Hello everyone, I'm the old vcds customer from Turkey aprx. 10 years. First of all thanks for Ross-Tech team for supporting me everytime.
My car is Audi A6 C7.5 facelift, I have retrofitted Bose Sound system to my car. I have two fault codes in the unit 47 and one situation '47-Sound System -- Status: Cannot be reached 0100', I didn't solve them.
Do you have any suggestions?
Regards...
My scan result:
Regards...
My scan result:
Friday,07,June,2019,19:43:32:32917
VCDS Version: 19.4.0.0 (x64) HEX-V2 CB: 0.4504.4
Data version: 20190411 DS307.0
VIN: WAUZZZ4G2HN131757 License Plate:
Mileage: 41782km-25962mi Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 36 3B 42 44 46 47 52 53
55 5F 62 6C 6D 72
VIN: WAUZZZ4G2HN131757 Mileage: 41782km-25962miles
Address 01: Engine (J623-CYPA) Labels:. 06L-907-115-V1.clb
Part No SW: 4G5 907 115 B HW: 8T2 907 115
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0A2500322426010B2002
ASAM Dataset: EV_ECM20TFS0204G5907115B 001003
ROD: EV_ECM20TFS0204G5907115B.rod
VCID: 290FFC19D9712B1FC85-807C
Readiness: 1010 0001
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G0 927 166 P HW: 0B5 927 156 K
Component: 0B5 20TFSIRdW H06 0002
Revision: --H06---
Coding: 100001
ASAM Dataset: EV_TCMDL501021 001022
ROD: EV_TCMDL501021.rod
VCID: 3A2D33552CD79087B1F-806E
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 11A69E41886579829B00
ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
VCID: 41DF44B94101C35FF05-8014
Part No SW: 4H0 907 064 JT HW: 4H0 907 064 JT
Component: BCM2 2.0 H44 0582
Coding: 05A86F0E000000000000
VCID: 04518DAD1E1316779B3-8050
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 BL HW: 4G0 820 043 BL
Serial number: 05051700041555
Coding: 640110B8A90000
VCID: 6A8DC3151CF7E00701F-803E
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 GH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0368
Revision: 1502003S Serial number: 00001658978201
Coding: 0105C01550349FE04101408380001800CF9CC3082E08020100000894E901150200400034030000
VCID: 74B1DD6D4EB326F7AB3-8020
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 170319 H38 0080
Serial number: 170411054250
Coding: 004DF7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 20213888X81A955547A0
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 18 04 2017 00000155
Subsystem 4 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: 740907A800PAG0MUFU03
Component: Airbag10.43 H82 0092
Revision: -------- Serial number: 003P100DHUUX
Coding: 30333130313630323935554A304C34473053
VCID: 3B23365123EDA98FAA9-806E
Serial number: 3575HRB400S59KNIF9D4
Serial number: 3585HRB401659KNIIOUJ
Serial number: 3515JRB400I59H1QP8U%
Serial number: 3525JRB400E59H1UCA68
Serial number: 3554VRB400M59ISIG0G7
Serial number: 3564VRB400M59ISI811T
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 91560QDS00091
Coding: 000034
VCID: 3B233651236DA98FAA9-806E
Serial number: 20 03 2017 C0040146
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 934 P HW: 4G8 920 934 P
Component: TBenRdw H17 0225
Revision: 17001311 Serial number: 658050517596020
Coding: 13AF08000B410008160000
ASAM Dataset: EV_RBD4K 004060
ROD: EV_RBD4K_AU57.rod
VCID: 3E253F4530FFBCA78D7-806A
Part No SW: 4G8 907 468 K HW: 4G8 907 468
Component: J533--Gateway H15 0110
Revision: -------- Serial number: 00000002601281
Coding: C0CD072918
ASAM Dataset: EV_GatewPkoUDS 002011
VCID: 40D941BD4A0BCA57FFB-8014
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Serial number: 8698983604
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 1701310000000000074C
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: FLA H04 0021
Revision: AA001002
VCID: 678BBA210F65DD6F1E1-8032
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
Component: KLIMA FOND H08 0113
Serial number: 04051700041662
Coding: 20
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000253239115
VCID: 77ABEA615FC54DEF8E1-8022
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720WKRKG
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 33331E710BBD61CF729-8066
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0511
Coding: 011F1E015E00620002080002
VCID: 45D750A955A9EF7FCCD-8010
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000002 Serial number: 0000825462
Coding: 101000010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
Revision: 00002001 Serial number: 0441002936
Coding: 011F0E2080B93185C330088400030E470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 B
Component: Sensor, DWA 005 0002
Subsystem 2 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Subsystem 3 - Part No SW: 4G8 959 591 A HW: 8V3 959 591 A
Component: J245 PS40.402 H03 0004
Serial number: 0000FST001KVM9B00000
Coding: 901E02
Subsystem 4 - Part No SW: 4G0 947 135 F HW: 4G0 947 135
Serial number: 0000000AP00032560864
Subsystem 5 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: GEB.F.Heckoef H16 0811
Serial number: 66007=26
Address 47: Sound System (J525) Labels:* None
Part No SW: 4G5 035 223 D HW: 4G5 035 223
Component: MIB2_amp_P H02 0430
Serial number: 00000000033400
Coding: 3175510A0A8AF03A5A0000010F03
Shop #: WSC 27036 002 104857
ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
ROD: EV_AMPMst16C4Gen2BOSE_AU57.rod
VCID: 2313EE31BB5DF14F829-8076
1600 - Data Set Implausible
B2012 00 [009] - -
[Control module (data record download) - implausible data record for sound audio parameters]
Reset counter: 40
Mileage: 41782 km
Date: 2019.06.07
Time: 19:34:20
Voltage terminal 30: 12.1 V
1636 - Data Set Implausible
B2012 00 [009] - -
[Steuergerät (DatensatzDownload) - Datensatz unplausibel für 3D-Audio]
Reset counter: 40
Mileage: 41782 km
Date: 2019.06.07
Time: 19:34:20
Part No SW: 4G8 959 792 H HW: 4G8 959 792 F
Component: TSG BF H04 0511
VCID: 44D14DAD5E93D677DB3-8010
Part No SW: 4H0 907 801 M HW: 4H0 907 801 M
Component: EPB-4 H01 0018
Revision: -------- Serial number: 00000002185694
ROD: EV_ParkiBrake_VW51.rod
VCID: 323D1B75F4A768C779F-8066
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Component: MxB-ECU 001 0100
Coding: 04FA02102A600200
VCID: 34311D6D0EB366F76B3-8060
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01E00
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E01E00
Part No SW: 4G1 035 045 G HW: 4G1 035 045 D
Component: MU-H-N-RW 053 0910
Serial number: A738E0H7520123
Coding: 0175010A0000000013110002000A00002F0006E4F17001005E
Shop #: WSC 48150 002 1048576
VCID: 2411ED2DBE53F677FB3-8070
Subsystem 1 - Part No SW: V03 959 801 Q HW: -----------
Component: ROW 2018 --- 0068
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9HY807UT9
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G1 919 610 F HW: 4G1 919 610 F
Serial number: 90349QDS00012
Component: Gracenote2 --- 4011
Part No SW: 4G8 959 795 H HW: 4G8 959 795 F
Component: TSG HL H03 0511
Coding: 010F1C004000620002080002
VCID: 47CB5AA16FA5FD6F3E1-8012
Address 6C: Back-up Cam. (J772) Labels:| 4S0-980-556.clb
Part No SW: 4S0 980 556 HW: 4M0 980 556
Component: RVC Compact H08 0140
Coding: 0275000102002003000040
ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
ROD: EV_CamSysRVRVCPANAAU57X_001_AU57.rod
VCID: 78A9E95D525B429787B-802C
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G5 959 107 C HW: 4G5 959 107 A
Component: HDSG-Modul H02 0049
Revision: 13002001 Serial number: 071701648
Coding: 111104C020
ASAM Dataset: EV_HDSGAu571 001022
ROD: EV_HDSGAu571.rod
Component: TSG HR H03 0511
End----------(Elapsed Time: 02:05, VBatt start/end: 14.0V/14.1V)-----------
