MK7 Halo headlight range to cluster illum dimmer
darkchina811
ITALY
C?ID=333184
I am finalizing the retrofit of LED headlights to my Golf 7, I had halogens as stock. Halogens had a manual height adjustment next to the light switch, please see picture:
https://www.dropbox.com/s/iqsonxrlow820w0/HaloRange.jpg
since that dial is not necessary anymore, I replaced it with the cluster illumination dimmer, please see picture:
https://www.dropbox.com/s/3wjcutqvq0m973q/ClusterDimmer.jpg
this is the wiring diagram, where I understand they are wired the very same, so I believe they are exchangeable:
https://www.dropbox.com/s/lgarsspw4087972/IllumWiring.JPG
actually the illumination dimmer does not work, so I wonder if any coding/adaptation need to be adjusted. I looked into modules 09 and 17 but could not find anything obvious.
does anybody have a solution? thanks :)
PetrolDave
Westbury, UK
C?ID=1423
With 398 posts here you should know that when asking a question about coding or adaptation you need to include a full unedited VCDS Auto-Scan :thanks:
darkchina811
ITALY
C?ID=333184
you have a point. the autoscan is here and all the adaptation maps are here:
https://www.dropbox.com/s/pofkgokte2gy04w/NETWORK_JUN132019.zip
for the record, I tried DISABLING BIT 2 from BYTE 12 in module 17 without any luck.
Thursday,13,June,2019,16:08:18:06888
VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
Dealer/Shop Name: dB
Workshop Code: 031 33097 006209
VIN: WVWZZZAUZHW0xxxxx   License Plate: FULL-LED-FINAL
Mileage: 29697km-18452mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 18 19 3C 42 44 52 55 5F 65
VIN: WVWZZZAUZHW0xxxxx   Mileage: 29697km-18452miles
Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HB    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H25 2833
   Revision: R7H25---
   Coding: 0119003A23441D082000
   Shop #: WSC 33097 031 06209
   ASAM Dataset: EV_ECM14TFS01104E906027HB 001005
   ROD: EV_ECM14TFS01104E906027HB.rod
   VCID: 6B833BBF03045EDF0F3-803E
   CAN Converter 01:
Readiness: 1110 0001
   Part No SW: 5Q0 614 517 CC    HW: 5Q0 614 517 AG
   Component: ESC           H62 0637
   Revision: 00000000    Serial number: 91596000011507
   Coding: 01FA6AA1242219704779060841C62980562498E26082947314205008408903
   VCID: 74B120C35E3A8127DE9-8020
   Part No SW: 5G0 907 044 BM    HW: 5G0 907 044 BM
   Revision: 00001K08
   Coding: 00020004104111011005004000101022
   VCID: 73B323DF5B34861FC73-8026
   Serial number: 01061633700891
   Coding: 00000846C20102FB0B244080B11407281400000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 045170030E9AB1A7EE9-8050
   Component: WWS    160522  043 0551
   Serial number:         160601172917
   Coding: 0E4DFD
   Component: RLFS  024 0042
   Serial number: Y13M05D10H00M20S03S4
   Coding: 06A8DD
   Serial number: 000000000ZY15028208R
   Serial number: 00000000000030139763
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Serial number: 000308417617145
   Coding: 0271165041
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 50F98C538A629D071A1-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 G    HW: 5Q0 907 567 G
   Component: ACC3          H08 0390
   Serial number: 19021303030627
   Coding: 00000300FE030B
   ASAM Dataset: EV_ACCBoschMQB 001021
   ROD: EV_ACCBoschMQB_VW37.rod
   VCID: 3FDBBFEF27FC127FF3B-806A
   Serial number: 003F6R1V1W4Y
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 41DFB9175108648F85F-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 506 16
   Serial number: 35767000000432B44C1Q
   Subsystem 2 - Part No SW: -----------    HW: 480 001 506 16
   Serial number: 358670000008B4C4DB17
   Subsystem 3 - Part No SW: -----------    HW: 480 400 306 16
   Serial number: 3516502BB205729313D3
   Subsystem 4 - Part No SW: -----------    HW: 480 401 105 16
   Serial number: 3526502AF2076340F201
   Subsystem 5 - Part No SW: -----------    HW: 480 401 106 16
   Serial number: 35565029B21160C1025X
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 13061608490829
   Coding: 0400
   VCID: 0D4755275DD0F0EFB17-8058
   Part No SW: 5G1 920 750 B    HW: 5G1 920 750 B
   Component: KOMBI         303 8311
   Coding: 03A501802E88000D02882B0D1401000000000000
   VCID: 26150A8BD866A3B790D-8072
   Part No SW: 5Q0 963 272 B    HW: 5Q0 963 272 B
   Component: STH-MQB       006 0069
   Coding: 1309
   VCID: 3537DDC715C0D82F297-8060
   Component: R64 D208L  004 0401
   Serial number: 00000000000000180382
   Revision: --------    Serial number: 0004271482
   Coding: 030100043F085700FB000258080F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 7CA108E3766AC967969-8028
   Component: E221__MFL-DC1  H10 0038
   Serial number: 29140002632800044485
   Coding: 2C0000
   Serial number: 8442320304
   Component: HRE_Master    H11 0071
   Serial number: 0392234969
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C21C8E336EA0967D69-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H11 0071
   Serial number: 0381249049
   Coding: 020111
   Serial number: 300516EEU02971
   Coding: 003F0220D000040100001000
   VCID: 43D3B31F4B14769F973-8016
   Coding: 8307
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2DCEFB3CDE3757C45-806E
   Serial number: 280516EER24731
   Coding: 003F0020DE00040100801000
   VCID: 42DDB61B540E7F979C5-8016
   Coding: 029A000001000000
   Shop #: WSC 00028 028 00068
   VCID: 75B71DC75540982FE97-8020
   Part No SW: 3Q0 035 824 B    HW: 3Q0 035 824 B
   Component: MU-S--ER      710 0744
   Coding: 02730000AA0000005111000100080A001F0206D40120010003
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2C01F8A3C68A99E7469-8078
   Subsystem 1 - Part No SW: 5G6 919 605     HW: 5G6 919 605
   Component: ABT_Std-2  H50 8120
   Serial number: VWZ6ZHT1541317
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 40000000018766
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3431E0C31EBAC1271E9-8060
End----(Elapsed Time: 01:38, VBatt start/end: 12.1V/12.0V. VIgn 12.0V)-----
jgordon
C?ID=62880
I don't have an answer, but I'm looking for similar information. I want to be able to dim the dashboard/instrument panel lights to 'off' or at least much darker than the factory setting. If you find an answer, please share. See the clues left by others in my earlier thread by searching for my user name 'jgordon'. It's the only thread I've posted.
darkchina811
ITALY
C?ID=333184
does anybody have a MQB car with the dimmer fitted as stock? I am stumbled upon this and I could scans/admaps as an example.
DV52
C?ID=194404
^^^^^ Darkchina- Hi.
I've developed a database (read, MS excel spreadsheet) of the "standard" function for BCM code switches for MQB platform vehicles over a number of years.
The data in my spreadsheet has come from many places (i.e. the net, options on various diagnostic cables and rare discussions with dealer master-technicians). At first in good citizen fashion, I started the spreadsheet by also recording the source of the information, but in my characteristic slack style that part of my record keeping disappeared - so attribution of the data is not possible (alas).
Anyhow - this is an extract from my spreadsheet that might be of interest:
  • Byte 7, Bit 0-1 (Lighting adjustment-Input media),
  • Options: not installed=hex0, Potentiometer=hex1, Button=hex2, HMI=hex3
The code string on your auto-scan reports Bit 7, Bit 0-1 as hex3 (i.e. control via the MENU). Try changing Bit 1 to 0
EDIT: Arrrhh........... I found it- always rely on the "yellow" helper screens!!! ;)
darkchina811
ITALY
C?ID=333184
thank you Don, I made some progress. I changed bits 0-1 to hex 01 (potentiometer) and here's the error I get:
https://www.dropbox.com/s/yah7gm02rlfajdt/DimmerFault.jpg
this makes me believe that the BCM does not sense the pot.
so I opened both pots, the old headlight level range and the new illum dimmer. they basically are the same, they have a 7pin connector but only 5 pins are populated.
pins 2 and 6 are for the illumination.
pins 3, 4 and 5 are the actual pot (the resistor is across 3 and 4 and 5 is the wiper).
when the car was stock, pin 5 was directly connected to the two motors that regulated height inside the halogen headlights. that wire is now disconnected on the headlights' side, because the new LED headlights height is regulated by control module 55.
so that pin 5 should now go to BCM, but I am not sure where. the wiring diagram says it COULD go to B33 "according to equipment / from May 2017", so I am perplexed.
DV52
C?ID=194404
^^^ hmm... small baby steps!!!;) I can't find much about the potentiometer for the illumination on my WD s. But I did manage to find this on the BCM pin out:
T73c /19 - Designation= Switch and instrument illumination regulator -E20-
Not sure if it helps, or hinders - hope the former, but I apologize if the latter applies
darkchina811
ITALY
C?ID=333184
what revision of WD do you have? mine is JUNE 2017, from erWin, and on the BCM pinout B33 and C19 are both shown as unused (blank).
E20 is indeed the pot I am trying to install :)
DV52
C?ID=194404
^^ My WD s are earlier (MY13 & MY14) - but the entire matter is academic if your BCM physically doesn't have either of the 2 x pin options in question. Perhaps start by confirming this (i.e. eye-ball the pins on the B & C sockets)? If the pins are not present, then you might need to forget this part of the exercise - it seems like the tail-wagging-the-dog if you are considering changing the BCM (IMO)
darkchina811
ITALY
C?ID=333184
BCM was replaced long ago with a CL, the correct HIGH version for the car. I believe all pins are there.
darkchina811
ITALY
C?ID=333184
UPDATE:
BCM does not have pin B33 so that's a dead end;
a friend made me notice our common BCM pinout calls for the pot to be connected on pin A55. I tried this morning and the error stays so that's another dead end.
we also found out this dimmer is installed only on NAR (USA market) cars so the wiring diagrams could be different. unfortunately I cannot access NAR schematics.
I will try pin C19 and see what happens.
it is really weird, I did plenty of retrofits on the car and everything worked out almost at first attempt; so far this stupid dimmer seems one of the most challenging things.
darkchina811
ITALY
C?ID=333184
darkchina811
ITALY
C?ID=333184
does anybody here from the USA can access the NAR version of erwin and kindly help me retrieve the diagram? I have VINs if needed.
darkchina811
ITALY
C?ID=333184
so I have acquired a NAR wiring diagram, and unfortunately it's not very different from the ROW version.
BCM C19 never shows as the input for the dimmer. at this point I am stuck.
I am starting to think it might be something about BCM parameterization, or the hell I know.
I might soon have to give up.
DV52
C?ID=194404
@DV52, can you please double check your diagrams? if it shows the output to BCM C19, where is the input to the dimmer coming from?
As I have said, I have very little information other than the extract below from the BCM pin-out. I've tried searching for "T73c /19" in all my WD s - but no hits.
If you believe that 5V is needed then this can easily be generated in lots of ways
darkchina811
ITALY
C?ID=333184
I tried the GFF with ODIS and I CANNOT see the dimmer value changing on the screen. this makes me believe that the dimmer is connected to the wrong pin.
now the interesting question is, why does VCDS show the value changing?
darkchina811
ITALY
C?ID=333184
together with the help of a friend, we finally found the solution. he has a little test set that simulates a car network with some modules, including a BCM of course.
so we put my old MID BCM into the jig and did some testing. it's way easier on a bench than in the car.
BCM pin A55 is a 5V reference output, needs to be wired to pin 4, input of the dimmer.
pin 5 of the dimmer (wiper) is the regulated signal that feeds back into the BCM pin C19.
dimmer pin 3 is ground.
it works fine and the errors all cleared.
now, fun fact, it turns out I also have a bad dimmer. at some point I wanted to double check the internal wiring and I opened it. it was tricky and I remember accidentally bending the wiper.
so I'll buy another and replace it, but it will have to wait until December because I am flying on saturday.
I wonder why this wiring is not documented on any diagram, even on the NAR version, which is the only market that actually has the option.
I wish there was a way to tell VAG headquarters they have some wrong diagrams.
darkchina811
ITALY
C?ID=333184
just a follow up, I definitely screwed up the dimmer when I opened it, so I bought a new (used) one, and I installed it a few days ago. all good and all errors are cleared.
for future reference, this is to retrofit the cluster illumination dimmer part number 5G0 941 334
