VW Passat 3C and EPB/ABS coding problem
V3lmu
Oulu, Finland
C?ID=229426
Hey! :)
Again, there would be a problem that requires the help of the wisest.
The car's current owner bought that car a couple of days ago. The previous owner has replaced the abs control unit for that car. The original abs control unit and its encodings are no longer available. After replacing the ABS control unit, the instrument lights have started to illuminate. The workshop has not been able to fix the problem. Electronic Handbrake + Handbrake button works. Dashboard malfunctions only interfere with driving.
Sunday,10,November,2019,18:13:52:00464
Dealer/Shop Name: J.P
VIN: WVWZZZ3CZ7P137854   License Plate: VW PASSAT
Mileage: 312000km-193867mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 18 19 22 25 42 44 46 47 52 53 56 62 72
          76
VIN: WVWZZZ3CZ7P137854   Mileage: 312000km-193867miles
Address 01: Engine        Labels: 03G-906-018-BKP.clb
   Part No SW: 03G 906 018 CE    HW: 03G 906 018 CE
   Component: R4 2.0l PPD1.5 G    9707
   Revision: --H45---    Serial number: VWZCZ000000000
   Coding: 0000172
   Shop #: WSC 66565 257 00032
   VCID: 6A8DC2BFB07FF457773-803E
005715 - Please check DTC Memory of ABS Controller
               P1653 - 008 -
                    Fault Status: 11101000
                    Reset counter: 40
                    Mileage: 311379 km
                    Date: 2019.09.04
                    Time: 08:20:47
                    Torque: 0.0 Nm
                        0.00 %
                    Voltage: 11.87 V
                    Bin. Bits: 00000100
                    Torque: 1016.0 Nm
Readiness: N/A
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 109     HW: 3C0 614 109
   Component: ESP 440 C4     H018 0001
   Revision:  H018       Serial number: 0775140884
   Coding: 0010000
   Shop #: WSC 11300 205 67446
   VCID: 5BE3977B6F259DDFFC5-800E
6 Faults Found:
                    Fault Frequency: 13
                    Reset counter: 13
                    Mileage: 311799 km
                    Date: 2019.11.09
                    Time: 15:01:45
                    Reset counter: 54
                    Mileage: 311799 km
                    Date: 2019.11.09
                    Time: 15:25:46
                    Reset counter: 54
                    Mileage: 311799 km
                    Date: 2019.11.09
                    Time: 15:25:46
                    Reset counter: 54
                    Mileage: 311799 km
                    Date: 2019.11.09
                    Time: 15:25:46
                    Reset counter: 54
                    Mileage: 311799 km
                    Date: 2019.11.09
                    Time: 15:25:46
00810 - Sensor 1/2 for Brake Pressure
                    Reset counter: 54
                    Mileage: 311799 km
                    Date: 2019.11.09
                    Time: 15:25:46
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 AJ    HW: 3C0 907 044 AJ
   Component: ClimatronicPQ46 050 0505
   Revision: 00050005    Serial number: 00000000000000
   VCID: 698FBDB3B579FF4F7E9-803C
   Part No SW: 3C0 937 049 AG    HW: 3C0 937 049 AG
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000004759596
   Coding: 01828F0700041A00470A00000F000000000C5D435C0001
   Shop #: WSC 11300 205 76641
   VCID: 6E85CEAF8C9718772BB-803A
   Subsystem 1 - Part No: 3C1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 310107 022  0601
   Coding: 00046997
   Shop #: WSC 11300
                    Reset counter: 16
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 10.75 V
                    Fault Status: 00101100
                    Reset counter: 49
                    Mileage: 311387 km
                    Date: 2019.09.15
                    Time: 01:29:00
                    Voltage: 11.30 V
                    Fault Status: 00101010
                    Reset counter: 50
                    Mileage: 311387 km
                    Date: 2019.09.15
                    Time: 00:01:00
                    Voltage: 11.95 V
   Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
   Component: 0B AIRBAG VW8   031 2522
   Revision: 11031000    Serial number: 003B1P31JV2A
   Coding: 0012354
   Shop #: WSC 00028 028 00001
   VCID: 303910D756234E87797-8064
   Subsystem 1 - Serial number: 6332MSME171F0671
   Subsystem 2 - Serial number: 6342MSME17026238
   Subsystem 3 - Serial number: 6351HTS6S4COI5L6
   Subsystem 4 - Serial number: 6361HTS6S4CK65B6
00532 - Supply Voltage B+
   Part No SW: 3C0 953 549 M    HW: 3C0 953 549 M
   Revision: 00006000    Serial number: 3C5953507AG
   Coding: 0000111
   VCID: 363526CFB44760B723B-8062
   Part No SW: 3C0 920 871     HW: 3C0 920 871
   Component: KOMBIINSTRUMENT VD1 1614
   Revision: V0007000    Serial number: 00000000000000
   Coding: 0007105
   Shop #: WSC 80093 222 69422
   VCID: 619FA5934D49B70FA69-8034
                    Reset counter: 46
                    Mileage: 311379 km
                    Date: 2019.09.04
                    Time: 08:15:04
                    Reset counter: 47
                    Mileage: 311386 km
                    Date: 2019.09.15
                    Time: 19:31:22
                    Reset counter: 47
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 1K0 815 071 T
   Component: Zuheizer        050 2504
   Revision: 00050000    Serial number: 09009839000000
   Coding: 0000012
00664 - Fuel gauge
                    Fault Frequency: 11
                    Reset counter: 139
                    Mileage: 194122 km
                    Date: 2017.03.22
                    Time: 12:40:30
01406 - No Flame
                    Reset counter: 144
                    Mileage: 194137 km
                    Date: 2017.03.22
                    Time: 17:42:15
                        Start
                    Temperature: 81.0°C
                    Temperature: 78.0°C
                    Voltage: 14.60 V
02251 - Heater Unit Locked
                    Reset counter: 104
                    Mileage: 194205 km
                    Date: 2017.03.23
                    Time: 15:14:40
Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
   Revision: 00007000    Serial number: 0700C0722007AB
   Coding: BDFD1C14CA1002
   Shop #: WSC 11300 205 176858
   VCID: 211FE5930DC9F70FE69-8074
                    Reset counter: 48
                    Mileage: 311387 km
                    Date: 2019.09.15
                    Time: 00:07:53
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 K
   Component: Haldex 4Motion      1118
   VCID: 353721C3A9416BAF2A1-8060
            013 - Check DTC Memory
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   Revision: 00042000    Serial number: VWZCZ000000000
   Shop #: WSC 11300 205 84992
   VCID: 392F2DF385598FCFCE9-806C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Reset counter: 47
                    Mileage: 311386 km
02818 - Steering Column Lock; Enabling for Electronic Ignition Lock
                    Fault Status: 00101001
                    Reset counter: 54
                    Mileage: 311640 km
                    Date: 2019.11.09
                    Time: 10:38:07
   Component: J386  TUER-SG FT    1131
   Revision: 32008001    Serial number: 00000093378216
   Coding: 0000181
   VCID: 3B2337FB8F65BDDFDC5-806E
                    Fault Status: 00100101
                    Reset counter: 48
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.136 H07 1806
   VCID: 34311CC7A23B72A71DF-8060
   Component:    KSG PQ46 ELV 042 0472
   Coding: 00910A0001860E763004941570084F0B607C01
   Part No: 3C0 035 456 D
   Component: 08K Audioverst.     0005
   Revision: 00002000    Serial number: 00000004102124
   Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
   Component: J387  TUER-SG BT    1131
   Revision: 32008001    Serial number: 00000061078216
   Coding: 0000180
   VCID: 3C2134E78A6BBAE7D5F-8068
   Part No SW: 3C0 907 801 E    HW: 3C0 907 801 E
   Component: EPB  VC8HC003   013 0003
   Revision:   013
   Coding: 0010000
   VCID: 2411EC8712DBE2278DF-8070
02433 - Supply Voltage for Right Parking Brake Motor (V283)
                    Fault Status: 00111011
                    Reset counter: 51
                    Voltage: 12.32 V
                    Count: 117
                    Fault Status: 00111100
                    Reset counter: 51
                    Mileage: 311536 km
                    Date: 2019.11.08
                    Time: 13:09:33
                    Voltage: 14.18 V
                    Count: 87
                    Fault Status: 11101101
                    Reset counter: 16
                    Mileage: 311384 km
                    Date: 2019.09.15
                    Time: 19:35:34
                    Voltage: 10.14 V
                    Count: 236
            000 - - - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 74
                    Reset counter: 7
                    Voltage: 11.39 V
                    Count: 171
02431 - Right Parking Brake Motor (V283) Resistance to Movement
                    Fault Status: 00111110
                    Reset counter: 51
                    Mileage: 311632 km
                    Date: 2019.11.08
                    Time: 18:36:53
                    Voltage: 12.42 V
                    Count: 17
   Part No SW: 3C0 035 195 B    HW: 3C0 035 195 B
   Component: Radio PM6       009 0018
   Revision: 00009000    Serial number: VWZ5Z7G1061819
   Coding: 0010010
   VCID: 1F1BE36B3BBDC1FFD0D-804A
                    Reset counter: 47
                    Mileage: 311386 km
                    Date: 2019.09.15
                    Time: 19:31:30
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1118
   Revision: 11006001    Serial number: 00000001353342
   Coding: 0000144
   VCID: 3D2739E39171B3EFE21-8068
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1118
   Revision: 11006001    Serial number: 00000001357818
   Coding: 0000144
   VCID: 3E253EEF9C77A8F7FBB-806A
Address 76: Park Assist        Labels: 3C0-919-283.lbl
   Part No SW: 3C0 919 283 C    HW: 3C0 919 283 C
   Component: Parkhilfe 8-Kan 004 0013
   Revision: 00004000    Serial number: 90630704805854
   Coding: 0010014
   Shop #: WSC 73000 205 61054
   VCID: 290FFDB375F93F4FBE9-807C
                    Reset counter: 47
01517 - Control Module for Trailer/Towing Sensor (J345)
                    Fault Frequency: 38
                    Reset counter: 16
                    Mileage: 311379 km
                    Date: 2019.09.04
                    Time: 07:59:20
                    Reset counter: 47
                    Mileage: 311386 km
                    Date: 2019.09.15
                    Time: 19:35:11
01626 - Sensor for Parking-Aid; Front Right (G252)
                    Reset counter: 46
                    Mileage: 311379 km
                    Date: 2019.09.04
                    Time: 09:18:29
End----------(Elapsed Time: 01:34, VBatt start/end: 12.3V/12.3V)-----------
I then checked the encodings with the abs unit. I was trying to change a setting at long coding when the bit type was missing the engine type code and gearbox type code. After that I saved the data and tried Auto-Scan again.
Sunday,10,November,2019,18:54:31:00464
VIN: WVWZZZ3CZ7P137854   License Plate: VW PASSAT VOL. 2
          76
   Coding: 0000172
               P1653 - 008 -
                    Reset counter: 40
                    Mileage: 311379 km
                    Date: 2019.09.04
                    Time: 08:20:47
                    Torque: 0.0 Nm
                        0.00 %
                    Voltage: 11.87 V
                    Bin. Bits: 00000100
                    Torque: 1016.0 Nm
Readiness: N/A
   Coding: 0010018
6 Faults Found:
                    Reset counter: 15
                    Mileage: 312002 km
                    Date: 2019.11.10
                    Time: 18:51:42
                    Reset counter: 15
                    Mileage: 312002 km
                    Date: 2019.11.10
                    Time: 18:51:42
                    Reset counter: 15
                    Mileage: 312002 km
                    Date: 2019.11.10
                    Time: 18:51:42
                    Reset counter: 15
                    Mileage: 312002 km
                    Date: 2019.11.10
                    Time: 18:51:42
                    Reset counter: 15
                    Mileage: 312002 km
                    Date: 2019.11.10
                    Time: 18:51:42
                    Reset counter: 15
                    Mileage: 312002 km
                    Date: 2019.11.10
                    Time: 18:51:42
   Coding: 00046997
   Shop #: WSC 11300
   Coding: 0012354
   Coding: 0000111
   Coding: 0007105
   Coding: 0000012
00664 - Fuel gauge
                    Fault Frequency: 11
                    Reset counter: 139
                    Mileage: 194122 km
                    Date: 2017.03.22
                    Time: 12:40:30
01406 - No Flame
                    Reset counter: 144
                    Mileage: 194137 km
                    Date: 2017.03.22
                    Time: 17:42:15
                        Start
                    Temperature: 81.0°C
                    Temperature: 78.0°C
                    Voltage: 14.60 V
                    Reset counter: 104
                    Mileage: 194205 km
                    Date: 2017.03.23
                    Time: 15:14:40
   Coding: 0000181
   Coding: 0000180
   Revision:   013
   Coding: 0000012
                    Reset counter: 16
                    Mileage: 311384 km
                    Date: 2019.09.15
                    Time: 19:35:34
                    Voltage: 10.14 V
                    Count: 236
            000 - - - MIL ON
                    Reset counter: 16
                    Mileage: 312000 km
                    Date: 2019.11.10
                    Time: 18:13:35
                    Voltage: 12.11 V
                    Count: 170
   Coding: 0010010
   Coding: 0000144
   Coding: 0000144
   Coding: 0010014
                    Reset counter: 16
                    Mileage: 312002 km
                    Date: 2019.11.10
                    Time: 18:13:37
End----------(Elapsed Time: 01:28, VBatt start/end: 12.2V/12.2V)-----------
I also checked the original sticker of the car, which shows the equipment installed on the car.
X1B = National sales program Finland
B0A = Component parts set without country-specific design requirement
C1G = Steel wheels 6.5J x 16
G0L = 6-speed manual transmission for four-wheel drive vehicle
HJ7 = Tires 215/55 R16 97W x1
J1D = Battery 380 A (72 Ah)
D3X = 4-cyl. turbo diesel eng.2.0 L/103 kW 16VTDI with pump-jet injection system base engine: T9G/TB3/TM0/TP0/TC3/TD3/TQ0
V0A = Tires w/o specification of tire brand
1AT = Electronic stabilization program (ESP)
1G2 = Steel spare wheel with original equipment tires
2ZB = Leather multi-function steering wheel
5RQ = Right exterior mirror: convex
5SL = Left exterior mirror: aspherical
TB3 = 4-cylinder diesel engine 2.0 L unit 03G.B
3S0 = Without roof rails/roof load rack
8T2 = Cruise control system (CCS) electronic
QG1 = Service interval prolongation
8AN = Radio with CD/MP3
8GV = Alternator 180 A
1LH = Disc brakes, front
L30 = Suspension range 30 installation control only, no requirement forecast
0YF = Weight range 6 installation control only, no requirement forecast
G07 = Front shock absorption
0GG = Emission standard EU4
1JA = Rear shock absorption, basic design 1
After that, the ideas ran out. Where should this problem be resolved first? :confused:
