I installed the European OLED tail lights some time ago but this weekend finallybought and used the VAG-COM to remove the annoying blinking brake lights among other things. Everything seemed ok until I took my first drive and I got a signal on the dash to turn on my headlights and when I put on Auto, they came on despite it being broad daylight. I set it to high at one point and the headlights appeared to act normally but on car restart they came back on again.
I followed the instructions here: https://www.audizine.com/forum/showt...g-brake-lights! AND here https://www.audiworld.com/forums/tt...w-disable-drl-wink-front-turn-signal-2964822/ to remove the blinking brake lights with turn signals; keep the DRL on with turn signals and coded for the ability to close the windows from key fob.
Unfortunately I didn't save original configuration of the car to reverse it. However, I think I saved all of the changes I made in the log file. I was hoping to activate high beam assistant but with this, I’m not moving on yet. Any ideas what I may have done wrong and how to undo it?
Attached is the log file of changes:
UDS Adaptation Channel (16B): ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20
Stored value Blinken links Dunkelphase
Address 09,5Q0 937 085 BT,channel ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,adapted from,Blinken links Dunkelphase ,to,not active ,
Address 09,5Q0 937 085 BT,channel ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,adapted from,Blinken rechts Dunkelphase ,to,not active ,
UDS Adaptation Channel (16B): ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21
Stored value not active
Address 09,5Q0 937 085 BT,channel ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,adapted from,Blinken rechts Hellphase ,to,Brake light ,
Address 09,5Q0 937 085 BT,channel ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,adapted from,Blinken links Hellphase ,to,Brake light ,
UDS Adaptation Channel (16B): ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20
Stored value Brake light
Saturday,09,November,2019,20:42:12:35787
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
Dealer/Shop Name: Jay's garage
VIN: WUAASAFV4K1900178 License Plate:
UDS Adaptation Channel (16B): ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26
Address 09,5Q0 937 085 BT,channel ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,adapted from,Blinken rechts Hellphase ,to,Brake light ,
Address 09,5Q0 937 085 BT,channel ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,adapted from,Blinken rechts Dunkelphase ,to,not active ,
UDS Adaptation Channel (16B): ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27
Address 09,5Q0 937 085 BT,channel ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,adapted from,0 ,to,100 ,
UDS Adaptation Channel (16B): ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2
Stored value 100
Address 09,5Q0 937 085 BT,channel ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,adapted from,minimize ,to,maximize ,
UDS Adaptation Channel (16B): ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4
Stored value maximize
Address 09,5Q0 937 085 BT,channel ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,adapted from,0 ,to,0100 ,
UDS Adaptation Channel (16B): ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3
Stored value 100
Address 09,5Q0 937 085 BT,channel ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,adapted from,minimize ,to,maximize ,
UDS Adaptation Channel (16B): ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5
Address 09,5Q0 937 085 BT,channel ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,adapted from,not active ,to,active ,
UDS Adaptation Channel (8B): ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen
Stored value active
