I have the ESP, Steering Wheel and Tire Pressure light on at all time. I've done a number of reset/clear of the codes but they instantly come back.
the MIL does not stay on or come on, I've put the battery on charge this evening to rule that out, failing the battery is there is anything I can do with VCDS to calibrate the steering angle sensor?
TIA
TIA
Thursday,12,December,2019,19:46:09:25558
VCDS Version: 19.6.2.0 (x64)
VIN: TMBBG7NE0H0166421 License Plate:
Mileage: 139193km-86490mi Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: TMBBG7NE0H0166421 Mileage: 139193km-86490miles
Address 01: Engine (2D2D2-CXXB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 056 CR HW: 04L 907 445 B
Component: R4 1.6l TDI H06 2797
Revision: 22004001
Coding: 01254012430519090000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM16TDI03004L906056CR 002007
ROD: EV_ECM16TDI_002_VW37.rod
VCID: 7F0B4523E69EAAB7DE-802A
Readiness: N/A
Part No SW: 0CW 300 041 D HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1004
Revision: 00005026 Serial number: CU501701066091
Shop #: WSC 73430 031 00063
ROD: EV_TCMDQ200021_VW31.rod
VCID: 366560078924ABFF4D-8062
Address 03: ABS Brakes (J104) Labels:* 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 AQ HW: 5Q0 614 517 AF
Component: ESC H62 0400
Revision: 00000000 Serial number: 60117000001890
Coding: 1A078A9114260972407B060240C4245851289002600224720041F070C002430000000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
ROD: EV_Brake1UDSContiMK100ESP_036.rod
VCID: 0009C6DF9B60D54FA7-8054
0295 - Steering angle sensor
Reset counter: 74
Mileage: 139193 km
Date: 2019.11.26
Time: 03:43:20
8277 - Databus
U1122 00 [009] - Implausible Message
Reset counter: 74
Mileage: 139193 km
Date: 2019.11.26
Time: 03:43:20
Part No SW: 5E0 907 044 AB HW: 5E0 907 044 AB
Component: Climatronic H04 1601
Revision: 00001K07
Coding: 01110104002110011005000000101002
VCID: 65C7F74B6402106734-8030
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 CJ HW: 5Q0 937 084 AL
Component: BCM MQBAB M H24 0175
Serial number: 01061635800524
Coding: 0F001842424700DB07A04082B10407280000000000000000000000000000
Shop #: WSC 73430 790 00000
ROD: EV_BCMBOSCH_015.rod
VCID: 020DCCD7956CC75FB1-8056
Subsystem 1 - Part No SW: 5E2 955 119 HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 161122 041 0570
Serial number: 161208142040
Coding: 065DDD
Subsystem 2 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY163083U08
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000067985623
Subsystem 4 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 71736775
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0054
Revision: -------- Serial number: 39261700402360
Coding: 0001050011
ASAM Dataset: EV_EPHVA14AU3700000 002024
VCID: 3C71722FB70871AFBB-8068
13637426 - Databus
Reset counter: 74
Mileage: 139193 km
Date: 2019.11.26
Time: 03:34:24
Part No SW: 3Q0 959 655 AK HW: 3Q0 959 655 AK
Component: Airbag VW21 004 0306
Revision: -------- Serial number: 003R6PQYUNXZ
Coding: 98CCC000000000005C5400CC008800000065
ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 071BDDC3BE4EE277E6-8052
Subsystem 1 - Part No SW: ----------- HW: 454 001 112 16
Serial number: 35700000000EC295312K
Subsystem 2 - Part No SW: ----------- HW: 454 001 112 16
Serial number: 358000000004A2953129
Subsystem 3 - Part No SW: ----------- HW: 454 801 412 16
Component: SideSensor_Dr 301 0148
Serial number: 351005319CF0D000000O
Subsystem 4 - Part No SW: ----------- HW: 454 801 512 16
Component: SideSensor_Pr 301 0148
Serial number: 35200E661D00D000000K
Subsystem 5 - Part No SW: ----------- HW: 454 800 912 16
Component: FrontSensor_D 304 0149
Serial number: 355008BC88E0D0000001
Part No SW: 5Q0 953 507 GJ HW: 5Q0 953 549 E
Revision: -------- Serial number: 19121608491203
Coding: 0610
VCID: 0401CACF8F78C96F83-8050
Part No SW: 5E0 920 981 C HW: 5E0 920 981 C
Component: KOMBI 202 9630
Coding: 27A402082180A60001082A001000000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009007
ROD: EV_DashBoardJCIMQBAB_009_VW48.rod
VCID: 2A5D44774D9CFF1FD9-807E
Part No SW: 3Q0 907 530 A HW: 3Q0 907 530 A
Component: GW MQB Low 416 4286
Revision: -------- Serial number: 0005781649
Coding: 030000045F087300EB0002481C0F00010001050000000000000000000000
ROD: EV_GatewNF.rod
VCID: 2D574F6B7C72E8273C-8078
Subsystem 2 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 75410803001701047378
Part No SW: 5Q4 959 393 E HW: 5Q4 959 393 B
Component: TSG FS 010 0032
Serial number: 0000235832888
Coding: 001000208001040000001100
VCID: 458717CBC4C23067D4-8010
Serial number: 00000000000012810601
Coding: 1D0200
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 129 1072
Coding: 0002
ROD: EV_SteerAssisMQB_013.rod
15873 - Steering angle sensor
Reset counter: 74
Mileage: 139193 km
Date: 2019.11.26
Time: 03:34:24
Motor status: 00
Supply voltage: 11.75 V
Temperature: 17.0 °C
KFC: 3E
KFA: 00 01
Environmental conditions: 5F
uioUdNotFilt_xdu16: 11.84 V
uAdSensI_SwitchedKl30_xdu16: 11.84 V
RP_VALCNTSAV: not activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: not activated
RP_CNTERR: not activated
Part No SW: 5Q4 959 392 E HW: 5Q4 959 392 B
Component: TSG BFS 010 0032
Serial number: 0000235336362
VCID: 44810ACFCFF8096FC3-8010
Serial number: 00000000000012841355
Coding: 050200
B1487 54 [009] - Missing Calibration / Basic Setting
Reset counter: 74
Mileage: 139193 km
Date: 2019.11.26
Time: 03:34:24
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 842 B HW: 5Q0 035 842 B
Component: MU-S-D-ER H30 0359
Serial number: SKZAZ2S5322059
Coding: 03730100FF00000011111201008800002F0100C60120010002
Shop #: WSC 73430 790 00063
ROD: EV_MUStd4CTSAT_VW41.rod
VCID: 2E5548677174933F05-807A
Subsystem 1 - Part No SW: 5E0 919 605 H HW: 5E0 919 605 H
Component: ABT_Std-2 H43 1031
Serial number: SKZ8Z9TLG025FT
End-------------------------(Elapsed Time: 03:45)--------------------------
