Hi. I replaced the broken auto gearbox with a manual, changed ecu to M one, but it seems like I can't recode ESP. I comes up with up with an error, tried literally all codings I could find over the internet, but none of them is fine. Attached scan. I don't mind about the runners error Could anyone post proper ecu and esp coding please? VIN WAUZZZ4F08N032362.
Tuesday,25,June,2019,15:57:32:60351
VCDS Version: 18.9.1.0 (x64)
Dealer/Shop Name: Dash Solutions
VIN: WAUZZZ4F08N032362 License Plate:
Chassis Type: 4F (4F0)
Scan: 01 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55 56
61 62 72
VIN: WAUZZZ4F08N032362 Mileage: 185290km-115133miles
0E-Media Player 1 -- Status: Malfunction 0010
Address 01: Engine Labels: 059-907-401-BPP.clb
Part No SW: 4F5 910 401 M HW: 4F0 907 401 C
Component: 2.7L V6TDI G000SG 0010
Revision: --H04--- Serial number:
Coding: 0011322
Shop #: WSC 10580 123 45725
VCID: 2B5562A68AEE8F1258-807E
012597 - Intake Manifold Runner Control
P3135 - 001 - Lower Stop not Reached
Fault Status: 01100001
Mileage: 185294 km
Date: 2019.06.25
Time: 15:43:53
RPM: 756 /min
Torque: 31.2 Nm
Voltage: 13.53 V
Duty Cycle: 88.8 %
Duty Cycle: 88.8 %
Duty Cycle: 80.9 %
004120 - Intake Manifold Runner (Bank 2)
P1018 - 001 - Lower limit not reached
Mileage: 185294 km
Date: 2019.06.25
Time: 15:43:53
RPM: 756 /min
Torque: 31.2 Nm
Voltage: 13.53 V
Duty Cycle: 88.8 %
Duty Cycle: 88.8 %
Duty Cycle: 80.9 %
P1653 - 002 -
Fault Status: 01100010
Fault Frequency: 6
Mileage: 185294 km
Date: 2019.06.25
Time: 15:43:53
RPM: 756 /min
Duty Cycle: 1.0 %
Voltage: 13.60 V
Bin. Bits: 00101100
Torque: 136.5 Nm
Bin. Bits: 00000100
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AC HW: 4F0 614 517 T
Component: ESP8 front H01 0070
Coding: 0020855
Shop #: WSC 02325 785 00200
VCID: 65C1D49EAC8A79624E-8030
Fault Status: 11100000
Reset counter: 230
Mileage: 185294 km
Date: 2019.06.25
Time: 15:50:49
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0014
Hex Value: 0x3191
Hex Value: 0x00FF
Reset counter: 230
Mileage: 185294 km
Date: 2019.06.25
Time: 15:50:49
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0014
Hex Value: 0x3091
Hex Value: 0x00FF
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 -
Reset counter: 230
Mileage: 185294 km
Date: 2019.06.25
Time: 15:50:49
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0014
Hex Value: 0x2391
Hex Value: 0x00FF
Component: FBSAUDIC6 ELV H31 0230
Revision: 09010701 Serial number: 10601500840968
Coding: 0000129
Shop #: WSC 02323 758 00200
VCID: 63C5CA86A2BE0752A0-8036
Subsystem 1 - Part No: 4F0 910 131 D
Component: FBSAUDIC6 EZS H45 0070
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 A HW: 4E0 035 729
Component: Interfacebox H43 4220
Revision: 00000000 Serial number: 350GM077811056
Coding: 0011001
Shop #: WSC 02335 758 00200
VCID: 2149808EF8225542F2-8074
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000819019
Subsystem 3 - Serial number: 0124.07.070000000100010377˙
Subsystem 4 - Serial number: 010377˙
00003 - Control Module
Fault Status: 01100101
Reset counter: 230
Mileage: 185294 km
Date: 2019.06.25
Time: 15:34:59
Part No SW: 4F0 910 043 B HW: 4F2 820 043 AA
Component: KLIMABETAETIGUNGH30 0080
Revision: 00000077 Serial number: 00000000798690
Coding: 0524646
VCID: 1D31BC7EC45A71A2D6-8048
00018 - Motor for Cold-Air Flap (V197)
003 - Mechanical Failure
Fault Status: 01100011
Fault Frequency: 11
Reset counter: 230
Mileage: 185284 km
Date: 2019.06.13
Time: 15:40:03
Voltage: 13.70 V
Temperature: 27.0°C
(no units): 95.0
(no units): 42.0
Temperature: 26.0°C
00715 - Rear Footwell Vent Positioning Motor (V112)
Fault Frequency: 11
Reset counter: 230
Mileage: 185284 km
Date: 2019.06.13
Time: 15:40:03
Voltage: 13.70 V
Temperature: 27.0°C
(no units): 128.0
(no units): 215.0
Temperature: 26.0°C
Fault Status: 01101100
Reset counter: 229
Mileage: 185284 km
Date: 2019.06.13
Time: 15:40:03
00796 - Fan for Interior Temp Sensor (V42)
Fault Frequency: 17
Reset counter: 230
Mileage: 185284 km
Date: 2019.06.13
Time: 15:40:18
Voltage: 13.60 V
Temperature: 27.0°C
00355 - Left Front Upper Body Outlet Motor (V237)
Fault Status: 00100011
Reset counter: 15
Mileage: 185294 km
Date: 2019.06.24
Time: 16:35:58
Voltage: 13.60 V
Temperature: 49.0°C
(no units): 37.0
(no units): 213.0
Temperature: 34.0°C
00256 - A/C Pressure/Temperature Sensor (G395)
Reset counter: 15
Mileage: 185294 km
Date: 2019.06.25
Time: 15:41:42
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H15 0240
Coding: 0001121
Shop #: WSC 31574 000 104857
VCID: 316970CEA8C2E5C262-8064
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H06 0210
Coding: 00064784
Shop #: WSC 31574
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00146221
Shop #: WSC 31574
01835 - Bulb for Side-Blinkers; Right (M19)
Fault Status: 01101011
Reset counter: 230
Mileage: 185280 km
Date: 2019.06.03
Time: 13:45:00
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 230
Mileage: 185280 km
Date: 2019.06.03
Time: 13:21:00
Reset counter: 230
Mileage: 185280 km
Date: 2019.06.03
Time: 13:21:00
01024 - Rain Sensor (G213)
014 - Defective
Fault Status: 01101110
Reset counter: 230
Mileage: 185292 km
Date: 2019.06.25
Time: 15:54:00
00924 - Relay for Headlamp Cleaning System (J39)
014 - Defective
Reset counter: 230
Mileage: 185280 km
Date: 2019.06.03
Time: 13:19:00
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H46 0350
Revision: 00046006 Serial number: AUZ5ZBG3445490
VCID: 183FAD6A2B78148A05-804C
Reset counter: 13
Mileage: 185280 km
Date: 2019.05.31
Time: 15:57:56
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 43 AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0X6GHU
Coding: 0013363
VCID: 295998AE80129D02AA-807C
Subsystem 1 - Serial number: 6332CSME105B3932
Subsystem 2 - Serial number: 6342CSME39432F0FD
Subsystem 3 - Serial number: 6352QSME590D1105B
Subsystem 4 - Serial number: 6362QSME590D0F29V
Subsystem 5 - Serial number: 63734SME1569084D4
Subsystem 6 - Serial number: 63834SME59293803+
01219 - Rear Side Airbag Igniter; Driver Side (N201)
01220 - Rear Side Airbag Igniter; Passenger Side (N202)
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - MIL ON
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H02000 Serial number: 90054071430273
Coding: 0002042
Shop #: WSC 00000 758 00200
VCID: 275D9E969606AB72BC-8072
Component: E0221 H02 0100
Part No SW: 4F0 910 930 C HW: 4F0 920 933 J
Component: KOMBIINSTR. M73 H21 0220
Revision: 00600000 Serial number: 6IN10EG77
Coding: 3076058
Shop #: WSC 11111 111 11111
VCID: 23458A86E23E4752E0-8076
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 13008077098098
Coding: 6CEE73C41B2104
007 - Short to Ground
Fault Status: 01100111
Reset counter: 230
Mileage: 185294 km
Date: 2019.06.25
Time: 15:32:40
Part No SW: 4E0 910 887 T HW: 4E0 919 887 M
Component: MNS ECE H50 1030
Revision: 00000000 Serial number: 364GR077700671
Shop #: WSC 21240 142 87008
VCID: 3E735BF2699C0ABAEF-806A
01316 - ABS Control Module
Reset counter: 13
Mileage: 185280 km
Date: 2019.06.03
Time: 14:19:22
Bin. Bits: 1100
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0210
Revision: 00000000 Serial number: H
Coding: 0003690
Shop #: WSC 02327 758 00200
VCID: 2C5761BA8FE0882A51-8078
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H25 0200
Revision: 02000025 Serial number: 01056221610000
Coding: 0139909
Fault Status: 01101001
Fault Frequency: 89
Reset counter: 230
Mileage: 185261 km
Date: 2007.03.04
Time: 05:20:09
01696 - Footwell Lighting; Rear Left (W45)
Reset counter: 230
Mileage: 185245 km
Date: 2007.03.06
Time: 08:27:29
01697 - Footwell Lighting; Rear Right (W46)
Reset counter: 230
Mileage: 185245 km
Date: 2007.03.06
Time: 08:27:29
00834 - Signal for Activation of Heated Rear Window
Fault Frequency: 8
Reset counter: 225
Mileage: 185255 km
Date: 2007.06.21
Time: 06:25:52
01503 - Bulb for 3rd Brake Light (M25)
Fault Status: 00101001
Fault Frequency: 6
Reset counter: 14
Mileage: 185289 km
Date: 2019.06.15
Time: 13:38:28
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4F0 910 223 K HW: 4F0 035 223 L
Component: Amp.-ASK-RD H07 0250
Revision: S0900000
Coding: 020001
Shop #: WSC 02399 823 56573
VCID: 26439392510CB27A87-8072
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000238860
Coding: 0001003
VCID: 5EB3FB7289DC2ABA8F-800A
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0210
Revision: 00000000 Serial number: Qb1
Coding: 0003610
008 - Implausible Signal
Fault Status: 01101000
Reset counter: 228
Mileage: 185280 km
Date: 2019.06.03
Time: 13:44:59
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000311
Shop #: WSC 02334 785 00200
VCID: 5DB1FC7E84DA31A296-8008
00650 - Clutch Pedal Switch (F36)
014 - Defective
Fault Frequency: 169
Reset counter: 228
Voltage: 10.77 V
Count: 73
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Coding: 0000003
Shop #: WSC 02325 758 00200
VCID: 3F8D26F66E9603B2E4-806A
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 394G%077795183
Coding: 0000001
VCID: 2E536BB2B9FCFA3A7F-807A
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000129131
Shop #: WSC 40380 123 59342
Subsystem 1 - Part No: 4F0 915 105 A
Component: von VA0 7922110398
Coding: 344630393135313035412056413037393232313130333938
Shop #: WSC 21033 146 56200
02254 - Interface to Generator
Fault Frequency: 16
Reset counter: 228
Mileage: 185280 km
Date: 2019.06.03
Time: 13:41:50
02479 - Partial Consumer Shut-Off Active
Fault Frequency: 9
Mileage: 185280 km
Date: 2019.06.03
Time: 14:01:26
Reset counter: 13
Mileage: 185280 km
Date: 2019.06.03
Time: 14:19:14
02272 - Quiescent Current Stage 1
Mileage: 185280 km
Date: 2019.06.10
Time: 14:48:14
02256 - Quiescent Current
Fault Status: 00100001
Reset counter: 15
Mileage: 185294 km
Date: 2019.06.24
Time: 05:28:06
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0003114
Shop #: WSC 02327 785 00200
Reset counter: 228
Mileage: 185280 km
Date: 2019.06.03
Time: 13:34:08
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0003114
Reset counter: 228
Mileage: 185280 km
Date: 2019.06.03
Time: 13:34:59
End-------------------------(Elapsed Time: 02:21)--------------------------
