Hi guys, can any body help with the errors I have below.
I carried out a scan as my auto start/stop no longer works.
This happened after replacing the battery.
I've checked the coding for the battery and it seems ok.
I've also checked all fuses and examined all the wiring including the connection for monitoring at the battery itself.
I'm at a loss now as I can't get rid of these codes.
The car starts and runs fine, just no start/stop.
Monday,27,May,2019,17:40:30:30223
VCDS Version: 18.9.1.0 HEX-V2 CB: 0.4505.4
VIN: WAUZZZ8T1FA014375 License Plate:
Chassis Type: 8T-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 30 36 42 44 46 52 53 56 5F
6C A9
VIN: WAUZZZ8T1FA014375 Mileage: 67190km-41749miles
Address 01: Engine (J623-CREC) Labels: None
Part No SW: 8K2 907 551 A HW: 4H2 907 551 A
Component: 3.0l V6 TFSI H10 0003
Revision: --H10---
Coding: 1A2500340427010B2800
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM30TFS0218K2907551A 002003
ROD: EV_ECM30TFS0218K2907551_002.rod
VCID: 313EE07241AE3A7F213-8064
Readiness: 1110 0001
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8K0 927 166 HW: 0B5 927 156 K
Component: 0B5 30TFSIRdW H02 0002
Revision: --H02---
Coding: 000001
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501021 001019
ROD: EV_TCMDL501021.rod
VCID: 72BC2F7E84284167989-8026
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CP HW: 8K0 907 379 CP
Component: ESP8 quattro H09 0020
Coding: 291DCC01
VCID: 094E6892893E22BFC93-805C
Part No SW: 8K0 907 064 JE HW: 8K0 907 064 JE
Component: BCM2 2.0 H14 0650
Coding: 01B04040000000000000
VCID: 7CA00146D6EC0717C25-8028
Subsystem 1 - Part No SW: 8K0 959 754 AH HW: 8K0 959 754 AH
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0514000090953012
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 0214000132448012
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 E HW: 8T0 959 760 E
Component: MEM-BFS H10 0077
Revision: AA000000 Serial number: 00000108711556
Coding: 01237025002C00000000
VCID: 45D6A4A2E5A686DFEDB-8010
Part No SW: 8K2 820 043 AQ HW: 8K2 820 043 AQ
Component: KLIMA 3 ZONEN H04 0122
Revision: D1000000 Serial number: 01140720142252
Coding: 6626028000
VCID: 78A81D56E2D42B37A6D-802C
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000862216101
Coding: 260000108034AFC00081404300001D0D0F1D438A27090201000008004400030100000034000000
Shop #: WSC 06325 123 12345
Subsystem 1 - Part No SW: 8T2 955 119 D HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 040714 H13 0080
Serial number: SWF14077045112
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 22912803
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000001607140946
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: F3D80C37000000000001
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H48 0610
Serial number: 003KFDC2VBS6
Coding: 30533933363030303030554A305238543053
VCID: 48C8AD96D2349BB716D-801C
Serial number: 6334MSME47695463H
Serial number: 6344MSME4769541DN
Serial number: 6352QSME4944056EN
Serial number: 6362QSME544316528
Serial number: 63732SME26433E40Z
Serial number: 63832SME36430054P
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862NGF0008J
Coding: 000036
VCID: 48C8AD96D2B49BB716D-801C
Component: E221 - MFL H03 0003
Part No SW: 8T0 920 984 C HW: 8T0 920 984 C
Component: KOMBIINSTR. H35 0564
Revision: 00000000 Serial number: Z9J367F7F
Coding: 33AF010003012600010400
VCID: 3FDAB64A877ADC0FA77-806A
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0060
Revision: 1Y080030 Serial number: 3041Y1471211C5
Coding: 80CF07FF00
VCID: 4ACC979ECCB869A7009-801E
00458 - Control Module for Battery Monitoring (J367)
Fault Frequency: 14
Reset counter: 45
Mileage: 66277 km
Date: 2019.05.24
Time: 12:29:19
Bin. Bits: 11111
Voltage: 14.00 V
Count: 6
Bin. Bits: 10000
03705 - Voltage Regulator
Fault Frequency: 14
Reset counter: 45
Mileage: 66277 km
Date: 2019.05.24
Time: 12:29:19
Bin. Bits: 11111
Voltage: 14.00 V
Count: 6
Bin. Bits: 10000
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 B HW: 8K0 907 440
Component: STS H04 0020
Revision: S0H04000 Serial number: 00000000105843
Coding: 01010101000000000001000102
VCID: 2D06FC025D165E9F05B-8078
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H10 0077
Revision: AA000000 Serial number: 00000110471872
Coding: 01237125002C00000000
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0305
Coding: 011C02224021120102
VCID: 56F473EE08003D47941-8002
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 J HW: 8K0 909 144 B
Component: RCEPS H41 0509
Revision: 00001000 Serial number: 0010758141
Coding: 100000000001
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_RCEPSAU48X 008016
ROD: EV_RCEPSAU48X_008.rod
VCID: 3828DD56A2D4EB3766D-806C
Revision: 00002001 Serial number: 0341817723
Coding: 011B068280B908008330003680000047
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0305
Coding: 011C02224821120102
VCID: 55F674E21506365F9DB-8000
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 10000000406951
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A2CC75E9CD8F927909-806E
Part No SW: 4G0 035 061 S HW: 4G0 035 061
Component: Radio U DAB H60 0154
Revision: AB001007 Serial number: 109G%0E7951328
Coding: 010103020100000001
Part No SW: 8R2 035 666 L HW: 8R2 035 666 C
Component: H-BN-EU H47 1036
Revision: -------- Serial number: 206G30EB009498
Coding: 140101020206A1EF41808B5E00000403E40000020000000000
VCID: 42DCBFBEF488B1E7C89-8016
Subsystem 1 - Part No: 8R0 060 884 GA
Component: EUR 2019 2802
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130GN0E3090910
Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
Component: E0380 Bedient H02 0030
Serial number: 00000001933313
Component: CD-Database 5950
Reset counter: 42
Mileage: 66277 km
Date: 2019.05.24
Time: 12:19:50
Text: DUA130,Front,M,0,0,6
03623 - Invalid Secruity/Release Code
Reset counter: 42
Mileage: 66277 km
Date: 2019.05.24
Time: 12:19:49
Hex Value: 0x0004
Hex Value: 0x000B
Count: 6
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H09--- Serial number: 525PA8-J45935G
Coding: 1020008
VCID: 3828DD56AE54EB3766D-806C
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8K0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0006
Serial number: 140624200300
End----------(Elapsed Time: 01:40, VBatt start/end: 13.9V/13.9V)-----------
