2016 Skoda Yeti Headlight Coding mistake
gdmot
C?ID=176124
Hi everyone this is the first time i have needed to use the forum to ask for help. I have made a mistake in coding the Central Electronic module and done something i shouldn't have. I changer the coding in Byte 18 Lighting from standard parameters (00) to Skoda yeti (5l1/sk356) with separate DRLs (1D). I now can't get it back to original settings. The car uses the same bulb for side/corner lights and the DRLs. I now get an error on the side/corner lights as in effect they are no longer there. Please can you help.
VIN: TMBKC75L7G6024914   License Plate:
Mileage: 64680km-40190mi   Repair Order:
Chassis Type: 5L-SK35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 61 62 72
VIN: TMBKC75L7G6024914   Mileage: 64680km-40190miles
Address 01: Engine (J623-CUUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 F    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 1188
   Revision: 8AH20---
   Coding: 01110012042501090000
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_ECM20TDI01104L906016F 001003
   ROD: EV_ECM20TDI01104L906016F_001.rod
   VCID: 2C01F9EA5688E90745F-8078
17158 - Databus
                    Mileage: 64689 km
                    Date: 2019.10.08
                    Time: 00:38:05
                    Coolant temperature: 33 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 11.780 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
                    Drivetrain coordinator: brake function status-Bits 0-7: 0
                    Drivetrain coordinator: brake function status-Bits 0-7: 32
                    Acceleration: 0.000 m/s²
   Part No SW: 1K0 907 379 CB    HW: 1K0 907 379 CB
   Component: ESP MK60EC1   H46 0174
   Revision: 00H46001
   Coding: 933F200E092405FEC91404E5901DA092A0000021
   Shop #: WSC 33361 790 00063
   VCID: 74B1218ACEB8F1C7DDF-8020
   Part No SW: 3T0 907 044 CD    HW: 3T0 907 044 CD
   Component: Climatronic   H19 0709
   Revision: 00001009
   Coding: 0010000003
   VCID: 76B51B82D844E3D7E3B-8022
   Part No SW: 1K0 937 086 AD    HW: 1K0 937 086 AD
   Component: BCM PQ35  M   112 0903
   Revision: AC112903
   Coding: 4E000ABCA01BF1C0400800C0110081EC4B0000AE624D8160E48187000041
   VCID: 72BD2792B4ACFFF7CF3-8026
   Subsystem 1 - Part No: 5L2 955 119 B  Labels: 1KX-955-119.CLB
   Component: SK356  26  0610
   Coding: 00F7B5
   Subsystem 2 - Part No: 1K8 951 171
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 3
                    Mileage: 64689 km
                    Date: 2019.10.08
                    Time: 00:38:02
                    Voltage: 11.85 V
                        Term 50 On
                    Reset counter: 3
                    Mileage: 64689 km
                    Date: 2019.10.08
                    Time: 00:38:02
                    Voltage: 11.85 V
                        Term 50 On
Address 10: Park/Steer Assist (J446)       Labels:| 5J0-919-475.clb
   Part No SW: 5J0 919 475 C    HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0011
   Revision: --H11---    Serial number: 32931522902066
   Coding: 108006
   ASAM Dataset: EV_EPHVA14SKxxx0000 002001
   ROD: EV_EPHVA14SKxxx0000_002.rod
   VCID: 3537DC8E85C2A8CF2A1-8060
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    014 0613
   Serial number: 003G5RAV1YHF
   Coding: 00004E42
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 313FE89E71AA84EF769-8064
   Serial number: 3572MSME3A180C53ZZZZ
   Serial number: 3582MSME4F021953ZZZX
   Serial number: 3516KSME41315C38ZZZQ
   Serial number: 3526KSME28493A38ZZZ.
   Part No SW: 5K0 953 521 DQ    HW: 5K0 953 569 AH
   Component: LENKS.MODUL   016 0162
   Revision: FF010042    Serial number: 20150818101207
   Coding: 1082140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7EA503A2F074AB97BBB-802A
   Subsystem 1 - Part No SW: 5E0 919 719 L    HW: 5E0 919 719 L
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000C0099010815
   Coding: 820000
   Part No SW: 5L0 920 940 T    HW: 5L0 920 940 T
   Component: KOMBI         H03 1007
   Coding: 720E010100
   ROD: EV_Kombi_UDS_VDD_RM09_005_SK26.rod
   VCID: 3D27C4AEBDF2708FE21-8068
13654544 - Databus
          [Steuergerät für Telefon keine Kommunikation]
                    Reset counter: 3
                    Mileage: 64689 km
                    Date: 2019.10.08
                    Time: 00:38:03
   Part No SW: 7N0 907 530 BA    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1663
   Revision:   H58       Serial number: 180815F1001925
   Coding: 356323
   VCID: 70B92D9ABAA0CDE7397-8024
                    Reset counter: 3
                    Mileage: 64689 km
                    Date: 2019.10.08
                    Time: 00:38:02
   Component: IMMO          H03 1007
   VCID: 6A8D3FF29CFC3737773-803E
Address 42: Door Elect, Driver (J386)       Labels:. 7N0-959-793.clb
   Part No SW: 7N0 959 793 H    HW: 7N0 959 793 F
   Component: TSG FA        H04 0561
   Revision:             Serial number: 0000162845743
   Coding: 011402208001231004
   VCID: 47CBA646EFAE2A5F48D-8012
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 69     3501
   Revision: 00H22000
   VCID: 392FD0BEA55A4CAFCE9-806C
Address 52: Door Elect, Pass. (J387)       Labels:. 7N0-959-792.clb
   Part No SW: 7N0 959 792 H    HW: 7N0 959 792 F
   Component: TSG BF        H04 0561
   Revision:             Serial number: 0000163653720
   Coding: 011400208001231004
   VCID: 46D5AB42E8A43357B3B-8012
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AL
   Component: Batt.regelung H58 1663
   Coding: 030F1873
   VCID: 71BF289EB1AAC4EF369-8024
   Component: J367-BDM  H07 0180
   Serial number: 42202206241491441790
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-795.clb
   Part No SW: 7N0 959 795 F    HW: 7N0 959 795 E
   Component: TSG HL        H04 0561
   Revision:             Serial number: 0000163662669
   Coding: 010000200001531004
Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-795.clb
   Component: TSG HR        H04 0561
   Revision:             Serial number: 0000164295288
End----(Elapsed Time: 01:05, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
Mike@Gendan
Swansea, UK
C?ID=57030
What do you mean by "I now can't get it back to original settings"?
Did you save an auto-scan before you made any changes?
If so, can you not just change the coding back to the previous values?
gdmot
C?ID=176124
Yes, we've changed the coding back to previous values but the sidelights still don't work.
There was a warning on VCDS that changing the coding might cause problems...
Mike@Gendan
Swansea, UK
C?ID=57030
Could you also post up the scan from before the change for comparison?
langers2k
C?ID=224085
If byte 18 was originally 00, then it might not be possible to restore the original lighting config using VCDS.
Where in the UK are you?
PetrolDave
Westbury, UK
C?ID=1423
A byte 18 value of 00 masks the true value, it has been posted many times on here that if byte 18 is zero then changing it is likely to end in tears - as OP has found.
AFAIK the only way to recover is for someone with the dealer tool to restore factory settings?
langers2k
C?ID=224085
Other tools will allow EEPROM access so with some experience and a wiring diagram, you can normally generate something close, if not identical to the stock config :)
gdmot
C?ID=176124
Sincere thanks to all that posted helpful information, situation was easily rectified today using ODIS :)
