Lane Assist Coding
Mike_Jones
C?ID=18137
All, I am really having a challenge finishing off the Active Lane assist on my facelift A6 2015 - it all works sort of but I have the following two issues.
The display recognises the road markings correctly! If I code the Image processing unit (8e) byte 1 to Lane Assist and Lane Change Assist (Coding 40) then the display flickers and the units shows missing messages (presumably from the side assist) but steering assistance works. If I select Lane Assist (which is what I think is Side Assist) not installed Coding 20 then the display works properly but steering assistance is unavailable and if I try to enable via adaption the command is rejected. There seems to be ambiguity between Active Lane Assist and what I call side assist.
I also cannot get the MMI to show active lane assist, just shows lane assist with incorrect sub menus?
I am so close but I cannot figure out the coding/adaptation. The scan below is with Coding 40 on byte 1 of the 8e unit - so steering assistance works but display flickers and sometimes locks up.
Any assistance would be appreciated.
Sunday,23,June,2019,16:10:23:55272
VCDS Version: 19.6.0.4 (x64)
VIN: WAUZZZ4G8FN068483   License Plate:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 28 3B 42 44 46 52 53 55 5F 62
          69 6C 6D 72 85 8E AC
VIN: WAUZZZ4G8FN068483   Mileage: 108775km-67589miles
17-Instruments -- Status: Malfunction 0110
Address 01: Engine (J623-CRTD)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G2 907 401 B    HW: 4G2 907 401
   Component: 3.0TDI EDC17  H33 0001
   Revision: 92H33---
   Coding: 12254012052601030000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TDI0114G2907401B 001001
   ROD: EV_ECM30TDI0114G2907311C.rod
   VCID: 244720EF2F0C176FD3-8070
   Part No SW: 4G0 927 166 C    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H03 0007
   Revision: --H03---
   Coding: 100001
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: 2D51C5CB7CC6D6270C-8078
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 17A69E41E86579829B00
   ASAM Dataset: EV_ESP9BOSCHAU57X 003019
   ROD: EV_ESP9BOSCHAU57X_003.rod
   VCID: 3F8D8F83A6AA54B7AE-806A
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0560
   Coding: 01B9704E000000000000
   VCID: 7AFB3E97F508B19FD9-802E
   Serial number: 3215000011387005
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 12021500040194
   Coding: 36A21178250000
   VCID: 63C563F36A825057EA-8036
Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V2.clb
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Revision: 15020001    Serial number: 00001008344002
   Coding: 0105001440349FE041014083000018000F9DE7082F08020100000894E100130200400034030000
   Shop #: WSC 53920 001 104857
   VCID: 71E919BBA87EF2C768-8024
   Component: WWS57X 150111  H37 0080
   Serial number:         150126014513
   Coding: 0045F7
   Serial number: 23730186
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 13 02 2015  00000883
   Serial number: F818C297000000000001
   Revision: --------    Serial number: 003P100390YW
   Coding: 30333130313730323737554A305234473053
   VCID: 3B75FB93B2B2489782-806E
   Serial number: 3575HRB401G52UQM71L
   Serial number: 3585HRB405133PKM68CD
   Serial number: 3515JRB40145358SI2AU
   Serial number: 3525JRB40145358SP91-
   Serial number: 3554VRB400Q534069H6.
   Serial number: 3564VRB400M5340670PY
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372OBC00036
   Coding: 0004F5
   VCID: 387FE49F8B84638F6F-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 06 01 2015  C0007902
   Part No SW: 4G8 920 985 L    HW: 4G8 920 985 L
   Component: TDieGb        H08 0043
   Revision: 04001037    Serial number: 658180215596026
   Coding: 33A612000B552600010000
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 408F8C7FDB542B4FD7-8014
1048578 - No Basic Setting
          B2010 00 [009] - -
                    Reset counter: 230
                    Mileage: 108745 km
                    Date: 2019.06.23
                    Time: 11:04:58
16776980 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 16
                    Mileage: 108753 km
                    Date: 2019.06.23
                    Time: 12:20:17
   Part No SW: 4G8 907 468     HW: 4G8 907 468
   Component: J533--Gateway H13 0075
   Revision: --------    Serial number: 00000001729380
   Coding: C0CD078118
   ASAM Dataset: EV_GatewPkoUDS 001024
   VCID: 75E12DABD416DEE7B4-8020
   Serial number: 1900125603
   Voltage stabilizer:
   Serial number: 1412100000000000044B
   Component: KLIMA FOND    H08 0112
   Serial number: 14021500040455
   Coding: 22
   VCID: 3D71F58BACA646A7BC-8068
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA8208ZJ6T
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3663EAA7899095FF7D-8062
   Coding: 011C16015001620002080002
   VCID: 479D9763F67A1C7716-8012
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0016426092
   Coding: 101001010001
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   VCID: 3365D3B39AE280D75A-8066
   Revision: 00002001    Serial number: 0360799116
   Coding: 013B0622A0B93080C320090420010F470000000000000000000000000000
   VCID: 46839A67F170057FED-8012
   Revision: --------    Serial number: 00000001368405
   ROD: EV_ParkiBrake_VW51.rod
   Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0081
   Coding: 04FE02202A130200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
   Coding: E01F00
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E01F00
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 021 D    HW: 4G1 035 021
   Component: MU-H-LND-EU   041 0389
   Serial number: A588B0F7505471
   Coding: 017502010000000013111102000A00132F0006E7F1700100DF
   VCID: 1B351B131272289762-804E
   Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Serial number: AUZ8Z9EY800PTF
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349OBD0006Q
   Component: Gracenote2  --- 1012
7961 - Control module
          B2001 00 [008] - Incorrect software version
                    Fault Frequency: 8
                    Reset counter: 17
                    Mileage: 108771 km
                    Date: 2019.06.23
                    Time: 15:53:53
                    Voltage terminal 30: 14.5 V
   Part No SW: 4G8 959 795 D    HW: 4G8 959 795
   Component: TSG HL        H03 0212
   Coding: 01081C004001620000080002
   Shop #: WSC 02312 785 00200
   VCID: 43858373C2423057CA-8016
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
   Component: Anhaenger     H14 0113
   Serial number: 0000454261
   Coding: 0100000202000000
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H04---    Serial number: 525 PA8J1XG2SO
   Coding: 1030005
   Shop #: WSC 98765 666 38384
   VCID: 26433AE79130E57FCD-8072
                    Reset counter: 230
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0150
   Revision: 14005001    Serial number: 030500754
   Coding: 093205C010
   ROD: EV_HDSGAu571.rod
   Component: TSG HR        H03 0212
   Shop #: WSC 28100 141 104456
   Component: DPC-SG        H27 0081
   Coding: 71160000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C57C8CF47DCDF2F1B-8078
   Component: BV-SG         H33 0090
   Serial number: 005000621903157
   Coding: 044239040111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0025 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 230
                    Mileage: 108745 km
                    Date: 2019.06.23
                    Time: 11:50:49
                    Outside air temperature: 18.5 ∞C
                    Voltage terminal 15: 11.6 V
                    Control Module temperature: 30.0 ∞C
0061 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 230
                    Mileage: 108745 km
                    Date: 2019.06.23
                    Time: 11:50:48
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 150210145
   ROD: EV_RDCMA00100_008.rod
End-------------------------(Elapsed Time: 05:51)--------------------------
hadez16
C?ID=289891
Following adp channels have to be changed in 5F:
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning (to active)
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high (to active)
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19 (to active)
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus (to Clamp 15)
Adapt channel in 8E:
IDE03466 to "active" (dont know the english translation, somethink like steer assistance)
Coding 8E:
Byte 1 is correct in your scan
Byte 2 is not correct. Remove Bit 4, you do not have Lane Change Assistance
Coding 16 is correct
Coding 44 is correct
Coding 09 is not correct
Set Bit 0 in Byte 35
Coding 17 is not correct
Remove Bit 4 in Byte 5
Set Bit 6 in Byte 4
Clear all fault codes.
Ignition off, lock car, wait 5 minutes.
Test and report back
Mike_Jones
C?ID=18137
Hello and thanks for your invaluable assistance - I have followed you instructions and we now have moved on a step. The missing messages error in 8e have cleared which I think is down to the 09 code which is not in the tutorial I used (from this site). The dash display doesn't flicker any more and Lane Assist is working as it should (it continued to flicker immediately after the code changes but then seemed to settle down. However the issue with the MMI menu remains.
If I set Bit 6 in Byte 4 (labelled Lane Assist in VCDS) I get a menu title of Audi Lane Assist. If I revert back to my setting Bit 4 in Byte 5 (labelled Active Lane Assist) I get a menu title of Active Lane Assist BUT for both menus they keep going grey/unavailable every couple of minutes. When in the lettering white I can select Vibration and Early/Late intervention.
It is now a very small issue but clearly something isn't quite right. Do you have any other thoughts?
Thank you
Mike_Jones
C?ID=18137
Also - the MMI menu can disappear completely sometimes if you press the lane assist button. Also the menu seems to have reverted to Audi Lane Assist and not Active Lane Assist. Having fiddled with the 5F Adaptations the flickering issue returned. I am going to leave it overnight as behaviour does seem to vary if it is left for a longer period. All very odd!
hadez16
C?ID=289891
I retrofitted Lane Assist several times to a A6 4G and never had such problems.
Could you be so kind and post a new Auto-Scan that has my settings coded with a description what still does not work based on this coding?
Mike_Jones
C?ID=18137
OK Scan below, current issue is simply the Menu System - which can't decide between Active Lane Assist or Audi Lane Assist and goes grey on a regular basis. The display seems to be affected if the lane assist button is pushed, sometimes the whole menu disappears. The Adaptations on 5F are as per your instructions. The 5F does report incorrect software version this has not been touched. I have successfully enabled traffic signs recognition and the menus for that work fine.
Friday,05,July,2019,17:32:35:55272
VCDS Version: 19.6.1.0 (x64)
VIN: WAUZZZ4G8FN068483   Mileage: 109703km-68166miles
   Revision: 92H33---
   VCID: 244720EF2F0C176FDD-8070
   Revision: --H03---
   Coding: 100001
   VCID: 2D51C5CB7CC6D62702-8078
   VCID: 3F8D8F83A6AA54B7A0-806A
   VCID: 7AFB3E97F508B19FD7-802E
   VCID: 63C563F36A825057E4-8036
   Coding: 0105001440349FE041014083000018000F9DE7082F08020100000894E100130200400035030000
   VCID: 71E919BBA87EF2C766-8024
   Coding: 0045F7
   Coding: 02006D
   VCID: 3B75FB93B2B248978C-806E
   Coding: 0004F5
   VCID: 387FE49F8B84638F61-806C
   Coding: 33A612004B452600010400
   VCID: 408F8C7FDB542B4FD9-8014
          B2010 00 [009] - -
                    Reset counter: 239
                    Mileage: 109681 km
                    Date: 2019.07.04
                    Time: 21:36:32
   Coding: C0CD078118
   VCID: 75E12DABD416DEE7BA-8020
   Voltage stabilizer:
   Coding: 22
   VCID: 3D71F58BACA646A7B2-8068
   ROD: EV_SARA2.rod
   VCID: 3663EAA7899095FF73-8062
   Component: TSG FA        H04 0507
   Coding: 011C1E015001620002080002
   VCID: 45819D6BCC760E67EA-8010
   VCID: 3365D3B39AE280D754-8066
   Part No SW: 4G8 959 792 H    HW: 4G8 959 792 F
   Component: TSG BF        H04 0507
   VCID: 4487806FC74C376FFD-8010
   Coding: E01F00
   Coding: E01F00
   Coding: E01F00
   Coding: E01F00
   VCID: 1B351B13127228976C-804E
3086 - Antenna for Telephone Mount
          B1564 01 [008] - Electrical Failure
                    Reset counter: 25
                    Mileage: 109703 km
                    Date: 2019.07.05
                    Time: 17:21:10
                    Voltage terminal 30: 11.6 V
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): not selected
                    Status of telephone-Handset holder (cradle): not connected
                    Fault Frequency: 9
                    Reset counter: 25
                    Mileage: 109703 km
                    Date: 2019.07.05
                    Time: 07:39:32
                    Voltage terminal 30: 12.3 V
   VCID: 43858373C2423057C4-8016
   Coding: 1030005
   VCID: 26433AE79130E57FC3-8072
                    Reset counter: 239
   Coding: 093205C010
   Coding: 71140000
   VCID: 2C57C8CF47DCDF2F15-8078
   Coding: 044229040111
   ROD: EV_BC7.rod
End-------------------------(Elapsed Time: 06:10)--------------------------
Mike_Jones
C?ID=18137
BTW - I have now cleared the instrument basic settings error, it was an incorrect service reset last time round!
Mike_Jones
C?ID=18137
I wonder if the problem could be the image processing adaptations - although the coding is now correct this was a retrofit item from eBay and could have come from anything. Traffic Sign Recognition coded fine so it can't be million miles off?
hadez16
C?ID=289891
Please provide CSV Maps of unit 5F and 8E. Coding is correct so far.
Mike_Jones
C?ID=18137
5F and 8E adaptation
c;SW:4G1-035-021-D   HW:4G1-035-021 ---  Information Electr.
;Component:MU-H-LND-EU   041 0389	 Coding:017502010000000013111102000A00132F0006E7F1700100DF
;EV_MUHig6C3Gen2HBAS	1115	EV_MUHig6C3Gen2HBAS_AU57.rod
;Saturday	6	July	2019	21:00:59:55272
;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
;VCID: 1B351B13127228976C-804E
IDE00001-Production mode	00 00 00 	3
IDE00346-Summertime-automatic	Europe 	1
IDE00759-Base volume of speech output	50%	1
IDE00768-Country identification: country of sale	GB 	2
IDE00769-Number 1 for Info call	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	23
IDE00770-Number 1 for roadside assistance	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	23
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages	OFF 	1
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages	OFF 	1
IDE00845-Wheel circ.	0 mm	2
IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module	Yes 	3
IDE01996-MAS00839-Installation list: specified installations-TV Tuner	No 	3
IDE01996-MAS00844-Installation list: specified installations-Radio	No 	3
IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module	Yes 	3
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1	Yes 	3
IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2	No 	3
IDE01996-MAS04300-Installation list: specified installations-DVD changer	No 	3
IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module	No 	3
IDE01996-SFT271943-Installation list: specified installations-Multimedia Operating Unit	No 	3
IDE01996-ENG154341-Installation list: specified installations-Reserved_8	No 	3
IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1	No 	3
IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2	No 	3
IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1	No 	3
IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2	No 	3
IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1	No 	3
IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2	No 	3
IDE02121-CD eject button	Enabled 	1
IDE02122-Developer mode	not activated 	1
IDE02330-Number 2 for Info call	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	23
IDE02331-Number 2 for roadside assistance	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	23
IDE02332-Deactivate production mode	0	3
IDE02476-MAS03001-Electrical test of loudspeakers-Mode	automatic 	49
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency	19000 Hz	49
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume	30	49
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency	19000 Hz	49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume	85	49
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency	19000 Hz	49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume	85	49
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency	19000 Hz	49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume	85	49
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency	19000 Hz	49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume	85	49
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency	19000 Hz	49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume	85	49
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency	19000 Hz	49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume	85	49
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency	19000 Hz	49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume	85	49
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency	19000 Hz	49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume	20	49
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency	19000 Hz	49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume	20	49
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency	19000 Hz	49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume	30	49
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency	19000 Hz	49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume	85	49
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency	19000 Hz	49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume	85	49
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency	19000 Hz	49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume	85	49
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency	19000 Hz	49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume	85	49
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency	19000 Hz	49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume	85	49
IDE02502-Confirmation of installation change	75 CA 	2
IDE02506-MAS03229-Copy multimedia data-Data medium	On 	1
IDE02506-MAS03230-Copy multimedia data-Optical drive	OFF 	1
IDE02607-Wheel pulse	0	2
IDE02699-Number 1 for roadside assistance	5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE02701-Number 1 (roaming) for roadside assistance	5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE03238-ENG117830-Parameter for connection transfer (UMTS)-1E_EcLo	0	8
IDE03238-ENG117831-Parameter for connection transfer (UMTS)-1E_RSCP	15	8
IDE03238-ENG117832-Parameter for connection transfer (UMTS)-1F_EcLo	0	8
IDE03238-ENG117833-Parameter for connection transfer (UMTS)-1F_RSCP	15	8
IDE03238-ENG122277-Parameter for connection transfer (UMTS)-2D_EcLo	0	8
IDE03238-ENG122278-Parameter for connection transfer (UMTS)-2D_RSCP	11	8
IDE03238-ENG122275-Parameter for connection transfer (UMTS)-3A_EcLo	0	8
IDE03238-ENG122276-Parameter for connection transfer (UMTS)-3A_RSCP	8	8
IDE03471-ENG117847-Vehicle configuration-advanced_range_display	OFF 	30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing	OFF 	30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO	OFF 	30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life	OFF 	30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios	OFF 	30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb	blocked 	30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant	0	30
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call	On 	30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support	OFF 	30
IDE03471-ENG130248-Vehicle configuration-Google_GAL	OFF 	30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts	On 	30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other	On 	30
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts	On 	30
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other	On 	30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data	not activated 	30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender	Deactivated 	30
IDE03471-ENG125049-Vehicle configuration-Joker_button_1	Not Present 	30
IDE03471-ENG125050-Vehicle configuration-Joker_button_2	Not Present 	30
IDE03471-ENG127492-Vehicle configuration-LGI	OFF 	30
IDE03471-ENG130246-Vehicle configuration-LTE_modul	activated 	30
IDE03471-ENG142142-Vehicle configuration-map_email_support	OFF 	30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support	OFF 	30
IDE03471-ENG142141-Vehicle configuration-map_sms_support	OFF 	30
IDE03471-ENG142152-Vehicle configuration-Map_Style	0	30
IDE03471-ENG152537-Vehicle configuration-media_control	not activated 	30
IDE03471-ENG138662-Vehicle configuration-Mirror_link	OFF 	30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code	MIB_EU 	30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference	RGB565 	30
IDE03471-ENG117843-Vehicle configuration-my_audi	On 	30
IDE03471-ENG117845-Vehicle configuration-online_dictation	On 	30
IDE03471-ENG127495-Vehicle configuration-online_media	On 	30
IDE03471-ENG117840-Vehicle configuration-online_navigation	On 	30
IDE03471-ENG117837-Vehicle configuration-online_POI	On 	30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice	On 	30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services	On 	30
IDE03471-ENG152553-Vehicle configuration-online_radio	Deactivated 	30
IDE03471-ENG117841-Vehicle configuration-online_street_view	On 	30
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit	OFF 	30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold	0	30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis	0	30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy	0	30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode	Data & language service active 	30
IDE03471-ENG117844-Vehicle configuration-picture_navi	On 	30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking	not activated 	30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use	not activated 	30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest	0	30
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi	OFF 	30
IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo	OFF 	30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version	PSD_1.4 	30
IDE03471-ENG117846-Vehicle configuration-remote_HMI	On 	30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component	Deactivated 	30
IDE03471-ENG126143-Vehicle configuration-RVC_video_input	FBAS 	30
IDE03471-ENG152556-Vehicle configuration-scon_telephony	not activated 	30
IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation	no restriction 	30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag	no_region 	30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch	not activated 	30
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch	present 	30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support	OFF 	30
IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi	activated 	30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode	0	30
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold	OFF 	30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling	OFF 	30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone	On 	30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location	OFF 	30
IDE03471-ENG126994-Vehicle configuration-TPEG_availability	OFF 	30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving	blocked 	30
IDE03471-ENG137647-Vehicle configuration-UOTA	On 	30
IDE03471-ENG167532-Vehicle configuration-UOTA_2	OFF 	30
IDE03471-ENG117852-Vehicle configuration-UPnP	On 	30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound	not activated 	30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound	not activated 	30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte	not activated 	30
IDE03471-ENG117836-Vehicle configuration-VZAPro	OFF 	30
IDE03471-ENG127494-Vehicle configuration-VZO	OFF 	30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI	OFF 	30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot	On 	30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch	not activated 	30
IDE03580-Country code for mobile network	0	2
IDE03902-Automatic ring break diagnostic	No automatic start 	1
IDE04292-Roadside assistance mode	Corresponding setting in MMI 	1
IDE04294-Number attempted dialing attempts for roadside assistance	3	1
IDE04295-Bluetooth: Preferred connection profile for phone book data	PBAP 	1
IDE04298-MAS01779-Vehicle dimensions-Length	0 mm	6
IDE04298-MAS01780-Vehicle dimensions-Width	0 mm	6
IDE04298-MAS02230-Vehicle dimensions-Height	0 mm	6
IDE04331-Selection of release codes for a SWaP function	FF FF FF FF 	4
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code	2	2
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code	2	2
IDE04485-MAS04349-Remote control for information electronics-Serial number remote control 1	0	8
IDE04485-MAS04350-Remote control for information electronics-Serial number remote control 2	0	8
IDE04521-Sporadic ring break detection	Visual 	1
IDE04522-Awakening ability on optical databus	OFF 	1
IDE04549-Telephone data services	On 	1
IDE04550-Bluetooth: Sniff mode	On 	1
IDE05111-Fee-based traffic information (TMC)	32783	2
IDE05113-Infotainment Recorder	activated 	1
IDE06425-Roller test bench mode: functional	not activated 	1
IDE06697-Audio management mute function	Muting of audio sources 	1
IDE07399-ENG142045-Engine type-Engine_type_adaption_1	Petrol 	1
IDE07399-ENG142046-Engine type-Engine_type_adaption_2	Petrol 	1
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass	On 	1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default	On 	1
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS	On 	1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo	On 	1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass	On 	1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1	OFF 	1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2	OFF 	1
IDE09382-ENG125051-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 2G	0	16
IDE09382-ENG125052-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 3G	0	16
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner	-128	40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio	17	40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM)	-128	40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM)	-128	40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB)	-128	40
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB	-128	40
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP	-128	40
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay	-128	40
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter	-128	40
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN	-128	40
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray	-128	40
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice	-128	40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA	-128	40
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud	-128	40
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD	-128	40
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI	-128	40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP	-128	40
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP	-128	40
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink	-128	40
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP	-128	40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB	-128	40
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice	-128	40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM	-128	40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep	-128	40
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging	-128	40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen	-128	40
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning	-128	40
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav	-128	40
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS	-128	40
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online	-128	40
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal	-128	40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI	-128	40
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN	-128	40
IDE10480-MAS10741-Interface for external media: activation-Connection 1	activated 	4
IDE10480-MAS10742-Interface for external media: activation-Connection 2	activated 	4
IDE10480-MAS10743-Interface for external media: activation-Connection 3	not activated 	4
IDE10480-MAS10744-Interface for external media: activation-Connection 4	not activated 	4
IDE10668-Internal SIM card: use	Never 	1
IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold	20 dBµV	3
IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation	50 dB	3
IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo	0.1 s	3
IDE11105-Brand-specific display of connect application	de.audi.mmiconnect 	19
IDE11153-ENG152487-Surroundings display: virtual camera positions-focallength	4294967295	330
IDE11153-ENG152457-Surroundings display: virtual camera positions-Pitchangle	65535	330
IDE11153-ENG152445-Surroundings display: virtual camera positions-Rollangle	65535	330
IDE11153-ENG147432-Surroundings display: virtual camera positions-xpos	32767	330
IDE11153-ENG152451-Surroundings display: virtual camera positions-Yawangle	65535	330
IDE11153-ENG147433-Surroundings display: virtual camera positions-ypos	32767	330
IDE11153-ENG147434-Surroundings display: virtual camera positions-zpos	32767	330
IDE11638-Bluetooth Audio Codec	FF 	1
MAS00951-Bluetooth	On 	1
MAS02809-MAS02870-Check tone frequency-High note frequency range	4000 Hz	6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range	1000 Hz	6
MAS02809-MAS02872-Check tone frequency-Low note frequency range	100 Hz	6
MAS03690-Telephone	Data & language service active 	1
MAS03782-WLAN	On 	1
ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off	On 	12
ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time	150.00 ms	12
ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off	OFF 	12
ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time	0.00 ms	12
ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off	OFF 	12
ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time	0.00 ms	12
ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off	On 	12
ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time	150.00 ms	12
ENG117920-Audio_Managment_Soundset_Menu	OFF 	1
ENG117917-BAP_Debug_Mode_Release	not_released 	1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization	not activated 	60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer	not activated 	60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off	not activated 	60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high	not activated 	60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill	not activated 	60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation	not activated 	60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer	not activated 	60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off	not activated 	60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high	not activated 	60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill	not activated 	60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent	not activated 	60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer	not activated 	60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off	not activated 	60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high	not activated 	60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill	not activated 	60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC	not activated 	60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer	not activated 	60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off	not activated 	60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high	not activated 	60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill	not activated 	60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key	activated 	60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer	not activated 	60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off	not activated 	60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high	activated 	60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill	not activated 	60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue	not activated 	60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer	not activated 	60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off	not activated 	60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high	not activated 	60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill	not activated 	60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper	not activated 	60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer	not activated 	60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off	not activated 	60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high	not activated 	60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill	not activated 	60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination	not activated 	60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer	not activated 	60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off	not activated 	60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high	not activated 	60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill	not activated 	60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope	not activated 	60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer	not activated 	60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off	not activated 	60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high	not activated 	60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill	not activated 	60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification	not activated 	60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer	not activated 	60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off	not activated 	60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high	not activated 	60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill	not activated 	60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating	not activated 	60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer	not activated 	60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off	not activated 	60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high	not activated 	60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill	not activated 	60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv	not activated 	60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer	not activated 	60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off	not activated 	60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high	not activated 	60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill	not activated 	60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management	not activated 	60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer	not activated 	60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off	not activated 	60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high	not activated 	60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill	not activated 	60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE	not activated 	60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer	not activated 	60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off	not activated 	60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high	not activated 	60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill	not activated 	60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer	activated 	60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer	not activated 	60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off	not activated 	60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high	activated 	60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill	not activated 	60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function	not activated 	60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer	not activated 	60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off	not activated 	60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high	not activated 	60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill	not activated 	60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror	not activated 	60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer	not activated 	60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off	not activated 	60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high	not activated 	60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill	not activated 	60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking	activated 	60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer	not activated 	60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off	not activated 	60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high	activated 	60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill	not activated 	60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master	activated 	60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer	not activated 	60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off	not activated 	60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high	activated 	60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill	not activated 	60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma	activated 	60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer	not activated 	60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off	not activated 	60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high	activated 	60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill	not activated 	60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration	activated 	60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer	not activated 	60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off	not activated 	60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high	activated 	60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill	not activated 	60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock	activated 	60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer	not activated 	60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off	not activated 	60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high	activated 	60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill	not activated 	60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass	not activated 	60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer	not activated 	60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off	not activated 	60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high	not activated 	60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill	not activated 	60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist	not activated 	60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer	not activated 	60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off	not activated 	60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high	not activated 	60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill	not activated 	60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration	not activated 	60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer	not activated 	60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off	not activated 	60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high	not activated 	60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill	not activated 	60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school	not activated 	60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer	not activated 	60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off	not activated 	60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high	not activated 	60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill	not activated 	60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall	not activated 	60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer	not activated 	60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off	not activated 	60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high	not activated 	60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill	not activated 	60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist	not activated 	60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer	not activated 	60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off	not activated 	60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high	not activated 	60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill	not activated 	60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI	not activated 	60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer	not activated 	60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off	not activated 	60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high	not activated 	60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill	not activated 	60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination	activated 	60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer	not activated 	60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off	not activated 	60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high	activated 	60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill	not activated 	60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display	not activated 	60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer	not activated 	60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off	not activated 	60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high	not activated 	60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill	not activated 	60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid	not activated 	60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer	not activated 	60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off	not activated 	60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high	not activated 	60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill	not activated 	60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant	not activated 	60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer	not activated 	60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off	not activated 	60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high	not activated 	60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill	not activated 	60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning	activated 	60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer	not activated 	60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off	not activated 	60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high	activated 	60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill	not activated 	60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker	not activated 	60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer	not activated 	60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off	not activated 	60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high	not activated 	60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill	not activated 	60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision	not activated 	60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer	not activated 	60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off	not activated 	60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high	not activated 	60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill	not activated 	60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level	activated 	60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer	not activated 	60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off	not activated 	60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high	activated 	60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill	not activated 	60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc	activated 	60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer	not activated 	60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off	not activated 	60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high	not activated 	60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill	not activated 	60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist	not activated 	60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer	not activated 	60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off	not activated 	60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high	not activated 	60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill	not activated 	60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk	activated 	60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer	not activated 	60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off	not activated 	60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high	not activated 	60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill	activated 	60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment	not activated 	60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer	not activated 	60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off	not activated 	60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high	not activated 	60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill	not activated 	60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load	not activated 	60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer	not activated 	60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off	not activated 	60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high	not activated 	60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill	not activated 	60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification	activated 	60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer	not activated 	60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off	not activated 	60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high	activated 	60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill	not activated 	60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration	not activated 	60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer	not activated 	60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off	not activated 	60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high	not activated 	60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill	not activated 	60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic	not activated 	60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer	not activated 	60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off	not activated 	60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high	not activated 	60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill	not activated 	60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia	activated 	60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer	not activated 	60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off	not activated 	60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high	activated 	60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill	not activated 	60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view	not activated 	60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer	not activated 	60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off	not activated 	60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high	not activated 	60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill	not activated 	60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions	not activated 	60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer	not activated 	60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off	not activated 	60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high	not activated 	60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill	not activated 	60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler	not activated 	60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer	not activated 	60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off	not activated 	60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high	not activated 	60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill	not activated 	60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI	not activated 	60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer	not activated 	60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off	not activated 	60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high	not activated 	60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill	not activated 	60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons	not activated 	60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer	not activated 	60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off	not activated 	60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high	not activated 	60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill	not activated 	60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant	not activated 	60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer	not activated 	60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off	not activated 	60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high	not activated 	60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill	not activated 	60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner	not activated 	60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer	not activated 	60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off	not activated 	60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high	not activated 	60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill	not activated 	60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo	not activated 	60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer	not activated 	60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off	not activated 	60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high	not activated 	60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill	not activated 	60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating	not activated 	60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer	not activated 	60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off	not activated 	60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high	not activated 	60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill	not activated 	60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin	activated 	60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer	not activated 	60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off	not activated 	60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high	activated 	60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill	not activated 	60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition	activated 	60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer	not activated 	60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off	not activated 	60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high	activated 	60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill	not activated 	60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows	not activated 	60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer	not activated 	60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off	not activated 	60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high	not activated 	60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill	not activated 	60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper	activated 	60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer	not activated 	60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off	not activated 	60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high	activated 	60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill	not activated 	60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol	not activated 	60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer	not activated 	60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off	not activated 	60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high	not activated 	60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill	not activated 	60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05	not activated 	64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus	not activated 	64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06	not activated 	64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus	not activated 	64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D	not activated 	64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus	not activated 	64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24	not activated 	64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus	not activated 	64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03	not activated 	64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus	not activated 	64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B	not activated 	64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus	not activated 	64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25	not activated 	64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus	not activated 	64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23	not activated 	64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus	not activated 	64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26	not activated 	64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus	not activated 	64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D	activated 	64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus	Terminal 15 	64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17	activated 	64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus	Terminal 15 	64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16	not activated 	64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus	not activated 	64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01	activated 	64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus	Terminal 15 	64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02	activated 	64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus	Terminal 15 	64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11	activated 	64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus	CAN_Kombi 	64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15	not activated 	64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus	not activated 	64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10	not activated 	64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus	not activated 	64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33	not activated 	64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus	not activated 	64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C	not activated 	64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C	not activated 	64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37	not activated 	64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus	not activated 	64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38	not activated 	64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus	not activated 	64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09	activated 	64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus	Terminal 15 	64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04	not activated 	64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus	not activated 	64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D	not activated 	64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus	not activated 	64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08	not activated 	64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus	not activated 	64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19	activated 	64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus	Terminal 15 	64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F	activated 	64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus	Terminal 15 	64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34	not activated 	64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34	not activated 	64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E	not activated 	64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus	not activated 	64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18	not activated 	64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus	not activated 	64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A	activated 	64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus	Terminal 15 	64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20	not activated 	64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus	not activated 	64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A	not activated 	64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A	not activated 	64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39	not activated 	64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39	not activated 	64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E	not activated 	64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus	not activated 	64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F	not activated 	64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus	not activated 	64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B	not activated 	64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B	not activated 	64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F	not activated 	64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F	not activated 	64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E	not activated 	64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E	not activated 	64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12	activated 	64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus	Terminal 15 	64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E	not activated 	64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus	not activated 	64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35	not activated 	64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35	not activated 	64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27	not activated 	64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus	not activated 	64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A	not activated 	64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus	not activated 	64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07	activated 	64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus	Terminal 15 	64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21	activated 	64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus	Terminal 15 	64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36	not activated 	64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36	not activated 	64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C	not activated 	64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus	not activated 	64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14	not activated 	64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus	not activated 	64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13	activated 	64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus	Terminal 15 	64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B	activated 	64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus	Terminal 15 	64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22	activated 	64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus	Terminal 15 	64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C	activated 	64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus	Terminal 15 	64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key	Available 	8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus	Terminal 15 	8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school	Not available 	8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus	Not available 	8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL	Available 	8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus	Databus Infotainment 	8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level	Available 	8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus	Terminal 15 	8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering	Available 	8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus	Terminal 15 	8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved	Not available 	8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1	Not available 	8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2	Not available 	8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3	Not available 	8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN	Available 	8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus	Terminal 15 	8
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps	OFF 	10
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture	OFF 	10
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart	OFF 	10
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode	H264 	10
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution	resolution_1 	10
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode	MOST_streaming 	10
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon	0	10
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most	OFF 	10
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode	H264 	10
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution	resolution_1 	10
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode	MOST_streaming 	10
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart	OFF 	10
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1	0	6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2	50	6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3	100	6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1	0	6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2	50	6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3	100	6
ENG126988-ENG99777-Dimming_Ambient_Illumination_serial_Operating_Unit-Y1	0	5
ENG126988-ENG100480-Dimming_Ambient_Illumination_serial_Operating_Unit-Y2	63	5
ENG126988-ENG100773-Dimming_Ambient_Illumination_serial_Operating_Unit-Y3	127	5
ENG126988-ENG100631-Dimming_Ambient_Illumination_serial_Operating_Unit-Y4	190	5
ENG126988-ENG102174-Dimming_Ambient_Illumination_serial_Operating_Unit-Y5	253	5
ENG126989-ENG99777-Dimming_Functional_Illumination_for_serial_Operating_Unit-Y1	5	5
ENG126989-ENG100480-Dimming_Functional_Illumination_for_serial_Operating_Unit-Y2	5	5
ENG126989-ENG100773-Dimming_Functional_Illumination_for_serial_Operating_Unit-Y3	45	5
ENG126989-ENG100631-Dimming_Functional_Illumination_for_serial_Operating_Unit-Y4	120	5
ENG126989-ENG102174-Dimming_Functional_Illumination_for_serial_Operating_Unit-Y5	253	5
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1	0	12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2	10	12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3	50	12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4	100	12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5	150	12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6	253	12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1	1%	12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2	2%	12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3	4%	12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4	13%	12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5	30%	12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6	100%	12
ENG117911-ENG117768-FM_Delay_Adaption-Parameter_Adaption_FM_Delay	0 ms	3
ENG117911-ENG117769-FM_Delay_Adaption-Seamless_linking_automatic	On 	3
ENG141636-ENG142049-Key_code_monitoring-monitoring_keycode_0x00_0x07	FF 	10
ENG141636-ENG142050-Key_code_monitoring-monitoring_keycode_0x08_0x0F	FF 	10
ENG141636-ENG142051-Key_code_monitoring-monitoring_keycode_0x10_0x17	FF 	10
ENG141636-ENG142052-Key_code_monitoring-monitoring_keycode_0x18_0x1F	FF 	10
ENG141636-ENG142053-Key_code_monitoring-monitoring_keycode_0x20_0x27	FF 	10
ENG141636-ENG142054-Key_code_monitoring-monitoring_keycode_0x28_0x2F	FF 	10
ENG141636-ENG142055-Key_code_monitoring-monitoring_keycode_0x30_0x37	FF 	10
ENG141636-ENG142056-Key_code_monitoring-monitoring_keycode_0x38_0x3F	FF 	10
ENG141636-ENG142057-Key_code_monitoring-monitoring_keycode_0x40_0x47	FF 	10
ENG141636-ENG142058-Key_code_monitoring-monitoring_keycode_0x48_0x4F	FF 	10
ENG141636-ENG142059-Key_code_monitoring-monitoring_keycode_0x50_0x57	0	10
ENG141636-ENG142060-Key_code_monitoring-monitoring_keycode_0x58_0x5F	0	10
ENG141636-ENG142061-Key_code_monitoring-monitoring_keycode_0x60_0x67	0	10
ENG141636-ENG142062-Key_code_monitoring-monitoring_keycode_0x68_0x6F	0	10
ENG141636-ENG142063-Key_code_monitoring-monitoring_keycode_0x70_0x77	0	10
ENG141636-ENG142064-Key_code_monitoring-monitoring_keycode_0x78_0x7F	0	10
ENG141636-ENG142065-Key_code_monitoring-monitoring_keycode_0x80_0x87	0	10
ENG141636-ENG142066-Key_code_monitoring-monitoring_keycode_0x88_0x8F	0	10
ENG141636-ENG142067-Key_code_monitoring-monitoring_keycode_0x90_0x97	0	10
ENG141636-ENG142068-Key_code_monitoring-monitoring_keycode_0x98_0x9F	0	10
ENG141636-ENG142069-Key_code_monitoring-monitoring_keycode_0xA0_0xA7	0	10
ENG141636-ENG142070-Key_code_monitoring-monitoring_keycode_0xA8_0xAF	0	10
ENG141636-ENG142071-Key_code_monitoring-monitoring_keycode_0xB0_0xB7	0	10
ENG141636-ENG142072-Key_code_monitoring-monitoring_keycode_0xB8_0xBF	0	10
ENG141636-ENG142073-Key_code_monitoring-monitoring_keycode_0xC0_0xC7	0	10
ENG141636-ENG142074-Key_code_monitoring-monitoring_keycode_0xC8_0xCF	0	10
ENG141636-ENG142075-Key_code_monitoring-monitoring_keycode_0xD0_0xD7	0	10
ENG141636-ENG142076-Key_code_monitoring-monitoring_keycode_0xD8_0xDF	0	10
ENG141636-ENG142077-Key_code_monitoring-monitoring_keycode_0xE0_0xE7	0	10
ENG141636-ENG142078-Key_code_monitoring-monitoring_keycode_0xE8_0xEF	0	10
ENG141636-ENG142079-Key_code_monitoring-monitoring_keycode_0xF0_0xF7	0	10
ENG141636-ENG142080-Key_code_monitoring-monitoring_keycode_0xF8_0xFF	0	10
ENG107658-ENG126192-mobile phone voice control availability-apple_device	not installed 	1
ENG107658-ENG126193-mobile phone voice control availability-other_devices	not installed 	1
ENG117809-p_damping_Display	5 ms	1
ENG117808-p_HMI_Display	10%	1
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset	0	2
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset	0	2
ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN	0	3
ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit	0 km/h	3
Elapsed Time: 01:04
IDE01973-Warning point	Early 	1
IDE01974-Steering wheel vibration	Strong 	1
IDE02001-Body height left front wheel house edge	0.00 mm	2
IDE02002-Body height right front wheel house edge	0.00 mm	2
IDE02003-Body height left rear wheel house edge	0.00 mm	2
IDE02004-Body height right rear wheel house edge	0.00 mm	2
IDE02005-EMC test mode	not activated 	1
IDE02065-Night vehicle detection activation brightness	3 lx	3
IDE02066-Windshield heat. direct. stabilize. assist. activation duration	63 min	1
IDE02691-Warning point factory setting	Adaptive 	1
IDE02692-Steering wheel vibration factory setting	Medium 	1
IDE03221-Night vehicle detection deactivation brightness	20 lx	3
IDE03239-Taillight spacing	147 cm	1
IDE03240-Front light spacing	145 cm	1
IDE03258-Taillight spacing for truck	147 cm	1
IDE03259-Front light spacing for truck	145 cm	1
IDE03260-Taillight height two-wheeled vehicle	80 cm	1
IDE03261-Driving light height two-wheeled vehicle	90 cm	1
IDE03280-Static calibration (end of assembly line)	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	37
IDE03355-Static calibration: yaw angle	0.052 ∞	2
IDE03356-Static calibration: pitch angle	-2.263 ∞	2
IDE03357-Static calibration: roll angle	-0.013 ∞	2
IDE03358-Static calibration: camera height	1318 mm	2
IDE04908-Factory setting f activation stat of directional stab assist	OFF 	1
IDE09392-Light distribution	Audi A6 	1
IDE09393-Vehicle detection during darkness: speed depend. activation	Deactivated 	1
IDE09394-Vehicle detection during darkness: permanent activation	Deactivated 	1
IDE09395-MAS08849-Threshold value for object quality-Threshold value for low object quality	60	3
IDE09395-MAS08850-Threshold value for object quality-Threshold value for average object quality	75	3
IDE09395-MAS08851-Threshold value for object quality-Threshold value for high object quality	90	3
IDE80006-Analysis 6	not activated 	1
IDE80007-Analysis 7	not activated 	1
IDE80010-Analysis 10	FF FF 	2
IDE80017-MAS03981-Analysis 17-Minimum heating time	0 min	8
IDE80017-MAS03982-Analysis 17-Minimum idling time	0 min	8
IDE80017-MAS03983-Analysis 17-Maximum camera temperature	85 ∞C	8
IDE80017-MAS03984-Analysis 17-Maximum activation temperature	75 ∞C	8
IDE80017-MAS03985-Analysis 17-Initial heating time	3 min	8
IDE80017-MAS03986-Analysis 17-Lower temperature threshold for deicing	-20 ∞C	8
IDE80017-MAS03987-Analysis 17-Upper temperature threshold for deicing	2 ∞C	8
IDE80017-MAS03988-Analysis 17-Debounce time for A/C condensation risk signal	0 s	8
Elapsed Time: 00:11
Mike_Jones
C?ID=18137
More information it appears that the issues revolve around these two adaptations.
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning (to active)
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold _high (to active)
If neither are activated I get both Lane Assist and Active Lane Assist menus in Grey - adding the others sometimes brings up Active Lane Assist but then I could end up with no menu at all. However sometimes the Lane Assist Icon flickers, and I even had a situation where the lane assist button toggles the vibration check box!
hadez16
C?ID=289891
Your maps were measurement maps, not adaptation.
You have to hit the adaptation check box...
Mike_Jones
C?ID=18137
Sorry 5F was correct 8e below, hope it helps!
;SW:4H0-907-107-H   HW:4H0-907-107 ---  Image Processing
;Component:BV-SG         H33 0090	 Coding:044229040111
;EV_BC7	1001	EV_BC7.rod
;Saturday	6	July
;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
;VCID: 2C57C8CF47DCDF2F15-8078
IDE00820-Activating and deactivating all development messages	0	1
IDE01958-Steering wheel vibration factory setting	activated 	1
IDE03462-Menu for time of assisted steering	activated 	1
IDE03463-Menu for steering wheel vibration	activated 	1
IDE03465-Steering wheel vibration active	activated 	1
IDE03466-Steering assistance active	not activated 	1
IDE04160-Direct. stab. assist speed threshold during towing mode	325 km/h	2
IDE04725-Intervention moment factory setting	Late 	1
IDE04726-Intervention moment	Early 	1
IDE04729-Direct. stab. assist.: acoustic warn when driving w/o hands	Gong 1 	1
IDE04733-Road sign detection fusion mode	Road sign fusion 	1
IDE04734-Display general maximum speed	Always 	1
IDE04735-Display invalid commands	111	1
IDE04736-Display end of speed limit symbol	1	1
IDE04737-Display no passing allowed	activated 	1
IDE04738-Predictive route data run time	0 ms	1
IDE04815-Display valid additional signs	activated 	1
IDE04816-Prioritize additional wetness signs	activated 	1
IDE04817-Sort valid traffic signs	174 km/h	2
IDE04841-Sorting alternatives	425 km/h	2
IDE04908-Factory setting f activation stat of directional stab assist	On 	1
IDE05984-Directional stabilization assist driver inact deactiv threshold	Late 	1
IDE05985-Directional stab. assist.: intensity: steering wheel vibration	Strong 	1
IDE05986-Directional stab. assist.: intensity: power steering support	Strong 	1
IDE07596-Personalization of lane dept. warning Cl. 15 on	activated 	1
IDE80010-Analysis 10	activated 	1
IDE80015-MAS00138-Analysis 15-1	0	3
IDE80015-MAS00139-Analysis 15-2	0	3
IDE80015-MAS00140-Analysis 15-3	0	3
IDE80015-MAS00141-Analysis 15-4	0	3
IDE80016-MAS00138-Analysis 16-1	0	15
IDE80016-MAS00139-Analysis 16-2	0	15
IDE80016-MAS00140-Analysis 16-3	0	15
IDE80016-MAS00141-Analysis 16-4	0	15
IDE80016-MAS00142-Analysis 16-5	0	15
IDE80016-MAS00143-Analysis 16-6	0	15
IDE80016-MAS00144-Analysis 16-7	0	15
IDE80016-MAS01338-Analysis 16-8	0	15
IDE80016-MAS03035-Analysis 16-9	0	15
IDE80016-MAS03036-Analysis 16-10	0	15
IDE80016-MAS03037-Analysis 16-11	0	15
IDE80016-MAS03038-Analysis 16-12	0	15
Elapsed Time: 00:11
hadez16
C?ID=289891
What about activating this?
Mike_Jones
C?ID=18137
Pressing the lane assist button enables this activation?
hadez16
C?ID=289891
I can't figure out what is wrong with your retrofit.
Can you make a video of this phenomenon described?
Mike_Jones
C?ID=18137
Video links attached 1 shows turning on and off vibration using the lane assist button on the stalk. Note also the menu changes across all three from Audi Lane Assist to Active Lane Assist? Also shows flickering instrument indication with no button presses???
[video]https://www.dropbox.com/s/1jh2bp984mlggwp/Lane%20Assist%201.mp4?dl=0[/video]
[video]https://www.dropbox.com/s/lzv29pv9u8jo0p5/Lane%20Assist%202.mp4?dl=0[/video]
[video]https://www.dropbox.com/s/gh1afy2mv7pcory/Lane%20Assist%203.mp4?dl=0[/video]
hadez16
C?ID=289891
I've never seen something like that.
Are you able to COMPLETELY revert all changes made since you retrofitted the stalk?
Mike_Jones
C?ID=18137
I have a "friendly" dealer who is going to take a look on Sunday - there is suggestion of firmware issues on the 5F on early FL models. Odd the Traffic Sign Coded perfectly with menus no problem. Thanks for your help.
Mike_Jones
C?ID=18137
Hello again, I think the issue is more than the 5F as I seem to have picked up the flickering issue described elsewhere. Can you (or anyone confirm) if they have done FL lane assist without side assist - I don't have any errors so I am thinking it is probably still adaptation. I have "unpicked" all the changes one by one and then reapplied and get the same issue. I am surprised the car "allows" it to work when the whole display is flickering.
