Results 1 to 4 of 4
Thread: 2020 Audi R8 - 5.2L - (NAR)
    16.4905° S, 151.7375° W
    Here is an early 2020 Audi R8 5.2L, NAR Auto-Scan and some of the more common controller Maps (will follow/post later).
    VIN numbers are omitted to for privacy purposes.
    Vehicle Identification No. WUAEEAFX3L7xxxxxx
    Model Audi R8 qu. 5.2
    Date of production 28.03.2019
    Model year 2020
    Sales type 4SPREE
    Engine Code DKAC
    Transmission Code TMY
    Exterior color / Paint Code 8R / X7F
    HEX-Net Auto-Scan
    Saturday,10,August,2019,09:19:45:01617
    VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4513.4
    VIN: WUAEEAFX3L7xxxxxx  License Plate:
    Chassis Type: FX-AU72 (4S0)
    Scan: 01 02 03 05 06 08 09 11 31 14 15 16 17 19 20 22 36 3B 42 44
              46 52 53 55 5F 65 6C 81 A6 C2
    VIN: WUAEEAFX3L7xxxxxx   Mileage: 65km-40miles
    A6-Microphone -- Status: OK 0000
    C2-Auto Trans 2 -- Status: OK 0000
    Address 01: Engine (------DKAC)       Labels: None
       Part No SW: 4S0 907 552 AC    HW: 4S0 907 552 R
       Component: V10 5.2l FSI  H57 0001
       Revision: NHH57---
       Coding: 1A2500320526000D3000
       ASAM Dataset: EV_ECM52FSI1114S0907552AC 001002
       ROD: EV_ECM52FSI1114S0907552AB.rod
       VCID: 77B1689ACECB15F7A8-8022
    Readiness: 0010 0101
    Address 02: Auto Trans (J217)       Labels: None
       Part No SW: 4S0 927 155 AC    HW: 0BH 927 711 F
       Component: AU 6 B NAR    H10 6202
       Revision: 00H10V01
       ASAM Dataset: EV_TCMDL800041 001016
       ROD: EV_TCMDL800041_AU72.rod
       VCID: 78B36BA6C3D51A8FA1-802C
       Part No SW: 4S0 907 379 J    HW: 4S0 907 379 J
       Component: ESP PREMIUM   H09 0600
       Coding: 01A1C10B808583D04B00
       ASAM Dataset: EV_ESPPremiAU57X 004050
       ROD: EV_ESPPremiAU57X_AU72.rod
       VCID: 44CBCF56CF9D8E6FFD-8010
       Part No SW: 4H0 907 064 JD    HW: 4H0 907 064 JD
       Component: BCM2 2.0      H44 0582
       Coding: 0D806506000000000000
       VCID: 74AB5F96D7BD7EEF8D-8020
       Component: J764 ELV MLB  H60 0046
       Serial number: 7218000248907015
       Part No SW: 4S0 959 760     HW: 4S0 959 760
       Component: MEM-BFS       001 0020
       Revision: AA001003    Serial number: 00000219629190
       Coding: 00001000000420F1000001210101210000000000000000
       VCID: 7BB974AAFAE33197CC-802E
       Part No SW: 4S0 820 043 K    HW: 4S0 820 043 K
       Component: AC Automat    H08 0050
       Revision: 20012000    Serial number: 96800000010908
       Coding: 4000A01000000410
       ASAM Dataset: EV_AirCondiVAPrehAU72x 003005
       ROD: EV_AirCondiVAPrehAU72x.rod
       VCID: 33299C8A9A3339D754-8066
       Operating and display unit 2 for air conditioning:
       Subsystem 1 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
       Component: E775 BuA_2  H07 0020
       Serial number: 00000000000000013759
       Operating and display unit 3 for air conditioning:
       Subsystem 2 - Part No SW: 8S0 820 359     HW: 8S0 820 359
       Component: E776 BuA_3  H07 0020
       Operating and display unit 4 for air conditioning:
       Subsystem 3 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
       Component: E777 BuA_4  H07 0020
              B10CD 00 [008] - -
                        Reset counter: 46
                        Mileage: 65 km
                        Date: 2019.07.19
                        Time: 14:01:55
                        Voltage terminal 30: 11.1 V
                        Blower reduction: No switch-off: no reduction
       Part No SW: 4H0 907 063 JK    HW: 4H0 907 063 EK
       Component: BCM1 2.0      H21 0729
       Revision: 2502105S    Serial number: 00002267811102
       Coding: 010D0091143C9FE06D0048C380001800C59CD2882A0832210004088461001100006000340B0000
       VCID: 7AB771AEF5D9089FD7-802E
       Subsystem 1 - Part No SW: 4S1 955 119 B    HW: 8V2 955 119 A
       Component: WWS624 190207  043 0081
       Serial number: 90248162190218120538
       Coding: 3247FD
       Serial number: 21801702X81A955547A0
       Coding: 02005D
       Subsystem 3 - Part No SW: 4S0 941 531     HW: 4S0 941 531
       Component: E1 - LDS  H01 0044
       Serial number: 11 02 2019  00000054
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z040020E3
       Subsystem 5 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: 77405B3900PAG0MUFU03
    Address 11: Engine II (-----)       Labels: None
       Revision: NHH57---
       ASAM Dataset: EV_ECM52FSI2114S0907552AC 001002
       ROD: EV_ECM52FSI2114S0907552AB.rod
    Address 14: Susp. Elect. (J250)       Labels: None
       Part No SW: 4S0 907 376 E    HW: 4S0 907 376 C
       Component: DAEMPFUNGS-SG H06 0065
       Serial number:       060219115
       ASAM Dataset: EV_AudiMagneRide 003007
       ROD: EV_AudiMagneRide_003.rod
       VCID: 3C3BB7B6B76DF6AF85-8068
       Part No SW: 4S0 959 655     HW: 4S0 959 655
       Component: Airbag10.43   H62 0204
       Revision: --------    Serial number: 003NJ001AVWX
       Coding: 303444393032303130374A55304C34533053
       ASAM Dataset: EV_AirbaAU10BPAAU64X 001036
       VCID: 7EBF7DBEE1F124BFEB-802A
       Serial number: 6940000Y180001SS8B09
       Serial number: 3575HRB404V5F8OK987
       Serial number: 3585HRB405B5F8OK40CC
       Serial number: 3515JRB405J5JE80G0G5
       Serial number: 3525JRB405J5JE809HSS
       Serial number: 3554VRB401I59PI0HHF0
       Serial number: 3564VRB401I59PI0C9AQ
       Part No SW: 4S0 907 129 K    HW: 4S0 907 129 K
       Component: Lenks.Modul   H06 0007
       Revision: C0071527    Serial number: 91335SBD00224-
       Coding: 000034
       VCID: 3E3FBDBEA971E4BFAB-806A
       Part No SW: 4S0 920 890 C    HW: 4S0 920 890 C
       Component: FBenUSA       H19 0308
       Coding: 086F30C1BA82CF050220ECC41800801000000000
       ASAM Dataset: EV_DashBoardBOSCHAU724 001031
       ROD: EV_DashBoardBOSCHAU724.rod
       VCID: 362FA59E89412CFF73-8062
       Part No SW: 4S0 907 468 C    HW: 4S0 907 468 A
       Component: J533--Gateway H15 0081
       Revision: --------    Serial number: 00000003064452
       Coding: 802103161C
       ASAM Dataset: EV_GatewPkoUDS 002014
       Subsystem 1 - Part No SW: 4S0 915 181     HW: 4S0 915 181
       Component: J367-BDM  H07 0270
       Serial number: 46043826450001148769
              U140B 00 [008] - -
              [Powermanagement active]
                        Reset counter: 46
                        Mileage: 65 km
                        Date: 2019.07.19
                        Time: 14:01:54
                        Voltage terminal 15: 11.1 V
                        Control Module temperature: 23 °C
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 1
    Address 20: High Beam Assist. (J844)       Labels:* None
       Part No SW: 81A 857 511 H    HW: 81A 857 511 H
       Component: FLA           H10 0003
       Revision: AB001001
       Coding: 0404001D00010001000001
       ASAM Dataset: EV_HighBeamAssisAU724 001007
       ROD: EV_HighBeamAssisAU724.rod
       VCID: 2D1D8AF27C176F2702-8078
    Address 22: AWD (J492)       Labels: None
       Part No SW: 4S0 907 160 A    HW: 4S0 907 160
       Component: 4 Wheel Drive H07 0220
       Revision: 00001002    Serial number: 00FGFYG
       ASAM Dataset: EV_AllWheelContrBORGLB724 006015
       ROD: EV_AllWheelContrBORGLB724.rod
       VCID: 2F2190FA761B1D3730-807A
       Component: MEM-FS        001 0020
       Revision: AA001003    Serial number: 00000219629192
       Coding: 00181900000420F1C00001210101210000000000000000
       Component: SARA 6D red   H04 0056
       Revision: --------    Serial number: EJ1BPA7E03EPDR
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 3731A89A8E4BD5F768-8062
       Coding: 011C53425000000300000402
       VCID: 47D1D85AF6ABA57718-8012
       Part No SW: 4S0 909 144 J    HW: 4S0 909 144 B
       Component: EPS           H13 0906
       Revision: 00000000    Serial number:      L00309217
       Coding: 0800
       ASAM Dataset: EV_EPSZFAU72X 003010
       ROD: EV_EPSZFAU72X_003.rod
       Revision: 00002001    Serial number: 0504091036
       Coding: 011E069A00F2C081E0B0CA00008500000001000000000000000000000000
       Subsystem 1 - Part No SW: 4S0 959 719 A    HW: 4S0 959 719 A
       Component: GTO BF  H01 0010
       Serial number: 20181122082501 00157
       Subsystem 2 - Part No: 4S0 951 177
       Component: Sensor, DWA  005 0002
       Subsystem 3 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0009
       Subsystem 4 - Part No SW: 4G8 959 252 A    HW: 4G8 959 252
       Component: HSP-SG  H11 0031
       Serial number: WA131462000046405160
       Coding: 011C53425E00000300000400
       VCID: 46CFD55EF1A1BC7FE3-8012
       Part No SW: 4S0 907 801     HW: 8K0 907 801 J
       Component: EPB-4         H04 0001
       Revision: --------    Serial number: 00000000006090
       ROD: EV_ParkiBrake_AU72.rod
       VCID: 70A35386ABA542CF69-8024
       Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0115
       Coding: 077A001122600400
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005011
       Subsystem 1 - Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H09 0008
       Coding: E02200
       Subsystem 2 - Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H09 0008
       Coding: E02200
       Part No SW: 4S0 035 025 F    HW: 4S0 035 025 E
       Component: MU-H-LNS-US   055 1390
       Serial number: A353B0KB002454
       Coding: 012784020000000013220002041A00332F0000E0007000047E
       ASAM Dataset: EV_MUHig6C8Gen2HBAS 001182
       ROD: EV_MUHig6C8Gen2HBAS.rod
       VCID: 2C1B87F6470D662F15-8078
       Subsystem 1 - Part No SW: V03 959 802 DK    HW: -----------
       Component: NAR 2018/2019  --- 0066
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 4S1 919 614 D    HW: 4S1 919 614 D
       Serial number: APVAK128121800010127
       Component: Gracenote2  --- 3013
    2565 - GPS Antenna
              B1054 13 [008] - Open Circuit
              [GPS aerial - open circuit]
                        Reset counter: 45
                        Mileage: 64 km
                        Date: 2019.06.25
                        Time: 12:30:27
                        Voltage terminal 30: 12.8 V
    Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
       Part No SW: 4H0 907 273 D    HW: 4H0 907 273 B
       Component: RDKBERU25     H10 0900
       Serial number: 10000000054302
       ROD: EV_RDKBERU25_AU57.rod
    Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
       Part No SW: 4S0 980 556 A    HW: 95B 980 551 L
       Component: RVC Compact   H15 0201
       Coding: 0275040102000001000040
       ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
       ROD: EV_CamSysRVRVCPANAAU57X_002_AU72.rod
       VCID: 3935AEA2B85FC3879E-806C
       Part No SW: 4S1 713 041 F    HW: 4M1 713 041 G
       Component: GSM-LL        H10 0077
       Revision: 0L0D5012    Serial number: 19021250997332
       ROD: EV_GSMWaehlZFAU736.rod
       VCID: 2E1F8DFE7111143F3B-807A
    Address A6: Microphone (J886)       Labels:. 420-907-394.clb
       Part No SW: 420 907 394 B    HW: 420 907 394
       Component: BELTMICBOX    H10 0840
       Coding: 0101030202
       ASAM Dataset: EV_BeltMicPARAGAU335 003011
       ROD: EV_BeltMicPARAGAU335.rod
       VCID: 18734B26E395FA8F41-804C
    Address C2: Auto Trans 2 (J217)       Labels: None
       Part No SW: 4S0 927 109     HW: 4S0 927 109
       Component: DL800 ZSG     H12 0002
       Revision: --H12---    Serial number: 0000000031
       Coding: 000001
       ASAM Dataset: EV_TCMDL800421 001024
       ROD: EV_TCMDL800.rod
       VCID: 73A95C8ADAB379D794-8026
    End----------(Elapsed Time: 01:58, VBatt start/end: 12.5V/12.5V)-----------
    drpeter
  2. Likes jyoung8607, NEtech, Uwe, Andy, D-Dub liked this post
  3. #2
    Blockmaps and Adpmaps
    Address - [01]
    blockmap-01-4S0-907-552-AC
    ;SW:4S0-907-552-AC   HW:4S0-907-552-R ---  Engine
    ;Component:V10 5.2l FSI  H57 0001, Coding:1A2500320526000D3000
    ;EV_ECM52FSI1114S0907552AC,001002,EV_ECM52FSI1114S0907552AB.rod
    ;Saturday,10,August,2019,09:35:54:30091
    ;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
    ;VCID: 77A8E1B45F4A1C0FFB3-8022
    Group,Description,Actual
    IDE00011,Vehicle Identification Number (VIN),WUAEEAFX3L7xxxxxx,
    IDE00019,Voltage terminal 30,12.440, V
    IDE00020-ENG57549,Terminal 15 status-Bits 0-7,1,
    IDE00021,Engine speed,0, /min
    IDE00025,Coolant temperature,23, °C
    IDE00030,Status of actuator test,not active,
    IDE00075,Vehicle speed,0, km/h
    IDE00076,Status of initial fuel filling,was not yet started,
    IDE00078,Time since engine start,0, s
    IDE00083,Throttle valve position (absolute),14.5, %
    IDE00084,Absolute load value,0, %
    IDE00085,Normed load value,0.0, %
    IDE00086,Accelerator position,15, %
    IDE00090-ENG57549,selected gear-Bits 0-7,0,
    IDE00094,Kick-down status,Not operated,
    IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
    IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
    IDE00100,Engine torque,0.0, Nm
    IDE00148,Median injection timing,0.000, ms
    IDE00150,Pressure in brake booster,955.98, hPa
    IDE00151,Oil fill level,57.928, mm
    IDE00152,Oil warning threshold,20.000, mm
    IDE00155,Timing angle retardation cylinder 1,0.0, °
    IDE00156,Timing angle retardation cylinder 2,0.0, °
    IDE00157,Timing angle retardation cylinder 3,0.0, °
    IDE00158,Timing angle retardation cylinder 4,0.0, °
    IDE00159,Timing angle retardation cylinder 5,0.0, °
    IDE00167,Exhaust temperature 1 bank 1,23.9, °C
    IDE00172,A/C compressor torque,0.0, Nm
    IDE00173,Cruise Control System: specified speed,0.00, km/h
    IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-17.000, °
    IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-17.000, °
    IDE00178,Camshaft adjustment intake bank 1: specified value,12.000, °
    IDE00179,Camshaft adjustment intake bank 1: actual value,12.000, °
    IDE00182,Camshaft adaptation intake bank 1: phase position,0.00, °
    IDE00184,Camshaft adaptation exhaust bank 1: phase position,0.00, °
    IDE00186,Fuel low pressure: actual value,697.9, kPa
    IDE00187,Coolant temperature at engine start,23.3, °C
    IDE00188,Fuel high pressure: actual value,0.6975, MPa
    IDE00194,Coolant temperature at radiator output: specified value,105.0, °C
    IDE00196,Engine oil temperature,23.7, °C
    IDE00201,High fuel pressure: specified value,0.6975, MPa
    IDE00202,Low fuel pressure: specified value,650.0, kPa
    IDE00252,Brake system vacuum pump,Pump off,
    IDE00252-ENG127370,Brake system vacuum pump-Test_Program_Channel 601,112,
    IDE00304,Fuel level,7.00, l
    IDE00322,Status of basic setting,was not yet started,
    IDE00323,Security Access: Number of invalid keys,0,
    IDE00348,Intake air temperature,32, °C
    IDE00350,Air mass: specified value,9.1, kg/h
    IDE00354,Engine start: start synchronization,EPM_MODE_WAIT,
    IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,1,
    IDE00355-ENG57549,Cruise Control System (CCS): status-Bits 0-7,6,
    IDE00356-ENG57549,Cruise Control System (CCS): switch position-Bits 0-7,0,
    IDE00357,Fuel temperature,23.3, °C
    IDE00358,Limitation: torque,799.9, Nm
    IDE00360,Limitation: accelerator pedal,0.0, Nm
    IDE00361,Ambient air pressure,983.83, hPa
    IDE00371,Fuel consumption,0.00, l/h
    IDE00375,Generator: load signal,0.00, %
    IDE00380,Coolant fan 1: activation,10.00, %
    IDE00381,Coolant fan 2: activation,10.00, %
    IDE00392,Accelerator pedal: sensor voltage 1,752.0, mV
    IDE00393,Accelerator pedal: sensor voltage 2,379.6, mV
    IDE00394,Camshaft position: start of phase window,111.01, °
    IDE00405,Crankshaft speed (RPM),0.0, /min
    IDE00406,Camshaft speed (RPM),0.0, /min
    IDE00407-ENG57549,Rail pressure regulation: status-Bits 0-7,0,
    IDE00408-ENG57549,Engine mount 1-Bits 0-7,0,
    IDE00412-ENG57549,Starter control: terminal 50-Bits 0-7,0,
    IDE00413-ENG57549,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
    IDE00414-ENG57549,Starter control: relay 1-Bits 0-7,0,
    IDE00416-ENG57549,Starter control: terminal 50 acknowledgment-Bits 0-7,4,
    IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,0,
    IDE00443-ENG57549,Accelerator pedal: switch positions-Bits 0-7,8,
    IDE00445,Unlearning counter according OBD,255,
    IDE00450,Operating Instructions,--no display--,
    IDE00451,Currently running routine,0,
    IDE00474,Ambient air pressure,98, kPa abs
    IDE00477,Torque request: sum of auxiliary aggregate,0.0, Nm
    IDE00496-ENG57549,Activation of oil pressure switch valve-Bits 0-7,0,
    IDE00497-ENG57549,Status of oil pressure switches-Bits 0-7,0,
    IDE00541,Acceleration,0.000, m/s²
    IDE00556,Outside air temperature,24, °C
    IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.998 Lambda / -0.020 mA,
    IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,1.275, V
    IDE00560-MAS04122,Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
    IDE00582,Equivalence ratio target value,1.999, Lambda
    IDE00584,Distance driven since erasing DTC memory,5, km
    IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,0, km
    IDE00588,Fuel tank fill level,7.5, %
    IDE00592,Oxygen sensor control status,Engine off,
    IDE00593,Ignition timing adjustment cylinder 1,0.0, Degrees
    IDE00595,Allocation of oxygen sensors,B1S1 B1S2 ,
    IDE00597,Long term adaptation of mixture formation bank 1,-2.3, %
    IDE00601,Monitoring status since erasing DTC memory,,
    IDE00602,Monitoring status in current driving cycle,,
    IDE00603,Number of driving cycles since erasing DTC memory,2,
    IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
    IDE00608,Type of fuel,Gasoline,
    IDE00612,Target position of EVAP canister valve,0.0, %
    IDE00699,ESI: minimum oil level in service interval,19.284, mm
    IDE00700,ESI: maximum oil level in service interval,25.172, mm
    IDE00727,Test steps still to be performed,0,
    IDE00738,Test of oxygen sensors bank 1: Delta-Lambda,0.00021,
    IDE00752,Test of oxygen sensor control.,Syst. OK,
    IDE00752-ENG127302,Test of oxygen sensor control.-Test_Program_Channel 213,228,
    IDE00773,Terminal 15 status via CAN,1,
    IDE00787,Cause for cancellation,0,
    IDE00949,Hide cylinder,active,
    IDE00949,Hide cylinder,not active,
    IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,1,
    IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
    IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
    IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
    IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
    IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
    IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
    IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
    IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,1,
    IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
    IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
    IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,1,
    IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,1,
    IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,1,
    IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
    IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
    IDE01076,Time since ignition off,65535, s
    IDE01098,Test of knock sensors: short trip result,Test off,
    IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
    IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,1.0000,
    IDE01260,Generator power,0, W
    IDE01266-ENG57549,Coolant shut-off valve-Bits 0-7,2,
    IDE01267,Height correction,0.97119,
    IDE01378,High fuel pressure: control deviation,0.0000, MPa
    IDE01384,Map controlled engine cooling thermostat: specified value,0.00, %
    IDE01385-ENG57549,Wear index-Bits 0-7,0,
    IDE01386-ENG57549,Soot index-Bits 0-7,0,
    IDE01405-ENG57549,Status of starter activation-Bits 0-7,0,
    IDE01590,Status of brakes,Not operated,
    IDE01590-ENG127367,Status of brakes-Test_Program_Channel 600,167,
    IDE01638,Result O2 sensor aging test bank 1 or 3 before cat. conv.,Test off,
    IDE01638-ENG127368,Result O2 sensor aging test bank 1 or 3 before cat. conv.-Test_Program_Channel 951,235,
    IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,1.661, V
    IDE01649,Throttle valve position 1,5.27, %
    IDE01650,Throttle valve position 2,15, %
    IDE01665,Result of test of camshaft adjustment intake bank 1,Test off,
    IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,235,
    IDE01667,Result of test of camshaft adjustment outlet bank 1,Test off,
    IDE01667-ENG127371,Result of test of camshaft adjustment outlet bank 1-Test_Program_Channel 619,235,
    IDE01679,Result of O2 sensor exchange 2 bank syst after cat conv,Syst. OK,
    IDE01679-ENG129420,Result of O2 sensor exchange 2 bank syst after cat conv-Test_Program_Channel 628,228,
    IDE01680,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve,Test off,
    IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,235,
    IDE01773,Misfire sum counter,0,
    IDE01774,Status misfire recognition,blocked,
    IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,104,
    IDE01775,Misfires per 1000 revolutions of cylinder 1,0,
    IDE01776,Misfires per 1000 revolutions of cylinder 2,0,
    IDE01777,Misfires per 1000 revolutions of cylinder 3,0,
    IDE01778,Misfires per 1000 revolutions of cylinder 4,0,
    IDE01834,Battery voltage,12440, mV
    IDE01869,Long-term fuel trim bank 1 at idle,-0.61, %
    IDE01870,Oxygen sensor after catalytic converter: operating status,Test off,
    IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,235,
    IDE01872,Result of oxygen sensor aging test after catalytic converter,Test off,
    IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,235,
    IDE01873,Test of catalytic converter: measured value,9.0000,
    IDE01874,Test of catalytic converter: result,Test off,
    IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,235,
    IDE01875,Required torque adjustment by idling regulator,0.000, %
    IDE01876,Adaptation of loss torque,0.0, Nm
    IDE01877-ENG57549,Operating condition of idle speed control-Bits 0-7,0,
    IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000000 ,
    IDE01879,Adaptation of throttle valve: result,ADP is OK,
    IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
    IDE01880,Accelerator position 2,15, %
    IDE01881,Adaptation of kick-down shifting point,4114.0, mV
    IDE01884,Camshaft adjustment intake bank 1: activation,0.000, %
    IDE01885,Shut off of oxygen sensor control,l-Reg.OFF,
    IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,3,
    IDE01887,Adaptation of Fuel Pump (FP),76.6, kPa
    IDE01888,Cold start enrichment: adaptation area 1,1.000,
    IDE01889,Cold start enrichment: adaptation area 2,1.000,
    IDE01890,Cold start enrichment: adaptation area 3,1.000,
    IDE01891,Cold start enrichment: adaptation area 4,1.000,
    IDE01892,Cold start enrichment: adaptation area 5,1.000,
    IDE01893,Fuel pump: specified value,10.001, %
    IDE01899,Load value: corrected specified value,117.12, %
    IDE01901,Lost torque adaptation: idle,1.8, Nm
    IDE01902,Lost torque adaptation A/C compressor,-9.7, Nm
    IDE01903,Lost torque adaptation driving mode,0.0, Nm
    IDE01904,Lost torque adaptation A/C compressor and driving mode,0.0, Nm
    IDE01909,Short term adapt. throttle valve for mass air flow sensor,1.00000,
    IDE01910,Long term adaptation of throttle valve for mass air flow sensor,0.97784,
    IDE01911,Leakage air,5.0, kg/h
    IDE01912,Oxygen sensor bank 1 sensor 1: specified value,15.9998,
    IDE01914-ENG57549,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bits 0-7,128,
    IDE01921-ENG100991,O2 reg: evap. emiss. can. purge reg. valve w/ active diagn.-Rel uw b200 UWORD Chann 295,100.000, %
    IDE01921-ENG127296,O2 reg: evap. emiss. can. purge reg. valve w/ active diagn.-Test_Program_Bitregister,0,
    IDE01922,Vehicle distance driven,65, km
    IDE01923,Control module distance driven,64566, m
    IDE01928,Close cam shaft angle at quantity control valve,90.0, °
    IDE01929,Open cam shaft angle at quantity control valve,146.9, °
    IDE01930,High pressure regulation: adaptation value,0.0000, MPa
    IDE01932,High pressure pump injection volume,0.00, mm³
    IDE01975,Numb.of misfir.: cylinder 1,0,
    IDE01976,Numb.of misfir.: cylinder 2,0,
    IDE01977,Numb.of misfir.: cylinder 3,0,
    IDE01978,Numb.of misfir.: cylinder 4,0,
    IDE01986,Contact for tank leak test,Open,
    IDE01986-ENG129322,Contact for tank leak test-Test_Program_Sw SAVW NVLD SWI UBYTE,0,
    IDE02115-ENG57549,Adjustment requirements for basic setting-Bits 0-7,178,
    IDE02116,Exhaust gas temperature before catalytic converter,23.99, °C
    IDE02117,Relative load value,69.30, %
    IDE02118,Oxygen sensor bank 1 sensor 1: voltage,1.494, V
    IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
    IDE02211,Brake pressure,0.00, MPa
    IDE02540-ENG57549,Longitudinal acceleration sensor: status-Bits 0-7,0,
    IDE02756-ENG57549,Number of manual engine starts-Bits 0-7,65,
    IDE02756-ENG57549,Number of manual engine starts-Bits 0-7,0,
    IDE02757-ENG57549,Number of automatic engine starts-Bits 0-7,0,
    IDE02832,Coolant circulation pump: activation,11.25, %
    IDE03108,Result of test of oxygen sensors bank 1,Test off,
    IDE03108-ENG127369,Result of test of oxygen sensors bank 1-Test_Program_Channel 976,235,
    IDE03189-ENG102843,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Air Density,0, counts
    IDE03189-ENG102547,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Brake Boost,0, counts
    IDE03189-ENG103808,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Fuel Mixture Adaption,0, counts
    IDE03189-ENG101159,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Random,0, counts
    IDE03189-ENG104187,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Regeneration Mode,0, counts
    IDE03189-ENG100165,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Start Behavior,0, counts
    IDE03189-ENG99535,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Air Density,0,
    IDE03189-ENG103192,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Brake Boost,0,
    IDE03189-ENG99739,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Fuel Mixture Adaption,0,
    IDE03189-ENG100597,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Random,0,
    IDE03189-ENG101689,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Regeneration Mode,0,
    IDE03189-ENG100582,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Start Behavior,0,
    IDE03189-ENG101720,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Air Density,0,
    IDE03189-ENG100669,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Brake Boost,0,
    IDE03189-ENG100932,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Fuel Mixture Adaption,0,
    IDE03189-ENG101264,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Random,0,
    IDE03189-ENG102430,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Regeneration Mode,0,
    IDE03189-ENG101165,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Start Behavior,0,
    IDE03189-ENG101829,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Air Density,0, km
    IDE03189-ENG99286,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Brake Boost,0, km
    IDE03189-ENG102800,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Fuel Mixture Adaption,0, km
    IDE03189-ENG102751,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Random,0, km
    IDE03189-ENG101356,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Regeneration Mode,0, km
    IDE03189-ENG99669,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Start Behavior,0, km
    IDE03189-ENG103828,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Air Density,0,
    IDE03189-ENG103959,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Brake Boost,0,
    IDE03189-ENG102465,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Fuel Mixture Adaption,0,
    IDE03189-ENG102710,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Random,0,
    IDE03189-ENG103568,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Regeneration Mode,0,
    IDE03189-ENG100877,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Start Behavior,0,
    IDE03189-ENG101280,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Air Density,0,
    IDE03189-ENG99226,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Brake Boost,0,
    IDE03189-ENG101471,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Fuel Mixture Adaption,0,
    IDE03189-ENG102877,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Random,0,
    IDE03189-ENG100198,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Regeneration Mode,0,
    IDE03189-ENG101676,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Start Behavior,0,
    IDE03189-ENG103694,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Air Density,0,
    IDE03189-ENG104142,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Brake Boost,0,
    IDE03189-ENG100353,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Fuel Mixture Adaption,0,
    IDE03189-ENG100878,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Random,0,
    IDE03189-ENG101433,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Regeneration Mode,0,
    IDE03189-ENG100557,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Start Behavior:,0,
    IDE03190-ENG100538,Number of requested start processes (statistics)-SSEUI Counter Start Desired By Brake Boost,0, counts
    IDE03190-ENG102427,Number of requested start processes (statistics)-SSEUI Day Start Desired By Brake Boost,0,
    IDE03190-ENG99329,Number of requested start processes (statistics)-SSEUI Hours Start Desired By Brake Boost,0,
    IDE03190-ENG102737,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Brake Boost,0, km
    IDE03190-ENG102760,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Brake Boost,0,
    IDE03190-ENG100816,Number of requested start processes (statistics)-SSEUI Month Start Desired By Brake Boost,0,
    IDE03190-ENG103223,Number of requested start processes (statistics)-SSEUI Year Start Desired By Brake Boost,0,
    IDE03246,Neutral position sensor: upper adaptation value,-0.0, °C
    IDE03247,Neutral position sensor: lower adaptation value,-0.0, °C
    IDE03262,Adapt of angle sensor 1 f throttle valve,0.530, V
    IDE03263,Adapt of angle sensor 2 f throttle valve,4.471, V
    IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.728, V
    IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.264, V
    IDE03362,Requested transmission torque,1000.0, Nm
    IDE03363,Numb.of misfir.: cylinder 5,0,
    IDE03364,Numb.of misfir.: cylinder 6,0,
    IDE03365,Numb.of misfir.: cylinder 7,0,
    IDE03366,Numb.of misfir.: cylinder 8,0,
    IDE03367,Numb.of misfir.: cylinder 9,0,
    IDE03368,Numb.of misfir.: cylinder 10,0,
    IDE03393-ENG57549,Selector lever position-Bits 0-7,8,
    IDE03406,Throttle valve position bank 2: normed,4.265, V
    IDE03493-ENG121091,Driver door status-Dsplb Drv Door Act Opn,1,
    IDE03583-ENG57549,Engine shut-down overrides-Bits 0-7,25,
    IDE03584-ENG57549,Engine starting requirements-Bits 0-7,0,
    IDE03585,System status for the start/stop function master,0,
    IDE03586-ENG57549,Starting requirements for active participants-Bits 0-7,0,
    IDE03587-ENG57549,Stop overrides for active participants-Bits 0-7,2,
    IDE03587-ENG57549,Stop overrides for active participants-Bits 0-7,0,
    IDE03588-ENG57549,System malfunctions for active participants start/stop-Bits 0-7,0,
    IDE03589-ENG57549,Error status for start-stop related sensors-Bits 0-7,6,
    IDE03660,Longitudinal acceleration,-0.001, m/s²
    IDE03692-ENG57549,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7,202,
    IDE03693-ENG57549,Monitoring status of additional Onboard Diagnosis-Bits 0-7,229,
    IDE03700,Status adaptation dew point end,ADP is running,
    IDE03700-ENG127325,Status adaptation dew point end-Test_Program_Channel 860,1,
    IDE03709,Angle difference actual-specified camshaft adjuster,0.000, °
    IDE03711,Mass flow through throttle valve,0.0, kg/h
    IDE03767,Engine status,COENG_READY,
    IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,1,
    IDE03795,Camshaft adjustment: exhaust: bank 1: activation,0.000, %
    IDE03805,Test of brake booster pump: result,Test off,
    IDE03805-ENG127323,Test of brake booster pump: result-Test_Program_Channel 603,235,
    IDE03806-ENG57549,Oxygen sensor bank 1 sensor 1: status-Bits 0-7,0,
    IDE03807-ENG57549,Oxygen sensor bank 1 sensor 2: status-Bits 0-7,0,
    IDE03813,Test of secondary air system: result,Test off,
    IDE03813-ENG129327,Test of secondary air system: result-Test_Program_Channel 239,235,
    IDE03814,Test of secondary air system: deviation mass air flow Bank 1,0.000,
    IDE03816,Exhaust flap bank 1,OFF,
    IDE03816-ENG129421,Exhaust flap bank 1-Test_Program_Channel 825,136,
    IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,131070.000, Ohm
    IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,1,
    IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,Htg.aC.OFF,
    IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,217,
    IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,1916.72, Ohm
    IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,0.000, %
    IDE03830,Status of adaptation of on-demand fuel pump,Test off,
    IDE03830-ENG129410,Status of adaptation of on-demand fuel pump-Test_Program_Channel 1021,235,
    IDE03836,Result of O2 sensor aging test bank 1 after cat. conv.,B1-S2 OK,
    IDE03836-ENG129323,Result of O2 sensor aging test bank 1 after cat. conv.-Test_Program_Channel 2114,209,
    IDE03876,Misfires per 1000 revolutions of cylinder 5,0,
    IDE03877,Misfires per 1000 revolutions of cylinder 6,0,
    IDE03878,Misfires per 1000 revolutions of cylinder 7,0,
    IDE03879,Misfires per 1000 revolutions of cylinder 8,0,
    IDE03953,Oxygen control: adaptation value at partial load: bank 1,1.00000,
    IDE03954-ENG112663,Throttle valve adaptation steady state condition-Badko se,0,
    IDE03955-ENG114936,Intake manifold pressure model steady state condition-Bapsl mdse,0,
    IDE03966,Transmission neutral position sensor PWM signal,-0.0, °C
    IDE04013,Mass airflow sensor,MAF A:0.00 g/s / MAF B:0.00 g/s,
    IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:600/--- kPa,
    IDE04083,Coolant temperatures,ECT 1:23 °C / ECT 2:23 °C,
    IDE04085,Throttle valve,THR A cmd/rel:2/4 % / THR B cmd/rel:2/4 %,
    IDE04234,Heat quantity f dew pt end before cat conv bank 1: modeled,0.000000, kJ
    IDE04236,Heat quantity f dew pt end behind fr cat conv bank 1: modeled,0.000000, kJ
    IDE04238,Heat quantity f dew pt end behind main cat conv bank 1: modeled,0.000000, kJ
    IDE04240,Counter start bef dew pt end f O2 sensor bef cat conv bank1,0,
    IDE04242,Counter start bef dew pt end f O2 sensor beh fr cat conv bank1,0,
    IDE04244,Count start bef dew pt end f O2 sensor beh main cat conv bank1,0,
    IDE04410,Intake manifold pressure: target value,384.22, hPa
    IDE04414,Cat conv temp: modeled,20, °C
    IDE04420,Activation of secondary air system,Atmosphere/off,
    IDE04468,Air mass at air mass meter 1,0.0, kg/h
    IDE04491,Temp sensor for fuel tank leakage diagnosis,-48.0, °C
    IDE04604,Accelerator pedal travel,0.00, %
    IDE04615,Segment adaptation for rough running: status,0,
    IDE04637,Engine temperature management actuator,0.00, %
    IDE04638,Transmission coolant valve,False result,
    IDE04638-ENG127289,Transmission coolant valve-Test_Program_B TRUE UBYTE,0,
    IDE04651,Torque request: A/C compressor,0.0, Nm
    IDE04654-ENG57549,CAN status - engine control module-Bits 0-7,0,
    IDE04655-ENG57549,CAN status - transmission control module-Bits 0-7,0,
    IDE04656-ENG57549,CAN status - brake control module 1-Bits 0-7,0,
    IDE04657-ENG57549,CAN status - brake control module 2-Bits 0-7,0,
    IDE04670,Crankshaft signal evaluation: status,WAITSIG,
    IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,2,
    IDE04677,O2 sensor 1 bank 1: O2 sensor actual value,12.8640,
    IDE04689,Starter control: Start interruption status,False result,
    IDE04689-ENG127289,Starter control: Start interruption status-Test_Program_B TRUE UBYTE,0,
    IDE04691,Calculated reducing transmission intervention torque,1000.0, Nm
    IDE04692,Reducing desired torque intervention of ESP,50000.0, Nm
    IDE04693,Increasing desired torque intervention of ESP,-50000.0, Nm
    IDE04695-ENG99946,Immobilizer snapshot A-Sia Error Snap A,00 00 00,
    IDE04696-ENG102592,Immobilizer snapshot B-Sia Error Snap B,00 00 00,
    IDE04814,Transmission oil cooler valve,False result,
    IDE04814-ENG127289,Transmission oil cooler valve-Test_Program_B TRUE UBYTE,0,
    IDE04820,Fuel content due to degassing of engine oil,0.00, %
    IDE04858,Brake booster low pressure actual value,27.85, hPa
    IDE04872,Brake pedal value sensor: relative value filtered,72.0, mV
    IDE04887,Powertrain target torque,-81.8, Nm
    IDE04889,Target torque for combustion engine crankshaft level,-75.8, Nm
    IDE04933,Number of fill level decreases,114,
    IDE04934,Last odometer reading since fill level decrease,0, km
    IDE04935,Next to last odometer reading since fill level decrease,0, km
    IDE04936,3. Last odometer reading since fill level decrease,60, km
    IDE04967,Misfires per 1000 revolutions of cylinder 9,0,
    IDE04968,Misfires per 1000 revolutions of cylinder 10,0,
    IDE05128,Intake air temperature in intake manifold bank 1,32.3, °C
    IDE05138,Shut-off timer: last engine shut-off time,655865, s
    IDE05221,E-machine torque actual value,0.0, Nm
    IDE05240-ENG57549,Request for A/C compressor power reduction-Bits 0-7,0,
    IDE05241-ENG57549,A/C compressor release status-Bits 0-7,0,
    IDE05261-ENG57549,Gear position sensor: last valid value-Bits 0-7,14,
    IDE05327,Activation for electrical reserve coolant pump in HT circuit,0.00, %
    IDE05332-ENG57549,Heat request from heater to thermal management-Bits 0-7,3,
    IDE05333,Indicator light in AUTO HOLD button,6,
    IDE05436,Engine operating condition,Idling,
    IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
    IDE05437,Outside air temperature via CAN,-48.0, °C
    IDE05438,Rear cat conv temp main cat conv model value,23.99, °C
    IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000000,
    IDE05441,ESI: Wear equivalent 2 calculated from wear index,0.00000000,
    IDE05442,Roadway slope angle acceleration interface: calculated,0.0000, rad
    IDE05444,Air filling: specified value,18.19, %
    IDE05445,Pressure before throttle valve of pressure sensor,983.83, hPa
    IDE05449,Oxygen sensor 2 bank 1 internal resistance limit value,700, Ohm
    IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00003,
    IDE05468,Oxygen sensor 1 bank 1 ceramic temp,594.34, °C
    IDE05470,Cat converter oxygen storage capacity,0.0, mg
    IDE05474,Main cat converter OSC age correction factor,1.000,
    IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
    IDE05478,Exh mss flw bef main cat conv bank 1 filtered,0.0, kg/h
    IDE05479,Misfire recognition reference moment,2.885, %
    IDE05482,Tank venting adaptation factor,0.000,
    IDE05484,Power steering pump desired actual moment for idling control,0.0, Nm
    IDE05485-ENG57549,Irregular shutdown of the counter control mod-Bits 0-7,0,
    IDE05486,Current system status,SYC_DRIVE,
    IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
    IDE05487,Coolant temperature linearized value,23.499, °C
    IDE05488,Coolant temperature modeled value,23.3, °C
    IDE05489,Coolant temperature max value,-48.0, °C
    IDE05490,Coolant temperature min value,143.3, °C
    IDE05491,Intake air temperature max value,32.3, °C
    IDE05492,Intake air temperature min value,32.3, °C
    IDE05508,Adaptation val cyl 1 with slow diagnosis,1.00000,
    IDE05509,Adaptation val cyl 3 with slow diagnosis,1.00000,
    IDE05510,Adaptation val cyl 4 with slow diagnosis,1.00000,
    IDE05511,Adaptation val cyl 2 with slow diagnosis,1.00000,
    IDE05512,Adaptation val cyl 1 with fast diagnosis,1.00000,
    IDE05513,Adaptation val cyl 3 with fast diagnosis,1.00000,
    IDE05514,Adaptation val cyl 4 with fast diagnosis,1.00000,
    IDE05515,Adaptation val cyl 2 with fast diagnosis,1.00000,
    IDE05593,Secondary air injection sensor 1,980.47, hPa
    IDE05797,Throttle valve adapter: specified value,2.000, %
    IDE05844,Pre-ignition counter cylinder 3,0,
    IDE05928,Fuel consumption since DTC memory last erased,59.032, l/100km
    IDE05941-ENG112665,Enable condition: camshaft control-Bnws,0,
    IDE05947,Pre-ignition counter cylinder 1,0,
    IDE05948,Pre-ignition counter cylinder 2,0,
    IDE05949,Pre-ignition counter cylinder 4,0,
    IDE06006,Idle speed specified value,930, /min
    IDE06017,Camshaft position deviation from reference position,0.00, °
    IDE06020,Intake air temperature in intake manifold bank raw value,32.3, °C
    IDE06023-ENG57549,BDE operating mode flag register-Bits 0-7,1,
    IDE06039,Required RPM at idle speed,930.0, /min
    IDE06040,High fuel pressure: regulator output value,0.0000, MPa
    IDE06041-ENG57549,PDTC drive cycle conditions status-Bits 0-7,0,
    IDE06043,Cylinder head temperature: actual value,23.2, °C
    IDE06045-ENG57549,Output DTM status-Bits 0-7,0,
    IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
    IDE06049,Pressure in brake booster: raw value,955.98, hPa
    IDE06098,Sensor control factor: output value,1.00000,
    IDE06192,Knock sensor: cylinder 2: voltage,16.768, V
    IDE06193,Knock sensor: cylinder 3: voltage,16.768, V
    IDE06194,Knock sensor: cylinder 4: voltage,16.768, V
    IDE06195,Knock sensor: cylinder 1: voltage,16.768, V
    IDE06255,Vehicle lateral acceleration,0.00, g
    IDE06256,Vehicle lateral acceleration: raw value,0.00, g
    IDE06257,Vehicle inclination acceleration angle: raw value,-0.001, m/s²
    IDE06386,Oil level: static measurement,0.000, mm
    IDE06387,Oil level: last valid dynamic value,20.688, mm
    IDE06388,Oil level: condition for static measurement fulfilled,0,
    IDE06391,Oil temperature sensor 2,23.7, °C
    IDE06392,Oil temperature sensor 2: raw value,3424.8, mV
    IDE06393,Oil level: dynamic average value,21.768, mm
    IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
    IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
    IDE06434-ENG112927,Oxygen control: bank 1: sensor 1: release status-Blrnd A,0,
    IDE06435,A/C compressor: refrigerant pressure,0, hPa
    IDE06436,A/C compressor: refrigerant pressure: raw value,0.00, %
    IDE06445,Longitudinal acceleration: raw value,0.000, m/s²
    IDE06446-ENG57549,Status: incline angle-Bits 0-7,0,
    IDE06552,Time since terminal 15 ON,221500, ms
    IDE06567-ENG57549,Start-stop function deactivation frequency counter-Bits 0-7,0,
    IDE06568-ENG57549,Stop prevention by driver frequency counter-Bits 0-7,0,
    IDE06569-ENG57549,Vehicle stopped frequency counter-Bits 0-7,0,
    IDE06570,Oil level and oil temp. sensor: oil temperature in oil pan,23.7, °C
    IDE06610-ENG57549,Vehicle standstill with stop frequency counter-Bits 0-7,0,
    IDE06647-ENG57549,Start-stop switch status-Bits 0-7,1,
    IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,2,
    IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,128,
    IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,0,
    IDE06703-ENG57549,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
    IDE06704-ENG57549,Drivetrain coordinator: brake fault status-Bits 0-7,1,
    IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,32,
    IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,4,
    IDE06706-ENG57549,ACC variants-Bits 0-7,0,
    IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,1,
    IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,49,
    IDE06709-ENG57549,ACC variants (coding)-Bits 0-7,1,
    IDE06710-ENG57549,Cruise control system: permanent deactivation-Bits 0-7,255,
    IDE06711-ENG57549,Cruise control system: temporary deactivation-Bits 0-7,255,
    IDE06758,Air mass since engine start,0.00, kg
    IDE06759,Cam shaft adaptation inlet: counter,30,
    IDE06760,Camshaft adaptation: exhaust: counter,30,
    IDE06761,Adaptation val cyl 5 with slow diagnosis,1.00000,
    IDE06762,Adaptation val cyl 5 with fast diagnosis,1.00000,
    IDE06799-ENG57549,A/C compressor status: HW input-Bits 0-7,0,
    IDE06800,A/C main switch status,1,
    IDE06944,A/C compressor: load current: act. value,0.00, A
    IDE06946-ENG57549,Brake actuated status-Bits 0-7,0,
    IDE06956-ENG57549,Driver-side belt buckle status-Bits 0-7,2,
    IDE07001,Piston-cooling jets: activation,1,
    IDE07002,Exhaust flap: activation,0.00, %
    IDE07031,Oil pressure switch for piston-cooling jets: status,0,
    IDE07036,Secondary air system: diagnostic status,0,
    IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,94,
    IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,102,
    IDE07051-ENG57549,Engaged gear: raw signal-Bits 0-7,0,
    IDE07055,Selector lever: status: monitoring,2,
    IDE07164,Number injections,0,
    IDE07170,Clutch K0: torque,0.0, Nm
    IDE07194,Calculated increasing transmission engagement torque,-3276.8, Nm
    IDE07224-ENG57549,Overrun cut-off-Bits 0-7,0,
    IDE07229,Pre-ignition counter cylinder 5,0,
    IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,0,
    IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,132,
    IDE07234,Status bid for valid static oil level,0,
    IDE07235,Status bid for dynamic oil level,0,
    IDE07238,Status of power transfer,0.00,
    IDE07242,Heater support pump: spec. value,10.00, %
    IDE07254,Gasoline pressure tank refueling request button,0,
    IDE07475,Throttle valve position 2,5.47, %
    IDE07573,Throttle valve adapter: actual value,5.59, %
    IDE07615,Operating of tank: empty or reserve,too Low,
    IDE07615-ENG129324,Operating of tank: empty or reserve-Test_Program_Channel 372,91,
    IDE07620-ENG57549,Status momentary default during stability intervention-Bits 0-7,0,
    IDE07664,Pre-coordinated torque of increased stability intervention,-50000.0, Nm
    IDE07665,Accel. pedal kick-down recognition: voltage threshold,4125.2, mV
    IDE07724,Coolant temperature at engine outlet: calculated,23.2, °C
    IDE07840-ENG57549,Status plausibility accelerator pedal to brake pedal-Bits 0-7,0,
    IDE07904-ENG57549,Brake test switch status-Bits 0-7,0,
    IDE07905-ENG57549,Brake light switch status-Bits 0-7,0,
    IDE07906-ENG57549,Upper clutch switch: status-Bits 0-7,0,
    IDE07908,Coolant fan activation requested by A/C,0.00, %
    IDE09529,Fuel mass flow rate due to degassing of eng. oil,0.0, mg/s
    IDE09531,Total mass of gasoline and alcohol in oil,0.00, g
    IDE09572,O2 sensor dwnstrm. of cat.: gradient transfer lean -> rich,0.00, s
    IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.00, s
    IDE09693-ENG57549,Charisma driving program: system status-Bits 0-7,0,
    IDE09695-ENG57549,Charisma driving program: target value from coordinator-Bits 0-7,2,
    IDE09696-ENG57549,Charisma driving program: CAN output value-Bits 0-7,2,
    IDE09925-ENG57549,Intake camshaft bank 1: adaption error cause-Bits 0-7,0,
    IDE09926-ENG57549,Outlet camshaft bank 1: adaption error cause-Bits 0-7,0,
    IDE09927,Intake camshaft bank 1: adaption hardware offset active,False result,
    IDE09927-ENG127289,Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
    IDE09928,Outlet camshaft bank 1: adaption hardware offset active,False result,
    IDE09928-ENG127289,Outlet camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
    IDE09942,Long-term adaptation of mixture formation FSI: additive,0.00, %
    IDE09943,Long-term adaptation of mixture formation FSI: multiplicative,1.00000,
    IDE09944,Long-term adaptation of mixture formation MPI: additive,-0.61, %
    IDE09945,Long-term adaptation of mixture formation MPI: multiplicative,0.99750,
    IDE10040,Outlet camshaft bank 1 active operating mode,0,
    IDE10041,Intake camshaft bank1 active operating mode,0,
    IDE10042,Outlet camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
    IDE10042-ENG127372,Outlet camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
    IDE10043,intake camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
    IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
    IDE10302,Time since engine start,0.0, s
    IDE10303,Integrated air masse at first engine start,0.0000, kg
    IDE10630,O2 sensor upstrm. of cat.: delay time transf. rich -> lean,0.00, s
    IDE10641,Low fuel pressure adaptation value for EFP: modeled,0.0, kPa
    IDE10670,O2 sensor upstrm. of cat.: filter constant transf. rich -> lean,0.00, s
    IDE10710,Exhaust warning light: triggering contr. module,---|---|---|---|---|---|---|---,
    IDE10710-ENG129321,Exhaust warning light: triggering contr. module-Test_Program_MIL Lmp Req Verb UBYTE,0,
    IDE11297,Heat qty.thresh.for dewpoint end dwn.strm. of main cat: bank1,2350.193778, kJ
    IDE11931,Heated oxygen sensor bank 1 sensor 1: positioning intervention rear cat controller,0.00021,
    IDE12355,ESI: consumption equivalent of the engine control module,0.00000000,
    IDE12914,Fuel low pressure 2: actual value,0.0, kPa
    IDE12915,Throttle 1: bank 1: position sensor 1: raw voltage,0.728, V
    IDE12916,Throttle 1: bank 1: position sensor 2: raw voltage,4.266, V
    IDE12923,Lambda regulation: bank 1: output value,1.00000,
    IDE12928,Lambda regulation: bank 1: filtered average output value,1.00000,
    IDE12936,Ignition angle: bank 1 raw value,0.0, °
    IDE13301,Drivetrain coordinator: brake fault status,1,
    IDE13336,Drive train coordinator reversible switch off conditions,41975810,
    IDE13337,Drive train coordinator irreversible switch off conditions,0,
    IDE13772,Engine protection torque limitation,1000.0, Nm
    IDE13774,Engine protection external torque limitation,1000.0, Nm
    IDE14242,Oil pressure valve for piston cooling nozzles: control switch button ratio,100.00, %
    IDE14247,Exhaust flap: position feedback actual value,0.00, %
    IDE14901,secondary air system: difference between specified and ambient pressure,0.00, hPa
    IDE14902,Secondary Air System: Differential Pressure pump and valve,0.00, hPa
    MAS16074,Temperature in pre-cat bank 1: model value,24.0, °C
    MAS16089,Lambda component protection: bank 1: specified value,1.0000,
    MAS16091,Lambda Delta from exhaust gas temperature regulation bank 1: actual value,0.0000,
    MAS16097,Tank ventilation factorial fuel amount: actual value,0.000,
    MAS16098,Tank ventilation relative mixture proportion: actual value,0.00, %
    MAS16301,Sensor adaptation: status with engine running,0,
    MAS16534-ENG57549,A/C compressor info: switch-off status-Bits 0-7,0,
    MAS16534-ENG57549,A/C compressor info: switch-off status-Bits 0-7,1,
    MAS16543,Bank 1 heated oxygen sensor downstream of catalytic converter: exhaust gas temperature calculated,23.94, °C
    MAS17038,Heated oxygen sensor 2 bank 1: heat output normalized,0.00,
    MAS17039,Heated oxygen sensor 1 Bank 1: target voltage adequate for lean conditions,1.000, V
    MAS17045,Heated oxygen sensor 2 bank 1: internal resistance,131070, Ohm
    MAS17047,Heated oxygen sensor 2 Bank 1: target voltage adequate for rich conditions,0.000, V
    MAS17055,Heated oxygen sensor 1 bank 1: identified total time (lean -> rich),0.00, s
    MAS17056,Heated oxygen sensor 1 Bank 1: adaptation value for filtering time constants,0.00, s
    MAS17058,Heated oxygen sensor 1 Bank 1: adaptation value for dead time,0.00, s
    MAS17059,Heated oxygen sensor 1 bank 1: identified total time (rich -> lean),0.00, s
    ENG105037,Acc Ped trq Des,-81.8, Nm
    ENG105054,Act Mod trq Clth,-75.8, Nm
    ENG105091,Afmim n,0.0, %
    ENG105092,Afmim x,0.0, %
    ENG105093,Afnmn,0, /min
    ENG105094,Afnmx,0, /min
    ENG105095,AFS dm,0.0, kg/h
    ENG112666,Air conditioner pressure linearised raw value,0, hPa
    ENG112928-ENG57549,Air_conditioning_compressor_actual_status-Bits 0-7,0,
    ENG105149,Air_mass_integral_for_thermostat_diagnosis_actual_value,0.00, kg
    ENG105150,Air_mass_integral_for_thermostat_diagnosis_limit_value,8.47, kg
    ENG106228,Ambient air pressure,983, hPa
    ENG106231,Ambient temperature,24.0, °C
    ENG105189,Anzhr dynaw,0,
    ENG105192,APP r,0.00, %
    ENG120760,B slp,False result,
    ENG120760-ENG127289,B slp-Test_Program_B TRUE UBYTE,0,
    ENG120761,B slv,False result,
    ENG120761-ENG127289,B slv-Test_Program_B TRUE UBYTE,0,
    ENG105385,C Eng Us T t,95.0, °C
    ENG101413,Calibration Identification,4S0552AC0001ATGK,
    ENG99697,Calibration Verification Number,70 2D D4 54,
    ENG105051,CCS limiting torque,-50000.0, Nm
    ENG01773-ENG57549,Configuration_of_cruise_control-Bits 0-7,104,
    ENG106503,Coolant temperature at radiator outlet,23.2, °C
    ENG126402-ENG57549,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
    ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,68,
    ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,24,
    ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,4,
    ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,1,
    ENG122710,Cruise_control_velocity_setpoint,0.000, km/h
    ENG111031-ENG57549,DFC_status_error_debounced_counter-Bits 0-7,0,
    ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,49,
    ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,3,
    ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,120,
    ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,1,
    ENG126404-ENG57549,Drive_train_coordinator_checked_coding-Bits 0-7,2,
    ENG112930,Driving_torque_coordinator_requested_driving_torque_from_GRA,-50000.0, Nm
    ENG111582,DrivingProgramSwitch_sport_mode_activated,False result,
    ENG111582-ENG127289,DrivingProgramSwitch_sport_mode_activated-Test_Program_B TRUE UBYTE,0,
    ENG100152-ENG104003,ECUNAME-ECU,ECM1,
    ENG100152,ECUNAME,EngineControl1,
    ENG114220,Effective_injection_duration,0.000, ms
    ENG112932,Engine_oil_temperature_measured_value,23.7, °C
    ENG111034,Engine_temperature_modelbased_substitute_value,32.3, °C
    ENG106223,Engine_torque_limitation_mechanical,1000.0, Nm
    ENG111610,Epm Ca S phi Adap Ref Pos O1 mp 0,69.39, °
    ENG121110,Epm Ca S phi Adap Ref Pos O1 mp 1,101.54, °
    ENG111043,Evaporative_emission_system_successful_mixture_checks_counter,0,
    ENG111044,Evaporative_emission_system_unsuccessful_mixture_checks_counter,0,
    ENG08887,Exh Dv T t Snsr Mdl Eng Bay Fild,23.9, °C
    ENG08886,Exh Dvt t Eng Bay,0.0, °C
    ENG08888,Exh T Snsr t Val Sent Snsr Plus Offs,48.1, °C
    ENG114499,Fan Ctl t Clnt Des Diff,81.8, °C
    ENG106507,Fan r Ps,10.00, %
    ENG106510,Fan r2 Ps,10.00, %
    ENG111607,Frequency_counters_for_test_signal_histogram,44,
    ENG106677,Frm w,1.00000,
    ENG08633-ENG20891,Fuel System Percentage Use-Fuel System A Use Percentage Bank 1,0.0, %
    ENG08633-ENG20899,Fuel System Percentage Use-Fuel System A Use Percentage Bank 1 supported,Available,
    ENG08633-ENG20893,Fuel System Percentage Use-Fuel System A Use Percentage Bank 2,0.0, %
    ENG08633-ENG20901,Fuel System Percentage Use-Fuel System A Use Percentage Bank 2 supported,Available,
    ENG08633-ENG20895,Fuel System Percentage Use-Fuel System A Use Percentage Bank 3,0.0, %
    ENG08633-ENG20903,Fuel System Percentage Use-Fuel System A Use Percentage Bank 3 supported,Not available,
    ENG08633-ENG20897,Fuel System Percentage Use-Fuel System A Use Percentage Bank 4,0.0, %
    ENG08633-ENG20905,Fuel System Percentage Use-Fuel System A Use Percentage Bank 4 supported,Not available,
    ENG08633-ENG20892,Fuel System Percentage Use-Fuel System B Use Percentage Bank 1,0.0, %
    ENG08633-ENG20900,Fuel System Percentage Use-Fuel System B Use Percentage Bank 1 supported,Available,
    ENG08633-ENG20894,Fuel System Percentage Use-Fuel System B Use Percentage Bank 2,0.0, %
    ENG08633-ENG20902,Fuel System Percentage Use-Fuel System B Use Percentage Bank 2 supported,Available,
    ENG08633-ENG20896,Fuel System Percentage Use-Fuel System B Use Percentage Bank 3,0.0, %
    ENG08633-ENG20904,Fuel System Percentage Use-Fuel System B Use Percentage Bank 3 supported,Not available,
    ENG08633-ENG20898,Fuel System Percentage Use-Fuel System B Use Percentage Bank 4,0.0, %
    ENG08633-ENG20906,Fuel System Percentage Use-Fuel System B Use Percentage Bank 4 supported,Not available,
    ENG111608,Fuel_consumption_actual_driving_cycle,0.000, l
    ENG106769-ENG57549,Gearbox_heat_request-Bits 0-7,1,
    ENG112667,Generator load normalised value,0.00, %
    ENG112931,Generator_load_from_CAN,0, W
    ENG112929,Generator_torque_request,0.0, Nm
    ENG106781-ENG57549,Glb Da Max Val 0-Bits 0-7,50,
    ENG106781-ENG57549,Glb Da Max Val 0-Bits 0-7,0,
    ENG106781-ENG57549,Glb Da Max Val 0-Bits 0-7,58,
    ENG106782-ENG57549,Glb Da Max Val 1-Bits 0-7,0,
    ENG106782-ENG57549,Glb Da Max Val 1-Bits 0-7,14,
    ENG106782-ENG57549,Glb Da Max Val 1-Bits 0-7,155,
    ENG106783-ENG57549,Glb Da Max Val 2-Bits 0-7,0,
    ENG106783-ENG57549,Glb Da Max Val 2-Bits 0-7,170,
    ENG106783-ENG57549,Glb Da Max Val 2-Bits 0-7,201,
    ENG106784-ENG57549,Glb Da Max Val 3-Bits 0-7,0,
    ENG106784-ENG57549,Glb Da Max Val 3-Bits 0-7,89,
    ENG106784-ENG57549,Glb Da Max Val 3-Bits 0-7,121,
    ENG106785-ENG57549,Glb Da Max Val 4-Bits 0-7,0,
    ENG106785-ENG57549,Glb Da Max Val 4-Bits 0-7,8,
    ENG106785-ENG57549,Glb Da Max Val 4-Bits 0-7,17,
    ENG121111-ENG57549,Glb Da Max Val 5-Bits 0-7,0,
    ENG110577-ENG57549,Glb Da Min Val 0-Bits 0-7,0,
    ENG121112-ENG57549,Glb Da Min Val 1-Bits 0-7,0,
    ENG107045,Intake_manifold_model_air_mass_flow_filtered_value,0.0, kg/h
    ENG100634,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2,2, counts
    ENG107236,Knock_sensor_cylinder_5_voltage,16.768, V
    ENG107309,Krivk w,5.16, Ohm
    ENG121113,Kvakb i w,0, µl
    ENG110574,Lambdacoordination_homogeneous_mode_range_limited_commanded_value,1.0000,
    ENG111606,Load value: unrestricted commanded value,11.67, %
    ENG125271,Maximum_ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.000,
    ENG107621,Milso l w,9.470, %
    ENG111040,Misfire_detection_sensor_wheel_adaptation_speed_load_range_index,0,
    ENG111581-ENG57549,Mode_control_start_order_combustion_engine-Bits 0-7,0,
    ENG112668,O2 sensor_controller_bank_1_p-rate,0.00000,
    ENG108178,Pbksi a w,0.0, kPa
    ENG108262,Powertrain_overall_gear_ratio,1.00,
    ENG111605,Pressure_before_throttle_valve_actual_value,983.83, hPa
    ENG108339,Psr w,983.83, hPa
    ENG108343,Pu w,983.83, hPa
    ENG125270,Ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.000,
    ENG109006,Spark_efficiency_deviation_at_idle_maximum,2.3, %
    ENG109007,Spark_efficiency_deviation_at_part_load_maximum,2.3, %
    ENG121093-ENG57549,State_of_cruise_control_or_speedlimiter-Bits 0-7,6,
    ENG01786-ENG57549,State_of_requestor_for_drivetrain_coordinator-Bits 0-7,6,
    ENG109344,Tasrg w,32.2, °C
    ENG111611,Tavso w,23.99, °C
    ENG109625,Temperature at air conditioner heat exchanger output,95.0, °C
    ENG01775,Top_speed_limitation,511.000, km/h
    ENG109528,Torque_coordination_idle_speed_control_torque_actual_value_air_path,0.0, Nm
    ENG109529,Torque_coordination_idle_speed_control_torque_SET_path_actual_value,0.0, Nm
    ENG01785-ENG57549,Transmission_state_of_drivetrain_coordinator-Bits 0-7,0,
    ENG01785-ENG57549,Transmission_state_of_drivetrain_coordinator-Bits 0-7,4,
    ENG109626,TS t Clnt Eng Out,23.2, °C
    ENG109653,Tumg,24.0, °C
    ENG111604,Turbocharger_inlet_pressure_corrected_value,983.83, hPa
    ENG121117,Udkp1 w,0.729, V
    ENG109861,Vehicle speed,0.00, km/h
    ENG01774,Velocity_limiter_setpoint,511.992, km/h
    Elapsed Time: 00:48
    adpmap-01-4S0-907-552-AC
    ;Saturday,10,August,2019,09:36:42:30091
    IDE02332-Deactivate production mode,00 00 00 ,3
    IDE03875-Activation of start-stop function,not active ,1
    IDE07855-Deactivation of warm travel request,active ,1
    IDE10261-MAS10172-Operating mode selec.-DI operation,not activated ,4
    IDE10261-MAS10174-Operating mode selec.-CNG operation,not activated ,4
    IDE10261-Operating mode selec.-,not activated ,4
    Elapsed Time: 00:01
    Address - [11]
    blockmap-11-4S0-907-552-AC
    ;SW:4S0-907-552-AC   HW:4S0-907-552-R ---  Engine II
    ;EV_ECM52FSI2114S0907552AC,001002,EV_ECM52FSI2114S0907552AB.rod
    ;Saturday,10,August,2019,09:43:29:30091
    IDE00019,Voltage terminal 30,12.460, V
    IDE00151,Oil fill level,57.728, mm
    IDE00160,Timing angle retardation cylinder 6,0.0, °
    IDE00161,Timing angle retardation cylinder 7,0.0, °
    IDE00162,Timing angle retardation cylinder 8,0.0, °
    IDE00163,Timing angle retardation cylinder 9,0.0, °
    IDE00164,Timing angle retardation cylinder 10,0.0, °
    IDE00168,Exhaust temperature 1 bank 2,23.9, °C
    IDE00176,Camshaft adjustment: exhaust: bank 2: specified value,-17.000, °
    IDE00177,Camshaft adjustment: exhaust: bank 2: actual value,-17.000, °
    IDE00180,Camshaft adjustment intake bank 2: specified value,12.000, °
    IDE00181,Camshaft adjustment intake bank 2: actual value,12.000, °
    IDE00183,Camshaft adaptation intake bank 2: phase position,0.00, °
    IDE00185,Camshaft adaptation exhaust bank 2: phase position,0.00, °
    IDE00186,Fuel low pressure: actual value,697.5, kPa
    IDE00252,Brake system vacuum pump,invalid,
    IDE00252-ENG127370,Brake system vacuum pump-Test_Program_Channel 601,115,
    IDE00348,Intake air temperature,33, °C
    IDE00355-ENG57549,Cruise Control System (CCS): status-Bits 0-7,0,
    IDE00380,Coolant fan 1: activation,0.00, %
    IDE00381,Coolant fan 2: activation,0.00, %
    IDE00394,Camshaft position: start of phase window,110.68, °
    IDE00416-ENG57549,Starter control: terminal 50 acknowledgment-Bits 0-7,0,
    IDE00565-MAS04135,Current of oxygen sensor bank 2 sensor 1 (broadband sensor)-Oxygen sensor value,0.996, lambda
    IDE00565-MAS04136,Current of oxygen sensor bank 2 sensor 1 (broadband sensor)-Current,127.97265625, mA
    IDE00566-MAS04121,Oxygen sensor bank 2 sensor 2 (jump sensor)-Voltage,1.275, V
    IDE00566-MAS04122,Oxygen sensor bank 2 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
    IDE00595,Allocation of oxygen sensors,  / B2S1 B2S2  ,
    IDE00598,Long term adaptation of mixture formation bank 2,-2.3, %
    IDE00605,Short term adaptation of mixture formation bank 2,0.0, %
    IDE00699,ESI: minimum oil level in service interval,19.296, mm
    IDE00700,ESI: maximum oil level in service interval,25.100, mm
    IDE00739,Test of oxygen sensors bank 2: Delta-Lambda,0.00012,
    IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
    IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
    IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
    IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
    IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
    IDE01639,Dynamic factor O2 sensors bank 2 or bank 4 before cat. conv.,1.0000,
    IDE01640,Result O2 sensor aging test bank 2 or 4 before cat. conv.,Test off,
    IDE01640-ENG129411,Result O2 sensor aging test bank 2 or 4 before cat. conv.-Test_Program_Channel 1022,235,
    IDE01645,Oxygen sensor voltage bank 2 after catalytic converter,1.661, V
    IDE01647,Result of O2 sensor aging test bank 2 after cat. conv.,Test off,
    IDE01647-ENG129417,Result of O2 sensor aging test bank 2 after cat. conv.-Test_Program_Channel 379,235,
    IDE01649,Throttle valve position 1,5.81, %
    IDE01666,Result of test of camshaft adjustment intake bank 2,Test off,
    IDE01666-ENG127298,Result of test of camshaft adjustment intake bank 2-Test_Program_Channel 140,235,
    IDE01668,Result of test of camshaft adjustment outlet bank 2,Test off,
    IDE01668-ENG127371,Result of test of camshaft adjustment outlet bank 2-Test_Program_Channel 619,235,
    IDE01834,Battery voltage,12460, mV
    IDE01887,Adaptation of Fuel Pump (FP),0.0, kPa
    IDE01899,Load value: corrected specified value,117.09, %
    IDE01901,Lost torque adaptation: idle,0.0, Nm
    IDE01902,Lost torque adaptation A/C compressor,0.0, Nm
    IDE01923,Control module distance driven,64567, m
    IDE01977,Numb.of misfir.: cylinder 3,1,
    IDE03262,Adapt of angle sensor 1 f throttle valve,0.522, V
    IDE03263,Adapt of angle sensor 2 f throttle valve,4.481, V
    IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.732, V
    IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.272, V
    IDE03364,Numb.of misfir.: cylinder 6,3,
    IDE03365,Numb.of misfir.: cylinder 7,4,
    IDE03366,Numb.of misfir.: cylinder 8,2,
    IDE03367,Numb.of misfir.: cylinder 9,3,
    IDE03368,Numb.of misfir.: cylinder 10,1,
    IDE03660,Longitudinal acceleration,-0.004, m/s²
    IDE03692-ENG57549,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7,53,
    IDE03794,Long-term fuel trim bank 2 at idle,-0.75, %
    IDE03796,Camshaft adjustment: exhaust: bank 2: activation,0.000, %
    IDE03797,Camshaft adjustment intake bank 2: activation,0.000, %
    IDE03805,Test of brake booster pump: result,invalid,
    IDE03805-ENG127323,Test of brake booster pump: result-Test_Program_Channel 603,115,
    IDE03808-ENG57549,Oxygen sensor bank 2 sensor 1: status-Bits 0-7,0,
    IDE03809-ENG57549,Oxygen sensor bank 2 sensor 2: status-Bits 0-7,0,
    IDE03810,Oxygen sensor bank 2 sensor 1: specified value,15.9998,
    IDE03811,Test of oxygen sensors bank 2: Delta-Lambda: result,Test off,
    IDE03811-ENG129422,Test of oxygen sensors bank 2: Delta-Lambda: result-Test_Program_Channel 977,235,
    IDE03815,Test of secondary air system: deviation mass air flow Bank 2,0.000,
    IDE03817,Exhaust flap bank 2,OFF,
    IDE03817-ENG129421,Exhaust flap bank 2-Test_Program_Channel 825,136,
    IDE03822-ENG101533,Heated oxygen sensor bank 2: sensor 2: resistance-R uw q2 UWORD Chann 121,131070.000, Ohm
    IDE03822-ENG127296,Heated oxygen sensor bank 2: sensor 2: resistance-Test_Program_Bitregister,1,
    IDE03823,Heated oxygen sensor bank 2: sensor 2: activation,Unknown (0),
    IDE03823-ENG129414,Heated oxygen sensor bank 2: sensor 2: activation-Test_Program_Channel 125,0,
    IDE03824,Heated oxygen sensor bank 2: sensor 1: resistance,1916.72, Ohm
    IDE03825,Heated oxygen sensor bank 2: sensor 1: activation,0.000, %
    IDE03826,Conversion test Bank 2: measured value,9.0000,
    IDE03837,Result of O2 sensor aging test bank 2 after cat. conv.,B2-S2 OK,
    IDE03837-ENG129416,Result of O2 sensor aging test bank 2 after cat. conv.-Test_Program_Channel 2115,213,
    IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:---/0 kPa,
    IDE04235,Heat quantity f dew pt end before cat conv bank 2: modeled,0.000000, kJ
    IDE04237,Heat quantity f dew pt end behind fr cat conv bank 2: modeled,0.000000, kJ
    IDE04239,Heat quantity f dew pt end behind main cat conv bank 2: modeled,0.000000, kJ
    IDE04241,Counter start bef dew pt end f O2 sensor bef cat conv bank2,0,
    IDE04243,Counter start bef dew pt end f O2 sensor beh fr cat conv bank2,0,
    IDE04245,Count start bef dew pt end f O2 sensor beh main cat conv bank2,0,
    IDE04320,Throttle valve position 3,15, %
    IDE04324,Long term adaptation of oxygen sensor control: bank 2,0.0, %
    IDE04826,O2 sensor 1 bank 2: O2 sensor actual value,13.3743,
    IDE04953,Mass flow through throttle valve 2,0.0, kg/h
    IDE04956,Injection volume of high pressure pump 2,0.00, mm³
    IDE04957,Status of adaptation of on-demand fuel pump 2,Test off,
    IDE04957-ENG129410,Status of adaptation of on-demand fuel pump 2-Test_Program_Channel 1021,235,
    IDE04958,Test of knock sensors: ECM 2: short trip result,Test off,
    IDE04958-ENG127299,Test of knock sensors: ECM 2: short trip result-Test_Program_Channel 165,235,
    IDE04959,Shut off of oxygen sensor control of ECM 2,l-Reg.OFF,
    IDE04959-ENG127301,Shut off of oxygen sensor control of ECM 2-Test_Program_Channel 212,3,
    IDE04960,Test of oxygen sensor control of ECM 2,Syst. OK,
    IDE04960-ENG127302,Test of oxygen sensor control of ECM 2-Test_Program_Channel 213,228,
    IDE04963,Long term adaptation of throttle valve f mass air flow sensor 2,0.97784,
    IDE04966,Median injection time of ECM 2,0.000, ms
    IDE04971-ENG57549,Operating condition of idle speed control of ECM 2-Bits 0-7,0,
    IDE04972,Operational readiness of oxygen sensor after cat conv ECM 2,Test off,
    IDE04972-ENG127295,Operational readiness of oxygen sensor after cat conv ECM 2-Test_Program_Channel 113,235,
    IDE04998,Secondary air system test: result for ECM 2,Test off,
    IDE04998-ENG129327,Secondary air system test: result for ECM 2-Test_Program_Channel 239,235,
    IDE05013,Short term adap of throttle valve f mass air flow sensor ECM 2,1.00000,
    IDE05014,Status of adaptation of dew point end ECM 2,ADP is running,
    IDE05014-ENG127325,Status of adaptation of dew point end ECM 2-Test_Program_Channel 860,1,
    IDE05016,Air leak ECM 2,5.0, kg/h
    IDE05022,Angle difference actual-target camshaft adjuster ECM 2,0.000, °
    IDE05024,Close cam shaft angle at quantity control valve ECM 2,90.0, °
    IDE05025,Open cam shaft angle at quantity control valve ECM 2,146.9, °
    IDE05028,High fuel pressure: specified value ECM 2,0.6975, MPa
    IDE05029,High pressure regulation: adaptation value ECM 2,0.0000, MPa
    IDE05030,High fuel pressure: control deviation ECM 2,0.0000, MPa
    IDE05031-ENG57549,Rail pressure regulation: status ECM 2-Bits 0-7,0,
    IDE05128,Intake air temperature in intake manifold bank 1,33.0, °C
    IDE05138,Shut-off timer: last engine shut-off time,656320, s
    IDE05437,Outside air temperature via CAN,24.0, °C
    IDE05439,Rear cat conv temp main cat conv bank 2 model value,23.99, °C
    IDE05448,Long term adaptation of mixture form bank 2 at partial load,1.00000,
    IDE05450,Oxygen sensor 2 bank 2 internal resistance limit value,700, Ohm
    IDE05463,Oxy sensor 1 bank 2 char curve offset,0.00000,
    IDE05469,Oxygen sensor 1 bank 2 ceramic temp,594.34, °C
    IDE05471,Cat converter oxygen storage capacity bank 2,0.0, mg
    IDE05475,Main cat converter OSC age correction factor bank 2,1.000,
    IDE05477,Cat converter oxygen storage capacity bank 2 measured,0.0, mg
    IDE05487,Coolant temperature linearized value,23.250, °C
    IDE05928,Fuel consumption since DTC memory last erased,59.007, l/100km
    IDE06020,Intake air temperature in intake manifold bank raw value,33.0, °C
    IDE06062,Throttle valve position 4,14.5, %
    IDE06212,Fuel pressure rail 2,0.6975, MPa
    IDE06214,Throttle valve adapter bank 2: target value,2.000, %
    IDE06552,Time since terminal 15 ON,674330, ms
    IDE06568-ENG57549,Stop prevention by driver frequency counter-Bits 0-7,54,
    IDE06569-ENG57549,Vehicle stopped frequency counter-Bits 0-7,54,
    IDE06704-ENG57549,Drivetrain coordinator: brake fault status-Bits 0-7,0,
    IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,0,
    IDE06763,Adaptation val cyl 6 with slow diagnosis,1.00000,
    IDE06764,Adaptation val cyl 6 with fast diagnosis,1.00000,
    IDE06765,Adaptation val cyl 7 with slow diagnosis,1.00000,
    IDE06766,Adaptation val cyl 7 with fast diagnosis,1.00000,
    IDE06767,Adaptation val cyl 8 with slow diagnosis,1.00000,
    IDE06768,Adaptation val cyl 8 with fast diagnosis,1.00000,
    IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,0,
    IDE07230,Pre-ignition counter cylinder 6,0,
    IDE07242,Heater support pump: spec. value,0.00, %
    IDE07468,Fuel high pressure rail 2: regulator output value,0.0000, MPa
    IDE07475,Throttle valve position 2,5.76, %
    IDE07955,Throttle valve adapter bank 2: actual value,5.59, %
    IDE09573,O2 sens. dwnstrm. of cat. bank 2: gradient transf. lean -> rich,0.00, s
    IDE09575,O2 sens. dwnstrm. of cat. bank 2: gradient transf. rich -> lean,0.00, s
    IDE09944,Long-term adaptation of mixture formation MPI: additive,-0.75, %
    IDE09945,Long-term adaptation of mixture formation MPI: multiplicative,0.99799,
    IDE10631,O2 sens.upstrm. of cat. bank 2: delay time transf.rich -> lean,0.00, s
    IDE10671,O2 sens.upstrm. of cat. B. 2: filter const.transf. rich -> lean,0.00, s
    IDE11931,Heated oxygen sensor bank 1 sensor 1: positioning intervention rear cat controller,0.00012,
    IDE12688,Catalytic converter temperature bank 2: modeled,20, °C
    IDE12903,Secondary air mass: bank 2: deviation,0.000,
    IDE12914,Fuel low pressure 2: actual value,697.5, kPa
    IDE12917,Throttle 1: bank 2: position sensor 1: raw voltage,0.740, V
    IDE12918,Throttle 1: bank 2: position sensor 2: raw voltage,4.265, V
    IDE12924,Lambda regulation: bank 2: output value,1.00000,
    IDE12934,Camshaft position deviation from reference position: bank 2,0.00, °
    IDE12935,Ignition angle: bank 2 raw value,0.0, °
    IDE13301,Drivetrain coordinator: brake fault status,0,
    IDE13336,Drive train coordinator reversible switch off conditions,0,
    IDE14242,Oil pressure valve for piston cooling nozzles: control switch button ratio,0.00, %
    MAS16075,Temperature in pre-cat bank 2: model value,24.0, °C
    ENG105091,Afmim n,99.6, %
    ENG105093,Afnmn,10200, /min
    ENG111056,Air_intake_temperature_maximum_value_engine_control_unit_2,33.0, °C
    ENG111057,Air_intake_temperature_minimum_value_engine_control_unit_2,32.3, °C
    ENG111045,Air_mass_integral_for_thermostat_diagnosis_limit_value_engine_control_unit_2,8.47, kg
    ENG120762,B slv2,False result,
    ENG120762-ENG127289,B slv2-Test_Program_B TRUE UBYTE,0,
    ENG101413,Calibration Identification,4S0552AC0001ATLK,
    ENG01773-ENG57549,Configuration_of_cruise_control-Bits 0-7,0,
    ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,0,
    ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,58,
    ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,111,
    ENG126404-ENG57549,Drive_train_coordinator_checked_coding-Bits 0-7,0,
    ENG100152-ENG104003,ECUNAME-ECU,ECM2,
    ENG100152,ECUNAME,EngineControl2,
    ENG111034,Engine_temperature_modelbased_substitute_value,33.0, °C
    ENG113653,Epm Ca S n Ca S mp B2,0.0, /min
    ENG111610,Epm Ca S phi Adap Ref Pos O1 mp 0,71.50, °
    ENG121110,Epm Ca S phi Adap Ref Pos O1 mp 1,103.29, °
    ENG08888,Exh T Snsr t Val Sent Snsr Plus Offs,49.5, °C
    ENG106507,Fan r Ps,0.00, %
    ENG106510,Fan r2 Ps,0.00, %
    ENG111607,Frequency_counters_for_test_signal_histogram,45,
    ENG106678,Frm2 w,1.00000,
    ENG106781-ENG57549,Glb Da Max Val 0-Bits 0-7,53,
    ENG111039,Knock_sensor_cylinder_10_voltage,16.768, V
    ENG107237,Knock_sensor_cylinder_6_voltage,16.768, V
    ENG107238,Knock_sensor_cylinder_7_voltage,16.768, V
    ENG107239,Knock_sensor_cylinder_8_voltage,16.768, V
    ENG111037,Knock_sensor_cylinder_9_voltage,16.768, V
    ENG107309,Krivk w,3.20, Ohm
    ENG111054,Load_value_relative_engine_control_unit_2,69.30, %
    ENG107964,Oxygen_sensor_bank_2_sensor_1_voltage,1.494, V
    ENG109006,Spark_efficiency_deviation_at_idle_maximum,3.1, %
    ENG121093-ENG57549,State_of_cruise_control_or_speedlimiter-Bits 0-7,1,
    ENG01786-ENG57549,State_of_requestor_for_drivetrain_coordinator-Bits 0-7,0,
    ENG109344,Tasrg w,33.0, °C
    ENG06113,Udkp1 w B3,0.741, V
    ENG06114,Udkp2 w B4,4.265, V
    Elapsed Time: 00:47
    adpmap-11-4S0-907-552-AC
    ;Component:V10 5.2l FSI  H57 0001, Coding:1A2500320526000D3000
    ;Saturday,10,August,2019,09:44:16:30091
    ;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
    ;VCID: 77A8E1B45F4A1C0FFB3-8022
    Elapsed Time: 00:01
    Address - [02]
    blockmap-02-4S0-927-155-AC
    ;SW:4S0-927-155-AC   HW:0BH-927-711-F ---  Auto Trans
    ;Component:AU 6 B NAR    H10 6202, Coding:0014
    ;EV_TCMDL800041,001016,EV_TCMDL800041_AU72.rod
    ;Saturday,10,August,2019,09:36:58:30091
    ;VCID: 78AAE28852541377F29-802C
    Group,Description,Actual
    IDE00008,Softwareversion,6202,
    IDE00011,Vehicle Identification Number (VIN),WUAEEAFX3L7xxxxxx,
    IDE00018,Voltage terminal 15,12.4, V
    IDE00019,Voltage terminal 30,12.4, V
    IDE00021-ENG99543,Engine speed-Engine RPM,0, /min
    IDE00022-ENG103074,Transmission input speed-Transmission Input Speed Sensor,0, /min
    IDE00023,Transmission output speed,0, /min
    IDE00024,Transmission fluid temperature,25, °C
    IDE00075-ENG99967,Vehicle speed-Vehicle Speed Sensor,0.00, km/h
    IDE00086-ENG98363,Accelerator position-Accelerator pedal position,0.0, %
    IDE00091-ENG101172,Status of starter lock-Status Engine Starter Lock,Activate,
    IDE00094,Kick-down status,OFF,
    IDE00095-ENG101643,Status of selector lever lock-Status Shift Lock,activated,
    IDE00096-ENG100569,Selector lever position-Shift Position,Position_P_Stop,
    IDE00101-ENG103259,Engine specified torque during transmission intervention-Calculated engine preset torque,1097.0, Nm
    IDE00102-ENG102028,Control Module temperature-Control modul temperature,26, °C
    IDE00130-ENG103124,Transmission specified idle RPM-Idle Speed Commanded Value,0, /min
    IDE00322,Status of basic setting,not active,
    IDE00450,Operating Instructions,--no display--,
    IDE00451-ENG103018,Currently running routine-Current Test Routine,0,
    IDE00872-ENG102188,Current of main pressure valve-Oil Pressure Actual Current,11.0, mA
    IDE00970-ENG99446,Coolant fan activation: actual value-Radiator fan activation: actual value,10.0, %
    IDE00972,Idle speed increase,OFF,
    IDE01077-ENG101438,Activation A/C compressor-Air Condition Compressor Activation,OFF,
    IDE01588-ENG101855,Driving direction-M015 SvnNAbRichtung,not known,
    IDE01716-ENG103234,Terminal 50 status-Status terminal 50,OFF,
    IDE02211,Brake pressure,0.00, bar
    IDE02221,Engine torque: qualification,valid,
    IDE02713,Brake Light Switch,not activated,
    IDE02714,Brake test switch,not activated,
    IDE02715-ENG103190,Validity of brake pressure-Brake Pressure State,valid,
    IDE02716,Tiptronic source,via CAN,
    IDE02717-ENG102076,Tiptronic upshift-Tiptronic Up,OFF,
    IDE02718-ENG101063,Tiptronic downshift-Tiptronic Down,OFF,
    IDE02719-ENG99606,Selector lever position made plausible-Shift Position Plausible,P,
    IDE02720-ENG103810,Transmission input speed (RPM) shaft 1-Transmission Input Speed Shaft 1,0, /min
    IDE02721-ENG100916,Transmission input speed (RPM) shaft 2-Transmission Input Speed Shaft 2,0, /min
    IDE02722-ENG101964,Transmission output speed (RPM) shaft 1-Transmission Output Speed Shaft 1,0, /min
    IDE02723-ENG100382,Transmission output speed (RPM) shaft 2-Transmission Output Speed Shaft 2,0, /min
    IDE02724,Direction of rotation shaft 1,not known,
    IDE02725,Direction of rotation shaft 2,not known,
    IDE02726-ENG100799,Voltage supply E-pump-Voltage Supply Electric Motor,12.4, V
    IDE02727-ENG99192,Selector lever lock SPECIFIED condition-Shift Lock Desired State,activated,
    IDE02728-ENG101668,Shift lock indicator lamp-Indicator Light Shift Lock,Lamp off,
    IDE02735-ENG100209,Display of driving mode in instrument panel-Display Driving Position,P,
    IDE02736-ENG100252,Display of gear in instrument panel-Display Driving Gear,KEIN_GANG,
    IDE02738-ENG100412,Selector lever illumination-Display Shift Lighting,P,
    IDE02739-ENG99525,A/C compressor off requirement-Demand Air Condition Compressor Stop,Deactivated,
    IDE02740-ENG99750,Temperature of friction lining for clutch 1-Temperatur_Friction_Lining_Clutch_1,24, °C
    IDE02741-ENG102724,Temperature of friction lining for clutch 2-Temperatur_Friction_Lining_Clutch_2,24, °C
    IDE02742,Oil pressure actual value,3.37, bar
    IDE02775-ENG101304,Status of basic setting data-State Of Basic Adjustmentdata,valid,
    IDE02776-ENG102757,Pressure of partial transmission 1 specified value-Pressure Transmission Part 1 Commanded Value,25.00, bar
    IDE02777-ENG101539,Pressure of partial transmission 1 actual value-Pressure Transmission Part 1 Actual Value,0.00, bar
    IDE02779-ENG100646,Pressure of partial transmission 2 specified value-Pressure Transmission Part 2 Commanded Value,25.00, bar
    IDE02780-ENG103741,Pressure of partial transmission 2 actual value-Pressure Transmission Part 2 Actual Value,0.00, bar
    IDE02782-ENG103418,Current of valve for partial transmission 1 specified value-Current Valve Transmission Part 1 Commanded Value,0.0, mA
    IDE02783-ENG99260,Current of valve for partial transmission 1 actual value-Current Valve Transmission Part 1 Actual Value,1.0, mA
    IDE02786-ENG101222,Current of valve for partial transmission 2 specified value-Current Valve Transmission Part 2 Commanded Value,0.0, mA
    IDE02787-ENG101614,Current of valve for partial transmission 2 actual value-Current Valve Transmission Part 2 Actual Value,0.0, mA
    IDE02790-ENG104124,Specified torque clutch 1-Clutch 1 Commanded Torque,-100.00, Nm
    IDE02791-ENG101742,Actual torque clutch 1-Clutch 1 Actual Torque,-100.00, Nm
    IDE02792-ENG101464,Specified position clutch 1-Clutch 1 Commanded Position,0.0, bar
    IDE02793-ENG102450,Actual position clutch 1-Clutch 1 Actual Position,-0.1, bar
    IDE02796-ENG103463,Current of valve for clutch 1 specified value-Current Valve Clutch 1 Commanded Value,0.0, mA
    IDE02797-ENG100730,Current of valve for clutch 1 actual value-Current Valve Clutch 1 Actual Value,0.0, mA
    IDE02800-ENG100171,Specified torque clutch 2-Clutch 2 Commanded Torque,-100.00, Nm
    IDE02802-ENG102780,Actual position clutch 2-Clutch 2 Actual Position,-0.1, bar
    IDE02805-ENG99237,Current of valve for clutch 2 specified value-Current Valve Clutch 2 Commanded Value,0.0, mA
    IDE02806-ENG103118,Current of valve for clutch 2 actual value-Current Valve Clutch 2 Actual Value,0.0, mA
    IDE02820,Transmission mileage,65.3, km
    IDE02821-ENG101653,Pressure supply specified pressure/threshold1-Pressure Supply Commanded Value Threshold 1,3.37, bar
    IDE02823-ENG100173,Identification of selector lever-Identification Selector Lever,,
    IDE02824-ENG99279,Main status of abort code basic setting-Basic Settings Main Status,0,
    IDE02825-ENG100313,Substatus of abort code basic setting-Basic Settings Sub Status,0,
    IDE02827-ENG103491,Steering wheel paddle installation info-Application Info Steering Paddels,0,
    IDE02828-ENG103640,Brake installation info-Application Info Breaksystem,0,
    IDE02829-ENG103127,Steering wheel module installation info-Application Info Steering Modul,0,
    IDE02830-ENG100103,Gateway installation info-Application Info Gateway,0,
    IDE02858-ENG100590,Status of basic setting data: gear selector-State Of Basic Adjustmentdata Gearpositioner,gültig Grundeinmessung,
    IDE02859-ENG99797,Status of basic setting data for clutch-State Of Basic Adjustmentdata Clutch,gültig Grundeinmessung,
    IDE02861-ENG103083,Mechatronic identification-Baudatum,190117,
    IDE02861-ENG98675,Mechatronic identification-Construction version,A6,
    IDE02861-ENG99175,Mechatronic identification-Kassel,K,
    IDE02861-ENG104192,Mechatronic identification-Kennung der Mechatronik-Montagelinie,A02,
    IDE02861-ENG103830,Mechatronic identification-Lfd.-Nr,0341,
    IDE02861-ENG103525,Mechatronic identification-Teilenummer (3 letzten + Index),0BZF ,
    IDE02862-ENG103213,Production data transmission-Aggregatekennzeichnung (Getriebe),006,
    IDE02862-ENG103083,Production data transmission-Baudatum,190204,
    IDE02862-ENG104019,Production data transmission-Getriebekennbuchstabe,TMY,
    IDE02862-ENG99175,Production data transmission-Kassel,K,
    IDE02862-ENG101707,Production data transmission-Kennung der Montagelinie,F05,
    IDE02862-ENG103830,Production data transmission-Lfd.-Nr,0003,
    IDE02864-ENG99505,Actual position of gear positioner A-Gearpositioner A Actual Position,-8.34, mm
    IDE02865-ENG104121,AD value 1 of actual position of gear positioner A-Gearpositioner A Actual Position AD Value 1,2804,
    IDE02867-ENG103746,Specified current of gear Solen.val. A-Gearpositioner A Valve Commanded Current,0.0, mA
    IDE02868-ENG102455,Actual current of gear Solen.val. A-Gearpositioner A Valve Actual Current,0.0, mA
    IDE02872-ENG102218,Actual position of gear adjuster B-Gearpositioner B Actual Position,0.40, mm
    IDE02873-ENG101728,AD value 1 of actual position of gear positioner B-Gearpositioner B Actual Position AD Value 1,2064,
    IDE02875-ENG101174,Specified current of gear Solen.val. B-Gearpositioner B Valve Commanded Current,0.0, mA
    IDE02876-ENG99266,Actual current of gear Solen.val. B-Gearpositioner B Valve Actual Current,1.0, mA
    IDE02880-ENG103036,Actual position of gear positioner C-Gearpositioner C Actual Position,-0.03, mm
    IDE02881-ENG99453,AD value 1 of actual position of gear positioner C-Gearpositioner C Actual Position AD Value 1,2036,
    IDE02883-ENG103740,Specified current of gear Solen.val. C-Gearpositioner C Valve Commanded Current,0.0, mA
    IDE02884-ENG99821,Actual current of gear Solen.val. C-Gearpositioner C Valve Actual Current,2.0, mA
    IDE02888-ENG103826,Actual position of gear positioner D-Gearpositioner D Actual Position,-7.97, mm
    IDE02889-ENG100525,AD value 1 of actual position of gear positioner D-Gearpositioner D Actual Position AD Value 1,1268,
    IDE02891-ENG101968,Specified current of gear Solen.val. D-Gearpositioner D Valve Commanded Current,0.0, mA
    IDE02892-ENG99541,Actual current of gear Solen.val. D-Gearpositioner D Valve Actual Current,0.0, mA
    IDE02989-ENG100843,Status of torque requirements on engine-State Of Torque Demand Engine,OFF,
    IDE03107-ENG101648,Kilometers at last basic setting-Kilometer Since Last Basic Adjustment,0, km
    IDE03152-ENG104154,Neutral due to driver registr. proced. cond.: cause-Driver Registration Procedure Condition Cause,00 00,
    IDE03153-ENG102498,Driver logon procedure: number of activations-Driver Registration Procedure Activation Counter,0,
    IDE03155-ENG99516,GE clutch data: Status-GE Clutch Data Status,DATEN_GUELTIG_GRUNDEINMESS,
    IDE03156-ENG102903,Last change to GE clutch data: odometer reading-Last Changing GE Clutch Data Km,0, km
    IDE03160-ENG100046,Remaining clutch fast adaptations: kiss point-Remaining Clutch Fastadaption Kisspoint,6,
    IDE03163-ENG103608,Protect. function temp. clutch 1 warn. level 1 number-Protective Function Temperature Clutch 1 Warning 1 Numbers,0,
    IDE03164-ENG101576,Protect. function temp. clutch 1 warn. level 2 number-Protective Function Temperature Clutch 1 Warning 2 Numbers,0,
    IDE03165-ENG102133,Protective function temp. clutch 1 protect. level 1 number-Protective Function Temperature Clutch 1 Protection 1 Numbers,0,
    IDE03167-ENG102425,Protect. function temp. clutch 2 warn. level 1 number-Protective Function Temperature Clutch 2 Warning 1 Numbers,0,
    IDE03168-ENG100182,Protect. function temp. clutch 2 warn. level 2 number-Protective Function Temperature Clutch 2 Warning 2 Numbers,0,
    IDE03169-ENG104175,Protective function temp. clutch 2 protect. level 1 number-Protective Function Temperature Clutch 2 Protection 1 Numbers,0,
    IDE03171-ENG102987,Driving strategy transmission mileage-Q002 Total Driving Time,62.8, km
    IDE03172-ENG100789,Driving strategy driving portions in D or S w/ CCS-Q003 Driving Time Ecological,43, %
    IDE03173-ENG103567,Driving strategy driving portions in S w/o CCS-Q004 Driving Time Sporty,24, %
    IDE03174-ENG100415,Driving strategy driving portions in Tiptronic-Q005 Driving Time Manual,33, %
    IDE03180-ENG103176,Number of standard trips-General Denominator,2,
    IDE03181-ENG102823,Number of ignition cycles-Ignition Cycle Counter,5,
    IDE04612-ENG101246,Clutch temperature air / splash oil-Centrifugal oil temperature,25, °C
    IDE05303-ENG99893,Actual torque clutch 2-Clutch 2 Actual Torque,-100.00, Nm
    IDE05987-ENG110507,Engine stop prohibitions-Anzahl Stoppverbote,0,
    IDE05987-ENG110524,Engine stop prohibitions-Basic setting,Basic setting not active,
    IDE05987-ENG28506,Engine stop prohibitions-Demontagestellung,Demontagestellung nicht aktiv,
    IDE05987-ENG28505,Engine stop prohibitions-Drucksensorausfall,Drucksensorausfall nicht aktiv,
    IDE05987-ENG28507,Engine stop prohibitions-Eingeschränkte Fahrfunktion / Notlauf / Liegenbleiber,Eingeschränkte Fahrfunktion / Notlauf / Liegenbleiber nicht aktiv,
    IDE05987-ENG110508,Engine stop prohibitions-km-Stand des letzten Stoppverbots,0.0, km
    IDE05987-ENG110525,Engine stop prohibitions-Stop prohibition via application,Stoppverbot über Applikation nicht aktiv,
    IDE05987-ENG28504,Engine stop prohibitions-Temperaturbedingung,Temperaturbedingung nicht aktiv,
    IDE05988-ENG110505,Pressure of clutch 2: actual value-Clutch_2_actual_value,-0.10, bar
    IDE05989-ENG110503,Pressure of clutch 1: actual value-Clutch_1_actual_value,-0.07, bar
    IDE05990-ENG110506,Pressure of clutch 2: specified value-Clutch_2_commanded_value,0.00, bar
    IDE05991-ENG110504,Pressure of clutch 1: specified value-Clutch_1_commanded_value,0.00, bar
    IDE06425,Roller test bench mode: functional,Deactivated,
    IDE08133,Basic setting: cause for cancellation,Basic setting not active,
    IDE08349,Sport program button,not activated,
    IDE10711,Downshift paddle switch: status,not activated,
    IDE10712,Upshift paddle switch: status,not activated,
    IDE80001-ENG100467,Analysis 1-Snapshot 1 Failure ID,0,
    IDE80002-ENG102386,Analysis 2-Snapshot 1 Mileage,0, km
    IDE80003-ENG101467,Analysis 3-Snapshot 1 Counter,0,
    IDE80004-ENG110548,Analysis 4-Snapshot 1 Oil Pressure Actual Value,-10.0, bar
    IDE80005-ENG103330,Analysis 5-Snapshot 1 Shift Position Plausible,P,
    IDE80006-ENG99650,Analysis 6-Snapshot 1 Main Status Vehicle Clutch Fahrzeugzustand,New,
    IDE80006-ENG102000,Analysis 6-Snapshot 1 Main Status Vehicle Clutch Kupplungshauptzustand,New,
    IDE80007-ENG101090,Analysis 7-Snapshot 1  Commanded Gear,GANG N,
    IDE80008-ENG100048,Analysis 8-Snapshot 1 Preselection Gear,GANG N,
    IDE80009-ENG102100,Analysis 9-Snapshot 1 Transmission Input Speed,0, /min
    IDE80010-ENG101565,Analysis 10-Snapshot 1 Transmission Output Speed Shaft 1,0, /min
    IDE80011-ENG100379,Analysis 11-Snapshot 1 Transmission Speed Shaft 1,0, /min
    IDE80012-ENG103459,Analysis 12-Snapshot 1 Transmission Speed Shaft 2,0, /min
    IDE80013-ENG99331,Analysis 13-Snapshot 1 Gearpositioner A Actual Value,-20.48, mm
    IDE80014-ENG99512,Analysis 14-Snapshot 1 Gearpositioner B Actual Value,-20.48, mm
    IDE80015-ENG100338,Analysis 15-Snapshot 1 Gearpositioner C Actual Value,-20.48, mm
    IDE80016-ENG100656,Analysis 16-Snapshot 1 Gearpositioner D Actual Value,-20.48, mm
    IDE80017-ENG99158,Analysis 17-Snapshot 1 Gearpositioner A Valve Actual Current,0, mA
    IDE80018-ENG101917,Analysis 18-Snapshot 1 Gearpositioner B Valve Actual Current,0, mA
    IDE80019-ENG102153,Analysis 19-Snapshot 1 Gearpositioner C Valve Actual Current,0, mA
    IDE80020-ENG100002,Analysis 20-Snapshot 1 Gearpositioner D Valve Actual Current,0, mA
    IDE80021-ENG102762,Analysis 21-Snapshot 1 Clutch 1 Actual Pressure,0.0, bar
    IDE80022-ENG100347,Analysis 22-Snapshot 1 Clutch 2 Actual Pressure,0.0, bar
    IDE80023-ENG99119,Analysis 23-Snapshot 1 Current Valve Clutch 1 Actual Value,0, mA
    IDE80024-ENG101123,Analysis 24-Snapshot 1 Current Valve Clutch 2 Actual Value,0, mA
    IDE80025-ENG103611,Analysis 25-Snapshot 1 Accelerator Pedal Position,0.0, %
    IDE80026-ENG101503,Analysis 26-Snapshot 1 Engine torque,-50, Nm
    IDE80027-ENG101521,Analysis 27-Snapshot 1 Current Valve Transmission Part 1 Actual Value,0, mA
    IDE80028-ENG103949,Analysis 28-Snapshot 1 Current Valve Transmission Part 2 Actual Value,0, mA
    IDE80029-ENG103070,Analysis 29-Snapshot 1 Voltage Terminal 15,0.0, V
    IDE80030-ENG101050,Analysis 30-Snapshot 1 Voltage Supply Electric Motor,0.0, V
    IDE80031-ENG102899,Analysis 31-Snapshot 1 Transmission Fluid Temperature,-60, °C
    IDE80032-ENG99872,Analysis 32-Snapshot 1 Maximum Temperature Clutch 1 Clutch 2,-60, °C
    IDE80033-ENG103098,Analysis 33-Snapshot 2 Failure ID,0,
    IDE80034-ENG101047,Analysis 34-Snapshot 2 Mileage,0, km
    IDE80035-ENG99915,Analysis 35-Snapshot 2 Counter,0,
    IDE80036-ENG110549,Analysis 36-Snapshot 2 Oil Pressure Actual Value,-10.0, bar
    IDE80037-ENG99369,Analysis 37-Snapshot 2 Shift Position Plausible,P,
    IDE80038-ENG99350,Analysis 38-Snapshot 2 Main Status Vehicle Clutch Fahrzeugzustand,New,
    IDE80038-ENG102372,Analysis 38-Snapshot 2 Main Status Vehicle Clutch Kupplungshauptzustand,New,
    IDE80039-ENG101369,Analysis 39-Snapshot 2  Commanded Gear,GANG N,
    IDE80040-ENG103638,Analysis 40-Snapshot 2 Preselection Gear,GANG N,
    IDE80041-ENG103367,Analysis 41-Snapshot 2 Transmission Input Speed,0, /min
    IDE80042-ENG102476,Analysis 42-Snapshot 2 Transmission Output Speed Shaft 1,0, /min
    IDE80043-ENG102699,Analysis 43-Snapshot 2 Transmission Speed Shaft 1,0, /min
    IDE80044-ENG101900,Analysis 44-Snapshot 2 Transmission Speed Shaft 2,0, /min
    IDE80045-ENG100935,Analysis 45-Snapshot 2 Gearpositioner A Actual Position,-20.48, mm
    IDE80046-ENG102046,Analysis 46-Snapshot 2 Gearpositioner B Actual Position,-20.48, mm
    IDE80047-ENG100712,Analysis 47-Snapshot 2 Gearpositioner C Actual Position,-20.48, mm
    IDE80048-ENG101670,Analysis 48-Snapshot 2 Gearpositioner D Actual Position,-20.48, mm
    IDE80049-ENG102288,Analysis 49-Snapshot 2 Gearpositioner A Valve Actual Current,0, mA
    IDE80050-ENG103952,Analysis 50-Snapshot 2 Gearpositioner B Valve Actual Current,0, mA
    IDE80051-ENG99664,Analysis 51-Snapshot 2 Gearpositioner C Valve Actual Current,0, mA
    IDE80052-ENG100255,Analysis 52-Snapshot 2 Gearpositioner D Valve Actual Current,0, mA
    IDE80053-ENG102973,Analysis 53-Snapshot 2 Clutch 1 Actual Pressure,0.0, bar
    IDE80054-ENG100122,Analysis 54-Snapshot 2 Clutch 2 Actual Pressure,0.0, bar
    IDE80055-ENG103189,Analysis 55-Snapshot 2 Current Valve Clutch 1 Actual Value,0, mA
    IDE80056-ENG103616,Analysis 56-Snapshot 2 Current Valve Clutch 2 Actual Value,0, mA
    IDE80057-ENG102447,Analysis 57-Snapshot 2 Accelerator Pedal Position,0.0, %
    IDE80058-ENG103198,Analysis 58-Snapshot 2 Engine torque,-50, Nm
    IDE80059-ENG100322,Analysis 59-Snapshot 2 Current Valve Transmission Part 1 Actual Value,0, mA
    IDE80060-ENG99335,Analysis 60-Snapshot 2 Current Valve Transmission Part 2 Actual Value,0, mA
    IDE80061-ENG101449,Analysis 61-Snapshot 2 Voltage Terminal 15,0.0, V
    IDE80062-ENG99916,Analysis 62-Snapshot 2 Voltage Supply Electric Motor,0.0, V
    IDE80063-ENG104157,Analysis 63-Snapshot 2 Transmission Fluid Temperature,-60, °C
    IDE80064-ENG101948,Analysis 64-Snapshot 2 Maximum Temperature Clutch 1 Clutch 2,-60, °C
    ENG103724,Accelerator pedal position: qualification,OK,
    ENG100091,Ambient temperature,24, °C
    ENG121993-ENG121995,Anzahl_Launch_Control_Anfahrt-Anzahl_Launch_Control,0,
    ENG06546,Anzahl_Waehlhebel_Reset,0,
    ENG99187,CAN version,0,
    ENG100280,Capacity protection function: clutch 1 number,0,
    ENG102139,Capacity protection function: clutch 2 number,0,
    ENG98482-ENG99180,Checksum of flash-Calibration Checksumme,EB 20 48 2F,
    ENG98482-ENG100495,Checksum of flash-Cboot Checksumme,8B 0F 4C 63,
    ENG98482-ENG100117,Checksum of flash-Checksumme ECU + CAL,BC ED ED 81,
    ENG98482-ENG102221,Checksum of flash-ECU Checksumme,F8 E5 79 BF,
    ENG99760,Clutch 1 Adaption basic charac. point 0 moment,0.0, Nm
    ENG101637,Clutch 1 Adaption basic charac. point 1 moment,100.0, Nm
    ENG102711,Clutch 1 Adaption basic charac. point 2 moment,650.0, Nm
    ENG102836,Clutch 1 Adaption basic charac. point 3 moment,800.0, Nm
    ENG101012,Clutch 1 adaption basic characteristic point 0 position,2.5, bar
    ENG102187,Clutch 1 adaption basic characteristic point 1 position,4.3, bar
    ENG99501,Clutch 1 adaption basic characteristic point 2 position,13.4, bar
    ENG99792,Clutch 1 adaption basic characteristic point 3 position,14.6, bar
    ENG103827,Clutch 1 adaption basic characteristic range 1 quick adaptions remaining km,35, km
    ENG99333,Clutch 1 adaption basic characteristic range 2 quick adaptions remaining km,35, km
    ENG102537,Clutch 1 adaption basic characteristic range 3 quick adaptions remaining km,35, km
    ENG110529,Clutch 1 adaption kiss point part 1 fault cause,00 00 00 00,
    ENG110528,Clutch 1 adaption kiss point part 1 fault cause cumulative,00 00 00 00,
    ENG110530,Clutch 1 adaption kiss point part 1 fault counter,0,
    ENG110531,Clutch 1 adaption kiss point part 1 remaining quick adaption,6,
    ENG110526,Clutch 1 adaption kiss point part 1 success counter,4,
    ENG110527,Clutch 1 adaption kiss point part 1 vehicle km reading,30, km
    ENG100324,Clutch 1 Characteristic line shift,-0.0, mm
    ENG103905,Clutch 1 Friction value correction factor,106.4, %
    ENG103094,Clutch 1 temperature maximum,143, °C
    ENG99215,Clutch 1 temperature time in range 0,43736.8, s
    ENG100695,Clutch 1 temperature time in range 1,4329.9, s
    ENG99265,Clutch 1 temperature time in range 2,95.3, s
    ENG102908,Clutch 1 temperature time in range 3,0.0, s
    ENG103456,Clutch 2 Adaption basic charac. point 0 moment,0.0, Nm
    ENG104166,Clutch 2 Adaption basic charac. point 1 moment,100.0, Nm
    ENG100996,Clutch 2 Adaption basic charac. point 2 moment,650.0, Nm
    ENG101985,Clutch 2 Adaption basic charac. point 3 moment,800.0, Nm
    ENG104250,Clutch 2 adaption basic characteristic point 0 position,2.4, bar
    ENG100941,Clutch 2 adaption basic characteristic point 1 position,4.3, bar
    ENG99957,Clutch 2 adaption basic characteristic point 2 position,13.2, bar
    ENG99481,Clutch 2 adaption basic characteristic point 3 position,14.6, bar
    ENG102732,Clutch 2 adaption basic characteristic range 1 quick adaptions remaining km,35, km
    ENG101931,Clutch 2 adaption basic characteristic range 2 quick adaptions remaining km,35, km
    ENG100136,Clutch 2 adaption basic characteristic range 3 quick adaptions remaining km,35, km
    ENG110535,Clutch 2 adaption kiss point part 1 fault cause,00 00 00 00,
    ENG110534,Clutch 2 adaption kiss point part 1 fault cause cumulative,00 00 00 00,
    ENG110536,Clutch 2 adaption kiss point part 1 fault counter,0,
    ENG110537,Clutch 2 adaption kiss point part 1 remaining quick adaption,5,
    ENG110532,Clutch 2 adaption kiss point part 1 success counter,5,
    ENG110533,Clutch 2 adaption kiss point part 1 vehicle km reading,40, km
    ENG102031,Clutch 2 Characteristic line shift,-0.0, mm
    ENG101046,Clutch 2 Friction value correction factor,106.4, %
    ENG103119,Clutch 2 temperature maximum,148, °C
    ENG102343,Clutch 2 temperature time in range 0,43885.8, s
    ENG103315,Clutch 2 temperature time in range 1,4243.3, s
    ENG102083,Clutch 2 temperature time in range 2,34.7, s
    ENG104251,Clutch 2 temperature time in range 3,0.0, s
    ENG102882,Clutch adaptation kiss-point fast adaptation remaining km tr,35, km
    ENG103186,Clutch center central plate temperature,25, °C
    ENG107241-ENG103334,Coefficient vmd_k_Clutch_1C0-Koeffizient,1134692463,
    ENG107242-ENG103334,Coefficient vmd_k_Clutch_1C1-Koeffizient,1114509368,
    ENG107243-ENG103334,Coefficient vmd_k_Clutch_1C2-Koeffizient,3282739074,
    ENG107244-ENG103334,Coefficient vmd_k_Clutch_1C3-Koeffizient,1099380918,
    ENG107245-ENG103334,Coefficient vmd_k_Clutch_2C0-Koeffizient,1138213062,
    ENG107246-ENG103334,Coefficient vmd_k_Clutch_2C1-Koeffizient,1116484478,
    ENG107247-ENG103334,Coefficient vmd_k_Clutch_2C2-Koeffizient,3284533799,
    ENG107248-ENG103334,Coefficient vmd_k_Clutch_2C3-Koeffizient,3259525405,
    ENG107249-ENG103334,Coefficient vmd_k_Cool_C0-Koeffizient,1145898686,
    ENG107250-ENG103334,Coefficient vmd_k_Cool_C1-Koeffizient,1133147001,
    ENG107251-ENG103334,Coefficient vmd_k_Cool_C2-Koeffizient,1057599122,
    ENG107252-ENG103334,Coefficient vmd_k_Cool_C3-Koeffizient,3251171885,
    ENG107253-ENG103334,Coefficient vmd_k_Cool_C4-Koeffizient,3228108451,
    ENG107254-ENG103334,Coefficient vmd_k_Cool_Qmax-Koeffizient,1106243659,
    ENG107255-ENG103334,Coefficient vmd_k_CutOff_ OddC0-Koeffizient,1125581500,
    ENG107256-ENG103334,Coefficient vmd_k_CutOff_ OddC1-Koeffizient,3197174997,
    ENG107257-ENG103334,Coefficient vmd_k_CutOff_ OddC2-Koeffizient,1099853668,
    ENG107258-ENG103334,Coefficient vmd_k_CutOff_Even_C0-Koeffizient,1126586850,
    ENG107259-ENG103334,Coefficient vmd_k_CutOff_Even_C1-Koeffizient,3197515575,
    ENG107260-ENG103334,Coefficient vmd_k_CutOff_Even_C2-Koeffizient,1100045778,
    ENG107261-ENG103334,Coefficient vmd_k_CutOff_Even_C3-Koeffizient,1041005449,
    ENG107262-ENG103334,Coefficient vmd_k_CutOff_Even_C4-Koeffizient,1121553902,
    ENG107263-ENG103334,Coefficient vmd_k_CutOff_OddC3-Koeffizient,1037720470,
    ENG107264-ENG103334,Coefficient vmd_k_CutOff_OddC4-Koeffizient,1122242986,
    ENG107265-ENG103334,Coefficient vmd_k_FlwC0_Even_ABw-Koeffizient,1144704488,
    ENG107266-ENG103334,Coefficient vmd_k_FlwC0_Even_AFw-Koeffizient,1144990773,
    ENG107267-ENG103334,Coefficient vmd_k_FlwC0_Even_BBw-Koeffizient,1145011580,
    ENG107268-ENG103334,Coefficient vmd_k_FlwC0_Even_BFw-Koeffizient,1147978121,
    ENG107269-ENG103334,Coefficient vmd_k_FlwC0_OddABw-Koeffizient,1144137264,
    ENG107270-ENG103334,Coefficient vmd_k_FlwC0_OddAFw-Koeffizient,1145930757,
    ENG107271-ENG103334,Coefficient vmd_k_FlwC0_OddBBw-Koeffizient,1145032133,
    ENG107272-ENG103334,Coefficient vmd_k_FlwC0_OddBFw-Koeffizient,1146124374,
    ENG107273-ENG103334,Coefficient vmd_k_FlwC1_Even_ABw-Koeffizient,1101855510,
    ENG107274-ENG103334,Coefficient vmd_k_FlwC1_Even_AFw-Koeffizient,1110892198,
    ENG107275-ENG103334,Coefficient vmd_k_FlwC1_Even_BBw-Koeffizient,1097706798,
    ENG107276-ENG103334,Coefficient vmd_k_FlwC1_Even_BFw-Koeffizient,1122755990,
    ENG107277-ENG103334,Coefficient vmd_k_FlwC1_OddABw-Koeffizient,1099218399,
    ENG107278-ENG103334,Coefficient vmd_k_FlwC1_OddAFw-Koeffizient,1113073684,
    ENG107279-ENG103334,Coefficient vmd_k_FlwC1_OddBBw-Koeffizient,1097891284,
    ENG107280-ENG103334,Coefficient vmd_k_FlwC1_OddBFw-Koeffizient,1116934670,
    ENG107281-ENG103334,Coefficient vmd_k_FlwC2_Even_ABw-Koeffizient,0,
    ENG107282-ENG103334,Coefficient vmd_k_FlwC2_Even_AFw-Koeffizient,0,
    ENG107283-ENG103334,Coefficient vmd_k_FlwC2_Even_BBw-Koeffizient,0,
    ENG107284-ENG103334,Coefficient vmd_k_FlwC2_Even_BFw-Koeffizient,1102942862,
    ENG107285-ENG103334,Coefficient vmd_k_FlwC2_OddABw-Koeffizient,1082712601,
    ENG107286-ENG103334,Coefficient vmd_k_FlwC2_OddAFw-Koeffizient,1084672348,
    ENG107287-ENG103334,Coefficient vmd_k_FlwC2_OddBBw-Koeffizient,925353388,
    ENG107288-ENG103334,Coefficient vmd_k_FlwC2_OddBFw-Koeffizient,1079420912,
    ENG107289-ENG103334,Coefficient vmd_k_FlwC3_Even_ABw-Koeffizient,3265459438,
    ENG107290-ENG103334,Coefficient vmd_k_FlwC3_Even_AFw-Koeffizient,1119277862,
    ENG107291-ENG103334,Coefficient vmd_k_FlwC3_Even_BBw-Koeffizient,3269055515,
    ENG107292-ENG103334,Coefficient vmd_k_FlwC3_Even_BFw-Koeffizient,3271532063,
    ENG107293-ENG103334,Coefficient vmd_k_FlwC3_OddABw-Koeffizient,3265226713,
    ENG107294-ENG103334,Coefficient vmd_k_FlwC3_OddAFw-Koeffizient,1104447637,
    ENG107295-ENG103334,Coefficient vmd_k_FlwC3_OddBBw-Koeffizient,3269156293,
    ENG107296-ENG103334,Coefficient vmd_k_FlwC3_OddBFw-Koeffizient,1080600308,
    ENG107297-ENG103334,Coefficient vmd_k_Line_C0-Koeffizient,3237477058,
    ENG107298-ENG103334,Coefficient vmd_k_Line_C1-Koeffizient,1146581125,
    ENG107299-ENG103334,Coefficient vmd_k_Line_C2-Koeffizient,3235067388,
    ENG107300-ENG103334,Coefficient vmd_k_Line_C3-Koeffizient,3210254179,
    ENG107301-ENG103334,Coefficient vmd_k_Line_C4-Koeffizient,1135886312,
    ENG99212,Common highside 1 specified condition,Common Highside soll eingeschaltet werden,
    ENG99878,Common highside 2 specified condition,Common Highside soll ausgeschaltet werden,
    ENG103403,Converter Loss Torque,6.9, Nm
    ENG100625,Coolant temperature,22, °C
    ENG99080,Designation entire-software,R62,
    ENG104016,Designation VWDQ-Lib,R61C01,
    ENG103822,Driver logon procedure: cause,0,
    ENG103514,Driver logon procedure: shaft,0,
    ENG103332,Driver logon procedure: vehicle odometer reading,0, km
    ENG98602,Driver request torque,-75.0, Nm
    ENG100746,Driving strategy: sport factor,0.0, %
    ENG101251,Empty,Empty,
    ENG99932,Engine coding info,57,
    ENG98585,Engine torque,0.0, Nm
    ENG101555,Engine torque limitation,463.0, Nm
    ENG104230,Engine torque loss,75.0, Nm
    ENG106287-ENG104036,Enriched maximum temperature clutch 1-Erreichte Maximaltemperatur Kupplung 1,143, °C
    ENG106287-ENG103379,Enriched maximum temperature clutch 1-Erreichte Maximaltemperatur Kupplung 2,148, °C
    ENG106553-ENG99912,FID memory entry-FID Fehlerspeicher 1,FF FF,
    ENG106553-ENG103610,FID memory entry-FID Fehlerspeicher 10,FF FF,
    ENG106553-ENG100206,FID memory entry-FID Fehlerspeicher 11,FF FF,
    ENG106553-ENG102629,FID memory entry-FID Fehlerspeicher 12,FF FF,
    ENG106553-ENG101958,FID memory entry-FID Fehlerspeicher 2,FF FF,
    ENG106553-ENG100537,FID memory entry-FID Fehlerspeicher 3,FF FF,
    ENG106553-ENG100043,FID memory entry-FID Fehlerspeicher 4,FF FF,
    ENG106553-ENG101208,FID memory entry-FID Fehlerspeicher 5,FF FF,
    ENG106553-ENG103015,FID memory entry-FID Fehlerspeicher 6,FF FF,
    ENG106553-ENG99633,FID memory entry-FID Fehlerspeicher 7,FF FF,
    ENG106553-ENG101556,FID memory entry-FID Fehlerspeicher 8,FF FF,
    ENG106553-ENG99976,FID memory entry-FID Fehlerspeicher 9,FF FF,
    ENG100414,Gangsteller A Adaption Neutralposition,-0.1, mm
    ENG100089,Gangsteller B Adaption Neutralposition,0.3, mm
    ENG103055,Gangsteller C Adaption Neutralposition,0.2, mm
    ENG101354,Gangsteller D Adaption Neutralposition,-0.1, mm
    ENG110510,Gear actuator adaption engaged position G1,-8.2, mm
    ENG110511,Gear actuator adaption engaged position G2,-8.7, mm
    ENG110512,Gear actuator adaption engaged position G3,8.6, mm
    ENG99484,Gear actuator adaption engaged position G4,8.0, mm
    ENG110513,Gear actuator adaption engaged position G5,7.7, mm
    ENG110514,Gear actuator adaption engaged position G6,9.4, mm
    ENG110515,Gear actuator adaption engaged position G7,-7.7, mm
    ENG110516,Gear actuator adaption engaged position GR,-7.9, mm
    ENG110517,Gear actuator adaption synchro position G1,-1.8, mm
    ENG110518,Gear actuator adaption synchro position G2,-1.3, mm
    ENG110519,Gear actuator adaption synchro position G3,1.9, mm
    ENG99198,Gear actuator adaption synchro position G4,1.6, mm
    ENG110520,Gear actuator adaption synchro position G5,1.7, mm
    ENG110521,Gear actuator adaption synchro position G6,1.8, mm
    ENG110522,Gear actuator adaption synchro position G7,-1.4, mm
    ENG110523,Gear actuator adaption synchro position GR,-1.7, mm
    ENG99720,Height info,974, mbar
    ENG98604,Hill factor driving strategy,0.0, %
    ENG103672,Hybrid maximum temperature,86, °C
    ENG99596,Indicated engine torque without external interventions,0.0, Nm
    ENG99582,Intake air temperature,31, °C
    ENG101816,K010_Odometer Internal,65, km
    ENG110538,Kupplung 2 Adaption Kupplungsendlage (KEL) geschlossen,15.0, bar
    ENG110539,Kupplung 2 Adaption Kupplungsendlage (KEL) offen,0.0, bar
    ENG110556-ENG110541,Leak oil compensation K1-Abbruch Zähler K1 Drucküberwachung,0,
    ENG110556-ENG110542,Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu groß,0,
    ENG110556-ENG110543,Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu klein,0,
    ENG110556-ENG110540,Leak oil compensation K1-Erfolgreiche K1 Leckölkompensation,0,
    ENG110557-ENG110545,Leak oil compensation K2-Abbruch Zähler K2 Drucküberwachung,0,
    ENG110557-ENG110546,Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu groß,0,
    ENG110557-ENG110547,Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu klein,0,
    ENG110557-ENG110544,Leak oil compensation K2-Erfolgreiche K2 Leckölkompensationen,0,
    ENG107605-ENG103083,Mechatronics-ID_Dev.-Baudatum,190117,
    ENG107605-ENG98675,Mechatronics-ID_Dev.-Construction version,A6,
    ENG107605-ENG99175,Mechatronics-ID_Dev.-Kassel,K,
    ENG107605-ENG104192,Mechatronics-ID_Dev.-Kennung der Mechatronik-Montagelinie,A02,
    ENG107605-ENG103830,Mechatronics-ID_Dev.-Lfd.-Nr,0341,
    ENG107605-ENG103525,Mechatronics-ID_Dev.-Teilenummer (3 letzten + Index),0BZF ,
    ENG101570,Neut. through logon proc. cond.: km traveled,0, km
    ENG105186-ENG100464,Number of gear jumps 7th gear-Anzahl Gangspringer 1-Gang,0,
    ENG105186-ENG103518,Number of gear jumps 7th gear-Anzahl Gangspringer 2-Gang,0,
    ENG105186-ENG101484,Number of gear jumps 7th gear-Anzahl Gangspringer 3-Gang,0,
    ENG105186-ENG102434,Number of gear jumps 7th gear-Anzahl Gangspringer 4-Gang,0,
    ENG105186-ENG100828,Number of gear jumps 7th gear-Anzahl Gangspringer 5-Gang,0,
    ENG105186-ENG99747,Number of gear jumps 7th gear-Anzahl Gangspringer 6-Gang,0,
    ENG105186-ENG102967,Number of gear jumps 7th gear-Anzahl Gangspringer 7-Gang,0,
    ENG105186-ENG100893,Number of gear jumps 7th gear-Anzahl Gangspringer R-Gang,0,
    ENG105185-ENG102381,Number of successful engagement operations 7th-gear-Anzahl erfolgreiche Einlegevorgänge 1-Gang,65,
    ENG105185-ENG99964,Number of successful engagement operations 7th-gear-Anzahl erfolgreiche Einlegevorgänge 2-Gang,125,
    ENG105185-ENG100231,Number of successful engagement operations 7th-gear-Anzahl erfolgreiche Einlegevorgänge 3-Gang,111,
    ENG105185-ENG104160,Number of successful engagement operations 7th-gear-Anzahl erfolgreiche Einlegevorgänge 4-Gang,89,
    ENG105185-ENG102663,Number of successful engagement operations 7th-gear-Anzahl erfolgreiche Einlegevorgänge 5-Gang,72,
    ENG105185-ENG99465,Number of successful engagement operations 7th-gear-Anzahl erfolgreiche Einlegevorgänge 6-Gang,44,
    ENG105185-ENG103205,Number of successful engagement operations 7th-gear-Anzahl erfolgreiche Einlegevorgänge 7-Gang,45,
    ENG105185-ENG103678,Number of successful engagement operations 7th-gear-Anzahl erfolgreiche Einlegevorgänge R-Gang,69,
    ENG105187-ENG103574,Number of unsuccessful engagement operations 7th gear-Anzahl nicht erfolgreiche Einlegevorgänge 1-Gang,0,
    ENG105187-ENG103754,Number of unsuccessful engagement operations 7th gear-Anzahl nicht erfolgreiche Einlegevorgänge 2-Gang,0,
    ENG105187-ENG99560,Number of unsuccessful engagement operations 7th gear-Anzahl nicht erfolgreiche Einlegevorgänge 3-Gang,0,
    ENG105187-ENG101116,Number of unsuccessful engagement operations 7th gear-Anzahl nicht erfolgreiche Einlegevorgänge 4-Gang,0,
    ENG105187-ENG99083,Number of unsuccessful engagement operations 7th gear-Anzahl nicht erfolgreiche Einlegevorgänge 5-Gang,0,
    ENG105187-ENG99508,Number of unsuccessful engagement operations 7th gear-Anzahl nicht erfolgreiche Einlegevorgänge 6-Gang,0,
    ENG105187-ENG101966,Number of unsuccessful engagement operations 7th gear-Anzahl nicht erfolgreiche Einlegevorgänge 7-Gang,0,
    ENG105187-ENG103519,Number of unsuccessful engagement operations 7th gear-Anzahl nicht erfolgreiche Einlegevorgänge R-Gang,0,
    ENG104079,Odometer state: last chng GE clutch mov press. char. curve,Not supported,
    ENG105325-ENG100707,Operating time clutch 1 (temperature range 1-4) / operating-Betriebszeit Kupplung 1 (Temperaturbereich 1),12.2, H
    ENG105325-ENG101697,Operating time clutch 1 (temperature range 1-4) / operating-Betriebszeit Kupplung 1 (Temperaturbereich 2),1.2, H
    ENG105325-ENG100556,Operating time clutch 1 (temperature range 1-4) / operating-Betriebszeit Kupplung 1 (Temperaturbereich 3),0.0, H
    ENG105325-ENG100205,Operating time clutch 1 (temperature range 1-4) / operating-Betriebszeit Kupplung 1 (Temperaturbereich 4),0.0, H
    ENG105324-ENG101291,Operating time clutch 1 (torque range 1-5) / operating time-Betriebszeit Kupplung 1 (Momentenbereich 1),0.4, H
    ENG105324-ENG104169,Operating time clutch 1 (torque range 1-5) / operating time-Betriebszeit Kupplung 1 (Momentenbereich 2),0.1, H
    ENG105324-ENG100021,Operating time clutch 1 (torque range 1-5) / operating time-Betriebszeit Kupplung 1 (Momentenbereich 3),0.0, H
    ENG105324-ENG101292,Operating time clutch 1 (torque range 1-5) / operating time-Betriebszeit Kupplung 1 (Momentenbereich 4),0.0, H
    ENG105324-ENG99418,Operating time clutch 1 (torque range 1-5) / operating time-Betriebszeit Kupplung 1 (Momentenbereich 5),0.0, H
    ENG105327-ENG103428,Operating time clutch 2 (temperature range 1-4) / operating-Betriebszeit Kupplung 2 (Temperaturbereich 1),12.2, H
    ENG105327-ENG101321,Operating time clutch 2 (temperature range 1-4) / operating-Betriebszeit Kupplung 2 (Temperaturbereich 2),1.2, H
    ENG105327-ENG100639,Operating time clutch 2 (temperature range 1-4) / operating-Betriebszeit Kupplung 2 (Temperaturbereich 3),0.0, H
    ENG105327-ENG103433,Operating time clutch 2 (temperature range 1-4) / operating-Betriebszeit Kupplung 2 (Temperaturbereich 4),0.0, H
    ENG105326-ENG99240,Operating time clutch 2 (torque range 1-5) / operating time-Betriebszeit Kupplung 2 (Momentenbereich 1),0.3, H
    ENG105326-ENG99973,Operating time clutch 2 (torque range 1-5) / operating time-Betriebszeit Kupplung 2 (Momentenbereich 2),0.1, H
    ENG105326-ENG103238,Operating time clutch 2 (torque range 1-5) / operating time-Betriebszeit Kupplung 2 (Momentenbereich 3),0.0, H
    ENG105326-ENG101007,Operating time clutch 2 (torque range 1-5) / operating time-Betriebszeit Kupplung 2 (Momentenbereich 4),0.0, H
    ENG105326-ENG101190,Operating time clutch 2 (torque range 1-5) / operating time-Betriebszeit Kupplung 2 (Momentenbereich 5),0.0, H
    ENG105329-ENG101124,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 1),0.0, H
    ENG105329-ENG100216,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 2),13.2, H
    ENG105329-ENG103067,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 3),0.2, H
    ENG105329-ENG101168,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 4),0.0, H
    ENG105329-ENG104150,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 5),0.0, H
    ENG105329-ENG100130,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 6),0.0, H
    ENG105328-ENG102219,Operating time engine (speed 1-5) /operating time engine (sp-Betriebszeit Motor (Drehzahlbereich 1),1.7, H
    ENG105328-ENG103682,Operating time engine (speed 1-5) /operating time engine (sp-Betriebszeit Motor (Drehzahlbereich 2),0.3, H
    ENG105328-ENG101200,Operating time engine (speed 1-5) /operating time engine (sp-Betriebszeit Motor (Drehzahlbereich 3),0.0, H
    ENG105328-ENG100226,Operating time engine (speed 1-5) /operating time engine (sp-Betriebszeit Motor (Drehzahlbereich 4),0.0, H
    ENG105328-ENG102223,Operating time engine (speed 1-5) /operating time engine (sp-Betriebszeit Motor (Drehzahlbereich 5),0.0, H
    ENG103874,Parameter set description,SES_4S0927155AC_6202_par,
    ENG100188,Reached maximum temperature control module,86, °C
    ENG102793,Road Resistance,0.3, %
    ENG103000,Run time complete system,13.3830, H
    ENG102748,Selector lever error flags,00 00,
    ENG06547,Signal_Waehlhebel_Reset,0,
    ENG100909,Snapshot 1 Info current ECM3 error 0,0,
    ENG100722,Snapshot 1 Info current ECM3 error 1,0,
    ENG103157,Snapshot 1 Info old ECM3 error 0,0,
    ENG99098,Snapshot 1 Info old ECM3 error 1,0,
    ENG102200,Snapshot 2 Info current ECM3 error 0,0,
    ENG101765,Snapshot 2 Info current ECM3 error 1,0,
    ENG101738,Snapshot 2 Info old ECM3 error 0,0,
    ENG101881,Snapshot 2 Info old ECM3 error 1,0,
    ENG121992,Spare Part Number,           ,
    ENG101057,Specified idle speed,930, /min
    ENG100803,Speed: output,0, /min
    ENG103454,Temperature hybrid time in region 0,0.0, s
    ENG103243,Temperature hybrid time in region 1,47404.9, s
    ENG102141,Temperature hybrid time in region 2,771.2, s
    ENG101757,Temperature hybrid time in region 3,0.0, s
    ENG100964,Temperature hybrid time in region 4,0.0, s
    ENG103493,Temperature hybrid time in region 5,0.0, s
    ENG100141,Transmission coding info,31,
    ENG106780-ENG103213,Transmission-ID_Dev.-Aggregatekennzeichnung (Getriebe),006,
    ENG106780-ENG103083,Transmission-ID_Dev.-Baudatum,190204,
    ENG106780-ENG104019,Transmission-ID_Dev.-Getriebekennbuchstabe,TMY,
    ENG106780-ENG99175,Transmission-ID_Dev.-Kassel,K,
    ENG106780-ENG101707,Transmission-ID_Dev.-Kennung der Montagelinie,F05,
    ENG106780-ENG103830,Transmission-ID_Dev.-Lfd.-Nr,0003,
    ENG121994-ENG122004,Ueberwachung_Ueberschwinger_Gangauslegen-Anzahl der Ueberschwinger auf gegenueberliegenden Sync-Position Gang-1,0,
    ENG121994-ENG122005,Ueberwachung_Ueberschwinger_Gangauslegen-Anzahl der Ueberschwinger auf gegenueberliegenden Sync-Position Gang-2,1,
    ENG121994-ENG122006,Ueberwachung_Ueberschwinger_Gangauslegen-Anzahl der Ueberschwinger auf gegenueberliegenden Sync-Position Gang-3,0,
    ENG121994-ENG122007,Ueberwachung_Ueberschwinger_Gangauslegen-Anzahl der Ueberschwinger auf gegenueberliegenden Sync-Position Gang-4,0,
    ENG121994-ENG122008,Ueberwachung_Ueberschwinger_Gangauslegen-Anzahl der Ueberschwinger auf gegenueberliegenden Sync-Position Gang-5,0,
    ENG121994-ENG122009,Ueberwachung_Ueberschwinger_Gangauslegen-Anzahl der Ueberschwinger auf gegenueberliegenden Sync-Position Gang-6,0,
    ENG121994-ENG122010,Ueberwachung_Ueberschwinger_Gangauslegen-Anzahl der Ueberschwinger auf gegenueberliegenden Sync-Position Gang-7,0,
    ENG121994-ENG122011,Ueberwachung_Ueberschwinger_Gangauslegen-Anzahl der Ueberschwinger auf gegenueberliegenden Sync-Position Gang-R,0,
    ENG121994-ENG121996,Ueberwachung_Ueberschwinger_Gangauslegen-Gesamtzahl der Auslegevorgaenge Gang-1,79,
    ENG121994-ENG121997,Ueberwachung_Ueberschwinger_Gangauslegen-Gesamtzahl der Auslegevorgaenge Gang-2,138,
    ENG121994-ENG121998,Ueberwachung_Ueberschwinger_Gangauslegen-Gesamtzahl der Auslegevorgaenge Gang-3,118,
    ENG121994-ENG121999,Ueberwachung_Ueberschwinger_Gangauslegen-Gesamtzahl der Auslegevorgaenge Gang-4,98,
    ENG121994-ENG122000,Ueberwachung_Ueberschwinger_Gangauslegen-Gesamtzahl der Auslegevorgaenge Gang-5,95,
    ENG121994-ENG122001,Ueberwachung_Ueberschwinger_Gangauslegen-Gesamtzahl der Auslegevorgaenge Gang-6,68,
    ENG121994-ENG122002,Ueberwachung_Ueberschwinger_Gangauslegen-Gesamtzahl der Auslegevorgaenge Gang-7,53,
    ENG121994-ENG122003,Ueberwachung_Ueberschwinger_Gangauslegen-Gesamtzahl der Auslegevorgaenge Gang-R,75,
    ENG121994-ENG122012,Ueberwachung_Ueberschwinger_Gangauslegen-Groesste Naehe zur gegenueberliegenden Sync-Position Gang-1,0.00, mm
    ENG121994-ENG122013,Ueberwachung_Ueberschwinger_Gangauslegen-Groesste Naehe zur gegenueberliegenden Sync-Position Gang-2,0.18, mm
    ENG121994-ENG122014,Ueberwachung_Ueberschwinger_Gangauslegen-Groesste Naehe zur gegenueberliegenden Sync-Position Gang-3,0.00, mm
    ENG121994-ENG122015,Ueberwachung_Ueberschwinger_Gangauslegen-Groesste Naehe zur gegenueberliegenden Sync-Position Gang-4,0.00, mm
    ENG121994-ENG122016,Ueberwachung_Ueberschwinger_Gangauslegen-Groesste Naehe zur gegenueberliegenden Sync-Position Gang-5,0.00, mm
    ENG121994-ENG122017,Ueberwachung_Ueberschwinger_Gangauslegen-Groesste Naehe zur gegenueberliegenden Sync-Position Gang-6,0.00, mm
    ENG121994-ENG122018,Ueberwachung_Ueberschwinger_Gangauslegen-Groesste Naehe zur gegenueberliegenden Sync-Position Gang-7,0.00, mm
    ENG121994-ENG122019,Ueberwachung_Ueberschwinger_Gangauslegen-Groesste Naehe zur gegenueberliegenden Sync-Position Gang-R,0.00, mm
    ENG103964,Veh. odometer state: last change of GE gear selector data,0, km
    ENG99024,Vehicle speed from transmission,0.0, km/h
    ENG101346,Version info driving strategy,FSJRMQIEI.039,
    ENG109959-ENG101914,vmd_i_FlwVlvCurMin_mA_EvenA-vmd i FlwVlvCurMin mA EvenA,457,
    ENG109960-ENG104144,vmd_i_FlwVlvCurMin_mA_EvenB-vmd i FlwVlvCurMin mA EvenB,452,
    ENG109961-ENG101870,vmd_i_FlwVlvCurMin_mA_OddA-vmd i FlwVlvCurMin mA OddA,454,
    ENG109962-ENG102688,vmd_i_FlwVlvCurMin_mA_OddB-vmd i FlwVlvCurMin mA OddB,471,
    ENG109963-ENG103264,vmd_i_NulFlw_mA_Even_ABw-vmd i NulFlw mA Even ABw,721,
    ENG109964-ENG100102,vmd_i_NulFlw_mA_Even_AFw-vmd i NulFlw mA Even AFw,805,
    ENG109965-ENG103659,vmd_i_NulFlw_mA_Even_BBw-vmd i NulFlw mA Even BBw,718,
    ENG109966-ENG100519,vmd_i_NulFlw_mA_Even_BFw-vmd i NulFlw mA Even BFw,811,
    ENG109967-ENG99410,vmd_i_NulFlw_mA_OddABw-vmd i NulFlw mA OddABw,716,
    ENG109968-ENG99443,vmd_i_NulFlw_mA_OddAFw-vmd i NulFlw mA OddAFw,821,
    ENG109969-ENG100167,vmd_i_NulFlw_mA_OddBBw-vmd i NulFlw mA OddBBw,738,
    ENG109970-ENG99387,vmd_i_NulFlw_mA_OddBFw-vmd i NulFlw mA OddBFw,822,
    ENG109971-ENG103334,vmd_k_Line_PmaxKoeffizient vmd_k_Line_Pmax-Koeffizient,1103203999,
    ENG109005-ENG101799,Voltage Common Highside 1-Param to DOP,12.4, V
    ENG99955,Voltage Common Highside 2,12.4, V
    Elapsed Time: 00:34
    adpmap-02-4S0-927-155-AC
    ;Saturday,10,August,2019,09:37:33:30091
    IDE06425-Roller test bench mode: functional,Deactivated ,1
    Elapsed Time: 00:00
    Address - [03]
    blockmap-03-4S0-907-379-J
    ;SW:4S0-907-379-J   HW:4S0-907-379-J ---  ABS Brakes
    ;Component:ESP PREMIUM   H09 0600, Coding:01A1C10B808583D04B00
    ;EV_ESPPremiAU57X,004050,EV_ESPPremiAU57X_AU72.rod
    ;Saturday,10,August,2019,09:37:51:30091
    ;VCID: 44D246785E1C8797AE1-8010
    IDE00019,Voltage terminal 30,12.48, V
    IDE00021,Engine speed,0, /min
    IDE00030,Status of actuator test,not active,
    IDE00150,Pressure in brake booster,959.313, mbar
    IDE00323,Security Access: Number of invalid keys,0,
    IDE00326,Steering wheel angle,-0.21875, °
    IDE00450-ENG101799,Operating Instructions-Param to DOP,Stop requested,
    IDE00609-MAS00811,Communication status of data bus 1-Active steering control module,detected,
    IDE00609-MAS00815,Communication status of data bus 1-Steering angle sensor,detected,
    IDE00920,Front left wheel speed,0, km/h
    IDE00921,Front right wheel speed,0, km/h
    IDE00922,Left rear wheel speed,0, km/h
    IDE00923,Right rear wheel speed,0, km/h
    IDE02211,Brake pressure,0.0000, bar
    IDE02239-ENG101799,Rotation rate sensor 1-Param to DOP,0.0000, rad/s
    IDE02241,Lateral acceleration sensor 1,-0.19, m/s²
    IDE02243-ENG101799,Rotation rate sensor 2-Param to DOP,0.0021, rad/s
    IDE02245,Lateral acceleration sensor 2,0.00, m/s²
    IDE02305,ESP brake application information,not activated,
    IDE02306,Engine brake application information,not activated,
    IDE02307,Parking brake status,operated,
    IDE02308,ESP button status,not activated,
    IDE02309,Valve relay status,passive,
    IDE02310,Status of return pump,passive,
    IDE02311,Left front wheel speed sensor installation position,Not available,
    IDE02312,Right front wheel speed sensor installation position,Not available,
    IDE02313,Left rear wheel speed sensor installation position,Not available,
    IDE02314,Right rear wheel speed sensor installation position,Not available,
    IDE02315,Direction of rotation front left wheel speed sensor,invalid,
    IDE02316,Direction of rotation front right wheel speed sensor,invalid,
    IDE02317,Direction of rotation rear left wheel speed sensor,invalid,
    IDE02318,Direction of rotation rear right wheel speed sensor,invalid,
    IDE02319-MAS02149,Hill start assistant signals-Hillside power take-off torque high wheel limit crawl torque,active,
    IDE02319-MAS02150,Hill start assistant signals-Engine torque high hillside power take-off torque,passive,
    IDE02319-MAS02151,Hill start assistant signals-Q bit: incline angle EPB,passive,
    IDE02319-MAS02153,Hill start assistant signals-Q bit EPB clutch pedal travel,passive,
    IDE02319-MAS02154,Hill start assistant signals-Q bit EPB switch position,passive,
    IDE02319-MAS02155,Hill start assistant signals-EPB error status,passive,
    IDE02320,Status overview ESP,active,
    IDE02320-MAS02136,Status overview ESP-Trailer stabilization,passive,
    IDE02320-MAS02137,Status overview ESP-Brake disc wiper,active,
    IDE02320-MAS02138,Status overview ESP-Hill-start assistant,active,
    IDE02320-MAS02139,Status overview ESP-SBC Hold assistant,passive,
    IDE02320-MAS02140,Status overview ESP-ESP coasting operation,passive,
    IDE02320-MAS02141,Status overview ESP-Monitoring VIN,active,
    IDE02320-MAS02142,Status overview ESP-Function µ-split,passive,
    IDE02320-MAS02143,Status overview ESP-Oversteering function,passive,
    IDE02320-MAS02144,Status overview ESP-Understeering function,passive,
    IDE02320-MAS02145,Status overview ESP-ESP ADS coding,passive,
    IDE02320-MAS02146,Status overview ESP-RKA+,passive,
    IDE02320-MAS02147,Status overview ESP-Text output,On,
    IDE02320-MAS02148,Status overview ESP-Acoustic output,On,
    IDE03008-MAS04511,Stop process prevented-Skidding vehicle detected,not active,
    IDE03008-MAS04512,Stop process prevented-Hard deceleration to standstill,not active,
    IDE03008-MAS04513,Stop process prevented-Brake control module pump operation,not active,
    IDE03008-MAS04514,Stop process prevented-Button for hill descent assist operated,not active,
    IDE03008-MAS04515,Stop process prevented-Roll-back detected,not active,
    IDE03008-ENG111908,Stop process prevented-Prohibition_Reason_4_ActiveAdaption,not active,
    IDE03008-ENG111907,Stop process prevented-Prohibition_Reason_5_Systemerror,not active,
    IDE03009-MAS04511,Start process requested-Skidding vehicle detected,not active,
    IDE03009-MAS04512,Start process requested-Hard deceleration to standstill,not active,
    IDE03009-MAS04513,Start process requested-Brake control module pump operation,not active,
    IDE03009-MAS04514,Start process requested-Button for hill descent assist operated,not active,
    IDE03009-MAS04515,Start process requested-Roll-back detected,not active,
    IDE03009-ENG111910,Start process requested-Restart_Reason_4_ActiveAdaption,not active,
    IDE03009-ENG111909,Start process requested-Restart_Reason_5_Systemerror,not active,
    IDE03010-MAS04511,Number of prevented stop processes-Skidding vehicle detected,0,
    IDE03010-MAS04512,Number of prevented stop processes-Hard deceleration to standstill,0,
    IDE03010-MAS04513,Number of prevented stop processes-Brake control module pump operation,0,
    IDE03010-MAS04514,Number of prevented stop processes-Button for hill descent assist operated,0,
    IDE03010-MAS04515,Number of prevented stop processes-Roll-back detected,0,
    IDE03010-ENG111908,Number of prevented stop processes-Prohibition_Reason_4_ActiveAdaption,0,
    IDE03010-ENG111907,Number of prevented stop processes-Prohibition_Reason_5_Systemerror,0,
    IDE03011-MAS04511,Number of requested start processes-Skidding vehicle detected,0,
    IDE03011-MAS04512,Number of requested start processes-Hard deceleration to standstill,0,
    IDE03011-MAS04513,Number of requested start processes-Brake control module pump operation,0,
    IDE03011-MAS04514,Number of requested start processes-Button for hill descent assist operated,0,
    IDE03011-MAS04515,Number of requested start processes-Roll-back detected,0,
    IDE03011-ENG111910,Number of requested start processes-Restart_Reason_4_ActiveAdaption,0,
    IDE03011-ENG111909,Number of requested start processes-Restart_Reason_5_Systemerror,0,
    IDE03127-IDE03008,Prevented stop processes (ring memory)-Stop process prevented,Measured value not available,
    IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2127,
    IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,15,
    IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,31,
    IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,31,
    IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,63,
    IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,63,
    IDE03128-IDE03009,Requested start processes (ring memory)-Start process requested,Measured value not available,
    IDE03128-MAS00106,Requested start processes (ring memory)-Year,2127,
    IDE03128-MAS00107,Requested start processes (ring memory)-Month,15,
    IDE03128-MAS00108,Requested start processes (ring memory)-Day,31,
    IDE03128-MAS00109,Requested start processes (ring memory)-Hours,31,
    IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,63,
    IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,63,
    IDE03212,Start-stop conditions,Stop release,
    IDE03213,Start-stop enabling,System malfunction,
    IDE03220-MAS00076,Communication status of data bus 2-Instrument cluster control module,detected,
    IDE03220-MAS00657,Communication status of data bus 2-All wheel drive control module,detected,
    IDE03220-MAS00661,Communication status of data bus 2-Level Control System Control Module,detected,
    IDE03220-MAS00795,Communication status of data bus 2-Diagnostic interface for data bus,detected,
    IDE03220-MAS00796,Communication status of data bus 2-Engine Control Module (ECM),detected,
    IDE03220-MAS00798,Communication status of data bus 2-Transmission Control Module (TCM),detected,
    IDE03220-MAS00799,Communication status of data bus 2-Airbag control module,detected,
    IDE03220-MAS00802,Communication status of data bus 2-Control module for distance control,detected,
    IDE03220-MAS00809,Communication status of data bus 2-Electro-Mechanical Parking Brake Control Module,detected,
    IDE03220-MAS00821,Communication status of data bus 2-Central ctrl. unit for comfort system,detected,
    IDE03220-MAS00830,Communication status of data bus 2-Towing recognition control module,detected,
    IDE03220-MAS02828,Communication status of data bus 2-Comfort system central control module 2,detected,
    IDE03491,Hydraulic pump run-on time,0,
    IDE03493-ENG111859,Driver door status-Switch Status FlexRay,Open,
    IDE03493-ENG111860,Driver door status-Switch Status HW,closed,
    IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
    IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
    IDE06752,Hill descent control button,not coded/not installed,
    MAS00364-ENG98385,Shift lever / selector lever position-Back-up light,passive,
    MAS00364-ENG98561,Shift lever / selector lever position-Driver door status,Open,
    MAS00364-ENG100940,Shift lever / selector lever position-forward gear status,passive,
    MAS00364-ENG101311,Shift lever / selector lever position-gearshift position,5,
    MAS00364-ENG101302,Shift lever / selector lever position-safty belt warning,active,
    MAS02117,Engine torque with external intervention,0, Nm
    MAS02118,Engine torque loss,75, Nm
    MAS02119,Throttle valve angle,0, %
    MAS02120-ENG98653,Instrument cluster info holding time-Hour,0, H
    MAS02120-ENG98739,Instrument cluster info holding time-Minute,0, min
    MAS02121,ESP info EDS temperature flag,passive,
    MAS02122,ESP info driver applying brakes Q bit,passive,
    MAS02124-ENG101799,Steering wheel angle sub data-Param to DOP,818.4, °
    MAS02134-ENG101799,Rotation rate sensor difference-Param to DOP,0.0021, rad/s
    MAS02135,Lateral acceleration difference sensor,0.00, m/s²
    MAS02152,EPB clutch pedal travel,0, %
    MAS02156,Button for SBC Hold assistant status,not activated,
    ENG111876,actual superposition angle dynamic steering,0.00000, °
    ENG111879,angle intervention esp,0,
    ENG105314-ENG101167,BB-No. and SW version-Base version,2300,
    ENG105314-ENG101969,BB-No. and SW version-BB-No.,66037,
    ENG105314-ENG98430,BB-No. and SW version-Branch 1,0000,
    ENG105314-ENG98431,BB-No. and SW version-Branch 2,0000,
    ENG105366,BTM Driving with pushed brakes,0,
    ENG105367-ENG98504,BTM Last occurence of driving with pushed brakes-Day,0, d
    ENG105367-ENG98748,BTM Last occurence of driving with pushed brakes-Month,0, mon
    ENG105367-ENG99063,BTM Last occurence of driving with pushed brakes-Year,2000, yr
    ENG105368-ENG98504,BTM Last occurence of maximum temp FL-Day,22, d
    ENG105368-ENG98748,BTM Last occurence of maximum temp FL-Month,3, mon
    ENG105368-ENG99063,BTM Last occurence of maximum temp FL-Year,2019, yr
    ENG105369-ENG98504,BTM Last occurence of temperature FL greater than temp limit-Day,0, d
    ENG105369-ENG98748,BTM Last occurence of temperature FL greater than temp limit-Month,0, mon
    ENG105369-ENG99063,BTM Last occurence of temperature FL greater than temp limit-Year,2000, yr
    ENG105370-ENG98504,BTM Last reset of driving with pushed brakes-Day,0, d
    ENG105370-ENG98748,BTM Last reset of driving with pushed brakes-Month,0, mon
    ENG105370-ENG99063,BTM Last reset of driving with pushed brakes-Year,2000, yr
    ENG105371-ENG98504,BTM Last reset of maximum temp FL-Day,0, d
    ENG105371-ENG98748,BTM Last reset of maximum temp FL-Month,0, mon
    ENG105371-ENG99063,BTM Last reset of maximum temp FL-Year,2000, yr
    ENG105372-ENG98504,BTM Last reset of temperature FL greater than temp limit-Day,0, d
    ENG105372-ENG98748,BTM Last reset of temperature FL greater than temp limit-Month,0, mon
    ENG105372-ENG99063,BTM Last reset of temperature FL greater than temp limit-Year,2000, yr
    ENG105373,BTM Maximum temp of temperature brake FL,350, °C
    ENG105374,BTM Time of temperature FL greater than temp limit,0,
    ENG98475,Coding dynamic steering in ESP,Value0,
    ENG105902,downtilt,valid,
    ENG106309,ESP Sensor unit 2: turn rate: confidence factor,0,
    ENG106310,ESP Sensor unit: lateral acceleration: confidence factor,0,
    ENG106311,ESP Sensor unit: longitudinal acceleration,0.00, m/s²
    ENG106312,ESP Sensor unit: longitudinal acceleration: confidence factor,0,
    ENG106313,ESP Sensor unit: turn rate: confidence factor,0,
    ENG106552,FIBEX Version,0608_00,
    ENG98615,Forward gear engaged,passive,
    ENG98753,Maximum gradient dynamic steering,0,
    ENG111878,nominal angle esp,0.00000, °
    ENG111877,nominal superposition angle dynamic steering,0.00000, °
    ENG108404,Reached elasticity,12,
    ENG108464,Reverse Light Switch,passive,
    ENG98935,Status dynamic steering,0,
    ENG111880,status esp of dynamic steering,Value0,
    ENG109112-MAS02126,steering angle sensor data-Steering angle sensor: status,active,
    ENG109112-MAS02127,steering angle sensor data-Q bit: steering wheel angle sub data,active,
    ENG109112-MAS02128,steering angle sensor data-Q bit: steering wheel angle,active,
    ENG111881,steering intervention esp of dynamic steering,passive,
    ENG100575-ENG101799,Switch status Electronic Park Brake-Param to DOP,Not operated,
    ENG109448-MAS01143,TimeStamp Faultmemory Deletion-Device number,2097151,
    ENG109448-MAS01144,TimeStamp Faultmemory Deletion-Importer number,1023,
    ENG109448-MAS01145,TimeStamp Faultmemory Deletion-Dealership number,131071,
    ENG109448-ENG98504,TimeStamp Faultmemory Deletion-Day,24,
    ENG109448-ENG98653,TimeStamp Faultmemory Deletion-Hour,18,
    ENG109448-ENG98672,TimeStamp Faultmemory Deletion-km,59,
    ENG109448-ENG98739,TimeStamp Faultmemory Deletion-Minute,16,
    ENG109448-ENG98748,TimeStamp Faultmemory Deletion-Month,6,
    ENG109448-ENG102365,TimeStamp Faultmemory Deletion-Second,21,
    ENG109448-ENG99063,TimeStamp Faultmemory Deletion-Year,2019,
    ENG109899,VIN last coding,FX00262,
    ENG110108-ENG103252,WAU Info KL15-FlexRay Transceiver PIN,active,
    ENG110108-ENG102268,WAU Info KL15-Klemme 15 PIN,active,
    Elapsed Time: 00:14
    adpmap-03-4S0-907-379-J
    ;Saturday,10,August,2019,09:38:06:30091
    IDE00820-ENG100715-Activating and deactivating all development messages-ECU specific 01/02,not active ,3
    IDE00820-ENG102355-Activating and deactivating all development messages-Internal System Error Number,00 00 ,3
    IDE00820-ENG102411-Activating and deactivating all development messages-Message 100,not active ,3
    IDE00820-ENG101646-Activating and deactivating all development messages-Message 101,not active ,3
    IDE00820-ENG103687-Activating and deactivating all development messages-Message 102,not active ,3
    IDE02630-ESP coasting operation,not activated ,1
    IDE04159-Deactivation of start-stop function,On ,1
    ENG98365-Acoustic warning,activated ,1
    ENG105251-AVH_HHC thresholds,normal ,1
    ENG105345-Brake assistant,activated ,1
    ENG98470-Brake disc wiper,normal ,1
    ENG111872-Can Stop Tx Delay Time,200 ms,1
    ENG106318-ESP_ASR,activated ,1
    ENG111858-GPS Rx PDU,Motor 02 PDU ,1
    ENG108268-Prefill,activated ,1
    ENG111874-Reset RKA Maximal System Runtime,Unknown (0),1
    ENG111873-SLC Activation,OFF ,1
    ENG109396-Text Warning,activated ,1
    ENG109900-VIN Monitoring,activated ,1
    ENG110141-ENG101644-WSS Direction Change-Wheel FL,Original ,1
    ENG110141-ENG102524-WSS Direction Change-Wheel FR,Original ,1
    ENG110141-ENG99883-WSS Direction Change-Wheel RL,Original ,1
    ENG110141-ENG99053-WSS Direction Change-wheel rr,Original ,1
    ENG111871-XCP Activation,not activated ,1
    Elapsed Time: 00:08
    drpeter
  4. Likes Uwe liked this post
  5. #3
    16.4905° S, 151.7375° W
    More maps
    Address - [17]
    blockmap-17-4S0-920-890-C
    ;SW:4S0-920-890-C   HW:4S0-920-890-C ---  Instruments
    ;Component:FBenUSA       H19 0308, Coding:086F30C1BA82CF050220ECC41800801000000000
    ;EV_DashBoardBOSCHAU724,001031,EV_DashBoardBOSCHAU724.rod
    ;Saturday,10,August,2019,09:21:27:01617
    ;VCID: 362FA59E89412CFF73-8062
    IDE00019,Voltage terminal 30,12.30, V
    IDE00025,Coolant temperature,22.50, °C
    IDE00075,Vehicle speed,0, km/h
    IDE00191,Charge air pressure: actual value,0.00, %
    IDE00196,Engine oil temperature,23, °C
    IDE00301,Distance,65, km
    IDE00310,Outside air temperature,24.50, °C
    IDE00316-IDE00500,Time-Hour,9, H
    IDE00316-IDE00501,Time-Minute,22, min
    IDE00316-MAS00111,Time-Seconds,46, s
    IDE00317-IDE00502,Date-Year,2019, yr
    IDE00317-IDE00503,Date-Month,8, mon
    IDE00317-IDE00504,Date-Day,10, d
    IDE00510,ESI: distance driven from inspection,0, km
    IDE00511,ESI: time from inspection,47, d
    IDE00512,ESI: minimum value km-driving distance/inspection,14500, km
    IDE00513,ESI: maximum value km-driving distance/inspection,14500, km
    IDE00514,ESI: maximum value of time between inspections,730, d
    IDE00515,ESI: oil quality,poor oil quality,
    IDE00517,ESI: soot entry,0, km
    IDE00518,ESI: thermal load,0, km
    IDE00520,Phototransistor,165,
    IDE00695,ESI: service exceedance in km,Not available,
    IDE00696,ESI: service exceedance in days,Not available,
    IDE00697,ESI: remaining distance,16000, km
    IDE00698,ESI: remaining running time,318, d
    IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
    IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
    IDE00819,Day counter,138, d
    IDE00827,ESI: minimum value of time between inspections,365, d
    IDE00845-MAS03213,Wheel circ.-Average wheel circumference for trip distance,2100, mm
    IDE00845-MAS03214,Wheel circ.-Maximum wheel circumference for speed,2143, mm
    IDE00935,ESI: Theoretical service interval,15000, km
    IDE01076,Time since ignition off,2096, s
    IDE01153,SIA: maximum value of distance to service,16000, km
    IDE01154,SIA: maximum value of time to service,365, d
    IDE01285,Counter of component protection malfunctions,0,
    IDE01985-ENG101043,FAZIT identification test sum-Checksum,A4 35 11 C2,
    IDE01985-ENG99027,FAZIT identification test sum-Version,81,
    IDE02642,Outside temp.: displayed value,24.50, °C
    IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,FC,
    IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,00,
    IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,64,
    IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,208,
    IDE03349,FIX: Max. distance until next mileage-related inspection,32032, km
    IDE03350,FIX: Maximum time until next time-dependent inspection,730, d
    IDE03351,FIX: Distance covered since last mileage-dependent inspection,0, km
    IDE03352,FIX: Time since last time-dependent inspection,47, d
    IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
    IDE03471-IDE03640,Vehicle configuration-Dynamic AFS light,Correct coding,
    IDE03471-IDE03726,Vehicle configuration-Parallel Parking Assistance,Correct coding,
    IDE03471-IDE04525,Vehicle configuration-Wheel Dampening Electronics,Correct coding,
    IDE03471-IDE04939,Vehicle configuration-Tire pressure monitoring display,Correct coding,
    IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
    IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring,Correct coding,
    IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
    IDE03471-MAS00809,Vehicle configuration-Electro-Mechanical Parking Brake Control Module,Correct coding,
    IDE03471-MAS00811,Vehicle configuration-Active steering control module,Correct coding,
    IDE03471-MAS00911,Vehicle configuration-All Wheel Drive (AWD),Correct coding,
    IDE03471-MAS01091,Vehicle configuration-Automated manual transmission,Correct coding,
    IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
    IDE03471-MAS01891,Vehicle configuration-Lane assistant,Correct coding,
    IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
    IDE03471-MAS02570,Vehicle configuration-Lock Electronics,Correct coding,
    IDE03471-MAS03385,Vehicle configuration-Lane change assistance,Correct coding,
    IDE03471-MAS04384,Vehicle configuration-Electrical steering column lock control module,Correct coding,
    IDE03471-MAS05723,Vehicle configuration-Adaptive cruise control or reducing stopping distance,Correct coding,
    IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
    IDE03471-MAS08201,Vehicle configuration-Trailer positioning assistant,Correct coding,
    IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
    IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
    IDE03471-ENG126401,Vehicle configuration-intelligent_park_assist,Correct coding,
    IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,0.00, l
    IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,32.30, l
    IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,32.30, l
    IDE03472-MAS03809,Volume after refueling-Last reference quantity,0.00, l
    IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,0.00, l
    IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,0.00, l
    IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,0.00, l
    IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,0.00, l
    IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,0.00, l
    IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,0.00, l
    IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,0.00, l
    IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,0.00, l
    IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,0.00, l
    IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,0.00, l
    IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,0.00, l
    IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,0.00, l
    IDE03472-MAS03822,Volume after refueling-Last error status,00,
    IDE03472-MAS03823,Volume after refueling-Penultimate error status,00,
    IDE03472-MAS03824,Volume after refueling-Third-last error status,00,
    IDE03472-MAS03825,Volume after refueling-Fourth-last error status,00,
    IDE03472-MAS06153,Volume after refueling-Last distance,0, km
    IDE03472-MAS06154,Volume after refueling-Penultimate distance,0, km
    IDE03472-MAS06155,Volume after refueling-Third to last distance,0, km
    IDE03472-MAS06156,Volume after refueling-Fourth to last distance,0, km
    IDE03473-IDE00730,Fuel tank sens-Fuel level sensor 1 including soiling resistance,461, Ohm
    IDE03473-IDE00731,Fuel tank sens-Fuel level sensor 2 including soiling resistance,976, Ohm
    IDE03473-IDE00732,Fuel tank sens-Fuel level sensor 1 soiling resistance,not_available,
    IDE03473-IDE00733,Fuel tank sens-Fuel level sensor 2 soiling resistance,not_available,
    IDE03473-IDE03494,Fuel tank sens-Fuel level sensor 3 including soiling resistance,961, Ohm
    IDE03473-IDE03495,Fuel tank sens-Fuel level sensor 3 soiling resistance,not_available,
    IDE03473-IDE03496,Fuel tank sens-Fuel level sensor 4 including soiling resistance,992, Ohm
    IDE03473-IDE03497,Fuel tank sens-Fuel level sensor 4 soiling resistance,not_available,
    IDE03473-MAS03798,Fuel tank sens-Raw value sensor 1 resistor 1,538,
    IDE03473-MAS03799,Fuel tank sens-Raw value sensor 1 resistor 2,not_available,
    IDE03473-MAS03800,Fuel tank sens-Raw value sensor 2 resistor 1,780,
    IDE03473-MAS03801,Fuel tank sens-Raw value sensor 2 resistor 2,not_available,
    IDE03473-MAS03802,Fuel tank sens-Raw value sensor 3 resistor 1,775,
    IDE03473-MAS03803,Fuel tank sens-Raw value sensor 3 resistor 2,not_available,
    IDE03473-MAS03804,Fuel tank sens-Raw value sensor 4 resistor 1,785,
    IDE03473-MAS03805,Fuel tank sens-Raw value sensor 4 resistor 2,not_available,
    IDE03474-IDE00304,Calculated volume-Fuel level,6.80, l
    IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,462, Ohm
    IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,977, Ohm
    IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,972, Ohm
    IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,980, Ohm
    IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,9.10, l
    IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,0.00, l
    IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.00, l
    IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.00, l
    IDE03474-IDE00802,Calculated volume-Full volume,83.00, l
    IDE03474-MAS03826,Calculated volume-Quality sensor 1,10,
    IDE03474-MAS03827,Calculated volume-Quality sensor 2,10,
    IDE03474-MAS03828,Calculated volume-Quality sensor 3,10,
    IDE03474-MAS03829,Calculated volume-Quality sensor 4,10,
    IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,9.10, l
    IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,-0.20, l
    IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,-0.50, l
    IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,-0.40, l
    IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.00,
    IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.00,
    IDE03474-ENG102894,Calculated volume-averaged_volume,9.20, l
    IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,9.20, l
    IDE03474-ENG101619,Calculated volume-calibrated_volume_total,9.10, l
    IDE03474-ENG126318,Calculated volume-gas_based_linking,1.00,
    IDE03474-ENG99553,Calculated volume-linking,0.0000000,
    IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.00, m/s
    IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,0.00, m/s
    IDE03474-ENG101623,Calculated volume-reference_volume,9.20, l
    IDE03474-ENG102479,Calculated volume-speed_based_linking,0.00,
    IDE03474-ENG99683,Calculated volume-version_of_application,3,
    IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0000000,
    IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
    IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
    IDE03475-MAS12387,Control button in instrument cluster-Button for daily distance driven,not active,
    IDE03477-IDE00500,GPS time-Hour,9, H
    IDE03477-IDE00501,GPS time-Minute,23, min
    IDE03477-IDE00501,GPS time-Minute,18, min
    IDE03477-IDE00502,GPS time-Year,2019, yr
    IDE03477-IDE00503,GPS time-Month,8, mon
    IDE03477-IDE00504,GPS time-Day,10, d
    IDE03477-MAS00111,GPS time-Seconds,8, s
    IDE03477-MAS00111,GPS time-Seconds,39, s
    IDE03477-MAS03493,GPS time-last synchronization year,2019, yr
    IDE03506,Distance: high resolution,00 00 FE 1B,
    IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,17,
    IDE03880-MAS03425,MOST address-Physical address,04 01,
    IDE03911-MAS01390,Service -interval- display: history 1-Block 1,4F F0 00 5B,
    IDE03911-MAS01391,Service -interval- display: history 1-Block 2,0F F0 00 3B,
    IDE03911-MAS01392,Service -interval- display: history 1-Block 3,8F F0 00 3B,
    IDE03911-MAS01393,Service -interval- display: history 1-Block 4,CF F0 00 5B,
    IDE03911-MAS01394,Service -interval- display: history 1-Block 5,FF FF FF FF,
    IDE03911-MAS01395,Service -interval- display: history 1-Block 6,FF FF FF FF,
    IDE03911-MAS01396,Service -interval- display: history 1-Block 7,FF FF FF FF,
    IDE03911-MAS01397,Service -interval- display: history 1-Block 8,FF FF FF FF,
    IDE03911-MAS01398,Service -interval- display: history 1-Block 9,FF FF FF FF,
    IDE03911-MAS01399,Service -interval- display: history 1-Block 10,FF FF FF FF,
    IDE03911-MAS01400,Service -interval- display: history 1-Block 11,FF FF FF FF,
    IDE03911-MAS01401,Service -interval- display: history 1-Block 12,FF FF FF FF,
    IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
    IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
    IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
    IDE03911-MAS01405,Service -interval- display: history 1-Block 16,FF FF FF FF,
    IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
    IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
    IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
    IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
    IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
    IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
    IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
    IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
    IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
    IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
    IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
    IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
    IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
    IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
    IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
    IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
    IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
    IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
    IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
    IDE03913-MAS01393,Service -interval- display: history 3-Block 4,FF FF FF FF,
    IDE03913-MAS01394,Service -interval- display: history 3-Block 5,FF FF FF FF,
    IDE03913-MAS01395,Service -interval- display: history 3-Block 6,FF FF FF FF,
    IDE03913-MAS01396,Service -interval- display: history 3-Block 7,FF FF FF FF,
    IDE03913-MAS01397,Service -interval- display: history 3-Block 8,FF FF FF FF,
    IDE03913-MAS01398,Service -interval- display: history 3-Block 9,FF FF FF FF,
    IDE03913-MAS01399,Service -interval- display: history 3-Block 10,FF FF FF FF,
    IDE03913-MAS01400,Service -interval- display: history 3-Block 11,FF FF FF FF,
    IDE03913-MAS01401,Service -interval- display: history 3-Block 12,FF FF FF FF,
    IDE03913-MAS01402,Service -interval- display: history 3-Block 13,FF FF FF FF,
    IDE03913-MAS01403,Service -interval- display: history 3-Block 14,FF FF FF FF,
    IDE03913-MAS01404,Service -interval- display: history 3-Block 15,FF FF FF FF,
    IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
    IDE03914-MAS01390,Service -interval- display: history 4-Block 1,FF FF FF FF,
    IDE03914-MAS01391,Service -interval- display: history 4-Block 2,FF FF FF FF,
    IDE03914-MAS01392,Service -interval- display: history 4-Block 3,FF FF FF FF,
    IDE03914-MAS01393,Service -interval- display: history 4-Block 4,FF FF FF FF,
    IDE03914-MAS01394,Service -interval- display: history 4-Block 5,FF FF FF FF,
    IDE03914-MAS01395,Service -interval- display: history 4-Block 6,FF FF FF FF,
    IDE03914-MAS01396,Service -interval- display: history 4-Block 7,FF FF FF FF,
    IDE03914-MAS01397,Service -interval- display: history 4-Block 8,FF FF FF FF,
    IDE03914-MAS01398,Service -interval- display: history 4-Block 9,FF FF FF FF,
    IDE03914-MAS01399,Service -interval- display: history 4-Block 10,FF FF FF FF,
    IDE03914-MAS01400,Service -interval- display: history 4-Block 11,FF FF FF FF,
    IDE03914-MAS01401,Service -interval- display: history 4-Block 12,FF FF FF FF,
    IDE03914-MAS01402,Service -interval- display: history 4-Block 13,FF FF FF FF,
    IDE03914-MAS01403,Service -interval- display: history 4-Block 14,FF FF FF FF,
    IDE03914-MAS01404,Service -interval- display: history 4-Block 15,FF FF FF FF,
    IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
    IDE04649-MAS06857,Activation for housing fan-Speed,0, /min
    IDE04649-ENG128738,Activation for housing fan-PWM_FAN,0, %
    IDE04649-ENG128737,Activation for housing fan-source_max_PWM_requested,none,
    IDE04649-ENG98933,Activation for housing fan-Status,OFF,
    IDE04649-ENG128733,Activation for housing fan-temperature_Boost,38, °C
    IDE04649-ENG128734,Activation for housing fan-temperature_chipled,65, °C
    IDE04649-ENG128736,Activation for housing fan-temperature_GPU,42, °C
    IDE04649-ENG128735,Activation for housing fan-temperature_KI,38, °C
    IDE06425-IDE06026,Roller test bench mode: functional-Adaptation of brake pedal path sensor,not activated,
    IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
    IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
    IDE06924,Performance display,0,
    IDE07145-MAS06772,Component protection properties-Component protection generation,02,
    IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,02,
    IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
    IDE07145-MAS06775,Component protection properties-KS Standard software correct number,01,
    IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Slave,
    IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,used,
    IDE07145-MAS06782,Component protection properties-Master ECU Key,administered by component protection,
    IDE07145-MAS06785,Component protection properties-GFA key,used,
    IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
    IDE07145-MAS06787,Component protection properties-Indiv Key Generation,used,
    IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
    IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
    IDE07145-MAS07187,Component protection properties-KS Data version,01,
    IDE07159-MAS01155,Control module switch-off: counter-Control module,0, min
    IDE07159-MAS05583,Control module switch-off: counter-Data bus,0, min
    IDE07578-MAS00138,Operating range consumption with electric drive-1,0.00,
    IDE07578-MAS00139,Operating range consumption with electric drive-2,65534,
    IDE07578-ENG04221,Operating range consumption with electric drive-ERW_Energieinhalt,0.00,
    IDE07578-ENG114651,Operating range consumption with electric drive-s_erw_rw_batterie,65534, km
    IDE07578-ENG114652,Operating range consumption with electric drive-s_erw_rw_batterie_anz,65534, km
    IDE07578-ENG114648,Operating range consumption with electric drive-s_erw_rwds,0.00, A
    IDE07578-ENG114640,Operating range consumption with electric drive-s_erw_rwds_high,10.00, A
    IDE07578-ENG114644,Operating range consumption with electric drive-s_erw_rwds_low,10.00, A
    IDE07578-ENG114637,Operating range consumption with electric drive-s_erw_rwdv_antrieb_high_unclass,2.50, kWh/100 km
    IDE07578-ENG114641,Operating range consumption with electric drive-s_erw_rwdv_antrieb_low_unclass,25.00,
    IDE07578-ENG114645,Operating range consumption with electric drive-s_erw_rwdv_antrieb_unclass,0.00,
    IDE07578-ENG114638,Operating range consumption with electric drive-s_erw_rwdv_dcdc_high_unclass,0.20, kWh/100 km
    IDE07578-ENG114642,Operating range consumption with electric drive-s_erw_rwdv_dcdc_low_unclass,0.20,
    IDE07578-ENG114646,Operating range consumption with electric drive-s_erw_rwdv_dcdc_unclass,0.00,
    IDE07578-ENG114639,Operating range consumption with electric drive-s_erw_rwdv_tme_high_unclass,0.50,
    IDE07578-ENG114643,Operating range consumption with electric drive-s_erw_rwdv_tme_low_unclass,0.50,
    IDE07578-ENG114647,Operating range consumption with electric drive-s_erw_rwdv_tme_unclass,0.00,
    IDE07578-ENG114649,Operating range consumption with electric drive-s_erw_rwdv_unclass,0.00,
    IDE07646-ENG114675,Consumption for road-specif. range with electric drive-s_erw_endsteigung,0.00, %
    IDE07646-ENG114667,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_0,0.00, kWh/100 km
    IDE07646-ENG114668,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_1,0.00, kWh/100 km
    IDE07646-ENG114669,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_2,0.00, kWh/100 km
    IDE07646-ENG114670,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_3,0.00, kWh/100 km
    IDE07646-ENG114671,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_4,0.00, kWh/100 km
    IDE07646-ENG114672,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_5,0.00, kWh/100 km
    IDE07646-ENG114673,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_6,0.00, kWh/100 km
    IDE07646-ENG114653,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_0,25.00, kWh/100 km
    IDE07646-ENG114654,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_1,25.00, kWh/100 km
    IDE07646-ENG114655,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_2,25.00, kWh/100 km
    IDE07646-ENG114656,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_3,25.00, kWh/100 km
    IDE07646-ENG114657,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_4,25.00, kWh/100 km
    IDE07646-ENG114658,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_5,25.00, kWh/100 km
    IDE07646-ENG114659,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_6,25.00, kWh/100 km
    IDE07646-ENG04222,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_low_class,25.00, kWh/100 km
    IDE07646-ENG114674,Consumption for road-specif. range with electric drive-s_erw_str_klasse,0,
    IDE08343,Immobilizer Challenge,3B DF CF EF,
    IDE08701-MAS07266,ESI: Status-Oil change: unit of dist. travelled,miles,
    IDE08701-MAS07267,ESI: Status-Oil change: dist. travelled,10000,
    IDE08701-MAS07268,ESI: Status-Oil change: stat. of dist. travelled,Service in,
    IDE08701-MAS07269,ESI: Status-Oil change: stat. of time,Service in,
    IDE08701-MAS07270,ESI: Status-Inspection: stat. of dist. travelled,Service in,
    IDE08701-MAS07271,ESI: Status-Inspection: unit of dist. travelled,miles,
    IDE08701-MAS07272,ESI: Status-Inspection: dist. travelled,20000,
    IDE08701-MAS07273,ESI: Status-Inspection: time,683,
    IDE08701-MAS07274,ESI: Status-Oil change warning,no warning,
    IDE08701-MAS07277,ESI: Status-Inspections warning,no warning,
    IDE08701-MAS07305,ESI: Status-Oil change: time,318,
    IDE08701-MAS07308,ESI: Status-Inspection: status time,Service in,
    IDE08701-MAS10768,ESI: Status-Daily mileage,100,
    MAS03121,Ring break diagnostic line status,Supply voltage,
    ENG126262-ENG114675,Consumption_for_distance_on_map-s_erw_endsteigung,0.00, %
    ENG126262-ENG114674,Consumption_for_distance_on_map-s_erw_str_klasse,0,
    ENG126262-ENG128739,Consumption_for_distance_on_map-s_vkmrw_rwdv_antrieb_low_class,16.90, l/100km
    ENG126262-ENG126309,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_0,14.80, l/100km
    ENG126262-ENG126310,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_1,14.30, l/100km
    ENG126262-ENG126311,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_2,14.30, l/100km
    ENG126262-ENG126312,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_3,14.30, l/100km
    ENG126262-ENG126313,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_4,14.30, l/100km
    ENG126262-ENG126314,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_5,14.30, l/100km
    ENG126262-ENG126315,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_6,14.30, l/100km
    ENG126262-ENG126302,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_0,11.10, l/100km
    ENG126262-ENG126303,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_1,10.00, l/100km
    ENG126262-ENG126304,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_2,10.00, l/100km
    ENG126262-ENG126305,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_3,10.00, l/100km
    ENG126262-ENG126306,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_4,10.00, l/100km
    ENG126262-ENG126307,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_5,10.00, l/100km
    ENG126262-ENG126308,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_6,10.00, l/100km
    ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,226, %
    ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,100, %
    ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,100, %
    ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,100, %
    ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,100, %
    ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
    ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
    ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
    ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
    ENG106303-ENG99971,ESI_active_warning-in_calculation,not active,
    ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
    ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
    ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
    ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
    ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
    ENG119883,ESI_mileage_per_day,100, km
    ENG107920-ENG98868,onboard_computer-Range,24, km
    ENG107920-ENG119788,onboard_computer-range_average_consumption,15.50, l/100km
    ENG107920-ENG126296,onboard_computer-range_average_consumption_cng,0.00, kg/100 km
    ENG107920-ENG126292,onboard_computer-range_average_consumption_cng_high,0.00, kg/100 km
    ENG107920-ENG126294,onboard_computer-range_average_consumption_cng_low,0.00, kg/100 km
    ENG107920-ENG119789,onboard_computer-range_average_consumption_high,12.20, l/100km
    ENG107920-ENG119790,onboard_computer-range_average_consumption_low,17.30, l/100km
    ENG107920-ENG126297,onboard_computer-range_average_consumption_lpg,0.00, kg/100 km
    ENG107920-ENG126293,onboard_computer-range_average_consumption_lpg_high,0.00, kg/100 km
    ENG107920-ENG126295,onboard_computer-range_average_consumption_lpg_low,0.00, kg/100 km
    ENG107920-ENG126298,onboard_computer-range_cng,65534, km
    ENG107920-ENG126300,onboard_computer-range_cng_display_value,65534, km
    ENG107920-ENG119791,onboard_computer-range_display_value,24, km
    ENG107920-ENG126299,onboard_computer-range_lpg,65534, km
    ENG107920-ENG126301,onboard_computer-range_lpg_display_value,65534, km
    ENG107953-ENG100938,outside_temp_algorithm_group-coolant_temperature_outdated_bit,not active,
    ENG107953-ENG101136,outside_temp_algorithm_group-distance_threshold_not_yet_reached,active,
    ENG107953-ENG99778,outside_temp_algorithm_group-downward_tendency,not active,
    ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,not active,
    ENG107953-ENG102352,outside_temp_algorithm_group-ice_warning_symbol,not active,
    ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,active,
    ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,149,
    ENG107953-ENG99258,outside_temp_algorithm_group-outside_temperature_filtered_error_state_bit,not active,
    ENG107953-ENG102589,outside_temp_algorithm_group-outside_temperature_old,not active,
    ENG107953-ENG102387,outside_temp_algorithm_group-outside_temperature_raw_score_error_state_bit,not active,
    ENG109340-ENG104056,tank_validation-s_vali_abs_active,not active,
    ENG109340-ENG102652,tank_validation-s_vali_abs_display_0,not active,
    ENG109340-ENG102994,tank_validation-s_vali_abs_distance/mileage,not active,
    ENG109340-ENG101149,tank_validation-s_vali_abs_rough,not active,
    ENG109340-ENG101740,tank_validation-s_vali_active,not active,
    ENG109340-ENG101355,tank_validation-s_vali_consumption_deq,3276.80, l
    ENG109340-ENG100596,tank_validation-s_vali_consumption_deq_abs,3276.80, l
    ENG109340-ENG102770,tank_validation-s_vali_display_0,not active,
    ENG109340-ENG99133,tank_validation-s_vali_needle_vol_ref,not active,
    ENG109340-ENG99562,tank_validation-s_vali_rough,not active,
    ENG109340-ENG100160,tank_validation-s_vali_status,0, l
    ENG109340-ENG103691,tank_validation-s_vali_vol_delta_gef,3276.80, l
    ENG109340-ENG100615,tank_validation-s_vali_vol_delta_roh,3276.80, l
    ENG109340-ENG99506,tank_validation-s_vali_vol_g1_vg,3276.80, l
    ENG109340-ENG103928,tank_validation-s_vali_vol_g2_vg,3276.80, l
    ENG109340-ENG101476,tank_validation-s_vali_vol_g3_vg,3276.80, l
    ENG109340-ENG101237,tank_validation-s_vali_vol_g4_vg,3276.80, l
    ENG109340-ENG101103,tank_validation-s_vali_vol_ref_gew,3276.80, l
    ENG109340-ENG100543,tank_validation-s_vali_vol_ref_vg,3276.80, l
    ENG109340-ENG100079,tank_validation-s_vali_vol_total_vg,3276.80, l
    Elapsed Time: 00:33
    adpmap-17-4S0-920-890-C
    ;Saturday,10,August,2019,09:22:00:01617
    ;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
    IDE00001-Production mode,not active ,3
    IDE00301-Distance,65 km,3
    IDE00342-ESI: Resetting ESI,no warning ,1
    IDE00343-Language version,US English ,1
    IDE00499-Display correction of consumptions and operating range,100 %,1
    IDE00500-Hour,9 H,1
    IDE00501-Minute,23 min,1
    IDE00502-Year,2019 yr,2
    IDE00503-Month,8 mon,1
    IDE00504-Day,10 d,1
    IDE00510-ESI: distance driven from inspection,0 km,3
    IDE00511-ESI: time from inspection,47 d,2
    IDE00512-ESI: minimum value km-driving distance/inspection,14500 km,2
    IDE00513-ESI: maximum value km-driving distance/inspection,14500 km,2
    IDE00514-ESI: maximum value of time between inspections,730 d,2
    IDE00515-ESI: oil quality,poor oil quality ,1
    IDE00517-ESI: soot entry,0 km,2
    IDE00518-ESI: thermal load,0 km,2
    IDE00819-Day counter,138 d,2
    IDE00827-ESI: minimum value of time between inspections,365 d,2
    IDE01153-SIA: maximum value of distance to service,16000 km,2
    IDE01154-SIA: maximum value of time to service,365 d,2
    IDE02489-Display depiction,Version 2 ,1
    IDE02494-Automatic door locking,No display ,1
    IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.80 l,5
    IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.80 l,5
    IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,-12.80 l,5
    IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,-12.80 l,5
    IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,-12.80 l,5
    IDE03329-Driving profiled for range remaining,12.20 l/100km,2
    IDE03346-IDE00301-Units adjusted-Distance,miles ,3
    IDE03346-MAS01230-Units adjusted-Date,mm_dd_yy ,3
    IDE03346-MAS01456-Units adjusted-Speed,Miles per hour ,3
    IDE03346-MAS02201-Units adjusted-Temperature,°F ,3
    IDE03346-MAS02957-Units adjusted-Time,12h AM_PM ,3
    IDE03346-MAS03032-Units adjusted-Volume,gallons (US) ,3
    IDE03346-MAS03034-Units adjusted-Pressure,psi ,3
    IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3
    IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,3
    IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3
    IDE03348-MAS01456-Speed warning-Speed,0 ,2
    IDE03348-MAS01561-Speed warning-Unit,Miles per hour ,2
    IDE03348-Speed warning-,not active ,2
    IDE03349-FIX: Max. distance until next mileage-related inspection,32032 km,3
    IDE03350-FIX: Maximum time until next time-dependent inspection,730 d,2
    IDE03351-FIX: Distance covered since last mileage-dependent inspection,0 km,3
    IDE03352-FIX: Time since last time-dependent inspection,47 d,2
    IDE03372-Source for synchronization of time,GPS ,1
    IDE03867-Deactivate seat belt warning,No ,1
    IDE05930-Service notification in days,30 d,1
    IDE06588-Ignition active message: actuator,Driver door ,1
    IDE06922-No-voltage display,No display ,1
    IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
    IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
    IDE07221-Cylinder shut-off,No display ,1
    IDE07579-MAS05872-Driving profile for operating range consump.with electric drive-Operating range average voltage,10.00 A,8
    IDE07579-MAS05875-Driving profile for operating range consump.with electric drive-Average consumption: electric drive,25 ,8
    IDE07579-MAS05876-Driving profile for operating range consump.with electric drive-Average consumption: low voltage auxiliary consumer,0.20 ,8
    IDE07579-MAS05877-Driving profile for operating range consump.with electric drive-Average consumption: high voltage auxiliary consumer,0.50 ,8
    IDE07600-ENG114653-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_0,25.00 ,14
    IDE07600-ENG114654-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_1,25.00 ,14
    IDE07600-ENG114655-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_2,25.00 ,14
    IDE07600-ENG114656-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_3,25.00 ,14
    IDE07600-ENG114657-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_4,25.00 ,14
    IDE07600-ENG114658-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_5,25.00 ,14
    IDE07600-ENG114659-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_6,25.00 ,14
    IDE10693-Initialize sensor for fuel level,No ,1
    IDE10694-ENG126302-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_0,11.10 l/100km,14
    IDE10694-ENG126303-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_1,10.00 l/100km,14
    IDE10694-ENG126304-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_2,10.00 l/100km,14
    IDE10694-ENG126305-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_3,10.00 l/100km,14
    IDE10694-ENG126306-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_4,10.00 l/100km,14
    IDE10694-ENG126307-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_5,10.00 l/100km,14
    IDE10694-ENG126308-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_6,10.00 l/100km,14
    IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel,Display ,4
    IDE11472-MAS05424-Configuration of displayable contents-Natural gas quality,No display ,4
    IDE11472-MAS12789-Configuration of displayable contents-Display: engine running required,No display ,4
    IDE11472-MAS18773-Configuration of displayable contents-Acceleration measurement,No display ,4
    IDE11472-MAS18774-Configuration of displayable contents-Drag indicator,No display ,4
    IDE11472-MAS19086-Configuration of displayable contents-Charge symbol color,Standard ,4
    IDE12050-Acoustic: drive position R,active ,1
    IDE13607-MAS16698-Lock display contents-Lock infotainment list,No ,9
    IDE13607-MAS16699-Lock display contents-Lock function lists,No ,9
    IDE13607-MAS16700-Lock display contents-Lock MFA displays,No ,9
    IDE13607-MAS16701-Lock display contents-Dynamic image lock,No ,9
    IDE13607-MAS16702-Lock display contents-Lock functional animation,No ,9
    IDE13607-MAS16703-Lock display contents-lock,No ,9
    IDE13607-MAS16704-Lock display contents-Lock system status animation,No ,9
    IDE13607-MAS16705-Lock display contents-Lock operating support animation,No ,9
    IDE13607-MAS16706-Lock display contents-List time out,0 s,9
    IDE13607-MAS17250-Lock display contents-Map locked,No ,9
    IDE13607-MAS17251-Lock display contents-Piloted driving locked,No ,9
    IDE13607-MAS17283-Lock display contents-Vehicle model locked,No ,9
    IDE13607-MAS17284-Lock display contents-Cover intensity locked,100 %,9
    IDE13607-MAS17285-Lock display contents-Number of list entries blocked,0 ,9
    MAS03555-Lap counter,No display ,1
    MAS03685-Digital speedometer,Display ,1
    ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,21
    ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,21
    ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,21
    ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,21
    ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,21
    ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,21
    ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,21
    ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,21
    ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,21
    ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,21
    ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,21
    ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,21
    ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,21
    ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,21
    ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,21
    ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,21
    ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,21
    ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,21
    ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,21
    ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,21
    ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,21
    ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,21
    ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,21
    ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,21
    ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,21
    ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,21
    ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,21
    ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,21
    ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,21
    ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,21
    ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,21
    ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,21
    ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,21
    ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,21
    ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40,OFF ,21
    ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,21
    ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,21
    ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,21
    ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,21
    ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,50ms ,21
    ENG128731-MAS01129-designvariant_activation-Version 1,active ,2
    ENG128731-MAS01130-designvariant_activation-Version 2,not active ,2
    ENG128731-MAS01131-designvariant_activation-Version 3,not active ,2
    ENG128731-MAS03101-designvariant_activation-Version 4,not active ,2
    ENG128731-MAS03102-designvariant_activation-Version 5,not active ,2
    ENG128731-MAS03103-designvariant_activation-Version 6,not active ,2
    ENG128731-MAS03104-designvariant_activation-Version 7,not active ,2
    ENG128731-MAS03105-designvariant_activation-Version 8,not active ,2
    ENG99320-Developers_menu,not active ,1
    ENG119879-ENG101574-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1,00 ,12
    ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,0A ,12
    ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,32 ,12
    ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,64 ,12
    ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,DC ,12
    ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6,FD ,12
    ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,02 ,12
    ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,02 ,12
    ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,06 ,12
    ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,0A ,12
    ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,50 ,12
    ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6,64 ,12
    ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A ,12
    ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,32 ,12
    ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,64 ,12
    ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,96 ,12
    ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,02 ,12
    ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,02 ,12
    ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,0E ,12
    ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,1E ,12
    ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,32 ,12
    ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
    ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
    ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
    ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
    ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,0E ,12
    ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1E ,12
    ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,32 ,12
    ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,14 ,12
    ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,1E ,12
    ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,32 ,12
    ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,46 ,12
    ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,64 ,12
    ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,00 ,12
    ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,14 ,12
    ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,1E ,12
    ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,32 ,12
    ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,46 ,12
    ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
    ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
    ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,DC ,12
    ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,02 ,12
    ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,02 ,12
    ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,06 ,12
    ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,0A ,12
    ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,50 ,12
    ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 96 ,20
    ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 32 ,20
    ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 64 ,20
    ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
    ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,12
    ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
    ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC ,12
    ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,02 ,12
    ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,02 ,12
    ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,06 ,12
    ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0A ,12
    ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,50 ,12
    ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xs_bus ,1
    ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,lds ,1
    ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16
    ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16
    ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16
    ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.00 km,16
    ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.00 °C,16
    ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.00 ,16
    ENG126283-parameter_hmi,41 43 56 03 05 FF 1E 03 00 01 00 FA 02 00 FF 00 00 FF FF 00 00 F3 00 00 FF 00 24 00 FF 43 14 28 00 00 5A 00 E1 00 19 FF B4 00 1E 8C AA 64 AA 00 BF 4B 68 A2 91 6D 6D 97 A2 73 9B 75 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,100
    ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25 ,18
    ENG109442-ENG103975-time_parameter_display-tDD15_on,0.50 ,18
    ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
    Elapsed Time: 00:32
    Address - [19]
    blockmap-19-4S0-907-468-C
    ;SW:4S0-907-468-C   HW:4S0-907-468-A ---  CAN Gateway
    ;Component:J533--Gateway H15 0081, Coding:802103161C
    ;EV_GatewPkoUDS,002014,EV_GatewPkoUDS_002_AU57.rod
    ;Saturday,10,August,2019,09:22:36:01617
    ;VCID: 3C3BB7B6B76DF6AF85-8068
    Group,Description,Actual
    IDE00018,Voltage terminal 15,12.2, V
    IDE00019,Voltage terminal 30,12.2, V
    IDE00030,Status of actuator test,not active,
    IDE00056,History data 1,2019-07-19-17:27*01.5*01*00162***
    2019-07-19-15:26*00.8*01**
    2019-07-03-16:35*22.6*01**
    2019-07-02-17:51*05.2*01**
    2019-07-02-12:30*01.3*01**
    2019-07-02-11:08*16.2*01**
    2019-07-01-18:48*01.0*01**
    2019-07-19-14:25*00.3*01*00371***
    2019-07-19-14:04*10.3*01**
    2019-07-19-03:40*11.6*01**
    2019-07-18-15:58*02.1*01**
    2019-07-18-13:38*01.0*01**
    2019-07-18-12:33*01.9*01**
    2019-07-18-09:44*14.4*01**
    2019-07-19-14:25*00.0*01*00000***
    2019-07-18-15:58*00.0*01**
    2000-01-01-00:00*00.0*00**
    2000-01-01-00:00*00.0*00**,
    IDE00057,History data 2,2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00*00000**
    2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00**
    2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00**,
    IDE00058,History data 3,2019-07-19-14:02*3*0*012*000*-08.81*0-0-0-0-0-0*0*0*00.0*04.5**
    2019-07-19-14:01*1*0*012*000*-12.28*0-0-0-0-0-0*0*0*00.0*04.5**
    2019-06-24-11:42*4*0*084*079*-10.44*0-0-0-0-0-0*0*0*00.0*00.0**
    2019-06-24-09:12*4*0*086*081*-21.32*0-0-0-0-0-0*0*0*00.0*00.0**
    2019-06-22-12:05*4*0*088*083*-22.01*0-0-0-0-0-0*0*0*00.0*00.0**
    2019-06-21-07:00*4*0*086*082*-13.39*0-0-0-0-0-0*0*0*00.0*00.0**
    2019-06-17-07:56*4*0*087*084*-14.11*0-0-0-0-0-0*0*0*00.0*00.0**
    2019-06-17-07:43*4*0*087*084*-14.06*0-0-0-0-0-0*0*0*00.0*00.0**
    2019-06-17-07:39*4*0*087*084*-09.39*0-0-0-0-0-0*0*0*00.0*00.0**
    2019-06-08-10:15*4*0*084*082*-14.61*0-0-0-0-0-0*0*0*00.0*00.0**
    2019-06-08-09:29*4*0*090*089*-12.64*0-0-0-0-0-0*0*0*00.0*00.0**
    2019-05-22-11:17*4*0*095*094*-14.26*0-0-0-0-0-0*0*0*00.0*00.0**
    2019-05-17-19:59*4*0*096*095*-11.02*0-0-0-0-0-0*0*0*00.0*00.0**
    2019-05-02-23:53*4*0*095*083*-14.72*0-0-0-0-0-0*0*0*00.0*00.0**
    2019-04-29-09:40*4*0*095*085*-12.73*0-0-0-0-0-0*0*0*00.0*00.0**,
    IDE00059,History data 4,2019-03-25-08:46*01*092*JCB*290318I088*10009*00171*0000*0000*0000**
    2000-01-01-00:00*00*---*---*----------*09999*00012*0000*0000*0000**
    2000-01-01-00:00*00*---*---*----------*00000*00000*0000*0000*0000**
    2000-01-01-00:00*00*---*---*----------*00000*00000*0000*0000*0000**,
    IDE00060,History data 5,2019-07-19-14:00*-00.01*-00.10*-08.04*11.50*000*05*-55.5*00155*09925*000065*0-0-0-0-0-0*0*00.0*04.5*576.9*23*00*01**
    2000-01-01-00:00*+00.00*+00.00*+00.00*00.00*000*00*+00.0*00000*00000*000000*0-0-0-0-0-0*0*00.0*00.0*000.0*00*00*00**
    2000-01-01-00:00*+00.00*+00.00*+00.00*00.00*000*00*+00.0*00000*00000*000000*0-0-0-0-0-0*0*00.0*00.0*000.0*00*00*00**,
    IDE00061,History data 6,2019-07-19-14:25*018*+24*+017.0*00.13**
    2019-06-25-14:21*081*+26*+002.7*00.10**
    2019-06-25-14:11*069*+26*+002.0*00.01**
    2019-06-25-12:30*093*+24*+000.2*00.01**
    2019-06-24-18:21*092*+36*+001.3*00.11**
    2019-06-24-18:12*091*+35*+000.3*00.01**
    2019-06-24-17:17*090*+35*+008.8*00.91**
    2019-06-24-11:41*079*+23*+000.1*00.00**
    2019-06-24-09:05*081*+22*+000.6*00.11**
    2019-06-22-11:55*083*+27*+001.3*00.16**
    2019-06-21-07:00*082*+24*+000.1*00.00**
    2019-06-17-07:49*084*+25*+000.9*00.10**
    2019-06-17-07:40*084*+25*+000.4*00.03**
    2019-06-17-07:36*084*+25*+000.6*00.03**
    2019-06-08-10:12*082*+24*+000.6*00.03**
    2019-06-08-09:25*089*+24*+000.5*00.05**
    2019-05-22-11:11*094*+24*+001.0*00.08**
    2019-05-17-16:53*095*+24*+001.8*00.10**
    2019-05-02-23:51*083*+04*+000.1*00.03**
    2019-04-29-09:37*085*+07*+000.4*00.03**,
    IDE00062,History data 7,2019-06-25-14:27*000*-055.9*577.3*04.6*00.0**
    2019-06-25-14:13*084*-000.8*000.1*00.0*00.0**
    2019-06-25-12:32*065*-020.8*001.6*01.0*00.9**
    2019-06-24-18:29*092*-000.6*018.0*00.0*00.0**
    2019-06-24-18:13*089*-001.9*000.1*00.1*00.1**
    2019-06-24-11:42*082*-000.5*005.5*00.0*00.0**
    2019-06-24-09:12*079*-000.3*002.4*00.0*00.0**
    2019-06-22-12:05*080*-000.5*045.0*00.0*00.0**
    2019-06-21-07:00*082*-000.5*028.9*00.0*00.0**
    2019-06-17-07:56*084*-001.4*095.1*00.0*00.0**
    2019-06-17-07:43*084*-000.1*000.1*00.0*00.0**
    2019-06-17-07:39*084*-000.1*000.0*00.0*00.0**
    2019-06-08-10:15*085*-002.4*213.6*00.0*00.0**
    2019-06-08-09:29*083*-000.3*000.7*00.0*00.0**
    2019-05-22-11:17*088*-004.8*406.7*00.0*00.0**
    2019-05-17-19:59*094*-001.5*111.3*00.0*00.0**
    2019-05-02-23:53*094*-004.1*353.7*00.0*00.0**
    2019-04-29-09:40*082*-001.1*086.3*00.0*00.0**
    2019-04-05-02:08*083*-006.6*584.7*00.0*00.0**
    2019-04-05-01:58*084*-000.1*000.0*00.0*00.0**,
    IDE00063,History data 8,2019-08-10-08:36*1*70*00*00*05*02*00*00*2000-01-01-00:00*01**
    2019-08-10-08:23*1*69*00*00*05*02*00*00*2000-01-01-00:00*01**
    2019-08-09-08:43*1*68*00*00*05*02*00*00*2000-01-01-00:00*01**
    2019-08-08-13:40*1*67*00*00*05*02*00*00*2000-01-01-00:00*01**
    2019-08-07-16:13*1*66*00*00*05*02*00*00*2000-01-01-00:00*01**,
    IDE00064,History data 9,2019-03-25-08:46*100*100*099*058*00012*12.80*+21*01*12.70*00000*00000**
    2019-08-01-17:46*100*094*095*090*00165*12.70*+21*01*12.70*00002*00000**
    2019-07-05-11:27*100*094*051*043*00125*12.10*+22*01*12.70*00002*00000**
    2019-06-08-09:59*100*099*089*087*00065*12.60*+24*01*12.70*00001*00000**
    2019-04-29-10:56*100*100*096*083*00054*12.70*+07*01*12.70*00001*00000**
    2017-10-20-00:00*000*000*100*100*00000*09.00*-40*00*00.00*00000*00000**
    2019-03-22-00:10*100*100*097*054*00002*12.80*+19*00*12.70*00000*00000**
    2000-01-01-00:00*000*000*000*000*00000*00.00*+00*00*00.00*00000*00000**
    2000-01-01-00:00*000*000*000*000*00000*00.00*+00*00*00.00*00000*00000**,
    IDE00065,History data 10,2000-01-01-00:00*0*000.0*0*000.0*0*000.0*00.00**
    2000-01-01-00:00*0*0*0*00.00**
    2000-01-01-00:00*0*000.0*00.00**
    2000-01-01-00:00*00*00.00*00.00*00.00**
    2000-01-01-00:00*00*00.00*00.00*00.00**,
    IDE00066,History data 11,2019-06-25-14:24*000*003*000*000*0000*006*01.6*00.3*088*084*089*081*01*00000*00001*00003*00003*00008**
    2019-06-24-18:22*000*000*003*000*0096*007*00.7*01.2*095*089*096*092*01**
    2019-06-24-18:13*000*000*000*000*0000*001*00.0*00.0*095*090*095*091*01**
    2019-06-24-18:12*000*000*000*000*0000*055*00.0*00.0*088*082*095*090*01**
    2019-03-25-23:13*000*000*000*000*0000*000*00.0*00.0*098*063*099*065*00**
    2019-03-25-23:08*000*000*000*000*0000*001*00.1*00.0*097*062*098*063*01**
    2019-03-25-22:53*000*000*014*000*0050*015*00.2*00.5*096*061*097*062*01**
    2019-03-25-22:41*000*000*008*000*0119*011*00.4*01.0*095*060*096*061*01**
    2019-03-25-22:25*000*000*014*000*0023*017*00.1*00.8*093*054*095*060*01**
    2000-01-01-00:00*000*000*000*000*0000*000*00.0*00.0*000*000*000*000*00**,
    IDE00067,History data 12,2000-01-01-00:00*0*000*000*+00*00*+00.0*+00.0*00.0*0**
    00000*00000*00000**,
    IDE00068,History data 13,2000-01-01-00:00*0-0-0-0-0*000.0*00000**
    2000-01-01-00:00*0-0-0-0-0*000.0**
    2000-01-01-00:00*0-0-0-0-0*000.0**,
    IDE00069,History data 14,2000-01-01-00:00*00*---*---*----------*00000*00000**
    2000-01-01-00:00*0*00*00*00*00*00**
    00000*00000*00000**
    2000-01-01-00:00*0-0-0-0-0-0-0-0**
    00000*00000*00000*00000*00000*00000*00000*00000**
    2000-01-01-00:00*0*000*000*00*00000*00000**
    IDE00070,History data 15,2000-01-01-00:00*000*00*00*000*00*00*000*00*00**
    2000-01-01-00:00*000*00*00*000*00*00*000*00*00**,
    IDE00071,History data 16,000065**
    00086*00013*00000*00000*00002**
    00038*00010*00004*00005**
    00616*00002*00004*00010**
    00046*00013*00000*00003**
    00058*00003*00001**
    00014*00000*00000**
    00000*00000*00000**
    00004*00001*00000**
    00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**
    00036*00014*00008*00011*00017**,
    IDE00102,Control Module temperature,26, °C
    IDE00276,Position in MOST Ring,00,
    IDE01803,History data 17,2000-01-01-00:00*0000*00*0**
    0*0000*0000*00*00*0000*00**
    0000*00*0000*00*0000*0000**
    2000-01-01-00:00*+000*0000*000*0000*00*0000*00**
    2000-01-01-00:00*+000*0000*000*0000*00*0000*00**,
    IDE01807,History data 21,00065*2019-07-26-14:25*0167.9*5f*0000.5*00*0000.0*00*0000.0*00*0000.0*00*0000.0**
    00061*2019-06-29-10:31*0091.8*5f*0000.5*00*0000.0*00*0000.0*00*0000.0*00*0000.0**
    00000*2000-00-00-00:00*0000.0*00*0000.0*00*0000.0*00*0000.0*00*0000.0*00*0000.0**
    00000*2000-00-00-00:00*0000.0*00*0000.0*00*0000.0*00*0000.0*00*0000.0*00*0000.0**,
    IDE01808,History data 22,00*00000*00*00000*00*00000*00*00000*00*00000*00*00000*00*00000*00*00000*00*00000*00*00000**,
    IDE01809,History data 23,00065*2019-07-27-16:56*0194.4*K*00042*06e2*1*06c1*0*06e2*1*06e3*1*0003*0**
    00061*2019-06-29-13:11*0094.5*K*00042*06e2*1*0003*0*06e6*0*06e2*1*06e2*0**
    00000*2000-00-00-00:00*0000.0*0*00000*0000*0*0000*0*0000*0*0000*0*0000*0**
    00000*2000-00-00-00:00*0000.0*0*00000*0000*0*0000*0*0000*0*0000*0*0000*0**,
    IDE01810,History data 24,00065*2019-07-25-16:34*0146.2*K*00030*000006e0*001*00000000*000*00000000*000*00000000*000*00000000*000**
    00065*2019-07-24-10:26*0116.0*K*00020*000006e0*009*000006e2*002*00000629*001*00000000*000*00000000*000**
    00061*2019-06-26-18:24*0027.8*K*00039*000006e0*005*000006e2*003*000006e3*002*00000000*000*00000000*000**
    00061*2019-06-25-18:06*0003.5*K*00021*000006e0*008*000006e2*003*000006e3*003*000006f5*001*00000000*000**
    00000*2000-00-00-00:00*0000.0*0*00000*00000000*000*00000000*000*00000000*000*00000000*000*00000000*000**,
    IDE01811,History data 25,00063*2019-07-19-14:25*0000.3**
    00063*2019-07-19-14:02*0000.0**
    00063*2019-07-19-14:01*0000.0**
    00054*2019-06-24-18:12*0000.0**
    00001*2019-03-28-04:09*0000.0**,
    IDE01812,History data 26,00727*00012*00000*00010*00495*00002*00000*00208**,
    IDE01813,History data 27,00475*00052*00017*00312*00007*00000*00087**,
    IDE01814,History data 28,00325*00000*00000*00325*00000**,
    IDE01815,History data 29,00274*00001*00000*00004*00156*00000*00000*00113**,
    IDE01816,History data 30,00167*00024*00001*00107*00001*00000*00034**,
    IDE01817,History data 31,00114*00000*00000*00114*00000**,
    IDE01818,History data 32,00065*2019-08-10-09:18*0522.6*06c8*0**
    00065*2019-08-10-08:32*0521.9*0003*0**
    00065*2019-08-10-08:21*0521.7*06e2*1**
    00065*2019-08-10-08:21*0521.7*06d9*0**
    00065*2019-08-10-08:20*0521.7*06e2*1**,
    IDE01819,History data 33,00065*2019-08-10-09:18*0522.6*000006e1*K**
    00065*2019-08-10-08:36*0521.9*000006c0*L**
    00065*2019-08-10-08:33*0521.9*000006e0*K**
    00065*2019-08-10-08:33*0521.9*000006e2*K**
    00065*2019-08-10-08:23*0521.7*000006c0*L**,
    IDE01820,History data 34,00065*2019-08-10-09:18*0522.6*06e1**
    00065*2019-08-10-08:32*0521.9*06e2**
    00065*2019-08-10-08:21*0521.7*06e2**
    00065*2019-08-10-08:20*0521.7*06e2**,
    IDE01821,History data 35,00000*00000*00000*00000*00000*00000*00000*00000*00000**,
    IDE01822,History data 36,00000*2000-00-00-00:00*0000.0*00000*00000*00000*00000*00000*00000*00000**
    00000*2000-00-00-00:00*0000.0*00000*00000*00000*00000*00000*00000*00000**,
    IDE01823,History data 37,00066*2019-03-28-04:06*0000.0*0000.0**,
    IDE01827,Generator specified voltage value,10.6, V
    IDE01828,Generator DF Signal,0.025, %
    IDE01829,Generator exciter current,0.000, A
    IDE01830-MAS01632,Generator Status-Status,Thermal OK,
    IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK,
    IDE01830-MAS02971,Generator Status-Status 3:,Electrical OK,
    IDE01831-MAS03159,Generator variant-Manufacturer,Hitachi,
    IDE01831-MAS04490,Generator variant-Size,140 - 210 ETA,
    IDE01831-ENG113380,Generator variant-alternator identification_regulator,4,
    IDE01831-ENG113379,Generator variant-alternator manufacture_regulator,Infineon Technologies AG,
    IDE01833-MAS03159,Battery variant-Manufacturer,JCI,
    IDE01833-MAS04490,Battery variant-Size,92 Ah,
    IDE01834,Battery voltage,12.489, V
    IDE01835,Battery current filtered,-10.900, A
    IDE01836,Battery current,-10.871, A
    IDE01837,Temperature of battery sensor,23, °
    IDE01838,Battery temperature,22, °
    IDE01839,Battery charge condition,91, %
    IDE01840,Battery condition for display,90, %
    IDE01841,Battery internal resistance,3.0, mOhm
    IDE01842,Usable battery charge,86, Ah
    IDE01843,Battery voltage at rest,12.7, V
    IDE01844,Increase idle speed request,not active,
    IDE01845,Reduce internal fan request,not active,
    IDE01846,Static current shutdown level,not active,
    IDE01847,Auxiliary heater activation restriction request,-,
    IDE01847-ENG100234,Auxiliary heater activation restriction request-park_heater_target_time,not active,
    IDE01848,Previous journey energy summary,0.0, Ah
    IDE01849,Previous journey duration,0.00, H
    IDE01850,Total energy summary,10009.0, Ah
    IDE01851,Total energy throughput,171.1, Ah
    IDE01852,Static current measurement: result,0.01, A
    IDE01853,Static current measurement: status,Measurement end,
    IDE01854,Energy reclamation request,not active,
    IDE01855,Generator current,0.0, A
    IDE01856,Battery acid stratification,0, %
    IDE01864-MAS03173,Status of current bus communication-Databus drivetrain,active,
    IDE01864-MAS03174,Status of current bus communication-Comfort data bus,active: local wakeup event,
    IDE01864-MAS03175,Status of current bus communication-Databus extended,active,
    IDE01864-MAS03176,Status of current bus communication-Display and control head databus,active,
    IDE01864-MAS03177,Status of current bus communication-Databus Infotainment,not installed,
    IDE01864-MAS03178,Status of current bus communication-Suspension data bus,active,
    IDE01864-MAS03179,Status of current bus communication-Local data bus 2,not installed,
    IDE01864-MAS03180,Status of current bus communication-Local data bus,active,
    IDE01864-MAS03181,Status of current bus communication-Flexray databus,active,
    IDE01864-MAS07380,Status of current bus communication-Data bus Sensor/Hybrid,not installed,
    IDE01865-MAS03182,Status flex ray communication-Branch 1,active,
    IDE01865-MAS03183,Status flex ray communication-Branch 2,active,
    IDE01865-MAS03184,Status flex ray communication-Branch 3,active,
    IDE01865-MAS03185,Status flex ray communication-Branch 4,active,
    IDE01865-MAS03186,Status flex ray communication-Branch 5,not installed,
    IDE01865-MAS03187,Status flex ray communication-Branch 6,not installed,
    IDE01865-MAS03188,Status flex ray communication-Branch 7,not installed,
    IDE01865-MAS03189,Status flex ray communication-Branch 8,not installed,
    IDE01866,MOST system condition,Light off,
    IDE01867-IDE01863,MOST hardware parameter-MOST light performance,Decrease 0 dB,
    IDE01867-MAS03121,MOST hardware parameter-Ring break diagnostic line status,0,
    IDE01867-MAS03122,MOST hardware parameter-Ring break diagnostic line voltage,25.5, V
    IDE01867-ENG100178,MOST hardware parameter-HW Instance (MP1-4)_MOST hardware value,0,
    IDE01868,Ring break diagnostic result,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
    IDE01948,Battery internal resistance not normed,3.2, mOhm
    IDE01979,Stored key for component protection participants,04 81 48 00 20 40 00 00 00 04 00 00,
    IDE01980,Component protection participant currently wrongly authent.,00 00 00 00 00 00 00 00 00 00 00 00,
    IDE01981,Comp. protect participant occasionally wrongly authent.,00 00 00 00 00 00 00 00 00 00 00 00,
    IDE01982,Transport protocol used for component protection,00 01 40 00 20 00 00 00 00 04 00 00,
    IDE01983,Number of successfully repaired keys,0,
    IDE01984,Number of successful key downloads,0,
    IDE01985-ENG101043,FAZIT identification test sum-Checksum,21 88 AF 57,
    IDE01985-ENG99027,FAZIT identification test sum-Version,1,
    IDE01992-ENG16230,Installation list: current installations-ECU present Bit 0,can be reached,
    IDE01992-ENG45410,Installation list: current installations-ECU present Bit 1,can be reached,
    IDE01992-ENG45396,Installation list: current installations-ECU present Bit 2,can be reached,
    IDE01992-ENG45402,Installation list: current installations-ECU present Bit 3,can be reached,
    IDE01992-ENG45430,Installation list: current installations-ECU present Bit 4,can be reached,
    IDE01992-ENG45377,Installation list: current installations-ECU present Bit 5,can be reached,
    IDE01992-ENG21674,Installation list: current installations-ECU present Bit 6,can be reached,
    IDE01992-ENG16217,Installation list: current installations-ECU present Bit 7,can be reached,
    IDE01993-ENG20451,Control module reference number-ECU ID,01,
    IDE01993-ENG20480,Control module reference number-ECU Name,Engine Control Module 1,
    IDE01995-ENG16990,Control module protocol information-Ethernet,No,
    IDE01995-ENG16987,Control module protocol information-ISO-TP,Yes,
    IDE01995-ENG16989,Control module protocol information-K Line,No,
    IDE01995-ENG16988,Control module protocol information-TP 1.6,No,
    IDE01995-ENG16991,Control module protocol information-TP 2.0,No,
    IDE01996-ENG20493,Installation list: specified installations-ECU coded Bit 0,Yes,
    IDE01996-ENG45436,Installation list: specified installations-ECU coded Bit 1,Yes,
    IDE01996-ENG45421,Installation list: specified installations-ECU coded Bit 2,Yes,
    IDE01996-ENG45358,Installation list: specified installations-ECU coded Bit 3,Yes,
    IDE01996-ENG45367,Installation list: specified installations-ECU coded Bit 4,Yes,
    IDE01996-ENG45433,Installation list: specified installations-ECU coded Bit 5,Yes,
    IDE01996-ENG45401,Installation list: specified installations-ECU coded Bit 6,Yes,
    IDE01996-ENG45426,Installation list: specified installations-ECU coded Bit 7,Yes,
    IDE02384-ENG16210,Status of event memory-ECU Dtc Bit 0,ERROR,
    IDE02384-ENG45352,Status of event memory-ECU Dtc Bit 1,OK,
    IDE02384-ENG45386,Status of event memory-ECU Dtc Bit 2,OK,
    IDE02384-ENG45404,Status of event memory-ECU Dtc Bit 3,OK,
    IDE02384-ENG45387,Status of event memory-ECU Dtc Bit 4,OK,
    IDE02384-ENG45440,Status of event memory-ECU Dtc Bit 5,OK,
    IDE02384-ENG21671,Status of event memory-ECU Dtc Bit 6,OK,
    IDE02384-ENG16227,Status of event memory-ECU Dtc Bit 7,OK,
    IDE03008-ENG98388,Stop process prevented-Battery charge condition too low,0,
    IDE03008-ENG98389,Stop process prevented-Battery temperature,0,
    IDE03008-ENG99012,Stop process prevented-Consumer current too high,0,
    IDE03008-ENG103231,Stop process prevented-Entnehmbare Ladung zu gering,0,
    IDE03008-ENG98719,Stop process prevented-Idle speed increase active,0,
    IDE03008-ENG122800,Stop process prevented-Intermittierender Betrieb aktiv,0,
    IDE03008-ENG98746,Stop process prevented-Possible service life too short,0,
    IDE03008-ENG103267,Stop process prevented-Sonderveto aktiv,0,
    IDE03008-ENG104139,Stop process prevented-Veto DC/DC Wandler,0,
    IDE03009-ENG98388,Start process requested-Battery charge condition too low,0,
    IDE03009-ENG104067,Start process requested-Charging contingent,0,
    IDE03009-ENG99104,Start process requested-Entnehmbare Ladung,0,
    IDE03009-ENG99021,Start process requested-Insuff. voltage,0,
    IDE03009-ENG101118,Start process requested-Stromverbrauch,0,
    IDE03009-ENG102869,Start process requested-Zielzeit abgelaufen,0,
    IDE03127,Prevented stop processes (ring memory),2000-01-01-00:00*0-0-0-0-0-0-0-0**
    IDE03128,Requested start processes (ring memory),2000-01-01-00:00*0-0-0-0-0-0-0-0**
    IDE03150-ENG20495,Readiness for bus sleep mode-ECU SleepReady Bit0,cannot be reached,
    IDE03150-ENG45365,Readiness for bus sleep mode-ECU SleepReady Bit1,cannot be reached,
    IDE03150-ENG45382,Readiness for bus sleep mode-ECU SleepReady Bit2,cannot be reached,
    IDE03150-ENG45417,Readiness for bus sleep mode-ECU SleepReady Bit3,cannot be reached,
    IDE03150-ENG45441,Readiness for bus sleep mode-ECU SleepReady Bit4,cannot be reached,
    IDE03150-ENG45422,Readiness for bus sleep mode-ECU SleepReady Bit5,can be reached,
    IDE03150-ENG45372,Readiness for bus sleep mode-ECU SleepReady Bit6,cannot be reached,
    IDE03150-ENG45428,Readiness for bus sleep mode-ECU SleepReady Bit7,cannot be reached,
    IDE03151,TP CAN identifier,00 00,
    IDE03212,Start-stop conditions,Stop release,
    IDE03213,Start-stop enabling,Not available,
    IDE03897,Generator: status communication,active,
    IDE03898,Voltage stabilizer: status communication,not active,
    IDE03899,Battery monitoring control module: status communication,active,
    IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
    IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
    IDE06747-IDE01834,Battery monitoring control unit 2-Battery voltage,4.000, V
    IDE06747-IDE01836,Battery monitoring control unit 2-Battery current,-32.768, A
    IDE06747-IDE01838,Battery monitoring control unit 2-Battery temperature,-40, °
    IDE06747-IDE01839,Battery monitoring control unit 2-Battery charge condition,0, %
    IDE06747-IDE01841,Battery monitoring control unit 2-Battery internal resistance,0.0, mOhm
    IDE06747-IDE01948,Battery monitoring control unit 2-Battery internal resistance not normed,0.0, mOhm
    IDE06747,Battery monitoring control unit 2,not active,
    IDE06747-ENG113366,Battery monitoring control unit 2-battery current puls,0,
    IDE06747-ENG113365,Battery monitoring control unit 2-battery voltage puls,9.000, V
    IDE06747-ENG113367,Battery monitoring control unit 2-BZE_Min_puls_duration,0, ms
    IDE06747-ENG113368,Battery monitoring control unit 2-BZE_Min_trigger,0,
    IDE06747-ENG101157,Battery monitoring control unit 2-BZE_Q_Elad,0.0, Ah
    IDE06747-ENG100159,Battery monitoring control unit 2-BZE_Q_Lad,0.0, Ah
    IDE06747-ENG106125,Battery monitoring control unit 2-EM_blBatteryDisconnected,connected,
    IDE06747-ENG98970,Battery monitoring control unit 2-Temperature of battery sensor,-40, °
    IDE08529-MAS01632,Service-key: query status-Status,active,
    IDE08529-MAS07126,Service-key: query status-Standard query,active,
    IDE08529-MAS07127,Service-key: query status-Immediate query,not active,
    IDE08529-MAS07128,Service-key: query status-Control module in except. handling 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
    IDE08529-MAS07129,Service-key: query status-Control module in except. handling 2,09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
    ENG107689-IDE01868,Automatic loop break diagnosis-Ring break diagnostic result,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
    ENG107689-MAS00043,Automatic loop break diagnosis-Supply voltage: Terminal 30,0.0, V
    ENG107689-MAS00711,Automatic loop break diagnosis-Odometer reading,0, km
    ENG107689-MAS01230,Automatic loop break diagnosis-Date,00.00.2000,
    ENG107689-MAS02957,Automatic loop break diagnosis-Time,00:00,
    ENG105315-ENG103971,BCmE_Versionnumber-Patch,2,
    ENG105315-ENG98889,BCmE_Versionnumber-Release,5,
    ENG105771-ENG102240,DCDC_First_Branch-DC_STST1_Bypassrelais_defekt_TW1,2,
    ENG105771-ENG102373,DCDC_First_Branch-DC_STST1_El_Fehler_Ausgang_KS_TW1,2,
    ENG105771-ENG104027,DCDC_First_Branch-DC_STST1_Lastabschaltung_TW1,2,
    ENG105771-ENG101272,DCDC_First_Branch-DC_STST1_Uebertemperatur_TW1,2,
    ENG105771-ENG100694,DCDC_First_Branch-DC_STST1_Unterspannung_Eingang_TW1,2,
    ENG105772-ENG102945,DCDC_Second_Branch-DC_STST1_Bypassrelais_defekt_TW2,2,
    ENG105772-ENG99327,DCDC_Second_Branch-DC_STST1_El_Fehler_Ausgang_KS_TW2,2,
    ENG105772-ENG100692,DCDC_Second_Branch-DC_STST1_Lastabschaltung_TW2,2,
    ENG105772-ENG100445,DCDC_Second_Branch-DC_STST1_Uebertemperatur_TW2,2,
    ENG105772-ENG101117,DCDC_Second_Branch-DC_STST1_Unterspannung_Eingang_TW2,2,
    ENG105773-ENG100371,DCDC_STST_Status-DC_STST1_Boost,2,
    ENG105773-ENG101192,DCDC_STST_Status-DC_STST1_Defekt,2,
    ENG105773-ENG101605,DCDC_STST_Status-DC_STST1_ErrorGueltigkeit,2,
    ENG105773-ENG103583,DCDC_STST_Status-DC_STST1_Fail,2,
    ENG105773-ENG103918,DCDC_STST_Status-DC_STST1_Fktbereit,2,
    ENG105773-ENG102020,DCDC_STST_Status-DC_STST1_Lokalaktiv,2,
    ENG105773-ENG103598,DCDC_STST_Status-DC_STST1_Stromgrenze,2,
    ENG105773-ENG99195,DCDC_STST_Status-DC_STST1_Uebertemperatur,2,
    ENG113398,EM Produktionsmodus Freigabe,1,
    ENG113397,EM RSM Freigabe,1,
    ENG106120,EM_battery identification known,known,
    ENG106121-ENG101157,EM_Battery_charge_discharge-BZE_Q_Elad,159.2, Ah
    ENG106121-ENG100159,EM_Battery_charge_discharge-BZE_Q_Lad,173.7, Ah
    ENG106122,EM_battery_identification,12,
    ENG106123,EM_blAlternator On,OFF,
    ENG106124,EM_blAlternator Valid,Yes,
    ENG106125,EM_blBatteryDisconnected,connected,
    ENG106126,EM_blBemSleepRdy,0,
    ENG106127,EM_blBoostRecognised,detected,
    ENG106128,EM_blCanMostActive,1,
    ENG106129,EM_blControlKFan,0,
    ENG106130,EM_blDisconnectionAdeptChannel,0,
    ENG106131,EM_blMmi Advance Warning,0,
    ENG106132,EM_blMmi Advance Warning Diag,0,
    ENG106133,EM_blParkHeatingEncoded,Not coded,
    ENG106134,EM_blRecuperation Encoded,coded,
    ENG106135,EM_blRecuperation Enforce,Not coded,
    ENG106136,EM_blSleepIndication,1,
    ENG106137,EM_blStabilisation EBalance,0,
    ENG106138,EM_blStabilisation EPowerSystem,0,
    ENG106139,EM_blVnaActive,0,
    ENG106140,EM_Current_Control_Recu,not active,
    ENG121181,EM_Energiebilanz_2,10000.0, Ah
    ENG106141,EM_errEBalanceDiag,0,
    ENG106142,EM_errEPowerSystem,0,
    ENG106143,EM_errOverVoltage,0,
    ENG113400-ENG113369,EM_Hybrid_Info-Hybrid_Info,Motorstart_ueber_12V_Starter_nur_bei_0kmh_moeglich,
    ENG106144,EM_IAlternator L1,0.0, A
    ENG106145,EM_IAlternator Reserve,0.0, A
    ENG106146,EM_IInternalFan,0.00, A
    ENG106147,EM_IKmStandTm Active,0, km
    ENG106148,EM_IKmStandTmActiveIn,100, km
    ENG106149,EM_INeutralBem,-1.576, A
    ENG106150,EM_IParkHeatingRequirements,10, A
    ENG121178,EM_Ladestrombegrenzung,not active,
    ENG106151,EM_Load Response Time,6.00, s
    ENG106160-ENG102785,EM_loss_of_voltage / param_specified_capacity-Battery technology,Batterietechnologie unbekannt,
    ENG106160-ENG100745,EM_loss_of_voltage / param_specified_capacity-BZE_DeltaUStart_Aktuell,12.70, V
    ENG106160-ENG101482,EM_loss_of_voltage / param_specified_capacity-BZE_DeltaUStart_Mittel,12.70, V
    ENG106160-ENG102509,EM_loss_of_voltage / param_specified_capacity-BZE_DeltaUStart_Trigger,1,
    ENG106160-ENG102743,EM_loss_of_voltage / param_specified_capacity-BZE_MinUStart,7.55, V
    ENG106160-ENG101108,EM_loss_of_voltage / param_specified_capacity-BZE_MinUStart_Trigger,1,
    ENG106160-ENG100156,EM_loss_of_voltage / param_specified_capacity-BZE_Q_Nom,104, Ah
    ENG106160-ENG100059,EM_loss_of_voltage / param_specified_capacity-Nenn Kapazität,Init,
    ENG106152,EM_MAlternator,0.0, Nm
    ENG106153,EM_NDisconnectionEngineSpeed,5990, /min
    ENG106154,EM_PAltMechanical,0, W
    ENG106155-ENG99338,EM_prcSoh-prc SohP,94, %
    ENG106155-ENG101494,EM_prcSoh-prc SohQ,100, %
    ENG106156,EM_PReserveFilter,0, W
    ENG106157-ENG101729,EM_RecuMode_Engine-Modus Rekuperation (Motor),Acceleration limited,
    ENG106159-ENG102920,EM_Recuperation_Prerequisite-Auslastung des Generators,1,
    ENG106159-ENG100983,EM_Recuperation_Prerequisite-Batteriealterung (Ladung),1,
    ENG106159-ENG99619,EM_Recuperation_Prerequisite-Batteriealterung (Leistung),1,
    ENG106159-ENG102670,EM_Recuperation_Prerequisite-Batterieregeneration,1,
    ENG106159-ENG103895,EM_Recuperation_Prerequisite-Energie Netz,1,
    ENG106159-ENG99263,EM_Recuperation_Prerequisite-Energiedurchsatz,1,
    ENG106159-ENG99104,EM_Recuperation_Prerequisite-Entnehmbare Ladung,1,
    ENG106159-ENG99756,EM_Recuperation_Prerequisite-Generatordiagnose,1,
    ENG106159-ENG103581,EM_Recuperation_Prerequisite-Ladezustand der Batterie,0,
    ENG106159-ENG100106,EM_Recuperation_Prerequisite-Leerlaufanhebung,1,
    ENG106159-ENG104009,EM_Recuperation_Prerequisite-LIN-Kommunikation,1,
    ENG106159-ENG98425,EM_Recuperation_Prerequisite-Outside air temperature,1,
    ENG106159-ENG102570,EM_Recuperation_Prerequisite-Säureschichtung,1,
    ENG106159-ENG101873,EM_Recuperation_Prerequisite-Sonderveto,1,
    ENG106159-ENG103261,EM_Recuperation_Prerequisite-Spannung der Batterie,1,
    ENG106159-ENG103394,EM_Recuperation_Prerequisite-Temperatur der Batterie,1,
    ENG106158-ENG104224,EM_Recuperation_Restriction-Abblendlicht Aktiv,0,
    ENG106158-ENG99969,EM_Recuperation_Restriction-Auslastung Innegeblaese Hoch,0,
    ENG106158-ENG103587,EM_Recuperation_Restriction-Bauteilschutz BDM,0,
    ENG106158-ENG102567,EM_Recuperation_Restriction-Bauteilschutz Fernlicht,0,
    ENG106158-ENG101156,EM_Recuperation_Restriction-Blinker links Aktiv,0,
    ENG106158-ENG101146,EM_Recuperation_Restriction-Blinker rechts Aktiv,0,
    ENG106158-ENG113355,EM_Recuperation_Restriction-EPS Leistunsanforderung,0,
    ENG106158-ENG101898,EM_Recuperation_Restriction-ESP-Anforderung,0,
    ENG106158-ENG99511,EM_Recuperation_Restriction-Innenlicht Aktiv,0,
    ENG106158-ENG102650,EM_Recuperation_Restriction-Motor-Anforderung,0,
    ENG121180-ENG121171,EM_Rekuperation_Sonderveto-Sonderveto_Anhaenger,No,
    ENG121180-ENG121172,EM_Rekuperation_Sonderveto-Sonderveto_Klima,No,
    ENG121180-ENG121174,EM_Rekuperation_Sonderveto-Sonderveto_Motor_Spannungsanforderung,No,
    ENG121180-ENG121170,EM_Rekuperation_Sonderveto-Sonderveto_Produktion,No,
    ENG121180-ENG121169,EM_Rekuperation_Sonderveto-Sonderveto_Transportmodus,No,
    ENG121180-ENG121173,EM_Rekuperation_Sonderveto-Sonderveto_Zustart_Batterie,No,
    ENG106161-ENG102992,EM_Start_Stop_State-Mögliche Stoppzeit,15,
    ENG106161-ENG100942,EM_Start_Stop_State-Start Stopp Phase,ERROR,
    ENG106161-ENG103632,EM_Start_Stop_State-Status Motorstopp,not active,
    ENG106161-ENG102878,EM_Start_Stop_State-Status Wiederstart,not active,
    ENG106161-ENG100005,EM_Start_Stop_State-Stromverbrauchsschätzung Stoppphase,30, A
    ENG106162-ENG102635,EM_Start_Stop_System_Error / system fault DC-Alternator failure,0,
    ENG106162-ENG101997,EM_Start_Stop_System_Error / system fault DC-Batterie zyklisch verbraucht,0,
    ENG106162-ENG103373,EM_Start_Stop_System_Error / system fault DC-Battery malfunction,0,
    ENG106162-ENG99392,EM_Start_Stop_System_Error / system fault DC-Fehler Diagnosesignal DC/DC-Wandler,0,
    ENG106162-ENG101407,EM_Start_Stop_System_Error / system fault DC-Start/Stopp-Koordinator unplausibel,0,
    ENG106162-ENG122799,EM_Start_Stop_System_Error / system fault DC-Systemfehler BDM Defekt,0,
    ENG106162-ENG100042,EM_Start_Stop_System_Error / system fault DC-Systemfehler DC/DC-Wandler,0,
    ENG106163-ENG99559,EM_tSgErrors-tSgError IO Duration tSgErrors,0, min
    ENG106163-ENG100405,EM_tSgErrors-tSgError NIO Duration tSgErrors,0, min
    ENG106163-ENG100563,EM_tSgErrors-tSgErrorDuration In tSgErrors,0, s
    ENG106163-ENG103494,EM_tSgErrors-tSgErrorDuration tSgErrors,0, s
    ENG106164,EM_UControlUnit,12.306, V
    ENG106165,EM_Ustart,6.5, V
    ENG106166,EM_valBdm LinTableSwitch,Terminal 15 on,
    ENG106167,EM_valBdm WakeUpReason,0,
    ENG106168,EM_valEngineId,4,
    ENG106169,EM_valHlkLevelRequirement,1,
    ENG106170,EM_valStatusHlk,0,
    ENG106171-ENG103971,EM_Versionnumber-Patch,2,
    ENG106171-ENG98889,EM_Versionnumber-Release,21,
    ENG113401-ENG113374,EM_Zustart Freigabe-Freigabe Aussentemperatur,Yes,
    ENG113401-ENG113370,EM_Zustart Freigabe-Freigabe Batterietemperatur (Bat1),Yes,
    ENG113401-ENG113372,EM_Zustart Freigabe-Freigabe Batterietemperatur (Bat2),Yes,
    ENG113401-ENG113371,EM_Zustart Freigabe-Freigabe Entnehmbare Ladung (Bat1),Yes,
    ENG113401-ENG113373,EM_Zustart Freigabe-Freigabe Leistungsfähigkeit Zustart,No,
    ENG121179-ENG121165,EM_Zustart_Systemfehler-EM_BatterieAb_BDM1,No,
    ENG121179-ENG121166,EM_Zustart_Systemfehler-EM_BatterieAb_BDM2,No,
    ENG121179-ENG121167,EM_Zustart_Systemfehler-EM_LIN1_ungueltig,No,
    ENG121179-ENG121168,EM_Zustart_Systemfehler-EM_LIN2_ungueltig,No,
    ENG113402-ENG113377,GW_Bap_Status-Lifecycle,Unknown (255),
    ENG113402-ENG99775,GW_Bap_Status-MOST,Unknown (255),
    ENG113402-ENG113378,GW_Bap_Status-PE_Freigabe,255,
    ENG106825,GW_SYS_BEM_SleepReady,EM active,
    ENG106826,GW_SYS_BM_Run-on,60, s
    ENG106827-ENG100038,GW_SYS_CPU_Load-CPU Load,0, %
    ENG106827-ENG113384,GW_SYS_CPU_Load-Task Level 1,0, %
    ENG106827-ENG113383,GW_SYS_CPU_Load-Task Level 2,0, %
    ENG106827-ENG113382,GW_SYS_CPU_Load-Task Level 3,0, %
    ENG106827-ENG113381,GW_SYS_CPU_Load-Task Level 4,0, %
    ENG106828,GW_SYS_EEPROM Repair,0,
    ENG106832-ENG100323,GW_SYS_LastWakeupReason-Car WakeUp Reason,Comfort data bus,
    ENG106832-ENG99403,GW_SYS_LastWakeupReason-Gateway WakeUp Reason,Comfort data bus,
    ENG106833,GW_SYS_Reset_Count,0,
    ENG106834,GW_SYS_ResetReason,Power On Reset,
    ENG100548-MAS00049,GW_SYS_State-Component protection,not active,
    ENG100548-MAS00795,GW_SYS_State-Diagnostic interface for data bus,active,
    ENG100548-MAS01468,GW_SYS_State-Terminal 15,active,
    ENG100548-MAS01490,GW_SYS_State-Energy management,not active,
    ENG100548-MAS03173,GW_SYS_State-Databus drivetrain,active,
    ENG100548-MAS03174,GW_SYS_State-Comfort data bus,active,
    ENG100548-MAS03175,GW_SYS_State-Databus extended,active,
    ENG100548-MAS03176,GW_SYS_State-Display and control head databus,active,
    ENG100548-MAS03177,GW_SYS_State-Databus Infotainment,not active,
    ENG100548-MAS03178,GW_SYS_State-Suspension data bus,active,
    ENG100548-MAS03180,GW_SYS_State-Local data bus,active,
    ENG100548-MAS03181,GW_SYS_State-Flexray databus,active,
    ENG100548-ENG102839,GW_SYS_State-A-Can Flexray F-Can SubMaster,active,
    ENG100548-ENG100518,GW_SYS_State-Busmonitor,active,
    ENG100548-ENG98571,GW_SYS_State-EEPROM,active,
    ENG100548-ENG99046,GW_SYS_State-Emergency signal flashing,not active,
    ENG100548-ENG100049,GW_SYS_State-K-Can Dash-Can SubMaster,active,
    ENG100548-ENG102799,GW_SYS_State-Mindestaktivzeit,active,
    ENG106837,GW_SYS_TP20_Counter,0,
    ENG110999,GW_Watchdog_Version,0,
    ENG08826-ENG09535,HVEM Autonome Zustaende-Aktivieren HV durch HVEM,no request,
    ENG08826-ENG09537,HVEM Autonome Zustaende-DCDC Ist-Modus,Initializing,
    ENG08826-ENG09536,HVEM Autonome Zustaende-HV-Bordnetz,not active,
    ENG08826-ENG09534,HVEM Autonome Zustaende-Laden HV-Batterie,no request,
    ENG08826-ENG09532,HVEM Autonome Zustaende-Nachladung NV Batterie,no request,
    ENG08826-ENG09533,HVEM Autonome Zustaende-Vorkonditionierung,Init,
    ENG08829-ENG09539,HVEM Energieverteilung-Aktuelle Energievorgabe an das NVEM,0, Wh
    ENG08829-ENG09538,HVEM Energieverteilung-Aktuelle Energievorgabe an das TME,0, Wh
    ENG08829-ENG09540,HVEM Energieverteilung-Aktuelle Leistung der Hochvoltseite des DCDC-Wandlers,0, Wh
    ENG08828-ENG09540,HVEM Leistungsverteilung-Aktuelle Leistung der Hochvoltseite des DCDC-Wandlers,0, W
    ENG08828-ENG09545,HVEM Leistungsverteilung-Aktuelle Leistung des TME,0, W
    ENG08828-ENG09546,HVEM Leistungsverteilung-Aktuelle Leistungsverbrauch der HV-Nebenverbraucher,0, W
    ENG08828-ENG09544,HVEM Leistungsverteilung-Aktuelle Leistungsvorgabe an das NVEM,0, W
    ENG08828-ENG09543,HVEM Leistungsverteilung-Aktuelle Leistungsvorgabe an die TME,0, W
    ENG08828-ENG09542,HVEM Leistungsverteilung-Aktuelle Leistungsvorgabe durch Ladegeraet,0, W
    ENG08828-ENG09541,HVEM Leistungsverteilung-Aktuelle Leistungsvorgabe durch MSG,25450, W
    ENG08830-ENG09547,HVEM NachladeanforderungAnHVLM-Status der Anforderung zur Vorkonditionierung,not active,
    ENG08827-ENG09548,HVEM Tiefentladeschutz-Abschaltstufe zur Vermeidung von Tiefentladung der HV-Batterie,No enabling,
    ENG08827-ENG09550,HVEM Tiefentladeschutz-Aktueller min SOC zum Entladen der HV Batterie,0.00, %
    ENG08827-ENG09549,HVEM Tiefentladeschutz-Aktueller SOC HV Batterie,0.00, %
    ENG100189,IN ESP_standstill flag,1,
    ENG100411,IN ESP_v_Signal,0, km/h
    ENG100786,IN HW terminal 15,1,
    ENG101017,IN KBI_odometer_reading,65,
    ENG101398,IN MO_engine_speed_01,0.00, /min
    ENG103286,IN MO_Motor_running,0,
    ENG106958-MAS00106,IN time_01-Year,2019,
    ENG106958-MAS00107,IN time_01-Month,8,
    ENG106958-MAS00108,IN time_01-Day,10,
    ENG106958-MAS00109,IN time_01-Hours,9,
    ENG106958-MAS00110,IN time_01-Minutes,24,
    ENG106958-MAS00111,IN time_01-Seconds,31,
    ENG106958-MAS00690,IN time_01-Daylight saving time,Daylight saving time,
    ENG106958-ENG103328,IN time_01-type of clock,GPS,
    ENG101569,IN ZAS_Te_15,1,
    ENG103048,IN ZAS_Te_X,1,
    ENG107685-ENG103912,MOST Deattaches-deatatch counter_MOST Deatatches,0,
    ENG107685-ENG99643,MOST Deattaches-present deatatch counter_MOST Deatatches,0,
    ENG107685-ENG100756,MOST Deattaches-present status_MOST Deatatches,Open circuit,
    ENG102460-ENG20471,MOST Notifications-Function ID,00 00,
    ENG102460-ENG20429,MOST Notifications-Target Adress 1,00 00,
    ENG102460-ENG20454,MOST Notifications-Target Adress 2,00 00,
    ENG102460-ENG20421,MOST Notifications-Target Adress 3,00 00,
    ENG107869-ENG102318,NW_MOST Addressing-diag inst-id,00,
    ENG107869-ENG101908,NW_MOST Addressing-groupadress,03 00,
    ENG107869-ENG101657,NW_MOST Addressing-logical adress,00 00,
    ENG107869-ENG99161,NW_MOST Addressing-vehicle inst-id,00,
    ENG107870-ENG100752,NW_MOST net mngmt status-Configuration_NW_MOST Networkmanagment.Status,not OK,
    ENG107870-ENG99305,NW_MOST net mngmt status-MMI_State_NW_MOST Networkmanagment.Status,MMI_Off,
    ENG107870-ENG103488,NW_MOST net mngmt status-ShutDownState_NW_MOST Networkmanagment.Status,normal operation,
    ENG107870-ENG104176,NW_MOST net mngmt status-Systemstate_NW_MOST Networkmanagment.Status,normal operation,
    ENG107948,OUT_Alternator_reference_voltage_value,10.6, V
    ENG107949,OUT_GW_Aging_counter_DIAG_01_message,7,
    ENG102605,outside_temperature,24.5, °C
    ENG111625-MAS00106,Pause recommendation-Year,2000,
    ENG111625-MAS00107,Pause recommendation-Month,0,
    ENG111625-MAS00108,Pause recommendation-Day,0,
    ENG111625-MAS00109,Pause recommendation-Hours,0,
    ENG111625-MAS00110,Pause recommendation-Minutes,0,
    ENG111625-ENG20549,Pause recommendation-Deaktiviert durch EEPROM-Wert,No,
    ENG111625-ENG20548,Pause recommendation-Deaktiviert durch falschen Datensatz,Yes,
    ENG111625-ENG113361,Pause recommendation-PE_Art_der_Meldung,Initializing,
    ENG111625-ENG113357,Pause recommendation-PE_Einstellung,active,
    ENG111625-ENG113359,Pause recommendation-PE_Fehlercode,not installed,
    ENG111625-ENG113362,Pause recommendation-PE_Index_HFC_TP,1.000,
    ENG111625-ENG113358,Pause recommendation-PE_Stufe,0,
    ENG113399-ENG113364,PE_Version-DS_Version,.,
    ENG113399-ENG109174,PE_Version-SW_VERSION,5.1,
    ENG107686-IDE00317,Reset date for counter: sporadic loop breaks-Date,00.00.2000,
    ENG27103-ENG30346,RTM-Anzahl DataIDs,00 00,
    ENG27103-ENG30614,RTM-ClientID #1,00 00,
    ENG27103-ENG30728,RTM-DataID #1,00 00,
    ENG27103-ENG30729,RTM-DataID #2,00 00,
    ENG27103-ENG30730,RTM-DataID #3,00 00,
    ENG27103-ENG31896,RTM-Laenge Payload DataID #1,0,
    ENG27103-ENG31897,RTM-Laenge Payload DataID #2,0,
    ENG27103-ENG31898,RTM-Laenge Payload DataID #3,0,
    ENG27103-ENG32206,RTM-Obdc Major-Version,,
    ENG27103-ENG32207,RTM-Obdc Minor-Version,,
    ENG27103-ENG32208,RTM-Obdc Sub-Version,,
    ENG27103-ENG33299,RTM-Version ClientID #1,00 00,
    ENG125408,SK2_AnpassungStatus,1,
    ENG122798-ENG103971,Sk2_Version-Patch,3,
    ENG122798-ENG98889,Sk2_Version-Release,2,
    ENG27171-ENG122591,SW-Version der Nebenfunktion-software_version_rwb,,
    ENG110089,Warm-Up-Cycle Counter (zVZ),0,
    Elapsed Time: 00:40
    adpmap-19-4S0-907-468-C*
    ;Saturday,10,August,2019,09:28:04:01617
    IDE00002-Transport mode,not active ,1
    IDE00859-Counter of sporadic MOST-ring disruptions,0 ,3
    IDE00860-Timer of sporadic MOST-ring disruptions,15000 ,3
    IDE01211-Static current measuring mode,not active ,1
    IDE01457-Energy management deactivation stage,- ,1
    IDE01847-Auxiliary heater activation restriction request-,- ,2
    IDE01847-ENG100234-Auxiliary heater activation restriction request-park_heater_target_time,not active ,2
    IDE01862-Switch-over LIN flash mode,normal ,1
    IDE01863-MOST light performance,Decrease 0 dB ,1
    IDE02200-Component protection showroom mode,not active ,1
    IDE03256-IDE00010-Battery adaptation-Serial number,290318I088 ,12
    IDE03256-MAS03159-Battery adaptation-Manufacturer,JCB ,12
    IDE03256-MAS04490-Battery adaptation-Size,92 Ah ,12
    IDE03903-Production process data 1,00 00 00 00 ,4
    IDE03904-Production process data 2,00 00 00 00 ,4
    IDE03905-Production process data 3,00 00 00 00 ,4
    IDE04159-Deactivation of start-stop function,OFF ,1
    IDE06417-IDE00010-Battery adaptation 2-Serial number,---------- ,12
    IDE06417-MAS03159-Battery adaptation 2-Manufacturer,Unknown ,12
    IDE06417-MAS04490-Battery adaptation 2-Size,Unknown ,12
    IDE06425-Roller test bench mode: functional,0 ,1
    IDE06748-Pause recommendation,active ,1
    IDE06753-ENG152429-Efficiency program display-Climate control,Yes ,4
    IDE06753-ENG152461-Efficiency program display-Fahrstufe D verwenden,Yes ,4
    IDE06753-ENG152460-Efficiency program display-Gaspedal im Stand nicht betätigen,Yes ,4
    IDE06753-ENG152482-Efficiency program display-Klima Ein Fenster schliessen,Yes ,4
    IDE06753-ENG152484-Efficiency program display-Klima Ein Fenster und Schiebedach,Yes ,4
    IDE06753-ENG152483-Efficiency program display-Klima Ein Schiebedach schliessen,Yes ,4
    IDE06753-ENG152485-Efficiency program display-Klima Ein Verdeck offen,Yes ,4
    IDE06753-ENG152432-Efficiency program display-Left heated seat,Yes ,4
    IDE06753-ENG152434-Efficiency program display-Left seat ventilation,Yes ,4
    IDE06753-ENG152478-Efficiency program display-LuftWD Fenster u Schiebedachsc,Yes ,4
    IDE06753-ENG152476-Efficiency program display-LuftWD Fensterschliessen,Yes ,4
    IDE06753-ENG152477-Efficiency program display-LuftWD Schiebedachschliessen,Yes ,4
    IDE06753-ENG152437-Efficiency program display-Mirror heater,Yes ,4
    IDE06753-ENG152431-Efficiency program display-Motorbremse,Yes ,4
    IDE06753-ENG152458-Efficiency program display-Motorstart ohne Gaspedal,Yes ,4
    IDE06753-ENG152459-Efficiency program display-Motorwarmlauf vermeiden,Yes ,4
    IDE06753-ENG152472-Efficiency program display-Nebel_Scheinwerfer,Yes ,4
    IDE06753-ENG152473-Efficiency program display-Nebel_Schlussleuchte,Yes ,4
    IDE06753-ENG152436-Efficiency program display-Parking heater,Yes ,4
    IDE06753-ENG152427-Efficiency program display-Rear window defogger,Yes ,4
    IDE06753-ENG152433-Efficiency program display-Right heated seat,Yes ,4
    IDE06753-ENG152435-Efficiency program display-Right seat ventilation,Yes ,4
    IDE06753-ENG152479-Efficiency program display-Schaltanzeige beachten,Yes ,4
    IDE06753-ENG152475-Efficiency program display-Sitzheizung_Sitzlueftung_im_Fond,Yes ,4
    IDE06753-ENG152474-Efficiency program display-Standheizung_Verbrauch,Yes ,4
    IDE06753-ENG152481-Efficiency program display-Start-Stopp einschalten,Yes ,4
    IDE06753-ENG152480-Efficiency program display-Start-Stopp nutzen,Yes ,4
    IDE06753-ENG152430-Efficiency program display-Steering wheel heater,Yes ,4
    IDE06753-ENG152426-Efficiency program display-Windshield defogger,Yes ,4
    IDE08528-MAS07123-Service-key: extended settings-Distance for activation,50 km,3
    IDE08528-MAS07124-Service-key: extended settings-Lower sp
    * The above adaptation channel map attempt failed to continue and is not complete.
    drpeter
  6. Likes Uwe liked this post
  7. #4
    16.4905° S, 151.7375° W
    More maps
    Address - [14]
    blockmap-14-4S0-907-376-E
    ;SW:4S0-907-376-E   HW:4S0-907-376-C ---  Susp. Elect.
    ;Component:DAEMPFUNGS-SG H06 0065, Coding:
    ;EV_AudiMagneRide,003007,EV_AudiMagneRide_003.rod
    ;Saturday,10,August,2019,09:50:10:30091
    ;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
    ;VCID: 3C223E9826ECFF57D61-8068
    IDE00019,Voltage terminal 30,12.5, V
    IDE00102-MAS05627,Control Module temperature-Activation front axle,30, °C
    IDE00102-MAS05628,Control Module temperature-Activation rear axle,30, °C
    IDE00322,Status of basic setting,not active,
    IDE00323,Security Access: Number of invalid keys,0,
    IDE00767-MAS01478,No. of unscheduled ECU resets-Insuff. voltage,118,
    IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,0,
    IDE00773,Terminal 15 status via CAN,Terminal 15 on,
    IDE03055-MAS00816,Currently set shock absorber code-normal,active,
    IDE03055-MAS01439,Currently set shock absorber code-reduced,not active,
    IDE03055-MAS05624,Currently set shock absorber code-Constant current,not active,
    IDE03055-MAS05625,Currently set shock absorber code-without current,not active,
    IDE03055-MAS05626,Currently set shock absorber code-Damping test,not active,
    IDE04434,Damping adjustment indicator lamp,OFF,
    IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
    IDE04805-MAS05375,Driving profile selection-Driving profile,performed,
    IDE04805-MAS05629,Driving profile selection-Driving profile: specified value,2,
    IDE04805-MAS05630,Driving profile selection-Driving profile: actual value,2,
    IDE04805-MAS05631,Driving profile selection-System status,Available,
    IDE04805-MAS13138,Driving profile selection-Driving profile: actual value in the RAM,2,
    IDE05437,Outside air temperature via CAN,24.5, °C
    IDE07141-MAS01853,Wiring resistance-Left front,0.24, Ohm
    IDE07141-MAS01854,Wiring resistance-Right front,0.24, Ohm
    IDE07141-MAS01855,Wiring resistance-Left rear,0.26, Ohm
    IDE07141-MAS01856,Wiring resistance-Right rear,0.16, Ohm
    IDE07142,Time since terminal 15 off,8384, s
    IDE07143-MAS03096,Vehicle level sensor: supply voltage-Voltage 1,5.0, V
    IDE07143-MAS03097,Vehicle level sensor: supply voltage-Voltage 2,5.0, V
    IDE07144,ESP automatic engagement,not activated,
    IDE07146-MAS01853,Dampening adjustment valve: resistance-Left front,1.56, Ohm
    IDE07146-MAS01854,Dampening adjustment valve: resistance-Right front,1.54, Ohm
    IDE07146-MAS01855,Dampening adjustment valve: resistance-Left rear,1.58, Ohm
    IDE07146-MAS01856,Dampening adjustment valve: resistance-Right rear,1.48, Ohm
    IDE07147-MAS01853,Dampening adjustment: current Highside-Left front,24, mA
    IDE07147-MAS01854,Dampening adjustment: current Highside-Right front,27, mA
    IDE07147-MAS01855,Dampening adjustment: current Highside-Left rear,27, mA
    IDE07147-MAS01856,Dampening adjustment: current Highside-Right rear,22, mA
    IDE07148-MAS01853,Dampening adjustment valve: current Lowside-Left front,22, mA
    IDE07148-MAS01854,Dampening adjustment valve: current Lowside-Right front,19, mA
    IDE07148-MAS01855,Dampening adjustment valve: current Lowside-Left rear,30, mA
    IDE07148-MAS01856,Dampening adjustment valve: current Lowside-Right rear,22, mA
    IDE07149-MAS01853,Vehicle level sensor: frequency-Left front,790, Hz
    IDE07149-MAS01854,Vehicle level sensor: frequency-Right front,800, Hz
    IDE07149-MAS01855,Vehicle level sensor: frequency-Left rear,810, Hz
    IDE07149-MAS01856,Vehicle level sensor: frequency-Right rear,800, Hz
    IDE07150-MAS01853,Dampening adjustment valve: temperature-Left front,24, °C
    IDE07150-MAS01854,Dampening adjustment valve: temperature-Right front,24, °C
    IDE07150-MAS01855,Dampening adjustment valve: temperature-Left rear,25, °C
    IDE07150-MAS01856,Dampening adjustment valve: temperature-Right rear,24, °C
    IDE07150-MAS05618,Dampening adjustment valve: temperature-Front left: calculated,39, °C
    IDE07150-MAS05619,Dampening adjustment valve: temperature-Front right: calculated,39, °C
    IDE07150-MAS05620,Dampening adjustment valve: temperature-Rear left: calculated,49, °C
    IDE07150-MAS05621,Dampening adjustment valve: temperature-Rear right: calculated,49, °C
    IDE07151-MAS01853,Vehicle level sensor: raw value-Left front,47.6, %
    IDE07151-MAS01854,Vehicle level sensor: raw value-Right front,46.4, %
    IDE07151-MAS01855,Vehicle level sensor: raw value-Left rear,48.0, %
    IDE07151-MAS01856,Vehicle level sensor: raw value-Right rear,48.8, %
    IDE07152,Fall-back level,00 00 00 00,
    IDE07153,End-of-line Status,0F,
    IDE07154,ESP status,0,
    IDE07162,Dampening adjustment valve: Temperature at terminal 15 on,24, °C
    IDE07177-MAS01632,Status Output DTM damper front left-Status,not active,
    IDE07177-MAS05584,Status Output DTM damper front left-Result,Unknown status,
    IDE07178-MAS01632,Status Output DTM damper front right-Status,not active,
    IDE07178-MAS05584,Status Output DTM damper front right-Result,Unknown status,
    IDE07179-MAS01632,Status Output DTM damper rear left-Status,not active,
    IDE07179-MAS05584,Status Output DTM damper rear left-Result,Unknown status,
    IDE07180-MAS01632,Status Output DTM damper rear right-Status,not active,
    IDE07180-MAS05584,Status Output DTM damper rear right-Result,Unknown status,
    IDE07187-MAS01853,Level control system sensor-Left front,361, mm
    IDE07187-MAS01854,Level control system sensor-Right front,364, mm
    IDE07187-MAS01855,Level control system sensor-Left rear,370, mm
    IDE07187-MAS01856,Level control system sensor-Right rear,374, mm
    IDE07187-MAS05610,Level control system sensor-Calibration,calibrated,
    IDE08127-MAS01853,Vehicle level sensor: offset-Left front,2.4, %
    IDE08127-MAS01854,Vehicle level sensor: offset-Right front,2.4, %
    IDE08127-MAS01855,Vehicle level sensor: offset-Left rear,5.6, %
    IDE08127-MAS01856,Vehicle level sensor: offset-Right rear,3.6, %
    IDE11646,Front axle lifting system: status,depth level,
    Elapsed Time: 00:04
    adpmap-14-4S0-907-376-E
    ;Saturday,10,August,2019,09:50:15:30091
    IDE00820-ENG119636-Activating and deactivating all development messages-DEV_Unit_0103,not activated ,4
    IDE00820-ENG119637-Activating and deactivating all development messages-DEV_Unit_0104,not activated ,4
    IDE00820-ENG110578-Activating and deactivating all development messages-S_100,not activated ,4
    IDE00820-ENG110579-Activating and deactivating all development messages-S_101,not activated ,4
    IDE00820-ENG110580-Activating and deactivating all development messages-S_102,not activated ,4
    IDE00820-ENG119638-Activating and deactivating all development messages-Set_internal_fault_code,00 00 00 ,4
    IDE00820-ENG99057-Activating and deactivating all development messages-XCP,Development ,4
    IDE04891-IDE02001-Adapting high values-Body height left front wheel house edge,367 mm,8
    IDE04891-IDE02002-Adapting high values-Body height right front wheel house edge,368 mm,8
    IDE04891-IDE02003-Adapting high values-Body height left rear wheel house edge,374 mm,8
    IDE04891-IDE02004-Adapting high values-Body height right rear wheel house edge,375 mm,8
    ENG119639-Enable Constant current on all dampers,not activated ,1
    ENG119640-Enable Damper test mode,not activated ,1
    Elapsed Time: 00:01
    Address - [5F]
    blockmap-5F-4S0-035-025-F
    ;SW:4S0-035-025-F   HW:4S0-035-025-E ---  Information Electr.
    ;Component:MU-H-LNS-US   055 1390, Coding:012784020000000013220002041A00332F0000E0007000047E
    ;EV_MUHig6C8Gen2HBAS,001182,EV_MUHig6C8Gen2HBAS.rod
    ;Saturday,10,August,2019,09:50:35:30091
    ;VCID: 2C020ED8D68C6FD7461-8078
    IDE00020,Terminal 15 status,On,
    IDE00021,Engine speed,0.00, /min
    IDE00075,Vehicle speed,0.00, km/h
    IDE00655-MAS01424,Temperature of processor circuit board-max.value,63, °C
    IDE00655-MAS01425,Temperature of processor circuit board-min.value,8, °C
    IDE00655-MAS02238,Temperature of processor circuit board-Current,52, °C
    IDE00668-MAS03231,Microphone current consumption-Microphone 1,5.40, mA
    IDE00668-MAS03232,Microphone current consumption-Microphone 2,5.20, mA
    IDE00767,No. of unscheduled ECU resets,0, counts
    IDE00916-MAS01188,Speaker status-Left front bass speaker,Measured value not available,
    IDE00916-MAS01190,Speaker status-Left front treble speaker,Measured value not available,
    IDE00916-MAS01191,Speaker status-Right front bass speaker,Measured value not available,
    IDE00916-MAS01193,Speaker status-Right front treble speaker,Measured value not available,
    IDE00916-MAS01198,Speaker status-Center speaker,Measured value not available,
    IDE00916-MAS01201,Speaker status-Subwoofer speaker,Measured value not available,
    IDE00916-ENG117413,Speaker status-loudspeaker_channel_10,Measured value not available,
    IDE00916-ENG117414,Speaker status-loudspeaker_channel_11,Measured value not available,
    IDE00916-ENG117415,Speaker status-loudspeaker_channel_12,Measured value not available,
    IDE00916-ENG117416,Speaker status-loudspeaker_channel_13,Measured value not available,
    IDE00916-ENG117417,Speaker status-loudspeaker_channel_14,Measured value not available,
    IDE00916-ENG117418,Speaker status-loudspeaker_channel_15,Measured value not available,
    IDE00916-ENG117419,Speaker status-loudspeaker_channel_16,Measured value not available,
    IDE00916-ENG117410,Speaker status-loudspeaker_channel_7,Measured value not available,
    IDE00916-ENG117411,Speaker status-loudspeaker_channel_8,Measured value not available,
    IDE00916-ENG117412,Speaker status-loudspeaker_channel_9,Measured value not available,
    IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,00 00,
    IDE01351,Terminal 75 status,On,
    IDE01442-MAS06123,Pressing a button-Eject button,not activated,
    IDE01712-MAS01779,GPS Position-Length,--------------,
    IDE01712-MAS01780,GPS Position-Width,--------------,
    IDE01713-MAS01632,Status GPS reception-Status,No GPS reception,
    IDE01713-MAS01785,Status GPS reception-Number of visible satellites,16,
    IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,0,
    IDE01715,Status terminal S,On,
    IDE01716,Terminal 50 status,OFF,
    IDE01767-MAS00940,Status of telephone-Antenna diagnostic,OK,
    IDE01767-MAS00941,Status of telephone-Telephone baseplate diagnostic,connected,
    IDE01767-MAS00955,Status of telephone-Handset in handset holder (cradle),not selected,
    IDE01767-MAS01806,Status of telephone-Handset holder (cradle),not connected,
    IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,43, mA
    IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,Electrical OK,
    IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,Electrical OK,
    IDE01768-MAS03991,Status of antenna 1 for radio-Reception level antenna 1,18, dBµV
    IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,38, mA
    IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,Electrical OK,
    IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,Electrical OK,
    IDE01769-MAS04344,Status of antenna 2 for radio-Reception level antenna 2,10, dBµV
    IDE01770-MAS01632,Status of GPS antenna-Status,Electrical OK,
    IDE01770-MAS01808,Status of GPS antenna-Antenna current,255, mA
    IDE01868-MAS00839,Ring break diagnostic result-TV Tuner,Not available,
    IDE01868-MAS00840,Ring break diagnostic result-Media Player: Position 1,Not available,
    IDE01868-MAS00844,Ring break diagnostic result-Radio,Not available,
    IDE01868-MAS00847,Ring break diagnostic result-Digital Sound System Control Module,Not available,
    IDE01868-MAS00849,Ring break diagnostic result-Information electronics control module 1,Not available,
    IDE01868-MAS00850,Ring break diagnostic result-Information electronics control module 2,Not available,
    IDE01868-MAS02840,Ring break diagnostic result-Instrument cluster display,Not available,
    IDE01868-MAS14306,Ring break diagnostic result-Windshield projection head up display control module,Not available,
    IDE01868-ENG117473,Ring break diagnostic result-MOST_Component_10,Not available,
    IDE01868-ENG117474,Ring break diagnostic result-MOST_Component_11,Not available,
    IDE01868-ENG117475,Ring break diagnostic result-MOST_Component_12,Not available,
    IDE01868-ENG117476,Ring break diagnostic result-MOST_Component_13,Not available,
    IDE01868-ENG117477,Ring break diagnostic result-MOST_Component_14,Not available,
    IDE01868-ENG117478,Ring break diagnostic result-MOST_Component_15,Not available,
    IDE01868-ENG117479,Ring break diagnostic result-MOST_Component_16,Not available,
    IDE01868-ENG117480,Ring break diagnostic result-MOST_Component_17,Not available,
    IDE01868-ENG117481,Ring break diagnostic result-MOST_Component_18,Not available,
    IDE01868-ENG117482,Ring break diagnostic result-MOST_Component_19,Not available,
    IDE01868-ENG117483,Ring break diagnostic result-MOST_Component_20,Not available,
    IDE01868-ENG117472,Ring break diagnostic result-MOST_Component_9,Not available,
    IDE01992-ENG16230,Installation list: current installations-ECU present Bit 0,not installed,
    IDE01992-ENG20557,Installation list: current installations-ECU present Bit 0 Main_Unit,installed,
    IDE01992-ENG45410,Installation list: current installations-ECU present Bit 1,not installed,
    IDE01992-ENG20556,Installation list: current installations-ECU present Bit 1 reserved,not installed,
    IDE01992-ENG20933,Installation list: current installations-ECU present Bit 10 SmartControlCarrier2,not installed,
    IDE01992-ENG20932,Installation list: current installations-ECU present Bit 11 WirelessCharger1,not installed,
    IDE01992-ENG20931,Installation list: current installations-ECU present Bit 12 WirelessCharger2,not installed,
    IDE01992-ENG20930,Installation list: current installations-ECU present Bit 13 Multimedia Operating Unit,not installed,
    IDE01992-ENG20929,Installation list: current installations-ECU present Bit 14 Head-up Display,not installed,
    IDE01992-ENG20950,Installation list: current installations-ECU present Bit 15,not installed,
    IDE01992-ENG45396,Installation list: current installations-ECU present Bit 2,not installed,
    IDE01992-ENG20555,Installation list: current installations-ECU present Bit 2 Sound_System,installed,
    IDE01992-ENG45402,Installation list: current installations-ECU present Bit 3,not installed,
    IDE01992-ENG20554,Installation list: current installations-ECU present Bit 3 TV_Tuner,not installed,
    IDE01992-ENG45430,Installation list: current installations-ECU present Bit 4,not installed,
    IDE01992-ENG20553,Installation list: current installations-ECU present Bit 4 DVD_Changer,not installed,
    IDE01992-ENG45377,Installation list: current installations-ECU present Bit 5,not installed,
    IDE01992-ENG20552,Installation list: current installations-ECU present Bit 5 RearSeatEntertainment,not installed,
    IDE01992-ENG21674,Installation list: current installations-ECU present Bit 6,not installed,
    IDE01992-ENG20919,Installation list: current installations-ECU present Bit 6 MOST Kombi-Display,installed,
    IDE01992-ENG16217,Installation list: current installations-ECU present Bit 7,not installed,
    IDE01992-ENG20918,Installation list: current installations-ECU present Bit 7 SmartDisplayCarrier1,not installed,
    IDE01992-ENG20935,Installation list: current installations-ECU present Bit 8 SmartDisplayCarrier2,not installed,
    IDE01992-ENG20934,Installation list: current installations-ECU present Bit 9 SmartControlCarrier1,not installed,
    IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,Electrical OK,
    IDE02067-MAS01808,Antenna for telephone status-Antenna current,255, mA
    IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,180.6, %
    IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,255,
    IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,255,
    IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,255,
    IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,255,
    IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,0, dBµV
    IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,0, dBµV
    IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,0, dBµV
    IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,0, dBµV
    IDE02384-ENG16210,Status of event memory-ECU Dtc Bit 0,OK,
    IDE02384-ENG20563,Status of event memory-ECU Dtc Bit 0 Main_Unit,ERROR,
    IDE02384-ENG20562,Status of event memory-ECU Dtc Bit 1 reserved,OK,
    IDE02384-ENG20924,Status of event memory-ECU Dtc Bit 10 SmartControlCarrier2,OK,
    IDE02384-ENG20923,Status of event memory-ECU Dtc Bit 11 WirelessCharger1,OK,
    IDE02384-ENG20922,Status of event memory-ECU Dtc Bit 12 WirelessCharger2,OK,
    IDE02384-ENG20921,Status of event memory-ECU Dtc Bit 13 Multimedia Operating Unit,OK,
    IDE02384-ENG20920,Status of event memory-ECU Dtc Bit 14 Head-up Display,OK,
    IDE02384-ENG20949,Status of event memory-ECU Dtc Bit 15,OK,
    IDE02384-ENG20561,Status of event memory-ECU Dtc Bit 2 Sound_System,OK,
    IDE02384-ENG20560,Status of event memory-ECU Dtc Bit 3 TV_Tuner,OK,
    IDE02384-ENG20559,Status of event memory-ECU Dtc Bit 4 DVD_Changer,OK,
    IDE02384-ENG20558,Status of event memory-ECU Dtc Bit 5 Rear_Seat_Entertainment,OK,
    IDE02384-ENG20945,Status of event memory-ECU Dtc Bit 6 MOST Kombi-Display,OK,
    IDE02384-ENG20944,Status of event memory-ECU Dtc Bit 7 SmartDisplayCarrier1,OK,
    IDE02384-ENG20926,Status of event memory-ECU Dtc Bit 8 SmartDisplayCarrier2,OK,
    IDE02384-ENG20925,Status of event memory-ECU Dtc Bit 9 SmartControlCarrier1,OK,
    IDE02452-IDE02451,Satellite radio tuner status-Satellite radio antenna status,Electrical OK,
    IDE02452-IDE02453,Satellite radio tuner status-Channel selection for satellite radio,1,
    IDE02452-MAS01765,Satellite radio tuner status-Audio Signal,Available,
    IDE02452-MAS01808,Satellite radio tuner status-Antenna current,118, mA
    IDE02452-MAS02573,Satellite radio tuner status-Reception quality,good_signal,
    IDE02452-MAS13343,Satellite radio tuner status-Satellite radio tuner: pre-activation status,05,
    IDE02452-MAS13344,Satellite radio tuner status-Satellite radio tuner: pre-activation value,05,
    IDE02486,Data logger triggering,not active,
    IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
    IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth available,
    IDE02766,Malfunction status,FF FB,
    IDE03150-ENG16256,Readiness for bus sleep mode-Sleep Bit 0,Sleep mode,
    IDE03150-ENG20569,Readiness for bus sleep mode-Sleep Bit 0 Main_Unit,End busstat,
    IDE03150-ENG45492,Readiness for bus sleep mode-Sleep Bit 1,Sleep mode,
    IDE03150-ENG20568,Readiness for bus sleep mode-Sleep Bit 1 reserved,Sleep mode,
    IDE03150-ENG20941,Readiness for bus sleep mode-Sleep Bit 10 SmartControlCarrier2,Sleep mode,
    IDE03150-ENG20940,Readiness for bus sleep mode-Sleep Bit 11 WirelessCharger1,Sleep mode,
    IDE03150-ENG20939,Readiness for bus sleep mode-Sleep Bit 12 WirelessCharger2,Sleep mode,
    IDE03150-ENG20938,Readiness for bus sleep mode-Sleep Bit 13 Bedienteil vorne,Sleep mode,
    IDE03150-ENG20937,Readiness for bus sleep mode-Sleep Bit 14 Head-up Display,Sleep mode,
    IDE03150-ENG20936,Readiness for bus sleep mode-Sleep Bit 15,Sleep mode,
    IDE03150-ENG45491,Readiness for bus sleep mode-Sleep Bit 2,Sleep mode,
    IDE03150-ENG20567,Readiness for bus sleep mode-Sleep Bit 2 Sound_System,End busstat,
    IDE03150-ENG45490,Readiness for bus sleep mode-Sleep Bit 3,Sleep mode,
    IDE03150-ENG20566,Readiness for bus sleep mode-Sleep Bit 3 TV_Tuner,Sleep mode,
    IDE03150-ENG45489,Readiness for bus sleep mode-Sleep Bit 4,Sleep mode,
    IDE03150-ENG20565,Readiness for bus sleep mode-Sleep Bit 4 DVD_Changer,Sleep mode,
    IDE03150-ENG45488,Readiness for bus sleep mode-Sleep Bit 5,Sleep mode,
    IDE03150-ENG20564,Readiness for bus sleep mode-Sleep Bit 5 RearSeatEntertainment,Sleep mode,
    IDE03150-ENG21675,Readiness for bus sleep mode-Sleep Bit 6,Sleep mode,
    IDE03150-ENG20928,Readiness for bus sleep mode-Sleep Bit 6 MOST Kombi-Display,End busstat,
    IDE03150-ENG16255,Readiness for bus sleep mode-Sleep Bit 7,Sleep mode,
    IDE03150-ENG20927,Readiness for bus sleep mode-Sleep Bit 7 SmartDisplayCarrier1,Sleep mode,
    IDE03150-ENG20943,Readiness for bus sleep mode-Sleep Bit 8 SmartDisplayCarrier2,Sleep mode,
    IDE03150-ENG20942,Readiness for bus sleep mode-Sleep Bit 9 SmartControlCarrier1,Sleep mode,
    IDE03477-MAS00106,GPS time-Year,2127,
    IDE03477-MAS00107,GPS time-Month,15,
    IDE03477-MAS00108,GPS time-Day,0,
    IDE03477-MAS00109,GPS time-Hours,31,
    IDE03477-MAS00110,GPS time-Minutes,63,
    IDE03477-MAS00111,GPS time-Seconds,63,
    IDE03477-MAS01632,GPS time-Status,invalid,
    IDE03610-MAS02573,Voice operation: last detected command-Reception quality,255, %
    IDE03610-MAS03874,Voice operation: last detected command-last detected command,0,
    IDE03610-MAS03875,Voice operation: last detected command-Reliability,255, %
    IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,5F,
    IDE03880-MAS03425,MOST address-Physical address,04 00,
    IDE04312-MAS00109,System run time-Hours,0, H
    IDE04312-MAS00110,System run time-Minutes,34, min
    IDE04317-MAS00108,Total system run time-Day,1, d
    IDE04317-MAS00109,Total system run time-Hours,5, H
    IDE04317-MAS00110,Total system run time-Minutes,10, min
    IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Available,
    IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,valid,
    IDE04329-IDE06260,Status of all SWaP functions-ID number,00 06 09 00,
    IDE04329-MAS01340,Status of all SWaP functions-Functions,Available,
    IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
    IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition met,
    IDE04329-MAS05616,Status of all SWaP functions-Cancellation,No,
    IDE04329-MAS05617,Status of all SWaP functions-Authentication,valid,
    IDE04334-MAS02643,Public key for SWaP function-Key,9A 49 9B 04 8B AE BF AC 83 3F DE 81 BA 80 30 93 05 B6 6F ED 54 59 C3 8F 60 F6 10 A9 AA 5A 19 10 05 17 05 8F EA 49 D3 75 E3 F9 E1 54 4E 17 EE C9 C3 C1 DD 7D 30 16 DE B1 55 45 FD 9E 18 00 51 22 D6 A1 33 10 95 C0 DD CF 43 A1 C2 FE C0 BC AA 1C FE 48 49 25 89 9E DD 71 B0 D4 08 CF 16 BF 10 E2 E1 BC 70 A3 52 F2 E6 54 0B 60 05 5A A7 52 EC 4A 83 65 F7 68 19 66 F4 D5 46 C7 38 B1 6B 5A 1F 13 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
    IDE04343-ENG20542,Bus identification-Bus Identifier,Busmaster,
    IDE04484,Regional codes,Not available,
    IDE04484,Regional codes,FE FF,
    IDE04484-MAS01632,Regional codes-Status,not active,
    IDE04484-MAS03230,Regional codes-Optical drive,0,
    IDE04541-MAS03621,Status of active media source at output 1-Video codec,--------------------,
    IDE04541-MAS03622,Status of active media source at output 1-Horizontal video resolution,65535,
    IDE04541-MAS03623,Status of active media source at output 1-Vertical video resolution,65535,
    IDE04541-MAS03778,Status of active media source at output 1-Active media source,Connection for external audio sources 2 (AUX-IN),
    IDE04541-MAS03783,Status of active media source at output 1-Video Bitrate,65535, kbps
    IDE04541-MAS03784,Status of active media source at output 1-Audio Bitrate,Not available,
    IDE04541-MAS03785,Status of active media source at output 1-Digital rights management (DRM),Not available,
    IDE04541-MAS03786,Status of active media source at output 1-Audio Codec,--------------------,
    IDE04541-MAS03787,Status of active media source at output 1-Image format,--------------------,
    IDE04541-MAS03788,Status of active media source at output 1-Horizontal image resolution,65535,
    IDE04541-MAS03789,Status of active media source at output 1-Vertical image resolution,65535,
    IDE04541-MAS03793,Status of active media source at output 1-Color depth,65535, bit
    IDE04542-MAS03621,Status of active media source at output 2-Video codec,--------------------,
    IDE04542-MAS03622,Status of active media source at output 2-Horizontal video resolution,65535,
    IDE04542-MAS03623,Status of active media source at output 2-Vertical video resolution,65535,
    IDE04542-MAS03778,Status of active media source at output 2-Active media source,Not available,
    IDE04542-MAS03783,Status of active media source at output 2-Video Bitrate,65535, kbps
    IDE04542-MAS03784,Status of active media source at output 2-Audio Bitrate,Not available,
    IDE04542-MAS03785,Status of active media source at output 2-Digital rights management (DRM),Not available,
    IDE04542-MAS03786,Status of active media source at output 2-Audio Codec,--------------------,
    IDE04542-MAS03787,Status of active media source at output 2-Image format,--------------------,
    IDE04542-MAS03788,Status of active media source at output 2-Horizontal image resolution,65535,
    IDE04542-MAS03789,Status of active media source at output 2-Vertical image resolution,65535,
    IDE04542-MAS03793,Status of active media source at output 2-Color depth,65535, bit
    IDE04543-MAS00866,Authorization level for protection of minors-system origin,0,
    IDE04543-MAS03778,Authorization level for protection of minors-Active media source,255,
    IDE04544,Media type in optical drive,Not available,
    IDE04545-IDE01588,Vehicle state-Driving direction,Measured value not available,
    IDE04545-IDE01714,Vehicle state-Status reverse gear,not selected,
    IDE04545-IDE01766,Vehicle state-Distance impulses,0,
    IDE04545-IDE03684,Vehicle state-Vehicle stopped,Yes,
    IDE04546-IDE00301,Navigation calibration-Distance,0.000, mm
    IDE04546-MAS03647,Navigation calibration-Calibration condition,complete,
    IDE04547,Traffic information,OFF,
    IDE04605-MAS01779,Navigation: Corrected position-Length,082°20'29,2"W ,
    IDE04605-MAS01780,Navigation: Corrected position-Width,034°48'48,4"N ,
    IDE04607-IDE03661,Angle of turn sensor for navigation-Rotation rate,-0.6, °/s
    IDE04607-ENG117452,Angle of turn sensor for navigation-gyro_sensor_x_acceleration,20.08, m/s²
    IDE04607-ENG117453,Angle of turn sensor for navigation-gyro_sensor_y_acceleration,20.08, m/s²
    IDE04607-ENG117454,Angle of turn sensor for navigation-gyro_sensor_z_acceleration,20.08, m/s²
    IDE04640,Over-temperature protection for amplifier,no restriction,
    IDE04641,Speed-dependent volume adjustment,0.0, dB
    IDE04649-MAS01968,Activation for housing fan-Fan,OFF,
    IDE04649-MAS06857,Activation for housing fan-Speed,0, /min
    IDE04749-ENG117444,Mute-am_fm_tuner,No,
    IDE04749-ENG117443,Mute-audiomanager,Mute,
    IDE04749-ENG117447,Mute-component_protection,No,
    IDE04749-ENG117445,Mute-dab_sdars_tuner,No,
    IDE04749-ENG117446,Mute-drm_hd_tuner,No,
    IDE04749-ENG113342,Mute-Hardware,No,
    IDE04750-MAS03876,SIM cards-active SIM card,Not available,
    IDE04750-MAS03877,SIM cards-SIM ID,---------------,
    IDE04750-MAS03878,SIM cards-SIM IMSI,---------------,
    IDE04750-MAS13882,SIM cards-SIM card in main unit: status,Not available,
    IDE04750-MAS13883,SIM cards-SIM card in handset1 for telephone: status,Not available,
    IDE04750-MAS13884,SIM cards-SIM card in handset 2 for telephone: status,Not available,
    IDE04750-MAS13885,SIM cards-SIM card in mobile telephone: status,Not available,
    IDE04767-MAS01240,Update software via medium-Programming status,not active,
    IDE04767-MAS02111,Update software via medium-Data consistency,valid,
    IDE04767-MAS02112,Update software via medium-Programmability,no request,
    IDE04768,Bluetooth device address,B8 9F 09 42 FA 98,
    IDE05040-MAS01632,Video input status-Status,Not available,
    IDE05040-MAS04390,Video input status-Active source,Not available,
    IDE05277-MAS04210,Available changes in regional codes-Available changes DVD,4,
    IDE05277-MAS04211,Available changes in regional codes-Available changes Blue-Ray,4,
    IDE05277-MAS04285,Available changes in regional codes-Regional codes DVD,1,
    IDE05277-MAS04286,Available changes in regional codes-Regional codes Blue-Ray,1,
    IDE05430,Telephone serial number,354128067436163,
    IDE05432-IDE07365,Mechanics of display unit 1 for multimedia system-Limit switch for display open,not activated,
    IDE05432-IDE07366,Mechanics of display unit 1 for multimedia system-Limit switch for display close,not activated,
    IDE05432-MAS01458,Mechanics of display unit 1 for multimedia system-Operating condition,not defined,
    IDE05595-MAS00106,Last time GPS without satellite reception-Year,2127,
    IDE05595-MAS00107,Last time GPS without satellite reception-Month,15,
    IDE05595-MAS00108,Last time GPS without satellite reception-Day,0,
    IDE05595-MAS00109,Last time GPS without satellite reception-Hours,31,
    IDE05595-MAS00110,Last time GPS without satellite reception-Minutes,63,
    IDE05595-MAS00111,Last time GPS without satellite reception-Seconds,63,
    IDE05596-MAS00106,Last time GPS position outside map-Year,2019,
    IDE05596-MAS00107,Last time GPS position outside map-Month,6,
    IDE05596-MAS00108,Last time GPS position outside map-Day,24,
    IDE05596-MAS00109,Last time GPS position outside map-Hours,18,
    IDE05596-MAS00110,Last time GPS position outside map-Minutes,23,
    IDE05596-MAS00111,Last time GPS position outside map-Seconds,53,
    IDE05597-IDE03615,Bluetooth: Paired device 1-Version,--
    IDE05597-IDE04768,Bluetooth: Paired device 1-Bluetooth device address,00 00 00 00 00 00,
    IDE05597-MAS01483,Bluetooth: Paired device 1-Softwareversion,--
    IDE05597-MAS02159,Bluetooth: Paired device 1-Remote SIM Access Profile (rSAP),00 00,
    IDE05597-MAS02160,Bluetooth: Paired device 1-Hands free profile (HFP),00 00,
    IDE05597-MAS03159,Bluetooth: Paired device 1-Manufacturer,--
    IDE05597-MAS04326,Bluetooth: Paired device 1-Device name,--
    IDE05597-ENG117431,Bluetooth: Paired device 1-A2DP,00 00,
    IDE05597-ENG117440,Bluetooth: Paired device 1-ACTIVESYNCML,00 00,
    IDE05597-ENG105233,Bluetooth: Paired device 1-AT,00 00,
    IDE05597-ENG117432,Bluetooth: Paired device 1-AVRCP,00 00,
    IDE05597-ENG117434,Bluetooth: Paired device 1-DUN,00 00,
    IDE05597-ENG106692,Bluetooth: Paired device 1-FTP,00 00,
    IDE05597-ENG117435,Bluetooth: Paired device 1-HIDP,00 00,
    IDE05597-ENG117429,Bluetooth: Paired device 1-HSP,00 00,
    IDE05597-ENG117437,Bluetooth: Paired device 1-IRMC,00 00,
    IDE05597-ENG101499,Bluetooth: Paired device 1-map,00 00,
    IDE05597-ENG117436,Bluetooth: Paired device 1-OBEX,00 00,
    IDE05597-ENG117439,Bluetooth: Paired device 1-OPP,00 00,
    IDE05597-ENG117433,Bluetooth: Paired device 1-PAN,00 00,
    IDE05597-ENG108174,Bluetooth: Paired device 1-PBAP,00 00,
    IDE05597-ENG117427,Bluetooth: Paired device 1-SDAP,00 00,
    IDE05597-ENG117428,Bluetooth: Paired device 1-SPP,00 00,
    IDE05597-ENG117438,Bluetooth: Paired device 1-SYNCML,00 00,
    IDE05598-IDE03615,Bluetooth: Paired device 2-Version,--
    IDE05598-IDE04768,Bluetooth: Paired device 2-Bluetooth device address,00 00 00 00 00 00,
    IDE05598-MAS01483,Bluetooth: Paired device 2-Softwareversion,--
    IDE05598-MAS02159,Bluetooth: Paired device 2-Remote SIM Access Profile (rSAP),00 00,
    IDE05598-MAS02160,Bluetooth: Paired device 2-Hands free profile (HFP),00 00,
    IDE05598-MAS03159,Bluetooth: Paired device 2-Manufacturer,--
    IDE05598-MAS04326,Bluetooth: Paired device 2-Device name,--
    IDE05598-ENG117431,Bluetooth: Paired device 2-A2DP,00 00,
    IDE05598-ENG117440,Bluetooth: Paired device 2-ACTIVESYNCML,00 00,
    IDE05598-ENG105233,Bluetooth: Paired device 2-AT,00 00,
    IDE05598-ENG117432,Bluetooth: Paired device 2-AVRCP,00 00,
    IDE05598-ENG117434,Bluetooth: Paired device 2-DUN,00 00,
    IDE05598-ENG106692,Bluetooth: Paired device 2-FTP,00 00,
    IDE05598-ENG117435,Bluetooth: Paired device 2-HIDP,00 00,
    IDE05598-ENG117429,Bluetooth: Paired device 2-HSP,00 00,
    IDE05598-ENG117437,Bluetooth: Paired device 2-IRMC,00 00,
    IDE05598-ENG101499,Bluetooth: Paired device 2-map,00 00,
    IDE05598-ENG117436,Bluetooth: Paired device 2-OBEX,00 00,
    IDE05598-ENG117439,Bluetooth: Paired device 2-OPP,00 00,
    IDE05598-ENG117433,Bluetooth: Paired device 2-PAN,00 00,
    IDE05598-ENG108174,Bluetooth: Paired device 2-PBAP,00 00,
    IDE05598-ENG117427,Bluetooth: Paired device 2-SDAP,00 00,
    IDE05598-ENG117428,Bluetooth: Paired device 2-SPP,00 00,
    IDE05598-ENG117438,Bluetooth: Paired device 2-SYNCML,00 00,
    IDE05599-IDE03615,Bluetooth: Paired device 3-Version,--
    IDE05599-IDE04768,Bluetooth: Paired device 3-Bluetooth device address,00 00 00 00 00 00,
    IDE05599-MAS01483,Bluetooth: Paired device 3-Softwareversion,--
    IDE05599-MAS02159,Bluetooth: Paired device 3-Remote SIM Access Profile (rSAP),00 00,
    IDE05599-MAS02160,Bluetooth: Paired device 3-Hands free profile (HFP),00 00,
    IDE05599-MAS03159,Bluetooth: Paired device 3-Manufacturer,--
    IDE05599-MAS04326,Bluetooth: Paired device 3-Device name,--
    IDE05599-ENG117431,Bluetooth: Paired device 3-A2DP,00 00,
    IDE05599-ENG117440,Bluetooth: Paired device 3-ACTIVESYNCML,00 00,
    IDE05599-ENG105233,Bluetooth: Paired device 3-AT,00 00,
    IDE05599-ENG117432,Bluetooth: Paired device 3-AVRCP,00 00,
    IDE05599-ENG117434,Bluetooth: Paired device 3-DUN,00 00,
    IDE05599-ENG106692,Bluetooth: Paired device 3-FTP,00 00,
    IDE05599-ENG117435,Bluetooth: Paired device 3-HIDP,00 00,
    IDE05599-ENG117429,Bluetooth: Paired device 3-HSP,00 00,
    IDE05599-ENG117437,Bluetooth: Paired device 3-IRMC,00 00,
    IDE05599-ENG101499,Bluetooth: Paired device 3-map,00 00,
    IDE05599-ENG117436,Bluetooth: Paired device 3-OBEX,00 00,
    IDE05599-ENG117439,Bluetooth: Paired device 3-OPP,00 00,
    IDE05599-ENG117433,Bluetooth: Paired device 3-PAN,00 00,
    IDE05599-ENG108174,Bluetooth: Paired device 3-PBAP,00 00,
    IDE05599-ENG117427,Bluetooth: Paired device 3-SDAP,00 00,
    IDE05599-ENG117428,Bluetooth: Paired device 3-SPP,00 00,
    IDE05599-ENG117438,Bluetooth: Paired device 3-SYNCML,00 00,
    IDE05600-IDE03615,Bluetooth: Paired device 4-Version,--
    IDE05600-IDE04768,Bluetooth: Paired device 4-Bluetooth device address,00 00 00 00 00 00,
    IDE05600-MAS01483,Bluetooth: Paired device 4-Softwareversion,--
    IDE05600-MAS02159,Bluetooth: Paired device 4-Remote SIM Access Profile (rSAP),00 00,
    IDE05600-MAS02160,Bluetooth: Paired device 4-Hands free profile (HFP),00 00,
    IDE05600-MAS03159,Bluetooth: Paired device 4-Manufacturer,--
    IDE05600-MAS04326,Bluetooth: Paired device 4-Device name,--
    IDE05600-ENG117431,Bluetooth: Paired device 4-A2DP,00 00,
    IDE05600-ENG117440,Bluetooth: Paired device 4-ACTIVESYNCML,00 00,
    IDE05600-ENG105233,Bluetooth: Paired device 4-AT,00 00,
    IDE05600-ENG117432,Bluetooth: Paired device 4-AVRCP,00 00,
    IDE05600-ENG117434,Bluetooth: Paired device 4-DUN,00 00,
    IDE05600-ENG106692,Bluetooth: Paired device 4-FTP,00 00,
    IDE05600-ENG117435,Bluetooth: Paired device 4-HIDP,00 00,
    IDE05600-ENG117429,Bluetooth: Paired device 4-HSP,00 00,
    IDE05600-ENG117437,Bluetooth: Paired device 4-IRMC,00 00,
    IDE05600-ENG101499,Bluetooth: Paired device 4-map,00 00,
    IDE05600-ENG117436,Bluetooth: Paired device 4-OBEX,00 00,
    IDE05600-ENG117439,Bluetooth: Paired device 4-OPP,00 00,
    IDE05600-ENG117433,Bluetooth: Paired device 4-PAN,00 00,
    IDE05600-ENG108174,Bluetooth: Paired device 4-PBAP,00 00,
    IDE05600-ENG117427,Bluetooth: Paired device 4-SDAP,00 00,
    IDE05600-ENG117428,Bluetooth: Paired device 4-SPP,00 00,
    IDE05600-ENG117438,Bluetooth: Paired device 4-SYNCML,00 00,
    IDE05601-IDE03615,Bluetooth: Paired device 5-Version,--
    IDE05601-IDE04768,Bluetooth: Paired device 5-Bluetooth device address,00 00 00 00 00 00,
    IDE05601-MAS01483,Bluetooth: Paired device 5-Softwareversion,--
    IDE05601-MAS02159,Bluetooth: Paired device 5-Remote SIM Access Profile (rSAP),00 00,
    IDE05601-MAS02160,Bluetooth: Paired device 5-Hands free profile (HFP),00 00,
    IDE05601-MAS03159,Bluetooth: Paired device 5-Manufacturer,--
    IDE05601-MAS04326,Bluetooth: Paired device 5-Device name,--
    IDE05601-ENG117431,Bluetooth: Paired device 5-A2DP,00 00,
    IDE05601-ENG117440,Bluetooth: Paired device 5-ACTIVESYNCML,00 00,
    IDE05601-ENG105233,Bluetooth: Paired device 5-AT,00 00,
    IDE05601-ENG117432,Bluetooth: Paired device 5-AVRCP,00 00,
    IDE05601-ENG117434,Bluetooth: Paired device 5-DUN,00 00,
    IDE05601-ENG106692,Bluetooth: Paired device 5-FTP,00 00,
    IDE05601-ENG117435,Bluetooth: Paired device 5-HIDP,00 00,
    IDE05601-ENG117429,Bluetooth: Paired device 5-HSP,00 00,
    IDE05601-ENG117437,Bluetooth: Paired device 5-IRMC,00 00,
    IDE05601-ENG101499,Bluetooth: Paired device 5-map,00 00,
    IDE05601-ENG117436,Bluetooth: Paired device 5-OBEX,00 00,
    IDE05601-ENG117439,Bluetooth: Paired device 5-OPP,00 00,
    IDE05601-ENG117433,Bluetooth: Paired device 5-PAN,00 00,
    IDE05601-ENG108174,Bluetooth: Paired device 5-PBAP,00 00,
    IDE05601-ENG117427,Bluetooth: Paired device 5-SDAP,00 00,
    IDE05601-ENG117428,Bluetooth: Paired device 5-SPP,00 00,
    IDE05601-ENG117438,Bluetooth: Paired device 5-SYNCML,00 00,
    IDE05602-MAS01763,Bluetooth: connected device 1-Signal Strength,Not available,
    IDE05602-MAS04326,Bluetooth: connected device 1-Device name,0,
    IDE05603-MAS01763,Bluetooth: connected device 2-Signal Strength,Not available,
    IDE05603-MAS04326,Bluetooth: connected device 2-Device name,0,
    IDE05604-MAS01763,Bluetooth: connected device 3-Signal Strength,Not available,
    IDE05604-MAS04326,Bluetooth: connected device 3-Device name,0,
    IDE05605-MAS01763,Bluetooth: connected device 4-Signal Strength,Not available,
    IDE05605-MAS04326,Bluetooth: connected device 4-Device name,0,
    IDE05606-MAS01763,Bluetooth: connected device 5-Signal Strength,Not available,
    IDE05606-MAS04326,Bluetooth: connected device 5-Device name,0,
    IDE05700-MAS01456,USB connection-Speed,Not available,
    IDE05700-MAS01632,USB connection-Status,Not available,
    IDE05700-MAS03159,USB connection-Manufacturer,FF FF,
    IDE05700-MAS04393,USB connection-USB device class,FF,
    IDE05700-MAS04394,USB connection-Connection status,not connected,
    IDE05700-MAS04436,USB connection-USB device sub-class,FF,
    IDE05700-ENG111957,USB connection-usb_product_id,FF FF,
    IDE05700-ENG111955,USB connection-usb_protocol,FF,
    IDE05704-MAS02646,Digital Transmission Content Protection (DTCP) key-Key type,License key (DTLA),
    IDE05705-MAS01159,Digital Transmission Content Protection (DTCP) device cert-Version number,2,
    IDE05705-MAS01779,Digital Transmission Content Protection (DTCP) device cert-Length,60,
    IDE05705-MAS06742,Digital Transmission Content Protection (DTCP) device cert-Certificate type,0,
    IDE05713-MAS01632,Network diagnosis-Status,Enabled,
    IDE05725,Terminal 58xs dimmer,0, %
    IDE05726,Terminal 58xd dimmer,99.94, %
    IDE05814,Individualization characteristic,27 7F 22 0E 73,
    IDE06028-MAS02317,Control head button operation-Button code 1,FF,
    IDE06028-MAS02318,Control head button operation-Button code 2,FF,
    IDE06028-MAS04151,Control head button operation-Joystick,00,
    IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,0,
    IDE06028-MAS04414,Control head button operation-Volume control,0,
    IDE06516-MAS01424,Temperature: optical drive-max.value,51, °C
    IDE06516-MAS01425,Temperature: optical drive-min.value,16, °C
    IDE06516-MAS02238,Temperature: optical drive-Current,43, °C
    IDE06517-MAS01424,Temperature: audio amplifier-max.value,66, °C
    IDE06517-MAS01425,Temperature: audio amplifier-min.value,5, °C
    IDE06517-MAS02238,Temperature: audio amplifier-Current,38, °C
    IDE06519-MAS01424,Temperature of MOST transceiver-max.value,57, °C
    IDE06519-MAS01425,Temperature of MOST transceiver-min.value,2, °C
    IDE06519-MAS02238,Temperature of MOST transceiver-Current,47, °C
    IDE06521-MAS01424,Temperature of MMX PC boards-max.value,63, °C
    IDE06521-MAS01425,Temperature of MMX PC boards-min.value,30, °C
    IDE06521-MAS02238,Temperature of MMX PC boards-Current,56, °C
    IDE06522-MAS01424,Temperature of phone unit-max.value,45, °C
    IDE06522-MAS01425,Temperature of phone unit-min.value,21, °C
    IDE06522-MAS02238,Temperature of phone unit-Current,41, °C
    IDE07174,Connection for extern. audio sources (USB): overcurrent detect.,OK,
    IDE07364,GPS receiver status,No GPS data available,
    IDE07589-IDE07590,Update programming: status-Currently processed module,0,
    IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
    IDE07589-MAS01632,Update programming: status-Status,not active,
    IDE07589-MAS10948,Update programming: status-control,Diagnosis,
    IDE07938,Cause of system start,Data bus,
    IDE07939,Last cause of system start,Data bus,
    IDE08530-MAS00106,Connection status online basic services-Year,2000.0, yr
    IDE08530-MAS00107,Connection status online basic services-Month,0, mon
    IDE08530-MAS00108,Connection status online basic services-Day,0, d
    IDE08530-MAS00109,Connection status online basic services-Hours,0, H
    IDE08530-MAS00110,Connection status online basic services-Minutes,0, min
    IDE08530-MAS07131,Connection status online basic services-ID steps,0,
    IDE08530-MAS07132,Connection status online basic services-Code status,65535,
    IDE08530-ENG20907,Connection status online basic services-Server_HTTP_Status_Code_Textual,Not available,
    IDE08531-MAS00106,Connection status online license services-Year,2000.0, yr
    IDE08531-MAS00107,Connection status online license services-Month,0, mon
    IDE08531-MAS00108,Connection status online license services-Day,0, d
    IDE08531-MAS00109,Connection status online license services-Hours,0, H
    IDE08531-MAS00110,Connection status online license services-Minutes,0, min
    IDE08531-MAS07132,Connection status online license services-Code status,0,
    IDE08531-MAS07134,Connection status online license services-ID services,0,
    IDE08531-MAS07135,Connection status online license services-Activation status,No expiry,
    IDE08531-MAS07136,Connection status online license services-Exp. year,0, yr
    IDE08531-MAS07137,Connection status online license services-Exp. month,0, mon
    IDE08531-MAS07138,Connection status online license services-Exp. day,0, d
    IDE08531-ENG20907,Connection status online license services-Server_HTTP_Status_Code_Textual,not defined,
    IDE09293-IDE00690,Status of antenna 2 for phone-Connection to antenna,Electrical OK,
    IDE09293-MAS01808,Status of antenna 2 for phone-Antenna current,255, mA
    IDE09293-MAS03991,Status of antenna 2 for phone-Reception level antenna 1,180.6, %
    IDE10200-MAS01482,Identification of volume control-Hardwareversion,H21,
    IDE10200-MAS01483,Identification of volume control-Softwareversion,0108,
    IDE10200-MAS09952,Identification of volume control-Part Number,4S1919616A ,
    IDE10201-MAS01482,Identification of control unit for driving and comfort funct.-Hardwareversion,---,
    IDE10201-MAS01483,Identification of control unit for driving and comfort funct.-Softwareversion,----,
    IDE10201-MAS09952,Identification of control unit for driving and comfort funct.-Part Number,-----------,
    IDE10412,Media status in optical drive,Empty,
    IDE10478-MAS01632,Interface for external media: status-Status,OK,
    IDE10600-MAS01159,Status of the navigation database-Version number,00 1E,
    IDE10600-MAS01632,Status of the navigation database-Status,valid,
    IDE10600-MAS10892,Status of the navigation database-Country Code,00 01,
    IDE10600-MAS10893,Status of the navigation database-Region Code,F0,
    IDE10669-MAS11003,Internal SIM card: identification-ICCID,--------------------,
    IDE10669-MAS11004,Internal SIM card: identification-UICCID,--------------------------------,
    IDE10843-MAS01482,Function module: identification-Hardwareversion,48,
    IDE10843-MAS04326,Function module: identification-Device name,DVD                              ,
    IDE10843-MAS11354,Function module: identification-Bootloader version,0,
    IDE10843-MAS11355,Function module: identification-Application version,32,
    IDE10843-MAS11356,Function module: identification-Module Name,Main                             ,
    IDE10857-MAS02476,Touchless loading of mobile phone: status-install,Available,
    IDE10857-MAS11500,Touchless loading of mobile phone: status-Foreign object,No,
    IDE10857-MAS11501,Touchless loading of mobile phone: status-charge,No,
    IDE10926-MAS00318,Function module: status-activated,Yes,
    IDE10926-MAS00791,Function module: status-installed,Yes,
    IDE10926-MAS11356,Function module: status-Module Name,Navigation,
    IDE10926-MAS11749,Function module: status-Function and diagnosis readiness,Yes,
    IDE11034-MAS01482,Satellite radio: module information-Hardwareversion,x01-00-01,
    IDE11034-MAS11961,Satellite radio: module information-Serial number,DVNWTAC5,
    IDE11034-MAS11962,Satellite radio: module information-Pre-activation key,8E D0 71 00 44 56 4E 57 54 41 43 35 00 02 98 05 8A 38 64 68 F5 31 71 89 CD BF 18 05 E7 F5 E9 3F 78 62 C6 6E 82 8A 03 41 00 66 03 41 00 07 00 66 00 07,
    IDE11034-MAS11963,Satellite radio: module information-Firmware version,x0b-24-00,
    IDE11034-MAS11964,Satellite radio: module information-Satellite Module Services Version,x01-22-13,
    IDE11034-MAS11965,Satellite radio: module information-SiriusXM Interconnect Version,x03-04-02,
    IDE11034-MAS11966,Satellite radio: module information-Database Version,C0a00-F0400,
    IDE11504-ENG127677,Satellite radio tuner: pre-activated subscription-SDARS_preactivation_coding status,Yes,
    IDE13417-MAS02646,Key (DTCP): MMX-Key type,none,
    IDE13516-MAS01159,Device certificate (DTCP): MMX-Version number,0,
    IDE13516-MAS01779,Device certificate (DTCP): MMX-Length,0,
    IDE13516-MAS06742,Device certificate (DTCP): MMX-Certificate type,0,
    MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
    MAS00464-MAS00107,Standard - ambient data 1-Month,8,
    MAS00464-MAS00108,Standard - ambient data 1-Day,10,
    MAS00464-MAS00109,Standard - ambient data 1-Hours,9,
    MAS00464-MAS00110,Standard - ambient data 1-Minutes,52,
    MAS00464-MAS00111,Standard - ambient data 1-Seconds,19,
    MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,7,
    MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,65, km
    MAS00481-ENG117777,BAP-BAP_Function_ID,FF,
    MAS00778-IDE03619,Multimedia display unit 1-System status,Not available,
    MAS00778-IDE05228,Multimedia display unit 1-Operating hour counter,65535, H
    MAS00778-MAS00110,Multimedia display unit 1-Minutes,255, min
    MAS00778-MAS00362,Multimedia display unit 1-Battery voltage,Not available,
    MAS00778-MAS02200,Multimedia display unit 1-Highest measured temperature,200, °C
    MAS00778-MAS02201,Multimedia display unit 1-Temperature,200, °C
    MAS00778-MAS03691,Multimedia display unit 1-Dimming,255, %
    MAS00837-MAS01632,Telephone Transceiver-Status,Unknown,
    MAS00951-IDE04058,Bluetooth-Bluetooth: devices found,0,
    MAS00951-MAS04324,Bluetooth-Bluetooth: connected devices,0,
    MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,0,
    MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Analog,
    MAS01760-MAS02949,Radio Tuner 1-Frequency,98.9, MHz
    MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,17, dBµV
    MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,11, dBµV
    MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),65535, kHz
    MAS01760-ENG117356,Radio Tuner 1-iboc_audio_signal,Not available,
    MAS01760-ENG117358,Radio Tuner 1-iboc_count,0,
    MAS01760-ENG117355,Radio Tuner 1-iboc_error_rate,0,
    MAS01760-ENG117357,Radio Tuner 1-iboc_service,1,
    MAS01761-MAS01763,Radio Tuner 2-Signal Strength,22, dBµV
    MAS01991-IDE00010,Card reader-Serial number,FF FF FF FF,
    MAS01991-IDE01001,Card reader-Application,--,
    MAS01991-MAS01632,Card reader-Status,not connected,
    MAS01991-MAS03159,Card reader-Manufacturer,FF,
    MAS01991-MAS03375,Card reader-Major version,15,
    MAS01991-MAS03376,Card reader-Minor version,15,
    MAS01991-MAS03959,Card reader-Write-protection,Not available,
    MAS01991-MAS04388,Card reader-Card type,-----,
    MAS01991-MAS13476,Card reader-Manufacturing date: month,15, mon
    MAS01991-MAS13477,Card reader-Manufacturing date: year,2255, yr
    MAS03121,Ring break diagnostic line status,Supply voltage,
    MAS03780-IDE00010,Card reader 2-Serial number,FF FF FF FF,
    MAS03780-IDE01001,Card reader 2-Application,--,
    MAS03780-MAS01632,Card reader 2-Status,not connected,
    MAS03780-MAS03159,Card reader 2-Manufacturer,FF,
    MAS03780-MAS03375,Card reader 2-Major version,15,
    MAS03780-MAS03376,Card reader 2-Minor version,15,
    MAS03780-MAS03959,Card reader 2-Write-protection,Not available,
    MAS03780-MAS04388,Card reader 2-Card type,-----,
    MAS03780-MAS13476,Card reader 2-Manufacturing date: month,15, mon
    MAS03780-MAS13477,Card reader 2-Manufacturing date: year,2255, yr
    MAS03782-ENG117422,WLAN-IP_Address,010.173.189.001                        ,
    MAS03782-ENG117423,WLAN-IP_Subnetmask,255.255.255.000                        ,
    MAS03782-ENG117421,WLAN-MAC_Address,B8 9F 09 42 FA 98,
    MAS04324-MAS04326,Bluetooth: connected devices-Device name,0,
    MAS04324-MAS04327,Bluetooth: connected devices-Bluetooth connection profile,SDAP,
    MAS04325-MAS04326,Bluetooth: Paired devices-Device name,0,
    MAS04325-MAS04327,Bluetooth: Paired devices-Bluetooth connection profile,SDAP,
    ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
    ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,OK,
    ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,OK,
    ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,OK,
    ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,OK,
    ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,OK,
    ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,OK,
    ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,OK,
    ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,OK,
    ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,OK,
    ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,OK,
    ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,OK,
    ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,OK,
    ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,OK,
    ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,OK,
    ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,OK,
    ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,OK,
    ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,OK,
    ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
    ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
    ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
    ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,OK,
    ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
    ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,OK,
    ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,OK,
    ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,OK,
    ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,OK,
    ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,OK,
    ENG117867-ENG117773,GPS_Count_Satellite_Phase_Lock_Counter-satellites,0,
    ENG117868-ENG117773,GPS_Satellite_Code_Lock_Counter-satellites,0,
    ENG117857-MAS00109,Last_System_Operating_Time-Hours,0, H
    ENG117857-MAS00110,Last_System_Operating_Time-Minutes,57, min
    ENG117856-MAS00106,Last_System_Operating_Time/Mins.-Year,19, yr
    ENG117856-MAS00107,Last_System_Operating_Time/Mins.-Month,8, mon
    ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,2, d
    ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,18, H
    ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,34, min
    ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,23, s
    ENG127486-ENG117422,mac_adress_wlan_tethering-IP_Address,---------------------------------------,
    ENG127486-ENG117423,mac_adress_wlan_tethering-IP_Subnetmask,---------------------------------------,
    ENG127486-ENG117421,mac_adress_wlan_tethering-MAC_Address,B8 9F 09 42 FA 97,
    ENG129160,MMX mNAND Flash Version,Product = mmx2
    Branch = dev/main
    Up to CL = 10803714
    FirstTierSupplier = HARMAN
    Project = project_mmx2_audi_nar_g24.cfg
    OEM = AU
    Region = NAR
    Variant = G24
    Media-Stack = EVO
    Framework = 5.51.6.SR1 MIB2MAIN I202 CI70
    JavaVM = j9_1.16+ObjectSwapper_1.02+XIPLoader_1.10+MCFObjectReader_1.01C+JavaCrypto_1.06+Socks5Support_1.00
    DSI = 2_69
    GraphicsServices = MIB2MAIN 217.5
    Splashscreens = 67.0 MIB2MAIN
    rdiserver = 126
    Navigation = CLU10_17123MIB2MAIN_B18.07.2.100345
    NavigationMapStyles:
    			- NAR  = 10.0.2692
    LocationAccessor = 0.9.15
    Speech = 132.1806.0-MIB2MAIN
    SpeechResources = 132.1805.1
    sseProc = 1.4.4
    HMI = HMI_AU_MIB2_H_NAR_G24_C10_182700
    GCT = 2.8.3.1843
    VoiceEncoderApp = v2.1.287_FW5.49.12.SR3_TC17.45.05A
    GoogleEarth =
    RenderDataProvider =
    Media = main_18074A
    PDK = Nvidia_17.54-10422966
    MediaEngine = MM2_Media_1.0.61.9
    exFAT-Library = Tuxera_2016/02/04-14:42:21-UTC
    TextToolVersionGUI = 36816
    TextToolVersionSDS = 35052
    TextToolVersionGUIAsia = 36823
    TextToolVersionSDSAsia = 36788
    OptionDrawerVersion = Ż(b$6/10/27-16:03:54-EDT
    BlueSDK = 4.3.1 + AV 2.2.2u1
    ALS6A-FW =6/10/27-16:03:54-EDT
    ALS6A-FW = 02.011 (App: 01.001.24)
    ALS6A-BOLO = 84084
    Bluetooth-Firmware = Id: w8787-Ax, RF878X, FP44, 14.44.35.p233
    TelephoneDriver = 10.735.888
    Radiodata = 2.8.0
    GracenoteSDK = 3.05.4
    OS = QNX 6.5.0
    Toolchain = RL_QNX_OS_650SP1_MMX2_17.54B
    ENG129161,MMX NOR Flash Version,Product = mmx2
    Branch = dev/main
    Up to CL = 10803714
    OEM = AU
    Region = NAR
    Variant = G24
    Media-Stack = EVO
    DSI = 2_69
    rdiserver = 126
    			- NAR  = 10.0.2692
    sseProc = 1.4.4
    GCT = 2.8.3.1843
    GoogleEarth =
    Media = main_18074A
    OptionDrawerVersion = Ż(b"6/10/27-16:03:54-EDT
    ALS6A-BOLO = 84084
    Radiodata = 2.8.0
    OS = QNX 6.5.0
    ENG117869-ENG117441,Nav._Calculated_Direction-driving direction corrected,58, °
    ENG117869-ENG98933,Nav._Calculated_Direction-Status,OK,
    ENG122217-ENG122284,SDARS_service-audio_service,subscribed,
    ENG122217-ENG122285,SDARS_service-traffic_service,not_subscribed,
    ENG122217-ENG122286,SDARS_service-travel_link_service,not_subscribed,
    ENG122216-MAS00106,SDARS_subscription_status-Year,2098,
    ENG122216-MAS00107,SDARS_subscription_status-Month,1,
    ENG122216-MAS00108,SDARS_subscription_status-Day,1,
    ENG122216-MAS00109,SDARS_subscription_status-Hours,0,
    ENG122216-MAS00110,SDARS_subscription_status-Minutes,0,
    ENG122216-MAS00111,SDARS_subscription_status-Seconds,0,
    ENG122216-ENG122279,SDARS_subscription_status-SDARS_subscription,subscribed,
    ENG122216-ENG125804,SDARS_subscription_status-SDARS_suspend_alert,no_alert,
    ENG122216-ENG122280,SDARS_subscription_status-SDARS_suspension,not_suspended,
    ENG117855-ENG117392,System_Character_Recognition-touchpanel_information,,
    Elapsed Time: 00:32
    adpmap-5F-4S0-035-025-F
    ;Saturday,10,August,2019,09:51:08:30091
    IDE00346-Summertime-automatic,automatic ,1
    IDE00768-Country identification: country of sale,US ,2
    IDE00769-Number 1 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
    IDE00770-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
    IDE00845-Wheel circ.,0 mm,2
    IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module,Yes ,3
    IDE01996-MAS00839-Installation list: specified installations-TV Tuner,No ,3
    IDE01996-MAS00844-Installation list: specified installations-Radio,No ,3
    IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module,Yes ,3
    IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1,Yes ,3
    IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2,No ,3
    IDE01996-MAS04300-Installation list: specified installations-DVD changer,No ,3
    IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module,No ,3
    IDE01996-SFT271943-Installation list: specified installations-Multimedia Operating Unit,No ,3
    IDE01996-ENG154341-Installation list: specified installations-Reserved_8,No ,3
    IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1,No ,3
    IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2,No ,3
    IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1,No ,3
    IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2,No ,3
    IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1,No ,3
    IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2,No ,3
    IDE02330-Number 2 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
    IDE02331-Number 2 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
    IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,45 ,49
    IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,85 ,49
    IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,85 ,49
    IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,85 ,49
    IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,85 ,49
    IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,85 ,49
    IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,85 ,49
    IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,85 ,49
    IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,25 ,49
    IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,25 ,49
    IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,45 ,49
    IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,85 ,49
    IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,85 ,49
    IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,85 ,49
    IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,85 ,49
    IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,85 ,49
    IDE02502-Confirmation of installation change,44 35 ,2
    IDE02506-MAS03229-Copy multimedia data-Data medium,On ,1
    IDE02506-MAS03230-Copy multimedia data-Optical drive,OFF ,1
    IDE02607-Wheel pulse,0 ,2
    IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
    IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
    IDE03238-ENG117830-Parameter for connection transfer (UMTS)-1E_EcLo,0 ,8
    IDE03238-ENG117831-Parameter for connection transfer (UMTS)-1E_RSCP,15 ,8
    IDE03238-ENG117832-Parameter for connection transfer (UMTS)-1F_EcLo,0 ,8
    IDE03238-ENG117833-Parameter for connection transfer (UMTS)-1F_RSCP,15 ,8
    IDE03238-ENG122277-Parameter for connection transfer (UMTS)-2D_EcLo,0 ,8
    IDE03238-ENG122278-Parameter for connection transfer (UMTS)-2D_RSCP,11 ,8
    IDE03238-ENG122275-Parameter for connection transfer (UMTS)-3A_EcLo,0 ,8
    IDE03238-ENG122276-Parameter for connection transfer (UMTS)-3A_RSCP,8 ,8
    IDE03471-ENG142146-Vehicle configuration-allow_message_editing,OFF ,30
    IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
    IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
    IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
    IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
    IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
    IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
    IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
    IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,On ,30
    IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,On ,30
    IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,On ,30
    IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,On ,30
    IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
    IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
    IDE03471-ENG142142-Vehicle configuration-map_email_support,On ,30
    IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
    IDE03471-ENG142141-Vehicle configuration-map_sms_support,On ,30
    IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
    IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
    IDE03471-ENG138662-Vehicle configuration-Mirror_link,OFF ,30
    IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_EU ,30
    IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
    IDE03471-ENG117843-Vehicle configuration-my_audi,On ,30
    IDE03471-ENG127495-Vehicle configuration-online_media,On ,30
    IDE03471-ENG117840-Vehicle configuration-online_navigation,On ,30
    IDE03471-ENG117837-Vehicle configuration-online_POI,On ,30
    IDE03471-ENG117838-Vehicle configuration-online_POI_voice,On ,30
    IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,On ,30
    IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
    IDE03471-ENG117841-Vehicle configuration-online_street_view,On ,30
    IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit,On ,30
    IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
    IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
    IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
    IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,only data service act. ,30
    IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF ,30
    IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
    IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
    IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
    IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.4 ,30
    IDE03471-ENG117846-Vehicle configuration-remote_HMI,On ,30
    IDE03471-ENG138661-Vehicle configuration-RSE_software_component,Deactivated ,30
    IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
    IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,REGION_NAR ,30
    IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
    IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
    IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0 ,30
    IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,On ,30
    IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On ,30
    IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
    IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,blocked ,30
    IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
    IDE03471-ENG117852-Vehicle configuration-UPnP,On ,30
    IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,activated ,30
    IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30
    IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
    IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,OFF ,30
    IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On ,30
    IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
    IDE03580-Country code for mobile network,0 ,2
    IDE04292-Roadside assistance mode,Corresponding setting in MMI ,1
    IDE04294-Number attempted dialing attempts for roadside assistance,3 ,1
    IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
    IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
    IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
    IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,1 ,2
    IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,1 ,2
    IDE04549-Telephone data services,On ,1
    IDE05111-Fee-based traffic information (TMC),65533 ,2
    IDE06697-Audio management mute function,Muting of audio sources ,1
    IDE07399-ENG142045-Engine type-Engine_type_adaption_1,Petrol ,1
    IDE07399-ENG142046-Engine type-Engine_type_adaption_2,not_installed ,1
    IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,On ,1
    IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
    IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,On ,1
    IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,On ,1
    IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,On ,1
    IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
    IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
    IDE09382-ENG125051-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 2G,0 ,16
    IDE09382-ENG125052-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 3G,0 ,16
    IDE10082-MAS09813-Telephone functions configuration-Entering Access Point Name,On ,1
    IDE10082-MAS09814-Telephone functions configuration-Call Center Function,On ,1
    IDE10082-MAS13846-Telephone functions configuration-Internet access via WiFi,Available ,1
    IDE10082-MAS13847-Telephone functions configuration-Call center function on MIB: roadside assistance call,On ,1
    IDE10082-MAS13848-Telephone functions configuration-Call center function on MIB: POI call,On ,1
    IDE10082-MAS16726-Telephone functions configuration-Call center function on MIB: POI call regions,OFF ,1
    IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,17 ,40
    IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
    IDE10480-MAS10742-Interface for external media: activation-Connection 2,activated ,4
    IDE10668-Internal SIM card: use,Never ,1
    IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold,20 dBµV,3
    IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation,50 dB,3
    IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo,0.1 s,3
    IDE11105-Brand-specific display of connect application,de.audi.mmiconnect ,19
    IDE11153-ENG152487-Surroundings display: virtual camera positions-focallength,4294967295 ,330
    IDE11153-ENG152457-Surroundings display: virtual camera positions-Pitchangle,65535 ,330
    IDE11153-ENG152445-Surroundings display: virtual camera positions-Rollangle,65535 ,330
    IDE11153-ENG147432-Surroundings display: virtual camera positions-xpos,32767 ,330
    IDE11153-ENG152451-Surroundings display: virtual camera positions-Yawangle,65535 ,330
    IDE11153-ENG147433-Surroundings display: virtual camera positions-ypos,32767 ,330
    IDE11153-ENG147434-Surroundings display: virtual camera positions-zpos,32767 ,330
    IDE11502-ENG127601-Locked menu contents-FB_CAR_0,blocked ,21
    IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,blocked ,21
    IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,blocked ,21
    IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,blocked ,21
    IDE11502-ENG127625-Locked menu contents-FB_MISC_0,blocked ,21
    IDE11502-ENG127626-Locked menu contents-FB_MISC_1,blocked ,21
    IDE11502-ENG127630-Locked menu contents-FB_MISC_5,blocked ,21
    IDE11502-ENG127631-Locked menu contents-FB_MISC_6,blocked ,21
    IDE11502-ENG127561-Locked menu contents-FB_NAV_0,blocked ,21
    IDE11502-ENG127562-Locked menu contents-FB_NAV_1,blocked ,21
    IDE11502-ENG127564-Locked menu contents-FB_NAV_3,blocked ,21
    IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,blocked ,21
    IDE11503-Satellite radio tuner: pre-activated subscription,05 ,1
    IDE11524-ENG142156-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42,not activated ,192
    IDE11524-ENG142157-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42_msg_bus,Comfort data bus ,192
    IDE11524-ENG142158-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47,not activated ,192
    IDE11524-ENG142159-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47_msg_bus,Comfort data bus ,192
    IDE11524-ENG152529-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51,not activated ,192
    IDE11524-ENG152530-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51_msg_bus,Comfort data bus ,192
    IDE11524-ENG137043-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45,not activated ,192
    IDE11524-ENG137044-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45_msg_bus,not activated ,192
    IDE11524-ENG142168-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D,not activated ,192
    IDE11524-ENG142169-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D_msg_bus,Comfort data bus ,192
    IDE11524-ENG142154-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41,not activated ,192
    IDE11524-ENG142155-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41_msg_bus,Comfort data bus ,192
    IDE11524-ENG152535-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50,not activated ,192
    IDE11524-ENG152536-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50_msg_bus,Comfort data bus ,192
    IDE11524-ENG152569-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E,not activated ,192
    IDE11524-ENG152570-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E_msg_bus,not activated ,192
    IDE11524-ENG139202-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44,not activated ,192
    IDE11524-ENG139203-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44_msg_bus,not activated ,192
    IDE11524-ENG127678-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40,not activated ,192
    IDE11524-ENG127679-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40_msg_bus,not activated ,192
    IDE11524-ENG142162-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A,not activated ,192
    IDE11524-ENG142163-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A_msg_bus,Comfort data bus ,192
    IDE11524-ENG142164-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B,not activated ,192
    IDE11524-ENG142165-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B_msg_bus,Comfort data bus ,192
    IDE11524-ENG142166-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C,not activated ,192
    IDE11524-ENG142167-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C_msg_bus,Comfort data bus ,192
    IDE11524-ENG142160-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48,not activated ,192
    IDE11524-ENG142161-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48_msg_bus,Comfort data bus ,192
    IDE11638-Bluetooth Audio Codec,FF ,1
    IDE12266-Follow on time for telephone,activated ,1
    IDE12353-Configuration of traffic light online functions,On ,1
    IDE12434-ENG152495-Vehicle menu operation: second generation: extension-menu_connection_manager,not activated ,60
    IDE12434-ENG152499-Vehicle menu operation: second generation: extension-menu_connection_manager_after_disclaimer,not activated ,60
    IDE12434-ENG152496-Vehicle menu operation: second generation: extension-menu_connection_manager_clamp_15_off,not activated ,60
    IDE12434-ENG152497-Vehicle menu operation: second generation: extension-menu_connection_manager_over_threshold_high,not activated ,60
    IDE12434-ENG152498-Vehicle menu operation: second generation: extension-menu_connection_manager_standstill,not activated ,60
    IDE12434-ENG152548-Vehicle menu operation: second generation: extension-menu_daf_profile,not activated ,60
    IDE12434-ENG152549-Vehicle menu operation: second generation: extension-menu_daf_profile_after_disclaimer,not activated ,60
    IDE12434-ENG152550-Vehicle menu operation: second generation: extension-menu_daf_profile_clamp_15_off,not activated ,60
    IDE12434-ENG152551-Vehicle menu operation: second generation: extension-menu_daf_profile_over_threshold_high,not activated ,60
    IDE12434-ENG152552-Vehicle menu operation: second generation: extension-menu_daf_profile_stillstand,not activated ,60
    IDE12434-ENG152515-Vehicle menu operation: second generation: extension-menu_fas_profile,not activated ,60
    IDE12434-ENG152519-Vehicle menu operation: second generation: extension-menu_fas_profile_after_disclaimer,not activated ,60
    IDE12434-ENG152516-Vehicle menu operation: second generation: extension-menu_fas_profile_clamp_15_off,not activated ,60
    IDE12434-ENG152517-Vehicle menu operation: second generation: extension-menu_fas_profile_over_threshold_high,not activated ,60
    IDE12434-ENG152518-Vehicle menu operation: second generation: extension-menu_fas_profile_standstill,not activated ,60
    IDE12434-ENG184478-Vehicle menu operation: second generation: extension-menu_mascot,not activated ,60
    IDE12434-ENG184479-Vehicle menu operation: second generation: extension-menu_mascot_after_disclaimer,not activated ,60
    IDE12434-ENG184480-Vehicle menu operation: second generation: extension-menu_mascot_clamp_15_off,not activated ,60
    IDE12434-ENG184481-Vehicle menu operation: second generation: extension-menu_mascot_over_threshold_high,not activated ,60
    IDE12434-ENG184482-Vehicle menu operation: second generation: extension-menu_mascot_stillstand,not activated ,60
    IDE12434-ENG152562-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile,not activated ,60
    IDE12434-ENG152563-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_after_disclaimer,not activated ,60
    IDE12434-ENG152564-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_clamp_15_off,not activated ,60
    IDE12434-ENG152565-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_over_threshold_high,not activated ,60
    IDE12434-ENG152566-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_stillstand,not activated ,60
    IDE12434-ENG152505-Vehicle menu operation: second generation: extension-menu_statistic,not activated ,60
    IDE12434-ENG152509-Vehicle menu operation: second generation: extension-menu_statistic_after_disclaimer,not activated ,60
    IDE12434-ENG152506-Vehicle menu operation: second generation: extension-menu_statistic_clamp_15_off,not activated ,60
    IDE12434-ENG152507-Vehicle menu operation: second generation: extension-menu_statistic_over_threshold_high,not activated ,60
    IDE12434-ENG152508-Vehicle menu operation: second generation: extension-menu_statistic_standstill,not activated ,60
    IDE12434-ENG152510-Vehicle menu operation: second generation: extension-menu_sunroof,not activated ,60
    IDE12434-ENG152514-Vehicle menu operation: second generation: extension-menu_sunroof_after_disclaimer,not activated ,60
    IDE12434-ENG152511-Vehicle menu operation: second generation: extension-menu_sunroof_clamp_15_off,not activated ,60
    IDE12434-ENG152512-Vehicle menu operation: second generation: extension-menu_sunroof_over_threshold_high,not activated ,60
    IDE12434-ENG152513-Vehicle menu operation: second generation: extension-menu_sunroof_standstill,not activated ,60
    IDE12434-ENG152500-Vehicle menu operation: second generation: extension-menu_wireless_charging,not activated ,60
    IDE12434-ENG152504-Vehicle menu operation: second generation: extension-menu_wireless_charging_after_disclaimer,not activated ,60
    IDE12434-ENG152501-Vehicle menu operation: second generation: extension-menu_wireless_charging_clamp_15_off,not activated ,60
    IDE12434-ENG152502-Vehicle menu operation: second generation: extension-menu_wireless_charging_over_threshold_high,not activated ,60
    IDE12434-ENG152503-Vehicle menu operation: second generation: extension-menu_wireless_charging_standstill,not activated ,60
    MAS00951-Bluetooth,On ,1
    MAS03690-Telephone,Data & language service active ,1
    MAS03782-WLAN,On ,1
    ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off,On ,12
    ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time,150.00 ms,12
    ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off,OFF ,12
    ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time,0.00 ms,12
    ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off,OFF ,12
    ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time,0.00 ms,12
    ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off,On ,12
    ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time,150.00 ms,12
    ENG117920-Audio_Managment_Soundset_Menu,OFF ,1
    ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
    ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated ,60
    ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,activated ,60
    ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,activated ,60
    ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ,60
    ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated ,60
    ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
    ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated ,60
    ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
    ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated ,60
    ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated ,60
    ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated ,60
    ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,activated ,60
    ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,activated ,60
    ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,activated ,60
    ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,activated ,60
    ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,not activated ,60
    ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
    ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,activated ,60
    ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,activated ,60
    ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
    ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
    ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated ,60
    ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,not activated ,60
    ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
    ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
    ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not activated ,60
    ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated ,60
    ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
    ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,not activated ,64
    ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,not activated ,64
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated ,64
    ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,not activated ,64
    ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
    ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,not activated ,64
    ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,not activated ,64
    ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated ,64
    ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,not activated ,64
    ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated ,64
    ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,not activated ,64
    ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Terminal 15 ,64
    ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Terminal 15 ,64
    ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,not activated ,64
    ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Terminal 15 ,64
    ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,not activated ,64
    ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,CAN_Kombi ,64
    ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,activated ,64
    ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
    ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,not activated ,64
    ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not activated ,64
    ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,not activated ,64
    ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,not activated ,64
    ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Terminal 15 ,64
    ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,not activated ,64
    ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,not activated ,64
    ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Terminal 15 ,64
    ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
    ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,not activated ,64
    ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Terminal 15 ,64
    ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,activated ,64
    ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,CAN_MIB ,64
    ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,not activated ,64
    ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,not activated ,64
    ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,not activated ,64
    ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,not activated ,64
    ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,not activated ,64
    ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated ,64
    ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,not activated ,64
    ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,not activated ,64
    ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,64
    ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,64
    ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Terminal 15 ,64
    ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,not activated ,64
    ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
    ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,not activated ,64
    ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,not activated ,64
    ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Terminal 15 ,64
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,not activated ,64
    ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,not activated ,64
    ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated ,64
    ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,not activated ,64
    ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Terminal 15 ,64
    ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated ,64
    ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Terminal 15 ,64
    ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
    ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,not activated ,64
    ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Terminal 15 ,64
    ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Available ,8
    ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Terminal 15 ,8
    ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available ,8
    ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Available ,8
    ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Terminal 15 ,8
    ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15 ,8
    ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Not available ,8
    ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Not available ,8
    ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Terminal 15 ,8
    ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,On ,10
    ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,LVDS_map_MMI_dashboard ,10
    ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,LVDS_map_MMI_dashboard ,10
    ENG107658-ENG126192-mobile phone voice control availability-apple_device,not installed ,1
    ENG107658-ENG126193-mobile phone voice control availability-other_devices,not installed ,1
    ENG167428-ENG167502-nhtsa_properties-limitation_dependency,Speed_threshold ,5
    ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length,activated ,5
    ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration,activated ,5
    ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,activated ,5
    ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback,activated ,5
    ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input,not activated ,5
    ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists,not activated ,5
    ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists,not activated ,5
    ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps,not activated ,5
    ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,activated ,5
    ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad,not activated ,5
    ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN,0 ,3
    ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit,0 km/h,3
    Elapsed Time: 00:59
    Address - [81]
    blockmap-81-4S1-713-041-F
    ;SW:4S1-713-041-F   HW:4M1-713-041-G ---  Gear Shift
    ;Component:GSM-LL        H10 0077, Coding:
    ;EV_GSMWaehlZFAU736,001017,EV_GSMWaehlZFAU736.rod
    ;Saturday,10,August,2019,09:49:47:30091
    ;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
    ;VCID: 2E0604D0E0901DC7685-807A
    Group,Description,Actual
    IDE00019,Voltage terminal 30,12.6, V
    IDE00773,Terminal 15 status via CAN,On,
    IDE01215,Terminal 58d dimmer,95.0, %
    IDE03393-MAS02985,Selector lever position-Value,04,
    IDE03393-MAS03359,Selector lever position-Text,Basic setting X,
    IDE07159-MAS01155,Control module switch-off: counter-Control module,0,
    IDE07159-MAS05583,Control module switch-off: counter-Data bus,0,
    IDE07270,Magnet for select. lever lock.: current,0.0, A
    IDE11401-MAS02985,Selec. range display: spec. val.-Value,08,
    IDE11401-MAS03359,Selec. range display: spec. val.-Text,P,
    IDE11402-MAS02985,Neutral halt position-Value,00,
    IDE11402-MAS03359,Neutral halt position-Text,not active,
    IDE11403-MAS00116,Selec. range display: spec. val.: volts.-Tiptronic +,4311, mV
    IDE11403-MAS00117,Selec. range display: spec. val.: volts.-Tiptronic -,4311, mV
    IDE11403-MAS00146,Selec. range display: spec. val.: volts.-P,1632, mV
    IDE11403-MAS00148,Selec. range display: spec. val.: volts.-R,3763, mV
    IDE11403-MAS00150,Selec. range display: spec. val.: volts.-N,3753, mV
    IDE11403-MAS00152,Selec. range display: spec. val.: volts.-d,3920, mV
    IDE11403-MAS12722,Selec. range display: spec. val.: volts.-Button for park. lock,1432, mV
    IDE11403-MAS12723,Selec. range display: spec. val.: volts.-Arrow symbol,3973, mV
    IDE11404,Magnet for park. lock.: voltage,0.1, V
    IDE11405,Magnet for select. lever lock.: act. current,0.1, A
    IDE11406,Magnet for select. lever lock.: spec. current,0.0, A
    IDE11407,Sensor for select. lever pos.: X-value,0.08, mm
    IDE11408,Sensor for select. lever pos.: Y-value,0.07, mm
    IDE11409,Button for select. lever unlock.: voltage,3.9, V
    IDE11411-MAS06275,Button for park. lock-Switch 2 and 3: voltage value,3.9, V
    IDE11411-MAS06276,Button for park. lock-Switch 2 and 3: state,no switch is operated,
    IDE11411-MAS11178,Button for park. lock-Signal to the transmission: status,not activated,
    IDE11411-MAS11179,Button for park. lock-Signal to the transmission: value,01,
    IDE11411-MAS11180,Button for park. lock-Switch 1: state,not activated,
    IDE11411-MAS11181,Button for park. lock-Switch 1: value,00,
    IDE11412,Magnet for park. lock.: resistance,0.0, Ohm
    IDE11413-MAS00116,Selec. range display: pulse duty cycle-Tiptronic +,0.7, %
    IDE11413-MAS00117,Selec. range display: pulse duty cycle-Tiptronic -,0.7, %
    IDE11413-MAS00146,Selec. range display: pulse duty cycle-P,43.7, %
    IDE11413-MAS00148,Selec. range display: pulse duty cycle-R,0.5, %
    IDE11413-MAS00150,Selec. range display: pulse duty cycle-N,0.5, %
    IDE11413-MAS00152,Selec. range display: pulse duty cycle-d,1.1, %
    IDE11413-MAS12722,Selec. range display: pulse duty cycle-Button for park. lock,84.3, %
    IDE11413-MAS12723,Selec. range display: pulse duty cycle-Arrow symbol,1.3, %
    IDE11414,Magnet for park. lock.: pulse duty cycle,0, %
    IDE11415-MAS02985,Selector lever release button-Value,01,
    IDE11415-MAS03359,Selector lever release button-Text,not activated,
    IDE11433-MAS02985,Status of magnet for park. lock.-Value,00,
    IDE11433-MAS03359,Status of magnet for park. lock.-Text,Initializing,
    IDE11451,Magnet for selector lever lock.: pulse duty cycle,0, %
    IDE11453-MAS02985,Magnet for selector lever lock.: status-Value,00,
    IDE11453-MAS03359,Magnet for selector lever lock.: status-Text,not activated,
    IDE11454-MAS02985,Motor for transv. selector lever lock.: status-Value,01,
    IDE11454-MAS03359,Motor for transv. selector lever lock.: status-Text,operated,
    ENG07136-ENG32277,Btn_OccurenceCounter_NotClosing-PBTN_MECHERROR,NoErrorActive,
    ENG07136-ENG07251,Btn_OccurenceCounter_NotClosing-PBTN_MS_PSM1,0,
    ENG07136-ENG07252,Btn_OccurenceCounter_NotClosing-PBTN_MS_PSM1_Flag,0,
    ENG07136-ENG07253,Btn_OccurenceCounter_NotClosing-PBTN_MS_PSM2,0,
    ENG07136-ENG07254,Btn_OccurenceCounter_NotClosing-PBTN_MS_PSM2_Flag,0,
    ENG07136-ENG07245,Btn_OccurenceCounter_NotClosing-PBTN_PSM1,0,
    ENG07136-ENG07246,Btn_OccurenceCounter_NotClosing-PBTN_PSM1_Flag,0,
    ENG07136-ENG07257,Btn_OccurenceCounter_NotClosing-PBTN_PSM1_MS,0,
    ENG07136-ENG07258,Btn_OccurenceCounter_NotClosing-PBTN_PSM1_MS_Flag,0,
    ENG07136-ENG07255,Btn_OccurenceCounter_NotClosing-PBTN_PSM1_PSM2,0,
    ENG07136-ENG07256,Btn_OccurenceCounter_NotClosing-PBTN_PSM1_PSM2_Flag,0,
    ENG07136-ENG07247,Btn_OccurenceCounter_NotClosing-PBTN_PSM2,0,
    ENG07136-ENG07248,Btn_OccurenceCounter_NotClosing-PBTN_PSM2_Flag,0,
    ENG07136-ENG07261,Btn_OccurenceCounter_NotClosing-PBTN_PSM2_MS,0,
    ENG07136-ENG07262,Btn_OccurenceCounter_NotClosing-PBTN_PSM2_MS_Flag,0,
    ENG07136-ENG07259,Btn_OccurenceCounter_NotClosing-PBTN_PSM2_PSM1,0,
    ENG07136-ENG07260,Btn_OccurenceCounter_NotClosing-PBTN_PSM2_PSM1_Flag,0,
    ENG07136-ENG07249,Btn_OccurenceCounter_NotClosing-PBTN_SWITCH,0,
    ENG07136-ENG07250,Btn_OccurenceCounter_NotClosing-PBTN_SWITCH_Flag,0,
    ENG07136-ENG07241,Btn_OccurenceCounter_NotClosing-UBTN_PSM,0,
    ENG07136-ENG07242,Btn_OccurenceCounter_NotClosing-UBTN_PSM_Flag,0,
    ENG07136-ENG07243,Btn_OccurenceCounter_NotClosing-UBTN_SWITCH,0,
    ENG07136-ENG07244,Btn_OccurenceCounter_NotClosing-UBTN_SWITCH_Flag,0,
    ENG07139,ECC_1Bit_ErrorCounter,0,
    ENG26767-ENG31008,EOL_dimming_curve-EOL_dimming_curve_CRC,50800,
    ENG26767-ENG31009,EOL_dimming_curve-EOL_dimming_curve_function_Arrow_1_X,0,
    ENG26767-ENG31010,EOL_dimming_curve-EOL_dimming_curve_function_Arrow_1_Y,115,
    ENG26767-ENG31011,EOL_dimming_curve-EOL_dimming_curve_function_Arrow_2_X,100,
    ENG26767-ENG31012,EOL_dimming_curve-EOL_dimming_curve_function_Arrow_2_Y,115,
    ENG26767-ENG31013,EOL_dimming_curve-EOL_dimming_curve_function_Arrow_3_X,9500,
    ENG26767-ENG31014,EOL_dimming_curve-EOL_dimming_curve_function_Arrow_3_Y,14700,
    ENG26767-ENG31015,EOL_dimming_curve-EOL_dimming_curve_function_DS_1_X,0,
    ENG26767-ENG31016,EOL_dimming_curve-EOL_dimming_curve_function_DS_1_Y,138,
    ENG26767-ENG31017,EOL_dimming_curve-EOL_dimming_curve_function_DS_2_X,100,
    ENG26767-ENG31018,EOL_dimming_curve-EOL_dimming_curve_function_DS_2_Y,138,
    ENG26767-ENG31019,EOL_dimming_curve-EOL_dimming_curve_function_DS_3_X,9500,
    ENG26767-ENG31020,EOL_dimming_curve-EOL_dimming_curve_function_DS_3_Y,18150,
    ENG26767-ENG31021,EOL_dimming_curve-EOL_dimming_curve_function_M_1_X,0,
    ENG26767-ENG31022,EOL_dimming_curve-EOL_dimming_curve_function_M_1_Y,83,
    ENG26767-ENG31023,EOL_dimming_curve-EOL_dimming_curve_function_M_2_X,100,
    ENG26767-ENG31024,EOL_dimming_curve-EOL_dimming_curve_function_M_2_Y,83,
    ENG26767-ENG31025,EOL_dimming_curve-EOL_dimming_curve_function_M_3_X,9500,
    ENG26767-ENG31026,EOL_dimming_curve-EOL_dimming_curve_function_M_3_Y,10850,
    ENG26767-ENG31027,EOL_dimming_curve-EOL_dimming_curve_function_N_1_X,0,
    ENG26767-ENG31028,EOL_dimming_curve-EOL_dimming_curve_function_N_1_Y,58,
    ENG26767-ENG31029,EOL_dimming_curve-EOL_dimming_curve_function_N_2_X,100,
    ENG26767-ENG31030,EOL_dimming_curve-EOL_dimming_curve_function_N_2_Y,58,
    ENG26767-ENG31031,EOL_dimming_curve-EOL_dimming_curve_function_N_3_X,9500,
    ENG26767-ENG31032,EOL_dimming_curve-EOL_dimming_curve_function_N_3_Y,8160,
    ENG26767-ENG31033,EOL_dimming_curve-EOL_dimming_curve_function_P_1_X,0,
    ENG26767-ENG31034,EOL_dimming_curve-EOL_dimming_curve_function_P_1_Y,143,
    ENG26767-ENG31035,EOL_dimming_curve-EOL_dimming_curve_function_P_2_X,100,
    ENG26767-ENG31036,EOL_dimming_curve-EOL_dimming_curve_function_P_2_Y,143,
    ENG26767-ENG31037,EOL_dimming_curve-EOL_dimming_curve_function_P_3_X,9500,
    ENG26767-ENG31038,EOL_dimming_curve-EOL_dimming_curve_function_P_3_Y,14000,
    ENG26767-ENG31039,EOL_dimming_curve-EOL_dimming_curve_function_PButton_1_X,0,
    ENG26767-ENG31040,EOL_dimming_curve-EOL_dimming_curve_function_PButton_1_Y,210,
    ENG26767-ENG31041,EOL_dimming_curve-EOL_dimming_curve_function_PButton_2_X,100,
    ENG26767-ENG31042,EOL_dimming_curve-EOL_dimming_curve_function_PButton_2_Y,210,
    ENG26767-ENG31043,EOL_dimming_curve-EOL_dimming_curve_function_PButton_3_X,9500,
    ENG26767-ENG31044,EOL_dimming_curve-EOL_dimming_curve_function_PButton_3_Y,27000,
    ENG26767-ENG31045,EOL_dimming_curve-EOL_dimming_curve_function_R_1_X,0,
    ENG26767-ENG31046,EOL_dimming_curve-EOL_dimming_curve_function_R_1_Y,60,
    ENG26767-ENG31047,EOL_dimming_curve-EOL_dimming_curve_function_R_2_X,100,
    ENG26767-ENG31048,EOL_dimming_curve-EOL_dimming_curve_function_R_2_Y,60,
    ENG26767-ENG31049,EOL_dimming_curve-EOL_dimming_curve_function_R_3_X,9500,
    ENG26767-ENG31050,EOL_dimming_curve-EOL_dimming_curve_function_R_3_Y,8200,
    ENG26767-ENG31051,EOL_dimming_curve-EOL_dimming_curve_raw,00 00 00 64 25 1C 00 8F 00 8F 36 B0 00 00 00 64 25 1C 00 00 00 00 00 00 00 00 00 64 25 1C 00 3C 00 3C 20 08 00 00 00 64 25 1C 00 00 00 01 00 B1 00 00 00 64 25 1C 00 3A 00 3A 1F E0 00 00 00 64 25 1C 00 00 00 01 00 B0 00 00 00 64 25 1C 00 8A 00 8A 46 E6 00 00 00 64 25 1C 00 00 00 01 01 77 00 00 00 64 25 1C 00 53 00 53 2A 62 00 00 00 64 25 1C 00 00 00 01 00 F5 00 00 00 64 25 1C 00 73 00 73 39 6C 00 00 00 64 25 1C 00 00 00 01 01 A6 00 00 00 64 25 1C 00 D2 00 D2 69 78 00 00 00 64 25 1C 00 00 00 01 02 21 C6 70 00 00,
    ENG26767-ENG31052,EOL_dimming_curve-EOL_dimming_curve_search_Arrow_1_X,0,
    ENG26767-ENG31053,EOL_dimming_curve-EOL_dimming_curve_search_Arrow_1_Y,0,
    ENG26767-ENG31054,EOL_dimming_curve-EOL_dimming_curve_search_Arrow_2_X,100,
    ENG26767-ENG31055,EOL_dimming_curve-EOL_dimming_curve_search_Arrow_2_Y,1,
    ENG26767-ENG31056,EOL_dimming_curve-EOL_dimming_curve_search_Arrow_3_X,9500,
    ENG26767-ENG31057,EOL_dimming_curve-EOL_dimming_curve_search_Arrow_3_Y,422,
    ENG26767-ENG31058,EOL_dimming_curve-EOL_dimming_curve_search_DS_1_X,0,
    ENG26767-ENG31059,EOL_dimming_curve-EOL_dimming_curve_search_DS_1_Y,0,
    ENG26767-ENG31060,EOL_dimming_curve-EOL_dimming_curve_search_DS_2_X,100,
    ENG26767-ENG31061,EOL_dimming_curve-EOL_dimming_curve_search_DS_2_Y,1,
    ENG26767-ENG31062,EOL_dimming_curve-EOL_dimming_curve_search_DS_3_X,9500,
    ENG26767-ENG31063,EOL_dimming_curve-EOL_dimming_curve_search_DS_3_Y,375,
    ENG26767-ENG31064,EOL_dimming_curve-EOL_dimming_curve_search_M_1_X,0,
    ENG26767-ENG31065,EOL_dimming_curve-EOL_dimming_curve_search_M_1_Y,0,
    ENG26767-ENG31066,EOL_dimming_curve-EOL_dimming_curve_search_M_2_X,100,
    ENG26767-ENG31067,EOL_dimming_curve-EOL_dimming_curve_search_M_2_Y,1,
    ENG26767-ENG31068,EOL_dimming_curve-EOL_dimming_curve_search_M_3_X,9500,
    ENG26767-ENG31069,EOL_dimming_curve-EOL_dimming_curve_search_M_3_Y,245,
    ENG26767-ENG31070,EOL_dimming_curve-EOL_dimming_curve_search_N_1_X,0,
    ENG26767-ENG31071,EOL_dimming_curve-EOL_dimming_curve_search_N_1_Y,0,
    ENG26767-ENG31072,EOL_dimming_curve-EOL_dimming_curve_search_N_2_X,100,
    ENG26767-ENG31073,EOL_dimming_curve-EOL_dimming_curve_search_N_2_Y,1,
    ENG26767-ENG31074,EOL_dimming_curve-EOL_dimming_curve_search_N_3_X,9500,
    ENG26767-ENG31075,EOL_dimming_curve-EOL_dimming_curve_search_N_3_Y,176,
    ENG26767-ENG31076,EOL_dimming_curve-EOL_dimming_curve_search_P_1_X,0,
    ENG26767-ENG31077,EOL_dimming_curve-EOL_dimming_curve_search_P_1_Y,0,
    ENG26767-ENG31078,EOL_dimming_curve-EOL_dimming_curve_search_P_2_X,100,
    ENG26767-ENG31079,EOL_dimming_curve-EOL_dimming_curve_search_P_2_Y,0,
    ENG26767-ENG31080,EOL_dimming_curve-EOL_dimming_curve_search_P_3_X,9500,
    ENG26767-ENG31081,EOL_dimming_curve-EOL_dimming_curve_search_P_3_Y,0,
    ENG26767-ENG31082,EOL_dimming_curve-EOL_dimming_curve_search_PButton_1_X,0,
    ENG26767-ENG31083,EOL_dimming_curve-EOL_dimming_curve_search_PButton_1_Y,0,
    ENG26767-ENG31084,EOL_dimming_curve-EOL_dimming_curve_search_PButton_2_X,100,
    ENG26767-ENG31085,EOL_dimming_curve-EOL_dimming_curve_search_PButton_2_Y,1,
    ENG26767-ENG31086,EOL_dimming_curve-EOL_dimming_curve_search_PButton_3_X,9500,
    ENG26767-ENG31087,EOL_dimming_curve-EOL_dimming_curve_search_PButton_3_Y,545,
    ENG26767-ENG31088,EOL_dimming_curve-EOL_dimming_curve_search_R_1_X,0,
    ENG26767-ENG31089,EOL_dimming_curve-EOL_dimming_curve_search_R_1_Y,0,
    ENG26767-ENG31090,EOL_dimming_curve-EOL_dimming_curve_search_R_2_X,100,
    ENG26767-ENG31091,EOL_dimming_curve-EOL_dimming_curve_search_R_2_Y,1,
    ENG26767-ENG31092,EOL_dimming_curve-EOL_dimming_curve_search_R_3_X,9500,
    ENG26767-ENG31093,EOL_dimming_curve-EOL_dimming_curve_search_R_3_Y,177,
    ENG26767-ENG31094,EOL_dimming_curve-EOL_dimming_curve_Variant,AUDI MLBevo,
    ENG26767-ENG31095,EOL_dimming_curve-EOL_dimming_curve_Version_Number,00,
    ENG48497-ENG49840,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_CRC,61257,
    ENG48497-ENG49841,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_function_X_1,0,
    ENG48497-ENG49842,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_function_X_2,10,
    ENG48497-ENG49843,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_function_X_3,100,
    ENG48497-ENG49844,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_function_X_4,200,
    ENG48497-ENG49845,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_function_X_5,253,
    ENG48497-ENG49846,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_function_Y_1,2,
    ENG48497-ENG49847,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_function_Y_2,2,
    ENG48497-ENG49848,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_function_Y_3,17,
    ENG48497-ENG49849,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_function_Y_4,50,
    ENG48497-ENG49850,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_function_Y_5,95,
    ENG48497-ENG49851,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_raw,00 0A 64 C8 FD 02 02 11 32 5F 00 01 32 5F 7D 00 01 32 5F 5F EF 49 01 00,
    ENG48497-ENG49852,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_search_X_1,0,
    ENG48497-ENG49853,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_search_X_2,1,
    ENG48497-ENG49854,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_search_X_3,50,
    ENG48497-ENG49855,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_search_X_4,95,
    ENG48497-ENG49856,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_search_X_5,125,
    ENG48497-ENG49857,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_search_Y_1,0,
    ENG48497-ENG49858,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_search_Y_2,1,
    ENG48497-ENG49859,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_search_Y_3,50,
    ENG48497-ENG49860,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_search_Y_4,95,
    ENG48497-ENG49861,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_search_Y_5,95,
    ENG48497-ENG49862,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_Variant,AUDI MSS,
    ENG48497-ENG49863,EOL_KL58_Dimming_curve-EOL_KL58_dimming_curve_Version,00,
    ENG07128,Gear_KL58xt_Signal,64,
    ENG07126,Gear_Park_Lock_Solenoid_Signal,Init / Not Used,
    ENG111659,Invalid_key_counter,00,
    ENG07135-ENG07240,LED_Level_Intensity-function_level_intensity,95, %
    ENG07135-ENG07239,LED_Level_Intensity-search_level_intensity,95, %
    ENG07131,MLL_Motor_Pos1Sensor_State,01,
    ENG07140-ENG07301,MLL_RetryCounter_PWM100-MLL_RetryCounter_PWM100_Kickback,0,
    ENG07140-ENG07300,MLL_RetryCounter_PWM100-MLL_RetryCounter_PWM100_Opening,0,
    ENG07137,Mll_TargetPwmDutyCycle,70, %
    ENG08877-ENG09593,MW_WH_Warnung-Mll_Wh_Warning_Info,none,
    ENG08877-ENG09594,MW_WH_Warnung-Moni_WhWarning,none,
    ENG07125,NWDF_Active,On,
    ENG08876-ENG07265,PLS_ErrorCounter-CurrentDeviationCounter_OncePerKL15,0,
    ENG08876-ENG07264,PLS_ErrorCounter-CurrentDeviationCounter_ThisKL15,0,
    ENG08876-ENG09591,PLS_ErrorCounter-LowVoltInOnCounter_ThisKL15,0,
    ENG08876-ENG09592,PLS_ErrorCounter-LowVoltInOnCounterCounter_OncePerKL15,0,
    ENG08876-ENG07271,PLS_ErrorCounter-OnlineDiagCounter_OncePerKL15,0,
    ENG08876-ENG07270,PLS_ErrorCounter-OnlineDiagCounter_ThisKL15,0,
    ENG08876-ENG09590,PLS_ErrorCounter-ResistanceInOnCounter_OncePerKL15,0,
    ENG08876-ENG09589,PLS_ErrorCounter-ResistanceInOnCounter_ThisKL15,0,
    ENG08876-ENG07268,PLS_ErrorCounter-UndervoltCurrentDeviationCounter_OncePerKL15,0,
    ENG08876-ENG07267,PLS_ErrorCounter-UndervoltCurrentDeviationCounter_ThisKL15,0,
    ENG07119-ENG36278,RuntimeDataStruct-Runtime_Data_bios_pls_deviationCounterPerKL15,0,
    ENG07119-ENG36279,RuntimeDataStruct-Runtime_Data_bios_pls_InOnCounterPerKL15onlineDiag,0,
    ENG07119-ENG36280,RuntimeDataStruct-Runtime_Data_bios_pls_InOnUndervoltCounterPerKL15,0,
    ENG07119-ENG36281,RuntimeDataStruct-Runtime_Data_bios_pls_onlineDiagCounterPerKL15,0,
    ENG07119-ENG36282,RuntimeDataStruct-Runtime_Data_bios_pls_undervoltDeviationCounterPerKL15,0,
    ENG07119-ENG32508,RuntimeDataStruct-Runtime_Data_btn_counters,00 00 00 00 00 00 00 00 00 00 00 00,
    ENG07119-ENG36283,RuntimeDataStruct-Runtime_Data_Bus_Knockout_counter,0,
    ENG07119-ENG36284,RuntimeDataStruct-Runtime_Data_ECC_Dsi_Error_counter,0,
    ENG07119-ENG36285,RuntimeDataStruct-Runtime_Data_ECC_Mci_Error_counter,0,
    ENG07119-ENG36286,RuntimeDataStruct-Runtime_Data_ECC_One_Bit_Error_counter,0,
    ENG07119-ENG36287,RuntimeDataStruct-Runtime_Data_ECU_Knockout_counter,0,
    ENG07119-ENG36288,RuntimeDataStruct-Runtime_Data_Fee_Overrun_counter,0,
    ENG07119-ENG36289,RuntimeDataStruct-Runtime_Data_handshake_reset_counter,0,
    ENG07119-ENG36290,RuntimeDataStruct-Runtime_Data_mll_Full_Pwm_kickback_counter,0,
    ENG07119-ENG36291,RuntimeDataStruct-Runtime_Data_mll_Full_Pwm_opening_counter,0,
    ENG07119-ENG32509,RuntimeDataStruct-Runtime_Data_Reserved,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
    ENG07119-ENG32510,RuntimeDataStruct-Runtime_Data_Std_FreezeFrame_Data,41 00 00 00 13 11 08 3B 09 0A,
    ENG07119-ENG36292,RuntimeDataStruct-Runtime_Data_unlearn_counter,7,
    ENG07127,Selector_Counter_Handshake_Resets,0,
    ENG108912,Selector_lever_position_inverse,Basic setting X,
    ENG07121,Selector_Lever_Position_Inverse_Undebounced,Basic setting X,
    ENG07120,Selector_Lever_Position_Undebounced,Basic setting X,
    ENG07124,Selector_Manual_Lane_Lock_State,closed,
    ENG27119,Selector_Park_Lock_Solenoid_Shiftlock_HSS_Value,OFF,
    ENG07122-ENG32542,Selector_Range_Sensor_Error_Status-Selector_Range_Sensor_Error_Status_Path1,no error,
    ENG07122-ENG32543,Selector_Range_Sensor_Error_Status-Selector_Range_Sensor_Error_Status_Path2,no error,
    ENG07129-ENG33138,WBS_Calib_Thresholds-Threshold_Init_Marker,EOL Written Thresholds,
    ENG07129-ENG33139,WBS_Calib_Thresholds-Threshold_Reserved,00 00 00 00 00 00 00 00 00 00 00 00,
    ENG07129-ENG07183,WBS_Calib_Thresholds-VALUE_Threshold_A12,-556,
    ENG07129-ENG07186,WBS_Calib_Thresholds-VALUE_Threshold_A1X,-176,
    ENG07129-ENG07184,WBS_Calib_Thresholds-VALUE_Threshold_A21,-496,
    ENG07129-ENG07190,WBS_Calib_Thresholds-VALUE_Threshold_B12,564,
    ENG07129-ENG07187,WBS_Calib_Thresholds-VALUE_Threshold_B1X,184,
    ENG07129-ENG07189,WBS_Calib_Thresholds-VALUE_Threshold_B21,504,
    ENG07129-ENG07207,WBS_Calib_Thresholds-VALUE_Threshold_CRC,31826,
    ENG07129-ENG07193,WBS_Calib_Thresholds-VALUE_Threshold_MTM,284,
    ENG07129-ENG07196,WBS_Calib_Thresholds-VALUE_Threshold_MTP,-276,
    ENG07129-ENG07191,WBS_Calib_Thresholds-VALUE_Threshold_MX,250,
    ENG07129-ENG07197,WBS_Calib_Thresholds-VALUE_Threshold_SA12,-556,
    ENG07129-ENG07200,WBS_Calib_Thresholds-VALUE_Threshold_SA1X,-176,
    ENG07129-ENG07198,WBS_Calib_Thresholds-VALUE_Threshold_SA21,-496,
    ENG07129-ENG07204,WBS_Calib_Thresholds-VALUE_Threshold_SB12,564,
    ENG07129-ENG07201,WBS_Calib_Thresholds-VALUE_Threshold_SB1X,184,
    ENG07129-ENG07203,WBS_Calib_Thresholds-VALUE_Threshold_SB21,504,
    ENG07129-ENG07205,WBS_Calib_Thresholds-VALUE_Threshold_SMX,250,
    ENG07129-ENG07199,WBS_Calib_Thresholds-VALUE_Threshold_SXA1,-276,
    ENG07129-ENG07202,WBS_Calib_Thresholds-VALUE_Threshold_SXB1,284,
    ENG07129-ENG07206,WBS_Calib_Thresholds-VALUE_Threshold_SXM,463,
    ENG07129-ENG07194,WBS_Calib_Thresholds-VALUE_Threshold_TMM,184,
    ENG07129-ENG07195,WBS_Calib_Thresholds-VALUE_Threshold_TPM,-176,
    ENG07129-ENG07208,WBS_Calib_Thresholds-VALUE_Threshold_VersionNumber,02,
    ENG07129-ENG07185,WBS_Calib_Thresholds-VALUE_Threshold_XA1,-276,
    ENG07129-ENG07188,WBS_Calib_Thresholds-VALUE_Threshold_XB1,284,
    ENG07129-ENG07192,WBS_Calib_Thresholds-VALUE_Threshold_XM,463,
    ENG07130-ENG07213,WBS_Sensor_Voltage-VALUE_WBS_Sensor_0_Volt,3485, mV
    ENG07130-ENG07214,WBS_Sensor_Voltage-VALUE_WBS_Sensor_1_Volt,3499, mV
    ENG07130-ENG07223,WBS_Sensor_Voltage-VALUE_WBS_Sensor_10_Volt,3470, mV
    ENG07130-ENG07224,WBS_Sensor_Voltage-VALUE_WBS_Sensor_11_Volt,3421, mV
    ENG07130-ENG07215,WBS_Sensor_Voltage-VALUE_WBS_Sensor_2_Volt,2756, mV
    ENG07130-ENG07216,WBS_Sensor_Voltage-VALUE_WBS_Sensor_3_Volt,1622, mV
    ENG07130-ENG07217,WBS_Sensor_Voltage-VALUE_WBS_Sensor_4_Volt,2668, mV
    ENG07130-ENG07218,WBS_Sensor_Voltage-VALUE_WBS_Sensor_5_Volt,3441, mV
    ENG07130-ENG07219,WBS_Sensor_Voltage-VALUE_WBS_Sensor_6_Volt,3411, mV
    ENG07130-ENG07220,WBS_Sensor_Voltage-VALUE_WBS_Sensor_7_Volt,3475, mV
    ENG07130-ENG07221,WBS_Sensor_Voltage-VALUE_WBS_Sensor_8_Volt,3485, mV
    ENG07130-ENG07222,WBS_Sensor_Voltage-VALUE_WBS_Sensor_9_Volt,3397, mV
    ENG07130-ENG07225,WBS_Sensor_Voltage-VALUE_WBS_Sensor_Off_Volt,4922, mV
    ENG08636-ENG09212,ZF_Coding_Block-ENUM_ZF_Coding_Ausleuchtung,Audi,
    ENG08636-ENG09206,ZF_Coding_Block-ENUM_ZF_Coding_Bordnetz,MLB (MSS),
    ENG08636-ENG09223,ZF_Coding_Block-ENUM_ZF_Coding_CodedFlag,coded,
    ENG08636-ENG09208,ZF_Coding_Block-ENUM_ZF_Coding_Dimmnachlauf,Feature deactivated,
    ENG08636-ENG09213,ZF_Coding_Block-ENUM_ZF_Coding_LEDdiag,Feature activated,
    ENG08636-ENG09216,ZF_Coding_Block-ENUM_ZF_Coding_MLD,Plus ist vorne,
    ENG08636-ENG09209,ZF_Coding_Block-ENUM_ZF_Coding_NHaltephase,Feature deactivated,
    ENG08636-ENG09207,ZF_Coding_Block-ENUM_ZF_Coding_ParkLockSolenoid,Feature deactivated,
    ENG08636-ENG09210,ZF_Coding_Block-ENUM_ZF_Coding_Rueckstellmotor,Feature activated,
    ENG08636-ENG09215,ZF_Coding_Block-ENUM_ZF_Coding_SMX,Audi,
    ENG08636-ENG09211,ZF_Coding_Block-ENUM_ZF_Coding_Sperrmagnet,Feature activated,
    ENG08636-ENG09214,ZF_Coding_Block-ENUM_ZF_Coding_Verpolschutz,Diode,
    ENG08636-ENG09222,ZF_Coding_Block-VALUE_ZF_Coding_CodingVersion,01,
    ENG08636-ENG09224,ZF_Coding_Block-VALUE_ZF_Coding_CRC,50,
    ENG08636-ENG33389,ZF_Coding_Block-ZF_Coding_Reserved,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
    ENG07160-ENG07183,ZF_EOL_WBS_Thresholds-VALUE_Threshold_A12,-556,
    ENG07160-ENG07186,ZF_EOL_WBS_Thresholds-VALUE_Threshold_A1X,-176,
    ENG07160-ENG07184,ZF_EOL_WBS_Thresholds-VALUE_Threshold_A21,-496,
    ENG07160-ENG07190,ZF_EOL_WBS_Thresholds-VALUE_Threshold_B12,564,
    ENG07160-ENG07187,ZF_EOL_WBS_Thresholds-VALUE_Threshold_B1X,184,
    ENG07160-ENG07189,ZF_EOL_WBS_Thresholds-VALUE_Threshold_B21,504,
    ENG07160-ENG07207,ZF_EOL_WBS_Thresholds-VALUE_Threshold_CRC,31826,
    ENG07160-ENG07193,ZF_EOL_WBS_Thresholds-VALUE_Threshold_MTM,284,
    ENG07160-ENG07196,ZF_EOL_WBS_Thresholds-VALUE_Threshold_MTP,-276,
    ENG07160-ENG07191,ZF_EOL_WBS_Thresholds-VALUE_Threshold_MX,250,
    ENG07160-ENG07197,ZF_EOL_WBS_Thresholds-VALUE_Threshold_SA12,-556,
    ENG07160-ENG07200,ZF_EOL_WBS_Thresholds-VALUE_Threshold_SA1X,-176,
    ENG07160-ENG07198,ZF_EOL_WBS_Thresholds-VALUE_Threshold_SA21,-496,
    ENG07160-ENG07204,ZF_EOL_WBS_Thresholds-VALUE_Threshold_SB12,564,
    ENG07160-ENG07201,ZF_EOL_WBS_Thresholds-VALUE_Threshold_SB1X,184,
    ENG07160-ENG07203,ZF_EOL_WBS_Thresholds-VALUE_Threshold_SB21,504,
    ENG07160-ENG07205,ZF_EOL_WBS_Thresholds-VALUE_Threshold_SMX,250,
    ENG07160-ENG07199,ZF_EOL_WBS_Thresholds-VALUE_Threshold_SXA1,-276,
    ENG07160-ENG07202,ZF_EOL_WBS_Thresholds-VALUE_Threshold_SXB1,284,
    ENG07160-ENG07206,ZF_EOL_WBS_Thresholds-VALUE_Threshold_SXM,463,
    ENG07160-ENG07194,ZF_EOL_WBS_Thresholds-VALUE_Threshold_TMM,184,
    ENG07160-ENG07195,ZF_EOL_WBS_Thresholds-VALUE_Threshold_TPM,-176,
    ENG07160-ENG07185,ZF_EOL_WBS_Thresholds-VALUE_Threshold_XA1,-276,
    ENG07160-ENG07188,ZF_EOL_WBS_Thresholds-VALUE_Threshold_XB1,284,
    ENG07160-ENG07192,ZF_EOL_WBS_Thresholds-VALUE_Threshold_XM,463,
    ENG07133,ZF_NvM_ResetSafeRamApplErrFlags,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
    ENG07134,ZF_ResetSafeRamErrFlags,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C5 67 3A 98 00 00 00 00 00 00 00 00 A5 00 00 00 00 00 00 00,
    ENG08635-ENG09205,ZF_Software_Version_Number-VALUE_Reserved,20,
    ENG08635-ENG09203,ZF_Software_Version_Number-VALUE_ZF_Build_Variante,S,
    ENG08635-ENG09201,ZF_Software_Version_Number-VALUE_ZF_Kundenkennung,A1,
    ENG08635-ENG09202,ZF_Software_Version_Number-VALUE_ZF_Software_Version,4111,
    ENG08635-ENG09204,ZF_Software_Version_Number-VALUE_ZF_Version_Timestamp,160728144816,
    Elapsed Time: 00:10
    adpmap-81-4S1-713-041-F
    ;Saturday,10,August,2019,09:49:57:30091
    IDE00820-Activating and deactivating all development messages,OFF ,1
    Elapsed Time: 00:00
    end
    These were all the maps that were captured at this time.
    drp.....
  8. Likes Uwe liked this post
