2011 Audi A1 ABS coding (ESP8.2i)
s4c
New Zealand
C?ID=93511
Hi
We have had to replace the ABS ECU due to it being fried. We have replaced it with one that has the same part numbers but the coding is all zeros.
Because we could not scan the old one i cant copy the long coding, can anyone help with the correct coding?
Below is a full VDCS scan.
Many thanks in advance
Chassis Type: 8X-AU21 (8X0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 57 5F
VIN: WAUZZZ8X5BB084923   Mileage: 76970km-47826miles
Address 01: Engine (J623-CAXA)       Labels:. 03C-906-016-CAX2.clb
   Part No SW: 03C 906 016 CG    HW: 03C 906 016 BG
   Component: 1.4l R4 TSI   H08 9943
   Revision: LEH08---    Serial number:
   Coding: 00250012000401000000
   Shop #: WSC 51870 741 187846
   ASAM Dataset: EV_ECM14TFS01103C906016CG 001009
   ROD: EV_ECM14TFS01103C906016CG.rod
   VCID: 66C849CC99821E7F3D-8032
7158 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [047] - -
                    Mileage: 76979 km
                    Date: 2019.10.02
                    Time: 08:03:02
                    Coolant temperature: 23 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 11.944 V
                    CAN status - engine control module-Bits 0-7: 00000000
                    CAN TimeOut meter - transmission-Bits 0-7: 00000000
                    Generator power: 0 W
                    CAN TimeOut meter - gateway-Bits 0-7: 00000000
                    CAN TimeOut meter - battery manager-Bits 0-7: 00000000
14413 - Implausible Data Received from ABS Control Module
          U0415 00 [032] - -
                    Mileage: 76979 km
                    Date: 2019.10.03
                    Time: 10:03:59
                    Coolant temperature: 25 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 11.449 V
                    CAN TimeOut meter - transmission-Bits 0-7: 00000001
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Fault Frequency: 18
                    Mileage: 76979 km
                    Date: 2019.10.07
                    Time: 00:01:31
                    Coolant temperature: 18 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 11.756 V
4660 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [039] - -
                    Mileage: 76979 km
                    Date: 2019.10.07
                    Time: 00:01:32
                    Voltage terminal 30: 11.850 V
4713 - No Communication with ABS Brake Control Module
          U0121 00 [172] - -
                    Mileage: 76979 km
                    Date: 2019.10.02
                    Time: 08:55:31
                    Coolant temperature: 19 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 11.826 V
Readiness: 1110 0101
   Part No SW: 0AM 300 050 N    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 9030
   Revision: 00043014    Serial number: CU501311296633
   Shop #: WSC 27899 002 1048576
   VCID: 346CE38454DEBCEF73-513C
006225 - Powertrain Data Bus
               P1851 - 000 - Missing Message from ABS Controller - Intermittent
                    Fault Frequency: 7
                    Reset counter: 10
                    Mileage: 76979 km
                    Date: 2019.10.02
                    Time: 08:55:31
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BB    HW: 6R0 907 379 AH
   Component: ESP8.2i front H07 0001
   Revision: --------
   Shop #: WSC 00046 000 00000
   VCID: 7F06FCA8EA18AFB7DE-802A
                    Fault Frequency: 11
                    Reset counter: 68
                    Mileage: 76979 km
                    Date: 2019.10.02
                    Time: 08:03:18
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x3013
                    Hex Value: 0x1498
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Fault Status: 01100101
                    Fault Frequency: 11
                    Reset counter: 68
                    Mileage: 76979 km
                    Date: 2019.10.02
                    Time: 08:03:18
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x3051
                    Hex Value: 0x1B98
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
00493 - ESP-Sensor Unit (G419)
                    Fault Frequency: 11
                    Reset counter: 68
                    Mileage: 76979 km
                    Date: 2019.10.02
                    Time: 08:03:18
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x30E1
                    Hex Value: 0x2098
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Fault Status: 00100101
                    Reset counter: 108
                    Mileage: 76979 km
                    Date: 2019.10.02
                    Time: 08:06:59
                    Hex Value: 0x0003
                    Hex Value: 0x0002
                    Hex Value: 0x3002
                    Hex Value: 0x2598
                    Hex Value: 0x00FF
                    Hex Value: 0x7FAA
                    Hex Value: 0x74F9
03306 - Coding Not Valid
                    Reset counter: 108
                    Mileage: 76979 km
                    Date: 2019.10.02
                    Time: 08:06:59
                    Hex Value: 0x0003
                    Hex Value: 0x0002
                    Hex Value: 0x3003
                    Hex Value: 0x2598
                    Hex Value: 0x00FF
                    Hex Value: 0x7FAA
                    Hex Value: 0x74F9
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 8X0 820 043 A    HW: 8X0 820 043 A
   Component: Klima 1 Zone  H12 0063
   Serial number: 00000000043175
   Coding: 6420680000
   Shop #: WSC 00046 790 00000
   ASAM Dataset: EV_AirCondiFrontAU210 006031
   ROD: EV_AirCondiFrontAU210_006.rod
   VCID: 3260E59C65CAB2DF61-8066
0005 - Motor for Central Flap
          B11AB 07 [009] - Mechanical Failure
                    Reset counter: 67
                    Mileage: 76979 km
                    Date: 2019.10.02
                    Time: 08:04:16
                    Voltage terminal 30: 11.9 V
                    Interior temperature: 17.6 °C
                    Outside air temperature: 18.0 °C
                    Central air flap motor: actual value-Data: 0.0 %
                    Central air flap motor: spec. value-Data: 1.3 %
0060 - Engine Off Timer Performance
          P150A 00 [009] - -
                    Reset counter: 68
                    Mileage: 76979 km
                    Date: 2019.10.07
                    Time: 00:01:31
                    Voltage terminal 30: 11.7 V
                    Terminal 15 status: On
0119 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 108
                    Mileage: 76979 km
                    Date: 2019.10.02
                    Time: 08:55:35
                    Voltage terminal 30: 11.8 V
                    Outside air temperature: 17.5 °C
Address 09: Cent. Elect.
Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
   Part No SW: 8X0 959 655 A    HW: 8X0 959 655 A
   Component: Airbag10.41   H04 0008
   Revision: --------    Serial number: 003JJ001KKD9
   Coding: 30314539303330303037554A305238583053
   ASAM Dataset: EV_Airba1041BPAAU210 001015
   ROD: EV_Airba1041BPAAU210.rod
   VCID: 4894A774F356280F2F-801C
   Serial number: 3554VRB405D0ESC6J86T
   Serial number: 3575HRB405R09RF2CP8.
   Serial number: 3585HRB405P09RF24GFQ
   Rear Impact Crash Sensor:
   Serial number: 3515ZRB40630D6IS50LJ
12656896 - No Communication with ABS Brake Control Module
          U0121 00 [008] - -
                    Reset counter: 108
                    Mileage: 76979 km
                    Date: 2019.10.02
                    Time: 08:55:34
Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
   Part No SW: 8X0 953 501 B    HW: 5K0 953 569 H
   Revision: FF010016    Serial number: 20110323200492
   Coding: 1984004000
   VCID: 3972D2B0B8BC4187A0-806C
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Component: E221 - MFL  H07 0009
114178 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 108
                    Mileage: 76979 km
                    Date: 2019.10.07
                    Time: 21:03:45
336900 - Databus
                    Reset counter: 108
                    Mileage: 76979 km
                    Date: 2019.10.02
                    Time: 08:55:36
Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb-SRI1
   Part No SW: 8X0 920 930     HW: 8X0 920 930
   Component: KOMBI         H07 0124
   Coding: 51DE00
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04086
   VCID: 77F61488CE2897F796-8022
12656896 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 108
                    Mileage: 76979 km
                    Date: 2019.10.02
                    Time: 08:55:36
Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
   Part No SW: 8X0 907 468 A    HW: 8X0 907 468 A
   Component: GAT 4CAN 1L M H04 0083
   Revision: 1C060023    Serial number: 2341C113108059
   Coding: F00000FE000000010053
   VCID: 438EB058C2700B57FA-8016
03020 - Local databus 2
                    Fault Frequency: 14
                    Reset counter: 68
                    Mileage: 76979 km
                    Date: 2019.10.02
                    Time: 08:04:39
                    Bin. Bits:    10111
                    Voltage: 11.80 V
                    Count: 6
                    Reset counter: 108
                    Mileage: 76979 km
                    Date: 2019.10.02
                    Time: 08:55:32
                    Bin. Bits:    10111
                    Voltage: 11.70 V
                    Count: 6
                    Bin. Bits:    10011
                    Time: 0.40 s
                    Reset counter: 108
                    Bin. Bits:    00000
                    Voltage: 12.30 V
                    Count: 10
                    Bin. Bits:    10000
                    Reset counter: 108
                    Mileage: 76979 km
                    Date: 2019.10.03
                    Time: 10:24:41
                    Bin. Bits:    11011
                    Voltage: 10.00 V
                    Count: 6
   Component: IMMO          H07 0124
   Coding: 000002
   ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04008
   ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
   Part No SW: 8X0 959 793 E    HW: 8X0 959 793 E
   Component: TSG FA        H09 0410
   Coding: 011E02201001000100
   VCID: 4FA68C681E38FF376E-801A
   Part No: 6R0 423 156 B
   Component: LenkhilfeTRW        V277
   Coding: 11251
   Shop #: WSC 00046
   VCID: 2F66ECE8EAF89F370E-807A
Address 46: Central Conv.
Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
   Part No SW: 8X0 959 792 E    HW: 8X0 959 792 E
   Component: TSG BF        H09 0410
   VCID: 4E98916C1932F63F65-801A
   Part No SW: 8X0 907 357     HW: 8X0 907 357
   Component: ****LWR12**** H02 0040
   Serial number: 110317-0004-034
   Coding: 1131941010002500
   ROD: EV_HeadlRegulBasic.rod
   VCID: 7F06FCA8E618AFB7DE-802A
0074 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 108
                    Mileage: 76979 km
                    Date: 2019.10.02
                    Time: 08:55:34
0076 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 108
                    Mileage: 76979 km
                    Date: 2019.10.02
                    Time: 08:55:34
0077 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
                    Reset counter: 68
                    Mileage: 76979 km
                    Date: 2019.10.02
                    Time: 08:03:41
0078 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 108
                    Mileage: 76979 km
                    Date: 2019.10.02
                    Time: 08:55:34
   Part No SW: 4G0 035 083     HW: 4G0 035 083
   Component: Radio U JP    H50 0055
   Revision: AB001007    Serial number: 448C.0B7507724
   Coding: 030005020100000002
   VCID: 5EB8612C49D246BFF5-800A
03278 - Functionality Limited due to Missing Messages
                    Reset counter: 108
                    Mileage: 76979 km
                    Date: 2019.10.03
                    Time: 18:56:42
                    Bin. Bits: 00000000 00000100
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 8F0 919 129 C    HW: 8F0 919 129
   Component: DTV-JP        H07 0600
   Revision: R0070000    Serial number: 79300701506801
   Coding: 100300
   VCID: 3064EF9463C680CF17-8064
   Subsystem 1 - Part No SW: 4F0 919 805     HW: 4F0 919 805
   Component: R204 TVKLeser  H07 0010
   Serial number: 2172800600595502
   Part No SW: 8X0 035 678     HW: 8X0 035 678
   Component: H-BN-JP       H14 0208
   Revision: --------    Serial number: K5FAN189A6GHV
   Coding: 0C0601020008C0E80100032400000001F400300000000000
   VCID: 7DFA06A0E414BDA7CC-8028
   Subsystem 1 - Part No: 8R0 060 884 L
   Component: JPN-17.06.10.  7323
   Subsystem 2 - Part No SW: 4F0 035 503 C    HW: 4F0 035 503 C
   Component: ETC-VICS-Ant.  H02 0020
   Subsystem 3 - Part No SW: 4L0 919 813 C    HW: 4L0 919 813 C
   Component: Card reader  H02 0100
   Serial number: 359011140233
   Subsystem 4 - Part No SW: 8X0 919 604     HW: 8X0 919 604
   Component: DU6 High  H42 0084
   Serial number: 9463B90B0014003
   Subsystem 5 - Part No: 8R0 060 961
   Component: CD-Database  1886
                    Reset counter: 108
                    Mileage: 76979 km
                    Date: 2019.10.03
                    Time: 18:56:42
                    Bin. Bits: 00000110 00100000
                    Bin. Bits: 00000000 00000000
