I was attempting to install a Throttle Controller. Install went OK but after starting the engine and revving the engine up past 3000rpm a number of faults appeared. I removed the throttle controller and this is the only fault remaining. Can anyone help me clear this fault??
Autoscan is attached
Monday,16,December,2019,12:47:33:10623
VCDS Version: 19.6.2.0 (x64)
VIN: WAUZZZ8K08A034692 License Plate: NBF70P
Mileage: 251200km-156088mi Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 07 08 09 0E 10 15 16 17 19 1E 37 42 46 47 52 53
55 56 62 72 77
VIN: WAUZZZ8K08A034692 Mileage: 251200km-156088miles
Address 01: Engine (J623-CALA) Labels:| 06E-907-559-CAL.clb
Part No SW: 8T0 907 559 D HW: 8T0 907 559 A
Component: 3.2 SIMOS8.2 H02 0003
Revision: --------
Coding: 01040003190F0121
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM32FSI8T0907559D A01002
ROD: EV_ECM32FSI8T0907559D.rod
VCID: 43853246CABCA757FA-8016
Readiness: 0110 0101
Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
Part No SW: 8K0 927 158 HW: 0B6 927 156
Component: 0B6 32 FSIRdW H04 0030
Revision: --H04---
Coding: 001001
ASAM Dataset: EV_TCMAL651 A01001
ROD: EV_TCMAL651.rod
VCID: 73E5A286DA9C57D7AA-8026
Part No SW: 8K0 907 379 Q HW: 8K0 907 379 Q
Component: ESP8 quattro H04 0170
Coding: 0F0500
VCID: 479D2656F6848B7726-8012
Part No SW: 8K0 907 064 AL HW: 8K0 907 064 AL
Component: BCM2 1.1 H71 0134
Coding: 051100
VCID: 7AFB8FA2F5F6269FE9-802E
Subsystem 1 - Part No SW: 8K0 905 852 C HW: 8K0 905 852 C
Component: ELVAUDIB8 H35 0039
Serial number: 0208000008014007
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 N HW: 4E0 035 729
Component: Interfacebox H43 5170
Revision: 00000000 Serial number: 329C.087549096
VCID: 4487315A07B2A06FC3-8010
Subsystem 1 - Part No: 8T0 919 609 C
Subsystem 2 - Serial number: 00000000052635
Subsystem 3 - Serial number: 0126.02.080000000100010109ÿ
Subsystem 4 - Serial number: 010109ÿ
00003 - Control Module
Fault Status: 01100101
Reset counter: 47
Mileage: 251209 km
Date: 2019.12.16
Time: 12:41:19
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 M HW: 8T2 820 043 M
Component: KLIMA 3 ZONEN H05 0120
Revision: D0000000 Serial number: 0112.03.080291
Coding: 46046000
VCID: 3C7749BABF42D8AFBB-8068
Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
Component: BCM1 1.0 H21 0253
Revision: 04021001 Serial number: 00000000109697
Coding: 260050914014AF010001000000001D0D0F1D430800010141000000
VCID: 2F6D6EF67E3433370E-807A
Subsystem 1 - Part No SW: 8K2 955 119 HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110308 H05 0060
Serial number: SWFBIE 0000114
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10076288
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Serial number: 00000000001403080110
Part No SW: 8T2 035 110 C HW: 8T2 035 110 C
Component: MP3-Changer H42 0390
Revision: 00042001 Serial number: AUZ5ZBH4574020
VCID: 2B557AE68A2C4F1722-807E
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 C HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0010
Revision: 11001001 Serial number: 75230807204762
Coding: 100103
VCID: 397950AEB070ED87A0-806C
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD13W5MK
Coding: 30373434363030303030554A3052384B3053
VCID: 3C7749BAB742D8AFBB-8068
Serial number: 6334MSME2A2632446
Serial number: 6344MSME385312163
Serial number: 6352QSME58122E5BP
Serial number: 6362QSME5B0B237BS
Serial number: 63732SME4F163C3BB
Serial number: 63832SME567377271
Component: Lenks.Modul H11 0012
Revision: -------- Serial number: 90315HCB00089
Coding: 000036
VCID: 3D7144BEA458D1A78C-8068
Part No SW: 8K0 920 930 A HW: 8K0 920 930 A
Component: KOMBIINSTR. H14 0216
Revision: 00200000 Serial number: 7BU28VD38
Coding: AF07090002000008010000
VCID: 2B557AE64A2C4F1722-807E
Part No SW: 8T0 907 468 F HW: 8T0 907 468 F
Component: GW-BEM 4CAN-M H07 0084
Revision: EB002032 Serial number: 3200E0831283B0
Coding: 000003
Shop #: WSC 23050 822 88145
VCID: 4487315AC7B2A06FC3-8010
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H03 0150
Serial number: 1800AACA260208
Address 1E: Media Player 2 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 D HW: 4E0 035 785
Component: SG ext.Player H15 0830
Revision: 00000000
VCID: 295980EE40D05D07D0-807C
Part No SW: 4E0 910 888 E HW: 4E0 919 887 M
Component: MNS ECE H51 1050
Revision: 00000000 Serial number: 333CO087549610
Shop #: WSC 23050 822 83558
VCID: 306F6D8AA30A2CCF17-8064
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000006919242
Coding: 011C12204101410001
VCID: 3F8D3EB6AE54C3B79E-806A
Revision: 00002001 Serial number: 0110017364
Coding: 01000E2200390405003001
Subsystem 1 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J245 PS033 H06 0036
Part No SW: 8T0 035 223 T HW: 8T0 035 223 F
Component: DSP Prem H14 0400
Revision: 00H14003 Serial number: 34871001180003
Coding: 020101
Shop #: WSC 12336 024 394758
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000006920579
VCID: 3E7343B2A95ECABF95-806A
Part No SW: 8K0 907 801 D HW: 8K0 907 801 D
Component: EPB Audi B8 H04 0050
Revision: 00000003 Serial number: 00000000095464
VCID: 306F6D8A630A2CCF17-8064
Part No: 8K0 907 357 B
Coding: 0000004
Shop #: WSC 06324 000 00000
VCID: 3467619A571210EF73-8060
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 336CZ087544758
Coding: 0000001
VCID: 2E5373F2B93E3A3F05-807A
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000006917809
Coding: 010C12204001210001
VCID: 7F0D7EB6EED403B7DE-802A
Part No SW: 8K0 959 794 HW: 8K0 959 795
Component: TSG HR H06 0170
Revision: Serial number: 0000006913149
VCID: 7EF383B2E9DE0ABFD5-802A
Address 77: Telephone
End-------------------------(Elapsed Time: 03:58)--------------------------
