Faulty driver side mirror
coconutaudi
Kuala Lumpur, Malaysia
C?ID=345326
Hello, I have this faulty driver side mirror. It won't fold in even if I use the button on the door. The passenger side works fine. The funny part is this malfunction did not appear in the VCDS auto scan. So I have no clue where to begin in repairing this faulty side mirror or whether to replace it altogether (which I'm trying to avoid). Is there any particular way to solve this issue? BTW I've noticed that the new post new thread webpage doesn't have the option to put the scan code like the old one. How do I include my auto scan? Thank you.
A6 C7 4G
Mari
C?ID=150535
You can put the autoscan here simply by copy & paste... check the wiring going into the door!
coconutaudi
C?ID=345326
Today I auto scanned the car to see if I managed to solve a problem but somehow the codes relating to the driver door appeared and the codes did mentioned about the folding mirror.
The codes are as follows :
   Part No SW: 4G8 959 793 C    HW: 4G8 959 793 A
   Component: TSG FA        H04 0210
   Coding: 011F16205E01628002080002
   Shop #: WSC 02312 785 00200
   VCID: 40D94367AA8BB5E7897-8014
01482 - Motors for Central Locking
                    Fault Status: 00100111
                    Reset counter: 94
                    Mileage: 168023 km
                    Date: 2019.12.13
                    Time: 18:57:12
02116 - Mirror Adjusting Motor
                    Fault Status: 00100110
                    Reset counter: 94
                    Mileage: 168023 km
                    Date: 2019.12.13
                    Time: 18:57:12
02117 - Motor for Mirror Folding
                    Reset counter: 94
                    Mileage: 168023 km
                    Date: 2019.12.13
                    Time: 18:57:12
                    Reset counter: 94
                    Mileage: 168023 km
                    Date: 2019.12.13
                    Time: 18:57:12
                    Reset counter: 94
                    Mileage: 168023 km
                    Date: 2019.12.13
                    Time: 18:57:20
                    Reset counter: 94
                    Mileage: 168023 km
                    Date: 2019.12.13
                    Time: 18:57:20
Most of the faults are wiring related and in the case of the folding mirror it was stated 007- short to ground - Intermittent. If I were to open up the door trim, what should I be looking for? One more thing, the above codes went away went I cleared the DTC. When I scanned it for the second time, the codes did not reappear.
the full scan is below :
onday,16,December,2019,14:09:52:34670
VIN: WAUZZZ4G9BN031X10   License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 42 44 46 52 53 55
          56 5F 62 6C 72 85 8F 90
VIN: WAUZZZ4G9BN031310   Mileage: 168120km-104464miles
Address 01: Engine (J623-CGWB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 907 551     HW: 4H0 907 551
   Component: 3.0l V6 TFSI  H05 0007
   Revision: --H05---
   Coding: 0A250034052701020000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TFS0214G0907551 002010
   ROD: EV_ECM30TFS0214G0907551_002.rod
   VCID: 6695B5FFE8EFBBD753B-8032
   Part No SW: 4G0 927 156 M    HW: 0B5 927 156 F
   Component: 0B5 30TFSIRdW H10 0024
   Revision: --H10---    Serial number: 0000000785
   Shop #: WSC 04940 001 00001
   ASAM Dataset: EV_TCMDL501 A02196
   ROD: EV_TCMDL501.rod
   VCID: 363525BFF8CF0B5723B-8062
   Part No SW: 4G0 907 379     HW: 4G0 907 379
   Component: ESP PREMIUM   H08 0190
   Coding: 44A687002265E100DB00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 003013
   ROD: EV_ESPPremiAU57X_003.rod
   VCID: 6E85CDDFC01F73972BB-803A
   Part No SW: 4H0 907 064 AP    HW: 4H0 907 064 AP
   Component: BCM2 2.0      H24 0217
   Coding: 05B82F00000000000000
   VCID: 77ABE8BBBFC5325FF8D-8022
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000097450009
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H11 0056
   Serial number: 06051100040574
   Coding: 6621007824
   ASAM Dataset: EV_AirCondiComfoUDS 002029
   VCID: 270BF8FB2F6562DFA8D-8072
0378 - Coolant Circulation Pump
          B10D0 04 [008] - Internal System Fault
                    Fault Frequency: 14
                    Reset counter: 96
                    Mileage: 167762 km
                    Date: 2019.12.10
                    Time: 10:12:42
                    Voltage terminal 30: 13.48 V
                    Outside air temperature: 32.5 °C
                    Interior temperature: 23.10 °C
0379 - Supply Voltage Terminal 30 for Coolant Pump
          B11D5 01 [009] - Electrical Failure
                    Fault Frequency: 44
                    Reset counter: 56
                    Mileage: 167382 km
                    Date: 2019.11.29
                    Time: 17:28:49
                    Voltage terminal 30: 12.45 V
                    Interior temperature: 35.37 °C
   Part No SW: 4H0 907 063 N    HW: 4H0 907 063 F
   Component: BCM1 2.0      H12 0092
   Revision: 20012002    Serial number: 00000001044197
   Coding: 0200201050B49FE0C181008380001908CF9DC3082F080101000008402100
   VCID: 33331CABEB3D1E7F045-8066
   Component: WWS57X 110404  H35 0051
   Serial number:         110407090850
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11418017
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 22 04 2011  00000235
   Serial number: 5228C6A5000000000001
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 33
                    Mileage: 167382 km
                    Date: 2019.11.29
                    Time: 17:28:00
   Part No SW: 4H0 919 475 J    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0032
   Revision: 11001001    Serial number: 55901107004778
   Coding: 300306
   Shop #: WSC 00097 210 98728
   ASAM Dataset: EV_EPHVA18AU57X0000 001002
   ROD: EV_EPHVA18AU57X0000_001.rod
   VCID: 392F2E83C9D1E42FCE9-806C
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG002BRPH
   Coding: 30323436313330303631554A305234473053
   Serial number: 3575HRB404T0HM766GDR
   Serial number: 3585HRB405H0H0LUC8R2
   Serial number: 3515JRB405D0H4DU9P4N
   Serial number: 3525JRB405F0G944N0G$
   Serial number: 3554VRB40630GR36HOS5
   Serial number: 3564VRB405D0GR36IHD.
   Revision: 00000000    Serial number: 20110505000939
   Coding: 000034
   VCID: 303913A71A2B2567797-8064
   Component: E221 - MFL  H07 0009
   Part No SW: 4G8 920 981 A    HW: 4G8 920 981 A
   Component: TBenGb        H34 0312
   Revision: 19100074    Serial number: 658020411593026
   Coding: 33A709000B012600010000
   ASAM Dataset: EV_RBD4K 004033
   ROD: EV_RBD4K_AU57.rod
   VCID: 313F16A311A12C6F769-8064
   Part No SW: 4G0 907 468 C    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0204
   Revision: --------    Serial number: 00000000141378
   Coding: 00CD073000
   ROD: EV_GatewUDS_AU57.rod
   VCID: 303913A71AAB2567797-8064
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650387009
   Voltage stabilizer:
   Serial number: 11130001538021200181
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0056
   Serial number: 06051100040012
   Coding: 02
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
   VCID: 2F3B10DB07953A9F60D-807A
0026 - Motor for Rear Left Upper Body Vent
          B10D3 21 [008] - Signal Amplitude Too Low
                    Reset counter: 82
                    Mileage: 167513 km
                    Date: 2019.12.04
                    Time: 09:48:55
                    Voltage terminal 30: 13.32 V
                    Outside air temperature: 41.5 °C
                    Left Rear Upper Body Vent Motor-Act.val.: 9849
                    Left Rear Upper Body Vent Motor-Specified value: 9849
                    Left Rear Upper Body Vent Motor-Stop open: 11400
                    Left Rear Upper Body Vent Motor-Stop closed: 10000
   Component: MEM-FS        H03 0153
   Revision: AA000000    Serial number: 00000006129999
   Coding: 00781B0000006001000001010101102030303232203232
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0004
   Revision: --------    Serial number: EJ1BPA4200UA850
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 2D070AD30D99488F521-8078
                    Reset counter: 94
                    Mileage: 168023 km
                    Date: 2019.12.13
                    Time: 18:57:12
                    Reset counter: 94
                    Mileage: 168023 km
                    Date: 2019.12.13
                    Time: 18:57:12
                    Reset counter: 94
                    Mileage: 168023 km
                    Date: 2019.12.13
                    Time: 18:57:12
                    Reset counter: 94
                    Mileage: 168023 km
                    Date: 2019.12.13
                    Time: 18:57:12
                    Reset counter: 94
                    Mileage: 168023 km
                    Date: 2019.12.13
                    Time: 18:57:20
                    Reset counter: 94
                    Mileage: 168023 km
                    Date: 2019.12.13
                    Time: 18:57:20
   Component: RCEPS         H33 0010
   Revision: 00001000    Serial number: 0010073316
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D19AF14A717770F3-8066
   Revision: 00002001    Serial number: 0149428872
   Coding: 011B0E2200B9048183300804080100000000000000000000000000000000
01134 - Alarm Horn (H12)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 33
                    Mileage: 167382 km
                    Date: 2019.11.29
                    Time: 17:28:50
   Part No SW: 4G8 959 792 C    HW: 4G8 959 792 A
   Component: TSG BF        H04 0210
   VCID: 3FDB409BD775CA1FF0D-806A
   Revision: --------    Serial number: 00000000070722
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A0D01CF3C775FB7B73-807E
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 A    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0012
   Serial number: 110502-0004-033
   Coding: 1121A633F918EB00
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
H02 0008
   Coding: 1D0000
H02 0008
   Coding: 1D0000
0061 - Function Restriction due to Implausible Message(s)
          U1112 00 [137] - -
          [Fehlerhafter DLC der CAN-Messages Kamera_Status  (0x318)]
                    Fault Frequency: 54
                    Reset counter: 56
                    Mileage: 167382 km
                    Date: 2019.11.29
                    Time: 17:28:52
   Part No SW: 4G0 035 056 A    HW: 4G0 035 056
   Component: Radio U STD   H52 0050
   Revision: AB001007    Serial number: 051EY0B7516476
   Coding: 010003020100000001
   VCID: 1F1BE01B77B5AA1FD0D-804A
   Part No SW: 4G0 035 670 B    HW: 4G0 035 670
   Component: H-BNT-EU      H46 0239
   Revision: --------    Serial number: 428EX0B7514227
   Coding: 050101000003E1EF45108B3E000000030000010000000000
   VCID: 221DE9EF44C787F7FF3-8076
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB1300QPJ1
   Subsystem 3 - Part No SW: 4G2 919 612 L    HW: 4G2 919 612 L
   Component: E380 BDT C7  H08 0120
   Serial number: 90349KDT0007U
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
03787 - Rotation Mechanism for Display Module Front
                    Fault Status: 00101011
                    Reset counter: 93
                    Mileage: 168022 km
                    Date: 2019.12.13
                    Time: 18:45:38
                    Voltage: 12.00 V
   Part No SW: 4G8 959 795 C    HW: 4G8 959 795 A
   Component: TSG HL        H03 0210
   Coding: 010F14204001628002080002
   VCID: 42DD496FA487A7F79F3-8016
   Part No SW: 4G0 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0050
   Revision: --H04---    Serial number: 525 PA8J14F0S1
   Coding: 1020004
   VCID: 2517F2F359E970CF9A1-8070
   Component: TSG HR        H03 0210
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H24 0034
   Coding: 64040000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 6597B2F315E9B0CF5A1-8030
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 00060000031F030000030800424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 6FBBD0DBC7157A9F20D-803A
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 70B9D3A7DA2B6567397-8024
End----------(Elapsed Time: 02:11, VBatt start/end: 12.3V/12.3V)-----------
