Audi A6 C7 Auto-hold memory last state
RHead
C?ID=368242
Hi
Is it possible to get working auto-hold function that remembers last state? Now i have to push button every time that i start engine.
Thursday,08,August,2019,10:31:27:48855
VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
VIN: License Plate:
Mileage:    Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 20 28 34 36 3B 42 44 46
          47 52 53 55 56 5F 62 69 6C 6D 72 A9 C0
VIN: Mileage:
C0-Act. for Ext. Noise -- Status: Malfunction 0010
Address 01: Engine (J623-CGQB)       Labels: Redir Fail!
   Part No SW: 4G0 907 589 C    HW: 4G0 907 589
   Component: 3.0BTD EDC17  H23 0001
   Revision: 57H23---
   Coding: 322A403A25360B020000
   ASAM Dataset: EV_ECM30BTD0114G0907589C 001001
   ROD: EV_ECM30BTD_AU57.rod
   VCID: 34311D7ABEB082D71E1-8060
   Part No SW: 4G0 927 158 AA    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H16 1003
   Revision: --H16---
   Coding: 000001
   ASAM Dataset: EV_TCMAL551211 002018
   VCID: 6D87C81E9D1A131F11F-8038
   Coding: 49A7C70592E5E3A0EB00
   VCID: 36352772A8CC90C7205-8062
   Part No SW: 4H0 907 064 CP    HW: 4H0 907 064 CP
   Component: BCM2 2.0      H32 0421
   Coding: 05A92F46000000000000
   VCID: 79AFEC4ED9D2BFBF8D7-802C
   Serial number: 2312000183867004
   Part No SW: 4G0 820 043 AE    HW: 4G0 820 043 AE
   Component: KLIMA 4 ZONEN H13 0076
   Serial number: 23091200040379
   Coding: 3692007821
   VCID: 629DAB2254C45C67BCD-8036
   Revision: 11012002    Serial number: 00000001619406
   Coding: 0907E01009749FE0098100C380001800CF9CE7082E080201000108546F00
   VCID: 6FBBD2169796E10F233-803A
   Component: WWS57X 120807  H36 0080
   Serial number:         120907192453
   Coding: 0045F7
   Serial number: 20588658
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 19 09 2012  00001663
   Subsystem 4 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Serial number: 00000014091200010008
   Coding: 110000
   Serial number: 00000019091200010521
   Coding: 110000
   Serial number: C0A80B46000000000001
Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
   Part No SW: 4H0 919 475 AF    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0050
   Revision: --------    Serial number: 56261225503537
   Coding: B9030C
   ASAM Dataset: EV_EPHVA2CAU57X0000 002011
   ROD: EV_EPHVA2CAU57X0000.rod
   VCID: 76B5E772E84CD0C7E05-8022
   Revision: --------    Serial number: 003JG00AARA9
   Coding: 30323436313330303431554A304C34473053
   Serial number: 3575HRB405T1HGMQE1C7
   Serial number: 3585HRB40671HA3IB85.
   Serial number: 3515JRB40551GLOM98V2
   Serial number: 3525JRB405B1GLOMPH36
   Serial number: 3554VRB40084ULPIBPGX
   Serial number: 3564VRB400U4ULPII21P
   Revision: --------    Serial number: 90372LIK000JQ
   Coding: 000435
   VCID: 3829294AA25866B7329-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 08 09 2012  D0113610
   Part No SW: 4G9 920 950 E    HW: 4G9 920 950 E
   Component: TDieRdw   Nv  H78 0515
   Revision: 28131207    Serial number: 658170912596047
   Coding: 13A621081B410008010600
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU57.rod
   VCID: 323D1B6244A48CE70CD-8066
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 E    HW: 4H0 265 105 E
   Component: Standheizung  H24 0260
   Revision: 66006006    Serial number: 20120822233553
   Coding: 5D3F01
   VCID: 2411ED3A0ED012578E1-8070
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AA
   Component: J533--Gateway H11 0035
   Revision: --------    Serial number: 00000000692370
   Coding: 00CD077D00
   ASAM Dataset: EV_GatewPkoUDS 001016
   VCID: 71BFD46E8122F7FF357-8024
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790211336
   Voltage stabilizer:
   Serial number: 12071600000000000191
   Revision: AA001002
   VCID: 7CA1F55AD6E08A97961-8028
   Part No SW: 4G0 919 158 J    HW: 4G0 919 158 J
   Component: KLIMA FOND    H07 0076
   Serial number: 24091200040676
   Coding: 21
   Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H18 0782
   Coding: 008001
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2E050F12509CA807685-807A
   Revision: AA000000    Serial number: 00000039835090
   VCID: 77ABEA76EFC6A9CFFB3-8022
   Component: SARA 6D       H02 0053
   Revision: --------    Serial number: EJ1BPA8201C5DZ
   ASAM Dataset: EV_SARA2 005011
   ROD: EV_SARA2.rod
   Component: TSG FA        H03 0506
   Coding: 011F16005E00620002080002
   VCID: 47CB5AB6DFA6194F4B3-8012
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0025910425
   Coding: 101100010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0184550374
   Coding: 013A0E2020B93081832009042001040F0000000000000000000000000000
   Revision: CJ007001    Serial number: 00000000006197
   Coding: 030000
   VCID: 1D67D8DE2DBA239FC1F-8048
   Component: TSG BF        H03 0506
   VCID: 46D557B2D8AC0047B05-8012
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000483495
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B030606638EDD2F4FB-807E
   Serial number: 120924-0002-039
   Coding: 11226F601002A300
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2D07081E5D9AD31F51F-8078
   Part No SW: 4G1 035 053 E    HW: 4G1 035 053
   Component: Radio U Basic H41 0093
   Revision: AB001007    Serial number: 227I 0C7638015
   Coding: 010003010000000001
   VCID: 211FE42E11C2077FE57-8074
   Part No SW: 4G0 035 666 H    HW: 4G0 035 666 H
   Component: H-BN-EU       H49 0526
   Revision: --------    Serial number: 189I10C7521572
   Coding: 080100050003F3EF4580AB1E00000003E00001020200000000
   VCID: 2D07081E5D1AD31F51F-8078
   Subsystem 1 - Part No: 8R0 060 884 AH
   Component: EUR 2012  1308
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Serial number: AUZ8ZDC9402LDW9
   Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
   Serial number: 90349LIJ0007V
   Component: CD-Database  3638
   Component: TSG HL        H03 0506
   Coding: 010F14004000620002080002
   VCID: 49CF5C8EC9B2EF3F5D7-801C
Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Revision: 5G001001    Serial number: 00000184211264
   Coding: 0109080000000000
   VCID: 71BFD46E81A2F7FF357-8024
   Revision: --H06---    Serial number: 525 PA8J28G6X7
   Coding: 1090005
   VCID: 2615F73274ECE047905-8072
   Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
   Component: HDSG-Modul    H03 0143
   Revision: 14003001    Serial number: 235200428
   Coding: 097205C011
   ROD: EV_HDSGAu571.rod
   VCID: 3537207EB5CA9BDF29F-8060
   Component: TSG HR        H03 0506
   Part No SW: 4G0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 120831201177
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   ROD: EV_SoundActuaGen2AU64X_002.rod
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 4G0 907 160 B    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0004
   Serial number: 120902200078
   VCID: 2411ED3A0E5012578E1-8070
0006 - Actuator 1 for Engine Noise Simulation
          C113C 13 [008] - Open Circuit
                    Fault Frequency: 54
                    Reset counter: 217
                    Mileage: 119404 km
                    Date: 2019.08.07
                    Time: 08:22:11
End----(Elapsed Time: 02:26, VBatt start/end: 11.8V/12.0V. VIgn 12.0V)-----
wuplur
C?ID=247333
It stores for me and I have the same car. I did change the code to store the start/stop memory last state. Can’t remember what it was cause I did it a while ago but try doing that.
RHead
C?ID=368242
Still haven't figured this out.
wuplur
C?ID=247333
Try this
- module 09-Cent. Elec.
- enter Security Code (20113)
- Adaptation on Channel 34:
add 32 to the value --> memorize last status (the Start & Stop status at engine startup will be the one at last engine shutdown)
- test & save
RHead
C?ID=368242
ooh.. start stop.. look topic what we are talking not start top.. autohold!
wuplur
C?ID=247333
I know you are talking about autohold. Once I did this coding it worked for both systems.
RHead
C?ID=368242
Yes i tried but not working with my car.
