ABS issue help please (ABS8.2 front)
autogear
C?ID=98714
Friday,06,December,2019,17:42:50:51301
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 19.6.2.0
VIN: VSSZZZ6JZAR121767   License Plate: FL10DNJ
Mileage: 158720km-98624mi   Repair Order:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZAR121767   Mileage: 158720km-98624miles
Address 01: Engine        Labels: 03C-906-024-BXW.lbl
   Part No SW: 03C 906 024 BK    HW: 03C 906 024 BK
   Component:       BXW   MM4HV G 4119
   Revision: --H11---    Serial number:
   Coding: 0000071
   Shop #: WSC 06402 785 00200
   VCID: 68D4B38058BBBE0F0F-513C
            P1570 - 000 -  - Intermittent
                    Reset counter: 111
                    Bin. Bits: 00000000
                    Load: 29.0 %
                    Lambda: 0.0 %
                    Temperature: 7.0°C
                    Absolute Pres.: 371.5 mbar
                    RPM: 1091 /min
Readiness: 0010 0001
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
   Part No SW: 6R0 907 379     HW: 6R0 907 379
   Component: ABS8.2 front  H03 0004
   Revision: --------
   Shop #: WSC 04941 000 00000
   VCID: 7BFEFCCCFE2D0597F2-802E
                    Fault Frequency: 29
                    Reset counter: 72
                    Mileage: 158721 km
                    Date: 2014.04.21
                    Time: 22:54:22
                    Hex Value: 0x0005
                    Hex Value: 0x0000
                    Hex Value: 0x3013
                    Hex Value: 0x1490
                    Hex Value: 0x00FF
                    Hex Value: 0x007F
                    Hex Value: 0x7F00
                    Hex Value: 0x0000
03306 - Coding Not Valid
                    Fault Frequency: 7
                    Reset counter: 109
                    Mileage: 158721 km
                    Date: 2014.01.30
                    Time: 03:22:02
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x3227
                    Hex Value: 0x14B1
                    Hex Value: 0x00FF
                    Hex Value: 0x007F
                    Hex Value: 0x7E00
                    Hex Value: 0x0000
Address 08: Auto HVAC        Labels: 6J0-820-045.clb
   Part No SW: 6J0 820 045     HW: 6J0 820 045
   Component: J301  Klimaanlage   0280
   Revision: 00 23 08    Serial number: 0000000485495-
   VCID: 63CEA4ACA29DDD57DA-8036
   Part No SW: 6R0 937 087 D    HW: 6R0 937 087 D
   Component: BCM PQ25 H+4  H46 0207
   Revision: BF046001    Serial number: 0147 029100439
   Coding: 248829EF886125009A2000007E0B1CC800C0400F608C0000200000000000
   Shop #: WSC 64564 324 38760
   VCID: 3E7835D8A9BFD0BF95-806A
   Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 3130
   Coding: 030000
   Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 3130
   Coding: 020000
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Subsystem 4 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
   Subsystem 5 - Part No SW: 6R0 959 591     HW: 6R0 959 591
   Component: J245/J878  H04 0054
   Serial number: 941300084499
   Coding: 000003
   Subsystem 6 - Part No: 1K8 951 171 A
00893 - Switch for Trunk Handle (E234)
                    Reset counter: 110
                    Mileage: 158721 km
                    Date: 2014.04.26
                    Time: 02:53:50
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10AirbagA05 H09 0018
   Revision: --------    Serial number: 003DW00B49PB
   Coding: 003035
   Shop #: WSC 06401 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 42804128D547B45FF1-8016
   Serial number: 3496GRB4029COCQ6TSJW
   Serial number: 3506GRB402JCOCQ74KB.
   Part No SW: 6J0 920 901     HW: 6J0 920 901
   Component: KOMBI         H07 0110
   Coding: 410A00
   VCID: 65CABAB464A9A36734-8030
   Part No SW: 6N0 909 901     HW: 6R0 937 087 D
   Component: GW-K-CAN TP20 0207
   Coding: 422100
   VCID: 70E4DBE0A36B76CF57-8024
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H07 0110
   Part No: 6R0 423 156 B
   Component: LenkhilfeTRW        V277
   Coding: 10111
   Shop #: WSC 06402
   VCID: 2F66189CEAD529370E-807A
Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
   Part No: 6J0 959 441
   Component: MF-Modul       0007 0001
   Shop #: WSC 77005 000 00000
   VCID: 70E4DBE0636B76CF57-8024
Address 56: Radio (J503)       Labels:. 6J0-035-153.clb
   Part No SW: 6J0 035 153 B    HW: 6J0 035 153 B
   Component: Radio G3 UL   H58 0058
   Revision: 0H001001    Serial number: SEZ1Z2K6496066
   Coding: 0502040002
   VCID: 234EE4AC221D9D579A-8076
                    Reset counter: 71
                    Mileage: 158724 km
                    Date: 2014.04.28
                    Time: 00:14:46
End-------------------------(Elapsed Time: 03:12)--------------------------
PetrolDave
Westbury, UK
C?ID=1423
What was done to the car for the ABS coding to be lost?
autogear
C?ID=98714
New pump was fitted and some one through old one away so couldnt retrieve it
