Audi 8E ABS short coding
wojciech300
Poland
C?ID=147841
after the accident, the module (abs) was replace. Some one can help with coding ?
Best regards
Thursday,24,October,2019,12:08:53:48233
VCDS Version: 19.6.2.0
Workshop Code: 115 00000 000000
VIN: WAUZZZ8E27A255574   License Plate: ZDR
Mileage: 181750km-112934mi   Repair Order:
          67 69 75 76 77
VIN: WAUZZZ8E27A255574   Mileage: 181750km-112934miles
Address 01: Engine        Labels: 03G-906-016-BPW.clb
   Part No SW: 03G 906 016 KM    HW: 03G 906 016 KM
   Component: R4 2,0L EDC G000SG  9749
   Revision: --H05---    Serial number: XXXXXXXXXXXXXX
   Coding: 0000172
   Shop #: WSC 66565 257 00032
   VCID: 78F5C1B30B6F228F9F-802C
000665 - Boost Pressure Regulation
               P0299 - 000 - Control Range Not Reached - Intermittent
                    Fault Status: 00110000
                    Mileage: 181750 km
                    RPM: 2415 /min
                    Speed: 54.0 km/h
                    Load: 52.5 %
                    Voltage: 14.21 V
                    Bin. Bits: 00101000
                    Absolute Pres.: 2346.0 mbar
                    Absolute Pres.: 1132.2 mbar
008825 - Leak in Air Intake System
               P2279 - 000 -  - Intermittent
                    Mileage: 181750 km
                    RPM: 2016 /min
                    Speed: 60.0 km/h
                    Load: 92.2 %
                    Voltage: 14.21 V
                    Bin. Bits: 00101000
                    Torque: 424.6 Nm
                    Temperature: 33.3°C
Address 03: ABS Brakes        Labels: 8E0-910-517.clb
   Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
   Component: ESP8 quattro    H06 0140
   Coding: 0004529
   Shop #: WSC 06335 000 00000
   VCID: 2E5927EBB9AB2C3F05-807A
                    Reset counter: 40
                    Hex Value: 0x0000
                    Hex Value: 0x0722
                    Hex Value: 0x0014
                    Hex Value: 0x208E
                    Hex Value: 0x0001
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 000 -
                    Reset counter: 40
                    Hex Value: 0x0000
                    Hex Value: 0x0722
                    Hex Value: 0x0014
                    Hex Value: 0x148E
                    Hex Value: 0x0001
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   3233
   Coding: 00000
   VCID: 6DDBE0E7272D97277C-5106
Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  ECE 0907
   Coding: 11021
   Shop #: WSC 65536
   VCID: 3D7B10A737CDC7A78C-4AEE
Address 15: Airbags        Labels: 8E0-959-655-94.lbl
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H13 4230
   Revision: 91H13423    Serial number: 0036M0G70P6%
   Coding: 0030612
   VCID: 3B7F1EBF7AD9C997B2-806E
   Subsystem 1 - Serial number: 6332DRB40518D28FZ
   Subsystem 2 - Serial number: 6342DRB4051D0817J
   Subsystem 3 - Serial number: 6352ARB4024916509
   Subsystem 4 - Serial number: 6362ARB4023B6AD1T
   Subsystem 5 - Serial number: 63729RB400D0E004E
   Subsystem 6 - Serial number: 63829RB400D0AB5BY
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0701
   Coding: 04042
   Shop #: WSC 20842
   VCID: 41836C574B35A347E8-4AD4
01304 - Radio
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
   Part No SW: 8E0 920 932     HW: 8E0 920 932
   Component: KOMBI+WFS 4     H10 0200
   Revision: 0200        Serial number: 00000000000000
   Coding: 0005008
   Shop #: WSC 80093 222 69422
   VCID: 66C99FCB52DBA47F3D-5124
01771 - Control Module for Headlight Range (J431)
Address 18: Aux. Heat        Labels: 8E0-265-105.lbl
   Part No: 8E0 265 105 K
   Component: Standheizung Diesel 0416
   Coding: 00011
   Shop #: WSC 17919
   VCID: 2B5F2EFFD9B9591722-5140
00532 - Supply Voltage B+
            06-10 - Signal too High - Intermittent
Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
   Coding: 0005008
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8E0 035 192 C    HW: 8E0 035 192 C
   Component: RNS-E HIGH EU   H52 X---
   Revision:      07S    Serial number: AUZBZ7D0401867
   Coding: 0309217
   Shop #: WSC 06435 000 00000
   VCID: 244DC5C3E467966FE3-515E
                    Reset counter: 174
                    Date: 2019.10.24
                    Time: 11:35:26
                    Bin. Bits: 00000001
                    Bin. Bits: 00000000
                    Bin. Bits:      000
00857 - CD Changer Unit (R41)
                    Reset counter: 174
                    Date: 2019.10.24
                    Time: 11:14:19
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0804
   Coding: 00001
   VCID: 6BDFEEFF1939991762-5140
01463 - Alarm triggered by Sensor for anti-theft alarm System
            43-00 - Closed
01462 - Anti-theft alarm ultra sonic Sensor (G209)
            53-10 - Supply Voltage Too Low - Intermittent
   Part No: 8E0 959 433 CR
   Component: Komfortgerát TBF    4236
   Coding: 07018
   Shop #: WSC 06335
   VCID: 030FA65F11A97157BA-4AEE
   Subsystem 1 - Part No: 8E1959801H
   Component: Tőrsteuer.FS BRM 0606
   Subsystem 2 - Part No: 8E1959802H
   Component: Tőrsteuer.BF BRM 0606
00956 - Key 2
            35-10 - - - Intermittent
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0309217
                    Reset counter: 174
                    Date: 2019.10.24
                    Time: 11:35:26
                    Bin. Bits: 00000001
                    Bin. Bits: 00000000
                    Bin. Bits:      000
                    Reset counter: 174
                    Date: 2019.10.24
                    Time: 11:14:19
Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
   Part No SW: 8E0 919 283 E    HW: 8E0 919 283 E
   Component: Parkhilfe 8-Kan H06 0010
   Revision: 00H06000    Serial number: 00067802120707
   Coding: 0000114
   VCID: 3261339BAE9308DF61-5124
02069 - Front Parking Aid Sensors
   Part No SW: 8P0 862 335 H    HW: 8P0 862 335 H
   Component: FSE_255x BT     H26 0290
   Revision: 00000000    Serial number: 00000005114949
   Coding: 0011811
   VCID: 3B7F1EBF79D9C997B2-5124
                    Reset counter: 9
                    Time Indication: 15
01304 - Radio
                    Reset counter: 156
                    Time Indication: 15
End-------------------------(Elapsed Time: 06:38)--------------------------
Jef
HQ
Coding: 0004529
0004529:
  • 2.0l TDI (PR-T1E/TB3/TR0/TQ0)
  • All-Wheel-Drive Manual Transmission (PR-G0L)
  • FN3 Teves 15" (PR-1LB/1LE)
Running your VIN, as per PL24:
  • Base engine TR0 4-cylinder diesel engine 2.0l
  • Transmission specifications G0L 6-speed manual transmission for four-wheel drive vehicle
  • Brake type, front 1LB Disc brakes in front
So the ABS coding looks fine to me. The installed ABS part number looks plausible to me, do you know what the original part number was? Also note that the Instrument Cluster is flagging for the J431 missing. That would be [55] - Headlight Aim Control and it doesn't show up in the scan... so what is up with that?
wojciech300
Poland
C?ID=147841
Thanks for u answer :)
Abs was replaced with the previous owner (I thought I had a problem here).
I checked the adaptations of Airbag ( ESP BRAKE, ESP POWERTRAIN), ESP brake was wrong, i change form 12 to 04 now its all ok. I think the crash in airbag was cleaned, but not correct.
It also has xenons, but it doesn't headlight level control module.
PetrolDave
Westbury, UK
C?ID=1423
AFAIK all 8E from the factory with Xenons had headlamp washers and a 55 level control module, maybe a previous owner retrofitted Xenons (incompletely).
wojciech300
Poland
C?ID=147841
Yes ofcourse :) I know that.
