Thanks for posting the current scans. There were 2 identical scans from Wednesday,26,June,2019,21:51:49:57315 so I deleted one of them.
03-
Original:
Address 03: Brakes (J104) Labels:. 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 P HW: 8R0 907 379 P
Component: ESP8 quattro H09 0080
Coding: 2D554C
Shop #: 06335 000 00000
VCID: 4DD28705140EFD2E2A-8018
Current:
Part No SW: 8R0 907 379 C HW: 8R0 907 379 C
Component: ESP8 quattro H06 0230
Coding: 025500
VCID: 40CCAE31D35C204FD5-8014
I don't believe the installed module is correct but you should try to code it to 2D554C. code 61378 = Coding Enabling will be required before coding is possible. If it won't accept the factory condition coding I would look for the identical used 8R0 907 379 P module.
44-Steering Assist
Original:
Dead/Address 44: Steering Assist
Current:
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8R0 909 144 Q HW: 8R0 909 144 L
Component: RCevo H54 0702
Revision: 00000002 Serial number: 0000033813
Coding: 100000010001
Shop #: 06192 000 00000
Dataset: EV_RCEPSAU48X 104002
: EV_RCEPSAU48X_104.
VCID: 46C0B829F9780E7FEF-8012
I'll be back for an edit after this phone call ....
I cannot use ETKA/ to determine what the original software part number was so verify the replacement rack has the identical part numbers on it. There is #44 long coding helper info available but would to try coding 44 to: 100001000001
I doubt 44 will require a code prior to coding but 43702 is listed in that label file and will appear in the form of a pop-up balloon when connected with .
