MMI 3G+/3GP system problem
Finnspring
New Member
Hi everyone! Gonna need little help please.
My car is Audi A6 avant 2012 3.0tdi quattro
Media Version : HN+R_EU_AU_P0485
Nav. database version : 8R0060884N ECE 5.12.5
Tried to update my firmware to the newer one K0900 and there was some prompted errors... First i tryed retry update few times, then i pressed skip this file and it did go forward a while, and then again error came... Next there was only option retry or cancel update and i tried to retry few times and then i cancelled update becaus nothing worked... So what i can do?? i have 32gb sdhc card fat32 formatted.. Is there anything what i can do myself?
Now when i try to start this update again and try to solve this problem, i put sdcard to slot 1 and start car.. This is all what happens... First green screen, its erasing something at start and succesfully do that, then system start to program something and after few minutes come Flash CRC error with RED screen and immediatly after that METAINFO CRC error with red screen and then 60seconds black screen and system goes black... so what i can do, can anyone help me? i can get fault codes tomorrow evening after work if that helps..
I have photos also but dont know how to add those to here... :/
Please post a full unedited VCDS Auto-Scan so we can see exactly how your MMI and car are configured.
Finnspring
New Member
Auto-Scan
Thank you for your answer, here is the list.
Wednesday,14,August,2019,21:11:48:31171
VCDS Version: 19.6.0.6 (x64)
VIN: WAUZZZ4G1CN052976   License Plate: CMF-586
Mileage: 175496   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 28 3B 42 44 46 52 53 55
          56 5F 62 69 72
17-Instruments -- Status: Cannot be reached 0100
56-Radio -- Status: Cannot be reached 0100
5F-Information Electr. -- Status: Cannot be reached 0100
Address 01: Engine (J623-CLAA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 311 B    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0002
   Revision: 53H37---
   Coding: 1225401A053601020000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TDI0114G0907311B 001003
   ROD: EV_ECM30TDI0114G0907311B.rod
   VCID: 2273D4B735B6325FA3-8076
   Part No SW: 4G1 927 156 C    HW: 0B5 927 156 F
   Component: 0B5 30 TDIRdW H10 0001
   Revision: --H10---    Serial number: 0000000204
   ASAM Dataset: EV_TCMDL501 A02087
   ROD: EV_TCMDL501.rod
   VCID: 2D69378B7C68FD270E-8078
   Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
   Component: ESP PREMIUM   H09 0250
   Coding: 07A68701E065E180FB00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004017
   VCID: 345F22EF9F42ACEF41-8060
   Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
   Component: BCM2 2.0      H31 0330
   Coding: 01A93006000000000000
   VCID: 76DBD8E7C1BEFEFFBF-8022
   Component: J764 ELV MLB  H39 0046
   Serial number: 2311000195273006
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H11 0062
   Serial number: 11091100040331
   Coding: 3612007820
   ASAM Dataset: EV_AirCondiComfoUDS 002033
   VCID: 2765C5A35E94D777F4-8072
   Part No SW: 4H0 907 063 BF    HW: 4H0 907 063 F
   Component: BCM1 2.0      H12 0100
   Revision: 20012002    Serial number: 00000001046063
   Coding: 2600E01040349FE00181008300001D0C0F9CE70826090101000008602100
   VCID: 6DE9F78BB4E83D274E-8038
   Component: WWS57X 110805  H35 0051
   Serial number:         110810022246
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11664405
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 11 09 2011  00000055
   Serial number: 66384FB5000000000001
   Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
   Revision: 11001001    Serial number: 55901125800747
   Coding: 090307
   ROD: EV_EPHVA18AU57X0000_002_AU57.rod
   VCID: 3B4D09D3B21C639780-806E
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG00452FL
   Coding: 30323436313330303431554A304C34473053
   VCID: 365B18E7893EBEFF7F-8062
   Serial number: 3575HRB404V0OPI2711K
   Serial number: 3585HRB40530OPI248MJ
   Serial number: 3515JRB405L0N49OB1FG
   Serial number: 3525JRB40610NS9O5H4L
   Serial number: 3554VRB40670N49OHO8/
   Serial number: 3564VRB405H0M8GE998R
   Revision: 00000000    Serial number: 20110914000338
   Coding: 000015
   VCID: 30572EFF635A90CF25-8064
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Component: E221 - MFL  H08 0009
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 931 E    HW: 4G8 920 931 E
   Component: TDieRdw       H71 0375
   Revision: 26181114    Serial number: 658140911591006
   Coding: 13A611000B010008010000
   ASAM Dataset: EV_RBD4K 004040
   ROD: N/A
   VCID: 30572EFF6B5A90CF25-8064
Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
No ASAM data for: "EV_RBD4K" (AU57)
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 E    HW: 4H0 265 105 E
   Component: Standheizung  H24 0250
   Revision: 66006006    Serial number: 20110820045353
   Coding: 5D3B00
   VCID: 247FD2AF27A23C6FD1-8070
   Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0213
   Revision: --------    Serial number: 00000000249497
   Coding: 00CD077D00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 325324F76556A2DF53-8066
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650309342
   Voltage stabilizer:
   Serial number: 11257000323011200181
0269 - Optical data bus
          U104A 00 [009] - No Communication
                    Fault Frequency: 76
                    Reset counter: 118
                    Mileage: 174946 km
                    Date: 2019.08.10
                    Time: 14:08:17
                    Voltage terminal 30: 12.6 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 45 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
12290 - Quiescent Current
          U1406 00 [008] - Too High
                    Reset counter: 157
                    Mileage: 175480 km
                    Date: 2019.08.14
                    Time: 10:02:44
                    Voltage terminal 30: 12.3 V
                    Control Module temperature: 17 °C
                    System status: LIN_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
                    Reset counter: 157
                    Mileage: 175480 km
                    Date: 2019.08.14
                    Time: 13:05:59
                    Voltage terminal 30: 12.2 V
                    Control Module temperature: 16 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0062
   Serial number: 29081100040716
   Coding: 01
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002015
   VCID: 2F552D8376648F373C-807A
0033 - Motor for Rear Right Upper Body Vent
          B10D4 22 [008] - Signal Amplitude Too High
                    Fault Frequency: 103
                    Reset counter: 156
                    Mileage: 171818 km
                    Date: 2019.06.17
                    Time: 15:45:45
                    Voltage terminal 30: 12.25 V
                    Outside air temperature: 31.0 °C
                    Right Rear Upper Body Vent Motor-Act.val.: 11701
                    Right Rear Upper Body Vent Motor-Specified value: 11701
                    Right Rear Upper Body Vent Motor-Stop open: 11395
                    Right Rear Upper Body Vent Motor-Stop closed: 10000
0034 - Motor for Rear Right Upper Body Vent
          B10D4 21 [008] - Signal Amplitude Too Low
                    Reset counter: 155
                    Mileage: 173946 km
                    Date: 2019.07.21
                    Time: 17:06:48
                    Voltage terminal 30: 14.38 V
                    Outside air temperature: 28.0 °C
                    Right Rear Upper Body Vent Motor-Act.val.: 9849
                    Right Rear Upper Body Vent Motor-Specified value: 9849
0075 - Button or Switch in Operating Unit
          B10C7 07 [008] - Mechanical Failure
                    Reset counter: 152
                    Mileage: 175053 km
                    Date: 2019.08.11
                    Time: 13:57:16
                    Outside air temperature: 26.5 °C
                    Left rear vent temperature: 16.1 °C
   Part No SW: 4G0 907 637     HW: 4G0 907 637
   Component: SARA 3D       H02 0004
   Revision: --------    Serial number: EJ1BPA3200HZBJ0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 6BEDF99382FC331750-803E
   Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
   Component: TSG FA        H05 0212
   Coding: 011C16204000620002080002
   Shop #: WSC 02312 785 00200
   VCID: 42B37437DDF6125FC3-8016
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0026150376
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0158532012
   Coding: 013A062020B9040083200904200104000000000000000000000000000000
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   VCID: 41B17B3BD8F00947DA-8014
   Revision: --------    Serial number: 00000000134909
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A633C974D86EA1FEB-807E
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Serial number: 110915-0004-118
   Coding: 1122A6101002A300
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2C6F3A8F4772F42F19-8078
Address 56: Radio
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010814204000620002080002
   VCID: 44BF722FC7E21C6FF1-8010
Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Revision: 5G001001    Serial number: 00000155492496
   Coding: 0109080000000000
   VCID: 71D1EBFBA8D0D9C76A-8024
   Component: TSG HR        H04 0212
End-------------------------(Elapsed Time: 04:46)--------------------------
Finnspring
New Member
Thanks Mari, im more wiser now. :) *or not, something went wrong :D *
https://imgur.com/SjoKErC
First happened this
https://imgur.com/4hrp5Xy
Then this one
https://imgur.com/86su1Fx
Red screen...
https://imgur.com/VT6FPCi
Red screen still..
Now the whole system is black, example i start car immediatly it shows that red screen, trigger shutdown and it goes full black screen after that 60seconds, but weirdly there is some "back" light still... Same when i put SD card to in and try update again, straight to red screen and after that black... nothing else...
Mari
C?ID=150535
Never try to fix things that are not broken...
We need more information... for instance where you got your update? And what procedure you have to follow to install the firmware update? I presume you have first downloaded something, but what step is the next one?
https://upgrademyaudi.net/tutorials/updating-the-firmware/
IMPORTANT: PLEASE DO NOT USE MACOS TO COPY THE FILES. MACOS CREATING LOTS OF HIDDEN FILES AND MMI CAN BE LITTLE BIT CONFUSED AND DISPLAY ERROR. SD CARD MUST BE FORMATTED AS FAT32!
Mari
C?ID=150535
Maybe this will help:
If you're lucky like I was, simply reformat the memory card and put the firmware that you were trying to upgrade to (NOT THE FW THAT YOU ALREADY HAVE).
Stick it into the MMI and reboot it holding the 3 buttons, this should kick the unit into emergency update mode
Finnspring
New Member
Hi again! Thanks for tips. Here's the link for updates and maps
https://www.a5oc.com/threads/mmi-3g...2-and-firmware-updates-currently-2017.113737/
My FW and maps is original from 2012 and wanted newer FW and maps so i can find new routes :DD And my BT connection was so messy some times so i thinked i want to newer FW to fix problems..
I have tryed to force reboot but nothing else happened, same think everytime... I think i need some emergency update file so i can force MMI to emergency mode, so i can update FW again and open Green menu etc... But do not know where i can find that kind of file.. :S
Or does anyone know if i can code MMI system back to work with VCDS or somehow?
Mari
C?ID=150535
Firmware doesn't fix hardware problems... some phones have good BT connections, others don't... Many forget that they can clean-up their BT connections on their phones and even on the infotainment-system in the car...
I'm afraid this problem can't be solved with VCDS... did you ask on the A5OC-forum for help? They provide the files... so they probably know how to solve things when it goes wrong!
