05145-ENG115596-Light configuration-Light_Function_C_33,0 ,560
IDE05145-ENG115615-Light configuration-Light_Function_C_34,0 ,560
IDE05145-ENG115096-Light configuration-Light_Function_C_4,0 ,560
IDE05145-ENG114979-Light configuration-Light_Function_C_5,0 ,560
IDE05145-ENG115117-Light configuration-Light_Function_C_6,0 ,560
IDE05145-ENG115136-Light configuration-Light_Function_C_7,0 ,560
IDE05145-ENG115155-Light configuration-Light_Function_C_8,0 ,560
IDE05145-ENG115174-Light configuration-Light_Function_C_9,0 ,560
IDE05145-ENG115021-Light configuration-Light_Function_D_0,0 ,560
IDE05145-ENG115040-Light configuration-Light_Function_D_1,0 ,560
IDE05145-ENG115002-Light configuration-Light_Function_D_10,0 ,560
IDE05145-ENG115196-Light configuration-Light_Function_D_11,0 ,560
IDE05145-ENG115215-Light configuration-Light_Function_D_12,0 ,560
IDE05145-ENG114961-Light configuration-Light_Function_D_13,0 ,560
IDE05145-ENG115236-Light configuration-Light_Function_D_14,0 ,560
IDE05145-ENG115255-Light configuration-Light_Function_D_15,0 ,560
IDE05145-ENG115274-Light configuration-Light_Function_D_16,0 ,560
IDE05145-ENG115293-Light configuration-Light_Function_D_17,0 ,560
IDE05145-ENG115312-Light configuration-Light_Function_D_18,0 ,560
IDE05145-ENG115331-Light configuration-Light_Function_D_19,0 ,560
IDE05145-ENG115059-Light configuration-Light_Function_D_2,0 ,560
IDE05145-ENG115350-Light configuration-Light_Function_D_20,0 ,560
IDE05145-ENG115369-Light configuration-Light_Function_D_21,0 ,560
IDE05145-ENG115388-Light configuration-Light_Function_D_22,0 ,560
IDE05145-ENG115407-Light configuration-Light_Function_D_23,0 ,560
IDE05145-ENG115426-Light configuration-Light_Function_D_24,0 ,560
IDE05145-ENG115445-Light configuration-Light_Function_D_25,0 ,560
IDE05145-ENG115464-Light configuration-Light_Function_D_26,0 ,560
IDE05145-ENG115483-Light configuration-Light_Function_D_27,0 ,560
IDE05145-ENG115502-Light configuration-Light_Function_D_28,0 ,560
IDE05145-ENG115521-Light configuration-Light_Function_D_29,0 ,560
IDE05145-ENG115078-Light configuration-Light_Function_D_3,0 ,560
IDE05145-ENG115540-Light configuration-Light_Function_D_30,0 ,560
IDE05145-ENG115559-Light configuration-Light_Function_D_31,0 ,560
IDE05145-ENG115578-Light configuration-Light_Function_D_32,0 ,560
IDE05145-ENG115597-Light configuration-Light_Function_D_33,0 ,560
IDE05145-ENG115616-Light configuration-Light_Function_D_34,0 ,560
IDE05145-ENG115097-Light configuration-Light_Function_D_4,0 ,560
IDE05145-ENG114980-Light configuration-Light_Function_D_5,0 ,560
IDE05145-ENG115118-Light configuration-Light_Function_D_6,0 ,560
IDE05145-ENG115137-Light configuration-Light_Function_D_7,0 ,560
IDE05145-ENG115156-Light configuration-Light_Function_D_8,0 ,560
IDE05145-ENG115175-Light configuration-Light_Function_D_9,0 ,560
IDE05145-ENG115024-Light configuration-Light_Function_E_0,0 ,560
IDE05145-ENG115043-Light configuration-Light_Function_E_1,0 ,560
IDE05145-ENG115005-Light configuration-Light_Function_E_10,0 ,560
IDE05145-ENG115199-Light configuration-Light_Function_E_11,0 ,560
IDE05145-ENG115218-Light configuration-Light_Function_E_12,0 ,560
IDE05145-ENG114964-Light configuration-Light_Function_E_13,0 ,560
IDE05145-ENG115239-Light configuration-Light_Function_E_14,0 ,560
IDE05145-ENG115258-Light configuration-Light_Function_E_15,0 ,560
IDE05145-ENG115277-Light configuration-Light_Function_E_16,0 ,560
IDE05145-ENG115296-Light configuration-Light_Function_E_17,0 ,560
IDE05145-ENG115315-Light configuration-Light_Function_E_18,0 ,560
IDE05145-ENG115334-Light configuration-Light_Function_E_19,0 ,560
IDE05145-ENG115062-Light configuration-Light_Function_E_2,0 ,560
IDE05145-ENG115353-Light configuration-Light_Function_E_20,0 ,560
IDE05145-ENG115372-Light configuration-Light_Function_E_21,0 ,560
IDE05145-ENG115391-Light configuration-Light_Function_E_22,0 ,560
IDE05145-ENG115410-Light configuration-Light_Function_E_23,0 ,560
IDE05145-ENG115429-Light configuration-Light_Function_E_24,0 ,560
IDE05145-ENG115448-Light configuration-Light_Function_E_25,0 ,560
IDE05145-ENG115467-Light configuration-Light_Function_E_26,0 ,560
IDE05145-ENG115486-Light configuration-Light_Function_E_27,0 ,560
IDE05145-ENG115505-Light configuration-Light_Function_E_28,0 ,560
IDE05145-ENG115524-Light configuration-Light_Function_E_29,0 ,560
IDE05145-ENG115081-Light configuration-Light_Function_E_3,0 ,560
IDE05145-ENG115543-Light configuration-Light_Function_E_30,0 ,560
IDE05145-ENG115562-Light configuration-Light_Function_E_31,0 ,560
IDE05145-ENG115581-Light configuration-Light_Function_E_32,0 ,560
IDE05145-ENG115600-Light configuration-Light_Function_E_33,0 ,560
IDE05145-ENG115619-Light configuration-Light_Function_E_34,0 ,560
IDE05145-ENG115100-Light configuration-Light_Function_E_4,0 ,560
IDE05145-ENG114983-Light configuration-Light_Function_E_5,0 ,560
IDE05145-ENG115121-Light configuration-Light_Function_E_6,0 ,560
IDE05145-ENG115140-Light configuration-Light_Function_E_7,0 ,560
IDE05145-ENG115159-Light configuration-Light_Function_E_8,0 ,560
IDE05145-ENG115178-Light configuration-Light_Function_E_9,0 ,560
IDE05145-ENG115025-Light configuration-Light_Function_F_0,0 ,560
IDE05145-ENG115044-Light configuration-Light_Function_F_1,0 ,560
IDE05145-ENG115006-Light configuration-Light_Function_F_10,0 ,560
IDE05145-ENG115200-Light configuration-Light_Function_F_11,0 ,560
IDE05145-ENG115219-Light configuration-Light_Function_F_12,0 ,560
IDE05145-ENG114965-Light configuration-Light_Function_F_13,0 ,560
IDE05145-ENG115240-Light configuration-Light_Function_F_14,0 ,560
IDE05145-ENG115259-Light configuration-Light_Function_F_15,0 ,560
IDE05145-ENG115278-Light configuration-Light_Function_F_16,0 ,560
IDE05145-ENG115297-Light configuration-Light_Function_F_17,0 ,560
IDE05145-ENG115316-Light configuration-Light_Function_F_18,0 ,560
IDE05145-ENG115335-Light configuration-Light_Function_F_19,0 ,560
IDE05145-ENG115063-Light configuration-Light_Function_F_2,0 ,560
IDE05145-ENG115354-Light configuration-Light_Function_F_20,0 ,560
IDE05145-ENG115373-Light configuration-Light_Function_F_21,0 ,560
IDE05145-ENG115392-Light configuration-Light_Function_F_22,0 ,560
IDE05145-ENG115411-Light configuration-Light_Function_F_23,0 ,560
IDE05145-ENG115430-Light configuration-Light_Function_F_24,0 ,560
IDE05145-ENG115449-Light configuration-Light_Function_F_25,0 ,560
IDE05145-ENG115468-Light configuration-Light_Function_F_26,0 ,560
IDE05145-ENG115487-Light configuration-Light_Function_F_27,0 ,560
IDE05145-ENG115506-Light configuration-Light_Function_F_28,0 ,560
IDE05145-ENG115525-Light configuration-Light_Function_F_29,0 ,560
IDE05145-ENG115082-Light configuration-Light_Function_F_3,0 ,560
IDE05145-ENG115544-Light configuration-Light_Function_F_30,0 ,560
IDE05145-ENG115563-Light configuration-Light_Function_F_31,0 ,560
IDE05145-ENG115582-Light configuration-Light_Function_F_32,0 ,560
IDE05145-ENG115601-Light configuration-Light_Function_F_33,0 ,560
IDE05145-ENG115620-Light configuration-Light_Function_F_34,0 ,560
IDE05145-ENG115101-Light configuration-Light_Function_F_4,0 ,560
IDE05145-ENG114984-Light configuration-Light_Function_F_5,0 ,560
IDE05145-ENG115122-Light configuration-Light_Function_F_6,0 ,560
IDE05145-ENG115141-Light configuration-Light_Function_F_7,0 ,560
IDE05145-ENG115160-Light configuration-Light_Function_F_8,0 ,560
IDE05145-ENG115179-Light configuration-Light_Function_F_9,0 ,560
IDE05145-ENG115028-Light configuration-Light_Function_G_0,0 ,560
IDE05145-ENG115047-Light configuration-Light_Function_G_1,0 ,560
IDE05145-ENG115009-Light configuration-Light_Function_G_10,0 ,560
IDE05145-ENG115203-Light configuration-Light_Function_G_11,0 ,560
IDE05145-ENG115222-Light configuration-Light_Function_G_12,0 ,560
IDE05145-ENG114968-Light configuration-Light_Function_G_13,0 ,560
IDE05145-ENG115243-Light configuration-Light_Function_G_14,0 ,560
IDE05145-ENG115262-Light configuration-Light_Function_G_15,0 ,560
IDE05145-ENG115281-Light configuration-Light_Function_G_16,0 ,560
IDE05145-ENG115300-Light configuration-Light_Function_G_17,0 ,560
IDE05145-ENG115319-Light configuration-Light_Function_G_18,0 ,560
IDE05145-ENG115338-Light configuration-Light_Function_G_19,0 ,560
IDE05145-ENG115066-Light configuration-Light_Function_G_2,0 ,560
IDE05145-ENG115357-Light configuration-Light_Function_G_20,0 ,560
IDE05145-ENG115376-Light configuration-Light_Function_G_21,0 ,560
IDE05145-ENG115395-Light configuration-Light_Function_G_22,0 ,560
IDE05145-ENG115414-Light configuration-Light_Function_G_23,0 ,560
IDE05145-ENG115433-Light configuration-Light_Function_G_24,0 ,560
IDE05145-ENG115452-Light configuration-Light_Function_G_25,0 ,560
IDE05145-ENG115471-Light configuration-Light_Function_G_26,0 ,560
IDE05145-ENG115490-Light configuration-Light_Function_G_27,0 ,560
IDE05145-ENG115509-Light configuration-Light_Function_G_28,0 ,560
IDE05145-ENG115528-Light configuration-Light_Function_G_29,0 ,560
IDE05145-ENG115085-Light configuration-Light_Function_G_3,0 ,560
IDE05145-ENG115547-Light configuration-Light_Function_G_30,0 ,560
IDE05145-ENG115566-Light configuration-Light_Function_G_31,0 ,560
IDE05145-ENG115585-Light configuration-Light_Function_G_32,0 ,560
IDE05145-ENG115604-Light configuration-Light_Function_G_33,0 ,560
IDE05145-ENG115623-Light configuration-Light_Function_G_34,0 ,560
IDE05145-ENG115104-Light configuration-Light_Function_G_4,0 ,560
IDE05145-ENG114987-Light configuration-Light_Function_G_5,0 ,560
IDE05145-ENG115125-Light configuration-Light_Function_G_6,0 ,560
IDE05145-ENG115144-Light configuration-Light_Function_G_7,0 ,560
IDE05145-ENG115163-Light configuration-Light_Function_G_8,0 ,560
IDE05145-ENG115182-Light configuration-Light_Function_G_9,0 ,560
IDE05145-ENG115029-Light configuration-Light_Function_H_0,0 ,560
IDE05145-ENG115048-Light configuration-Light_Function_H_1,0 ,560
IDE05145-ENG115010-Light configuration-Light_Function_H_10,0 ,560
IDE05145-ENG115204-Light configuration-Light_Function_H_11,0 ,560
IDE05145-ENG115223-Light configuration-Light_Function_H_12,0 ,560
IDE05145-ENG114969-Light configuration-Light_Function_H_13,0 ,560
IDE05145-ENG115244-Light configuration-Light_Function_H_14,0 ,560
IDE05145-ENG115263-Light configuration-Light_Function_H_15,0 ,560
IDE05145-ENG115282-Light configuration-Light_Function_H_16,0 ,560
IDE05145-ENG115301-Light configuration-Light_Function_H_17,0 ,560
IDE05145-ENG115320-Light configuration-Light_Function_H_18,0 ,560
IDE05145-ENG115339-Light configuration-Light_Function_H_19,0 ,560
IDE05145-ENG115067-Light configuration-Light_Function_H_2,0 ,560
IDE05145-ENG115358-Light configuration-Light_Function_H_20,0 ,560
IDE05145-ENG115377-Light configuration-Light_Function_H_21,0 ,560
IDE05145-ENG115396-Light configuration-Light_Function_H_22,0 ,560
IDE05145-ENG115415-Light configuration-Light_Function_H_23,0 ,560
IDE05145-ENG115434-Light configuration-Light_Function_H_24,0 ,560
IDE05145-ENG115453-Light configuration-Light_Function_H_25,0 ,560
IDE05145-ENG115472-Light configuration-Light_Function_H_26,0 ,560
IDE05145-ENG115491-Light configuration-Light_Function_H_27,0 ,560
IDE05145-ENG115510-Light configuration-Light_Function_H_28,0 ,560
IDE05145-ENG115529-Light configuration-Light_Function_H_29,0 ,560
IDE05145-ENG115086-Light configuration-Light_Function_H_3,0 ,560
IDE05145-ENG115548-Light configuration-Light_Function_H_30,0 ,560
IDE05145-ENG115567-Light configuration-Light_Function_H_31,0 ,560
IDE05145-ENG115586-Light configuration-Light_Function_H_32,0 ,560
IDE05145-ENG115605-Light configuration-Light_Function_H_33,0 ,560
IDE05145-ENG115624-Light configuration-Light_Function_H_34,0 ,560
IDE05145-ENG115105-Light configuration-Light_Function_H_4,0 ,560
IDE05145-ENG114988-Light configuration-Light_Function_H_5,0 ,560
IDE05145-ENG115126-Light configuration-Light_Function_H_6,0 ,560
IDE05145-ENG115145-Light configuration-Light_Function_H_7,0 ,560
IDE05145-ENG115164-Light configuration-Light_Function_H_8,0 ,560
IDE05145-ENG115183-Light configuration-Light_Function_H_9,0 ,560
IDE05145-ENG154373-Light configuration-Reserved_0,0 ,560
IDE05145-ENG101416-Light configuration-Reserved_1,0 ,560
IDE05145-ENG154318-Light configuration-Reserved_10,0 ,560
IDE05145-ENG99637-Light configuration-Reserved_11,0 ,560
IDE05145-ENG154355-Light configuration-Reserved_12,0 ,560
IDE05145-ENG154196-Light configuration-Reserved_13,0 ,560
IDE05145-ENG154298-Light configuration-Reserved_14,0 ,560
IDE05145-ENG154243-Light configuration-Reserved_15,0 ,560
IDE05145-ENG154297-Light configuration-Reserved_16,0 ,560
IDE05145-ENG154432-Light configuration-reserved_17,0 ,560
IDE05145-ENG154433-Light configuration-reserved_18,0 ,560
IDE05145-ENG154434-Light configuration-reserved_19,0 ,560
IDE05145-ENG99458-Light configuration-Reserved_2,0 ,560
IDE05145-ENG154435-Light configuration-reserved_20,0 ,560
IDE05145-ENG154436-Light configuration-reserved_21,0 ,560
IDE05145-ENG159603-Light configuration-reserved_22,0 ,560
IDE05145-ENG154437-Light configuration-reserved_23,0 ,560
IDE05145-ENG159604-Light configuration-reserved_24,0 ,560
IDE05145-ENG159605-Light configuration-reserved_25,0 ,560
IDE05145-ENG159606-Light configuration-reserved_26,0 ,560
IDE05145-ENG159607-Light configuration-reserved_27,0 ,560
IDE05145-ENG159608-Light configuration-reserved_28,0 ,560
IDE05145-ENG159609-Light configuration-reserved_29,0 ,560
IDE05145-ENG99668-Light configuration-Reserved_3,00 ,560
IDE05145-ENG159610-Light configuration-reserved_30,0 ,560
IDE05145-ENG159611-Light configuration-reserved_31,0 ,560
IDE05145-ENG114291-Light configuration-reserved_32,0 ,560
IDE05145-ENG184465-Light configuration-reserved_33,0 ,560
IDE05145-ENG159612-Light configuration-reserved_34,0 ,560
IDE05145-ENG154261-Light configuration-Reserved_4,0 ,560
IDE05145-ENG154330-Light configuration-Reserved_5,0 ,560
IDE05145-ENG154188-Light configuration-Reserved_6,0 ,560
IDE05145-ENG154256-Light configuration-Reserved_7,0 ,560
IDE05145-ENG154341-Light configuration-Reserved_8,0 ,560
IDE05145-ENG154185-Light configuration-Reserved_9,0 ,560
IDE05145-ENG115013-Light configuration-Type_Of_Load_0,Blinkleuchten ,560
IDE05145-ENG115032-Light configuration-Type_Of_Load_1,Blinkleuchten ,560
IDE05145-ENG114995-Light configuration-Type_Of_Load_10,not active ,560
IDE05145-ENG115188-Light configuration-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose ,560
IDE05145-ENG115207-Light configuration-Type_Of_Load_12,allgemeine Scheinwerfer ,560
IDE05145-ENG114954-Light configuration-Type_Of_Load_13,allgemeine Scheinwerfer ,560
IDE05145-ENG115228-Light configuration-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose ,560
IDE05145-ENG115247-Light configuration-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose ,560
IDE05145-ENG115266-Light configuration-Type_Of_Load_16,LED Blinkleuchten ,560
IDE05145-ENG115285-Light configuration-Type_Of_Load_17,LED Blinkleuchten ,560
IDE05145-ENG115304-Light configuration-Type_Of_Load_18,Blinkleuchten ,560
IDE05145-ENG115323-Light configuration-Type_Of_Load_19,Blinkleuchten ,560
IDE05145-ENG115051-Light configuration-Type_Of_Load_2,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115342-Light configuration-Type_Of_Load_20,Bremsleuchten ,560
IDE05145-ENG115361-Light configuration-Type_Of_Load_21,Bremsleuchten ,560
IDE05145-ENG115380-Light configuration-Type_Of_Load_22,LEDdritteBremsleuchte ,560
IDE05145-ENG115399-Light configuration-Type_Of_Load_23,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115418-Light configuration-Type_Of_Load_24,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115437-Light configuration-Type_Of_Load_25,2* 5W ,560
IDE05145-ENG115456-Light configuration-Type_Of_Load_26,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115475-Light configuration-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose ,560
IDE05145-ENG115494-Light configuration-Type_Of_Load_28,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115513-Light configuration-Type_Of_Load_29,allgemeineGluehlampe12W ,560
IDE05145-ENG115070-Light configuration-Type_Of_Load_3,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115532-Light configuration-Type_Of_Load_30,allgemeineGluehlampe12W ,560
IDE05145-ENG115551-Light configuration-Type_Of_Load_31,not active ,560
IDE05145-ENG115570-Light configuration-Type_Of_Load_32,not active ,560
IDE05145-ENG115589-Light configuration-Type_Of_Load_33,not active ,560
IDE05145-ENG115608-Light configuration-Type_Of_Load_34,not active ,560
IDE05145-ENG115089-Light configuration-Type_Of_Load_4,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG114973-Light configuration-Type_Of_Load_5,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115110-Light configuration-Type_Of_Load_6,Low beam ,560
IDE05145-ENG115129-Light configuration-Type_Of_Load_7,Low beam ,560
IDE05145-ENG115148-Light configuration-Type_Of_Load_8,allgemeineScheinwerferohneAbschaltung ,560
IDE05145-ENG115167-Light configuration-Type_Of_Load_9,allgemeineScheinwerferohneAbschaltung ,560
IDE05822-DWA Vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 63 0A 78 01 14 0A 03 C1 33 0C 00 00 00 01 CD 46 06 00 0F 1D 00 85 0F 39 F7 24 23 65 42 57 9B 25 44 3F 3A 69 35 95 2C 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 29 0F E3 42 87 1B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 29 1E 65 42 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 24 0C 42 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 64 26 06 15 0C 12 18 86 09 30 33 27 23 65 42 57 9B 25 24 0C FA 0A 34 95 2C 09 A3 21 03 00 02 02 02 02 02 02 91 10 A1 26 A5 ,172
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active ,6
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,6
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,6
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,6
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,6
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung,not active ,6
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %,6
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,2
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,2
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,2
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,2
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,2
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,2
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,2
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,2
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,2
IDE07007-ENG115783-A/C heater function via remote control-Remote_Start_Duration,0 min,2
IDE07007-ENG126614-A/C heater function via remote control-valid_remote_starts,0 ,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,5
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,5
IDE08542-IDE02021-Access control 2-Comfort closing,active ,6
IDE08542-IDE02022-Access control 2-Comfort opening,active ,6
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,6
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,6
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,6
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,6
IDE08542-ENG116649-Access control 2-Freigabenachlauf FH bei Tueroeffnen,active ,6
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,6
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,6
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active ,6
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,6
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,No ,6
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,No ,6
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,6
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,6
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active ,6
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,6
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,6
IDE08542-ENG125658-Access control 2-Profilfunktion für Anklappung der Außenspiegel,active ,6
IDE08542-ENG115671-Access control 2-Regenschließen,not active ,6
IDE08542-ENG125656-Access control 2-Regenschliessen_art,once ,6
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active ,6
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active ,6
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active ,6
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,Open ,6
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active ,6
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active ,6
IDE08542-ENG126612-Access control 2-Spiegelanklappung geschwindigkeitsabhängig,not active ,6
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,0 ms,4
IDE08786-ENG142177-Assistance light functions-Assistance_lighting_sensitivity_adjustable,Not Present ,4
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,4
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein Hinweis ,4
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active ,4
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,4
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,4
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,4
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,4
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,4
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,not active ,1
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,not active ,1
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken,not active ,4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
IDE10286-ENG130228-Configuration of light collective diagnostic line 1: instance 1-Defektbit,Licht_vorne_01 Byte 5 ,7
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC,36 ,7
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0,not active ,7
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1,not active ,7
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10,not active ,7
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11,not active ,7
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12,not active ,7
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13,not active ,7
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14,not active ,7
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15,not active ,7
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16,not active ,7
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17,not active ,7
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18,not active ,7
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19,not active ,7
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2,not active ,7
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20,not active ,7
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21,not active ,7
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22,not active ,7
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23,not active ,7
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24,not active ,7
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25,not active ,7
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26,not active ,7
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27,not active ,7
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28,not active ,7
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29,not active ,7
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3,not active ,7
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30,not active ,7
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31,not active ,7
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32,not active ,7
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33,not active ,7
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34,not active ,7
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4,not active ,7
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5,not active ,7
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6,not active ,7
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7,not active ,7
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8,not active ,7
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9,not active ,7
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand,150_Ohm ,7
IDE10288-ENG130228-Configuration of light collective diagnostic line 2: instance 1-Defektbit,Licht_vorne_01 Byte 5 ,7
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC,40 ,7
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0,not active ,7
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1,not active ,7
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10,not active ,7
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11,not active ,7
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12,not active ,7
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13,not active ,7
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14,not active ,7
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15,not active ,7
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16,not active ,7
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17,not active ,7
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18,not active ,7
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19,not active ,7
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2,not active ,7
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20,not active ,7
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21,not active ,7
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22,not active ,7
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23,not active ,7
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24,not active ,7
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25,not active ,7
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26,not active ,7
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27,not active ,7
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28,not active ,7
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29,not active ,7
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3,not active ,7
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30,not active ,7
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31,not active ,7
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32,not active ,7
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33,not active ,7
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34,not active ,7
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4,not active ,7
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5,not active ,7
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6,not active ,7
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7,not active ,7
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8,not active ,7
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9,not active ,7
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand,150_Ohm ,7
MAS01490-Energy management,Energy management not active ,1
MAS08233-ENG126574-other-auspraegung_Bremsfluessigkeitsschalter,closed ,1
MAS08233-ENG126575-other-mute_mode_aktiv,not active ,1
MAS08233-ENG125011-other-pa_Funktion_2aus3,not installed ,1
ENG124896-Adaptation_theft_protection,not active ,2
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,150
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.0 %,22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.0 %,22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.0 %,22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.0 %,22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.0 %,22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.0 %,22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.0 %,22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.0 %,22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.0 %,22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.0 %,22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.0 %,22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 lx,22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 lx,22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.0 %,22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.0 %,22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.0 %,22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.0 %,22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.0 %,22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.0 %,22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.0 %,22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.0 %,22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.0 %,22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.0 %,22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.0 %,22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.0 %,12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.0 %,12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.0 %,12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.0 %,12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.0 %,12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.0 %,12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.0 ,10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.0 ,10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.0 ,10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.0 ,10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.0 ,10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.0 ,10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.0 ,10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.0 ,10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.0 ,10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.0 ,10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,100.0 %,12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,100.0 %,12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,100.0 %,12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,100.0 %,12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,100.0 %,12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.0 %,12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.0 ,8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.0 ,8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.0 ,8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.0 ,8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.0 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.0 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.0 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.0 ,8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.0 %,6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.0 %,6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.0 %,6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.0 %,6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.0 %,6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.0 %,6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.0 ,8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.0 ,8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.0 ,8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.0 ,8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.0 ,8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.0 ,8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.0 ,8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.0 ,8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.0 %,6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.0 %,6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.0 %,6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.0 %,6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.0 %,6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.0 %,6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,0 ms,10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,0 ms,10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,0 ms,10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,0 ms,10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,0.0 %,10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,0.0 ,10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,0.0 ,10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,0.0 ,10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,0.0 ,10
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0,100 ,16
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0,0 ,16
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0,maximize ,16
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0,maximize ,16
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0,maximize ,16
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0,0 ,16
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0,0 ,16
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0,14 ,16
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0,34 ,16
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0,Always ,16
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0,Blinken links Hellphase ,16
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0,not active ,16
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0,not active ,16
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0,not active ,16
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0,not active ,16
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0,not active ,16
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0,not active ,16
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0,not active ,16
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0,Blinkleuchten ,16
ENG124871-ENG114999-Leuchte10SHUTTER LRB45-Dimming_AB_10,0 ,16
ENG124871-ENG115003-Leuchte10SHUTTER LRB45-Dimming_CD_10,0 ,16
ENG124871-ENG115004-Leuchte10SHUTTER LRB45-Dimming_Direction_CD_10,maximize ,16
ENG124871-ENG115008-Leuchte10SHUTTER LRB45-Dimming_Direction_EF_10,maximize ,16
ENG124871-ENG115012-Leuchte10SHUTTER LRB45-Dimming_Direction_GH_10,maximize ,16
ENG124871-ENG115007-Leuchte10SHUTTER LRB45-Dimming_EF_10,0 ,16
ENG124871-ENG115011-Leuchte10SHUTTER LRB45-Dimming_GH_10,0 ,16
ENG124871-ENG126585-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10,00 ,16
ENG124871-ENG114996-Leuchte10SHUTTER LRB45-Lampendefektbit_Position_10,00 ,16
ENG124871-ENG115000-Leuchte10SHUTTER LRB45-Light_Control_HD_AB_10,Always ,16
ENG124871-ENG114997-Leuchte10SHUTTER LRB45-Light_Function_A_10,not active ,16
ENG124871-ENG114998-Leuchte10SHUTTER LRB45-Light_Function_B_10,not active ,16
ENG124871-ENG115001-Leuchte10SHUTTER LRB45-Light_Function_C_10,not active ,16
ENG124871-ENG115002-Leuchte10SHUTTER LRB45-Light_Function_D_10,not active ,16
ENG124871-ENG115005-Leuchte10SHUTTER LRB45-Light_Function_E_10,not active ,16
ENG124871-ENG115006-Leuchte10SHUTTER LRB45-Light_Function_F_10,not active ,16
ENG124871-ENG115009-Leuchte10SHUTTER LRB45-Light_Function_G_10,not active ,16
ENG124871-ENG115010-Leuchte10SHUTTER LRB45-Light_Function_H_10,not active ,16
ENG124871-ENG114995-Leuchte10SHUTTER LRB45-Type_Of_Load_10,not active ,16
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11,100 ,16
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11,0 ,16
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11,maximize ,16
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11,maximize ,16
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11,maximize ,16
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11,0 ,16
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11,0 ,16
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11,00 ,16
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11,00 ,16
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11,Always ,16
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11,Warnblinktaster ,16
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11,not active ,16
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11,not active ,16
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11,not active ,16
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11,not active ,16
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11,not active ,16
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11,not active ,16
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11,not active ,16
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose ,16
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12,100 ,16
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12,0 ,16
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12,maximize ,16
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12,maximize ,16
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12,maximize ,16
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12,0 ,16
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12,0 ,16
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12,22 ,16
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12,38 ,16
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12,Always ,16
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12,Nebellicht links ,16
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12,Abbiegelicht links ,16
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12,not active ,16
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12,not active ,16
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12,not active ,16
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12,not active ,16
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12,not active ,16
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12,not active ,16
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12,allgemeine Scheinwerfer ,16
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13,100 ,16
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13,0 ,16
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13,maximize ,16
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13,maximize ,16
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13,maximize ,16
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13,0 ,16
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13,0 ,16
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13,23 ,16
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13,42 ,16
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13,Always ,16
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13,Nebellicht rechts ,16
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13,Abbiegelicht rechts ,16
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13,not active ,16
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13,not active ,16
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13,not active ,16
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13,not active ,16
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13,not active ,16
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13,not active ,16
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13,allgemeine Scheinwerfer ,16
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15,100 ,16
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15,0 ,16
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15,maximize ,16
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15,maximize ,16
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15,maximize ,16
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15,0 ,16
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15,0 ,16
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15,00 ,16
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15,00 ,16
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15,Always ,16
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15,SafeLED ,16
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15,not active ,16
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15,not active ,16
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15,not active ,16
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15,not active ,16
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15,not active ,16
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15,not active ,16
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15,not active ,16
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose ,16
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16,100 ,16
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16,0 ,16
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16,maximize ,16
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16,maximize ,16
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16,maximize ,16
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16,0 ,16
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16,0 ,16
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16,00 ,16
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16,00 ,16
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16,Always ,16
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16,Blinken links Hellphase ,16
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16,not active ,16
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16,not active ,16
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16,not active ,16
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16,not active ,16
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16,not active ,16
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16,not active ,16
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16,not active ,16
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16,LED Blinkleuchten ,16
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17,100 ,16
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17,0 ,16
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17,maximize ,16
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17,maximize ,16
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17,maximize ,16
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17,0 ,16
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17,0 ,16
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17,00 ,16
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17,00 ,16
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17,Always ,16
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17,Blinken rechts Hellphase ,16
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17,not active ,16
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17,not active ,16
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17,not active ,16
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17,not active ,16
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17,not active ,16
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17,not active ,16
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17,not active ,16
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17,LED Blinkleuchten ,16
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18,100 ,16
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18,0 ,16
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18,maximize ,16
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18,maximize ,16
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18,maximize ,16
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18,0 ,16
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18,0 ,16
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18,16 ,16
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18,08 ,16
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18,Always ,16
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18,Blinken links Hellphase ,16
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18,not active ,16
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18,not active ,16
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18,not active ,16
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18,not active ,16
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18,not active ,16
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18,not active ,16
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18,not active ,16
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18,Blinkleuchten ,16
ENG124880-ENG115328-Leuchte19BLK HRC8-Dimming_AB_19,100 ,16
ENG124880-ENG115332-Leuchte19BLK HRC8-Dimming_CD_19,0 ,16
ENG124880-ENG115333-Leuchte19BLK HRC8-Dimming_Direction_CD_19,maximize ,16
ENG124880-ENG115337-Leuchte19BLK HRC8-Dimming_Direction_EF_19,maximize ,16
ENG124880-ENG115341-Leuchte19BLK HRC8-Dimming_Direction_GH_19,maximize ,16
ENG124880-ENG115336-Leuchte19BLK HRC8-Dimming_EF_19,0 ,16
ENG124880-ENG115340-Leuchte19BLK HRC8-Dimming_GH_19,0 ,16
ENG124880-ENG126594-Leuchte19BLK HRC8-Fehlerort_mittleres_Byte_DTC-DFCC_19,18 ,16
ENG124880-ENG115785-Leuchte19BLK HRC8-Lampendefektbit_Position_19,18 ,16
ENG124880-ENG115329-Leuchte19BLK HRC8-Light_Control_HD_AB_19,Always ,16
ENG124880-ENG115326-Leuchte19BLK HRC8-Light_Function_A_19,Blinken rechts Hellphase ,16
ENG124880-ENG115327-Leuchte19BLK HRC8-Light_Function_B_19,not active ,16
ENG124880-ENG115330-Leuchte19BLK HRC8-Light_Function_C_19,not active ,16
ENG124880-ENG115331-Leuchte19BLK HRC8-Light_Function_D_19,not active ,16
ENG124880-ENG115334-Leuchte19BLK HRC8-Light_Function_E_19,not active ,16
ENG124880-ENG115335-Leuchte19BLK HRC8-Light_Function_F_19,not active ,16
ENG124880-ENG115338-Leuchte19BLK HRC8-Light_Function_G_19,not active ,16
ENG124880-ENG115339-Leuchte19BLK HRC8-Light_Function_H_19,not active ,16
ENG124880-ENG115323-Leuchte19BLK HRC8-Type_Of_Load_19,Blinkleuchten ,16
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1,100 ,16
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1,0 ,16
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1,maximize ,16
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1,maximize ,16
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1,maximize ,16
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1,0 ,16
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1,0 ,16
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1,15 ,16
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1,3E ,16
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1,Always ,16
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1,Blinken rechts Hellphase ,16
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1,not active ,16
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1,not active ,16
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1,not active ,16
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1,not active ,16
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1,not active ,16
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1,not active ,16
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1,not active ,16
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1,Blinkleuchten ,16
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20,100 ,16
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20,0 ,16
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20,maximize ,16
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20,maximize ,16
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20,maximize ,16
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20,0 ,16
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20,0 ,16
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20,2B ,16
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20,09 ,16
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20,Always ,16
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20,Brake light ,16
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20,not active ,16
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20,not active ,16
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20,not active ,16
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20,not active ,16
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20,not active ,16
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20,not active ,16
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20,not active ,16
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20,Bremsleuchten ,16
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21,100 ,16
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21,0 ,16
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21,maximize ,16
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21,maximize ,16
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21,maximize ,16
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21,0 ,16
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21,0 ,16
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21,2D ,16
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21,19 ,16
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21,Always ,16
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21,Brake light ,16
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21,not active ,16
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21,not active ,16
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21,not active ,16
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21,not active ,16
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21,not active ,16
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21,not active ,16
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21,not active ,16
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21,Bremsleuchten ,16
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22,100 ,16
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22,0 ,16
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22,maximize ,16
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22,maximize ,16
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22,maximize ,16
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22,0 ,16
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22,0 ,16
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22,2C ,16
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22,29 ,16
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22,Always ,16
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22,Brake light ,16
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22,not active ,16
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22,not active ,16
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22,not active ,16
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22,not active ,16
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22,not active ,16
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22,not active ,16
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22,not active ,16
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22,LEDdritteBremsleuchte ,16
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23,60 ,16
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23,0 ,16
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23,maximize ,16
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23,maximize ,16
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23,maximize ,16
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23,0 ,16
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23,0 ,16
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23,29 ,16
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23,0A ,16
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23,Always ,16
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23,Parking light ,16
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23,Parking light left ,16
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23,not active ,16
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23,not active ,16
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23,not active ,16
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23,not active ,16
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23,not active ,16
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23,not active ,16
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23,allgemeineGluehlampe6W:auchH6W ,16
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24,60 ,16
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24,0 ,16
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24,maximize ,16
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24,maximize ,16
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24,maximize ,16
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24,0 ,16
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24,0 ,16
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24,2A ,16
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24,1A ,16
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24,Always ,16
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24,Parking light ,16
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24,Parking light right ,16
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24,not active ,16
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24,not active ,16
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24,not active ,16
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24,not active ,16
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24,not active ,16
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24,not active ,16
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24,allgemeineGluehlampe6W:auchH6W ,16
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25,100 ,16
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25,0 ,16
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25,maximize ,16
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25,maximize ,16
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25,maximize ,16
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25,0 ,16
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25,0 ,16
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25,00 ,16
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25,00 ,16
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25,Always ,16
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25,Parking light ,16
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25,not active ,16
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25,not active ,16
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25,not active ,16
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25,not active ,16
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25,not active ,16
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25,not active ,16
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25,not active ,16
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25,2* 5W ,16
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26,100 ,16
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26,0 ,16
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26,maximize ,16
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26,maximize ,16
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26,maximize ,16
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26,0 ,16
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26,0 ,16
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26,2E ,16
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26,0C ,16
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26,Always ,16
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26,NebelschlusslichtwennkeinAnhaengergestecktundLinksverkehr ,16
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26,not active ,16
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26,not active ,16
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26,not active ,16
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26,not active ,16
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26,not active ,16
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26,not active ,16
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26,not active ,16
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27,100 ,16
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27,0 ,16
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27,maximize ,16
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27,maximize ,16
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize ,16
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27,0 ,16
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27,0 ,16
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27,08 ,16
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27,00 ,16
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27,Always ,16
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27,Terminal 58xs dimmer ,16
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27,not active ,16
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27,not active ,16
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27,not active ,16
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27,not active ,16
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27,not active ,16
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27,not active ,16
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27,not active ,16
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose ,16
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28,100 ,16
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28,0 ,16
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize ,16
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize ,16
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize ,16
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28,0 ,16
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28,0 ,16
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,32 ,16
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28,1B ,16
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28,Always ,16
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht ,16
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28,not active ,16
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28,not active ,16
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28,not active ,16
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28,not active ,16
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28,not active ,16
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28,not active ,16
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28,not active ,16
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29,100 ,16
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29,0 ,16
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize ,16
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize ,16
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize ,16
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29,0 ,16
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29,0 ,16
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,01 ,16
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29,00 ,16
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always ,16
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29,Klemme 30G ,16
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29,not active ,16
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29,not active ,16
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29,not active ,16
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29,not active ,16
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29,not active ,16
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29,not active ,16
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29,not active ,16
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeineGluehlampe12W ,16
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2,100 ,16
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2,0 ,16
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2,maximize ,16
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2,maximize ,16
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2,maximize ,16
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2,0 ,16
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2,0 ,16
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2,26 ,16
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2,35 ,16
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2,Always ,16
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2,Parking light ,16
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2,Parking light left ,16
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2,not active ,16
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2,not active ,16
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2,not active ,16
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2,not active ,16
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2,not active ,16
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2,not active ,16
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2,allgemeineGluehlampe6W:auchH6W ,16
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30,100 ,16
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30,0 ,16
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30,maximize ,16
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30,maximize ,16
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30,maximize ,16
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30,0 ,16
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30,0 ,16
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30,07 ,16
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30,00 ,16
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30,Always ,16
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30,Interior light ,16
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30,not active ,16
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30,not active ,16
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30,not active ,16
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30,not active ,16
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30,not active ,16
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30,not active ,16
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30,not active ,16
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30,allgemeineGluehlampe12W ,16
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31,0 ,16
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31,0 ,16
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31,maximize ,16
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31,maximize ,16
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31,maximize ,16
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31,0 ,16
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31,0 ,16
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31,00 ,16
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31,00 ,16
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31,Always ,16
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31,not active ,16
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31,not active ,16
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31,not active ,16
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31,not active ,16
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31,not active ,16
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31,not active ,16
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31,not active ,16
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31,not active ,16
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31,not active ,16
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32,0 ,16
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32,0 ,16
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32,maximize ,16
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32,maximize ,16
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32,maximize ,16
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32,0 ,16
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32,0 ,16
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32,00 ,16
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32,00 ,16
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32,Always ,16
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32,not active ,16
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32,not active ,16
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32,not active ,16
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32,not active ,16
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32,not active ,16
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32,not active ,16
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32,not active ,16
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32,not active ,16
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32,not active ,16
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33,0 ,16
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33,0 ,16
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33,maximize ,16
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33,maximize ,16
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33,maximize ,16
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33,0 ,16
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33,0 ,16
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33,00 ,16
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33,00 ,16
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33,Always ,16
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33,not active ,16
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33,not active ,16
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33,not active ,16
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33,not active ,16
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33,not active ,16
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33,not active ,16
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33,not active ,16
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33,not active ,16
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33,not active ,16
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34,0 ,16
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34,0 ,16
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34,maximize ,16
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34,maximize ,16
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34,maximize ,16
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34,0 ,16
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34,0 ,16
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34,00 ,16
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34,00 ,16
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34,Always ,16
ENG124894-ENG115611-Leuchte34AMBL 4C71-Light_Function_A_34,not active ,16
ENG124894-ENG115612-Leuchte34AMBL 4C71-Light_Function_B_34,not active ,16
ENG124894-ENG115615-Leuchte34AMBL 4C71-Light_Function_C_34,not active ,16
ENG124894-ENG115616-Leuchte34AMBL 4C71-Light_Function_D_34,not active ,16
ENG124894-ENG115619-Leuchte34AMBL 4C71-Light_Function_E_34,not active ,16
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34,not active ,16
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34,not active ,16
ENG124894-ENG115624-Leuchte34AMBL 4C71-Light_Function_H_34,not active ,16
ENG124894-ENG115608-Leuchte34AMBL 4C71-Type_Of_Load_34,not active ,16
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3,100 ,16
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3,0 ,16
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3,maximize ,16
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3,maximize ,16
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3,maximize ,16
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3,0 ,16
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3,0 ,16
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3,27 ,16
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3,3F ,16
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3,Always ,16
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3,Parking light ,16
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3,Parking light right ,16
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3,not active ,16
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3,not active ,16
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3,not active ,16
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3,not active ,16
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3,not active ,16
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3,not active ,16
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3,allgemeineGluehlampe6W:auchH6W ,16
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4,100 ,16
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4,0 ,16
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4,maximize ,16
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4,maximize ,16
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4,maximize ,16
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4,0 ,16
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4,0 ,16
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4,20 ,16
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4,3A ,16
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4,Always ,16
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4,Daytime running lights ,16
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4,not active ,16
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4,not active ,16
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4,not active ,16
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4,not active ,16
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4,not active ,16
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4,not active ,16
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4,not active ,16
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5,100 ,16
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5,0 ,16
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5,maximize ,16
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5,maximize ,16
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5,maximize ,16
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5,0 ,16
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5,0 ,16
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5,21 ,16
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5,44 ,16
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5,Always ,16
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5,Daytime running lights ,16
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5,not active ,16
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5,not active ,16
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5,not active ,16
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5,not active ,16
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5,not active ,16
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5,not active ,16
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5,not active ,16
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6,100 ,16
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6,0 ,16
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6,maximize ,16
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6,maximize ,16
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6,maximize ,16
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6,0 ,16
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6,0 ,16
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6,1A ,16
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6,36 ,16
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6,Always ,16
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6,Abblendlicht links ,16
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6,ComingHome LeavingHome ,16
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6,not active ,16
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6,not active ,16
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6,not active ,16
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6,not active ,16
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6,not active ,16
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6,not active ,16
ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6,Low beam ,16
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7,100 ,16
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7,0 ,16
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7,maximize ,16
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7,maximize ,16
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7,maximize ,16
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7,0 ,16
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7,0 ,16
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7,1B ,16
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7,40 ,16
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7,Always ,16
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7,Abblendlicht rechts ,16
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7,ComingHome LeavingHome ,16
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7,not active ,16
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7,not active ,16
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7,not active ,16
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7,not active ,16
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7,not active ,16
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7,not active ,16
ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7,Low beam ,16
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8,100 ,16
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8,0 ,16
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8,maximize ,16
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8,maximize ,16
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7,maximize ,16
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8,0 ,16
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8,0 ,16
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8,1C ,16
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8,37 ,16
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8,Always ,16
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8,Left high beam ,16
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8,Headlamp flasher ,16
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8,not active ,16
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8,not active ,16
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8,not active ,16
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8,not active ,16
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8,not active ,16
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8,not active ,16
ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8,allgemeineScheinwerferohneAbschaltung ,16
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9,100 ,16
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9,0 ,16
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9,maximize ,16
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9,maximize ,16
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9,maximize ,16
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9,0 ,16
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9,0 ,16
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9,1D ,16
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9,41 ,16
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9,Always ,16
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9,Right high beam ,16
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9,Headlamp flasher ,16
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9,not active ,16
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9,not active ,16
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9,not active ,16
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9,not active ,16
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9,not active ,16
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9,not active ,16
ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9,allgemeineScheinwerferohneAbschaltung ,16
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14,100 ,16
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14,0 ,16
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14,maximize ,16
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14,maximize ,16
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14,maximize ,16
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14,0 ,16
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14,0 ,16
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14,00 ,16
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14,00 ,16
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14,Always ,16
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14,LockUnlockLED ,16
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14,not active ,16
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14,not active ,16
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14,not active ,16
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14,not active ,16
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14,not active ,16
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14,not active ,16
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14,not active ,16
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose ,16
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0 ,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,10 ,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,100 ,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,150 ,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,220 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,253 ,12
ENG130141-Patch_Code: Beifahrer,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130136-Patch_Code: Fahrer,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117299-Reversing_Threshold_Driver_Side_Rear,0 %,1
ENG117298-Reversing_Threshold_Passenger_Side_Front,0 %,1
ENG130135-Window_Regulator_Supplier_Settings_Driver_Side_3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130138-Window_Regulator_Supplier_Settings_Passener_Side_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130139-Window_Regulator_Supplier_Settings_Passener_Side_2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130140-Window_Regulator_Supplier_Settings_Passener_Side_3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG127068-Window_Regulator_VW_Settings_Driver_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
ENG130137-Window_Regulator_VW_Settings_Passenger_Side,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,88
ENG127067-Window_Regulator_VW_Settings_Passenger_Side_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
ENG127069-Window_Regulator_VW_Settings_Passenger_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
Elapsed Time: 01:28
