DSG failure, no drive
m11erl
HC712689
Hi there we have a 2012 golf with no drive, dsg 7 speed. I need info on what the oil pressure in the mechatronics unit should be. Ive looked on ErWin with no luck, any help would be great thanks.
GaryM
Oxford, UK
C?ID=226919
If your DSG box is the 0AM one then the oil pressure should be 70 bar (1015 psi).
If you have VCDS then it would be helpful if post up Auto-Scan results of the car inside some
 tags which will help confirm what DSG box your car actually has so you get the correct advice.
m11erl
HC712689
Please see below for faults codes and ecu info, any advise, we have made sure the mechatronics unit is coded but still no drive at the wheels at all.
Monday,19,January,2015,16:35:08:61575
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: License Plate: LD12KBN
Address 02: Auto Trans Labels: 0AM-927-769.lbl
Control Module Part Number: 0AM 300 048 P HW: 0AM 927 769 D
Component and/or Version: GSG DSG AG7 402 1901
Software Coding: 0000020
Work Shop Code: WSC 02069 000 90108
VCID: 3D776506648129C944D-8068
001850 - Gear 5
P073A - 008 - Not Selectable - Intermittent - MIL ON
Fault Status: 10101000
Reset counter: 40
Mileage: 4276 km
Date: 2017.14.08
Time: 00:29:04
001837 - Gear 2
P072D - 008 - Not Selectable - Intermittent - MIL ON
Reset counter: 40
Mileage: 4276 km
Date: 2017.14.08
Time: 00:29:04
GaryM
Oxford, UK
C?ID=226919
Yes, your DSG box is the 0AM one so the pressure I previously stated is correct for that box. I'm no expert on this but it appears that you either have a Mechatronic failure or a mechanical failure within the DSG box itself.
Have you put in a new Mechatronic unit or done some kind of re-coding for your existing unit? Or has your existing DSG box just stopped working without you having done anything?
GaryM
Oxford, UK
C?ID=226919
I just realised your car is a 2012 model.
I really wouldn't bother trying to sort this out yourself. Your car will still be covered under the original 3-year VW warranty so I would just get it back to your nearest VW dealer ASAP before the warranty expires and let them worry about how to fix the problem. If the car isn't drivable then it should be the responsibility of VW to get it to a dealer premises.
