RHD to lhd 6r polo rear lights
justinmart
C?ID=339983
Hi I have changed the rear lights to LHD ones but the rear fog and reversing lights are on the wrong sides. I have found the long code to change from 'RHD long code 0300184042130A7B0F244080B12703C810005B025701 If I change it to LHD long code 0000184042130A7B0F244080B12703C810005B025701 will that do the trick?
Justin
Can't answer that without seeing a full unedited VCDS Auto-Scan ;)
justinmart
C?ID=339983
Tuesday,23,July,2019,12:03:04:36901
VIN: WVWZZZ6RZHY184359   License Plate: LS17 VVN
Mileage: 30060km-18678mi   Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 02 03 08 09 10 15 17 19 44 5F
VIN: WVWZZZ6RZHY184359   Mileage: 30060km-18678miles
Address 01: Engine (J623-CJZC)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 LH    HW: 04E 907 309 AF
   Component: R4 1.2l TFS   H23 3855
   Revision: R4H23---
   Coding: 01250032232411080000
   Shop #: WSC 04275 002 1048576
   ASAM Dataset: EV_ECM12TFS01104E906027LH 001001
   ROD: EV_ECM12TFS01104E906027BB.rod
   VCID: 75B611F3954834FFE9F-8020
   CAN Converter 01:
   Part No SW: 0CW 300 040 L    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1003
   Revision: 00005026    Serial number: CU501706217169
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 3D26C9D3EDF8ACBFE1F-8068
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 R    HW: 6R0 907 379 BA
   Component: ESP9.0i       H04 0006
   Serial number: 08501618170114
   Coding: 23DD2885892B33C41117106E005AC41491CC88080005CB098F00
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   VCID: 3E24CEDFE0FEB7A7F85-806A
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6C0 820 045 G    HW: 6C0 820 045 G
   Component: AC Manuell    H03 0204
   Serial number:  1612201B-0292
   Coding: 200100001100100000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 23121FAB6B5CFA4FF7B-8076
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [012] - -
                    Reset counter: 151
                    Mileage: 29849 km
                    Date: 2019.07.14
                    Time: 23:30:25
                    Voltage terminal 30: 14.1 V
                    Compressor shut-off requirement: Shut-off of engine control module via CAN (T > 15 sec.)
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 D    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H10 0094
   Serial number: 006308322249
   Coding: 0300184042130A7B0F244080B12703C810005B0257010000000000000000
   ASAM Dataset: EV_BCMA0 006002
   ROD: EV_BCMA0_006_VW26.rod
   VCID: 313EE5E321A058DF757-8064
   Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  042 0105
   Serial number: S2Y17M01D03H19M32S30
   Coding: 0038DD
   Drivers Door Control Module:
   Subsystem 2 - Part No SW: 6R0 959 802 DM    HW: 6R0 959 802 DM  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 0620
   Serial number: KU0KU004011770041708
   Coding: 1400A1
   Subsystem 3 - Part No SW: 6R0 959 801 DK    HW: 6R0 959 801 DK  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 0620
   Serial number: KU0KU004011770046179
   Coding: 0400A1
   Subsystem 4 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY163482NG7
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000036740388
   Revision: --------    Serial number: 39361700905979
   Coding: 0031051011
   ROD: EV_EPHVA18AU3700000_VW26.rod
   VCID: 43D2BF2B8B1CDA4F97B-8016
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 J    HW: 6C0 959 655 J
   Component: VW20Airbag00B 002 0380
   Revision: --------    Serial number: 003TH00FB380
   Coding: 88C0C000000000005C000000008800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3A2CC2CFFCD69B87C4D-806E
   Subsystem 1 - Part No SW: -----------    HW: 410 821 912 16
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00A3233EFA4422N
   Subsystem 2 - Part No SW: -----------    HW: 410 821 912 16
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00A122D3D4310DH
   Subsystem 3 - Part No SW: -----------    HW: 442 151 501 17
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A000C2A5195AC67J
   Subsystem 4 - Part No SW: -----------    HW: 442 151 501 17
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00122A52B3636A2
   Part No SW: 6C0 920 940 G    HW: 6C0 920 940 G
   Component: KOMBI         202 2310
   Coding: 232401082180260001082A001000000000000000
   Shop #: WSC 12345 123 61029
   VCID: 28080887127A1917A29-807C
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901 A    HW: 6C0 937 089
   Component: GW MQB A0     H10 0094
   Revision: --------    Serial number: 006308322249
   Coding: 030100046F0A560071000000000000010001010000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_013_VW26.rod
   VCID: 261406BF186E0F67905-8072
   Subsystem 1 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A  Labels: 3C8-959-537.CLB
   Serial number: 0171715560401697AD1B
   Coding: 280000
   Subsystem 2 - Part No SW: 6C0 915 181 B    HW: 6C0 915 181 B
   Component: J367-BDM  H08 0270
   Serial number: 53356954595881079205
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C2 909 144 AJ    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  323 3242
   Serial number: CH1B1288
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016134
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 71BE25E3E12018DF357-8024
   Part No SW: 3Q0 035 842 B    HW: 3Q0 035 842 B
   Component: MU-S-D-ER     H30 0359
   Serial number: VWZAZ2S0740188
   Coding: 02620000BE00000051110101008808001F0100C60120010003
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 2C00F49706823537461-8078
   Subsystem 1 - Part No SW: 6C0 919 603 B    HW: 6C0 919 603 B
   Component: ABTm_Std2  H53 1031
   Serial number: VWZ8Z9TKW029FE
End----------(Elapsed Time: 00:54, VBatt start/end: 13.3V/13.2V)-----------
Mike@Gendan
Swansea, UK
C?ID=57030
This may be a silly question, but when you say the lights are on the wrong sides, what do you mean?
Are you converting a RHD car to drive on LHD roads abroad, but the wrong bulbs are being lit, or are you retro-fitting lights that came from a LHD car onto a RHD car, to continue using it in the UK?
justinmart
C?ID=339983
I live in Spain. It is a RHD car. The reversing light and rear fog opposite. I have fitted LHD rear lights but now the reversing light is red and the fog white.
So is the reversing light still on the left and the fog light still on the right?
DV52
C?ID=194404
justin: Like Dave, I'm a little confused too
As far as the operation of the 2 x lamps is concerned- these are managed by Leuchte-commands. To swap the lamps, try this (in adaptation, in the BCM):
  • For the Reversing light - ONLY if ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28 has the value Rueckfahrlicht - change to NebelschlusslichtwennkeinAnhaengergestecktundRechtsverkehr
  • For the rear fog light - ONLY if ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26 has the value NebelschlusslichtwennkeinAnhaengergestecktundRechtsverkehr -change to Rueckfahrlicht
justinmart
C?ID=339983
Hi Don, Just tried to change codes but failed because lack of security access code any idea where to find the code?
Justin
NEtech
C?ID=56995
Try to press the button [Security Access-16], it should pop up.
