- Aug 11, 2019
- 31
- 14
- Toronto, Canada
- C?ID=55522
MY2019 Audi RS3, 2.5TFSI EA855 EVO (DAZA)
Autoscan
Believe these are the channel maps. I obtained them in the different states by going to Applications-->Controller Channel Map-->Single Controller Address "01" and Selecting Measuring Values and Adaptations and logging to CSV. If there is a different procedure to get them please let me know and I'll pull new ones.
Engine Channel Map - Cold Engine, Engine Off
Engine Channel Map - Cold Engine, Engine Idle
Engine Channel Map - Engine +80C, Engine Idle
Engine Channel Map - Engine +80C, Engine Off
Blockmap - 01 - Engine
- Canadian Model
- Black Optics
- Technology Package
- Staggered Rim/Tire Setup (255/30/R19 on 19x8.5 front, 235/35/R19 on 19x8 rear)
- RS Sport Exhaust
Autoscan
Sunday,11,August,2019,16:06:42:40778
VCDS Version: 19.6.1.0 (x64) HEX-NET CB: 0.4508.4
VIN: WUABWGFF9KA906644 License Plate: INITIAL-SCAN
Mileage: 500km-310mi Repair Order:
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 29 2B 39 3C 42 44 47
4B 52 5F 6C A5 BB BC CF D6 D7
VIN: WUABWGFF9KA906644 Mileage: 500km-310miles
Address 01: Engine (------DAZA) Labels: None
Part No SW: 8V0 907 404 J HW: 07K 907 309 E
Component: R5 2.5l TFSI H22 0002
Revision: 53H22000
Coding: 0A250032246600053620
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM25TFS0118V0907404J 001003
ROD: EV_ECM25TFS011_AU37.rod
VCID: 40CC8C12DB1C894FD9-8014
Readiness: 1110 0101
Part No SW: 0DL 300 013 E HW: 0GC 927 711 G
Component: GSG DQ500 H06 3023
Revision: 00H06V07
VCID: 2C14C8A247947D2F15-8078
Part No SW: 8V0 614 517 D HW: 8V0 614 517 C
Component: ESC H25 0640
Revision: 00000000 Serial number: 61299000001134
Coding: 2EAA6B7DD4990BAF89970B6840956974D62BD091D0029636184150D482A8420000000012121212B835351919323200
Shop #: WSC 06335 790 00021
ASAM Dataset: EV_Brake1UDSContiMK100IPB 037008
ROD: EV_Brake1UDSContiMK100IPB_037_VW41.rod
VCID: 3A38FEFABDC0D39F97-806E
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000 Serial number: 0518424816
Coding: 030C0C1720
VCID: 43C6831ECA0A9257C4-8016
Part No SW: 8V0 820 043 AF HW: 8V0 820 043 AF
Component: AC Automat H03 0150
Revision: 20003000 Serial number: 00000001840853
Coding: 03000015010000000000000000001400
ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
VCID: 76A02ACAC95877FFB3-8022
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: 7F909DA900PAG0MUFU03
Part No SW: 5Q0 937 085 BS HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H38 0273
Serial number: 01001915700990
Shop #: WSC 06324 790 00021
ASAM Dataset: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 0B566B3EA2DA1A17FC-805E
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 190517 043 0585
Serial number: 190523211029
Coding: 0A47F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 21926848X81A955547A0
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 21 03 2019 20000488
Serial number: 00000000000047137102
Sun Roof:
Component: J245 PS73.404 H04 0005
Serial number: 0000FST002CJ7CG00000
Coding: 101F00
Steering Column Switch:
Subsystem 6 - Part No SW: 82A 953 521 CQ HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0070
Serial number: 00000006061904400042
Part No SW: 5QA 919 294 C HW: 5QA 919 294
Component: PDC 8 KanalH07 0050
Serial number: 000308418019157
Coding: 0470155811
ASAM Dataset: EV_EPHVA18AU3700000 009039
VCID: 4CD4A822E7545D2F35-8018
Part No SW: 5Q0 907 572 P HW: 5Q0 907 572 J
Coding: B50087C119FFC4247498815580302600000000000000000004
VCID: 44C48002CF04956FFD-8010
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 H HW: 8V0 907 376 F
Component: DAEMPFUNGS-SG H11 0083
Serial number: 230519067
ASAM Dataset: EV_AudiMagneRide 003007
ROD: EV_AudiMagneRide_003.rod
VCID: 46C09A0AF938A77FE3-8012
Serial number: 003GCR0C1Z8S
Coding: 9DCCFCC0008000005000001AC248000000C5
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 47DE970EFE32BE7718-8012
Belt Pretensioner left:
Serial number: 34230167A04061921314
Coding: 333135
Belt Pretensioner right:
Serial number: 34230168A05061930047
Coding: 333135
Occupant Detection:
Serial number: 694000000000001W9YFO
Coding: 303433
Subsystem 4 - Part No SW: ----------- HW: 480 000 606 19
Serial number: 35700000000FC189BC30
Subsystem 5 - Part No SW: ----------- HW: 480 000 606 19
Serial number: 3580000000071BD8EC3%
Subsystem 6 - Part No SW: ----------- HW: 480 400 406 19
Component: SideSensor_Dr 005 6149
Serial number: 3510001BCF001341D981
Subsystem 7 - Part No SW: ----------- HW: 480 400 406 19
Component: SideSensor_Pr 005 6149
Serial number: 3520001BCF001342799+
Subsystem 8 - Part No SW: ----------- HW: 480 402 305 19
Component: FrontSensor_D 005 6149
Serial number: 3550001A4F001357F4A2
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 402 305 19
Component: FrontSensor_P 005 6149
Serial number: 3560001A4F001358249X
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI2
Part No SW: 8V0 920 790 C HW: 8V0 920 790 C
Component: FBenRDW H19 0109
Coding: 080F18537F8800080284EC001800001000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001032
ROD: EV_DashBoardFPKAU37X.rod
VCID: 3C34F8E2B7F4EDAF85-8068
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 442 4368
Revision: -------- Serial number: 0009628985
Coding: 0301000434085D005B00801EB80B00000001010000000000000000000000
ROD: EV_GatewNF.rod
VCID: 6E9002AAB1084F3F7B-803A
Component: 1-01-09-01-04
Subsystem 2 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0004
Serial number: 20190529131859 31365
Subsystem 3 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 7808151505
Part No SW: 0CQ 907 554 K HW: 0CQ 525 130
Component: Haldex4Motion H55 7762
Serial number: HA1-00006.05.19
Coding: 0601
Shop #: WSC 06325 790 00021
VCID: 4DD2A5261C4E542722-8018
Address 29: Left Light (J1018) Labels: 8S0-907-397.clb
Part No SW: 8S0 907 397 D HW: 8S0 907 397 D
Component: LCM_MQB H07 0022
VCID: 42C8861AD5109B5FCF-8016
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 19000159332015
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_AU37.rod
VCID: 312AD9D660B610C726-8064
Address 39: Right Light (J1023) Labels: 8S0-907-397.clb
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 H HW: 3Q0 907 566
Component: MRR1Rear H25 0630
Revision: --------
Coding: 04C002
VCID: 3D32F5E6ACEEE4A7B2-8068
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS002 0287
Serial number: YE007SEL0107B
Coding: 005E1B205000008000000002
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Coding: 911E0000
ROD: EV_SteerAssisMQB_015.rod
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 466 B HW: 81A 035 466
Component: MIB2_amp_P_A3 H10 0440
Revision: 00000001 Serial number: AUZ8ZAK5F02HGWK
Coding: 0173030000AAAA2AAA0000010000
ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
ROD: EV_AMPMst16C9Gen2ALPI.rod
VCID: 240420822F44B56FDD-8070
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 03061910522025
Coding: 000000050900143206112300040000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW41.rod
VCID: 3522EDC694DE3CE77A-8060
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS002 0287
Serial number: YE007SEI1690E
Coding: 005E13205C00008000000002
Part No SW: 8V1 035 880 C HW: 8V1 035 880 C
Component: MU-P-LNS-US 055 1363
Serial number: A702F0KS017736
Coding: 017361020000000011220002041A00102F0028E4017001047E
Subsystem 1 - Part No SW: V03 959 802 DL HW: -----------
Component: NAR 2019 --- 0069
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9K1Y0JDV0
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BT HW: 8V0 919 614 BT
Component: ControlUnit_H H85 0858
Serial number: ALJAL114121800050385
Component: Gracenote2 --- 3013
Component: RVC Compact H18 0231
Coding: 0273010102002001400040
VCID: 393AE1F6B8C6D8879E-806C
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H12 0610
Serial number: 20051915P11679
Coding: 040307010000020101222346814E490080000E20012000
ROD: EV_MFKBoschMQBB_002_VW36.rod
Part No SW: 8W1 959 595 D HW: 8W1 959 595 D
Component: TSG HFS004 0189
Serial number: YE007SEM13872
Coding: 000E13204000008000000002
VCID: 4ED0A22A11486F3F5B-801A
Component: TSG HBFS004 0189
Serial number: YE007SEM1383E
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 H HW: 3Q0 907 590
Revision: --------
Coding: 04C002
ASAM Dataset: EV_RearRadarS2BoschVW48X 001007
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
VCID: 177E074EEE12EEF748-8042
Component: LED1R H09 0008
End----------(Elapsed Time: 01:48, VBatt start/end: 12.1V/12.0V)-----------
;SW:8V0-907-404-J HW:07K-907-309-E --- Engine
;Component:R5 2.5l TFSI H22 0002, Coding:0A250032246600053620
;EV_ECM25TFS0118V0907404J,001003,EV_ECM25TFS011_AU37.rod
;Sunday,11,August,2019,16:26:49:40778
;VCDS Version: Release 19.6.1 (x64) Data version: 20190529 DS308.0
;VCID: 40CC8C12DB1C894FD9-8014
IDE01945-Engine run-in oil pressure,active ,1
IDE02332-Deactivate production mode,00 00 00 ,3
IDE04158-Activation of start-stop function,active ,1
IDE06726-Timing deviation after chain replacement: intake bank 1,2.56 ∞,2
IDE06728-Timing deviation after chain replacement: exhaust bank 1,-0.13 ∞,2
IDE06730-Timing deviation after other repairs: intake bank 1,0.00 ∞,2
IDE06732-Timing deviation after other repairs: exhaust bank 1,0.00 ∞,2
IDE06734-Timing deviation: current value intake bank 1,0.00 ∞,2
IDE06736-Timing deviation: current value exhaust bank 1,0.00 ∞,2
IDE06738-Chain elongation: no. of valid initial values: intake bank 1,1 ,1
IDE06740-Chain elongation: no. of valid initial values: exhaust bank 1,1 ,1
IDE06742-Chain elongation: initial values valid: intake bank 1,not active ,1
IDE06744-Chain elongation: initial values valid: exhaust bank 1,not active ,1
IDE07855-Deactivation of warm travel request,active ,1
IDE10261-MAS10172-Operating mode selec.-DI operation,not activated ,4
IDE10261-MAS10174-Operating mode selec.-CNG operation,not activated ,4
IDE10261-Operating mode selec.-,not activated ,4
Elapsed Time: 00:04
;Sunday,11,August,2019,16:31:35:40778
Elapsed Time: 00:04
;Sunday,11,August,2019,16:42:54:40778
Elapsed Time: 00:04
;Sunday,11,August,2019,16:45:21:40778
Elapsed Time: 00:04
;Sunday,11,August,2019,16:11:52:40778
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),WUABWGFF9KA906644,
IDE00019,Voltage terminal 30,11.980, V
IDE00020-ENG57549,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine speed,0, /min
IDE00025,Coolant temperature,26, ∞C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00076,Status of initial fuel filling,was not yet started,
IDE00078,Time since engine start,0, s
IDE00083,Throttle valve position (absolute),14.5, %
IDE00084,Absolute load value,0, %
IDE00085,Normed load value,0.0, %
IDE00086,Accelerator position,15, %
IDE00090-ENG57549,selected gear-Bits 0-7,0,
IDE00094,Kick-down status,Not operated,
IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00100,Engine torque,0.0, Nm
IDE00148,Median injection timing,0.000, ms
IDE00150,Pressure in brake booster,998.44, hPa
IDE00151,Oil fill level,55.432, mm
IDE00152,Oil warning threshold,32.500, mm
IDE00155,Timing angle retardation cylinder 1,0.0, ∞
IDE00156,Timing angle retardation cylinder 2,0.0, ∞
IDE00157,Timing angle retardation cylinder 3,0.0, ∞
IDE00158,Timing angle retardation cylinder 4,0.0, ∞
IDE00159,Timing angle retardation cylinder 5,0.0, ∞
IDE00167,Exhaust temperature 1 bank 1,25.4, ∞C
IDE00172,A/C compressor torque,0.0, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-23.000, ∞
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-23.000, ∞
IDE00178,Camshaft adjustment intake bank 1: specified value,30.000, ∞
IDE00179,Camshaft adjustment intake bank 1: actual value,30.000, ∞
IDE00182,Camshaft adaptation intake bank 1: phase position,0.00, ∞
IDE00184,Camshaft adaptation exhaust bank 1: phase position,0.00, ∞
IDE00186,Fuel low pressure: actual value,668.0, kPa
IDE00187,Coolant temperature at engine start,26.3, ∞C
IDE00188,Fuel high pressure: actual value,0.6680, MPa
IDE00190,Charge air pressure specified value,948.52, hPa
IDE00191,Charge air pressure: actual value,994.92, hPa
IDE00194,Coolant temperature at radiator output: specified value,90.0, ∞C
IDE00196,Engine oil temperature,25.7, ∞C
IDE00201,High fuel pressure: specified value,10.1595, MPa
IDE00202,Low fuel pressure: specified value,650.0, kPa
IDE00304,Fuel level,46.00, l
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00348,Intake air temperature,27, ∞C
IDE00349,Throttle valve position: normed,5, %
IDE00350,Air mass: specified value,7.8, kg/h
IDE00354,Engine start: start synchronization,EPM_MODE_WAIT,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,1,
IDE00355-ENG57549,Cruise Control System (CCS): status-Bits 0-7,2,
IDE00357,Fuel temperature,45.0, ∞C
IDE00358,Limitation: torque,1000.0, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00361,Ambient air pressure,998.44, hPa
IDE00371,Fuel consumption,0.00, l/h
IDE00375,Generator: load signal,0.02, %
IDE00380,Coolant fan 1: activation,10.00, %
IDE00392,Accelerator pedal: sensor voltage 1,742.2, mV
IDE00393,Accelerator pedal: sensor voltage 2,364.8, mV
IDE00394,Camshaft position: start of phase window,118.70, ∞
IDE00405,Crankshaft speed (RPM),0.0, /min
IDE00406,Camshaft speed (RPM),0.0, /min
IDE00407-ENG57549,Rail pressure regulation: status-Bits 0-7,0,
IDE00412-ENG57549,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG57549,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG57549,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG57549,Starter control: terminal 50 acknowledgment-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00443-ENG57549,Accelerator pedal: switch positions-Bits 0-7,8,
IDE00445,Unlearning counter according OBD,255,
IDE00450,Operating Instructions,--no display--,
IDE00451,Currently running routine,0,
IDE00474,Ambient air pressure,99, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,0.0, Nm
IDE00496-ENG57549,Activation of oil pressure switch valve-Bits 0-7,1,
IDE00541,Acceleration,0.000, m/s≤
IDE00556,Outside air temperature,25, ∞C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),1.013 Lambda / -0.004 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.455, V
IDE00560-MAS04122,Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00582,Equivalence ratio target value,1.999, Lambda
IDE00583,Throttle valve specified value,2, %
IDE00584,Distance driven since erasing DTC memory,0, km
IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,0, km
IDE00588,Fuel tank fill level,83.9, %
IDE00592,Oxygen sensor control status,Engine off,
IDE00593,Ignition timing adjustment cylinder 1,0.0, Degrees
IDE00594,Absolute intake pressure,99, kPa abs
IDE00595,Allocation of oxygen sensors,B1S1 B1S2 ,
IDE00597,Long term adaptation of mixture formation bank 1,0.0, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,0,
IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
IDE00608,Type of fuel,Gasoline,
IDE00612,Target position of EVAP canister valve,0.0, %
IDE00699,ESI: minimum oil level in service interval,22.732, mm
IDE00700,ESI: maximum oil level in service interval,24.768, mm
IDE00727,Test steps still to be performed,0,
IDE00738,Test of oxygen sensors bank 1: Delta-Lambda,0.00000,
IDE00752,Test of oxygen sensor control.,Test off,
IDE00752-ENG127302,Test of oxygen sensor control.-Test_Program_Channel 213,235,
IDE00787,Cause for cancellation,0,
IDE00949,Hide cylinder,not active,
IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
IDE00973,Outside air temperature,25.5, ∞C
IDE01076,Time since ignition off,55072, s
IDE01098,Test of knock sensors: short trip result,Test off,
IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,1.0000,
IDE01236,Coolant recirculation pump,0.00, %
IDE01260,Generator power,0, W
IDE01266-ENG57549,Coolant shut-off valve-Bits 0-7,2,
IDE01267,Height correction,0.98566,
IDE01369,Intake manifold runner control (IMRC): offset closed,2.695, V
IDE01378,High fuel pressure: control deviation,9.4915, MPa
IDE01384,Map controlled engine cooling thermostat: specified value,0.00, %
IDE01385-ENG57549,Wear index-Bits 0-7,0,
IDE01386-ENG57549,Soot index-Bits 0-7,0,
IDE01405-ENG57549,Status of starter activation-Bits 0-7,0,
IDE01590,Status of brakes,Not operated,
IDE01590-ENG127367,Status of brakes-Test_Program_Channel 600,167,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.450, V
IDE01649,Throttle valve position 1,6.30, %
IDE01650,Throttle valve position 2,15, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test off,
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,235,
IDE01680,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve,Test off,
IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,235,
IDE01773,Misfire sum counter,0,
IDE01774,Status misfire recognition,blocked,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,104,
IDE01775,Misfires per 1000 revolutions of cylinder 1,0,
IDE01776,Misfires per 1000 revolutions of cylinder 2,0,
IDE01777,Misfires per 1000 revolutions of cylinder 3,0,
IDE01778,Misfires per 1000 revolutions of cylinder 4,0,
IDE01834,Battery voltage,11980, mV
IDE01869,Long-term fuel trim bank 1 at idle,0.00, %
IDE01870,Oxygen sensor after catalytic converter: operating status,Test off,
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,235,
IDE01873,Test of catalytic converter: measured value,1.0000,
IDE01874,Test of catalytic converter: result,Test off,
IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,235,
IDE01875,Required torque adjustment by idling regulator,0.000, %
IDE01876,Adaptation of loss torque,0.0, Nm
IDE01877-ENG57549,Operating condition of idle speed control-Bits 0-7,0,
IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000000 ,
IDE01879,Adaptation of throttle valve: result,ADP is OK,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4114.0, mV
IDE01884,Camshaft adjustment intake bank 1: activation,0.000, %
IDE01885,Shut off of oxygen sensor control,l-Reg.OFF,
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,3,
IDE01887,Adaptation of Fuel Pump (FP),0.3, kPa
IDE01888,Cold start enrichment: adaptation area 1,1.000,
IDE01889,Cold start enrichment: adaptation area 2,1.000,
IDE01890,Cold start enrichment: adaptation area 3,1.000,
IDE01891,Cold start enrichment: adaptation area 4,1.000,
IDE01892,Cold start enrichment: adaptation area 5,1.000,
IDE01893,Fuel pump: specified value,10.001, %
IDE01898,Load value: specified value,126.66, %
IDE01899,Load value: corrected specified value,126.66, %
IDE01900,Charge press. ctrl.: spec. value,0.0, %
IDE01901,Lost torque adaptation: idle,0.0, Nm
IDE01902,Lost torque adaptation A/C compressor,0.0, Nm
IDE01903,Lost torque adaptation driving mode,0.0, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,0.0, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,1.00000,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,1.04150,
IDE01911,Leakage air,-1.1, kg/h
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,15.9998,
IDE01916,Leakage recognition from oxygen sensor control,15.9998,
IDE01917,Leakage after throttle valve,0.000,
IDE01918,Leakage before throttle valve,0.000,
IDE01919-ENG57549,Leakage recognition: status-Bits 0-7,212,
IDE01920,Oxygen sensor: mixture correction with active diagnosis,0,
IDE01922,Vehicle distance driven,500, km
IDE01923,Control module distance driven,499614, m
IDE01924,Load shift flaps: actual value,0.806, %
IDE01925,Load shift flaps: specified value,0.000, %
IDE01926,Adaptation of load shift flaps,2.695, V
IDE01927,Result of load shift flap adaptation,ADP is OK,
IDE01927-ENG129325,Result of load shift flap adaptation-Test_Program_Channel 514,2,
IDE01928,Close cam shaft angle at quantity control valve,98.5, ∞
IDE01929,Open cam shaft angle at quantity control valve,-58.5, ∞
IDE01930,High pressure regulation: adaptation value,0.0000, MPa
IDE01932,High pressure pump injection volume,260.05, mm≥
IDE01975,Numb.of misfir.: cylinder 1,109,
IDE01976,Numb.of misfir.: cylinder 2,89,
IDE01977,Numb.of misfir.: cylinder 3,108,
IDE01978,Numb.of misfir.: cylinder 4,84,
IDE01986,Contact for tank leak test,Open,
IDE01986-ENG129322,Contact for tank leak test-Test_Program_Sw SAVW NVLD SWI UBYTE,0,
IDE02115-ENG57549,Adjustment requirements for basic setting-Bits 0-7,178,
IDE02116,Exhaust gas temperature before catalytic converter,25.44, ∞C
IDE02117,Relative load value,82.88, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,0.03, MPa
IDE02540-ENG57549,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02742,Oil pressure actual value,95.9, kPa
IDE02756,Number of manual engine starts,68,
IDE02757,Number of automatic engine starts,0,
IDE02832,Coolant circulation pump: activation,0.00, %
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function restriction,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,active,
IDE03008-MAS06604,Stop process prevented-Start-stop sensor system,not active,
IDE03008-MAS06605,Stop process prevented-Regeneration operation,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,0,
IDE03010-MAS01627,Number of prevented stop processes-Steering,0,
IDE03010-MAS02040,Number of prevented stop processes-Play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function restriction,3,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,2,
IDE03010-MAS04591,Number of prevented stop processes-Diagnosis of air system,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power insufficient,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary consumers power too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Test of thermostat not complete,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,0,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,13,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration operation,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,255,
IDE03010-MAS08032,Number of prevented stop processes-Event memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Adaptation active,0,
IDE03010-MAS11563,Number of prevented stop processes-Engine hood open,0,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE03010-MAS12864,Number of prevented stop processes-Tighter traffic flow detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Motor protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel salinization protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust emission control diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in the start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function restriction,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power insufficient,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary consumers power too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-Cat. heater,0,
IDE03011-MAS11563,Number of requested start processes-Engine hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Motor protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel salinization protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in the start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test off,
IDE03108-ENG127369,Result of test of oxygen sensors bank 1-Test_Program_Channel 976,235,
IDE03189-ENG102843,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Air Density,0, counts
IDE03189-ENG102547,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Brake Boost,0, counts
IDE03189-ENG103808,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Fuel Mixture Adaption,0, counts
IDE03189-ENG101159,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Random,0, counts
IDE03189-ENG104187,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Regeneration Mode,0, counts
IDE03189-ENG100165,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Start Behavior,0, counts
IDE03189-ENG99535,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Air Density,0,
IDE03189-ENG103192,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Brake Boost,0,
IDE03189-ENG99739,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG100597,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Random,0,
IDE03189-ENG101689,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100582,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Start Behavior,0,
IDE03189-ENG101720,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Air Density,0,
IDE03189-ENG100669,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Brake Boost,0,
IDE03189-ENG100932,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG101264,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Random,0,
IDE03189-ENG102430,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101165,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Start Behavior,0,
IDE03189-ENG101829,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Air Density,0, km
IDE03189-ENG99286,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Brake Boost,0, km
IDE03189-ENG102800,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Fuel Mixture Adaption,0, km
IDE03189-ENG102751,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Random,0, km
IDE03189-ENG101356,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Regeneration Mode,0, km
IDE03189-ENG99669,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Start Behavior,0, km
IDE03189-ENG103828,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Air Density,0,
IDE03189-ENG103959,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Brake Boost,0,
IDE03189-ENG102465,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG102710,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Random,0,
IDE03189-ENG103568,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100877,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Start Behavior,0,
IDE03189-ENG101280,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Air Density,0,
IDE03189-ENG99226,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Brake Boost,0,
IDE03189-ENG101471,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG102877,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Random,0,
IDE03189-ENG100198,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101676,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Start Behavior,0,
IDE03189-ENG103694,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Air Density,0,
IDE03189-ENG104142,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Brake Boost,0,
IDE03189-ENG100353,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG100878,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Random,0,
IDE03189-ENG101433,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100557,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Start Behavior:,0,
IDE03190-ENG100538,Number of requested start processes (statistics)-SSEUI Counter Start Desired By Brake Boost,0, counts
IDE03190-ENG100036,Number of requested start processes (statistics)-SSEUI Counter Start Desired By High Engine Temperature,0, counts
IDE03190-ENG103639,Number of requested start processes (statistics)-SSEUI Counter Start Desired By Low Engine Temperature,0, counts
IDE03190-ENG102427,Number of requested start processes (statistics)-SSEUI Day Start Desired By Brake Boost,0,
IDE03190-ENG99459,Number of requested start processes (statistics)-SSEUI Day Start Desired By High Engine Temperature,0,
IDE03190-ENG99665,Number of requested start processes (statistics)-SSEUI Day Start Desired By Low Engine Temperature,0,
IDE03190-ENG99329,Number of requested start processes (statistics)-SSEUI Hours Start Desired By Brake Boost,0,
IDE03190-ENG100944,Number of requested start processes (statistics)-SSEUI Hours Start Desired By High Engine Temperature,0,
IDE03190-ENG100535,Number of requested start processes (statistics)-SSEUI Hours Start Desired By Low Engine Temperature,0,
IDE03190-ENG102737,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Brake Boost,0, km
IDE03190-ENG101377,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By High Engine Temperature,0, km
IDE03190-ENG99682,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Low Engine Temperature,0, km
IDE03190-ENG102760,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Brake Boost,0,
IDE03190-ENG103163,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By High Engine Temperature,0,
IDE03190-ENG101771,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Low Engine Temperature,0,
IDE03190-ENG100816,Number of requested start processes (statistics)-SSEUI Month Start Desired By Brake Boost,0,
IDE03190-ENG104013,Number of requested start processes (statistics)-SSEUI Month Start Desired By High Engine Temperature,0,
IDE03190-ENG104020,Number of requested start processes (statistics)-SSEUI Month Start Desired By Low Engine Temperature,0,
IDE03190-ENG103223,Number of requested start processes (statistics)-SSEUI Year Start Desired By Brake Boost,0,
IDE03190-ENG103563,Number of requested start processes (statistics)-SSEUI Year Start Desired By High Engine Temperature,0,
IDE03190-ENG103316,Number of requested start processes (statistics)-SSEUI Year Start Desired By Low Engine Temperature,0,
IDE03246,Neutral position sensor: upper adaptation value,0, mV
IDE03247,Neutral position sensor: lower adaptation value,0, mV
IDE03262,Adapt of angle sensor 1 f throttle valve,0.500, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.497, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.739, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.257, V
IDE03362,Requested transmission torque,1000.0, Nm
IDE03363,Numb.of misfir.: cylinder 5,79,
IDE03393-ENG57549,Selector lever position-Bits 0-7,8,
IDE03406,Throttle valve position bank 2: normed,4.260, V
IDE03489,Chain extension control chain 1,0.00, ∞
IDE03490,Chain extension control chain 2,0.00, ∞
IDE03493-ENG121091,Driver door status-Dsplb Drv Door Act Opn,1,
IDE03584-ENG57549,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,System malfunction,
IDE03586-ENG57549,Starting requirements for active participants-Bits 0-7,0,
IDE03587-IDE02697,Stop overrides for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stop overrides for active participants-A/C,not active,
IDE03587-MAS00127,Stop overrides for active participants-brakes,not active,
IDE03587-MAS00506,Stop overrides for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stop overrides for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stop overrides for active participants-Transmission,not active,
IDE03587-MAS01106,Stop overrides for active participants-Level control system,not active,
IDE03587-MAS01490,Stop overrides for active participants-Energy management,not active,
IDE03587-MAS01627,Stop overrides for active participants-Steering,not active,
IDE03587-MAS02237,Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stop overrides for active participants-All-wheel electronics,not active,
IDE03587-MAS03757,Stop overrides for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stop overrides for active participants-Engine,active,
IDE03587-MAS06709,Stop overrides for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stop overrides for active participants-Parking aid,not active,
IDE03587-MAS13018,Stop overrides for active participants-Front sensor system for driver assistance systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Engine,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor system for driver assistance systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication error,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-Engine hood open,active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03660,Longitudinal acceleration,-0.249, m/s≤
IDE03692-ENG57549,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7,202,
IDE03693-ENG57549,Monitoring status of additional Onboard Diagnosis-Bits 0-7,229,
IDE03700,Status adaptation dew point end,ADP is running,
IDE03700-ENG127325,Status adaptation dew point end-Test_Program_Channel 860,1,
IDE03709,Angle difference actual-specified camshaft adjuster,0.000, ∞
IDE03711,Mass flow through throttle valve,0.0, kg/h
IDE03767,Engine status,COENG_READY,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,1,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,0.000, %
IDE03806-ENG57549,Oxygen sensor bank 1 sensor 1: status-Bits 0-7,0,
IDE03807-ENG57549,Oxygen sensor bank 1 sensor 2: status-Bits 0-7,0,
IDE03816,Exhaust flap bank 1,OFF,
IDE03816-ENG129421,Exhaust flap bank 1-Test_Program_Channel 825,136,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,0.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,0,
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,Htg.aC.OFF,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,217,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,0.00, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,0.000, %
IDE03832,Oxygen sensor bank 1 sensor 2: response time,0,
IDE03834,Oxygen sensor bank 1 sensor 2: response time filtered,0,
IDE03836,Result of O2 sensor aging test bank 1 after cat. conv.,B1-S2 OK,
IDE03836-ENG129323,Result of O2 sensor aging test bank 1 after cat. conv.-Test_Program_Channel 2114,209,
IDE03838,Oxygen sensor aging test bank 1 after catalytic converter,0,
IDE03876,Misfires per 1000 revolutions of cylinder 5,0,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,1.00000,
IDE03954-ENG112663,Throttle valve adaptation steady state condition-Badko se,0,
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE03998,Clutch Position Sensor,0.0, %
IDE04002,Charge press. ctrl.,BP_A act:99, kPa
IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:630/--- kPa,
IDE04234,Heat quantity f dew pt end before cat conv bank 1: modeled,0.000000, kJ
IDE04236,Heat quantity f dew pt end behind fr cat conv bank 1: modeled,0.000000, kJ
IDE04238,Heat quantity f dew pt end behind main cat conv bank 1: modeled,0.000000, kJ
IDE04240,Counter start bef dew pt end f O2 sensor bef cat conv bank1,0,
IDE04242,Counter start bef dew pt end f O2 sensor beh fr cat conv bank1,0,
IDE04244,Count start bef dew pt end f O2 sensor beh main cat conv bank1,1,
IDE04409,Intake manifold pressure: corrected,999.38, hPa
IDE04410,Intake manifold pressure: target value,297.58, hPa
IDE04414,Cat conv temp: modeled,20, ∞C
IDE04491,Temp sensor for fuel tank leakage diagnosis,-48.0, ∞C
IDE04604,Accelerator pedal travel,0.00, %
IDE04615,Segment adaptation for rough running: status,0,
IDE04630,AVS valve stroke position: current,true,
IDE04630-ENG06942,AVS valve stroke position: current-Test_Program_Xaied Fa Ehan Adc jnotd jb n 0 A1T UBYTE,1,
IDE04637,Engine temperature management actuator,99.74, %
IDE04638,Transmission coolant valve,False result,
IDE04638-ENG127289,Transmission coolant valve-Test_Program_B TRUE UBYTE,0,
IDE04651,Torque request: A/C compressor,0.0, Nm
IDE04654-ENG57549,CAN status - engine control module-Bits 0-7,0,
IDE04655-ENG57549,CAN status - transmission control module-Bits 0-7,0,
IDE04656-ENG57549,CAN status - brake control module 1-Bits 0-7,0,
IDE04657-ENG57549,CAN status - brake control module 2-Bits 0-7,0,
IDE04670,Crankshaft signal evaluation: status,WAITSIG,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,2,
IDE04677,O2 sensor 1 bank 1: O2 sensor actual value,15.9998,
IDE04689,Starter control: Start interruption status,False result,
IDE04689-ENG127289,Starter control: Start interruption status-Test_Program_B TRUE UBYTE,0,
IDE04691,Calculated reducing transmission intervention torque,1000.0, Nm
IDE04692,Reducing desired torque intervention of ESP,50000.0, Nm
IDE04693,Increasing desired torque intervention of ESP,-50000.0, Nm
IDE04695-ENG99946,Immobilizer snapshot A-Sia Error Snap A,00 00 00,
IDE04696-ENG102592,Immobilizer snapshot B-Sia Error Snap B,00 00 00,
IDE04814,Transmission oil cooler valve,False result,
IDE04814-ENG127289,Transmission oil cooler valve-Test_Program_B TRUE UBYTE,0,
IDE04820,Fuel content due to degassing of engine oil,0.00, %
IDE04858,Brake booster low pressure actual value,0.00, hPa
IDE04872,Brake pedal value sensor: relative value filtered,0.00, %
IDE04887,Powertrain target torque,-715.8, Nm
IDE04889,Target torque for combustion engine crankshaft level,-42.3, Nm
IDE05128,Intake air temperature in intake manifold bank 1,27.0, ∞C
IDE05135,Status of compressor release,Correct result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,1,
IDE05138,Shut-off timer: last engine shut-off time,55088, s
IDE05140,Intake manifold pressure raw value,994.92, hPa
IDE05213,Activation pulse duty factor for tank vent valve for diag,0.000, %
IDE05214,Tank vent valve diagnosis pressure difference ratio,0.00,
IDE05221,E-machine torque actual value,0.0, Nm
IDE05228,Operating hour counter,570, min
IDE05240-ENG57549,Request for A/C compressor power reduction-Bits 0-7,0,
IDE05241-ENG57549,A/C compressor release status-Bits 0-7,0,
IDE05261-ENG57549,Gear position sensor: last valid value-Bits 0-7,14,
IDE05327,Activation for electrical reserve coolant pump in HT circuit,0.00, %
IDE05332-ENG57549,Heat request from heater to thermal management-Bits 0-7,3,
IDE05333,Indicator light in AUTO HOLD button,6,
IDE05436,Engine operating condition,Idling,
IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
IDE05437,Outside air temperature via CAN,25.5, ∞C
IDE05438,Rear cat conv temp main cat conv model value,25.44, ∞C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000000,
IDE05441,ESI: Wear equivalent 2 calculated from wear index,0.00000000,
IDE05442,Roadway slope angle acceleration interface: calculated,-0.0236, rad
IDE05444,Air filling: specified value,16.34, %
IDE05445,Pressure before throttle valve of pressure sensor,998.98, hPa
IDE05446,LDR Control deviation uncorrected mean value,0,
IDE05449,Oxygen sensor 2 bank 1 internal resistance limit value,10000, Ohm
IDE05452,Dynamic test oxygen sensor 1 bank 1 time offset max M-value,0,
IDE05454,Oxygen sensor 1 bank 1 dynamic test min M-value time offset,0,
IDE05456,Dyn test oxy sensr 1 bank 1 controller vibration counter,0,
IDE05458,Dyn test oxy sensr 1 bank 1 max time offset counter,0,
IDE05460,Dynamic test oxygen sensor 1 bank 1 min time offset counter,0,
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00000,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,-273.15, ∞C
IDE05470,Cat converter oxygen storage capacity,0.0, mg
IDE05472,Cat converter oxygen storage capacity ref standardized,0,
IDE05474,Main cat converter OSC age correction factor,1.000,
IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
IDE05478,Exh mss flw bef main cat conv bank 1 filtered,0.0, kg/h
IDE05479,Misfire recognition reference moment,0.313, %
IDE05482,Tank venting adaptation factor,0.000,
IDE05484,Power steering pump desired actual moment for idling control,0.0, Nm
IDE05485-ENG57549,Irregular shutdown of the counter control mod-Bits 0-7,0,
IDE05486,Current system status,SYC_DRIVE,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05487,Coolant temperature linearized value,26.628, ∞C
IDE05488,Coolant temperature modeled value,26.3, ∞C
IDE05489,Coolant temperature max value,-48.0, ∞C
IDE05490,Coolant temperature min value,143.3, ∞C
IDE05491,Intake air temperature max value,20.3, ∞C
IDE05492,Intake air temperature min value,20.3, ∞C
IDE05508,Adaptation val cyl 1 with slow diagnosis,1.00000,
IDE05509,Adaptation val cyl 3 with slow diagnosis,1.00000,
IDE05510,Adaptation val cyl 4 with slow diagnosis,1.00000,
IDE05511,Adaptation val cyl 2 with slow diagnosis,1.00000,
IDE05512,Adaptation val cyl 1 with fast diagnosis,1.00000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,1.00000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,1.00000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,1.00000,
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,30,
IDE05797,Throttle valve adapter: specified value,1.700, %
IDE05808,Duration of positive deviation of idle speed regulation,0,
IDE05809,Counter: implaus. short-term adapt. values: misfire detection,0,
IDE05928,Fuel consumption since DTC memory last erased,0.000, l/100km
IDE05941-ENG112665,Enable condition: camshaft control-Bnws,0,
IDE05942,Activation for electrical reserve coolant pump 2: status,0.00, %
IDE05943,Release for supply to fuel pump,OFF,
IDE05943-ENG129326,Release for supply to fuel pump-Test_Program_Channel 890,136,
IDE06006,Idle speed specified value,790, /min
IDE06015,Time since term 15 OFF StartStop,55092, s
IDE06017,Camshaft position deviation from reference position,0.00, ∞
IDE06020,Intake air temperature in intake manifold bank raw value,27.0, ∞C
IDE06021,Intake air temperature before throttle valve: raw value,27.0, ∞C
IDE06023-ENG57549,BDE operating mode flag register-Bits 0-7,1,
IDE06039,Required RPM at idle speed,790.0, /min
IDE06040,High fuel pressure: regulator output value,3.8555, MPa
IDE06041-ENG57549,PDTC drive cycle conditions status-Bits 0-7,0,
IDE06043,Cylinder head temperature: actual value,27.5, ∞C
IDE06045-ENG57549,Output DTM status-Bits 0-7,0,
IDE06046,Status of error conditions of charge pressure control diagnosis,0,
IDE06047,Status adjust recovery conditions of charge press ctrl diagn,0,
IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
IDE06049,Pressure in brake booster: raw value,0.00, hPa
IDE06098,Sensor control factor: output value,1.00000,
IDE06112-ENG57549,Cylinder shut-off test-Bits 0-7,5,
IDE06192,Knock sensor: cylinder 2: voltage,16.768, V
IDE06193,Knock sensor: cylinder 3: voltage,16.768, V
IDE06194,Knock sensor: cylinder 4: voltage,16.768, V
IDE06195,Knock sensor: cylinder 1: voltage,16.768, V
IDE06198-ENG57549,Tank vent valve: diagnostic status-Bits 0-7,0,
IDE06255,Vehicle lateral acceleration,-0.07, g
IDE06256,Vehicle lateral acceleration: raw value,-0.07, g
IDE06257,Vehicle inclination acceleration angle: raw value,-12.557, m/s≤
IDE06307-MAS00106,Stop prevention history data-Year,2019,
IDE06307-MAS00107,Stop prevention history data-Month,8,
IDE06307-MAS00108,Stop prevention history data-Day,11,
IDE06307-MAS00109,Stop prevention history data-Hours,0,
IDE06307-MAS00110,Stop prevention history data-Minutes,54,
IDE06307-MAS00111,Stop prevention history data-Seconds,1,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Brake under pressure too low,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,Engine temperature too high,
IDE06308,Start request history data,Fuel salinization protection active,
IDE06308,Start request history data,Deceleration takeover active,
IDE06308,Start request history data,Hybrid battery power insufficient,
IDE06308,Start request history data,Engine hood open,
IDE06308,Start request history data,Engine temperature too low,
IDE06308,Start request history data,SCR System requires restart,
IDE06308,Start request history data,Steering,
IDE06308,Start request history data,Restriction in the start system,
IDE06308,Start request history data,Rolling vehicle,
IDE06308,Start request history data,Cat. heater,
IDE06308,Start request history data,Brake under pressure too low,
IDE06308,Start request history data,Sporadic function restriction,
IDE06308,Start request history data,Auxiliary consumers power too high,
IDE06308,Start request history data,Motor protection active,
IDE06386,Oil level: static measurement,55.564, mm
IDE06387,Oil level: last valid dynamic value,24.224, mm
IDE06388,Oil level: condition for static measurement fulfilled,1,
IDE06391,Oil temperature sensor 2,-0.0, ∞C
IDE06392,Oil temperature sensor 2: raw value,0.0, mV
IDE06393,Oil level: dynamic average value,131.068, mm
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06434-ENG112927,Oxygen control: bank 1: sensor 1: release status-Blrnd A,0,
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06445,Longitudinal acceleration: raw value,-0.282, m/s≤
IDE06446-ENG57549,Status: incline angle-Bits 0-7,1,
IDE06495,Results of testing of crankcase ventilation successful,0,
IDE06496,Results of testing of crankcase ventilation unsuccessful,0,
IDE06567,Start-stop function deactivation frequency counter,0,
IDE06568,Stop prevention by driver frequency counter,0,
IDE06569,Vehicle stopped frequency counter,0,
IDE06570,Oil level and oil temp. sensor: oil temperature in oil pan,25.7, ∞C
IDE06610,Vehicle standstill with stop frequency counter,0,
IDE06647-ENG57549,Start-stop switch status-Bits 0-7,0,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,0,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,128,
IDE06703-ENG57549,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
IDE06704-ENG57549,Drivetrain coordinator: brake fault status-Bits 0-7,0,
IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,0,
IDE06706-ENG57549,ACC variants-Bits 0-7,2,
IDE06707-ENG57549,CCS Switch-Bits 0-7,2,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,1,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,49,
IDE06709-ENG57549,ACC variants (coding)-Bits 0-7,3,
IDE06710-ENG57549,Cruise control system: permanent deactivation-Bits 0-7,255,
IDE06711-ENG57549,Cruise control system: temporary deactivation-Bits 0-7,255,
IDE06726,Timing deviation after chain replacement: intake bank 1,2.56, ∞
IDE06728,Timing deviation after chain replacement: exhaust bank 1,-0.13, ∞
IDE06730,Timing deviation after other repairs: intake bank 1,0.00, ∞
IDE06732,Timing deviation after other repairs: exhaust bank 1,0.00, ∞
IDE06734,Timing deviation: current value intake bank 1,0.00, ∞
IDE06736,Timing deviation: current value exhaust bank 1,0.00, ∞
IDE06738-ENG57549,Chain elongation: no. of valid initial values: intake bank 1-Bits 0-7,1,
IDE06740-ENG57549,Chain elongation: no. of valid initial values: exhaust bank 1-Bits 0-7,1,
IDE06742,Chain elongation: initial values valid: intake bank 1,not active,
IDE06742-ENG36870,Chain elongation: initial values valid: intake bank 1-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06744,Chain elongation: initial values valid: exhaust bank 1,not active,
IDE06744-ENG36870,Chain elongation: initial values valid: exhaust bank 1-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06758,Air mass since engine start,0.00, kg
IDE06761,Adaptation val cyl 5 with slow diagnosis,1.00000,
IDE06762,Adaptation val cyl 5 with fast diagnosis,1.00000,
IDE06800,A/C main switch status,Correct result,
IDE06800-ENG127289,A/C main switch status-Test_Program_B TRUE UBYTE,1,
IDE06828,Coolant recirc. pump 2: spec. value,10.00, %
IDE06944,A/C compressor: load current: act. value,0.00, A
IDE06946-ENG57549,Brake actuated status-Bits 0-7,0,
IDE06956-ENG57549,Driver-side belt buckle status-Bits 0-7,2,
IDE06957,Unfiltered clutch input rpm,0.0, /min
IDE07002,Exhaust flap: activation,10.00, %
IDE07003,Exhaust flap bank 2: activation,10.00, %
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,94,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,98,
IDE07051-ENG57549,Engaged gear: raw signal-Bits 0-7,0,
IDE07077,AVS valve stroke position: exhaust,31,
IDE07079,AVS result of last switch-over: exhaust,31,
IDE07164,Number injections,0,
IDE07170,Clutch K0: torque,0.0, Nm
IDE07194,Calculated increasing transmission engagement torque,-3276.8, Nm
IDE07224,Overrun cut-off,0,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,70,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,0,
IDE07234,Status bid for valid static oil level,1,
IDE07235,Status bid for dynamic oil level,0,
IDE07238,Status of power transfer,0.00,
IDE07240-ENG57549,Status transition of engine control module sequencing-Bits 0-7,0,
IDE07242,Heater support pump: spec. value,0.00, %
IDE07254,Gasoline pressure tank refueling request button,0,
IDE07257,Tank pressure from leakage diagnosis: calculated,0.000, hPa
IDE07475,Throttle valve position 2,6.30, %
IDE07573,Throttle valve adapter: actual value,6.27, %
IDE07615,Operating of tank: empty or reserve,OK,
IDE07615-ENG129324,Operating of tank: empty or reserve-Test_Program_Channel 372,194,
IDE07620-ENG57549,Status momentary default during stability intervention-Bits 0-7,0,
IDE07664,Pre-coordinated torque of increased stability intervention,-50000.0, Nm
IDE07665,Accel. pedal kick-down recognition: voltage threshold,4125.2, mV
IDE07712,Turbocharger 1 turbine inlet: temp. sensor 1 bank 1: raw value,-273.15, ∞C
IDE07724,Coolant temperature at engine outlet: calculated,26.3, ∞C
IDE07799,Heater support pump 1 bank 1 primary circuit: activation,99.64, %
IDE07840-ENG57549,Status plausibility accelerator pedal to brake pedal-Bits 0-7,0,
IDE07904-ENG57549,Brake test switch status-Bits 0-7,0,
IDE07905-ENG57549,Brake light switch status-Bits 0-7,0,
IDE07906-ENG57549,Upper clutch switch: status-Bits 0-7,0,
IDE07908,Coolant fan activation requested by A/C,0.00, %
IDE07963-ENG57549,Cam piece counter position malfunction-Bits 0-7,0,
IDE09529,Fuel mass flow rate due to degassing of eng. oil,0.0, mg/s
IDE09572,O2 sensor dwnstrm. of cat.: gradient transfer lean -> rich,0.00, s
IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.00, s
IDE09576,O2 sensor dwnstrm. of cat.: delay time transf. lean -> rich,0.00, s
IDE09578,O2 sensor dwnstrm. of cat.: delay time transf. rich -> lean,0.00, s
IDE09693-ENG57549,Charisma driving program: system status-Bits 0-7,0,
IDE09695-ENG57549,Charisma driving program: target value from coordinator-Bits 0-7,3,
IDE09696-ENG57549,Charisma driving program: CAN output value-Bits 0-7,3,
IDE09925-ENG57549,Intake camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09926-ENG57549,Outlet camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09927,Intake camshaft bank 1: adaption hardware offset active,False result,
IDE09927-ENG127289,Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09928,Outlet camshaft bank 1: adaption hardware offset active,False result,
IDE09928-ENG127289,Outlet camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09942,Long-term adaptation of mixture formation FSI: additive,0.00, %
IDE09943,Long-term adaptation of mixture formation FSI: multiplicative,1.00000,
IDE09944,Long-term adaptation of mixture formation MPI: additive,0.00, %
IDE09945,Long-term adaptation of mixture formation MPI: multiplicative,1.00000,
IDE10040-ENG57549,Outlet camshaft bank 1 active operating mode-Bits 0-7,0,
IDE10041-ENG57549,Intake camshaft bank1 active operating mode-Bits 0-7,0,
IDE10042,Outlet camshaft bank 1 status adaption,EPMCAS_STNOADAP,
IDE10042-ENG127372,Outlet camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,0,
IDE10043,intake camshaft bank 1 status adaption,EPMCAS_STNOADAP,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,0,
IDE10120,Chain elongation inlet: mileage of the last adaptation,19, km
IDE10121,Chain elongation outlet: mileage of the last adaptation,2, km
IDE10302,Time since engine start,0.0, s
IDE10303,Integrated air masse at first engine start,0.0000, kg
IDE10560-ENG57549,Adaption of radiator shutters: status-Bits 0-7,1,
IDE10630,O2 sensor upstrm. of cat.: delay time transf. rich -> lean,0.00, s
IDE10641,Low fuel pressure adaptation value for EFP: modeled,0.0, kPa
IDE10670,O2 sensor upstrm. of cat.: filter constant transf. rich -> lean,0.00, s
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG130099,Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG06494,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG06495,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10970-MAS11563,Number of prevented stop processes-Engine hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989-MAS00106,Immobilizer: historic data-Year,2127,
IDE10989-MAS00107,Immobilizer: historic data-Month,15,
IDE10989-MAS00108,Immobilizer: historic data-Day,31,
IDE10989-MAS00109,Immobilizer: historic data-Hours,31,
IDE10989-MAS00110,Immobilizer: historic data-Minutes,63,
IDE10989-MAS00111,Immobilizer: historic data-Seconds,63,
IDE10989,Immobilizer: historic data,Engine hood open,
IDE10989,Immobilizer: historic data,Brake pedal information: plausibility,
IDE10989,Immobilizer: historic data,Function locked due to excessive stalling,
IDE10994,Poor start counter at start-stop,0,
IDE11080,AVS operating state: outlet,0,
IDE11115,Start/stop driver request: counter restart by starter,0,
IDE11116,Start/stop driver request: counter internal-motor restart,0,
IDE11293,Fuel consumption difference: injectors/sensors,3.238, l
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,0.000, l
IDE11297,Heat qty.thresh.for dewpoint end dwn.strm. of main cat: bank1,701.781333, kJ
IDE11329-ENG57549,Oil press. sensor: raw value-Bits 0-7,178,
IDE11329-ENG57549,Oil press. sensor: raw value-Bits 0-7,0,
IDE11541-ENG57549,Autom.pre-selection sys operat.state of the actuator test-Bits 0-7,0,
IDE11931,Heated oxygen sensor bank 1 sensor 1: positioning intervention rear cat controller,0.00000,
IDE12355,ESI: consumption equivalent of the engine control module,0.00000000,
IDE12483,Service life data 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12915,Throttle 1: bank 1: position sensor 1: raw voltage,0.736, V
IDE12916,Throttle 1: bank 1: position sensor 2: raw voltage,4.261, V
IDE12923,Lambda regulation: bank 1: output value,1.00000,
IDE12928,Lambda regulation: bank 1: filtered average output value,1.00000,
IDE12936,Ignition angle: bank 1 raw value,0.0, ∞
IDE12944,Fuel injector A: bank 1: average injection time,0.000, ms
IDE13301,Drivetrain coordinator: brake fault status,0,
IDE13336,Drive train coordinator reversible switch off conditions,8388608,
IDE13337,Drive train coordinator irreversible switch off conditions,0,
IDE13772,Engine protection torque limitation,1000.0, Nm
IDE14241,Exhaust flap bank 2: position feedback actual value,0.00, %
IDE14247,Exhaust flap: position feedback actual value,0.00, %
MAS15845,Fuel: tank fill level,46.0, l
MAS16066,Exhaust gas temperature at the probe before PreCat bank 1: model value,25.5, ∞C
MAS16089,Lambda component protection: bank 1: specified value,1.0000,
MAS16091,Lambda Delta from exhaust gas temperature regulation bank 1: actual value,0.0000,
MAS16097,Tank ventilation factorial fuel amount: actual value,0.000,
MAS16098,Tank ventilation relative mixture proportion: actual value,0.00, %
MAS16222,Heated oxygen sensor bank 1 probe 1: status 2G,False result,
MAS16222-ENG127289,Heated oxygen sensor bank 1 probe 1: status 2G-Test_Program_B TRUE UBYTE,0,
MAS16301,Sensor adaptation: status with engine running,0,
MAS16534-ENG57549,A/C compressor info: switch-off status-Bits 0-7,0,
MAS16534-ENG57549,A/C compressor info: switch-off status-Bits 0-7,1,
MAS16534-ENG57549,A/C compressor info: switch-off status-Bits 0-7,3,
MAS16543,Bank 1 heated oxygen sensor downstream of catalytic converter: exhaust gas temperature calculated,25.44, ∞C
MAS17030,Engine control module hardware timer: self-diagnosis status,False result,
MAS17030-ENG127289,Engine control module hardware timer: self-diagnosis status-Test_Program_B TRUE UBYTE,0,
MAS17038,Heated oxygen sensor 2 bank 1: heat output normalized,0.00,
MAS17039,Heated oxygen sensor 1 Bank 1: target voltage adequate for lean conditions,1.000, V
MAS17041,Heated oxygen sensor 1 bank 1: effective heater voltage,0.000, V
MAS17045,Heated oxygen sensor 2 bank 1: internal resistance,0, Ohm
MAS17047,Heated oxygen sensor 2 Bank 1: target voltage adequate for rich conditions,0.000, V
MAS17055,Heated oxygen sensor 1 bank 1: identified total time (lean -> rich),0.00, s
MAS17056,Heated oxygen sensor 1 Bank 1: adaptation value for filtering time constants,0.00, s
MAS17058,Heated oxygen sensor 1 Bank 1: adaptation value for dead time,0.00, s
MAS17059,Heated oxygen sensor 1 bank 1: identified total time (rich -> lean),0.00, s
ENG112928-ENG57549,Air_conditioning_compressor_actual_status-Bits 0-7,0,
ENG105149,Air_mass_integral_for_thermostat_diagnosis_actual_value,0.00, kg
ENG105150,Air_mass_integral_for_thermostat_diagnosis_limit_value,10.96, kg
ENG26434-ENG57549,AVS_Cam_element_position_error_counter_lift_0-Bits 0-7,0,
ENG26435-ENG57549,AVS_Cam_element_position_error_counter_lift_1-Bits 0-7,0,
ENG26436-ENG57549,AVS_Cam_element_position_error_counter_manifold_pressure_diagnosis-Bits 0-7,0,
ENG26437-ENG57549,AVS_Cam_element_position_error_counter_misfire_detection-Bits 0-7,0,
ENG121428-ENG57549,AVS_counter_error_debonce-Bits 0-7,0,
ENG121429-ENG57549,AVS_counter_error_limphome-Bits 0-7,0,
ENG121426-ENG57549,AVS_counter_sporadic_diagnosis_errors-Bits 0-7,0,
ENG121427-ENG57549,AVS_counter_sporadic_switch_errors-Bits 0-7,0,
ENG112670-ENG112664,Brake_booster_start_request_combustion_engine-Bbkvs ta,1,
ENG101413,Calibration Identification,8V0404J 0002ATAK,
ENG99697,Calibration Verification Number,3B 51 E0 76,
ENG110572,Chain_elongation_MAX_drive_chain_1,0.00, ∞
ENG110573,Chain_elongation_MAX_drive_chain_2,0.00, ∞
ENG01773-ENG57549,Configuration_of_cruise_control-Bits 0-7,2,
ENG126402-ENG57549,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,0,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,64,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,1,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,68,
ENG122710,Cruise_control_velocity_setpoint,0.000, km/h
ENG111031-ENG57549,DFC_status_error_debounced_counter-Bits 0-7,0,
ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,2,
ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,254,
ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,1,
ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,147,
ENG126404-ENG57549,Drive_train_coordinator_checked_coding-Bits 0-7,5,
ENG112930,Driving_torque_coordinator_requested_driving_torque_from_GRA,-50000.0, Nm
ENG111582,DrivingProgramSwitch_sport_mode_activated,Correct result,
ENG111582-ENG127289,DrivingProgramSwitch_sport_mode_activated-Test_Program_B TRUE UBYTE,1,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG114220,Effective_injection_duration,0.000, ms
ENG06527-ENG57549,Eng Da st Run In-Bits 0-7,0,
ENG06528,Eng Strt m Fu Oil,0.00, g
ENG112932,Engine_oil_temperature_measured_value,25.7, ∞C
ENG111034,Engine_temperature_modelbased_substitute_value,27.0, ∞C
ENG106223,Engine_torque_limitation_mechanical,1000.0, Nm
ENG26778,Evap_purge_system_bank_1_cross_correlation_maximum_engine_load_gradient,0.00, hPa
ENG26779,Evap_purge_system_bank_1_cross_correlation_maximum_engine_speed_gradient,0.0, /min
ENG26781,Evap_purge_system_bank_1_insertion_pre_turbocharger_corrected_cross_correlation_coefficient,0.00,
ENG26788,ExhMgT_fetak_hllfa_msg,1.000,
ENG26789,ExhMgT_fetak_htlfa_msg,1.000,
ENG106501,Fan Ctl st Ok,Correct result,
ENG106501-ENG127289,Fan Ctl st Ok-Test_Program_B TRUE UBYTE,1,
ENG26808,Fl Lvl vol Tnk Plaus Old,46.000, l
ENG111607,Frequency_counters_for_test_signal_histogram,0,
ENG106677,Frm w,1.00000,
ENG08633-ENG20891,Fuel System Percentage Use-Fuel System A Use Percentage Bank 1,0.0, %
ENG08633-ENG20899,Fuel System Percentage Use-Fuel System A Use Percentage Bank 1 supported,Available,
ENG08633-ENG20893,Fuel System Percentage Use-Fuel System A Use Percentage Bank 2,0.0, %
ENG08633-ENG20901,Fuel System Percentage Use-Fuel System A Use Percentage Bank 2 supported,Not available,
ENG08633-ENG20895,Fuel System Percentage Use-Fuel System A Use Percentage Bank 3,0.0, %
ENG08633-ENG20903,Fuel System Percentage Use-Fuel System A Use Percentage Bank 3 supported,Not available,
ENG08633-ENG20897,Fuel System Percentage Use-Fuel System A Use Percentage Bank 4,0.0, %
ENG08633-ENG20905,Fuel System Percentage Use-Fuel System A Use Percentage Bank 4 supported,Not available,
ENG08633-ENG20892,Fuel System Percentage Use-Fuel System B Use Percentage Bank 1,0.0, %
ENG08633-ENG20900,Fuel System Percentage Use-Fuel System B Use Percentage Bank 1 supported,Available,
ENG08633-ENG20894,Fuel System Percentage Use-Fuel System B Use Percentage Bank 2,0.0, %
ENG08633-ENG20902,Fuel System Percentage Use-Fuel System B Use Percentage Bank 2 supported,Not available,
ENG08633-ENG20896,Fuel System Percentage Use-Fuel System B Use Percentage Bank 3,0.0, %
ENG08633-ENG20904,Fuel System Percentage Use-Fuel System B Use Percentage Bank 3 supported,Not available,
ENG08633-ENG20898,Fuel System Percentage Use-Fuel System B Use Percentage Bank 4,0.0, %
ENG08633-ENG20906,Fuel System Percentage Use-Fuel System B Use Percentage Bank 4 supported,Not available,
ENG111608,Fuel_consumption_actual_driving_cycle,0.000, l
ENG106769-ENG57549,Gearbox_heat_request-Bits 0-7,0,
ENG112667,Generator load normalised value,0.02, %
ENG112931,Generator_load_from_CAN,0, W
ENG112929,Generator_torque_request,0.0, Nm
ENG106781-ENG57549,Glb Da Max Val 0-Bits 0-7,0,
ENG106782-ENG57549,Glb Da Max Val 1-Bits 0-7,0,
ENG106783-ENG57549,Glb Da Max Val 2-Bits 0-7,0,
ENG106784-ENG57549,Glb Da Max Val 3-Bits 0-7,0,
ENG106785-ENG57549,Glb Da Max Val 4-Bits 0-7,0,
ENG121111-ENG57549,Glb Da Max Val 5-Bits 0-7,0,
ENG110577-ENG57549,Glb Da Min Val 0-Bits 0-7,0,
ENG121112-ENG57549,Glb Da Min Val 1-Bits 0-7,0,
ENG107045,Intake_manifold_model_air_mass_flow_filtered_value,0.0, kg/h
ENG100634,In-use Per Tr: 16 or 20 cou†sec O2 Sens Mon Com Enc Cou B 2,14, counts
ENG107236,Knock_sensor_cylinder_5_voltage,16.768, V
ENG110574,Lambdacoordination_homogeneous_mode_range_limited_commanded_value,1.0000,
ENG06529,Ldimx a w 0,0.000, %
ENG06530,Ldimx a w 1,0.000, %
ENG06531,Ldimx a w 2,0.000, %
ENG06532,Ldimx a w 3,0.000, %
ENG06533,Ldimx a w 4,0.000, %
ENG06534,Ldimx ak w,0.000, %
ENG111603,Leakage_air_mass_flow_across_throttle_normalized_value,0.0, kg/h
ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2127,
ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,15,
ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,31,
ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,31,
ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,63,
ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,63,
ENG127734,Life_cycle_data_start_requirement_development,brakes,
ENG127734,Life_cycle_data_start_requirement_development,Quattro Sport,
ENG127734,Life_cycle_data_start_requirement_development,Level control system,
ENG127734,Life_cycle_data_start_requirement_development,Front sensor system for driver assistance systems,
ENG127734,Life_cycle_data_start_requirement_development,All-wheel electronics,
ENG127734,Life_cycle_data_start_requirement_development,Front axis lift system,
ENG127734,Life_cycle_data_start_requirement_development,Steering,
ENG127734,Life_cycle_data_start_requirement_development,12 V electrical system,
ENG127734,Life_cycle_data_start_requirement_development,ACC,
ENG127734,Life_cycle_data_start_requirement_development,Transmission,
ENG127734,Life_cycle_data_start_requirement_development,Immobilizer,
ENG127734,Life_cycle_data_start_requirement_development,Kessy,
ENG127734,Life_cycle_data_start_requirement_development,Engine,
ENG127734,Life_cycle_data_start_requirement_development,Convertible top control module,
ENG127734,Life_cycle_data_start_requirement_development,Multifunction unit control module,
ENG127734,Life_cycle_data_start_requirement_development,Parking aid,
ENG127734,Life_cycle_data_start_requirement_development,A/C,
ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2127,
ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,15,
ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,31,
ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,31,
ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,63,
ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,63,
ENG127735,Life_cycle_data_stop_prohibition_development,brakes,
ENG127735,Life_cycle_data_stop_prohibition_development,Steering,
ENG127735,Life_cycle_data_stop_prohibition_development,Front sensor system for driver assistance systems,
ENG127735,Life_cycle_data_stop_prohibition_development,All-wheel electronics,
ENG127735,Life_cycle_data_stop_prohibition_development,Front axis lift system,
ENG127735,Life_cycle_data_stop_prohibition_development,Multifunction unit control module,
ENG127735,Life_cycle_data_stop_prohibition_development,Parking aid,
ENG127735,Life_cycle_data_stop_prohibition_development,ACC,
ENG127735,Life_cycle_data_stop_prohibition_development,Quattro Sport,
ENG127735,Life_cycle_data_stop_prohibition_development,Level control system,
ENG127735,Life_cycle_data_stop_prohibition_development,Immobilizer,
ENG127735,Life_cycle_data_stop_prohibition_development,Kessy,
ENG127735,Life_cycle_data_stop_prohibition_development,A/C,
ENG127735,Life_cycle_data_stop_prohibition_development,Convertible top control module,
ENG127735,Life_cycle_data_stop_prohibition_development,Engine,
ENG127735,Life_cycle_data_stop_prohibition_development,12 V electrical system,
ENG127735,Life_cycle_data_stop_prohibition_development,Transmission,
ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2019,
ENG127733-MAS00107,Life_cycle_data_system_failure-Month,7,
ENG127733-MAS00108,Life_cycle_data_system_failure-Day,23,
ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,15,
ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,32,
ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,34,
ENG127733,Life_cycle_data_system_failure,not active,
ENG127733,Life_cycle_data_system_failure,Engine,
ENG111606,Load value: unrestricted commanded value,12.05, %
ENG06535,Lrnst at,4,
ENG125271,Maximum_ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.000,
ENG06536,Mdver l w,6.055, %
ENG06537,Migs w,99.998, %
ENG06538,Miist w,0.000, %
ENG111040,Misfire_detection_sensor_wheel_adaptation_speed_load_range_index,0,
ENG107661-ENG57549,Mode_control_operating_status_hybrid_system_bitcoded-Bits 0-7,0,
ENG107662-ENG57549,Mode_control_start_mode_commanded_value-Bits 0-7,0,
ENG111581-ENG57549,Mode_control_start_order_combustion_engine-Bits 0-7,0,
ENG107761,Nmotl l,0, /min
ENG112668,O2 sensor_controller_bank_1_p-rate,0.00000,
ENG108178,Pbksi a w,-22.4, kPa
ENG108262,Powertrain_overall_gear_ratio,14.49,
ENG111605,Pressure_before_throttle_valve_actual_value,998.98, hPa
ENG06539-ENG57549,Prj Sw Adp st KD-Bits 0-7,0,
ENG06540,Ps w,999.38, hPa
ENG125270,Ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.000,
ENG06542-ENG57549,S Wa Pmp st Pmp2-Bits 0-7,0,
ENG109006,Spark_efficiency_deviation_at_idle_maximum,0.0, %
ENG109007,Spark_efficiency_deviation_at_part_load_maximum,0.0, %
ENG121093-ENG57549,State_of_cruise_control_or_speedlimiter-Bits 0-7,0,
ENG01786-ENG57549,State_of_requestor_for_drivetrain_coordinator-Bits 0-7,2,
ENG109324,Tabgm,20, ∞C
ENG109330,Taikr m w,25.44, ∞C
ENG06543,Tateo ut w,0.000, %
ENG109460,Tkihk m w,25.44, ∞C
ENG109505,TKMWL chlno 599,OFF,
ENG109505-ENG130088,TKMWL chlno 599-Test_Program_Channel 599,136,
ENG01775,Top_speed_limitation,238.000, km/h
ENG109528,Torque_coordination_idle_speed_control_torque_actual_value_air_path,0.0, Nm
ENG109529,Torque_coordination_idle_speed_control_torque_SET_path_actual_value,0.0, Nm
ENG01785-ENG57549,Transmission_state_of_drivetrain_coordinator-Bits 0-7,4,
ENG01785-ENG57549,Transmission_state_of_drivetrain_coordinator-Bits 0-7,0,
ENG111604,Turbocharger_inlet_pressure_corrected_value,999.38, hPa
ENG06544,Tvlue s1,9.8, %
ENG121117,Udkp1 w,0.736, V
ENG109861,Vehicle speed,0.00, km/h
ENG01774,Velocity_limiter_setpoint,511.992, km/h
ENG109886,Vgesh dp w,655.35, mm≥
ENG06545,Zwout,0.0, ∞
Elapsed Time: 00:57
