I have audi a3 8v fwd 1.8t
I keep having issues with 44 steering assist, when I use reset to factory settings.
The first time I did it, all my electronics errors like hill assist, parking sensors, ESP, maybe 5 or 6 total malfunctions, it also says audi presense fault but I do not have presense feature from factory anyways.
Anyways, the first time I did it, I cycled the ignition and all errors would not disappear, I tried test driving and everything and it wouldn't disappear... for about an hour or so, then I was test driving it again and all of a sudden everything worked...…
So now I did it one more time because I think I messed up trying to calibrate the G85 sensor, so I reset to factory again. But this time all the errors are not going away. I did it last night and test drove ect…. waited, and it's still messed up, my power steering doesn't return to center anymore, but it's not hard to turn.
So anyways, I think the parking sensors ESP ect...doesn't want to work because of basic setting lost of G85, I think I have to calibrate it correctly first before trying to reset the steering to factory, the fault won't go away and I think you have to clear all faults before changing basic settings.
When I tried to calibrate G85 I was almost there but it wouldn't say finished correctly, so I just ended it. But it was saying permitted for both after turning lock to lock, but then I centered the wheel and nothing but waiting.....
I'm going to keep trying obviously but thought I'd post this in the meantime in case someone more experienced might want to chime in.
Sorry took out the VIN don't know how much anyone would need it.
Tuesday,26,November,2019,02:00:46:63944
VIN: License Plate:
Mileage: 27139km-16863mi Repair Order:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F 6C BB BC
VIN: Mileage: 27139km-16863miles
Address 01: Engine (J623-CNSB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 F HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0004
Revision: --H13---
Coding: 0A1D00122424000F2000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM18TFS0208V0906264F 001004
ROD: EV_ECM18TFS0208V0906264F.rod
VCID: 3FDB448E07F2207FF0D-806A
17178 - Databus
Mileage: 27136 km
Date: 2019.11.25
Time: 22:03:31
Coolant temperature: 96 °C
Intake air temperature: 53 °C
Voltage terminal 30: 12.773 V
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Readiness: 0010 1101
Part No SW: 0D9 300 042 C HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4907
Revision: 06253104 Serial number: TFK01511142120
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 196FCA16B9162E4F2E9-804C
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 63215000001376
Coding: 13FF6A9234260A74017C020681C929C8562C5080408194B4024100548208
VCID: 79AFEA965956CE4F8E9-802C
0295 - Steering angle sensor
Reset counter: 23
Mileage: 26733 km
Date: 2019.11.09
Time: 13:50:06
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Reset counter: 63
Mileage: 26733 km
Date: 2019.11.09
Time: 13:58:30
8277 - Databus
[FCAN: EPS_DSR_Status signal is invalid]
Reset counter: 1
Mileage: 26733 km
Date: 2019.11.09
Time: 13:53:25
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 253
Mileage: 25859 km
Date: 2019.10.07
Time: 14:54:36
16412 - Display for Tire Pressure Monitoring
Reset counter: 23
Mileage: 26733 km
Date: 2019.11.09
Time: 13:50:16
16413 - Display for Tire Pressure Monitoring
Reset counter: 23
Mileage: 26733 km
Date: 2019.11.09
Time: 13:50:16
Part No SW: 8V0 820 043 C HW: 8V0 820 043 C
Component: AC Automat H14 0060
Revision: 20028000 Serial number: 00000000804853
VCID: 323D1DBAC4A0FD170F3-8066
Serial number: 2C084AD7000000000001
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 AH HW: 5Q0 937 085 AE
Component: BCM MQBAB MNA H24 0175
Serial number: 01061533101029
Coding: 04141A42C04122F541C04004511007000000000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 7F5B048E4772E07FB0D-802A
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 151106 043 0585
Serial number: 151118183555
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 60999007
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AD HW: 8V0 941 531 AD
Serial number: 17 09 2015 00001675
Component: Sirene, DWA 005 0312
Serial number: 00000000000034027844
Sun Roof:
Component: J245 PS73.404 H03 0004
Serial number: 0000FST000ON2ER00000
Coding: 101F00
Revision: -------- Serial number: 39391533008979
Coding: 0010150011
VCID: 43D3487E6B1A449F945-8016
13637426 - Databus
Reset counter: 23
Mileage: 27136 km
Date: 2019.11.25
Time: 21:59:21
Serial number: 003GCR044M24
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 47CB5C6E5F2268BF48D-8012
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34230167A30111541026
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34230168A30111551108
Coding: 333135
Occupant Detection:
Serial number: 694000000000001F0WAY
Coding: 303332
Subsystem 4 - Part No SW: ----------- HW: 480 000 411 15
Serial number: 357000000001C599371J
Subsystem 5 - Part No SW: ----------- HW: 480 000 411 15
Serial number: 358000000004D84C971V
Subsystem 6 - Part No SW: ----------- HW: 480 401 711 15
Serial number: 3510002991E34431513P
Subsystem 7 - Part No SW: ----------- HW: 480 402 411 15
Serial number: 35200029B1E2431592B+
Subsystem 8 - Part No SW: ----------- HW: 480 401 509 15
Serial number: 3550002A31CB0C21A3C6
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 401 509 15
Serial number: 3560002A31CB0C23D10+
1050117 - Databus
Reset counter: 23
Mileage: 26733 km
Date: 2019.11.09
Time: 13:50:06
Part No SW: 8V0 953 521 EP HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 26111504220022
Coding: A018
ASAM Dataset: EV_SMLSKLOMQB 020001
VCID: 0C41A34206C4CBE7A5F-8058
Part No SW: 8V0 920 960 M HW: 8V0 920 960 M
Component: KOMBI H03 6423
Coding: 0BF419092B80D7050200A8001800000000000000
VCID: 45D75666652E7AAFBA1-8010
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 24111510520552
Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
ROD: EV_GatewConti_013.rod
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Serial number: 23 11 2015 F0068820
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 171015BJH0224A
Coding: 00100B204000048000000002
VCID: 41DF42767106568F869-8014
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1063
Coding: 0002
VCID: 44D14B626E1443A7ADF-8010
15873 - Steering angle sensor
Reset counter: 23
Mileage: 27136 km
Date: 2019.11.25
Time: 22:01:17
Motor status: 00
Supply voltage: 12.00 V
Temperature: 40.0 °C
KFC: 3E
KFA: 00 01
Environmental conditions: 5F
uioUdNotFilt_xdu16: 12.02 V
uAdSensI_SwitchedKl30_xdu16: 12.01 V
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 111015BJA06092
Coding: 001003204000048000000002
VCID: 40D947727A0C5F87897-8014
Component: LWR-ECU 005 0080
Coding: 011A000101000000
VCID: 75B7E6A6754EAA2FEA1-8020
13705992 - Databus
[LWI_01: Fehlerwert im Signal LWI_Lenkradwinkel]
Reset counter: 24
Mileage: 27136 km
Date: 2019.11.25
Time: 21:58:23
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 844 C HW: 8V0 035 844
Component: MU-S-S-US 014 0660
Serial number: A7A00112150557
Coding: 01730100FF0A000011220001001A00002F0001440100010002
ASAM Dataset: EV_MUStd6C3PASE 002020
ROD: EV_MUStd6C3PASE.rod
VCID: 392F2A9619D60E4FCE9-806C
Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0014
Serial number: AUZ8Z9FY30EKHH
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 P HW: 8V0 919 614 P
Component: ControlUnit_B H41 0054
Serial number: C1000007101500030138
0020 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Reset counter: 23
Mileage: 27136 km
Date: 2019.11.25
Time: 21:57:33
Voltage terminal 30: 12.1 V
Satellite radio tuner status-Satellite radio antenna status: Electrical OK
Satellite radio tuner status-Channel selection for satellite radio: 0
Satellite radio tuner status-Audio Signal: Not available
Satellite radio tuner status-Antenna current: 0 mA
Satellite radio tuner status-Reception quality: Not available
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300010201000300
ROD: EV_2CamSysRearPASE.rod
VCID: 303917B2CAACCF07797-8064
9529428 - Steering angle sensor
Reset counter: 23
Mileage: 27136 km
Date: 2019.11.25
Time: 21:56:33
passive
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 071115BK70245C
Coding: 000003204000048000000002
Component: TSG HBFS 020 0041
Serial number: 071115BK702741
End----------(Elapsed Time: 01:33, VBatt start/end: 12.6V/12.6V)-----------
