Friday,20,December,2019,12:38:18:14741
VCDS Version: 19.10.0.0 (x64) HEX-NET CB: 0.4517.4
Data version: 20190930 DS316.0
VIN: 3VV3B7AX6LM009820 License Plate:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 3C 42 44 52 5F 6C 6D 75 A5
BB BC CA
VIN: 3VV3B7AX6LM009820 Mileage: 31km-19miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DGUA) Labels: None
Part No SW: 83A 907 115 B HW: 06L 907 309 B
Component: R4 2.0l TFSI H31 0004
Revision: 1DH31000
Coding: 012A00122464012FB4000000000000000000000000000000
Shop #: WSC 03999 444 28888
ASAM Dataset: EV_ECM20TFS01183A907115B 001005
ROD: EV_ECM20TFS01183A907115B.rod
VCID: A51C1ADE75621F793A6D-80F0
Readiness: 0010 0101
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 DS HW: 09G 927 158
Component: AISIN AQ8 206 3699
Coding: 0002000100000000000000000000000000000000
Shop #: WSC 00066 790 00446
ROD: EV_TCMAQ450031_VW32.rod
VCID: 87407056EFAE2D692851-80D2
Part No SW: 5Q0 614 517 FE HW: 5Q0 614 517 BP
Component: ESC H35 0191
Revision: 00000000 Serial number: 52039000000295
Coding: 0BFA6BA450201B75C57F0202A2C349D0D60AD8A34045927038415058D2A24A0B00002764121A1C230A35351919323200
ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
VCID: F9A406AEA95A4B992EA5-80AC
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0520308780
Coding: 132C0C0723
Shop #: WSC 00066 790 00184
ROD: EV_KessyHellaMQBAB.rod
VCID: C5DCBA5E9522FF791AAD-8090
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 5NN 907 044 AA HW: 5NN 907 044 AA
Component: AC Automat H36 4803
Revision: 20K03000 Serial number: 00000D00405690
Coding: 00020024200118001104010C12111406
ASAM Dataset: EV_ACClimaPrehVW37X 002027
ROD: EV_ACClimaPrehVW37X_002_VW37.rod
VCID: 8B484C66F3C649090C69-80DE
Part No SW: 5Q0 937 087 BG HW: 5Q0 937 087 BA
Component: BCM PQ37BOSCH 038 0303
Revision: -------- Serial number: C864100819019I
Shop #: WSC 00066 790 00448
ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
ROD: EV_BCMBOSCH_020_VW37.rod
VCID: 81546E4EC18A13596615-80D4
Subsystem 1 - Part No SW: 5NN 955 119 HW: 5NN 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 190531 034 0373
Serial number: 19052921035740
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0206
Serial number: S7Y19M07D11H23M24S35
Coding: 0008DD
Steering Column Switch:
Subsystem 4 - Part No SW: 5Q1 953 521 R HW: 5Q1 953 569 B
Component: Lenks.Modul H23 0170
Serial number: 0300120720190C201397
Part No SW: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000259540419220
Coding: 0471155811
ASAM Dataset: EV_EPHVA18AU3700000 009046
VCID: D0F29B0A5A602AD1B93B-8084
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 3200075258FF8728749C810530409700000000000000000004
ASAM Dataset: EV_ACCMRRCONTIVW376 003016
ROD: EV_ACCMRRCONTIVW376_003.rod
VCID: C3D8A4469B16C14934B9-8096
Part No SW: 5Q0 959 655 BM HW: 5Q0 959 655 BM
Component: AirbagVW21 005 0403
Serial number: 003FGM04SRN9
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
VCID: 8C4A4F7AF6C84E310563-80D8
Occupant Detection:
Component: BF-Gewichtss. H14 0022
Serial number: IBH00000000000BU7X31
Coding: 303451
Subsystem 2 - Part No SW: ----------- HW: 480 001 706 19
Serial number: 35700000000436B0583C
Subsystem 3 - Part No SW: ----------- HW: 480 002 706 19
Serial number: 358000000006E874CB3
Subsystem 4 - Part No SW: ----------- HW: 480 400 207 19
Component: SideSensor_Dr 005 6149
Serial number: 3510001C4F0A2E11145-
Subsystem 5 - Part No SW: ----------- HW: 480 401 107 19
Component: SideSensor_Pr 005 6149
Serial number: 35200019CF03BAE2370B
Subsystem 6 - Part No SW: ----------- HW: 480 402 307 19
Component: FrontSensor_D 005 6149
Serial number: 3550001AEF112386A525
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 307 19
Component: FrontSensor_P 005 6149
Serial number: 3560001AEF112387B4DI
Part No SW: 3G0 920 890 E HW: 3G0 920 890 E
Component: KOMBI 502 4192
Coding: 08A420086788CF050288624B10010000A0000D07
ASAM Dataset: EV_DashBoardVDDMQBA0 001042
ROD: EV_DashBoardVDDMQBA0_VW37.rod
VCID: AB08ECE613862909ECA9-80FE
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 04081900842548
Coding: 030100347F085900FA000258180F00010001070000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: F0B23B8AFA200AD1997B-80A4
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 5NA 959 442 B HW: 5NA 959 442 B
Component: E221__MFL-TAT H06 0025
Serial number: 2001907132300754FG2B
Coding: 2E0000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 7995786700
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0148
Serial number: 11230013777499
Coding: 52954640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15.rod
VCID: B924C6AEE9DA8B996E25-80EC
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 5Q4 959 393 K HW: 5Q4 959 393 K
Component: TSG FS 007 0480
Serial number: 14058917600612
Coding: 00301B200000048000000000
Shop #: WSC 01383 790 50316
ROD: EV_DCU2DriveSideMAXHKLO.rod
VCID: CBC88C66B3460909CCE9-809E
Subsystem 1 - Part No SW: 5Q4 959 811 G HW: 5Q4 959 811 G
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000003780273
Coding: 011000
Part No SW: 5QM 909 144 B HW: 5QM 909 144 B
Component: EPS_MQB_ZFLS 173 1081
Coding: 111F0000
ROD: EV_SteerAssisMQB_015.rod
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 5Q4 959 392 K HW: 5Q4 959 392 K
Component: TSG BFS 007 0480
Serial number: 15058922202423
Coding: 003013200000048000000000
ROD: EV_DCU2PasseSideMAXHKLO.rod
VCID: CAC68962BC3C1001F7FF-809E
Subsystem 1 - Part No SW: 5Q4 959 812 G HW: 5Q4 959 812 G
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000003802594
Coding: 091000
Part No SW: 2GM 035 876 B HW: 2GM 035 876 B
Component: MU-S-NS-US 854 0520
Coding: 02730602BE00000051220001001808211F0500E401200405C6
ROD: EV_MUStd4CDELP_VW37.rod
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav 254 8130
Serial number: VWZ6ZMW2275030
Subsystem 2 - Part No SW: 5NA 919 866 P HW: -----------
Component: NAR 2019/20 --- 0910
Component: RVC Compact H18 0231
Coding: 0123060122002017300040
Part No SW: 5Q0 959 107 S HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0271
Revision: -------- Serial number: A2-C758-8680-4
Coding: 0A08
VCID: C8C2B36AA230E211E1CB-809C
Address 75: Telematics (J949) Labels:* None
Part No SW: 5WA 035 283 HW: 5WA 035 283
Component: OCUGen3Low H10 0295
Serial number: 0000000907NVLZ3
Coding: 0232602019682C208005461160100607
ASAM Dataset: EV_OCUGen3Low 002036
ROD: EV_OCUGen3Low.rod
VCID: 82566142C48C08417F0F-80D6
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H11 0610
Serial number: 18021915P22045
Coding: 0003070601020201002213468140490084000E00010000
ROD: EV_MFKBoschMQBB_002.rod
VCID: C0D2AB4A8A00DA51299B-8094
Address BB: Door Rear Drv
Address BC: Door Rear Pass
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Coding: 00804073260C
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: F5BC0A9E85422FF94A8D-80A0
End----------(Elapsed Time: 01:27, VBatt start/end: 14.9V/15.1V)-----------
Engine @ idle, cold start:
;SW:83A-907-115-B HW:06L-907-309-B --- Engine
;Component:R4 2.0l TFSI H31 0004, Coding:012A00122464012FB4000000000000000000000000000000
;EV_ECM20TFS01183A907115B,001005,EV_ECM20TFS01183A907115B.rod
;Friday,20,December,2019,12:35:24:14741
;VCDS Version: Beta 19.10.0 (x64) Data version: 20190930 DS316.0
;VCID: A51C1ADE75621F793A6D-80F0
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),3VV3B7AX6LM009820,
IDE00019,Voltage terminal 30,14.760, V
IDE00020-ENG57549,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine speed,1217, /min
IDE00025,Coolant temperature,5, °C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00076,Status of initial fuel filling,was not yet started,
IDE00078,Time since engine start,11, s
IDE00083,Throttle valve position (absolute),14.9, %
IDE00084,Absolute load value,40, %
IDE00085,Normed load value,23.9, %
IDE00086,Accelerator position,15, %
IDE00090-ENG57549,selected gear-Bits 0-7,0,
IDE00094,Kick-down status,Not operated,
IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00100,Engine torque,53.2, Nm
IDE00102,Control Module temperature,8.7, °C
IDE00148,Median injection timing,2.0712, ms
IDE00150,Pressure in brake booster,86.99, hPa
IDE00151,Oil fill level,80.508, mm
IDE00152,Oil warning threshold,58.000, mm
IDE00155,Timing angle retardation cylinder 1,0.0, °
IDE00156,Timing angle retardation cylinder 2,0.0, °
IDE00157,Timing angle retardation cylinder 3,0.0, °
IDE00158,Timing angle retardation cylinder 4,0.0, °
IDE00167,Exhaust temperature 1 bank 1,11.6, °C
IDE00172,A/C compressor torque,20.0, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-23.00, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-22.72, °
IDE00178,Camshaft adjustment intake bank 1: specified value,0.00, °
IDE00179,Camshaft adjustment intake bank 1: actual value,0.06, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.00, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,0.00, °
IDE00186,Fuel low pressure: actual value,0.0, kPa
IDE00187,Coolant temperature at engine start,3.1, °C
IDE00188,Fuel high pressure: actual value,5.7980, MPa
IDE00190,Charge air pressure specified value,540.94, hPa
IDE00191,Charge air pressure: actual value,999.61, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,7.2, °C
IDE00194,Coolant temperature at radiator output: specified value,98.2, °C
IDE00196,Engine oil temperature,6.5, °C
IDE00201,High fuel pressure: specified value,5.9000, MPa
IDE00202,Low fuel pressure: specified value,417.9, kPa
IDE00304,Fuel level,57.00, l
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00347,Air mass: actual value:,8.77, g/s
IDE00348,Intake air temperature,8, °C
IDE00349,Throttle valve position: normed,5, %
IDE00350,Air mass: specified value,32.3, kg/h
IDE00354,Engine start: start synchronization,EPM_MODE_OK,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00355-ENG57549,Cruise Control System (CCS): status-Bits 0-7,2,
IDE00357,Fuel temperature,6.0, °C
IDE00358,Limitation: torque,1000.0, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00361,Ambient air pressure,999.41, hPa
IDE00371,Fuel consumption,3.16, l/h
IDE00375,Generator: load signal,25.78, %
IDE00380,Coolant fan 1: activation,10.54, %
IDE00392,Accelerator pedal: sensor voltage 1,733.6, mV
IDE00393,Accelerator pedal: sensor voltage 2,374.6, mV
IDE00405,Crankshaft speed (RPM),1209.5, /min
IDE00406,Camshaft speed (RPM),600.8, /min
IDE00407-ENG57549,Rail pressure regulation: status-Bits 0-7,1,
IDE00412-ENG57549,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG57549,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG57549,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG57549,Starter control: terminal 50 acknowledgment-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,1,
IDE00443-ENG57549,Accelerator pedal: switch positions-Bits 0-7,9,
IDE00445,Unlearning counter according OBD,255,
IDE00450,Operating Instructions,---,
IDE00451,Currently running routine,Unknown (0),
IDE00474,Ambient air pressure,99, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,8.3, Nm
IDE00496-ENG57549,Activation of oil pressure switch valve-Bits 0-7,0,
IDE00497-ENG57549,Status of oil pressure switches-Bits 0-7,143,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside air temperature,10, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),1.003 Lambda / -0.004 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,1.275, V
IDE00560-MAS04122,Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00582,Equivalence ratio target value,1.000, Lambda
IDE00583,Throttle valve specified value,6, %
IDE00584,Distance driven since erasing DTC memory,13, km
IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,0, km
IDE00588,Fuel tank fill level,100.0, %
IDE00589,Fuel pressure,5910, kPa rel
IDE00592,Oxygen sensor control status,Open loop, conditions for / closed loop not yet satisfied ,
IDE00593,Ignition timing adjustment cylinder 1,-10.5, Degrees
IDE00594,Absolute intake pressure,48, kPa abs
IDE00595,Allocation of oxygen sensors,B1S1 B1S2 ,
IDE00597,Long term adaptation of mixture formation bank 1,-0.8, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,1,
IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
IDE00608,Type of fuel,Gasoline,
IDE00612,Target position of EVAP canister valve,0.0, %
IDE00699,ESI: minimum oil level in service interval,32.000, mm
IDE00700,ESI: maximum oil level in service interval,-32.000, mm
IDE00727,Test steps still to be performed,0,
IDE00738,Test of oxygen sensors bank 1: Delta-Lambda,0.00079,
IDE00752,Test of oxygen sensor control.,Test off,
IDE00752-ENG127302,Test of oxygen sensor control.-Test_Program_Channel 213,235,
IDE00773,Terminal 15 status via CAN,1,
IDE00787,Cause for cancellation,0,
IDE00949,Hide cylinder,not active,
IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
IDE00973,Outside air temperature,10.5, °C
IDE01076,Time since ignition off,65535, s
IDE01098,Test of knock sensors: short trip result,Test off,
IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
IDE01260,Generator power,697.434, W
IDE01266-ENG57549,Coolant shut-off valve-Bits 0-7,2,
IDE01267,Height correction,0.98651,
IDE01378,High fuel pressure: control deviation,0.0160, MPa
IDE01385-ENG57549,Wear index-Bits 0-7,0,
IDE01386-ENG57549,Soot index-Bits 0-7,0,
IDE01405-ENG57549,Status of starter activation-Bits 0-7,2,
IDE01590,Status of brakes,Not operated,
IDE01590-ENG127367,Status of brakes-Test_Program_Channel 600,167,
IDE01638,Result O2 sensor aging test bank 1 or 3 before cat. conv.,Test off,
IDE01638-ENG127368,Result O2 sensor aging test bank 1 or 3 before cat. conv.-Test_Program_Channel 951,235,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,1.522, V
IDE01650,Throttle valve position 2,15, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test off,
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,235,
IDE01667,Result of test of camshaft adjustment outlet bank 1,Test off,
IDE01667-ENG127371,Result of test of camshaft adjustment outlet bank 1-Test_Program_Channel 619,235,
IDE01680,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve,Test off,
IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,235,
IDE01773,Misfire sum counter,2,
IDE01774,Status misfire recognition,activated,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,103,
IDE01775,Misfires per 1000 revolutions of cylinder 1,0,
IDE01776,Misfires per 1000 revolutions of cylinder 2,2,
IDE01777,Misfires per 1000 revolutions of cylinder 3,0,
IDE01778,Misfires per 1000 revolutions of cylinder 4,0,
IDE01834,Battery voltage,14800, mV
IDE01869,Long-term fuel trim bank 1 at idle,-1.73, %
IDE01870,Oxygen sensor after catalytic converter: operating status,Test off,
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,235,
IDE01872,Result of oxygen sensor aging test after catalytic converter,Test off,
IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,235,
IDE01873,Test of catalytic converter: measured value,8.0000,
IDE01874,Test of catalytic converter: result,Test off,
IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,235,
IDE01875,Required torque adjustment by idling regulator,0.000, %
IDE01876,Adaptation of loss torque,-1.6, Nm
IDE01877-ENG57549,Operating condition of idle speed control-Bits 0-7,5,
IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000000 ,
IDE01879,Adaptation of throttle valve: result,ERROR,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,90,
IDE01880,Accelerator position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01884,Camshaft adjustment intake bank 1: activation,31.207, %
IDE01885,Shut off of oxygen sensor control,l-Reg.OFF,
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,3,
IDE01887,Adaptation of Fuel Pump (FP),0.0, kPa
IDE01888,Cold start enrichment: adaptation area 1,1.000,
IDE01889,Cold start enrichment: adaptation area 2,1.000,
IDE01890,Cold start enrichment: adaptation area 3,1.000,
IDE01891,Cold start enrichment: adaptation area 4,1.000,
IDE01892,Cold start enrichment: adaptation area 5,1.000,
IDE01893,Fuel pump: specified value,47.549, %
IDE01896,Charge pressure control: damping grtr max. threshold adaptation,0.000, %
IDE01897,Charge pressure control: damping lsr min. threshold adaptation,0.000, %
IDE01899,Load value: corrected specified value,112.41, %
IDE01900,Charge press. ctrl.: spec. value,99.6, %
IDE01901,Lost torque adaptation: idle,0.0, Nm
IDE01902,Lost torque adaptation A/C compressor,-1.6, Nm
IDE01903,Lost torque adaptation driving mode,0.0, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,0.9, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,0.97015,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,1.04956,
IDE01911,Leakage air,3.1, kg/h
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,1.0000,
IDE01914-ENG57549,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bits 0-7,0,
IDE01916,Leakage recognition from oxygen sensor control,0.9954,
IDE01917,Leakage after throttle valve,0.000,
IDE01918,Leakage before throttle valve,-1.000,
IDE01919-ENG57549,Leakage recognition: status-Bits 0-7,208,
IDE01922,Vehicle distance driven,31, km
IDE01923,Control module distance driven,30751, m
IDE01924,Load shift flaps: actual value,0.000, %
IDE01925,Load shift flaps: specified value,0.000, %
IDE01926,Adaptation of load shift flaps,3.770, V
IDE01927,Result of load shift flap adaptation,ADP is OK,
IDE01927-ENG129325,Result of load shift flap adaptation-Test_Program_Channel 514,2,
IDE01928,Close cam shaft angle at quantity control valve,37.4, °
IDE01929,Open cam shaft angle at quantity control valve,-3.2, °
IDE01930,High pressure regulation: adaptation value,-0.118, MPa
IDE01932,High pressure pump injection volume,-25.37, mm³
IDE01975,Numb.of misfir.: cylinder 1,34,
IDE01976,Numb.of misfir.: cylinder 2,34,
IDE01977,Numb.of misfir.: cylinder 3,53,
IDE01978,Numb.of misfir.: cylinder 4,57,
IDE02115-ENG57549,Adjustment requirements for basic setting-Bits 0-7,146,
IDE02117,Relative load value,32.32, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,-0.03, MPa
IDE02540-ENG57549,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02756,Number of manual engine starts,74,
IDE02757,Number of automatic engine starts,1,
IDE02832,Coolant circulation pump: activation,10.00, %
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function restriction,active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,active,
IDE03008-MAS06604,Stop process prevented-Start-stop sensor system,active,
IDE03008-MAS06605,Stop process prevented-Regeneration operation,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,0,
IDE03010-MAS01627,Number of prevented stop processes-Steering,10,
IDE03010-MAS02040,Number of prevented stop processes-Play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function restriction,3,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,4,
IDE03010-MAS04591,Number of prevented stop processes-Diagnosis of air system,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power insufficient,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary consumers power too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Test of thermostat not complete,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,8,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,4,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration operation,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,0,
IDE03010-MAS08032,Number of prevented stop processes-Event memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Adaptation active,0,
IDE03010-MAS11563,Number of prevented stop processes-Engine hood open,1,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,2,
IDE03010-MAS12864,Number of prevented stop processes-Tighter traffic flow detected,1,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Motor protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel salinization protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust emission control diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in the start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function restriction,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power insufficient,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary consumers power too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-Cat. heater,0,
IDE03011-MAS11563,Number of requested start processes-Engine hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Motor protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel salinization protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in the start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test off,
IDE03108-ENG127369,Result of test of oxygen sensors bank 1-Test_Program_Channel 976,235,
IDE03189-ENG102843,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Air Density,0, counts
IDE03189-ENG102547,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Brake Boost,0, counts
IDE03189-ENG103808,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Fuel Mixture Adaption,0, counts
IDE03189-ENG101159,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Random,0, counts
IDE03189-ENG104187,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Regeneration Mode,0, counts
IDE03189-ENG100165,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Start Behavior,0, counts
IDE03189-ENG99535,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Air Density,0,
IDE03189-ENG103192,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Brake Boost,0,
IDE03189-ENG99739,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG100597,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Random,0,
IDE03189-ENG101689,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100582,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Start Behavior,0,
IDE03189-ENG101720,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Air Density,0,
IDE03189-ENG100669,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Brake Boost,0,
IDE03189-ENG100932,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG101264,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Random,0,
IDE03189-ENG102430,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101165,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Start Behavior,0,
IDE03189-ENG101829,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Air Density,0, km
IDE03189-ENG99286,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Brake Boost,0, km
IDE03189-ENG102800,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Fuel Mixture Adaption,0, km
IDE03189-ENG102751,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Random,0, km
IDE03189-ENG101356,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Regeneration Mode,0, km
IDE03189-ENG99669,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Start Behavior,0, km
IDE03189-ENG103828,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Air Density,0,
IDE03189-ENG103959,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Brake Boost,0,
IDE03189-ENG102465,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG102710,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Random,0,
IDE03189-ENG103568,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100877,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Start Behavior,0,
IDE03189-ENG101280,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Air Density,0,
IDE03189-ENG99226,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Brake Boost,0,
IDE03189-ENG101471,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG102877,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Random,0,
IDE03189-ENG100198,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101676,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Start Behavior,0,
IDE03189-ENG103694,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Air Density,0,
IDE03189-ENG104142,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Brake Boost,0,
IDE03189-ENG100353,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG100878,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Random,0,
IDE03189-ENG101433,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100557,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Start Behavior:,0,
IDE03190-ENG100538,Number of requested start processes (statistics)-SSEUI Counter Start Desired By Brake Boost,0, counts
IDE03190-ENG100036,Number of requested start processes (statistics)-SSEUI Counter Start Desired By High Engine Temperature,0, counts
IDE03190-ENG102427,Number of requested start processes (statistics)-SSEUI Day Start Desired By Brake Boost,0,
IDE03190-ENG99459,Number of requested start processes (statistics)-SSEUI Day Start Desired By High Engine Temperature,0,
IDE03190-ENG99329,Number of requested start processes (statistics)-SSEUI Hours Start Desired By Brake Boost,0,
IDE03190-ENG100944,Number of requested start processes (statistics)-SSEUI Hours Start Desired By High Engine Temperature,0,
IDE03190-ENG102737,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Brake Boost,0, km
IDE03190-ENG101377,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By High Engine Temperature,0, km
IDE03190-ENG102760,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Brake Boost,0,
IDE03190-ENG103163,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By High Engine Temperature,0,
IDE03190-ENG100816,Number of requested start processes (statistics)-SSEUI Month Start Desired By Brake Boost,0,
IDE03190-ENG104013,Number of requested start processes (statistics)-SSEUI Month Start Desired By High Engine Temperature,0,
IDE03190-ENG103223,Number of requested start processes (statistics)-SSEUI Year Start Desired By Brake Boost,0,
IDE03190-ENG103563,Number of requested start processes (statistics)-SSEUI Year Start Desired By High Engine Temperature,0,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,0.00, °
IDE03246,Neutral position sensor: upper adaptation value,0, mV
IDE03247,Neutral position sensor: lower adaptation value,0, mV
IDE03262,Adapt of angle sensor 1 f throttle valve,0.491, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.504, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.931, V
IDE03277,Intake manifold Runner Control (IMRC): unconditioned voltage,3.828, V
IDE03328,Transmission neutral position sensor voltage,0, mV
IDE03362,Requested transmission torque,1000.0, Nm
IDE03375-ENG57549,Adaptation status for transmission neutral position sensor-Bits 0-7,0,
IDE03377,Coolant temp at radiator output: unconditioned voltage,4042.6, mV
IDE03393-ENG57549,Selector lever position-Bits 0-7,8,
IDE03493-ENG121091,Driver door status-Dsplb Drv Door Act Opn,0,
IDE03584-ENG57549,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03586-ENG57549,Starting requirements for active participants-Bits 0-7,0,
IDE03587-IDE02697,Stop overrides for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stop overrides for active participants-A/C,not active,
IDE03587-MAS00127,Stop overrides for active participants-brakes,not active,
IDE03587-MAS00506,Stop overrides for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stop overrides for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stop overrides for active participants-Transmission,not active,
IDE03587-MAS01106,Stop overrides for active participants-Level control system,not active,
IDE03587-MAS01490,Stop overrides for active participants-Energy management,not active,
IDE03587-MAS01627,Stop overrides for active participants-Steering,not active,
IDE03587-MAS02237,Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stop overrides for active participants-All-wheel electronics,not active,
IDE03587-MAS03757,Stop overrides for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stop overrides for active participants-Engine,active,
IDE03587-MAS06709,Stop overrides for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stop overrides for active participants-Parking aid,not active,
IDE03587-MAS13018,Stop overrides for active participants-Front sensor system for driver assistance systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Engine,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor system for driver assistance systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication error,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-Engine hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,not active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03660,Longitudinal acceleration,-0.001, m/s²
IDE03692-ENG57549,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7,138,
IDE03693-ENG57549,Monitoring status of additional Onboard Diagnosis-Bits 0-7,231,
IDE03700,Status adaptation dew point end,ADP is running,
IDE03700-ENG127325,Status adaptation dew point end-Test_Program_Channel 860,1,
IDE03709,Angle difference actual-specified camshaft adjuster,0.11, °
IDE03711,Mass flow through throttle valve,29.3, kg/h
IDE03767,Engine status,COENG_RUNNING,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,28.574, %
IDE03806-ENG57549,Oxygen sensor bank 1 sensor 1: status-Bits 0-7,0,
IDE03807-ENG57549,Oxygen sensor bank 1 sensor 2: status-Bits 0-7,0,
IDE03813,Test of secondary air system: result,Test off,
IDE03813-ENG129327,Test of secondary air system: result-Test_Program_Channel 239,235,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,131070.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,1,
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,Htg.aC.ON,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,216,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,0.0, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,1.544, %
IDE03830,Status of adaptation of on-demand fuel pump,Test off,
IDE03830-ENG129410,Status of adaptation of on-demand fuel pump-Test_Program_Channel 1021,235,
IDE03932,Charge pressure actuator: specified position,150.00, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3414.8, mV
IDE03935,Charge pressure actuator: adaptation for upper stop,604.8, mV
IDE03951-ENG114937,Intake manifold pressure adjustment recovery conditions-Bhedp sr,1,
IDE03952-ENG114938,Intake manifold pressure plausibility check recovery conditions-Bhepl psr,0,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.99957,
IDE03954-ENG112663,Throttle valve adaptation steady state condition-Badko se,0,
IDE03955-ENG114936,Intake manifold pressure model steady state condition-Bapsl mdse,0,
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE03998,Clutch Position Sensor,0.0, %
IDE04002,Charge press. ctrl.,BP_A act:100, kPa
IDE04010,Engine torque: normalized,14, %
IDE04011,Nominal torque,320, Nm
IDE04083,Coolant temperatures,ECT 1:11 °C / ECT 2:7 °C,
IDE04110,Additional inputs and outputs,,
IDE04256,Temp sensor for engine coolant: unconditioned voltage,3882.6, mV
IDE04278,Bypass valve f high press turboch turbine inlet: target value,99.99, %
IDE04279,Bypass valve f high press turboch turbine inlet: actual value,100.44, %
IDE04280,Bypass valve f high press turboch turbine inlet: offset closed,-4.09, %
IDE04281,Bypass valve f high press turboch turbine inlet: offset open,4.09, %
IDE04301,Bypass valve for high press turboch turbine inlet: activation,-14.19, %
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,7,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,64,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,18,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,0,
IDE04303,Bypass valve for high press turboch turbine inlet: uncond volt,3428.0, mV
IDE04409,Intake manifold pressure: corrected,483.59, hPa
IDE04410,Intake manifold pressure: target value,486.48, hPa
IDE04414,Cat conv temp: modeled,35, °C
IDE04420,Activation of secondary air system,Atmosphere/off,
IDE04604,Accelerator pedal travel,0.00, %
IDE04615,Segment adaptation for rough running: status,2,
IDE04630,AVS valve stroke position: current,false,
IDE04630-ENG06942,AVS valve stroke position: current-Test_Program_Xaied Fa Ehan Adc jnotd jb n 0 A1T UBYTE,0,
IDE04638,Transmission coolant valve,False result,
IDE04638-ENG127289,Transmission coolant valve-Test_Program_B TRUE UBYTE,0,
IDE04651,Torque request: A/C compressor,2.0, Nm
IDE04670,Crankshaft signal evaluation: status,GAPFOUND,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,8,
IDE04685,Setpoint generation interior torque,46.8, Nm
IDE04689,Starter control: Start interruption status,Correct result,
IDE04689-ENG127289,Starter control: Start interruption status-Test_Program_B TRUE UBYTE,1,
IDE04692,Reducing desired torque intervention of ESP,50000.0, Nm
IDE04693,Increasing desired torque intervention of ESP,-3276.8, Nm
IDE04695-ENG06680,Immobilizer snapshot A-Sia Error Snap,00 00 00,
IDE04696-ENG06680,Immobilizer snapshot B-Sia Error Snap,00 00 00,
IDE04814,Transmission oil cooler valve,False result,
IDE04814-ENG127289,Transmission oil cooler valve-Test_Program_B TRUE UBYTE,0,
IDE04820,Fuel content due to degassing of engine oil,0.00, %
IDE04858,Brake booster low pressure actual value,976.21, hPa
IDE04872,Brake pedal value sensor: relative value filtered,0.00, %
IDE04887,Powertrain target torque,9.0, Nm
IDE04889,Target torque for combustion engine crankshaft level,16.1, Nm
IDE04909-ENG57549,Operating mode of hybrid system-Bits 0-7,0,
IDE04933,Number of fill level decreases,0,
IDE04934,Last odometer reading since fill level decrease,0, km
IDE04935,Next to last odometer reading since fill level decrease,0, km
IDE04936,3. Last odometer reading since fill level decrease,0, km
IDE05128,Intake air temperature in intake manifold bank 1,8.3, °C
IDE05135,Status of compressor release,False result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05138,Shut-off timer: last engine shut-off time,1295787, s
IDE05140,Intake manifold pressure raw value,476.88, hPa
IDE05213,Activation pulse duty factor for tank vent valve for diag,0.000, %
IDE05214,Tank vent valve diagnosis pressure difference ratio,0.00,
IDE05215,Tank vent valve diagnosis result correlation factor,0.00,
IDE05221,E-machine torque actual value,0.0, Nm
IDE05240-ENG57549,Request for A/C compressor power reduction-Bits 0-7,0,
IDE05241-ENG57549,A/C compressor release status-Bits 0-7,1,
IDE05260-ENG57549,Gear position sensor: current value-Bits 0-7,0,
IDE05261-ENG57549,Gear position sensor: last valid value-Bits 0-7,14,
IDE05262,Gear position sensor: gear position valid,False result,
IDE05262-ENG127289,Gear position sensor: gear position valid-Test_Program_B TRUE UBYTE,0,
IDE05327,Activation for electrical reserve coolant pump in HT circuit,0.00, %
IDE05332-ENG57549,Heat request from heater to thermal management-Bits 0-7,1,
IDE05436,Engine operating condition,Idling,
IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
IDE05437,Outside air temperature via CAN,9.8, °C
IDE05438,Rear cat conv temp main cat conv model value,46.2, °C
IDE05442,Roadway slope angle acceleration interface: calculated,0.0000, rad
IDE05444,Air filling: specified value,31.27, %
IDE05445,Pressure before throttle valve of pressure sensor,995.63, hPa
IDE05449,Oxygen sensor 2 bank 1 internal resistance limit value,700, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00421,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,-273.15, °C
IDE05470,Cat converter oxygen storage capacity,0.0, mg
IDE05474,Main cat converter OSC age correction factor,0.70313,
IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
IDE05479,Misfire recognition reference moment,9.450, %
IDE05482,Tank venting adaptation factor,0.000,
IDE05484,Power steering pump desired actual moment for idling control,0.0, Nm
IDE05485-ENG57549,Irregular shutdown of the counter control mod-Bits 0-7,0,
IDE05486,Current system status,SYC_DRIVE,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05488,Coolant temperature modeled value,3.1, °C
IDE05497,Adaptation value of the charge pressure control,0.00, hPa
IDE05593,Secondary air injection sensor 1,997.54, hPa
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,30,
IDE05797,Throttle valve adapter: specified value,5.805, %
IDE05809,Counter: implaus. short-term adapt. values: misfire detection,0,
IDE05928,Fuel consumption since DTC memory last erased,18.977, l/100km
IDE05941-ENG112665,Enable condition: camshaft control-Bnws,1,
IDE05943,Release for supply to fuel pump,On,
IDE05943-ENG129326,Release for supply to fuel pump-Test_Program_Channel 890,135,
IDE05950,Charge pressure control adaptation value 1,0, hPa
IDE05951,Charge pressure control adaptation value 2,0, hPa
IDE05952,Charge pressure control adaptation value 3,0, hPa
IDE06014,Charge pressure control adaptation value 0,0, hPa
IDE06015,Time since term 15 OFF StartStop,65535, s
IDE06017,Camshaft position deviation from reference position,0.00, °
IDE06020,Intake air temperature in intake manifold bank raw value,8.4, °C
IDE06023-ENG57549,BDE operating mode flag register-Bits 0-7,65,
IDE06039,Required RPM at idle speed,1200.0, /min
IDE06040,High fuel pressure: regulator output value,-0.3280, MPa
IDE06041-ENG57549,PDTC drive cycle conditions status-Bits 0-7,36,
IDE06043,Cylinder head temperature: actual value,13.3, °C
IDE06045-ENG57549,Output DTM status-Bits 0-7,0,
IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
IDE06049,Pressure in brake booster: raw value,19, hPa
IDE06098,Sensor control factor: output value,1.00000,
IDE06112-ENG57549,Cylinder shut-off test-Bits 0-7,5,
IDE06192,Knock sensor: cylinder 2: voltage,0.0075058, V•ms
IDE06193,Knock sensor: cylinder 3: voltage,0.0105515, V•ms
IDE06194,Knock sensor: cylinder 4: voltage,0.0080284, V•ms
IDE06195,Knock sensor: cylinder 1: voltage,0.0057236, V•ms
IDE06198-ENG57549,Tank vent valve: diagnostic status-Bits 0-7,0,
IDE06255,Vehicle lateral acceleration,0.00, g
IDE06256,Vehicle lateral acceleration: raw value,0.00, g
IDE06257,Vehicle inclination acceleration angle: raw value,0.000, m/s²
IDE06307-MAS00106,Stop prevention history data-Year,2019,
IDE06307-MAS00107,Stop prevention history data-Month,12,
IDE06307-MAS00108,Stop prevention history data-Day,5,
IDE06307-MAS00109,Stop prevention history data-Hours,11,
IDE06307-MAS00110,Stop prevention history data-Minutes,27,
IDE06307-MAS00111,Stop prevention history data-Seconds,7,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Driving situation,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,Brake under pressure too low,
IDE06308,Start request history data,Cat. heater,
IDE06308,Start request history data,Engine temperature too high,
IDE06308,Start request history data,Motor protection active,
IDE06308,Start request history data,Engine hood open,
IDE06308,Start request history data,Fuel salinization protection active,
IDE06308,Start request history data,Deceleration takeover active,
IDE06308,Start request history data,Sporadic function restriction,
IDE06308,Start request history data,Rolling vehicle,
IDE06308,Start request history data,Auxiliary consumers power too high,
IDE06308,Start request history data,Hybrid battery power insufficient,
IDE06308,Start request history data,Engine temperature too low,
IDE06308,Start request history data,SCR System requires restart,
IDE06308,Start request history data,Steering,
IDE06308,Start request history data,Restriction in the start system,
IDE06386,Oil level: static measurement,0.000, mm
IDE06387,Oil level: last valid dynamic value,0.000, mm
IDE06388,Oil level: condition for static measurement fulfilled,0,
IDE06391,Oil temperature sensor 2,-273.1, °C
IDE06393,Oil level: dynamic average value,131.068, mm
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06431,Result: aging test: O2 sensor 1: bank 1: before cat converter,Test off,
IDE06431-ENG130130,Result: aging test: O2 sensor 1: bank 1: before cat converter-Test_Program_Channel 115,235,
IDE06434-ENG112927,Oxygen control: bank 1: sensor 1: release status-Blrnd A,0,
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06445,Longitudinal acceleration: raw value,-0.031, m/s²
IDE06446-ENG57549,Status: incline angle-Bits 0-7,0,
IDE06495,Results of testing of crankcase ventilation successful,0,
IDE06496,Results of testing of crankcase ventilation unsuccessful,0,
IDE06552,Time since terminal 15 ON,46790, ms
IDE06567,Start-stop function deactivation frequency counter,2,
IDE06568,Stop prevention by driver frequency counter,20,
IDE06569,Vehicle stopped frequency counter,38,
IDE06570,Oil level and oil temp. sensor: oil temperature in oil pan,3.7, °C
IDE06610,Vehicle standstill with stop frequency counter,1,
IDE06647-ENG57549,Start-stop switch status-Bits 0-7,1,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,0,
IDE06703-ENG57549,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
IDE06704-ENG57549,Drivetrain coordinator: brake fault status-Bits 0-7,0,
IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,0,
IDE06706-ENG57549,ACC variants-Bits 0-7,2,
IDE06707-ENG57549,CCS Switch-Bits 0-7,2,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,32,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,1,
IDE06709-ENG57549,ACC variants (coding)-Bits 0-7,3,
IDE06710-ENG57549,Cruise control system: permanent deactivation-Bits 0-7,255,
IDE06711-ENG57549,Cruise control system: temporary deactivation-Bits 0-7,255,
IDE06726,Timing deviation after chain replacement: intake bank 1,-1.07, °
IDE06728,Timing deviation after chain replacement: exhaust bank 1,1.93, °
IDE06730,Timing deviation after other repairs: intake bank 1,0.00, °
IDE06732,Timing deviation after other repairs: exhaust bank 1,0.00, °
IDE06734,Timing deviation: current value intake bank 1,0.00, °
IDE06736,Timing deviation: current value exhaust bank 1,0.00, °
IDE06738-ENG57549,Chain elongation: no. of valid initial values: intake bank 1-Bits 0-7,1,
IDE06740-ENG57549,Chain elongation: no. of valid initial values: exhaust bank 1-Bits 0-7,1,
IDE06742,Chain elongation: initial values valid: intake bank 1,not active,
IDE06742-ENG36870,Chain elongation: initial values valid: intake bank 1-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06744,Chain elongation: initial values valid: exhaust bank 1,not active,
IDE06744-ENG36870,Chain elongation: initial values valid: exhaust bank 1-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06758,Air mass since engine start,0.4203, kg
IDE06794,NG to gasoline split factor,0.000,
IDE06800,A/C main switch status,Correct result,
IDE06800-ENG127289,A/C main switch status-Test_Program_B TRUE UBYTE,1,
IDE06944,A/C compressor: load current: act. value,0.00, A
IDE06946-ENG57549,Brake actuated status-Bits 0-7,0,
IDE06947-ENG57549,E-machine operating mode: spec. state-Bits 0-7,0,
IDE06950-ENG57549,Load request from external load manager-Bits 0-7,0,
IDE06956-ENG57549,Driver-side belt buckle status-Bits 0-7,2,
IDE06957,Unfiltered clutch input rpm,1211.5, /min
IDE06970,Desired braking torque: driving assistant,0.0, Nm
IDE06975-ENG57549,Regeneration stages-Bits 0-7,0,
IDE07001,Piston-cooling jets: activation,0,
IDE07031,Oil pressure switch for piston-cooling jets: status,0,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,12,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,98,
IDE07051-ENG57549,Engaged gear: raw signal-Bits 0-7,0,
IDE07076,AVS valve stroke position intake,0,
IDE07077,AVS valve stroke position: exhaust,15,
IDE07078,AVS result of last switch-over: intake,15,
IDE07164,Number injections,2014,
IDE07170,Clutch K0: torque,0.0, Nm
IDE07194,Calculated increasing transmission engagement torque,-3276.8, Nm
IDE07224-ENG57549,Overrun cut-off-Bits 0-7,0,
IDE07225-ENG57549,Transfer electric drive to combustion drive-Bits 0-7,0,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,0,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,66,
IDE07234,Status bid for valid static oil level,0,
IDE07235,Status bid for dynamic oil level,0,
IDE07238,Status of power transfer,0.00,
IDE07240-ENG57549,Status transition of engine control module sequencing-Bits 0-7,0,
IDE07242,Heater support pump: spec. value,94.79, %
IDE07254,Gasoline pressure tank refueling request button,0,
IDE07257,Tank pressure from leakage diagnosis: calculated,0.000, hPa
IDE07548,Engine temp. mangmt. actuator: specified value of angle,61.95, %
IDE07549,Engine temp. mangmt. actuator: actual value of angle,61.66, %
IDE07550,Engine temp. management actuator: raw value,2492.2, mV
IDE07551,Engine temp. management actuator: duty cycle activation,0.00, %
IDE07553,Engine temperature management actuator: after-run stop,3953.4, mV
IDE07554,Engine temperature management actuator: stop open,137.8, mV
IDE07573,Throttle valve adapter: actual value,5.758, %
IDE07615,Operating of tank: empty or reserve,OK,
IDE07615-ENG129324,Operating of tank: empty or reserve-Test_Program_Channel 372,194,
IDE07620-ENG57549,Status momentary default during stability intervention-Bits 0-7,0,
IDE07664,Pre-coordinated torque of increased stability intervention,-50000.0, Nm
IDE07665,Accel. pedal kick-down recognition: voltage threshold,4125.2, mV
IDE07666,Target torque of elec. motor: coordinated output signal,0.0, Nm
IDE07667,Desired torque of regeneration,-36.0, Nm
IDE07724,Coolant temperature at engine outlet: calculated,14.4, °C
IDE07796-ENG57549,Turboch. 1 turb.byp.v. 1 bank 1: pos.feedback -Breakaw.attempts-Bits 0-7,0,
IDE07840-ENG57549,Status plausibility accelerator pedal to brake pedal-Bits 0-7,0,
IDE07904-ENG57549,Brake test switch status-Bits 0-7,0,
IDE07905-ENG57549,Brake light switch status-Bits 0-7,0,
IDE07906-ENG57549,Upper clutch switch: status-Bits 0-7,0,
IDE07908,Coolant fan activation requested by A/C,0.00, %
IDE07963-ENG57549,Cam piece counter position malfunction-Bits 0-7,0,
IDE08071-ENG57549,Remote start cancellation reason store 1-Bits 0-7,0,
IDE08072-ENG57549,Remote start cancellation reason store 2-Bits 0-7,0,
IDE08073-ENG57549,Remote start cancellation reason store 3-Bits 0-7,0,
IDE08074-ENG57549,Remote start cancellation reason store 4-Bits 0-7,0,
IDE08075-ENG57549,Remote start cancellation reason store 5-Bits 0-7,0,
IDE08353-ENG57549,Bypass valve turbocharger: adaptation status-Bits 0-7,0,
IDE08353-ENG57549,Bypass valve turbocharger: adaptation status-Bits 0-7,6,
IDE09307-ENG57549,Pre-ignition counter cylinder 1-Bits 0-7,0,
IDE09308-ENG57549,Pre-ignition counter cylinder 2-Bits 0-7,0,
IDE09309-ENG57549,Pre-ignition counter cylinder 3-Bits 0-7,0,
IDE09310-ENG57549,Pre-ignition counter cylinder 4-Bits 0-7,0,
IDE09313-ENG57549,Pre-ignition counter over serv.life cylinder 1-Bits 0-7,0,
IDE09314-ENG57549,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,0,
IDE09315-ENG57549,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,0,
IDE09316-ENG57549,Pre-ignition counter over serv.life cylinder 4-Bits 0-7,0,
IDE09319-ENG57549,Pre-ignition action counter injection cut-off-Bits 0-7,0,
IDE09320-ENG57549,Pre-ignition action counter fill level limit-Bits 0-7,0,
IDE09529,Fuel mass flow rate due to degassing of eng. oil,0.0, mg/s
IDE09531,Total mass of gasoline and alcohol in oil,5.78, g
IDE09532,Correction factor for fuel mixture,1.00000,
IDE09572,O2 sensor dwnstrm. of cat.: gradient transfer lean -> rich,0.00, s
IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.00, s
IDE09693-ENG57549,Charisma driving program: system status-Bits 0-7,0,
IDE09694-ENG57549,Charisma driving program: act. value-Bits 0-7,2,
IDE09695-ENG57549,Charisma driving program: target value from coordinator-Bits 0-7,0,
IDE09696-ENG57549,Charisma driving program: CAN output value-Bits 0-7,2,
IDE09925-ENG57549,Intake camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09926-ENG57549,Outlet camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09927,Intake camshaft bank 1: adaption hardware offset active,False result,
IDE09927-ENG127289,Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09928,Outlet camshaft bank 1: adaption hardware offset active,False result,
IDE09928-ENG127289,Outlet camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09929,Intake camshaft bank 1: adaption value hardware offset active,-1.16, °
IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,3.01, °
IDE09931,Outlet camshaft bank 1: adaption value sensor tolerance,-2.29, °
IDE09932,Intake camshaft bank1: adaption value sensor tolerance,0.62, °
IDE09942,Long-term adaptation of mixture formation FSI: additive,-1.73, %
IDE09943,Long-term adaptation of mixture formation FSI: multiplicative,0.99957,
IDE09944,Long-term adaptation of mixture formation MPI: additive,0.00, %
IDE09945,Long-term adaptation of mixture formation MPI: multiplicative,1.00000,
IDE09977,Control module temp.: max. value,77.5, °C
IDE10040-ENG57549,Outlet camshaft bank 1 active operating mode-Bits 0-7,22,
IDE10041,Intake camshaft bank1 active operating mode,22,
IDE10042,Outlet camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10042-ENG127372,Outlet camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10043,intake camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10120,Chain elongation inlet: mileage of the last adaptation,1, km
IDE10121,Chain elongation outlet: mileage of the last adaptation,0, km
IDE10302,Time since engine start,56.4, s
IDE10303,Integrated air masse at first engine start,0.4836, kg
IDE10366,Chg. press. ctrl. valve: sensor voltage max. value,3.53, V
IDE10560-ENG57549,Adaption of radiator shutters: status-Bits 0-7,0,
IDE10630,O2 sensor upstrm. of cat.: delay time transf. rich -> lean,0.00, s
IDE10641,Low fuel pressure adaptation value for EFP: modeled,20.0, kPa
IDE10670,O2 sensor upstrm. of cat.: filter constant transf. rich -> lean,0.00, s
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG130099,Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG06494,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG06495,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10968,Activation radiator shutter result,0.00, %
IDE10970-MAS11563,Number of prevented stop processes-Engine hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989-MAS00106,Immobilizer: historic data-Year,2127,
IDE10989-MAS00107,Immobilizer: historic data-Month,15,
IDE10989-MAS00108,Immobilizer: historic data-Day,31,
IDE10989-MAS00109,Immobilizer: historic data-Hours,31,
IDE10989-MAS00110,Immobilizer: historic data-Minutes,63,
IDE10989-MAS00111,Immobilizer: historic data-Seconds,63,
IDE10989,Immobilizer: historic data,Function locked due to excessive stalling,
IDE10989,Immobilizer: historic data,Engine hood open,
IDE10989,Immobilizer: historic data,Brake pedal information: plausibility,
IDE10994,Poor start counter at start-stop,0,
IDE11081,AVS operating state: inlet,1,
IDE11083-ENG29792,Special software: name-SigXL Bypass tool output name 4F47,ORIGINAL A2L,
IDE11115,Start/stop driver request: counter restart by starter,0,
IDE11116,Start/stop driver request: counter internal-motor restart,0,
IDE11293,Fuel consumption difference: injectors/sensors,0.000, l
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,1.332, l
IDE11372,Camshaft angle adaptation: inlet deviation,0.000, °
IDE11541-ENG57549,Autom.pre-selection sys operat.state of the actuator test-Bits 0-7,0,
IDE11635-ENG57549,Radiator shutter 1: status referencing-Bits 0-7,0,
IDE11636-ENG57549,Radiator shutter 2: status referencing-Bits 0-7,0,
IDE11931,Heated oxygen sensor bank 1 sensor 1: positioning intervention rear cat controller,0.00079,
IDE12355,ESI: consumption equivalent of the engine control module,0.00000216,
IDE12453,Knock sensor based camshaft angle adjustment: counter,0,
IDE13012,Tank breather valve: activation duty factor,0.000, %
IDE13301,Drivetrain coordinator: brake fault status,0,
IDE13336,Drive train coordinator reversible switch off conditions,0,
IDE13337,Drive train coordinator irreversible switch off conditions,0,
IDE13746,Flushing rate in cylinder charging,1.0000,
IDE13772,Engine protection torque limitation,1000.0, Nm
IDE14242,Oil pressure valve for piston cooling nozzles: control switch button ratio,100.00, %
IDE14534,Knock control: error status,2147614720,
IDE14818,Reduce ignition advance with global knock control adaptation,0.0, °
IDE15614,Time since first start of combustion engine,59730, ms
IDE80106,Analysis 106,00 03 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D6 00 00 00 00 00 00 00 A7 00 12 00 06 00 00 00 00 00 00 00 00,
MAS15845,Fuel: tank fill level,57.0, l
MAS16066,Exhaust gas temperature at the probe before PreCat bank 1: model value,572.5, °C
MAS16074,Temperature in pre-cat bank 1: model value,299.4, °C
MAS16088,Lambda driver request: specified value,1.0000,
MAS16089,Lambda component protection: bank 1: specified value,1.0000,
MAS16091,Lambda Delta from exhaust gas temperature regulation bank 1: actual value,0.0000,
MAS16097,Tank ventilation factorial fuel amount: actual value,0.000,
MAS16098,Tank ventilation relative mixture proportion: actual value,0.00, %
MAS16301,Sensor adaptation: status with engine running,0,
MAS16534-ENG57549,A/C compressor info: switch-off status-Bits 0-7,0,
MAS16543,Bank 1 heated oxygen sensor downstream of catalytic converter: exhaust gas temperature calculated,129.83, °C
MAS17030,Engine control module hardware timer: self-diagnosis status,1,
MAS17031,Radiator shutter 1: actual position,399.99, %
MAS17032,Radiator shutter 2: actual position,399.99, %
MAS17038,Heated oxygen sensor 2 bank 1: heat output normalized,0.25,
MAS17039,Heated oxygen sensor 1 Bank 1: target voltage adequate for lean conditions,1.000, V
MAS17041,Heated oxygen sensor 1 bank 1: effective heater voltage,1.840, V
MAS17045,Heated oxygen sensor 2 bank 1: internal resistance,131070, Ohm
MAS17047,Heated oxygen sensor 2 Bank 1: target voltage adequate for rich conditions,0.000, V
MAS17055,Heated oxygen sensor 1 bank 1: identified total time (lean -> rich),0.00, s
MAS17056,Heated oxygen sensor 1 Bank 1: adaptation value for filtering time constants,0.00, s
MAS17058,Heated oxygen sensor 1 Bank 1: adaptation value for dead time,0.00, s
MAS17059,Heated oxygen sensor 1 bank 1: identified total time (rich -> lean),0.00, s
MAS17060,Characteristics cooling module 1: end stage activation,0.00, %
MAS17191,Characteristics cooling module: target position,61.95, %
MAS17192,Characteristics cooling module: upper mechanical stop,137.8, mV
MAS17193,Characteristics cooling module: lower mechanical stop,3953.4, mV
MAS17236-ENG57549,Adaptation of radiator shutter 2: status-Bits 0-7,0,
MAS17237-ENG57549,Adaptation of radiator shutter 3: status-Bits 0-7,0,
MAS17238-ENG57549,Adaptation of radiator shutter 4: status-Bits 0-7,0,
ENG119898,Actual_section_of_standard_test,0,
ENG112928-ENG57549,Air_conditioning_compressor_actual_status-Bits 0-7,1,
ENG105149,Air_mass_integral_for_thermostat_diagnosis_actual_value,0.00, kg
ENG105150,Air_mass_integral_for_thermostat_diagnosis_limit_value,9.45, kg
ENG26434-ENG57549,AVS_Cam_element_position_error_counter_lift_0-Bits 0-7,0,
ENG26435-ENG57549,AVS_Cam_element_position_error_counter_lift_1-Bits 0-7,0,
ENG26436-ENG57549,AVS_Cam_element_position_error_counter_manifold_pressure_diagnosis-Bits 0-7,0,
ENG26437-ENG57549,AVS_Cam_element_position_error_counter_misfire_detection-Bits 0-7,0,
ENG121428-ENG57549,AVS_counter_error_debonce-Bits 0-7,0,
ENG121428-ENG57549,AVS_counter_error_debonce-Bits 0-7,2,
ENG121429-ENG57549,AVS_counter_error_limphome-Bits 0-7,0,
ENG121426-ENG57549,AVS_counter_sporadic_diagnosis_errors-Bits 0-7,0,
ENG121427-ENG57549,AVS_counter_sporadic_switch_errors-Bits 0-7,0,
ENG112670-ENG112664,Brake_booster_start_request_combustion_engine-Bbkvs ta,0,
ENG101413,Calibration Identification,83A115B 0004DXBA,
ENG99697,Calibration Verification Number,0C F6 63 23,
ENG08794-ENG57549,Com st X Set1 Val1-Bits 0-7,0,
ENG08795-ENG57549,Com st X Set1 Val2-Bits 0-7,0,
ENG08796-ENG57549,Com st X Set1 Val3-Bits 0-7,0,
ENG08797-ENG57549,Com st X Set1 Val4-Bits 0-7,0,
ENG08798-ENG57549,Com st X Set1 Val5-Bits 0-7,0,
ENG08799-ENG57549,Com st X Set1 Val6-Bits 0-7,0,
ENG08800-ENG57549,Com st X Set1 Val7-Bits 0-7,0,
ENG08801-ENG57549,Com st X Set2 Val1-Bits 0-7,0,
ENG08802-ENG57549,Com st X Set2 Val2-Bits 0-7,0,
ENG08803-ENG57549,Com st X Set2 Val3-Bits 0-7,0,
ENG08804-ENG57549,Com st X Set2 Val4-Bits 0-7,0,
ENG08805-ENG57549,Com st X Set2 Val5-Bits 0-7,0,
ENG08806-ENG57549,Com st X Set2 Val6-Bits 0-7,0,
ENG08807-ENG57549,Com st X Set2 Val7-Bits 0-7,0,
ENG08808-ENG57549,Com st X Set3 Val1-Bits 0-7,0,
ENG08809-ENG57549,Com st X Set3 Val2-Bits 0-7,0,
ENG08810-ENG57549,Com st X Set3 Val3-Bits 0-7,0,
ENG08811-ENG57549,Com st X Set3 Val4-Bits 0-7,0,
ENG08812-ENG57549,Com st X Set3 Val5-Bits 0-7,0,
ENG08813-ENG57549,Com st X Set3 Val6-Bits 0-7,0,
ENG08814-ENG57549,Com st X Set3 Val7-Bits 0-7,0,
ENG01773-ENG57549,Configuration_of_cruise_control-Bits 0-7,0,
ENG126402-ENG57549,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,64,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,0,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,1,
ENG122710,Cruise_control_velocity_setpoint,0.000, km/h
ENG111031-ENG57549,DFC_status_error_debounced_counter-Bits 0-7,0,
ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,42,
ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,4,
ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,239,
ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,0,
ENG126404-ENG57549,Drive_train_coordinator_checked_coding-Bits 0-7,5,
ENG112930,Driving_torque_coordinator_requested_driving_torque_from_GRA,-32768.0, Nm
ENG111582,DrivingProgramSwitch_sport_mode_activated,False result,
ENG111582-ENG127289,DrivingProgramSwitch_sport_mode_activated-Test_Program_B TRUE UBYTE,0,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG114220,Effective_injection_duration,11.808, ms
ENG111593,Emachine_achievable_enginetorque_maximum_value,0.0, Nm
ENG111594,Emachine_achievable_generatortorque_maximum_value,0.0, Nm
ENG115973,Engine Exhaust Flow Rate,29.6, kg/h
ENG20102,Engine Friction - Percent Torque,8.0, %
ENG112932,Engine_oil_temperature_measured_value,-273.1, °C
ENG111034,Engine_temperature_modelbased_substitute_value,20.3, °C
ENG118071-ENG57549,Engine_torque_interventi_status-Bits 0-7,2,
ENG118071-ENG57549,Engine_torque_interventi_status-Bits 0-7,0,
ENG112302,EngineCoordinator_activation_within_quasistationary_limits_of_ElM,False result,
ENG112302-ENG127289,EngineCoordinator_activation_within_quasistationary_limits_of_ElM-Test_Program_B TRUE UBYTE,0,
ENG111568,EngineCoordinator_intervention_request_actual_value,0,
ENG112301,EngineManagement_activation_limited_reduction_of_efficiency,False result,
ENG112301-ENG127289,EngineManagement_activation_limited_reduction_of_efficiency-Test_Program_B TRUE UBYTE,0,
ENG26778,Evap_purge_system_bank_1_cross_correlation_maximum_engine_load_gradient,0.00, hPa
ENG26779,Evap_purge_system_bank_1_cross_correlation_maximum_engine_speed_gradient,0.0, /min
ENG26780,Evap_purge_system_bank_1_cross_correlation_measured_mean_amplitude,0.0, hPa
ENG26781,Evap_purge_system_bank_1_insertion_pre_turbocharger_corrected_cross_correlation_coefficient,0.00,
ENG26788,ExhMgT_fetak_hllfa_msg,1.000,
ENG26789,ExhMgT_fetak_htlfa_msg,1.000,
ENG26808,Fl Lvl vol Tnk Plaus Old,57.000, l
ENG115974-ENG55378,Fuel Rate-Engine Fuel Rate,0.54, g/s
ENG115974-ENG116137,Fuel Rate-Vehicle Fuel Rate,0.54, g/s
ENG111608,Fuel_consumption_actual_driving_cycle,0.05, l
ENG106769-ENG57549,Gearbox_heat_request-Bits 0-7,0,
ENG112667,Generator load normalised value,22.54, %
ENG112931,Generator_load_from_CAN,593.761, W
ENG112929,Generator_torque_request,4.7, Nm
ENG107016,Injection quantity average,0.00, mg/stroke
ENG107045,Intake_manifold_model_air_mass_flow_filtered_value,27.5, kg/h
ENG100634,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2,00 01 00 20 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00 00 00 01 00 01 00 07 00 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00,
ENG110574,Lambdacoordination_homogeneous_mode_range_limited_commanded_value,1.0000,
ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2127,
ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,15,
ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,31,
ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,31,
ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,63,
ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,63,
ENG127734,Life_cycle_data_start_requirement_development,Steering,
ENG127734,Life_cycle_data_start_requirement_development,Front sensor system for driver assistance systems,
ENG127734,Life_cycle_data_start_requirement_development,All-wheel electronics,
ENG127734,Life_cycle_data_start_requirement_development,A/C,
ENG127734,Life_cycle_data_start_requirement_development,Convertible top control module,
ENG127734,Life_cycle_data_start_requirement_development,12 V electrical system,
ENG127734,Life_cycle_data_start_requirement_development,Transmission,
ENG127734,Life_cycle_data_start_requirement_development,Level control system,
ENG127734,Life_cycle_data_start_requirement_development,Multifunction unit control module,
ENG127734,Life_cycle_data_start_requirement_development,Parking aid,
ENG127734,Life_cycle_data_start_requirement_development,ACC,
ENG127734,Life_cycle_data_start_requirement_development,Front axis lift system,
ENG127734,Life_cycle_data_start_requirement_development,Engine,
ENG127734,Life_cycle_data_start_requirement_development,Immobilizer,
ENG127734,Life_cycle_data_start_requirement_development,Kessy,
ENG127734,Life_cycle_data_start_requirement_development,brakes,
ENG127734,Life_cycle_data_start_requirement_development,Quattro Sport,
ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2127,
ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,15,
ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,31,
ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,31,
ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,63,
ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,63,
ENG127735,Life_cycle_data_stop_prohibition_development,Quattro Sport,
ENG127735,Life_cycle_data_stop_prohibition_development,Steering,
ENG127735,Life_cycle_data_stop_prohibition_development,Multifunction unit control module,
ENG127735,Life_cycle_data_stop_prohibition_development,Parking aid,
ENG127735,Life_cycle_data_stop_prohibition_development,Engine,
ENG127735,Life_cycle_data_stop_prohibition_development,Immobilizer,
ENG127735,Life_cycle_data_stop_prohibition_development,Kessy,
ENG127735,Life_cycle_data_stop_prohibition_development,A/C,
ENG127735,Life_cycle_data_stop_prohibition_development,Convertible top control module,
ENG127735,Life_cycle_data_stop_prohibition_development,Front axis lift system,
ENG127735,Life_cycle_data_stop_prohibition_development,12 V electrical system,
ENG127735,Life_cycle_data_stop_prohibition_development,ACC,
ENG127735,Life_cycle_data_stop_prohibition_development,Transmission,
ENG127735,Life_cycle_data_stop_prohibition_development,brakes,
ENG127735,Life_cycle_data_stop_prohibition_development,Level control system,
ENG127735,Life_cycle_data_stop_prohibition_development,Front sensor system for driver assistance systems,
ENG127735,Life_cycle_data_stop_prohibition_development,All-wheel electronics,
ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2019,
ENG127733-MAS00107,Life_cycle_data_system_failure-Month,11,
ENG127733-MAS00108,Life_cycle_data_system_failure-Day,22,
ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,0,
ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,56,
ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,33,
ENG127733,Life_cycle_data_system_failure,Engine,
ENG127733,Life_cycle_data_system_failure,not active,
ENG111606,Load value: unrestricted commanded value,30.87, %
ENG125271,Maximum_ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.008,
ENG111040,Misfire_detection_sensor_wheel_adaptation_speed_load_range_index,1,
ENG26325,Mo F Strt st Strtr Blk Err Msg,0,
ENG26978-ENG57549,Mo XEMM st EMM Alrms Idx0-Bits 0-7,0,
ENG26979-ENG57549,Mo XEMM st EMM Alrms Idx1-Bits 0-7,0,
ENG26980-ENG57549,Mo XEMM st EMM Alrms Idx2-Bits 0-7,0,
ENG55145-ENG57549,Mo XEMM st EMM Alrms Idx3-Bits 0-7,0,
ENG55146-ENG57549,Mo XEMM st EMM Alrms Idx4-Bits 0-7,0,
ENG111571,Mode_control_activation_P1_mode,False result,
ENG111571-ENG127289,Mode_control_activation_P1_mode-Test_Program_B TRUE UBYTE,0,
ENG107660,Mode_control_commanded_dragmoment_for_em,-35.0, Nm
ENG107661-ENG57549,Mode_control_operating_status_hybrid_system_bitcoded-Bits 0-7,0,
ENG111581-ENG57549,Mode_control_start_order_combustion_engine-Bits 0-7,0,
ENG107663,Mode_control_torque_electrical_auxilary_systems_requested_value,0.0, Nm
ENG112668,O2 sensor_controller_bank_1_p-rate,0.00000,
ENG26996-ENG57549,OEM2RB VW Byp flg E Hmnplt u8-Bits 0-7,0,
ENG108262,Powertrain_overall_gear_ratio,1.00,
ENG111605,Pressure_before_throttle_valve_actual_value,995.23, hPa
ENG125270,Ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.000,
ENG109006,Spark_efficiency_deviation_at_idle_maximum,22.7, %
ENG109007,Spark_efficiency_deviation_at_part_load_maximum,21.9, %
ENG121093-ENG57549,State_of_cruise_control_or_speedlimiter-Bits 0-7,0,
ENG01786-ENG57549,State_of_requestor_for_drivetrain_coordinator-Bits 0-7,2,
ENG08688,Thr Vlv u Sens1 B1,0.706, V
ENG08689,Thr Vlv u Sens2 B1,4.296, V
ENG01775,Top_speed_limitation,201.000, km/h
ENG109528,Torque_coordination_idle_speed_control_torque_actual_value_air_path,0.0, Nm
ENG109529,Torque_coordination_idle_speed_control_torque_SET_path_actual_value,41.2, Nm
ENG109533,Torque_distribution_Emaschine_combustion_engine_driver_request,9.0, Nm
ENG115975-ENG116124,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG115975-ENG116108,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG115975-ENG116105,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG115975-ENG116116,Transmission Actual Gear-Transmission Actual Gear Status Supported,Available,
ENG01785-ENG57549,Transmission_state_of_drivetrain_coordinator-Bits 0-7,4,
ENG01785-ENG57549,Transmission_state_of_drivetrain_coordinator-Bits 0-7,0,
ENG111604,Turbocharger_inlet_pressure_corrected_value,467.03, hPa
ENG119911,UEGO r Lam S1 B1,0.9958,
ENG115976,Vehicle Odometer,31.0, km
ENG01774,Velocity_limiter_setpoint,511.992, km/h
ENG27262,Virtual_SigXSet_SyC_tiPostDrv,0, s
ENG27263,Virtual_SigXSet_TiEngOff_tiDiagRef,69, s
ENG27264,Virtual_SigXSet_TiEngOff_tiStopCnt_Dif,1295799, s
ENG27265,Virtual_SigXSet_TiEngOff_tiStopCnt_Raw,7404201, s
ENG27266,Virtual_SigXSet_TiOff_tiStrtEnd_Off,65535, s
Elapsed Time: 01:01
engine @ idle, +80C:
;SW:83A-907-115-B HW:06L-907-309-B --- Engine
;Component:R4 2.0l TFSI H31 0004, Coding:012A00122464012FB4000000000000000000000000000000
;EV_ECM20TFS01183A907115B,001005,EV_ECM20TFS01183A907115B.rod
;Friday,20,December,2019,12:45:50:14741
;VCDS Version: Beta 19.10.0 (x64) Data version: 20190930 DS316.0
;VCID: A51C1ADE75621F793A6D-80F0
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),3VV3B7AX6LM009820,
IDE00019,Voltage terminal 30,14.800, V
IDE00020-ENG57549,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine speed,801, /min
IDE00025,Coolant temperature,83, °C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00076,Status of initial fuel filling,was not yet started,
IDE00078,Time since engine start,637, s
IDE00083,Throttle valve position (absolute),11.4, %
IDE00084,Absolute load value,20, %
IDE00085,Normed load value,17.6, %
IDE00086,Accelerator position,15, %
IDE00090-ENG57549,selected gear-Bits 0-7,0,
IDE00094,Kick-down status,Not operated,
IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00100,Engine torque,32.0, Nm
IDE00102,Control Module temperature,19.0, °C
IDE00148,Median injection timing,0.9272, ms
IDE00150,Pressure in brake booster,17.97, hPa
IDE00151,Oil fill level,78.748, mm
IDE00152,Oil warning threshold,65.000, mm
IDE00155,Timing angle retardation cylinder 1,0.0, °
IDE00156,Timing angle retardation cylinder 2,0.0, °
IDE00157,Timing angle retardation cylinder 3,0.0, °
IDE00158,Timing angle retardation cylinder 4,0.0, °
IDE00167,Exhaust temperature 1 bank 1,393.6, °C
IDE00172,A/C compressor torque,20.0, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-22.89, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-22.95, °
IDE00178,Camshaft adjustment intake bank 1: specified value,-2.25, °
IDE00179,Camshaft adjustment intake bank 1: actual value,-2.59, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.09, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,-0.86, °
IDE00186,Fuel low pressure: actual value,0.0, kPa
IDE00187,Coolant temperature at engine start,3.1, °C
IDE00188,Fuel high pressure: actual value,6.6500, MPa
IDE00190,Charge air pressure specified value,338.98, hPa
IDE00191,Charge air pressure: actual value,992.97, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,11.0, °C
IDE00194,Coolant temperature at radiator output: specified value,99.2, °C
IDE00196,Engine oil temperature,51.3, °C
IDE00201,High fuel pressure: specified value,6.6540, MPa
IDE00202,Low fuel pressure: specified value,500.0, kPa
IDE00304,Fuel level,57.00, l
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00347,Air mass: actual value:,2.91, g/s
IDE00348,Intake air temperature,15, °C
IDE00349,Throttle valve position: normed,1, %
IDE00350,Air mass: specified value,10.6, kg/h
IDE00354,Engine start: start synchronization,EPM_MODE_OK,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00355-ENG57549,Cruise Control System (CCS): status-Bits 0-7,2,
IDE00357,Fuel temperature,47.3, °C
IDE00358,Limitation: torque,1000.0, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00361,Ambient air pressure,998.63, hPa
IDE00371,Fuel consumption,0.87, l/h
IDE00375,Generator: load signal,38.65, %
IDE00380,Coolant fan 1: activation,10.15, %
IDE00392,Accelerator pedal: sensor voltage 1,737.4, mV
IDE00393,Accelerator pedal: sensor voltage 2,377.0, mV
IDE00405,Crankshaft speed (RPM),793.5, /min
IDE00406,Camshaft speed (RPM),396.8, /min
IDE00407-ENG57549,Rail pressure regulation: status-Bits 0-7,1,
IDE00412-ENG57549,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG57549,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG57549,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG57549,Starter control: terminal 50 acknowledgment-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,1,
IDE00443-ENG57549,Accelerator pedal: switch positions-Bits 0-7,8,
IDE00445,Unlearning counter according OBD,255,
IDE00450,Operating Instructions,---,
IDE00451,Currently running routine,Unknown (0),
IDE00474,Ambient air pressure,99, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,9.0, Nm
IDE00496-ENG57549,Activation of oil pressure switch valve-Bits 0-7,1,
IDE00497-ENG57549,Status of oil pressure switches-Bits 0-7,165,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside air temperature,11, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.968 Lambda / -0.078 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,1.275, V
IDE00560-MAS04122,Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00582,Equivalence ratio target value,1.000, Lambda
IDE00583,Throttle valve specified value,2, %
IDE00584,Distance driven since erasing DTC memory,13, km
IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,0, km
IDE00588,Fuel tank fill level,100.0, %
IDE00589,Fuel pressure,6760, kPa rel
IDE00592,Oxygen sensor control status,Closed loop, / using O2 sensors ,
IDE00593,Ignition timing adjustment cylinder 1,-1.5, Degrees
IDE00594,Absolute intake pressure,33, kPa abs
IDE00595,Allocation of oxygen sensors,B1S1 B1S2 ,
IDE00597,Long term adaptation of mixture formation bank 1,-10.2, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,1,
IDE00604,Short term adaptation of mixture formation bank 1,-7.8, %
IDE00608,Type of fuel,Gasoline,
IDE00612,Target position of EVAP canister valve,4.7, %
IDE00699,ESI: minimum oil level in service interval,32.000, mm
IDE00700,ESI: maximum oil level in service interval,-32.000, mm
IDE00727,Test steps still to be performed,0,
IDE00738,Test of oxygen sensors bank 1: Delta-Lambda,0.00079,
IDE00752,Test of oxygen sensor control.,Test off,
IDE00752-ENG127302,Test of oxygen sensor control.-Test_Program_Channel 213,235,
IDE00773,Terminal 15 status via CAN,1,
IDE00787,Cause for cancellation,0,
IDE00949,Hide cylinder,not active,
IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
IDE00973,Outside air temperature,11.0, °C
IDE01076,Time since ignition off,65535, s
IDE01098,Test of knock sensors: short trip result,Test off,
IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
IDE01260,Generator power,697.434, W
IDE01266-ENG57549,Coolant shut-off valve-Bits 0-7,2,
IDE01267,Height correction,0.98578,
IDE01378,High fuel pressure: control deviation,0.0120, MPa
IDE01385-ENG57549,Wear index-Bits 0-7,0,
IDE01386-ENG57549,Soot index-Bits 0-7,0,
IDE01405-ENG57549,Status of starter activation-Bits 0-7,2,
IDE01590,Status of brakes,Not operated,
IDE01590-ENG127367,Status of brakes-Test_Program_Channel 600,167,
IDE01638,Result O2 sensor aging test bank 1 or 3 before cat. conv.,Test off,
IDE01638-ENG127368,Result O2 sensor aging test bank 1 or 3 before cat. conv.-Test_Program_Channel 951,235,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,1.477, V
IDE01650,Throttle valve position 2,11, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test off,
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,235,
IDE01667,Result of test of camshaft adjustment outlet bank 1,Test on,
IDE01667-ENG127371,Result of test of camshaft adjustment outlet bank 1-Test_Program_Channel 619,234,
IDE01680,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve,Test off,
IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,235,
IDE01773,Misfire sum counter,0,
IDE01774,Status misfire recognition,activated,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,103,
IDE01775,Misfires per 1000 revolutions of cylinder 1,0,
IDE01776,Misfires per 1000 revolutions of cylinder 2,0,
IDE01777,Misfires per 1000 revolutions of cylinder 3,0,
IDE01778,Misfires per 1000 revolutions of cylinder 4,0,
IDE01834,Battery voltage,14820, mV
IDE01869,Long-term fuel trim bank 1 at idle,-1.73, %
IDE01870,Oxygen sensor after catalytic converter: operating status,Test off,
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,235,
IDE01872,Result of oxygen sensor aging test after catalytic converter,Test off,
IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,235,
IDE01873,Test of catalytic converter: measured value,8.0000,
IDE01874,Test of catalytic converter: result,Test off,
IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,235,
IDE01875,Required torque adjustment by idling regulator,0.000, %
IDE01876,Adaptation of loss torque,-1.2, Nm
IDE01877-ENG57549,Operating condition of idle speed control-Bits 0-7,4,
IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000000 ,
IDE01879,Adaptation of throttle valve: result,ERROR,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,90,
IDE01880,Accelerator position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01884,Camshaft adjustment intake bank 1: activation,35.242, %
IDE01885,Shut off of oxygen sensor control,l-Reg.ON,
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,4,
IDE01887,Adaptation of Fuel Pump (FP),0.0, kPa
IDE01888,Cold start enrichment: adaptation area 1,1.000,
IDE01889,Cold start enrichment: adaptation area 2,1.000,
IDE01890,Cold start enrichment: adaptation area 3,1.000,
IDE01891,Cold start enrichment: adaptation area 4,1.000,
IDE01892,Cold start enrichment: adaptation area 5,1.000,
IDE01893,Fuel pump: specified value,53.378, %
IDE01896,Charge pressure control: damping grtr max. threshold adaptation,0.000, %
IDE01897,Charge pressure control: damping lsr min. threshold adaptation,0.000, %
IDE01899,Load value: corrected specified value,100.01, %
IDE01900,Charge press. ctrl.: spec. value,99.6, %
IDE01901,Lost torque adaptation: idle,-1.1, Nm
IDE01902,Lost torque adaptation A/C compressor,-1.6, Nm
IDE01903,Lost torque adaptation driving mode,0.0, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,0.9, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,1.01404,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,1.04956,
IDE01911,Leakage air,3.1, kg/h
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,1.0000,
IDE01914-ENG57549,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bits 0-7,168,
IDE01916,Leakage recognition from oxygen sensor control,0.8657,
IDE01917,Leakage after throttle valve,-1.000,
IDE01918,Leakage before throttle valve,-1.000,
IDE01919-ENG57549,Leakage recognition: status-Bits 0-7,212,
IDE01922,Vehicle distance driven,31, km
IDE01923,Control module distance driven,30751, m
IDE01924,Load shift flaps: actual value,0.000, %
IDE01925,Load shift flaps: specified value,0.000, %
IDE01926,Adaptation of load shift flaps,3.770, V
IDE01927,Result of load shift flap adaptation,ADP is OK,
IDE01927-ENG129325,Result of load shift flap adaptation-Test_Program_Channel 514,2,
IDE01928,Close cam shaft angle at quantity control valve,31.5, °
IDE01929,Open cam shaft angle at quantity control valve,30.0, °
IDE01930,High pressure regulation: adaptation value,-0.118, MPa
IDE01932,High pressure pump injection volume,-26.62, mm³
IDE01975,Numb.of misfir.: cylinder 1,34,
IDE01976,Numb.of misfir.: cylinder 2,34,
IDE01977,Numb.of misfir.: cylinder 3,53,
IDE01978,Numb.of misfir.: cylinder 4,57,
IDE02115-ENG57549,Adjustment requirements for basic setting-Bits 0-7,191,
IDE02117,Relative load value,19.03, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,0.00, MPa
IDE02540-ENG57549,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02756,Number of manual engine starts,74,
IDE02757,Number of automatic engine starts,1,
IDE02832,Coolant circulation pump: activation,10.00, %
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function restriction,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start-stop sensor system,active,
IDE03008-MAS06605,Stop process prevented-Regeneration operation,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,0,
IDE03010-MAS01627,Number of prevented stop processes-Steering,10,
IDE03010-MAS02040,Number of prevented stop processes-Play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function restriction,3,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,4,
IDE03010-MAS04591,Number of prevented stop processes-Diagnosis of air system,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power insufficient,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary consumers power too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Test of thermostat not complete,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,8,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,4,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration operation,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,0,
IDE03010-MAS08032,Number of prevented stop processes-Event memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Adaptation active,0,
IDE03010-MAS11563,Number of prevented stop processes-Engine hood open,1,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,2,
IDE03010-MAS12864,Number of prevented stop processes-Tighter traffic flow detected,1,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Motor protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel salinization protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust emission control diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in the start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function restriction,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power insufficient,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary consumers power too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-Cat. heater,0,
IDE03011-MAS11563,Number of requested start processes-Engine hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Motor protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel salinization protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in the start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test off,
IDE03108-ENG127369,Result of test of oxygen sensors bank 1-Test_Program_Channel 976,235,
IDE03189-ENG102843,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Air Density,0, counts
IDE03189-ENG102547,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Brake Boost,0, counts
IDE03189-ENG103808,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Fuel Mixture Adaption,0, counts
IDE03189-ENG101159,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Random,0, counts
IDE03189-ENG104187,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Regeneration Mode,0, counts
IDE03189-ENG100165,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Start Behavior,0, counts
IDE03189-ENG99535,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Air Density,0,
IDE03189-ENG103192,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Brake Boost,0,
IDE03189-ENG99739,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG100597,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Random,0,
IDE03189-ENG101689,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100582,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Start Behavior,0,
IDE03189-ENG101720,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Air Density,0,
IDE03189-ENG100669,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Brake Boost,0,
IDE03189-ENG100932,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG101264,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Random,0,
IDE03189-ENG102430,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101165,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Start Behavior,0,
IDE03189-ENG101829,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Air Density,0, km
IDE03189-ENG99286,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Brake Boost,0, km
IDE03189-ENG102800,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Fuel Mixture Adaption,0, km
IDE03189-ENG102751,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Random,0, km
IDE03189-ENG101356,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Regeneration Mode,0, km
IDE03189-ENG99669,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Start Behavior,0, km
IDE03189-ENG103828,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Air Density,0,
IDE03189-ENG103959,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Brake Boost,0,
IDE03189-ENG102465,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG102710,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Random,0,
IDE03189-ENG103568,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100877,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Start Behavior,0,
IDE03189-ENG101280,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Air Density,0,
IDE03189-ENG99226,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Brake Boost,0,
IDE03189-ENG101471,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG102877,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Random,0,
IDE03189-ENG100198,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101676,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Start Behavior,0,
IDE03189-ENG103694,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Air Density,0,
IDE03189-ENG104142,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Brake Boost,0,
IDE03189-ENG100353,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG100878,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Random,0,
IDE03189-ENG101433,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100557,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Start Behavior:,0,
IDE03190-ENG100538,Number of requested start processes (statistics)-SSEUI Counter Start Desired By Brake Boost,0, counts
IDE03190-ENG100036,Number of requested start processes (statistics)-SSEUI Counter Start Desired By High Engine Temperature,0, counts
IDE03190-ENG102427,Number of requested start processes (statistics)-SSEUI Day Start Desired By Brake Boost,0,
IDE03190-ENG99459,Number of requested start processes (statistics)-SSEUI Day Start Desired By High Engine Temperature,0,
IDE03190-ENG99329,Number of requested start processes (statistics)-SSEUI Hours Start Desired By Brake Boost,0,
IDE03190-ENG100944,Number of requested start processes (statistics)-SSEUI Hours Start Desired By High Engine Temperature,0,
IDE03190-ENG102737,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Brake Boost,0, km
IDE03190-ENG101377,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By High Engine Temperature,0, km
IDE03190-ENG102760,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Brake Boost,0,
IDE03190-ENG103163,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By High Engine Temperature,0,
IDE03190-ENG100816,Number of requested start processes (statistics)-SSEUI Month Start Desired By Brake Boost,0,
IDE03190-ENG104013,Number of requested start processes (statistics)-SSEUI Month Start Desired By High Engine Temperature,0,
IDE03190-ENG103223,Number of requested start processes (statistics)-SSEUI Year Start Desired By Brake Boost,0,
IDE03190-ENG103563,Number of requested start processes (statistics)-SSEUI Year Start Desired By High Engine Temperature,0,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,0.00, °
IDE03246,Neutral position sensor: upper adaptation value,0, mV
IDE03247,Neutral position sensor: lower adaptation value,0, mV
IDE03262,Adapt of angle sensor 1 f throttle valve,0.491, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.504, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.931, V
IDE03277,Intake manifold Runner Control (IMRC): unconditioned voltage,3.813, V
IDE03328,Transmission neutral position sensor voltage,0, mV
IDE03362,Requested transmission torque,1000.0, Nm
IDE03375-ENG57549,Adaptation status for transmission neutral position sensor-Bits 0-7,0,
IDE03377,Coolant temp at radiator output: unconditioned voltage,3913.2, mV
IDE03393-ENG57549,Selector lever position-Bits 0-7,8,
IDE03493-ENG121091,Driver door status-Dsplb Drv Door Act Opn,0,
IDE03584-ENG57549,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03586-ENG57549,Starting requirements for active participants-Bits 0-7,0,
IDE03587-IDE02697,Stop overrides for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stop overrides for active participants-A/C,not active,
IDE03587-MAS00127,Stop overrides for active participants-brakes,not active,
IDE03587-MAS00506,Stop overrides for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stop overrides for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stop overrides for active participants-Transmission,not active,
IDE03587-MAS01106,Stop overrides for active participants-Level control system,not active,
IDE03587-MAS01490,Stop overrides for active participants-Energy management,not active,
IDE03587-MAS01627,Stop overrides for active participants-Steering,not active,
IDE03587-MAS02237,Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stop overrides for active participants-All-wheel electronics,not active,
IDE03587-MAS03757,Stop overrides for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stop overrides for active participants-Engine,not active,
IDE03587-MAS06709,Stop overrides for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stop overrides for active participants-Parking aid,not active,
IDE03587-MAS13018,Stop overrides for active participants-Front sensor system for driver assistance systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Engine,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor system for driver assistance systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication error,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-Engine hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,not active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03660,Longitudinal acceleration,0.000, m/s²
IDE03692-ENG57549,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7,138,
IDE03693-ENG57549,Monitoring status of additional Onboard Diagnosis-Bits 0-7,227,
IDE03700,Status adaptation dew point end,ADP is running,
IDE03700-ENG127325,Status adaptation dew point end-Test_Program_Channel 860,1,
IDE03709,Angle difference actual-specified camshaft adjuster,0.41, °
IDE03711,Mass flow through throttle valve,11.3, kg/h
IDE03767,Engine status,COENG_RUNNING,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,31.018, %
IDE03806-ENG57549,Oxygen sensor bank 1 sensor 1: status-Bits 0-7,3,
IDE03807-ENG57549,Oxygen sensor bank 1 sensor 2: status-Bits 0-7,0,
IDE03813,Test of secondary air system: result,Test off,
IDE03813-ENG129327,Test of secondary air system: result-Test_Program_Channel 239,235,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,52560.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,1,
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,Htg.aC.OFF,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,217,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,300.4, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,27.731, %
IDE03830,Status of adaptation of on-demand fuel pump,Test off,
IDE03830-ENG129410,Status of adaptation of on-demand fuel pump-Test_Program_Channel 1021,235,
IDE03932,Charge pressure actuator: specified position,150.00, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3414.8, mV
IDE03935,Charge pressure actuator: adaptation for upper stop,604.8, mV
IDE03951-ENG114937,Intake manifold pressure adjustment recovery conditions-Bhedp sr,1,
IDE03952-ENG114938,Intake manifold pressure plausibility check recovery conditions-Bhepl psr,0,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.99957,
IDE03954-ENG112663,Throttle valve adaptation steady state condition-Badko se,1,
IDE03955-ENG114936,Intake manifold pressure model steady state condition-Bapsl mdse,0,
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE03998,Clutch Position Sensor,0.0, %
IDE04002,Charge press. ctrl.,BP_A act:99, kPa
IDE04010,Engine torque: normalized,10, %
IDE04011,Nominal torque,320, Nm
IDE04083,Coolant temperatures,ECT 1:84 °C / ECT 2:11 °C,
IDE04110,Additional inputs and outputs,,
IDE04256,Temp sensor for engine coolant: unconditioned voltage,1124.4, mV
IDE04278,Bypass valve f high press turboch turbine inlet: target value,99.99, %
IDE04279,Bypass valve f high press turboch turbine inlet: actual value,99.17, %
IDE04280,Bypass valve f high press turboch turbine inlet: offset closed,-4.09, %
IDE04281,Bypass valve f high press turboch turbine inlet: offset open,4.09, %
IDE04301,Bypass valve for high press turboch turbine inlet: activation,-14.22, %
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,7,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,64,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,18,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,0,
IDE04303,Bypass valve for high press turboch turbine inlet: uncond volt,3390.6, mV
IDE04409,Intake manifold pressure: corrected,348.44, hPa
IDE04410,Intake manifold pressure: target value,354.53, hPa
IDE04414,Cat conv temp: modeled,330, °C
IDE04420,Activation of secondary air system,Atmosphere/off,
IDE04604,Accelerator pedal travel,0.00, %
IDE04615,Segment adaptation for rough running: status,2,
IDE04630,AVS valve stroke position: current,false,
IDE04630-ENG06942,AVS valve stroke position: current-Test_Program_Xaied Fa Ehan Adc jnotd jb n 0 A1T UBYTE,0,
IDE04638,Transmission coolant valve,False result,
IDE04638-ENG127289,Transmission coolant valve-Test_Program_B TRUE UBYTE,0,
IDE04651,Torque request: A/C compressor,0.0, Nm
IDE04670,Crankshaft signal evaluation: status,GAPFOUND,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,8,
IDE04685,Setpoint generation interior torque,33.3, Nm
IDE04689,Starter control: Start interruption status,Correct result,
IDE04689-ENG127289,Starter control: Start interruption status-Test_Program_B TRUE UBYTE,1,
IDE04692,Reducing desired torque intervention of ESP,50000.0, Nm
IDE04693,Increasing desired torque intervention of ESP,-3276.8, Nm
IDE04695-ENG06680,Immobilizer snapshot A-Sia Error Snap,00 00 00,
IDE04696-ENG06680,Immobilizer snapshot B-Sia Error Snap,00 00 00,
IDE04814,Transmission oil cooler valve,False result,
IDE04814-ENG127289,Transmission oil cooler valve-Test_Program_B TRUE UBYTE,0,
IDE04820,Fuel content due to degassing of engine oil,0.70, %
IDE04858,Brake booster low pressure actual value,980.74, hPa
IDE04872,Brake pedal value sensor: relative value filtered,0.00, %
IDE04887,Powertrain target torque,5.0, Nm
IDE04889,Target torque for combustion engine crankshaft level,14.2, Nm
IDE04909-ENG57549,Operating mode of hybrid system-Bits 0-7,0,
IDE04933,Number of fill level decreases,0,
IDE04934,Last odometer reading since fill level decrease,0, km
IDE04935,Next to last odometer reading since fill level decrease,0, km
IDE04936,3. Last odometer reading since fill level decrease,0, km
IDE05128,Intake air temperature in intake manifold bank 1,15.0, °C
IDE05135,Status of compressor release,False result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05138,Shut-off timer: last engine shut-off time,1295787, s
IDE05140,Intake manifold pressure raw value,341.64, hPa
IDE05213,Activation pulse duty factor for tank vent valve for diag,0.000, %
IDE05214,Tank vent valve diagnosis pressure difference ratio,0.00,
IDE05215,Tank vent valve diagnosis result correlation factor,0.00,
IDE05221,E-machine torque actual value,0.0, Nm
IDE05240-ENG57549,Request for A/C compressor power reduction-Bits 0-7,0,
IDE05241-ENG57549,A/C compressor release status-Bits 0-7,1,
IDE05260-ENG57549,Gear position sensor: current value-Bits 0-7,0,
IDE05261-ENG57549,Gear position sensor: last valid value-Bits 0-7,14,
IDE05262,Gear position sensor: gear position valid,False result,
IDE05262-ENG127289,Gear position sensor: gear position valid-Test_Program_B TRUE UBYTE,0,
IDE05327,Activation for electrical reserve coolant pump in HT circuit,0.00, %
IDE05332-ENG57549,Heat request from heater to thermal management-Bits 0-7,2,
IDE05436,Engine operating condition,Idling,
IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
IDE05437,Outside air temperature via CAN,9.8, °C
IDE05438,Rear cat conv temp main cat conv model value,334.7, °C
IDE05442,Roadway slope angle acceleration interface: calculated,0.0000, rad
IDE05444,Air filling: specified value,18.91, %
IDE05445,Pressure before throttle valve of pressure sensor,992.89, hPa
IDE05449,Oxygen sensor 2 bank 1 internal resistance limit value,700, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00421,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,785.08, °C
IDE05470,Cat converter oxygen storage capacity,0.0, mg
IDE05474,Main cat converter OSC age correction factor,0.70313,
IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
IDE05479,Misfire recognition reference moment,6.712, %
IDE05482,Tank venting adaptation factor,2.150,
IDE05484,Power steering pump desired actual moment for idling control,0.0, Nm
IDE05485-ENG57549,Irregular shutdown of the counter control mod-Bits 0-7,0,
IDE05486,Current system status,SYC_DRIVE,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05488,Coolant temperature modeled value,20.9, °C
IDE05497,Adaptation value of the charge pressure control,0.00, hPa
IDE05593,Secondary air injection sensor 1,997.54, hPa
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,30,
IDE05797,Throttle valve adapter: specified value,2.023, %
IDE05809,Counter: implaus. short-term adapt. values: misfire detection,0,
IDE05928,Fuel consumption since DTC memory last erased,20.599, l/100km
IDE05941-ENG112665,Enable condition: camshaft control-Bnws,1,
IDE05943,Release for supply to fuel pump,On,
IDE05943-ENG129326,Release for supply to fuel pump-Test_Program_Channel 890,135,
IDE05950,Charge pressure control adaptation value 1,0, hPa
IDE05951,Charge pressure control adaptation value 2,0, hPa
IDE05952,Charge pressure control adaptation value 3,0, hPa
IDE06014,Charge pressure control adaptation value 0,0, hPa
IDE06015,Time since term 15 OFF StartStop,65535, s
IDE06017,Camshaft position deviation from reference position,-0.13, °
IDE06020,Intake air temperature in intake manifold bank raw value,15.7, °C
IDE06023-ENG57549,BDE operating mode flag register-Bits 0-7,1,
IDE06039,Required RPM at idle speed,800.0, /min
IDE06040,High fuel pressure: regulator output value,-0.3160, MPa
IDE06041-ENG57549,PDTC drive cycle conditions status-Bits 0-7,37,
IDE06043,Cylinder head temperature: actual value,85.2, °C
IDE06045-ENG57549,Output DTM status-Bits 0-7,0,
IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
IDE06049,Pressure in brake booster: raw value,18, hPa
IDE06098,Sensor control factor: output value,0.99069,
IDE06112-ENG57549,Cylinder shut-off test-Bits 0-7,5,
IDE06192,Knock sensor: cylinder 2: voltage,0.0055573, V•ms
IDE06193,Knock sensor: cylinder 3: voltage,0.0049179, V•ms
IDE06194,Knock sensor: cylinder 4: voltage,0.0045151, V•ms
IDE06195,Knock sensor: cylinder 1: voltage,0.0047791, V•ms
IDE06198-ENG57549,Tank vent valve: diagnostic status-Bits 0-7,32,
IDE06255,Vehicle lateral acceleration,0.00, g
IDE06256,Vehicle lateral acceleration: raw value,0.00, g
IDE06257,Vehicle inclination acceleration angle: raw value,0.000, m/s²
IDE06307-MAS00106,Stop prevention history data-Year,2019,
IDE06307-MAS00107,Stop prevention history data-Month,12,
IDE06307-MAS00108,Stop prevention history data-Day,5,
IDE06307-MAS00109,Stop prevention history data-Hours,11,
IDE06307-MAS00110,Stop prevention history data-Minutes,27,
IDE06307-MAS00111,Stop prevention history data-Seconds,7,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Driving situation,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,Brake under pressure too low,
IDE06308,Start request history data,Cat. heater,
IDE06308,Start request history data,Engine temperature too high,
IDE06308,Start request history data,Motor protection active,
IDE06308,Start request history data,Engine hood open,
IDE06308,Start request history data,Fuel salinization protection active,
IDE06308,Start request history data,Deceleration takeover active,
IDE06308,Start request history data,Sporadic function restriction,
IDE06308,Start request history data,Rolling vehicle,
IDE06308,Start request history data,Auxiliary consumers power too high,
IDE06308,Start request history data,Hybrid battery power insufficient,
IDE06308,Start request history data,Engine temperature too low,
IDE06308,Start request history data,SCR System requires restart,
IDE06308,Start request history data,Steering,
IDE06308,Start request history data,Restriction in the start system,
IDE06386,Oil level: static measurement,0.000, mm
IDE06387,Oil level: last valid dynamic value,0.000, mm
IDE06388,Oil level: condition for static measurement fulfilled,0,
IDE06391,Oil temperature sensor 2,-273.1, °C
IDE06393,Oil level: dynamic average value,131.068, mm
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06431,Result: aging test: O2 sensor 1: bank 1: before cat converter,Test off,
IDE06431-ENG130130,Result: aging test: O2 sensor 1: bank 1: before cat converter-Test_Program_Channel 115,235,
IDE06434-ENG112927,Oxygen control: bank 1: sensor 1: release status-Blrnd A,1,
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06445,Longitudinal acceleration: raw value,0.000, m/s²
IDE06446-ENG57549,Status: incline angle-Bits 0-7,0,
IDE06495,Results of testing of crankcase ventilation successful,2,
IDE06496,Results of testing of crankcase ventilation unsuccessful,0,
IDE06552,Time since terminal 15 ON,672660, ms
IDE06567,Start-stop function deactivation frequency counter,2,
IDE06568,Stop prevention by driver frequency counter,20,
IDE06569,Vehicle stopped frequency counter,38,
IDE06570,Oil level and oil temp. sensor: oil temperature in oil pan,30.3, °C
IDE06610,Vehicle standstill with stop frequency counter,1,
IDE06647-ENG57549,Start-stop switch status-Bits 0-7,1,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,0,
IDE06703-ENG57549,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
IDE06704-ENG57549,Drivetrain coordinator: brake fault status-Bits 0-7,0,
IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,0,
IDE06706-ENG57549,ACC variants-Bits 0-7,2,
IDE06707-ENG57549,CCS Switch-Bits 0-7,2,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,32,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,1,
IDE06709-ENG57549,ACC variants (coding)-Bits 0-7,3,
IDE06710-ENG57549,Cruise control system: permanent deactivation-Bits 0-7,255,
IDE06711-ENG57549,Cruise control system: temporary deactivation-Bits 0-7,255,
IDE06726,Timing deviation after chain replacement: intake bank 1,-1.07, °
IDE06728,Timing deviation after chain replacement: exhaust bank 1,1.93, °
IDE06730,Timing deviation after other repairs: intake bank 1,0.00, °
IDE06732,Timing deviation after other repairs: exhaust bank 1,0.00, °
IDE06734,Timing deviation: current value intake bank 1,0.00, °
IDE06736,Timing deviation: current value exhaust bank 1,0.00, °
IDE06738-ENG57549,Chain elongation: no. of valid initial values: intake bank 1-Bits 0-7,1,
IDE06740-ENG57549,Chain elongation: no. of valid initial values: exhaust bank 1-Bits 0-7,1,
IDE06742,Chain elongation: initial values valid: intake bank 1,not active,
IDE06742-ENG36870,Chain elongation: initial values valid: intake bank 1-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06744,Chain elongation: initial values valid: exhaust bank 1,not active,
IDE06744-ENG36870,Chain elongation: initial values valid: exhaust bank 1-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06758,Air mass since engine start,2.8715, kg
IDE06794,NG to gasoline split factor,0.000,
IDE06800,A/C main switch status,Correct result,
IDE06800-ENG127289,A/C main switch status-Test_Program_B TRUE UBYTE,1,
IDE06944,A/C compressor: load current: act. value,0.00, A
IDE06946-ENG57549,Brake actuated status-Bits 0-7,0,
IDE06947-ENG57549,E-machine operating mode: spec. state-Bits 0-7,0,
IDE06950-ENG57549,Load request from external load manager-Bits 0-7,0,
IDE06956-ENG57549,Driver-side belt buckle status-Bits 0-7,2,
IDE06957,Unfiltered clutch input rpm,787.0, /min
IDE06970,Desired braking torque: driving assistant,0.0, Nm
IDE06975-ENG57549,Regeneration stages-Bits 0-7,0,
IDE07001,Piston-cooling jets: activation,0,
IDE07031,Oil pressure switch for piston-cooling jets: status,0,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,12,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,98,
IDE07051-ENG57549,Engaged gear: raw signal-Bits 0-7,0,
IDE07076,AVS valve stroke position intake,0,
IDE07077,AVS valve stroke position: exhaust,15,
IDE07078,AVS result of last switch-over: intake,15,
IDE07164,Number injections,20520,
IDE07170,Clutch K0: torque,0.0, Nm
IDE07194,Calculated increasing transmission engagement torque,-3276.8, Nm
IDE07224-ENG57549,Overrun cut-off-Bits 0-7,0,
IDE07225-ENG57549,Transfer electric drive to combustion drive-Bits 0-7,0,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,0,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,66,
IDE07234,Status bid for valid static oil level,0,
IDE07235,Status bid for dynamic oil level,0,
IDE07238,Status of power transfer,0.00,
IDE07240-ENG57549,Status transition of engine control module sequencing-Bits 0-7,0,
IDE07242,Heater support pump: spec. value,94.79, %
IDE07254,Gasoline pressure tank refueling request button,0,
IDE07257,Tank pressure from leakage diagnosis: calculated,0.000, hPa
IDE07548,Engine temp. mangmt. actuator: specified value of angle,61.95, %
IDE07549,Engine temp. mangmt. actuator: actual value of angle,61.74, %
IDE07550,Engine temp. management actuator: raw value,2496.2, mV
IDE07551,Engine temp. management actuator: duty cycle activation,0.00, %
IDE07553,Engine temperature management actuator: after-run stop,3953.4, mV
IDE07554,Engine temperature management actuator: stop open,137.8, mV
IDE07573,Throttle valve adapter: actual value,2.047, %
IDE07615,Operating of tank: empty or reserve,OK,
IDE07615-ENG129324,Operating of tank: empty or reserve-Test_Program_Channel 372,194,
IDE07620-ENG57549,Status momentary default during stability intervention-Bits 0-7,0,
IDE07664,Pre-coordinated torque of increased stability intervention,-50000.0, Nm
IDE07665,Accel. pedal kick-down recognition: voltage threshold,4125.2, mV
IDE07666,Target torque of elec. motor: coordinated output signal,0.0, Nm
IDE07667,Desired torque of regeneration,-28.0, Nm
IDE07724,Coolant temperature at engine outlet: calculated,85.4, °C
IDE07796-ENG57549,Turboch. 1 turb.byp.v. 1 bank 1: pos.feedback -Breakaw.attempts-Bits 0-7,0,
IDE07840-ENG57549,Status plausibility accelerator pedal to brake pedal-Bits 0-7,0,
IDE07904-ENG57549,Brake test switch status-Bits 0-7,0,
IDE07905-ENG57549,Brake light switch status-Bits 0-7,0,
IDE07906-ENG57549,Upper clutch switch: status-Bits 0-7,0,
IDE07908,Coolant fan activation requested by A/C,0.00, %
IDE07963-ENG57549,Cam piece counter position malfunction-Bits 0-7,0,
IDE08071-ENG57549,Remote start cancellation reason store 1-Bits 0-7,0,
IDE08072-ENG57549,Remote start cancellation reason store 2-Bits 0-7,0,
IDE08073-ENG57549,Remote start cancellation reason store 3-Bits 0-7,0,
IDE08074-ENG57549,Remote start cancellation reason store 4-Bits 0-7,0,
IDE08075-ENG57549,Remote start cancellation reason store 5-Bits 0-7,0,
IDE08353-ENG57549,Bypass valve turbocharger: adaptation status-Bits 0-7,0,
IDE08353-ENG57549,Bypass valve turbocharger: adaptation status-Bits 0-7,6,
IDE09307-ENG57549,Pre-ignition counter cylinder 1-Bits 0-7,0,
IDE09308-ENG57549,Pre-ignition counter cylinder 2-Bits 0-7,0,
IDE09309-ENG57549,Pre-ignition counter cylinder 3-Bits 0-7,0,
IDE09310-ENG57549,Pre-ignition counter cylinder 4-Bits 0-7,0,
IDE09313-ENG57549,Pre-ignition counter over serv.life cylinder 1-Bits 0-7,0,
IDE09314-ENG57549,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,0,
IDE09315-ENG57549,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,0,
IDE09316-ENG57549,Pre-ignition counter over serv.life cylinder 4-Bits 0-7,0,
IDE09319-ENG57549,Pre-ignition action counter injection cut-off-Bits 0-7,0,
IDE09320-ENG57549,Pre-ignition action counter fill level limit-Bits 0-7,0,
IDE09529,Fuel mass flow rate due to degassing of eng. oil,8.5, mg/s
IDE09531,Total mass of gasoline and alcohol in oil,5.25, g
IDE09532,Correction factor for fuel mixture,1.00000,
IDE09572,O2 sensor dwnstrm. of cat.: gradient transfer lean -> rich,0.00, s
IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.00, s
IDE09693-ENG57549,Charisma driving program: system status-Bits 0-7,0,
IDE09694-ENG57549,Charisma driving program: act. value-Bits 0-7,2,
IDE09695-ENG57549,Charisma driving program: target value from coordinator-Bits 0-7,0,
IDE09696-ENG57549,Charisma driving program: CAN output value-Bits 0-7,2,
IDE09925-ENG57549,Intake camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09926-ENG57549,Outlet camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09927,Intake camshaft bank 1: adaption hardware offset active,False result,
IDE09927-ENG127289,Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09928,Outlet camshaft bank 1: adaption hardware offset active,False result,
IDE09928-ENG127289,Outlet camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09929,Intake camshaft bank 1: adaption value hardware offset active,-1.23, °
IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,3.12, °
IDE09931,Outlet camshaft bank 1: adaption value sensor tolerance,-2.29, °
IDE09932,Intake camshaft bank1: adaption value sensor tolerance,0.62, °
IDE09942,Long-term adaptation of mixture formation FSI: additive,-1.73, %
IDE09943,Long-term adaptation of mixture formation FSI: multiplicative,0.99957,
IDE09944,Long-term adaptation of mixture formation MPI: additive,0.00, %
IDE09945,Long-term adaptation of mixture formation MPI: multiplicative,1.00000,
IDE09977,Control module temp.: max. value,77.5, °C
IDE10040-ENG57549,Outlet camshaft bank 1 active operating mode-Bits 0-7,8,
IDE10041,Intake camshaft bank1 active operating mode,8,
IDE10042,Outlet camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10042-ENG127372,Outlet camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10043,intake camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10120,Chain elongation inlet: mileage of the last adaptation,1, km
IDE10121,Chain elongation outlet: mileage of the last adaptation,0, km
IDE10302,Time since engine start,682.3, s
IDE10303,Integrated air masse at first engine start,2.8974, kg
IDE10366,Chg. press. ctrl. valve: sensor voltage max. value,3.53, V
IDE10560-ENG57549,Adaption of radiator shutters: status-Bits 0-7,0,
IDE10630,O2 sensor upstrm. of cat.: delay time transf. rich -> lean,0.00, s
IDE10641,Low fuel pressure adaptation value for EFP: modeled,20.0, kPa
IDE10670,O2 sensor upstrm. of cat.: filter constant transf. rich -> lean,0.00, s
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG130099,Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG06494,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG06495,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10968,Activation radiator shutter result,0.00, %
IDE10970-MAS11563,Number of prevented stop processes-Engine hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989-MAS00106,Immobilizer: historic data-Year,2127,
IDE10989-MAS00107,Immobilizer: historic data-Month,15,
IDE10989-MAS00108,Immobilizer: historic data-Day,31,
IDE10989-MAS00109,Immobilizer: historic data-Hours,31,
IDE10989-MAS00110,Immobilizer: historic data-Minutes,63,
IDE10989-MAS00111,Immobilizer: historic data-Seconds,63,
IDE10989,Immobilizer: historic data,Function locked due to excessive stalling,
IDE10989,Immobilizer: historic data,Engine hood open,
IDE10989,Immobilizer: historic data,Brake pedal information: plausibility,
IDE10994,Poor start counter at start-stop,0,
IDE11081,AVS operating state: inlet,1,
IDE11083-ENG29792,Special software: name-SigXL Bypass tool output name 4F47,ORIGINAL A2L,
IDE11115,Start/stop driver request: counter restart by starter,0,
IDE11116,Start/stop driver request: counter internal-motor restart,0,
IDE11293,Fuel consumption difference: injectors/sensors,0.000, l
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,1.543, l
IDE11372,Camshaft angle adaptation: inlet deviation,0.000, °
IDE11541-ENG57549,Autom.pre-selection sys operat.state of the actuator test-Bits 0-7,0,
IDE11635-ENG57549,Radiator shutter 1: status referencing-Bits 0-7,0,
IDE11636-ENG57549,Radiator shutter 2: status referencing-Bits 0-7,0,
IDE11931,Heated oxygen sensor bank 1 sensor 1: positioning intervention rear cat controller,0.00079,
IDE12355,ESI: consumption equivalent of the engine control module,0.00000046,
IDE12453,Knock sensor based camshaft angle adjustment: counter,0,
IDE13012,Tank breather valve: activation duty factor,9.215, %
IDE13301,Drivetrain coordinator: brake fault status,0,
IDE13336,Drive train coordinator reversible switch off conditions,0,
IDE13337,Drive train coordinator irreversible switch off conditions,0,
IDE13746,Flushing rate in cylinder charging,1.0000,
IDE13772,Engine protection torque limitation,1000.0, Nm
IDE14242,Oil pressure valve for piston cooling nozzles: control switch button ratio,100.00, %
IDE14534,Knock control: error status,2147614720,
IDE14818,Reduce ignition advance with global knock control adaptation,0.0, °
IDE15614,Time since first start of combustion engine,685600, ms
IDE80106,Analysis 106,00 03 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D6 00 00 00 00 00 00 00 A7 00 12 00 06 00 00 00 00 00 00 00 00,
MAS15845,Fuel: tank fill level,57.0, l
MAS16066,Exhaust gas temperature at the probe before PreCat bank 1: model value,388.0, °C
MAS16074,Temperature in pre-cat bank 1: model value,392.8, °C
MAS16088,Lambda driver request: specified value,1.0000,
MAS16089,Lambda component protection: bank 1: specified value,1.0000,
MAS16091,Lambda Delta from exhaust gas temperature regulation bank 1: actual value,0.0000,
MAS16097,Tank ventilation factorial fuel amount: actual value,0.086,
MAS16098,Tank ventilation relative mixture proportion: actual value,1.64, %
MAS16301,Sensor adaptation: status with engine running,0,
MAS16534-ENG57549,A/C compressor info: switch-off status-Bits 0-7,0,
MAS16543,Bank 1 heated oxygen sensor downstream of catalytic converter: exhaust gas temperature calculated,334.75, °C
MAS17030,Engine control module hardware timer: self-diagnosis status,1,
MAS17031,Radiator shutter 1: actual position,399.99, %
MAS17032,Radiator shutter 2: actual position,399.99, %
MAS17038,Heated oxygen sensor 2 bank 1: heat output normalized,0.25,
MAS17039,Heated oxygen sensor 1 Bank 1: target voltage adequate for lean conditions,1.000, V
MAS17041,Heated oxygen sensor 1 bank 1: effective heater voltage,7.320, V
MAS17045,Heated oxygen sensor 2 bank 1: internal resistance,50996, Ohm
MAS17047,Heated oxygen sensor 2 Bank 1: target voltage adequate for rich conditions,0.000, V
MAS17055,Heated oxygen sensor 1 bank 1: identified total time (lean -> rich),0.00, s
MAS17056,Heated oxygen sensor 1 Bank 1: adaptation value for filtering time constants,0.00, s
MAS17058,Heated oxygen sensor 1 Bank 1: adaptation value for dead time,0.00, s
MAS17059,Heated oxygen sensor 1 bank 1: identified total time (rich -> lean),0.00, s
MAS17060,Characteristics cooling module 1: end stage activation,0.00, %
MAS17191,Characteristics cooling module: target position,61.95, %
MAS17192,Characteristics cooling module: upper mechanical stop,137.8, mV
MAS17193,Characteristics cooling module: lower mechanical stop,3953.4, mV
MAS17236-ENG57549,Adaptation of radiator shutter 2: status-Bits 0-7,0,
MAS17237-ENG57549,Adaptation of radiator shutter 3: status-Bits 0-7,0,
MAS17238-ENG57549,Adaptation of radiator shutter 4: status-Bits 0-7,0,
ENG119898,Actual_section_of_standard_test,0,
ENG112928-ENG57549,Air_conditioning_compressor_actual_status-Bits 0-7,0,
ENG105149,Air_mass_integral_for_thermostat_diagnosis_actual_value,2.04, kg
ENG105150,Air_mass_integral_for_thermostat_diagnosis_limit_value,9.45, kg
ENG26434-ENG57549,AVS_Cam_element_position_error_counter_lift_0-Bits 0-7,0,
ENG26435-ENG57549,AVS_Cam_element_position_error_counter_lift_1-Bits 0-7,0,
ENG26436-ENG57549,AVS_Cam_element_position_error_counter_manifold_pressure_diagnosis-Bits 0-7,0,
ENG26437-ENG57549,AVS_Cam_element_position_error_counter_misfire_detection-Bits 0-7,0,
ENG121428-ENG57549,AVS_counter_error_debonce-Bits 0-7,0,
ENG121428-ENG57549,AVS_counter_error_debonce-Bits 0-7,2,
ENG121429-ENG57549,AVS_counter_error_limphome-Bits 0-7,0,
ENG121426-ENG57549,AVS_counter_sporadic_diagnosis_errors-Bits 0-7,0,
ENG121427-ENG57549,AVS_counter_sporadic_switch_errors-Bits 0-7,0,
ENG112670-ENG112664,Brake_booster_start_request_combustion_engine-Bbkvs ta,0,
ENG101413,Calibration Identification,83A115B 0004DXBA,
ENG99697,Calibration Verification Number,0C F6 63 23,
ENG08794-ENG57549,Com st X Set1 Val1-Bits 0-7,0,
ENG08795-ENG57549,Com st X Set1 Val2-Bits 0-7,0,
ENG08796-ENG57549,Com st X Set1 Val3-Bits 0-7,0,
ENG08797-ENG57549,Com st X Set1 Val4-Bits 0-7,0,
ENG08798-ENG57549,Com st X Set1 Val5-Bits 0-7,0,
ENG08799-ENG57549,Com st X Set1 Val6-Bits 0-7,0,
ENG08800-ENG57549,Com st X Set1 Val7-Bits 0-7,0,
ENG08801-ENG57549,Com st X Set2 Val1-Bits 0-7,0,
ENG08802-ENG57549,Com st X Set2 Val2-Bits 0-7,0,
ENG08803-ENG57549,Com st X Set2 Val3-Bits 0-7,0,
ENG08804-ENG57549,Com st X Set2 Val4-Bits 0-7,0,
ENG08805-ENG57549,Com st X Set2 Val5-Bits 0-7,0,
ENG08806-ENG57549,Com st X Set2 Val6-Bits 0-7,0,
ENG08807-ENG57549,Com st X Set2 Val7-Bits 0-7,0,
ENG08808-ENG57549,Com st X Set3 Val1-Bits 0-7,0,
ENG08809-ENG57549,Com st X Set3 Val2-Bits 0-7,0,
ENG08810-ENG57549,Com st X Set3 Val3-Bits 0-7,0,
ENG08811-ENG57549,Com st X Set3 Val4-Bits 0-7,0,
ENG08812-ENG57549,Com st X Set3 Val5-Bits 0-7,0,
ENG08813-ENG57549,Com st X Set3 Val6-Bits 0-7,0,
ENG08814-ENG57549,Com st X Set3 Val7-Bits 0-7,0,
ENG01773-ENG57549,Configuration_of_cruise_control-Bits 0-7,0,
ENG126402-ENG57549,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,64,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,0,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,1,
ENG122710,Cruise_control_velocity_setpoint,0.000, km/h
ENG111031-ENG57549,DFC_status_error_debounced_counter-Bits 0-7,0,
ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,85,
ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,4,
ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,196,
ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,0,
ENG126404-ENG57549,Drive_train_coordinator_checked_coding-Bits 0-7,5,
ENG112930,Driving_torque_coordinator_requested_driving_torque_from_GRA,-32768.0, Nm
ENG111582,DrivingProgramSwitch_sport_mode_activated,False result,
ENG111582-ENG127289,DrivingProgramSwitch_sport_mode_activated-Test_Program_B TRUE UBYTE,0,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG114220,Effective_injection_duration,5.588, ms
ENG111593,Emachine_achievable_enginetorque_maximum_value,0.0, Nm
ENG111594,Emachine_achievable_generatortorque_maximum_value,0.0, Nm
ENG115973,Engine Exhaust Flow Rate,12.0, kg/h
ENG20102,Engine Friction - Percent Torque,6.0, %
ENG112932,Engine_oil_temperature_measured_value,-273.1, °C
ENG111034,Engine_temperature_modelbased_substitute_value,75.0, °C
ENG118071-ENG57549,Engine_torque_interventi_status-Bits 0-7,2,
ENG118071-ENG57549,Engine_torque_interventi_status-Bits 0-7,0,
ENG112302,EngineCoordinator_activation_within_quasistationary_limits_of_ElM,False result,
ENG112302-ENG127289,EngineCoordinator_activation_within_quasistationary_limits_of_ElM-Test_Program_B TRUE UBYTE,0,
ENG111568,EngineCoordinator_intervention_request_actual_value,0,
ENG112301,EngineManagement_activation_limited_reduction_of_efficiency,False result,
ENG112301-ENG127289,EngineManagement_activation_limited_reduction_of_efficiency-Test_Program_B TRUE UBYTE,0,
ENG26778,Evap_purge_system_bank_1_cross_correlation_maximum_engine_load_gradient,0.00, hPa
ENG26779,Evap_purge_system_bank_1_cross_correlation_maximum_engine_speed_gradient,0.0, /min
ENG26780,Evap_purge_system_bank_1_cross_correlation_measured_mean_amplitude,0.0, hPa
ENG26781,Evap_purge_system_bank_1_insertion_pre_turbocharger_corrected_cross_correlation_coefficient,0.00,
ENG26788,ExhMgT_fetak_hllfa_msg,1.000,
ENG26789,ExhMgT_fetak_htlfa_msg,1.000,
ENG26808,Fl Lvl vol Tnk Plaus Old,57.000, l
ENG115974-ENG55378,Fuel Rate-Engine Fuel Rate,0.18, g/s
ENG115974-ENG116137,Fuel Rate-Vehicle Fuel Rate,0.18, g/s
ENG111608,Fuel_consumption_actual_driving_cycle,0.26, l
ENG106769-ENG57549,Gearbox_heat_request-Bits 0-7,0,
ENG112667,Generator load normalised value,38.65, %
ENG112931,Generator_load_from_CAN,744.557, W
ENG112929,Generator_torque_request,8.9, Nm
ENG107016,Injection quantity average,0.00, mg/stroke
ENG107045,Intake_manifold_model_air_mass_flow_filtered_value,11.3, kg/h
ENG100634,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2,00 01 00 20 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00 00 00 01 00 01 00 07 00 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00,
ENG110574,Lambdacoordination_homogeneous_mode_range_limited_commanded_value,1.0000,
ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2127,
ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,15,
ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,31,
ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,31,
ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,63,
ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,63,
ENG127734,Life_cycle_data_start_requirement_development,Steering,
ENG127734,Life_cycle_data_start_requirement_development,Front sensor system for driver assistance systems,
ENG127734,Life_cycle_data_start_requirement_development,All-wheel electronics,
ENG127734,Life_cycle_data_start_requirement_development,A/C,
ENG127734,Life_cycle_data_start_requirement_development,Convertible top control module,
ENG127734,Life_cycle_data_start_requirement_development,12 V electrical system,
ENG127734,Life_cycle_data_start_requirement_development,Transmission,
ENG127734,Life_cycle_data_start_requirement_development,Level control system,
ENG127734,Life_cycle_data_start_requirement_development,Multifunction unit control module,
ENG127734,Life_cycle_data_start_requirement_development,Parking aid,
ENG127734,Life_cycle_data_start_requirement_development,ACC,
ENG127734,Life_cycle_data_start_requirement_development,Front axis lift system,
ENG127734,Life_cycle_data_start_requirement_development,Engine,
ENG127734,Life_cycle_data_start_requirement_development,Immobilizer,
ENG127734,Life_cycle_data_start_requirement_development,Kessy,
ENG127734,Life_cycle_data_start_requirement_development,brakes,
ENG127734,Life_cycle_data_start_requirement_development,Quattro Sport,
ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2127,
ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,15,
ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,31,
ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,31,
ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,63,
ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,63,
ENG127735,Life_cycle_data_stop_prohibition_development,Quattro Sport,
ENG127735,Life_cycle_data_stop_prohibition_development,Steering,
ENG127735,Life_cycle_data_stop_prohibition_development,Multifunction unit control module,
ENG127735,Life_cycle_data_stop_prohibition_development,Parking aid,
ENG127735,Life_cycle_data_stop_prohibition_development,Engine,
ENG127735,Life_cycle_data_stop_prohibition_development,Immobilizer,
ENG127735,Life_cycle_data_stop_prohibition_development,Kessy,
ENG127735,Life_cycle_data_stop_prohibition_development,A/C,
ENG127735,Life_cycle_data_stop_prohibition_development,Convertible top control module,
ENG127735,Life_cycle_data_stop_prohibition_development,Front axis lift system,
ENG127735,Life_cycle_data_stop_prohibition_development,12 V electrical system,
ENG127735,Life_cycle_data_stop_prohibition_development,ACC,
ENG127735,Life_cycle_data_stop_prohibition_development,Transmission,
ENG127735,Life_cycle_data_stop_prohibition_development,brakes,
ENG127735,Life_cycle_data_stop_prohibition_development,Level control system,
ENG127735,Life_cycle_data_stop_prohibition_development,Front sensor system for driver assistance systems,
ENG127735,Life_cycle_data_stop_prohibition_development,All-wheel electronics,
ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2019,
ENG127733-MAS00107,Life_cycle_data_system_failure-Month,11,
ENG127733-MAS00108,Life_cycle_data_system_failure-Day,22,
ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,0,
ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,56,
ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,33,
ENG127733,Life_cycle_data_system_failure,Engine,
ENG127733,Life_cycle_data_system_failure,not active,
ENG111606,Load value: unrestricted commanded value,18.49, %
ENG125271,Maximum_ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.031,
ENG111040,Misfire_detection_sensor_wheel_adaptation_speed_load_range_index,1,
ENG26325,Mo F Strt st Strtr Blk Err Msg,0,
ENG26978-ENG57549,Mo XEMM st EMM Alrms Idx0-Bits 0-7,0,
ENG26979-ENG57549,Mo XEMM st EMM Alrms Idx1-Bits 0-7,0,
ENG26980-ENG57549,Mo XEMM st EMM Alrms Idx2-Bits 0-7,0,
ENG55145-ENG57549,Mo XEMM st EMM Alrms Idx3-Bits 0-7,0,
ENG55146-ENG57549,Mo XEMM st EMM Alrms Idx4-Bits 0-7,0,
ENG111571,Mode_control_activation_P1_mode,False result,
ENG111571-ENG127289,Mode_control_activation_P1_mode-Test_Program_B TRUE UBYTE,0,
ENG107660,Mode_control_commanded_dragmoment_for_em,-28.0, Nm
ENG107661-ENG57549,Mode_control_operating_status_hybrid_system_bitcoded-Bits 0-7,0,
ENG111581-ENG57549,Mode_control_start_order_combustion_engine-Bits 0-7,0,
ENG107663,Mode_control_torque_electrical_auxilary_systems_requested_value,0.0, Nm
ENG112668,O2 sensor_controller_bank_1_p-rate,0.00000,
ENG26996-ENG57549,OEM2RB VW Byp flg E Hmnplt u8-Bits 0-7,0,
ENG108262,Powertrain_overall_gear_ratio,1.00,
ENG111605,Pressure_before_throttle_valve_actual_value,992.89, hPa
ENG125270,Ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.031,
ENG109006,Spark_efficiency_deviation_at_idle_maximum,22.7, %
ENG109007,Spark_efficiency_deviation_at_part_load_maximum,21.9, %
ENG121093-ENG57549,State_of_cruise_control_or_speedlimiter-Bits 0-7,0,
ENG01786-ENG57549,State_of_requestor_for_drivetrain_coordinator-Bits 0-7,2,
ENG08688,Thr Vlv u Sens1 B1,0.566, V
ENG08689,Thr Vlv u Sens2 B1,4.432, V
ENG01775,Top_speed_limitation,201.000, km/h
ENG109528,Torque_coordination_idle_speed_control_torque_actual_value_air_path,0.0, Nm
ENG109529,Torque_coordination_idle_speed_control_torque_SET_path_actual_value,29.3, Nm
ENG109533,Torque_distribution_Emaschine_combustion_engine_driver_request,4.0, Nm
ENG115975-ENG116124,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG115975-ENG116108,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG115975-ENG116105,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG115975-ENG116116,Transmission Actual Gear-Transmission Actual Gear Status Supported,Available,
ENG01785-ENG57549,Transmission_state_of_drivetrain_coordinator-Bits 0-7,4,
ENG01785-ENG57549,Transmission_state_of_drivetrain_coordinator-Bits 0-7,0,
ENG111604,Turbocharger_inlet_pressure_corrected_value,339.92, hPa
ENG119911,UEGO r Lam S1 B1,1.0032,
ENG115976,Vehicle Odometer,31.0, km
ENG01774,Velocity_limiter_setpoint,511.992, km/h
ENG27262,Virtual_SigXSet_SyC_tiPostDrv,0, s
ENG27263,Virtual_SigXSet_TiEngOff_tiDiagRef,69, s
ENG27264,Virtual_SigXSet_TiEngOff_tiStopCnt_Dif,1295799, s
ENG27265,Virtual_SigXSet_TiEngOff_tiStopCnt_Raw,7404201, s
ENG27266,Virtual_SigXSet_TiOff_tiStrtEnd_Off,65535, s
Elapsed Time: 01:01
09:
;SW:5Q0-937-087-BG HW:5Q0-937-087-BA --- Cent. Elect.
;Component:BCM PQ37BOSCH 038 0303, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BodyContrModul1UDSBosc,020001,EV_BCMBOSCH_020_VW37.rod
;Friday,20,December,2019,12:41:35:14741
;VCDS Version: Beta 19.10.0 (x64) Data version: 20190930 DS316.0
;VCID: 81546E4EC18A13596615-80D4
Group,Description,Actual
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0.00, km/h
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,No communication,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,No communication,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,No communication,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,No communication,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Decelerate tap,No communication,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Setting,No communication,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Activation,No communication,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,NOT-DEFINED,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,No communication,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not Used,No communication,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Control unit,No communication,
IDE00374-MAS05377,Electric auxiliary heater: relay activation-Low heat output relay,not coded/not installed,
IDE00374-MAS05378,Electric auxiliary heater: relay activation-High heat output relay,not coded/not installed,
IDE00844-MAS07314,Switch for engine hood-Status engine hood contact,closed,
IDE00844-ENG122175,Switch for engine hood-Bonnet_Magnetic_Lock,not coded/not installed,
IDE00973,Outside air temperature,11.00, °C
IDE01066-IDE02092,Convertible top status-Tailgate condition,not coded/not installed,
IDE01066,Convertible top status,not coded/not installed,
IDE01285,Counter of component protection malfunctions,0,
IDE01464-IDE04741,Rear window defogger-Rear window defogger button,not activated,
IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,OFF,
IDE01464-MAS01580,Rear window defogger-Activation,not active,
IDE01537-IDE04742,Windshield defogger-Windshield defogger button,not coded/not installed,
IDE01537-IDE04743,Windshield defogger-Windshield defogger indicator lamp,not coded/not installed,
IDE01537-MAS01580,Windshield defogger-Activation,not coded/not installed,
IDE01943-MAS01737,Turn signal-Diagnosis,normal,
IDE01943-MAS02248,Turn signal-Signal state,not active,
IDE01943-MAS03873,Turn signal-Duty cycle,0.0, %
IDE01943-MAS04351,Turn signal-Connector terminal number,36,
IDE01943-MAS04352,Turn signal-Connector number,Plug B,
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,not coded/not installed,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlocking button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote release button,not activated,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,closed,
IDE02092-MAS02447,Tailgate condition-Release,Enabled,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,not activated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,closed,
IDE02486,Data logger triggering,not active,
IDE02488-MAS01632,DWA Interior monitoring-Status,not coded/not installed,
IDE02488-MAS04508,DWA Interior monitoring-Alarm detected,not coded/not installed,
IDE02515-MAS01737,Low beam-Diagnosis,normal,
IDE02515-MAS02248,Low beam-Signal state,not active,
IDE02515-MAS03873,Low beam-Duty cycle,0.0, %
IDE02515-MAS04351,Low beam-Connector terminal number,5,
IDE02515-MAS04352,Low beam-Connector number,Plug C,
IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,active,
IDE02588-IDE00773,Terminal signals and start release-Terminal 15 status via CAN,active,
IDE02588-IDE01351,Terminal signals and start release-Terminal 75 status,On,
IDE02588-IDE01715,Terminal signals and start release-Status terminal S,active,
IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
IDE02588-IDE06027,Terminal signals and start release-Terminal S status via CAN,active,
IDE02588-MAS12787,Terminal signals and start release-Terminal 15 ignition switch signal 1,active,
IDE02588-MAS12788,Terminal signals and start release-Terminal 15 ignition switch signal 2,active,
IDE02614-MAS02788,Reversing light switch-CAN,not active,
IDE02614-MAS05360,Reversing light switch-Discreet wire,not active,
IDE02711,Rear Window Wiper,not active,
IDE02743-MAS01737,High Beam-Diagnosis,normal,
IDE02743-MAS02248,High Beam-Signal state,not active,
IDE02743-MAS03873,High Beam-Duty cycle,0.0, %
IDE02743-MAS04351,High Beam-Connector terminal number,39,
IDE02743-MAS04352,High Beam-Connector number,Plug B,
IDE02744-MAS01632,Steering wheel heater-Status,switched off,
IDE02744-MAS02311,Steering wheel heater-Steering wheel heating button,not activated,
IDE02744-MAS09758,Steering wheel heater-Temperature sensor,75,
IDE02857-IDE03111,Activation current-Interior light,0, mA
IDE02857-IDE05533,Activation current-Spray nozzle heater,0, mA
IDE02857-IDE06012,Activation current-Search lights,0, mA
IDE02857-MAS01554,Activation current-Left heated seat,0, mA
IDE02857-MAS01556,Activation current-Right heated seat,0, mA
IDE02857-MAS05942,Activation current-Windshield and rear window washer pump,0, mA
IDE02857-ENG128454,Activation current-Cockpittaster_1,0, mA
IDE02857-ENG128455,Activation current-Cockpittaster_2,65532, mA
IDE02857-ENG128456,Activation current-Cockpittaster_3,65532, mA
IDE02857-ENG128457,Activation current-Cockpittaster_4,65532, mA
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,65532, mV
IDE02857-ENG126436,Activation current-signal_horn,65533, mV
IDE02957-MAS01737,Ambient lighting-Diagnosis,not coded/not installed,
IDE02957-MAS02248,Ambient lighting-Signal state,NOT-DEFINED,
IDE02957-MAS03873,Ambient lighting-Duty cycle,0.00, %
IDE02957-MAS04351,Ambient lighting-Connector terminal number,0,
IDE02957-MAS04352,Ambient lighting-Connector number,not coded/not installed,
IDE02957-MAS06670,Ambient lighting-Channel,Not available,
IDE03111-MAS01737,Interior light-Diagnosis,normal,
IDE03111-MAS02248,Interior light-Signal state,active,
IDE03111-MAS03873,Interior light-Duty cycle,85.50, %
IDE03111-MAS04351,Interior light-Connector terminal number,12,
IDE03111-MAS04352,Interior light-Connector number,Plug C,
IDE03195-IDE03854,High values for automatic vertical headlight aim-Left front level control system sensor: height value current,0.0,
IDE03195-IDE04144,High values for automatic vertical headlight aim-Left rear level control system sensor: height value current,0.0,
IDE03195-IDE07143,High values for automatic vertical headlight aim-Vehicle level sensor: supply voltage,0.0, V
IDE03195-MAS13964,High values for automatic vertical headlight aim-Spec. value: activation vehicle level sensor,0.0,
IDE03195-MAS13965,High values for automatic vertical headlight aim-Vehicle level sensor: control voltage,0.0, V
IDE03310-MAS01737,Brake light-Diagnosis,normal,
IDE03310-MAS02248,Brake light-Signal state,not active,
IDE03310-MAS03873,Brake light-Duty cycle,0.0, %
IDE03310-MAS04351,Brake light-Connector terminal number,71,
IDE03310-MAS04352,Brake light-Connector number,Plug A,
IDE03388-IDE01217,Left front heated seat: status-Left heated seat stage,OFF,
IDE03388-MAS02201,Left front heated seat: status-Temperature,22.00, °C
IDE03389-IDE01218,Right front heated seat: status-Right heated seat stage,OFF,
IDE03389-MAS02201,Right front heated seat: status-Temperature,15.00, °C
IDE03504-IDE02022,Personalized settings-Comfort opening,OFF,
IDE03504-IDE03679,Personalized settings-Adaptive light functions,not active,
IDE03504-IDE04036,Personalized settings-High beam assistant: status,active,
IDE03504-MAS01597,Personalized settings-Sunroof,not active,
IDE03504-MAS04322,Personalized settings-Masked continuous high beam,active,
IDE03504-MAS06456,Personalized settings-Autolock,active,
IDE03504-MAS06457,Personalized settings-autounlock,not active,
IDE03504-MAS06911,Personalized settings-Status Coming Home,active,
IDE03504-MAS06912,Personalized settings-Status Leaving Home,active,
IDE03504-MAS07014,Personalized settings-Tourist light,not active,
IDE03504-MAS07967,Personalized settings-profile,1,
IDE03504-MAS07971,Personalized settings-Electrical rear lid,not active,
IDE03504-MAS07972,Personalized settings-Manual door unlock,Unlock. indiv. doors,
IDE03504-MAS07973,Personalized settings-Rain closure,not active,
IDE03504-MAS07978,Personalized settings-Mirror adjustment,INDIVIDUAL,
IDE03504-MAS07980,Personalized settings-Mirror lowering,not active,
IDE03504-MAS07981,Personalized settings-Automatic mirror fold-in,not active,
IDE03504-MAS07982,Personalized settings-Activation sound: theft warning system,active,
IDE03504-MAS07983,Personalized settings-Virtual pedal,not active,
IDE03504-MAS07984,Personalized settings-Automatic rear window wiper,active,
IDE03504-MAS07985,Personalized settings-Coming Home set point,5, s
IDE03504-MAS07986,Personalized settings-Leaving Home set point,5, s
IDE03504-MAS07987,Personalized settings-Light intensity,normal,
IDE03504-MAS07990,Personalized settings-Comfort flasher,active,
IDE03504-MAS07991,Personalized settings-Comfort flasher set point,3,
IDE03504-MAS07992,Personalized settings-Sliding beam range,active,
IDE03504-MAS07993,Personalized settings-Rain light,active,
IDE03504-ENG29901,Personalized settings-Touristenlicht Einstellwert,not active,
IDE03638-MAS01737,static AFS light-Diagnosis,normal,
IDE03638-MAS02248,static AFS light-Signal state,not active,
IDE03638-MAS03873,static AFS light-Duty cycle,0.0, %
IDE03638-MAS04351,static AFS light-Connector terminal number,45,
IDE03638-MAS04352,static AFS light-Connector number,Plug B,
IDE04213,Central locking button,not coded/not installed,
IDE04213-IDE07357,Central locking button-Indicator light for central locking,not coded/not installed,
IDE04254-MAS06517,Play protection for central locking-Rear spoiler counter,not active,
IDE04347-IDE00104,Expanded environmental conditions-DTC,00 00 00,
IDE04347-IDE07836,Expanded environmental conditions-Log data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE04347-IDE00020,Expanded environmental conditions-Terminal 15 status,On,
IDE04347-IDE01716,Expanded environmental conditions-Terminal 50 status,OFF,
IDE04347-IDE02515,Expanded environmental conditions-Low beam,not activated,
IDE04347-IDE04639,Expanded environmental conditions-Last wake-up cause,Radio telegram: valid,
IDE04347-IDE07956,Expanded environmental conditions-redundant signal line,infinite,
IDE04347-MAS01957,Expanded environmental conditions-Outside air temperature,11.0, °C
IDE04347-MAS02462,Expanded environmental conditions-Automatic high beam assist,not activated,
IDE04347-MAS02788,Expanded environmental conditions-CAN,On,
IDE04347-MAS03835,Expanded environmental conditions-Parking light,not activated,
IDE04347-MAS04121,Expanded environmental conditions-Voltage,14.9, V
IDE04347-MAS06466,Expanded environmental conditions-Parking light left,not activated,
IDE04347-MAS06467,Expanded environmental conditions-Parking light right,not activated,
IDE04347-MAS14232,Expanded environmental conditions-Light switch: zero setting,operated,
IDE04347-MAS19766,Expanded environmental conditions-Status of brake lamp switch: discrete,OFF,
IDE04347-MAS19768,Expanded environmental conditions-Brake lamp switch via CAN: status,OFF,
IDE04925-MAS01737,Daytime running lights-Diagnosis,not coded/not installed,
IDE04925-MAS02248,Daytime running lights-Signal state,Measured value not available,
IDE04925-MAS03873,Daytime running lights-Duty cycle,0.0, %
IDE04925-MAS04351,Daytime running lights-Connector terminal number,0,
IDE04925-MAS04352,Daytime running lights-Connector number,not coded/not installed,
IDE05042-IDE05043,Emergency flasher button-Emergency flasher indicator lamp,On,
IDE05042-MAS02158,Emergency flasher button-Actuation condition,Not operated,
IDE05042-MAS03873,Emergency flasher button-Duty cycle,18.00, %
IDE05045-IDE05183,Front windshield wiper module-Malfunction left,no error,
IDE05045-IDE05184,Front windshield wiper module-Malfunction right,no error,
IDE05045-MAS01632,Front windshield wiper module-Status,not active,
IDE05045-MAS02282,Front windshield wiper module-Position,park position,
IDE05045-MAS03638,Front windshield wiper module-Wipe speed,0, /min
IDE05045-MAS05057,Front windshield wiper module-Number of wiper cycles,900,
IDE05045-MAS05878,Front windshield wiper module-Stage,not coded/not installed,
IDE05323-MAS01737,Fog light-Diagnosis,normal,
IDE05323-MAS02248,Fog light-Signal state,active,
IDE05323-MAS03873,Fog light-Duty cycle,100.0, %
IDE05323-MAS04351,Fog light-Connector terminal number,10,
IDE05323-MAS04352,Fog light-Connector number,Plug B,
IDE05434-MAS01737,Rear entry light-Diagnosis,not coded/not installed,
IDE05434-MAS02248,Rear entry light-Signal state,Measured value not available,
IDE05434-MAS03873,Rear entry light-Duty cycle,0.00, %
IDE05434-MAS04150,Rear entry light-Side,NOT-DEFINED,
IDE05434-MAS04351,Rear entry light-Connector terminal number,0,
IDE05434-MAS04352,Rear entry light-Connector number,not coded/not installed,
IDE05533,Spray nozzle heater,not active,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded/not installed,
IDE05719-MAS02339,Window washer system-Windshield washer system,not active,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05720-IDE04214,Front driver side door status-Key switch in door lock,Not operated,
IDE05720-MAS06256,Front driver side door status-Status door lock,Signal from door lock: released,
IDE05722-IDE02589,Door status: driver side rear-Rotary latch status,closed,
IDE05722-IDE04213,Door status: driver side rear-Central locking button,not coded/not installed,
IDE05722-MAS06256,Door status: driver side rear-Status door lock,Signal from door lock: released,
IDE05727-IDE02589,Front passenger side door status-Rotary latch status,closed,
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,Not operated,
IDE05727-MAS06256,Front passenger side door status-Status door lock,Signal from door lock: released,
IDE05729-IDE02589,Door status: frt. pass. side rear-Rotary latch status,closed,
IDE05729-IDE04213,Door status: frt. pass. side rear-Central locking button,not coded/not installed,
IDE05729-MAS06256,Door status: frt. pass. side rear-Status door lock,Signal from door lock: released,
IDE05730-MAS01737,Luggage compartment light-Diagnosis,not coded/not installed,
IDE05730-MAS02248,Luggage compartment light-Signal state,Measured value not available,
IDE05730-MAS03873,Luggage compartment light-Duty cycle,0.00, %
IDE05730-MAS04351,Luggage compartment light-Connector terminal number,0,
IDE05730-MAS04352,Luggage compartment light-Connector number,not coded/not installed,
IDE05739-MAS01737,Footwell light-Diagnosis,normal,
IDE05739-MAS02248,Footwell light-Signal state,not active,
IDE05739-MAS03873,Footwell light-Duty cycle,0.0, %
IDE05739-MAS04351,Footwell light-Connector terminal number,72,
IDE05739-MAS04352,Footwell light-Connector number,Plug C,
IDE05742-IDE02515,Light switch position-Low beam,not activated,
IDE05742-IDE05323,Light switch position-Fog light,not activated,
IDE05742-IDE07956,Light switch position-redundant signal line,OFF,
IDE05742-MAS00063,Light switch position-OFF,operated,
IDE05742-MAS02462,Light switch position-Automatic high beam assist,not activated,
IDE05742-MAS03835,Light switch position-Parking light,not activated,
IDE05742-MAS03836,Light switch position-Rear fog light,not coded/not installed,
IDE05822-MAS01632,DWA Vehicle inclination sensor-Status,not coded/not installed,
IDE05822-MAS04508,DWA Vehicle inclination sensor-Alarm detected,not coded/not installed,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not coded/not installed,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Alarm horn for anti-theft warning system,not coded/not installed,
IDE05829-ENG28562,Rear spoiler history data-Spoiler_Activation_Trigger,NoEntry,
IDE05829-ENG28563,Rear spoiler history data-Spoiler_Activation_Trigger_Date,0,
IDE05829-ENG28565,Rear spoiler history data-Spoiler_Activation_Trigger_Milage,0, km
IDE05829-ENG28564,Rear spoiler history data-Spoiler_Activation_Trigger_Time,0,
IDE05830-MAS02282,Rear Spoiler-Position,Unknown (65534),
IDE05830-ENG115793,Rear Spoiler-Spoiler_Button,not coded/not installed,
IDE05830-ENG115792,Rear Spoiler-Spoiler_Cycle_Protection,not coded/not installed,
IDE05830-ENG115794,Rear Spoiler-Spoiler_Indication_Light,not coded/not installed,
IDE05830-ENG115791,Rear Spoiler-Spoiler_Position,not coded/not installed,
IDE05833-MAS00106,Anti-theft warning system: history data-Year,2000,
IDE05833-MAS00107,Anti-theft warning system: history data-Month,0,
IDE05833-MAS00108,Anti-theft warning system: history data-Day,0,
IDE05833-MAS00109,Anti-theft warning system: history data-Hours,0,
IDE05833-MAS00110,Anti-theft warning system: history data-Minutes,0,
IDE05833-MAS00111,Anti-theft warning system: history data-Seconds,0,
IDE05833-MAS00711,Anti-theft warning system: history data-Odometer reading,0, km
IDE05833-MAS04478,Anti-theft warning system: history data-Cause for alarm activation,No alarm,
IDE05834-IDE01718,Driver info-Crash signal,not active,
IDE05834-MAS00211,Driver info-Insufficient brake fluid,not active,
IDE05834-MAS00212,Driver info-Insufficient washer fluid,not active,
IDE05834-MAS00213,Driver info-Insufficient coolant,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not coded/not installed,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,0,
IDE05836-MAS03638,Rain recognition sensor-Wipe speed,0,
IDE05836-MAS04806,Rain recognition sensor-Splash,not active,
IDE05836-MAS04807,Rain recognition sensor-park position,active,
IDE05837,Activation for signal horn,not active,
IDE05838-MAS01794,Light recognition sensor-Freeway,OFF,
IDE05838-MAS02248,Light recognition sensor-Signal state,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,41600, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,6126, lx
IDE05838-MAS04808,Light recognition sensor-Rain,OFF,
IDE05838-MAS04809,Light recognition sensor-Darkness,OFF,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,OFF,
IDE05839-MAS01737,Parking light-Diagnosis,normal,
IDE05839-MAS02248,Parking light-Signal state,active,
IDE05839-MAS03873,Parking light-Duty cycle,100.0, %
IDE05839-MAS04351,Parking light-Connector terminal number,10,
IDE05839-MAS04352,Parking light-Connector number,Plug B,
IDE05841-MAS06441,Central locking history data-Control-section / cause,Remote control,
IDE05841-MAS07519,Central locking history data-Command,Unlocking of entire vehicle,
IDE05841-MAS07942,Central locking history data-Additional information,Rem. ctrl. no. 2,
IDE05841-ENG29969,Central locking history data-command_direction_locking,No_locking,
IDE05841-ENG29970,Central locking history data-command_direction_unlocking,Door unlock,
IDE05842-MAS00218,Comfort function history data-Driver door,active,
IDE05842-MAS00219,Comfort function history data-Front Passenger Door,active,
IDE05842-MAS00220,Comfort function history data-Left rear door,active,
IDE05842-MAS00221,Comfort function history data-Right rear door,active,
IDE05842-MAS06441,Comfort function history data-Control-section / cause,KESSY: driver door,
IDE05842-MAS07560,Comfort function history data-Top,not active,
IDE05842-MAS07561,Comfort function history data-Sun roof/tilt roof,active,
IDE05842-MAS07941,Comfort function history data-Operating command,Close,
IDE06012-MAS01737,Search lights-Diagnosis,normal,
IDE06012-MAS02248,Search lights-Signal state,not active,
IDE06012-MAS03873,Search lights-Duty cycle,0.0, %
IDE06012-MAS04351,Search lights-Connector terminal number,62,
IDE06012-MAS04352,Search lights-Connector number,Plug C,
IDE06012-MAS15156,Search lights-terminal,Variant A,
IDE06091-IDE01440,Humidity sensor: internal-Windshield temperature,-38.4, °C
IDE06091-MAS04629,Humidity sensor: internal-Sensor temperature,38.5, °C
IDE06091-MAS04630,Humidity sensor: internal-Relative humidity,10.5, %
IDE06091-MAS04647,Humidity sensor: internal-Dew point,-39.0, °C
IDE06096-IDE03111,Interior lighting-Interior light,0, %
IDE06096-IDE05724,Interior lighting-Terminal 58xt dimmer,100.0, %
IDE06096-IDE05725,Interior lighting-Terminal 58xs dimmer,0.0, %
IDE06096-IDE05726,Interior lighting-Terminal 58xd dimmer,100.0, %
IDE06096-MAS01634,Interior lighting-Supply voltage,85.5, %
IDE06096-MAS04528,Interior lighting-Instrument panel and switch illumination dimmer switch,100, %
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,not coded/not installed,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,not coded/not installed,
IDE06470-MAS01737,Ambience lighting-Diagnosis,not coded/not installed,
IDE06470-MAS02248,Ambience lighting-Signal state,Measured value not available,
IDE06470-MAS03873,Ambience lighting-Duty cycle,0.0, %
IDE06470-MAS04351,Ambience lighting-Connector terminal number,0,
IDE06470-MAS04352,Ambience lighting-Connector number,not coded/not installed,
IDE06507-MAS13127,Button in center console-Status of button 1,not activated,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,OFF,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded/not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded/not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,not coded/not installed,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,not coded/not installed,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded/not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded/not installed,
IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
IDE06644-IDE06864,Vehicle positioning system-Daytime running lights,not coded/not installed,
IDE06644-MAS01288,Vehicle positioning system-Signal horn,not coded/not installed,
IDE06644-MAS03834,Vehicle positioning system-Emergency signal flashing,not coded/not installed,
IDE06644-MAS03835,Vehicle positioning system-Parking light,not coded/not installed,
IDE06649-MAS05016,Radio-frequency transmitter-Receiver status,not installed,
IDE06649-MAS05048,Radio-frequency transmitter-Number of transmitters adapted,0,
IDE06649-ENG116085,Radio-frequency transmitter-Kom.Schlüssel eFFB Handsender 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06649-ENG116115,Radio-frequency transmitter-Kom.Schlüssel eFFB Handsender 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06695-IDE01459,Energy management: last critical state-Energy management heat output control status,0,
IDE06695-MAS00107,Energy management: last critical state-Month,0,
IDE06695-MAS00108,Energy management: last critical state-Day,0,
IDE06695-MAS06555,Energy management: last critical state-Maximum switch-off priority while driving,0,
IDE06695-MAS06570,Energy management: last critical state-Number of critical operation cycles,0,
IDE06695-ENG28924,Energy management: last critical state-Anz_erreichte_Max_Freigaben,0,
IDE06695-ENG28921,Energy management: last critical state-Anz_krit_Betriebszyklen,0,
IDE06695-ENG28922,Energy management: last critical state-Bedingung_Tab_NQ,0,
IDE06695-ENG28920,Energy management: last critical state-min_prio_Tab_K,0,
IDE06695-ENG28919,Energy management: last critical state-min_prio_Tab_M,0,
IDE06695-ENG28923,Energy management: last critical state-min_prio_Tab_NQ,0,
IDE06695-ENG99063,Energy management: last critical state-Year,2000,
IDE06864-MAS01737,Daytime running lights-Diagnosis,normal,
IDE06864-MAS02248,Daytime running lights-Signal state,active,
IDE06864-MAS03873,Daytime running lights-Duty cycle,100.0, %
IDE06864-MAS04351,Daytime running lights-Connector terminal number,10,
IDE06864-MAS04352,Daytime running lights-Connector number,Plug B,
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,02,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,04,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Slave,
IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,Not Used,
IDE07145-MAS06782,Component protection properties-Master ECU Key,not administered by component protection,
IDE07145-MAS06785,Component protection properties-GFA key,used,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,Not Used,
IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
IDE07145-MAS07187,Component protection properties-KS Data version,01,
IDE07145-MAS09609,Component protection properties-Status IKA start key,not active,
IDE07145-MAS09610,Component protection properties-Status GFA Key,valid,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,stored,
IDE07187-MAS06538,Level control system sensor-Left Front Level Control System Sensor: PWM signal,655.35, %
IDE07187-MAS06539,Level control system sensor-Left Rear Level Control System Sensor: PWM signal,655.35, %
IDE07187-MAS06540,Level control system sensor-Left front level control system sensor: frequency,6553.5, Hz
IDE07187-MAS06541,Level control system sensor-Left Rear Left Control System Sensor: frequency,6553.5, Hz
IDE07187-MAS06542,Level control system sensor-Vehicle level sensor: supply voltage,65.535, V
IDE07344-IDE00542,Sunroof shade-Excessive temperature protection,not active,
IDE07344-IDE03114,Sunroof shade-Comfort function,not active,
IDE07344-MAS01979,Sunroof shade-Adapting,Not adapted,
IDE07344-MAS02282,Sunroof shade-Position,0, %
IDE07344-MAS02447,Sunroof shade-Release,not active,
IDE07344-MAS03656,Sunroof shade-Reverse,not active,
IDE07344-MAS05563,Sunroof shade-Norming,not normed,
IDE07345-MAS07997,Sunroof front closed position switch-Rotary switch activation,Implausible,
IDE07345,Sunroof front closed position switch,not activated,
IDE07345-ENG122183,Sunroof front closed position switch-rotary_switch_position,closed,
IDE07346,Sunroof shade switches,not activated,
IDE08125-MAS01458,Left cabin heater-Operating condition,not coded/not installed,
IDE08125-MAS06651,Left cabin heater-PTC heater element: current consumption,Unknown (254),
IDE08125-MAS06652,Left cabin heater-Blower motor: speed,Unknown (254),
IDE08125-MAS06653,Left cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS01458,Right cabin heater-Operating condition,not coded/not installed,
IDE08126-MAS06651,Right cabin heater-PTC heater element: current consumption,not coded/not installed,
IDE08126-MAS06652,Right cabin heater-Blower motor: speed,Unknown (254),
IDE08126-MAS06653,Right cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08177-MAS06456,Central locking-Autolock,not active,
IDE08177-MAS06740,Central locking-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking-Status exterior skin,closed,
IDE08177-MAS09896,Central locking-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking-Act. condition: Status central locking safe,not active,
IDE08177-MAS09900,Central locking-Spec. condition: Status central lock,Signal from door lock: released,
IDE08177-MAS13126,Central locking-Luggage hold closure,not coded/not installed,
IDE08211-MAS00106,History data control module reset-Year,0,
IDE08211-MAS00107,History data control module reset-Month,0,
IDE08211-MAS00108,History data control module reset-Day,0,
IDE08211-MAS00109,History data control module reset-Hours,0,
IDE08211-MAS00110,History data control module reset-Minutes,0,
IDE08211-MAS03129,History data control module reset-Reset counter,9,
IDE08211-MAS06734,History data control module reset-last cause of reset,Analysis 1,
IDE08343,Immobilizer Challenge,EF 50 1A 17,
IDE08949-MAS07867,Operating current: light driver-Conn. pin 0,0, mA
IDE08949-MAS07868,Operating current: light driver-Conn. pin 1,0, mA
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,20, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,20, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,290, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,300, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,0, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,0, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,0, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,0, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,0, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,0, mA
IDE08949-MAS07881,Operating current: light driver-Conn. pin 14,0, mA
IDE08949-MAS07882,Operating current: light driver-Conn. pin 15,0, mA
IDE08949-MAS07883,Operating current: light driver-Conn. pin 16,0, mA
IDE08949-MAS07884,Operating current: light driver-Conn. pin 17,0, mA
IDE08949-MAS07885,Operating current: light driver-Conn. pin 18,0, mA
IDE08949-MAS07886,Operating current: light driver-Conn. pin 19,0, mA
IDE08949-MAS07887,Operating current: light driver-Conn. pin 20,0, mA
IDE08949-MAS07888,Operating current: light driver-Conn. pin 21,0, mA
IDE08949-MAS07889,Operating current: light driver-Conn. pin 22,0, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,0, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,0, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,0, mA
IDE08949-MAS07893,Operating current: light driver-Conn. pin 26,0, mA
IDE08949-MAS07894,Operating current: light driver-Conn. pin 27,0, mA
IDE08949-MAS07895,Operating current: light driver-Conn. pin 28,0, mA
IDE08949-MAS07896,Operating current: light driver-Conn. pin 29,0, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,0, mA
IDE08949-MAS07898,Operating current: light driver-Conn. pin 31,0, mA
IDE08949-MAS07899,Operating current: light driver-Conn. pin 32,0, mA
IDE08949-MAS07900,Operating current: light driver-Conn. pin 33,0, mA
IDE08949-MAS07901,Operating current: light driver-Conn. pin 34,0, mA
IDE09065-MAS07964,Status: remote start-Engine run time after remote start,0, s
IDE09065-MAS16464,Status: remote start-Number of RemoteStarts carried out,0,
IDE09850-MAS07146,Garage Door Opener Operating Unit-Button 1,not coded/not installed,
IDE09850-MAS07147,Garage Door Opener Operating Unit-Button 2,not coded/not installed,
IDE09850-MAS07148,Garage Door Opener Operating Unit-Button 3,not coded/not installed,
IDE11134-IDE01943,Light sequence HU test result-Turn signal,Installed: not active,
IDE11134-IDE02515,Light sequence HU test result-Low beam,Installed: not active,
IDE11134-IDE02614,Light sequence HU test result-Reversing light switch,Installed: not active,
IDE11134-IDE02743,Light sequence HU test result-High Beam,Installed: not active,
IDE11134-IDE03310,Light sequence HU test result-Brake light,Installed: not active,
IDE11134-IDE03638,Light sequence HU test result-static AFS light,Installed: not active,
IDE11134-IDE05323,Light sequence HU test result-Fog light,Installed: not active,
IDE11134-IDE05839,Light sequence HU test result-Parking light,not installed / not active,
IDE11134-IDE06470,Light sequence HU test result-Ambience lighting,not installed / not active,
IDE11134-IDE06864,Light sequence HU test result-Daytime running lights,Installed: not active,
IDE11134-MAS02354,Light sequence HU test result-Headlamp flasher,Installed: not active,
IDE11134-MAS03835,Light sequence HU test result-Parking light,Installed: not active,
IDE11134-MAS03836,Light sequence HU test result-Rear fog light,not installed / not active,
IDE11134-MAS11025,Light sequence HU test result-Status,no restriction,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,327670, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,327670, W/m²
IDE11668-MAS06256,Driver side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11668-MAS06431,Driver side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11668-MAS06433,Driver side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11669-MAS06256,Passenger side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11669-MAS06431,Passenger side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11669-MAS06433,Passenger side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11670-MAS06256,Rear wing door: central locking signals-Status door lock,not coded/not installed,
IDE11670-MAS06431,Rear wing door: central locking signals-Door contact switch,not coded/not installed,
IDE11670-MAS06433,Rear wing door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11727-IDE04806,Function of the central console button-Driving profile selection button,LED installed,
IDE11727-MAS13125,Function of the central console button-Function of button 1,Start-stop,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded/not installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,not coded/not installed,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded/not installed,
IDE11943-MAS01737,Signature light-Diagnosis,not coded/not installed,
IDE11943-MAS02248,Signature light-Signal state,Measured value not available,
IDE11943-MAS03873,Signature light-Duty cycle,0.0, %
IDE11943-MAS04351,Signature light-Connector terminal number,0,
IDE11943-MAS04352,Signature light-Connector number,not coded/not installed,
IDE11999-IDE03853,High values of headlight range adjustment: basic setting-Left front level control system sensor: height value adapted,-100.0,
IDE11999-IDE04143,High values of headlight range adjustment: basic setting-Left rear level control system sensor: height value adapted,-100.0,
IDE12060,Headlight range adjustment counter,00 00 00 00,
IDE12212,Cause control module incorrectly coded,Not Present,
IDE12940-IDE01268,Lever functions of the steering column electronics-Windshield wiper,not activated,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,not activated,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear Window Wiper,not activated,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,not activated,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,not activated,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,not activated,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,not activated,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,No malfunction detected,
IDE12940-MAS01288,Lever functions of the steering column electronics-Signal horn,not activated,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,Stage 1,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,not activated,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,not activated,
IDE12940,Lever functions of the steering column electronics,not activated,
IDE14095-MAS17564,Wiper park position heater-Relay actuation,not coded/not installed,
IDE14110-MAS17842,Digital Key-NFC control section,not coded/not installed,
IDE14110-MAS17843,Digital Key-Bluetooth control section,not coded/not installed,
IDE14172-MAS03692,Remote key movement information-Key 1,not inoperative,
IDE14172-MAS03693,Remote key movement information-Key 2,not inoperative,
IDE14172-MAS03694,Remote key movement information-Key 3,not inoperative,
IDE14172-MAS03695,Remote key movement information-Key 4,not inoperative,
IDE14963-MAS19705,Remote start: current operating parameters-Captcha List,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE14963-MAS19706,Remote start: current operating parameters-Communication key,00 00 00 00 00 00 00 00,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06650,Head area heater-Right front occupation status,not coded/not installed,
MAS00043-IDE00019,Supply voltage: Terminal 30-Voltage terminal 30,14.85, V
MAS00043-IDE05835,Supply voltage: Terminal 30-Supply voltage for central locking,14.90, V
MAS00043-IDE05967,Supply voltage: Terminal 30-Voltage terminal 30 left,14.90, V
MAS00043-IDE05968,Supply voltage: Terminal 30-Voltage terminal 30 right,14.90, V
MAS00043-IDE08734,Supply voltage: Terminal 30-Supply voltage for anti-theft alarm system,5.00, V
MAS00043-IDE08735,Supply voltage: Terminal 30-Supply voltage for seat heater,14.90, V
MAS00043-MAS00362,Supply voltage: Terminal 30-Battery voltage,5.00, V
MAS00043-MAS07472,Supply voltage: Terminal 30-Battery voltage BEM,14.95, V
MAS00043-MAS07473,Supply voltage: Terminal 30-Test voltage rear window defogger,0.00, V
MAS00043-MAS07474,Supply voltage: Terminal 30-Test voltage windshield defogger,0.00, V
MAS00043-ENG119641,Supply voltage: Terminal 30-Messauswertung Pruefspannung Wischerablagenheizung,0.00, V
MAS00179-MAS04422,Brake Light Switch-Brake light signal via CAN,OFF,
MAS00179-MAS07313,Brake Light Switch-Brake light signal via HW,OFF,
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,12,
MAS00464-MAS00108,Standard - ambient data 1-Day,20,
MAS00464-MAS00109,Standard - ambient data 1-Hours,12,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,41,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,34,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,1,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,31, km
MAS00829-MAS00244,Access and start authorization-Awakening wire,not activated,
MAS00829-MAS01763,Access and start authorization-Signal Strength,-60,
MAS00829-MAS07866,Access and start authorization-Duration: last awakening wire actua.,0, ms
MAS01281-MAS01737,Back-up light-Diagnosis,normal,
MAS01281-MAS02248,Back-up light-Signal state,not active,
MAS01281-MAS03873,Back-up light-Duty cycle,0.0, %
MAS01281-MAS04351,Back-up light-Connector terminal number,11,
MAS01281-MAS04352,Back-up light-Connector number,Plug C,
MAS01431-IDE01442,Vehicle key with remote control-Pressing a button,not activated,
MAS01431-IDE01839,Vehicle key with remote control-Battery charge condition,Not available,
MAS01431-MAS00077,Vehicle key with remote control-Immobilizer,OK,
MAS01431-MAS01551,Vehicle key with remote control-Key number,255,
MAS01431-MAS05048,Vehicle key with remote control-Number of transmitters adapted,2,
MAS01431-MAS06362,Vehicle key with remote control-Code in detection area,Not available,
MAS01490-IDE02744,Energy management-Steering wheel heater,Enabled,
MAS01490-IDE04216,Energy management-Mirror heater,Enabled,
MAS01490-IDE80251,Energy management-Head area heater,not coded/not installed,
MAS01490-MAS01535,Energy management-Rear window defogger,Enabled,
MAS01490-MAS01563,Energy management-Auxiliary Air Heater,not coded/not installed,
MAS01490-MAS01564,Energy management-Windshield defogger,not coded/not installed,
MAS01490-MAS01632,Energy management-Status,not active,
MAS01490-MAS02390,Energy management-Shutoff,9,
MAS01490-MAS05795,Energy management-Rear seat heater,Enabled,
MAS01490-MAS05796,Energy management-Emergency shut-down,0,
MAS01490-MAS05887,Energy management-Battery cut out relay 2,not enabled,
MAS01490-MAS06551,Energy management-Seat ventilation,not coded/not installed,
MAS01490-MAS06552,Energy management-Seat heater front,Enabling stage 3,
MAS01490-MAS06553,Energy management-Display consumer switch-off,not active,
MAS01490-MAS06554,Energy management-Switch-off priority while driving,0,
MAS01490-MAS06555,Energy management-Maximum switch-off priority while driving,0,
MAS01490-MAS06556,Energy management-Switch-off with voltage drops,0,
MAS01490-MAS06557,Energy management-Switch-off priority with vehicle crash,0,
MAS01490-MAS06558,Energy management-Current negative charge balance,0, %
MAS01490-MAS06559,Energy management-Switch-off priority with engine off,0,
MAS01490-MAS06560,Energy management-Short distance drive,1,
MAS01597-IDE00542,Sunroof-Excessive temperature protection,not active,
MAS01597-IDE03114,Sunroof-Comfort function,not active,
MAS01597-MAS01979,Sunroof-Adapting,Not adapted,
MAS01597-MAS02282,Sunroof-Position,0, %
MAS01597-MAS02447,Sunroof-Release,not active,
MAS01597-MAS03656,Sunroof-Reverse,not active,
MAS01597-MAS05563,Sunroof-Norming,not normed,
MAS01597-MAS05737,Sunroof-Position,Tilt out posi.,
MAS03835-MAS01737,Parking light-Diagnosis,normal,
MAS03835-MAS02248,Parking light-Signal state,active,
MAS03835-MAS03873,Parking light-Duty cycle,100.0, %
MAS03835-MAS04351,Parking light-Connector terminal number,10,
MAS03835-MAS04352,Parking light-Connector number,Plug B,
MAS03836-MAS01737,Rear fog light-Diagnosis,not coded/not installed,
MAS03836-MAS02248,Rear fog light-Signal state,Measured value not available,
MAS03836-MAS03873,Rear fog light-Duty cycle,0.0, %
MAS03836-MAS04351,Rear fog light-Connector terminal number,0,
MAS03836-MAS04352,Rear fog light-Connector number,not coded/not installed,
MAS07959-IDE00787,Remote start history data-Cause for cancellation,no reason for cancellation,
MAS07959-MAS00107,Remote start history data-Month,15,
MAS07959-MAS00108,Remote start history data-Day,31,
MAS07959-MAS00109,Remote start history data-Hours,31,
MAS07959-MAS00110,Remote start history data-Minutes,63,
MAS07959-MAS07960,Remote start history data-Stop or cancel cause,No reason for prevention,
MAS08202-MAS09607,CAN p locked-Switch p locked,Engaged and locked,
MAS08202-MAS09608,CAN p locked-SMLS p locked plausibility,Implausible,
MAS08228-MAS01632,Light sensor-Status,not coded/not installed,
MAS08228-MAS02851,Light sensor-Brightness,22860, lx
MAS08228-MAS04121,Light sensor-Voltage,25.4, V
MAS13141,Test voltage,0, V
MAS18843-MAS00106,SE references from last used digital key devices-Year,0,
MAS18843-MAS00107,SE references from last used digital key devices-Month,0,
MAS18843-MAS00108,SE references from last used digital key devices-Day,0,
MAS18843-MAS00109,SE references from last used digital key devices-Hours,0,
MAS18843-MAS00110,SE references from last used digital key devices-Minutes,0,
MAS18843-ENG119380,SE references from last used digital key devices-km_Stand,1048574,
MAS18843-ENG118445,SE references from last used digital key devices-Secure_element_reference,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS18843-ENG118320,SE references from last used digital key devices-Secure_element_reference_state,invalid,
ENG116910,Control unit internal measured value (supplier),31 39 30 30 30 30 31 39 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG117285-ENG115839,Cycle_Protection_Counter-central_locking_cycle_protection_counter,0,
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,1,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,gueltiges Funktelegramm,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,0, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,0, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,0,
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,0,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,0,
ENG117286-ENG116724,Kopfraumheizung_Entwicklung-KRH_l_Error,not coded/not installed,
ENG117286-ENG116725,Kopfraumheizung_Entwicklung-KRH_l_Error_Gueltigkeit,not coded/not installed,
ENG117286-ENG116723,Kopfraumheizung_Entwicklung-KRH_l_Luefter_Error,not coded/not installed,
ENG117286-ENG116727,Kopfraumheizung_Entwicklung-KRH_l_PTC_Error,not coded/not installed,
ENG117286-ENG116726,Kopfraumheizung_Entwicklung-KRH_l_ResponseError,not coded/not installed,
ENG117286-ENG116730,Kopfraumheizung_Entwicklung-KRH_r_Error,not coded/not installed,
ENG117286-ENG116731,Kopfraumheizung_Entwicklung-KRH_r_Error_Gueltigkeit,not coded/not installed,
ENG117286-ENG116728,Kopfraumheizung_Entwicklung-KRH_r_Luefter_Error,not coded/not installed,
ENG117286-ENG116729,Kopfraumheizung_Entwicklung-KRH_r_PTC_Error,not coded/not installed,
ENG117286-ENG116732,Kopfraumheizung_Entwicklung-KRH_r_ResponseError,not coded/not installed,
ENG116008-IDE10662,light_swich_module-Light switch (button module),not coded/not installed,
ENG116008-MAS17838,light_swich_module-Exterior lighting: global shutoff,not coded/not installed,
ENG116909-ENG107391,LIN activity-LIN 1,active,
ENG116909-ENG107392,LIN activity-LIN 2,not coded/not installed,
ENG116909-ENG114948,LIN activity-LIN 3,not coded/not installed,
ENG116909-ENG114949,LIN activity-LIN 4,not coded/not installed,
ENG116909-ENG114950,LIN activity-LIN 5,not coded/not installed,
ENG116909-ENG114951,LIN activity-LIN 6,active,
ENG116793,Monitor 1,00 00 00 00 00 00 00 00,
ENG116802,Monitor 10,00 00 00 00 00 00 00 00,
ENG116794,Monitor 2,00 00 00 00 00 00 00 00,
ENG116795,Monitor 3,00 00 00 00 00 00 00 00,
ENG116796,Monitor 4,00 00 00 00 00 00 00 00,
ENG116797,Monitor 5,00 00 00 00 00 00 00 00,
ENG116798,Monitor 6,00 00 00 00 00 00 00 00,
ENG116799,Monitor 7,00 00 00 00 00 00 00 00,
ENG116800,Monitor 8,00 00 00 00 00 00 00 00,
ENG116801,Monitor 9,00 00 00 00 00 00 00 00,
ENG128380,Parametermonitor_0,82 14 64 64 A0 78 00 00 00 00 00 00 00 00 00 00 50 50 32 32 00 50 50 50 50 50 50 50 50 00 00 64 3C 01 21 21 0A 04 00 00 1E 0A 1E 1E 03 07 00 00 06 06 28 00 3C 03 1E 22 00 04 19 05 00 01 01 28 00 02 00 02 1E 64 05 B4 1E 32 00 00 00 00 26 1D 5A 96 02 05 0A 6E 96 05 00 00 00 00 00 00 00 00 0A 1E 3C 42 0F 00 00 00 00 00 00 00 00 00 00 00 64 0A 01 00 00 00 00 00 00 00 00 00 00 00 00 00 63 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 5A 19 E1 32 01 0A 00 00 00 00 00 A0 00 00 00 A0 00 00 00 A0 06 0C 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116806,Parametermonitor_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 00 64 64 64 64 64 64 64 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 14 00 46 7E 7F 46 46 7E 46 46 46 7F 46 46 46 46 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG130145,Parametermonitor_10,00 5A 00 F0 05 05 05 2D 0F 32 32 0A 01 2C 14 01 03 0A 0A 05 01 02 05 01 09 00 9E 02 BC 5F 4B 41 06 9A 86 00 32 00 01 00 01 02 08 04 05 05 05 06 03 09 0A 07 07 FF FF FF 01 02 02 03 03 04 05 05 05 FF 01 01 01 01 01 01 01 01 01 FF 01 01 01 01 01 01 01 01 01 FF 02 01 03 03 04 06 07 05 FF FF 01 02 03 03 03 04 05 06 07 FF 00 00 00 00 00 00 28 12 10 0E 0C 0A 06 04 00 00 19 16 15 18 16 1D 15 16 14 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116807,Parametermonitor_2,0F 05 0A 00 16 00 00 14 28 14 00 14 32 5A 32 0A 1E 12 00 4B 0A 01 1E 5A 0F 3C 3C 05 0A 01 0A 78 00 FA 01 1C 00 0F 00 05 0A 14 03 02 00 19 64 00 64 1E 32 18 18 7D 28 05 28 28 7D 3C 3C 7D 7D 0A 19 3C 7D 2B 00 00 02 00 00 01 28 0A 28 19 0A 23 04 C8 FA 17 16 88 00 1E 05 00 01 C8 32 C8 14 00 5A 03 00 03 03 00 00 04 01 05 32 32 32 64 03 00 00 00 00 00 22 00 08 00 00 00 00 00 00 00 00 00 0F 14 50 78 32 3C 02 58 00 00 0A 6E 05 64 28 00 0A 06 05 02 0A 28 00 00 00 00 00 00 00 00 00 00 14 14 14 00 32 00 00 00 00 28 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 14 14 C8 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115827,Parametermonitor_3-parameter_monitor_3_climatic,FF 02 32 00 3C FF 80 05 05 00 00 00 00 00 00 00 80 FF 02 32 3C 00 05 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 FF 02 05 00 00 00 00 00 00 00 00 00 00 00 00 02 0A 28 0F 1E 06 32 0A 34 0B 01 64 64 03 0A 05 01 0A 46 00 1E 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 18 14 14 78 14 06 00 00 00 00,
ENG116808-ENG115828,Parametermonitor_3-parameter_monitor_3_wiper,0A 00 00 19 19 00 03 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 50 46 00 58 8B FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116809,Parametermonitor_4,04 04 14 1E 03 B4 00 0A 05 05 0A 4B 4B 32 0A 03 00 1E 32 05 14 00 00 00 00 00 00 00 00 00 00 00 01 02 02 01 0A 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 04 0C 78 04 04 0C 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 3E 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 0A FF 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 0A 00 00 00 00 00 04 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 32 28 00 00 00 00 00 05 05 3C 04 01 01 01 01 96 01 01 C8 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FE FD FF 00 00 00 00 00 00 00 00 00 00 00 00 3C 14 37 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116810,Parametermonitor_5,0A 00 0C 08 09 0A 05 0A 0A 14 08 0A 03 00 0A 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 04 00 00 1E 0A 05 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 46 00 03 09 01 05 00 00 00 00 00 00 0A 0F 0F 00 00 60 06 16 06 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116811,Parametermonitor_6,00 46 32 FA 3C 00 1E 32 05 04 3C 00 08 05 01 00 01 00 00 00 05 0A 50 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116911,Parametermonitor_7,00 0A 00 0A 00 0A FF FF 00 0A 00 0A FF FF FF FF 0F A0 00 32 00 32 00 32 00 32 00 32 00 0A 00 0A 00 32 FF FE 00 0A 00 32 00 32 00 00 00 0A 00 0A 00 00 FF FF 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 0A 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116812,Parametermonitor_FF,00 00 05 30 30 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG126653-MAS00107,Personalized_Account_Key_History-Month,0,
ENG126653-MAS00108,Personalized_Account_Key_History-Day,0,
ENG126653-MAS00109,Personalized_Account_Key_History-Hours,0,
ENG126653-MAS00110,Personalized_Account_Key_History-Minutes,0,
ENG126653-MAS01551,Personalized_Account_Key_History-Key number,0,
ENG126653-ENG28771,Personalized_Account_Key_History-Account,0,
ENG126652-MAS03692,Personalized_key__Setting-Key 1,0,
ENG126652-MAS03693,Personalized_key__Setting-Key 2,0,
ENG126652-MAS03694,Personalized_key__Setting-Key 3,0,
ENG126652-MAS03695,Personalized_key__Setting-Key 4,0,
ENG126652-MAS03696,Personalized_key__Setting-Key 5,0,
ENG126652-MAS03697,Personalized_key__Setting-Key 6,0,
ENG126652-MAS03698,Personalized_key__Setting-Key 7,0,
ENG126654-MAS00107,Personalized_Signals-Month,0,
ENG126654-MAS00108,Personalized_Signals-Day,0,
ENG126654-MAS00109,Personalized_Signals-Hours,0,
ENG126654-MAS00110,Personalized_Signals-Minutes,0,
ENG126654-ENG30061,Personalized_Signals-Perso_Aktiv,0,
ENG126654-ENG28925,Personalized_Signals-Perso_Bedienstelle,0,
ENG126654-ENG28926,Personalized_Signals-Perso_Freigabe_Verstellung,0,
ENG126654-ENG28772,Personalized_Signals-Perso_Konto,0,
ENG126654-ENG28775,Personalized_Signals-Perso_Status,0,
ENG126654-ENG28773,Personalized_Signals-Perso_Steuerung,0,
ENG126654-ENG28774,Personalized_Signals-Perso_Steuerungs_parameter,0,
ENG116792-ENG115817,Power up history-Funktionsanforderung,10,
ENG130589-MAS16304,Remotestart_Monitor-Number of driver takeovers from RemoteStart,0,
ENG130589-MAS16305,Remotestart_Monitor-Number of duplicate activations,0,
ENG130589-MAS16306,Remotestart_Monitor-Number of incorrect takeovers,0,
ENG130589-MAS16307,Remotestart_Monitor-Average running time: group 1,0,
ENG130589-MAS16308,Remotestart_Monitor-Average running time: group 2,0,
ENG130589-MAS16309,Remotestart_Monitor-Average running time: group 3,0,
ENG130589-MAS16333,Remotestart_Monitor-Number of RemoteStarts,0,
ENG130589-MAS16334,Remotestart_Monitor-RemoteStart cancellations counter,0,
ENG116790-MAS00711,Supply voltage history-Odometer reading,17, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.0, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,14.9, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,14.9, V
ENG116791,Temperatures,11.00, °C
ENG127111-ENG127149,Valeo_Entwickler_MWB-Batterie_Spannung_KL_15,0.0, V
ENG127111-ENG127148,Valeo_Entwickler_MWB-Batterie_Spannung_KL_30,0.0, V
ENG127111-ENG127156,Valeo_Entwickler_MWB-GRA leitung,0,
ENG127111-ENG30013,Valeo_Entwickler_MWB-Historienspeicher im Fehlerfall,00 00 00 00 94 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG127111-ENG98652,Valeo_Entwickler_MWB-Horn,OFF,
ENG127111-ENG30027,Valeo_Entwickler_MWB-Lenkrad Heizung,0,
ENG127111-ENG30075,Valeo_Entwickler_MWB-Resetmonitor,0,
ENG127111-ENG127158,Valeo_Entwickler_MWB-U12V_SW2,0,
ENG127111-ENG30182,Valeo_Entwickler_MWB-WakeUp2,OFF,
Elapsed Time: 00:44
09 Adaptation:
;SW:5Q0-937-087-BG HW:5Q0-937-087-BA --- Cent. Elect.
;Component:BCM PQ37BOSCH 038 0303, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BodyContrModul1UDSBosc,020001,EV_BCMBOSCH_020_VW37.rod
;Friday,20,December,2019,12:42:21:14741
;VCDS Version: Beta 19.10.0 (x64) Data version: 20190930 DS316.0
;VCID: 81546E4EC18A13596615-80D4
IDE01550-Service position,178.999822 °,2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,active ,10
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage,not installed ,11
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv,-2.0 °C,11
IDE04927-ENG141962-Window heater-Waschduesenheizung,installed ,11
IDE04927-ENG154810-Window heater-window heating front activation time pause,320 s,11
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,active ,8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,active ,8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,activ ,8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,not installed ,8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,activ ,8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,8
IDE05145-Light configuration,0C 34 00 14 02 00 64 00 00 00 00 00 00 00 00 00 0C 3E 00 15 04 00 64 00 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 08 09 1A 12 06 9A 00 00 00 04 4C 00 4C 14 00 64 08 0A 1A 13 07 9A 00 00 00 01 3A 00 49 14 00 7F 06 00 80 08 09 7F 00 00 00 01 44 00 4B 14 00 7F 07 00 80 08 0A 7F 00 00 00 0B 36 00 1A 0B 00 64 00 00 00 00 00 00 00 00 00 0B 40 00 1B 0C 00 64 00 00 00 00 00 00 00 00 00 0A 37 00 1C 0D 0F 64 00 00 00 00 00 00 00 00 00 0A 41 00 1D 0E 0F 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00 ,224
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler,0 ,30
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,Heizmatten am BCM ,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,21.00 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,20.00 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,21.00 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,20.00 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.50 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.50 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,49.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,48.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,49.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,48.00 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Sollspannungsanforderung 14.7 ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.7 V,30
IDE06507-MAS13132-Button in center console-Function of button 3,not coded/not installed ,8
IDE07007-ENG249923-A/C heater function via remote control-pa_RSt_MOD_verbaut,installed ,8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start,installed ,8
IDE07007-ENG246992-A/C heater function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
IDE07356-Position during interval mode,40.999959 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit ,6
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19
IDE09731-ENG249826-Int. light: 2nd generation-Ambiente_Fahrprofil_Offroad_Individual,11 ,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,0 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,50 %,19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,50 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,50 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,50 %,19
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
IDE10298-Alternating park position 1,19.999980 °,2
IDE10299-Alternating park position 2,34.999965 °,2
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.20 ,256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,0.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.00 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000 ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000 ,256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000000 ,256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000 ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000 ,256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00000000 ,256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00000000 ,256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000000 ,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,0 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,0 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,0 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,0 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,70 %,256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,0 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,0 %,256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,0 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,0 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,0 %,256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,0 %,256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,0 %,256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,0 %,256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,0 %,256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,0 %,256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,0 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,70 %,256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,0 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,0 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,0 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,0 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,0 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,0 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,0 %,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.0 s,256
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,not installed ,3
IDE11944-ENG141948-Keyless access and start authorization-Kessy,installed ,3
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeber,active ,3
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,active ,3
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,3
IDE12302-SFT271873-Identification of sub-bus participant-Control Unit For Wiper Motor,Not available ,6
IDE12302-SFT271874-Identification of sub-bus participant-Rain Light Recognition Sensor,Not available ,6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch,Not available ,6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,Not available ,6
IDE12302-SFT271877-Identification of sub-bus participant-Garage Door Opener Operating Unit,Not available ,6
IDE12302-SFT271894-Identification of sub-bus participant-Sensor For Anti Theft Alarm System,Not available ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,Not available ,6
IDE12302-SFT271904-Identification of sub-bus participant-Sun Roof,Not available ,6
IDE12302-SFT271910-Identification of sub-bus participant-Ceiling Light Module,Not available ,6
IDE12302-SFT271928-Identification of sub-bus participant-Roof Blind,Not available ,6
IDE12302-SFT271947-Identification of sub-bus participant-Relative Air Humidity Interior Sender,Not available ,6
IDE12302-SFT271966-Identification of sub-bus participant-Neck Heating Left,Not available ,6
IDE12302-SFT271967-Identification of sub-bus participant-Neck Heating Right,Not available ,6
IDE12302-SFT272065-Identification of sub-bus participant-Seat Backrest Fan 1 Front Left,Not available ,6
IDE12302-SFT272067-Identification of sub-bus participant-Seat Cushion Fan 1 Front Left,Not available ,6
IDE12302-SFT272069-Identification of sub-bus participant-Seat Backrest Fan 1 Front Right,Not available ,6
IDE12302-SFT272071-Identification of sub-bus participant-Seat Cushion Fan 1 Front Right,Not available ,6
IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control,Not available ,6
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch,Not available ,6
MAS05055-lower turn position,42.999957 °,2
MAS05056-upper turn position,178.999822 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,2512 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 50 ,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4500 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,6000 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,2000 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active ,4
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,not active ,10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,not active ,10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,not active ,10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,10
ENG141649-ENG249932-Außenlicht_Blinker-Rollenmodusblinken,not active ,10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,not active ,10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,not active ,10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,10
ENG141649-ENG251922-Außenlicht_Blinker-Travel_Assist_Blinken,not active ,10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,not active ,10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,not active ,10
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max,120 min,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,not active ,10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,not active ,10
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren,not active ,9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,active ,9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active ,9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,limitieren ,9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht,Yes ,5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,not active ,5
ENG141656-ENG249813-Außenlicht_uebergreifend-ABL_Abschaltung_nach_ECE48_Rev6,No ,18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,abschaltbar über Energiemanagement ,18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,abschaltbar über Energiemanagement ,18
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf,0 ms,18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,automatic ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,not active ,18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,true ,18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,No ,18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht,Yes ,18
ENG141656-ENG249901-Außenlicht_uebergreifend-Licht_Schaltung_nach_ECE48_Rev6,not active ,18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,not installed ,18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,not active ,18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,not active ,18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,24 s,18
ENG141656-ENG249943-Außenlicht_uebergreifend-TFL_Abschaltung_nach_ECE48_Rev6,No ,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Sollspannungsanforderung 13.5 ,18
ENG246955-ENG246967-digital_key-central_locking_digital_key_general,not installed ,3
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle,not active ,3
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle,not active ,3
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246991-digital_key-pa_Two_Keys,not active ,3
ENG122934-erase_error_table,00 00 00 ,3
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,Basis ,6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,not active ,6
ENG141685-Front_wash_function,10 ,2
ENG141645-MAS00214-HW_Verbau-Brake pad wear,not installed ,8
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,100.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,100.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,100.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,83.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,67.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,50.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,33.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,17.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,64.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,64.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,64.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,64.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,57.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,50.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,42.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,27.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,22.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,15.0 %,30
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Warnblinktaster_Suchbeleuchtung ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,48 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,47 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,0 ,16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,00 ,16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,00 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,not active ,16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,not active ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,0 ,16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,00 ,16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,00 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,not active ,16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,not active ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,minimize ,16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,13 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,3D ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,13 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,35 - kombinierte LED Blink-Bremsleuchten ,16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,Blinken links Hellphase ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Blinken links Dunkelphase ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,minimize ,16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,13 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3E ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,23 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,35 - kombinierte LED Blink-Bremsleuchten ,16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,Blinken rechts Hellphase ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Blinken rechts Dunkelphase ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,35 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W ,16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,only_if_closed ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,36 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W ,16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,only_if_closed ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,54 ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,00 ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,32 - allgemeine LED bis 12W ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,32 - allgemeine LED bis 12W ,16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,minimize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,26 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,26 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Nebellicht links ,16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,Blinken links aktiv (beide Phasen) ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,89 ,16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,minimize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,26 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,26 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,Parking light right ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Nebellicht rechts ,16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,Blinken rechts aktiv (beide Phasen) ,16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,minimize ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,127 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Blinken links aktiv (beide Phasen) ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,minimize ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,127 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Blinken rechts aktiv (beide Phasen) ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right ,16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,100 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,11 - Abblendlicht ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,not active ,16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,100 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,11 - Abblendlicht ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,not active ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,10 - allgemeine Scheinwerfer ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,10 - allgemeine Scheinwerfer ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23 13 00 3D 18 02 64 03 00 80 08 00 0D 00 00 00 23 23 00 3E 18 04 64 05 00 80 08 00 0D 00 00 00 2A 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 20 0A 00 35 08 00 FF 00 00 00 00 00 00 00 00 00 20 1A 00 36 08 00 FF 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 54 08 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 20 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,25 00 00 48 08 00 7F 00 00 00 00 00 00 00 00 00 25 00 00 47 08 00 7F 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,100.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,0.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-101.5 ms,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,not installed ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,1.0 %,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,10.0 %/s,62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,1.00 s,62
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1,2.0 s,7
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang,10 s,7
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,7
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,7
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS,Nicht_verbaut ,7
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark,not active ,7
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze,100 m,7
ENG246957-ENG246981-Lichttaster-Lichttastermodul,lds ,7
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config,00000001 ,7
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle,30 km/h,7
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig,active ,7
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig,active ,7
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig,not active ,7
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,27
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,27
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,27
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,27
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,27
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,27
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,27
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,27
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,27
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.40 ,27
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,5 °C,27
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,18.0 %,27
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,27
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,27
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,27
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,27
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,34 °C,27
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,39 °C,27
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,44 °C,27
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,27
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,50 °C,27
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,0 ms,27
ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung,0 ms,27
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,27
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,27
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,27
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,30 s,27
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation,Always ,2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear Window Wiper,installed ,2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition key removal lock,not installed ,2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation,not installed ,2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,not installed ,2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,not installed ,2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,not installed ,2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2
ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation,not active ,2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,installed ,2
ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button,not installed ,2
ENG122979-ENG141953-Networking-Getriebesteuergeraet,installed ,8
ENG124714-ENG142044-OCU-DWA_push,active ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
ENG124714-ENG246970-OCU-IAA -Nutzer_management,not installed ,8
ENG124714-OCU-,installed ,8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via BAP / Fazit ,8
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,not active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_inactive ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Schluessel ,16
ENG249801-ENG249833-PKW-Schiebetueren-CAN_TSG_HBFS_verbaut,No ,4
ENG249801-ENG249834-PKW-Schiebetueren-CAN_TSG_HFS_verbaut,No ,4
ENG249801-ENG249925-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_nachverriegeln,No ,4
ENG249801-ENG249926-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_verbaut,No ,4
ENG249801-ENG249927-PKW-Schiebetueren-PKW_Schiebetuer_HFS_nachverriegeln,No ,4
ENG249801-ENG249928-PKW-Schiebetueren-PKW_Schiebetuer_HFS_verbaut,No ,4
ENG249801-ENG251921-PKW-Schiebetueren-SBT_Entr_im_Zustand_entriegelt,No ,4
ENG249801-ENG249939-PKW-Schiebetueren-STSG_HBFS_verbaut,No ,4
ENG249801-ENG249940-PKW-Schiebetueren-STSG_HFS_verbaut,No ,4
ENG249802-ENG249933-Rear_view_camera_wash-RVC_Speed_Hysteresis,5 km/h,8
ENG249802-ENG249934-Rear_view_camera_wash-RVC_Speed_max,50 km/h,8
ENG249802-ENG249935-Rear_view_camera_wash-RVC_Time_cleaning_Pumpe_active_BCM,1.5 s,8
ENG249802-ENG249936-Rear_view_camera_wash-RVC_Waschen_HMI,not active ,8
ENG249802-ENG249937-Rear_view_camera_wash-RVC_Wash,not installed ,8
ENG122927-RLS_close_glazing,2.0 s,1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
ENG115729-ENG249900-Scheinwerferreinigung-Init Versatz Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,active ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2000 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,800 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,800 ms,10
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,0 ms,48
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,0 ms,48
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,0 ms,48
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 s,48
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,0 ,48
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,0 ms,48
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,0 ms,48
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,0 ms,48
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,0 ms,48
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,0 s,48
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,0.0 s,48
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,0 s,48
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG,not installed ,4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,not active ,5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by convenience operation via remote control key ,5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,not active ,5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,not active ,5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,not active ,5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,not active ,5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,not active ,5
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,1000 ms,10
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,20.0 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,3.0 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,2 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 %,21
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,200 lx,12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,400 lx,12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,600 lx,12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,84 ,12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,166 ,12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,250 ,12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,370 ,12
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,active ,4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,active ,4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,installed ,4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,installed ,4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,CAN ,4
ENG141969-ENG249827-UGDO-Anlernblinken,not active ,3
ENG141969-ENG249832-UGDO-Bedienfeld,not installed ,3
ENG141969-ENG172987-UGDO-ugdo_transmitter,not installed ,3
ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable,not active ,3
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,active ,9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,nur wenn mind. 1 Raste zu ,9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,installed ,9
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar,not active ,9
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version,Version_1_2 ,9
ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation,5 ,8
ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold,30 s,8
ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation,180 s,8
ENG124901-Wischer_Fehlermaske_Mitsuba_Entw,0 bit,4
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30 ,3
ENG141651-ENG141957-ZV allgemein-Radio freq.,315MHz ,7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Einzeltuerentriegelung ,7
ENG141654-ENG116706-ZV Autolock-Autounlock NAR,active ,3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock,not active ,3
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,active ,4
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,not active ,7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,active ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Kontaktsteuerung mit Mindestansteuerzeit ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,not active ,8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen,not active ,8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,not active ,8
Elapsed Time: 02:09
17:
;SW:3G0-920-890-E HW:3G0-920-890-E --- Instruments
;Component:KOMBI 502 4192, Coding:08A420086788CF050288624B10010000A0000D07
;EV_DashBoardVDDMQBA0,001042,EV_DashBoardVDDMQBA0_VW37.rod
;Friday,20,December,2019,12:48:16:14741
;VCDS Version: Beta 19.10.0 (x64) Data version: 20190930 DS316.0
;VCID: AB08ECE613862909ECA9-80FE
Group,Description,Actual
IDE00019,Voltage terminal 30,14.9, V
IDE00021,Engine speed,801.00, /min
IDE00025,Coolant temperature,90.00, °C
IDE00075,Vehicle speed,0, km/h
IDE00191,Charge air pressure: actual value,0.00, %
IDE00196,Engine oil temperature,36, °C
IDE00301,Distance,31, km
IDE00310,Outside air temperature,11.0, °C
IDE00316-IDE00500,Time-Hour,12, H
IDE00316-IDE00501,Time-Minute,47, min
IDE00316-MAS00111,Time-Seconds,50, s
IDE00317-IDE00502,Date-Year,2019, yr
IDE00317-IDE00503,Date-Month,12, mon
IDE00317-IDE00504,Date-Day,20, d
IDE00323,Security Access: Number of invalid keys,0,
IDE00510,ESI: distance driven from inspection,31, km
IDE00511,ESI: time from inspection,119, d
IDE00512,ESI: minimum value km-driving distance/inspection,15000, km
IDE00513,ESI: maximum value km-driving distance/inspection,30000, km
IDE00514,ESI: maximum value of time between inspections,730, d
IDE00515,ESI: oil quality,poor oil quality,
IDE00517,ESI: soot entry,0, km
IDE00518,ESI: thermal load,200, km
IDE00520,Phototransistor,253,
IDE00695,ESI: service exceedance in km,0, km
IDE00696,ESI: service exceedance in days,0, d
IDE00697,ESI: remaining distance,16070, km
IDE00698,ESI: remaining running time,246, d
IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
IDE00819,Day counter,118, d
IDE00827,ESI: minimum value of time between inspections,365, d
IDE00843,Starting impulse recognized,No,
IDE00845-MAS03213,Wheel circ.-Average wheel circumference for trip distance,2205, mm
IDE00845-MAS03214,Wheel circ.-Maximum wheel circumference for speed,2205, mm
IDE00935,ESI: Theoretical service interval,15000, km
IDE01076,Time since ignition off,131068, s
IDE01153,SIA: maximum value of distance to service,16100, km
IDE01154,SIA: maximum value of time to service,365, d
IDE01285,Counter of component protection malfunctions,0,
IDE02307,Parking brake status,not activated,
IDE02486,Data logger triggering,not active,
IDE02642,Outside temp.: displayed value,10.5, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,FD,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,00,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,64,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,310,
IDE03349,FIX: Max. distance until next mileage-related inspection,32200, km
IDE03350,FIX: Maximum time until next time-dependent inspection,730, d
IDE03351,FIX: Distance covered since last mileage-dependent inspection,0, km
IDE03352,FIX: Time since last time-dependent inspection,119, d
IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
IDE03471-IDE03640,Vehicle configuration-Dynamic AFS light,Correct coding,
IDE03471-IDE03726,Vehicle configuration-Parallel Parking Assistance,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Dampening Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire pressure monitoring display,Correct coding,
IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring,Correct coding,
IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
IDE03471-MAS00809,Vehicle configuration-Electro-Mechanical Parking Brake Control Module,Correct coding,
IDE03471-MAS00811,Vehicle configuration-Active steering control module,Correct coding,
IDE03471-MAS00911,Vehicle configuration-All Wheel Drive (AWD),Correct coding,
IDE03471-MAS01091,Vehicle configuration-Automated manual transmission,Correct coding,
IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assistant,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Lock Electronics,Correct coding,
IDE03471-MAS02725,Vehicle configuration-Customer-specific function control module,Correct coding,
IDE03471-MAS03385,Vehicle configuration-Lane change assistance,Correct coding,
IDE03471-MAS04384,Vehicle configuration-Electrical steering column lock control module,Correct coding,
IDE03471-MAS05723,Vehicle configuration-Adaptive cruise control or reducing stopping distance,Correct coding,
IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer positioning assistant,Correct coding,
IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
IDE03471-MAS12422,Vehicle configuration-intelligent parking assistant,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,0.3, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,57.0, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,59.7, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,6.5, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,3.6, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,8.3, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,8.4, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,3.7, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,0.0, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,0.0, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,0.0, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,0.0, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,0.0, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,0.0, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,0.0, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,0.0, l
IDE03472-MAS03822,Volume after refueling-Last error status,0,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,0,
IDE03472-MAS03824,Volume after refueling-Third-last error status,0,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,0,
IDE03472-MAS06153,Volume after refueling-Last distance,0,
IDE03472-MAS06154,Volume after refueling-Penultimate distance,0,
IDE03472-MAS06155,Volume after refueling-Third to last distance,0,
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,0,
IDE03473-IDE00730,Fuel tank sens-Fuel level sensor 1 including soiling resistance,75, Ohm
IDE03473-IDE00731,Fuel tank sens-Fuel level sensor 2 including soiling resistance,65535, Ohm
IDE03473-IDE00732,Fuel tank sens-Fuel level sensor 1 soiling resistance,-2, Ohm
IDE03473-IDE00733,Fuel tank sens-Fuel level sensor 2 soiling resistance,-32768, Ohm
IDE03473-IDE03494,Fuel tank sens-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,Fuel tank sens-Fuel level sensor 3 soiling resistance,-32768, Ohm
IDE03473-IDE03496,Fuel tank sens-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,Fuel tank sens-Fuel level sensor 4 soiling resistance,-32768, Ohm
IDE03473-MAS03798,Fuel tank sens-Raw value sensor 1 resistor 1,1141,
IDE03473-MAS03799,Fuel tank sens-Raw value sensor 1 resistor 2,2368,
IDE03473-MAS03800,Fuel tank sens-Raw value sensor 2 resistor 1,65535,
IDE03473-MAS03801,Fuel tank sens-Raw value sensor 2 resistor 2,65535,
IDE03473-MAS03802,Fuel tank sens-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,Fuel tank sens-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,Fuel tank sens-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,Fuel tank sens-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,57.0, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,72, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,65535, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,56.6, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,0.0, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.0, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.0, l
IDE03474-MAS03826,Calculated volume-Quality sensor 1,10,
IDE03474-MAS03827,Calculated volume-Quality sensor 2,not installed,
IDE03474-MAS03828,Calculated volume-Quality sensor 3,not installed,
IDE03474-MAS03829,Calculated volume-Quality sensor 4,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,-56.6, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,-32768.0, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,-32768.0, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,-32768.0, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000, m/s
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000, m/s
IDE03474-ENG102894,Calculated volume-averaged_volume,56.6, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,56.6, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,56.6, l
IDE03474-ENG99553,Calculated volume-linking,0.0000000,
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.00000, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-0.00,
IDE03474-ENG101623,Calculated volume-reference_volume,56.9, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000, m/s
IDE03474-ENG99683,Calculated volume-version_of_application,133,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0024996,
IDE03475-MAS00216,Control button in instrument cluster-External button for daily distance driven,not active,
IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
IDE03477-IDE00500,GPS time-Hour,18, H
IDE03477-IDE00501,GPS time-Minute,34, min
IDE03477-IDE00501,GPS time-Minute,48, min
IDE03477-IDE00502,GPS time-Year,2019, yr
IDE03477-IDE00503,GPS time-Month,12, mon
IDE03477-IDE00504,GPS time-Day,20, d
IDE03477-MAS00111,GPS time-Seconds,6, s
IDE03477-MAS00111,GPS time-Seconds,59, s
IDE03477-MAS03493,GPS time-last synchronization year,2019, yr
IDE03506,Distance: high resolution,00 00 79 2A,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,FF FF FF FF,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,FF FF FF FF,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,FF FF FF FF,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,FF FF FF FF,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,FF FF FF FF,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,FF FF FF FF,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,FF FF FF FF,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,FF FF FF FF,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,FF FF FF FF,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,FF FF FF FF,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,FF FF FF FF,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,FF FF FF FF,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,FF FF FF FF,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-MAS01393,Service -interval- display: history 3-Block 4,FF FF FF FF,
IDE03913-MAS01394,Service -interval- display: history 3-Block 5,FF FF FF FF,
IDE03913-MAS01395,Service -interval- display: history 3-Block 6,FF FF FF FF,
IDE03913-MAS01396,Service -interval- display: history 3-Block 7,FF FF FF FF,
IDE03913-MAS01397,Service -interval- display: history 3-Block 8,FF FF FF FF,
IDE03913-MAS01398,Service -interval- display: history 3-Block 9,FF FF FF FF,
IDE03913-MAS01399,Service -interval- display: history 3-Block 10,FF FF FF FF,
IDE03913-MAS01400,Service -interval- display: history 3-Block 11,FF FF FF FF,
IDE03913-MAS01401,Service -interval- display: history 3-Block 12,FF FF FF FF,
IDE03913-MAS01402,Service -interval- display: history 3-Block 13,FF FF FF FF,
IDE03913-MAS01403,Service -interval- display: history 3-Block 14,FF FF FF FF,
IDE03913-MAS01404,Service -interval- display: history 3-Block 15,FF FF FF FF,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01390,Service -interval- display: history 4-Block 1,FF FF FF FF,
IDE03914-MAS01391,Service -interval- display: history 4-Block 2,FF FF FF FF,
IDE03914-MAS01392,Service -interval- display: history 4-Block 3,FF FF FF FF,
IDE03914-MAS01393,Service -interval- display: history 4-Block 4,FF FF FF FF,
IDE03914-MAS01394,Service -interval- display: history 4-Block 5,FF FF FF FF,
IDE03914-MAS01395,Service -interval- display: history 4-Block 6,FF FF FF FF,
IDE03914-MAS01396,Service -interval- display: history 4-Block 7,FF FF FF FF,
IDE03914-MAS01397,Service -interval- display: history 4-Block 8,FF FF FF FF,
IDE03914-MAS01398,Service -interval- display: history 4-Block 9,FF FF FF FF,
IDE03914-MAS01399,Service -interval- display: history 4-Block 10,FF FF FF FF,
IDE03914-MAS01400,Service -interval- display: history 4-Block 11,FF FF FF FF,
IDE03914-MAS01401,Service -interval- display: history 4-Block 12,FF FF FF FF,
IDE03914-MAS01402,Service -interval- display: history 4-Block 13,FF FF FF FF,
IDE03914-MAS01403,Service -interval- display: history 4-Block 14,FF FF FF FF,
IDE03914-MAS01404,Service -interval- display: history 4-Block 15,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE05931,FIX: Reset value for next mileage-dependent inspection,32200, km
IDE05932,FIX: Reset value for next time-dependent inspections,730, d
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,02,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,03,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,used,
IDE07145-MAS06782,Component protection properties-Master ECU Key,not administered by component protection,
IDE07145-MAS06785,Component protection properties-GFA key,used,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,Not Used,
IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS07187,Component protection properties-KS Data version,01,
IDE07145-MAS09609,Component protection properties-Status IKA start key,not active,
IDE07145-MAS09610,Component protection properties-Status GFA Key,valid,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,not stored,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08235-ENG118223,Status of immobilizer participant-ELV_State,00,
IDE08235-ENG118222,Status of immobilizer participant-GSG_State,00,
IDE08235-ENG118217,Status of immobilizer participant-Immobilizer_State,00,
IDE08235-ENG118216,Status of immobilizer participant-key_state,1C,
IDE08235-ENG118218,Status of immobilizer participant-MSG_1_State,F8,
IDE08235-ENG118219,Status of immobilizer participant-MSG_2_State,00,
IDE08235-ENG118220,Status of immobilizer participant-MSG_3_State,00,
IDE08235-ENG118221,Status of immobilizer participant-MSG_4_State,00,
IDE08236-ENG118224,Status locking periods immobilizer-blocking_time,00 00 00 00 00 00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 00 02,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,00 00 00 00,
IDE08239,Transponder ID Key 1,FD 06 B6 E0,
IDE08240,Transponder ID Key 2,0B F9 B5 E0,
IDE08251-IDE80258,Configuration immobilizer-Immobilizer status,00 00,
IDE08251-MAS01159,Configuration immobilizer-Version number,00,
IDE08251-MAS01483,Configuration immobilizer-Softwareversion,00 00 00,
IDE08251-MAS11095,Configuration immobilizer-cause:,00 00 00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,37 2D AA 4C,
IDE08343,Immobilizer Challenge,68 28 D0 43,
IDE12262-MAS14182,Virtual radio key: status-Master key coded,Yes,
IDE12262-MAS14183,Virtual radio key: status-Virtual radio key active,No,
IDE12262-MAS14184,Virtual radio key: status-Number of secure elements in the ticket table,00,
IDE12263,Virtual radio key: vehicle ID,DE 60 FC 62 ED 30 A8 B3 C6 03 0E 77 6B 87 7A 40,
IDE12264-MAS14185,Virtual radio key: ticket table-Ticket 1,01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14186,Virtual radio key: ticket table-Ticket 2,02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14187,Virtual radio key: ticket table-Ticket 3,03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14188,Virtual radio key: ticket table-Ticket 4,04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14189,Virtual radio key: ticket table-Ticket 5,05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14190,Virtual radio key: ticket table-Ticket 6,06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14191,Virtual radio key: ticket table-Ticket 7,07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14192,Virtual radio key: ticket table-Ticket 8,08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14193,Virtual radio key: ticket table-Ticket 9,09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14194,Virtual radio key: ticket table-Ticket 10,0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14195,Virtual radio key: ticket table-Ticket 11,0B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14196,Virtual radio key: ticket table-Ticket 12,0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14197,Virtual radio key: ticket table-Ticket 13,0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14198,Virtual radio key: ticket table-Ticket 14,0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14199,Virtual radio key: ticket table-Ticket 15,0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14200,Virtual radio key: ticket table-Ticket 16,10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12265-MAS06854,Virtual radio key: check sum-Version,C1,
IDE12265-MAS06879,Virtual radio key: check sum-Checksum,E9 6C A1 77,
IDE14186-MAS17993,Communication transponder-Phase value,13,
IDE14186-MAS17994,Communication transponder-Compensation constant,3D,
IDE14186-MAS17995,Communication transponder-external oscillator frequency,04,
MAS00077-ENG99298,Immobilizer-State,02 01 03 76 02 00 00 00 15 00,
MAS03121,Ring break diagnostic line status,Supply voltage,
ENG119259-ENG119523,Condition_check_1-State_info_1,4,
ENG119259-ENG119409,Condition_check_1-State_info_2,1,
ENG119259-ENG119615,Condition_check_1-Transponder_Identification,00 00 00 00,
ENG119260-ENG119523,Condition_check_2-State_info_1,4,
ENG119260-ENG119409,Condition_check_2-State_info_2,1,
ENG119260-ENG119615,Condition_check_2-Transponder_Identification,0,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,100, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,100, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,100, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,100, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,75, %
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
ENG119883,ESI_mileage_per_day,100, km
ENG99439,Instrument_recorder,06 41 91 00 46 50 4B 45 56 57 07 39 53 31 08 41 43 35 44 0B 62 33 62 32 33 30 5F 06 00 02 00 29 00 0A 00 00 02 E2 00 00 00 00 00 00 00 00 00 05 90 CD F7 D5 AB 00 00 B0 00 1F 00 00 01 E8 00 00 00 00 80 00 00 00 00 05 97 E4 DE 54 DE F8 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 06 FF FF FF FF FF FF FF FF FF 00 00 1F 00 B0 00 E8 01 00 00 00 00 00 00 E4 97 05 00 F8 DE 54 DE 0A 00 29 00 E2 02 00 00 00 00 00 00 CD 90 05 00 00 AB D5 F7 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 24 00 03 00 00 00 03 00 03 00 01 00 01 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG128745,Instrument_recorder_graphic,04 41 92 00 46 50 4B 45 56 57 07 39 53 31 09 47 43 5F 56 57 0B 00 00 00 F9 00 0F 00 00 04 A0 00 00 00 00 00 02 00 05 9A 21 EA A5 29 85 00 00 04 5F 00 84 00 8B 00 5E 00 00 00 00 00 00 00 05 98 54 DC 1D 0D 4B 00 00 03 6A 00 6C 00 00 00 22 00 00 00 00 00 00 00 05 9A 21 19 A8 60 D8 00 00 04 B9 00 8B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 B9 00 8B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 B9 00 8B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 B9 00 8B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 B9 00 8B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG107920-ENG98868,onboard_computer-Range,630, km
ENG107920-ENG119788,onboard_computer-range_average_consumption,8.5, l/100km
ENG107920-ENG126296,onboard_computer-range_average_consumption_cng,6.0, kg/100 km
ENG107920-ENG126292,onboard_computer-range_average_consumption_cng_high,6.0, kg/100 km
ENG107920-ENG126294,onboard_computer-range_average_consumption_cng_low,6.0, kg/100 km
ENG107920-ENG119789,onboard_computer-range_average_consumption_high,8.5, l/100km
ENG107920-ENG119790,onboard_computer-range_average_consumption_low,10.8, l/100km
ENG107920-ENG126297,onboard_computer-range_average_consumption_lpg,10.0, kg/100 km
ENG107920-ENG126293,onboard_computer-range_average_consumption_lpg_high,10.0, kg/100 km
ENG107920-ENG126295,onboard_computer-range_average_consumption_lpg_low,10.0, kg/100 km
ENG107920-ENG126298,onboard_computer-range_cng,0, km
ENG107920-ENG126300,onboard_computer-range_cng_display_value,0, km
ENG107920-ENG119791,onboard_computer-range_display_value,630, km
ENG107920-ENG126299,onboard_computer-range_lpg,0, km
ENG107920-ENG126301,onboard_computer-range_lpg_display_value,0, km
ENG107953-ENG100938,outside_temp_algorithm_group-coolant_temperature_outdated_bit,not active,
ENG107953-ENG101136,outside_temp_algorithm_group-distance_threshold_not_yet_reached,active,
ENG107953-ENG99778,outside_temp_algorithm_group-downward_tendency,not active,
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,active,
ENG107953-ENG102352,outside_temp_algorithm_group-ice_warning_symbol,not active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,not active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,121,
ENG107953-ENG99258,outside_temp_algorithm_group-outside_temperature_filtered_error_state_bit,not active,
ENG107953-ENG102589,outside_temp_algorithm_group-outside_temperature_old,not active,
ENG107953-ENG102387,outside_temp_algorithm_group-outside_temperature_raw_score_error_state_bit,not active,
ENG103405,read_out_measured_value_block,0,
ENG119885-ENG103300,Service_Key_current_data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG108927-ENG119819,Service_Key_Master_Counter-Counter_ID_Kessy,16,
ENG108927-ENG119811,Service_Key_Master_Counter-Counter_Key_ID_1,0,
ENG108927-ENG119812,Service_Key_Master_Counter-Counter_Key_ID_2,0,
ENG108927-ENG119813,Service_Key_Master_Counter-Counter_Key_ID_3,0,
ENG108927-ENG119814,Service_Key_Master_Counter-Counter_Key_ID_4,0,
ENG108927-ENG119815,Service_Key_Master_Counter-Counter_Key_ID_5,0,
ENG108927-ENG119816,Service_Key_Master_Counter-Counter_Key_ID_6,0,
ENG108927-ENG119817,Service_Key_Master_Counter-Counter_Key_ID_7,0,
ENG108927-ENG119818,Service_Key_Master_Counter-Counter_Key_ID_8,0,
ENG108927-ENG119821,Service_Key_Master_Counter-Counter_Trigger,0,
ENG108927-ENG119822,Service_Key_Master_Counter-Error_Counter,0,
ENG108927-ENG119823,Service_Key_Master_Counter-Immo_Key,2,
ENG108927-ENG119820,Service_Key_Master_Counter-Last_Key,ID_Kessy,
ENG108927-ENG99298,Service_Key_Master_Counter-State,Wait_SpeedlimitExceed,
ENG108929-ENG99961,Service_Key_Pointer-Current_Bank,key_not_readable,
ENG108929-ENG30183,Service_Key_Pointer-Write_Pointer_Adr_160,0,
ENG108929-ENG30184,Service_Key_Pointer-Write_Pointer_Adr_184,0,
ENG108929-ENG30185,Service_Key_Pointer-Write_Pointer_Adr_208,0,
Elapsed Time: 00:26
17 Adatation:
;Friday,20,December,2019,12:48:43:14741
IDE00001-Production mode-,No ,3
IDE00295-Oil temperature display,On ,1
IDE00342-ESI: Resetting ESI,no warning ,1
IDE00343-Language version,US English ,1
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible ,3
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset ,3
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset ,3
IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection,MFA3-Reset ,3
IDE00499-Display correction of consumptions and operating range,100 %,1
IDE00500-Hour,12 H,1
IDE00501-Minute,48 min,1
IDE00502-Year,2019 yr,2
IDE00503-Month,12 mon,1
IDE00504-Day,20 d,1
IDE00510-ESI: distance driven from inspection,31 km,3
IDE00511-ESI: time from inspection,119 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
IDE00514-ESI: maximum value of time between inspections,730 d,2
IDE00515-ESI: oil quality,poor oil quality ,1
IDE00517-ESI: soot entry,0 km,2
IDE00518-ESI: thermal load,200 km,2
IDE00819-Day counter,118 d,2
IDE00827-ESI: minimum value of time between inspections,365 d,2
IDE01153-SIA: maximum value of distance to service,16100 km,2
IDE01154-SIA: maximum value of time to service,365 d,2
IDE02489-Display depiction,Version 1 ,1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l,5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l,5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,12.7 l,5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l,5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l,5
IDE03329-Driving profiled for range remaining,8.5 l/100km,2
IDE03346-IDE00301-Units adjusted-Distance,miles ,3
IDE03346-MAS01230-Units adjusted-Date,mm_dd_yy ,3
IDE03346-MAS01456-Units adjusted-Speed,Miles per hour ,3
IDE03346-MAS02201-Units adjusted-Temperature,°F ,3
IDE03346-MAS02957-Units adjusted-Time,12h AM_PM ,3
IDE03346-MAS03032-Units adjusted-Volume,gallons (US) ,3
IDE03346-MAS03034-Units adjusted-Pressure,psi ,3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3
IDE03346-MAS13665-Units adjusted-Trailer/support load ground,kilogram (kg) ,3
IDE03348-MAS01456-Speed warning-Speed,0 ,2
IDE03348-MAS01561-Speed warning-Unit,Miles per hour ,2
IDE03348-Speed warning-,not active ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,32200 km,2
IDE03350-FIX: Maximum time until next time-dependent inspection,730 d,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,0 km,2
IDE03352-FIX: Time since last time-dependent inspection,119 d,2
IDE03372-Source for synchronization of time,internal clock ,1
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On ,5
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5
IDE03867-Deactivate seat belt warning,No ,1
IDE05930-Service notification in days,30 d,1
IDE05931-FIX: Reset value for next mileage-dependent inspection,32200 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,730 d,2
IDE06588-Ignition active message: actuator,Driver door ,1
IDE06922-No-voltage display,Not available ,1
IDE07221-Cylinder shut-off,Display ,1
IDE11086-Service notification,30 d,1
IDE11932-MAS01877-Display of colour adjustment-Red,0 ,3
IDE11932-MAS01878-Display of colour adjustment-Green,0 ,3
IDE11932-MAS01879-Display of colour adjustment-Blue,0 ,3
IDE12211-China variant,No ,1
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation,active ,1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-CCS,not active ,1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter,not active ,1
IDE12467-Tubes illustration,Version 2 ,1
IDE12722-Driving profile display,No ,1
IDE13094-Tachometer end value,Version 0 ,1
IDE13607-MAS16698-Lock display contents-Lock infotainment list,No ,9
IDE13607-MAS16699-Lock display contents-Lock function lists,No ,9
IDE13607-MAS16700-Lock display contents-Lock MFA displays,No ,9
IDE13607-MAS16701-Lock display contents-Dynamic image lock,No ,9
IDE13607-MAS16702-Lock display contents-Lock functional animation,No ,9
IDE13607-MAS16703-Lock display contents-lock,No ,9
IDE13607-MAS16704-Lock display contents-Lock system status animation,No ,9
IDE13607-MAS16705-Lock display contents-Lock operating support animation,No ,9
IDE13607-MAS16706-Lock display contents-List time out,0 s,9
IDE13607-MAS17250-Lock display contents-Map locked,No ,9
IDE13607-MAS17251-Lock display contents-Piloted driving locked,No ,9
IDE13607-MAS17283-Lock display contents-Vehicle model locked,No ,9
IDE13607-MAS17284-Lock display contents-Cover intensity locked,100 %,9
IDE13607-MAS17285-Lock display contents-Number of list entries blocked,0 ,9
IDE14184-Active participant personalization,No ,1
IDE14220-Vehicle speed warning for India-,No ,1
IDE14220-Vehicle speed warning for India-,60 s,1
IDE14984-R Logo,no R logo ,1
IDE14986-ACC illustration China,No display ,1
IDE15073-ENG249922-Digital Key 3-number_of_repeats_of_authentication_of_central_locking,01 ,3
IDE15073-ENG249951-Digital Key 3-time_for_waiting_of_receive_of_message_MDK_ZV_Resp,01 F4 s,3
IDE15113-Shift exit warning,Car exit warning ,1
IDE15132-Activate/deactivate development messages via Ethernet,not active ,1
MAS01299-Offroad,No display ,1
ENG253348-3D_speed,not active ,1
ENG114742-Activation of Development Messages,not active ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
ENG119875-defuel_threshold,9 l,1
ENG119879-ENG101574-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1,00 ,12
ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,14 ,12
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,32 ,12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,64 ,12
ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,96 ,12
ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6,FD ,12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,01 ,12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,01 ,12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,02 ,12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,04 ,12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,32 ,12
ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6,64 ,12
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1,00 ,12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,32 ,12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,64 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,96 ,12
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD ,12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,01 ,12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,01 ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,03 ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,06 ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,28 ,12
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64 ,12
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1,00 ,12
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2,0A ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,01 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,01 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,03 ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,06 ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,28 ,12
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64 ,12
ENG128744-ENG101574-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X1,00 00 ,24
ENG128744-ENG99557-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X2,00 0A ,24
ENG128744-ENG102140-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X3,00 32 ,24
ENG128744-ENG102936-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X4,00 64 ,24
ENG128744-ENG103548-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X5,00 96 ,24
ENG128744-ENG113992-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X6,00 FD ,24
ENG128744-ENG99777-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y1,00 32 ,24
ENG128744-ENG100480-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y2,00 32 ,24
ENG128744-ENG100773-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y3,00 78 ,24
ENG128744-ENG100631-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y4,00 E6 ,24
ENG128744-ENG102174-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y5,01 F4 ,24
ENG128744-ENG113993-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y6,03 E8 ,24
ENG128743-ENG101574-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X1,00 00 ,24
ENG128743-ENG99557-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X2,00 0A ,24
ENG128743-ENG102140-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X3,00 32 ,24
ENG128743-ENG102936-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X4,00 64 ,24
ENG128743-ENG103548-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X5,00 96 ,24
ENG128743-ENG113992-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X6,00 FD ,24
ENG128743-ENG99777-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y1,00 0C ,24
ENG128743-ENG100480-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y2,00 0C ,24
ENG128743-ENG100773-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y3,00 23 ,24
ENG128743-ENG100631-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y4,00 46 ,24
ENG128743-ENG102174-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y5,01 F4 ,24
ENG128743-ENG113993-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y6,03 E8 ,24
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00 ,20
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32 ,20
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64 ,20
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 FA ,20
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4 ,20
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 28 ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 50 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 96 ,20
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD ,20
ENG119833-Display_Save_CP,Yes ,1
ENG119874-Gas_functionality,not active ,1
ENG251650-GPS_speed,active ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,auto_lowbeam_foglight ,1
ENG119882-init_fuel_algorithm,No ,1
ENG130585-Leaving_warning_delay,1.6 s,1
ENG249798-MDK_coding-,00 ,8
ENG249799-ENG249828-MDK_parameter-AZK bConfig COV,01 ,36
ENG249799-ENG249829-MDK_parameter-AZK num Time resp KY,800 ms,36
ENG249799-ENG249830-MDK_parameter-AZK num Time resp MDK,800 ms,36
ENG249799-ENG249831-MDK_parameter-AZK num Time resp WFS,5000 ms,36
ENG249799-ENG249904-MDK_parameter-MDK num Time Zv Cmd High,200 ms,36
ENG249799-ENG249905-MDK_parameter-MDK num Time Zv Cmd Low,100 ms,36
ENG249799-ENG249929-MDK_parameter-Rep Cmd Apdu,01 ,36
ENG249799-ENG249930-MDK_parameter-Rep User Auth,01 ,36
ENG249799-ENG249944-MDK_parameter-Time Esm Aktiv,10 s,36
ENG249799-ENG249945-MDK_parameter-Time Out Mob Dev Key Cmd,30 s,36
ENG249799-ENG249946-MDK_parameter-Time Out Resp Apdu,500 s,36
ENG249799-ENG249947-MDK_parameter-Time Out Ticket Table,120 s,36
ENG249799-ENG249948-MDK_parameter-Time Out VTAN Dec,2 s,36
ENG249799-ENG249949-MDK_parameter-Time Out VTAN Resp,10 s,36
ENG249799-ENG249950-MDK_parameter-Time SKC1,15 s,36
ENG249799-ENG249953-MDK_parameter-Veh Arch,00 ,36
ENG249800-ENG249840-MDK_parameter_2-Dev Param 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,96
ENG249800-ENG249841-MDK_parameter_2-Dev Param 2,14 02 32 32 32 32 32 32 02 C8 C8 05 0A 1E 64 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,96
ENG103063-Mileage,31 km,3
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0,15 s,16
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.0 km,16
ENG102605-ENG103631-outside_temperature-P_speed_threshold,20 km/h,16
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off,180 min,16
ENG102605-ENG104179-outside_temperature-p_tendency_damping,15 s,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C,16
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1,40 s,16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0 ,16
ENG119825-Picture_Upload_Download,not active ,1
ENG153765-Second_digital_speed,Display ,1
ENG119876-Service_Key_Clear_All_Counter,Yes ,1
ENG98918-Sport,No display ,1
ENG130584-Statistic_phev_mileage,5 km,1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,35 s,18
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF,300 ms,18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.40 s,18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.30 ,18
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
ENG112418-ENG99298-total_range_gas-State,not active ,4
Elapsed Time: 00:34
