Hello
2017 seat leon
steering not workin after accident
I was make factory reset with vcds but nothing..
here my full scan file..need help please
2017 seat leon
Saturday,20,July,2019,11:36:16:11570
VCDS Version: 19.6.0.6 HEX-NET CB: 0.4505.4
Dealer/Shop Name: beyinci.com
Workshop Code: 389 04501 103077
VIN: VSSZZZ5FZHR068948 License Plate:
Mileage: 29371km-18250mi Repair Order:
Chassis Type: 5F-SE37 (3Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: VSSZZZ5FZHR068948 Mileage: 29371km-18250miles
Address 01: Engine (J623-DDYA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 056 HE HW: 04L 907 445 E
Component: R4 1.6l TDI H01 4118
Revision: 22005001
Coding: 01254012432419092000
Shop #: WSC 00049 770 00123
ASAM Dataset: EV_ECM16TDI03004L906056HE 004006
ROD: EV_ECM16TDI03004L906056HB_004.rod
VCID: 77BE1266CEE076F7A4-8022
25126 - Implausible Data Received from ESP Control Module
U0416 00 [039] - -
Mileage: 29371 km
Date: 2018.05.23
Time: 00:13:30
Coolant temperature: 24 °C
Intake air temperature: 27 °C
Ambient air pressure: 910 mbar
Voltage terminal 30: 12.187 V
Acceleration: 0.000 m/s²
Cruise Control System (CCS): status: main switch off
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake function status-ABS intervention: No
Drivetrain coordinator: brake function status-ESP intervention: No
Drivetrain coordinator: brake function status-EDL intervention: No
Drivetrain coordinator: brake function status-ASR intervention: No
Drivetrain coordinator: brake function status-MSR intervention: No
Drivetrain coordinator: brake function status-Driver braking: No
Drivetrain coordinator: brake function status-HDC active: No
Drivetrain coordinator: brake function status-ESP invokes TSK braking: No
Drivetrain coordinator: brake function status-EPB active: No
Drivetrain coordinator: brake function status-ASP intervention: No
Drivetrain coordinator: brake function status-ADS intervention: No
Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt: No
Drivetrain coordinator: brake function status-ESP sampled passive (ESP off): No
Drivetrain coordinator: brake function status-ASR sampled passive (ASR off): No
Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest: No
Drivetrain coordinator: brake function status-ACC stopping distance control active: No
27171 - Heater support pump
P16C1 00 [175] - Open circuit
Mileage: 29371 km
Date: 2018.05.22
Time: 05:11:24
Coolant temperature: 45 °C
Intake air temperature: 0 °C
Ambient air pressure: 900 mbar
Voltage terminal 30: 11.921 V
Heater support pump 1 bank 1 second.circuit: activat.: 94.78 %
Heater support pump 1 bank 1 primary circuit: activation: 95.00 %
Heater supp.pump 1 bank 1 charg.air cool.circuit: activat.: 10.00 %
Readiness: N/A
Part No SW: 0CW 300 041 D HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1004
Revision: 00005026 Serial number: CU501704065691
Shop #: WSC 17734 418 534600
ROD: EV_TCMDQ200021_VW31.rod
VCID: 3620DF62896A4FFF7F-8062
Part No SW: 5Q0 614 517 CG HW: 5Q0 614 517 AG
Component: ESC H62 0643
Revision: 00000000 Serial number: 50897000000067
Coding: 20EE6292242609748780060440CB2404462490E1600224730042F034C202430000000012121212B835351919323200
Shop #: WSC 00049 770 00103
ROD: EV_Brake1UDSContiMK100IPB_036_AU37.rod
VCID: 78BC115AC3FE798FAD-802C
0295 - Steering angle sensor
Reset counter: 106
Mileage: 29371 km
Date: 2018.05.23
Time: 00:13:30
Part No SW: 5F0 907 044 AK HW: 5F0 907 044 AK
Component: Climatronic H05 1801
Revision: 00001K09
Coding: 00000104200110011005000000101020
VCID: 6FAE2A06B6B03E377C-803A
459015 - Databus
[Feuchtesensor innen - kein Signal/Kommunikation]
Fault Frequency: 23
Reset counter: 106
Mileage: 29359 km
Date: 2018.05.15
Time: 00:53:13
262914 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Reset counter: 105
Mileage: 29368 km
Date: 2018.05.15
Time: 06:15:19
Outside air temperature: 63.0 °C
Engine speed: 700 /min
Temperature after evaporator: 36.7 °C
System run time-Engine running time: 4 s
System run time-Terminal 15 on: 5 s
393479 - Air Blower
B10BE 31 [008] - No Signal
[ZSB Gebläse/Regler (LIN) - kein Signal/Kommunikation]
Reset counter: 146
Mileage: 29359 km
Date: 2018.05.15
Time: 00:53:13
Voltage terminal 30: 14.0 V
Interior temperature: 33.5 °C
System run time-Engine running time: 255 s
System run time-Terminal 15 on: 255 s
459527 - Databus
[Klima_Sensor_02 - empfangener Fehlerwert]
Reset counter: 146
Mileage: 29359 km
Date: 2018.05.15
Time: 00:53:13
B10CD 00 [008] - -
Fault Frequency: 14
Reset counter: 146
Mileage: 29368 km
Date: 2018.05.15
Time: 01:14:00
Voltage terminal 30: 11.6 V
Part No SW: 5Q0 937 084 CD HW: 5Q0 937 084 CD
Component: BCM MQBAB B H34 0236
Serial number: 01001710100821
ROD: EV_BCMBOSCH_017.rod
VCID: 7CB40D4AF7C655AFC9-8028
Subsystem 1 - Part No SW: 5F1 955 119 A HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 170224 041 0574
Serial number: 170310122851
Coding: 0BC5FD
18698 - Left LED Module for DRL and Parking Lights
B12EC F2 [009] - Voltage Supply Open or Short to Plus
Reset counter: 106
Mileage: 29371 km
Date: 2018.05.22
Time: 05:12:54
545300 - Databus
[Gateway_78 Datenbus empfangener Fehlerwert EPS_Lastinfo]
Reset counter: 106
Mileage: 29371 km
Date: 2018.05.22
Time: 05:12:59
934148 - No Communications with Rain/Light Sensor
U10F6 00 [009] - -
[Sensor für Regen- und Lichterkennung->kein Signal/ Kommunikation]
Reset counter: 106
Mileage: 29371 km
Date: 2018.05.22
Time: 05:12:59
939524 - No Communications with Humidity Sensor
U10F5 00 [009] - -
[Sensor für Feuchteerkennung->kein Signal/ Kommunikation]
Reset counter: 106
Mileage: 29371 km
Date: 2018.05.22
Time: 05:12:57
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5QA 919 283 A HW: 5QA 919 283
Component: PDC 4 KanalH07 0038
Serial number: 000308419617100
Coding: 0600140011
ASAM Dataset: EV_EPHVA14AU3700000 009029
ROD: EV_EPHVA14AU3700000_009.rod
VCID: 48DCA19AF39EC90F1D-801C
13637411 - Databus
[Bremsensteuergerät - ESP_10.ESP_WegimpulsVL - Fehlerspeicher auslesen]
Fault Frequency: 7
Reset counter: 146
Mileage: 29359 km
Date: 2018.05.15
Time: 00:54:05
U1400 00 [008] - -
[Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
Reset counter: 145
Mileage: 29368 km
Date: 2018.05.15
Time: 22:38:56
13637888 - Databus
[Steuergerät für Schalttafeleinsatz-J285 - Kombi_02.KBI_Aussen_Temp_gef - Fehlerspeicher auslesen]
Reset counter: 146
Mileage: 29359 km
Date: 2018.05.15
Time: 00:54:09
13637424 - Databus
[ESP - ESP_19.ESP_VL_Radgeschw_02 - Fehlerspeicher auslesen]
Fault Frequency: 7
Reset counter: 146
Mileage: 29359 km
Date: 2018.05.15
Time: 00:54:05
13637426 - Databus
Reset counter: 106
Mileage: 29359 km
Date: 2018.05.15
Time: 00:54:05
Part No SW: 3Q0 959 655 AS HW: 3Q0 959 655 AS
Component: Airbag VW20 013 0200
Revision: -------- Serial number: 003SQP6Q9Y7Z
Coding: 98CCC00000000000400000CC000800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 0F6E4A86D6705E371C-805A
Subsystem 1 - Part No SW: ----------- HW: 454 000 303 17
Serial number: 3576U0000006657CD22I
Subsystem 2 - Part No SW: ----------- HW: 454 000 208 17
Serial number: 3586U00000099419772E
Subsystem 3 - Part No SW: ----------- HW: 454 802 603 17
Component: SideSensor_Dr 301 0148
Serial number: 3516R2024D00F000000Z
Subsystem 4 - Part No SW: ----------- HW: 454 802 303 17
Component: SideSensor_Pr 301 0148
Serial number: 3526R3319800F000000$
Subsystem 5 - Part No SW: ----------- HW: 454 801 903 17
Component: FrontSensor_D 304 0149
Serial number: 3556VC4A1F30E000000N
Part No SW: 5Q0 953 507 GP HW: 5Q0 953 549 E
Revision: -------- Serial number: 01041704221733
Coding: 1410
VCID: 0A585B92AD127B1FCB-805E
Part No SW: 5F0 920 741 D HW: 5F0 920 741 D
Component: KOMBI 206 8311
Coding: 07A42A082380000800082A001000000000000000
VCID: 26000F2259CA3F7FCF-8072
Part No SW: 3Q0 907 530 B HW: 3Q0 907 530 B
Component: GW MQB Mid 514 5286
Serial number: 10041710520244
Coding: 030100F40F087300EA000240140F00010001050000000000000000000000
ROD: EV_GatewNF.rod
VCID: 2E10F702713A773F37-807A
Subsystem 2 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000H0382080417
Coding: 002000
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 75886000001703241B59
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0032
Serial number: 0000248256322
Coding: 00100320DC00040000001000
Shop #: WSC 00049 770 00124
VCID: 47DEA2A6FE80C67714-8012
Serial number: 00000000000013898024
Coding: 310000
589829 - Window Regulator; Rear Driver side
B131F F5 [008] - Supply Voltage too Low
Reset counter: 145
Mileage: 29368 km
Date: 2018.05.15
Time: 22:39:12
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 129 1072
Coding: 0002
ROD: EV_SteerAssisMQB_013.rod
VCID: 45C2A8AEC48CD467E6-8010
4867 - Internal Fault
B200F F0 [008] - Unknown Error Elaboration
[Fehler im Abschaltpfadtest 1st current check (PWM: 65/35/50)]
Reset counter: 142
Motor status: 03
System status: Reset
Supply voltage: 12.00 V
Temperature: 18.0 °C
KFC: 13
KFA: 00 03
Environmental conditions: 71
nApplI_RotorSpeedFilt_xds16: -10 /min
mApplI_LimitedMotorTorque_xds16: 0.000 Nm
icuCurrentPhase_U_IRQ_xds16: 21.13 A
icuCurrentPhase_W_IRQ_xds16: -0.25 A
mApplI_TorsionBarTorque_xds16: 0.00 Nm
wrsCurrRotorPosIRQ_xdu16: 33.4 °
229504 - Internal Control Module Memory Check Sum Error
B2000 00 [153] - -
[Steuergerät defekt - Interne Störung]
MIL ON - Confirmed - Not Tested Since Memory Clear
Motor status: 03
KFC: 13
KFA: 00 03
15873 - Steering angle sensor
Reset counter: 106
Mileage: 29371 km
Date: 2018.05.23
Time: 00:17:37
Motor status: 00
Supply voltage: 0.00 V
Temperature: 32.0 °C
KFC: 3E
KFA: 00 01
Environmental conditions: 5F
uioUdNotFilt_xdu16: 0.06 V
uAdSensI_SwitchedKl30_xdu16: 0.07 V
RP_VALCNTSAV: not activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: not activated
RP_CNTERR: not activated
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0032
Serial number: 0000250828020
Coding: 00100320DE00040000001000
VCID: 46C0AFA2F98ADF7FEF-8012
Serial number: 00000000000014271296
Coding: 290000
589845 - Window Regulator; Front Passenger side
B1320 F5 [008] - Supply Voltage too Low
Reset counter: 146
Mileage: 29368 km
Date: 2018.05.15
Time: 22:39:12
Address 5F: Information Electr. (J794) Labels:| 5F0-035-MIB-STD2.clb
Part No SW: 5QA 035 824 A HW: 5QA 035 824 A
Component: MU-S--ER H30 0359
Serial number: SEZAZ2T1078619
Coding: 04738000D70A00001111000100090A002F0100D40120010002
ASAM Dataset: EV_MUStd6C1TSAT 001015
ROD: EV_MUStd6C1TSAT_SE37.rod
VCID: 3E30C742A15A87BFA7-806A
Subsystem 1 - Part No SW: 5F0 919 606 HW: 5F0 919 606
Component: ABTm-2_8-CR H41 1041
Serial number: SEZ8Z9TJH01FMJ
1539 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Function restriction due to insufficient voltage - lower limit value not reached]
Reset counter: 146
Mileage: 29368 km
Date: 2018.05.21
Time: 23:51:12
Voltage terminal 30: 6.5 V
End----------(Elapsed Time: 01:18, VBatt start/end: 12.3V/12.2V)-----------
