OCTAVIA 18 2.0 TDI SCOUT
Jacek
C?ID=360566
Log;
Tuesday,21,May,2019,11:49:51:46674
VCDS Version: 19.4.0.0 (x64)  HEX-NET CB: 0.4504.4
Data version: 20190411 DS307.0
VIN: TMBLK7NE7J029   License Plate: OCTAVIA 18 2.0 TDI SCOUT
Mileage: 12580km-7816mi   Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 18 19 22 42 44 4B 52 5F 69 6C
          6D 75 D6 D7
VIN: TMBLK7NE7J02.....   Mileage: 12580km-7816miles
16-Steering wheel -- Status: OK 0010
19-CAN Gateway -- Status: OK 0010
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 BT    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H24 1542
   Revision: B5H24---
   Coding: 011D001A043605080000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM20TDI01104L906026BT 002003
   ROD: EV_ECM20TDI01104L906026BS_002.rod
   VCID: FDB273C86C47BCA020-80A8
   Part No SW: 0D9 300 014 T    HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5201
   Revision: 06454104    Serial number: TFK01801221873
   ROD: EV_TCMDQ250021.rod
   VCID: A91A7798C84FF0003C-80FC
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 CP    HW: 5Q0 614 517 AB
   Component: ESC           H25 0323
   Revision: 00000000    Serial number: 60578000001283
   Coding: 2607629134290975407B070560CB2964462C9002E0069474B0615070C009430B0009021212131AA435351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009
   ROD: EV_Brake1UDSContiMK100ESP_037_VW37.rod
   VCID: 814A0F3810BFD84044-80D4
   Part No SW: 5E0 907 044 AR    HW: 5E0 907 044 AR
   Component: Climatronic   H04 2002
   Revision: 00001K00
   Coding: 02010104004111011005000C00101022
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ACClimaBHBVW37X 006147
   ROD: EV_ACClimaBHBVW37X.rod
   VCID: F5A26BE85477E4E068-80A0
   Air quality sensor:
   Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 034 0245
   Revision: --------    Serial number: 86582802180244
   Shop #: WSC 73430 790 00000
   ROD: EV_BCMBOSCH_018.rod
   VCID: 86401C243991FF7871-80D2
   Subsystem 1 - Part No SW: 5E1 955 119 A    HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 180216  051 0916
   Serial number: 887353F0401804700252
   Coding: 164DDD
   Component: RLHS  047 0105
   Serial number: SBY18M03D07H15M43S37
   Coding: 00885D
   Sun Roof:
   Subsystem 3 - Part No SW: 5E9 959 591 B    HW: 6R0 959 591 D
   Component: J245 PS24.402  H04 0005
   Serial number: 0000FST001VQYSC00000
   Coding: 991800
   Roof Blind:
   Subsystem 4 - Part No SW: 5E9 959 591 C    HW: 8V3 959 591 A
   Component: J394 PS24.402  H04 0005
   Serial number: 0000FST001YTG0800000
   Coding: 991800
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Serial number: 000308417618029
   Coding: 0C71151151
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: D0ECFA7C8B55E1C89B-8084
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 3300600941FFC728949C810500400600000000000000000000
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: BE30B4C421C167B879-80EA
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W4P3YD6VM
   Coding: 98CCC000000000005C5400CC000840000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 85421B280497F46078-80D0
   Subsystem 1 - Part No SW: -----------    HW: 454 002 202 18
   Serial number: 35700000000F30FC6D2
   Subsystem 2 - Part No SW: -----------    HW: 454 001 702 18
   Serial number: 35800000000D41DC6D2.
   Subsystem 3 - Part No SW: -----------    HW: 454 802 002 18
   Serial number: 351008E67B613000000M
   Subsystem 4 - Part No SW: -----------    HW: 454 801 202 18
   Serial number: 35200C9269613000000F
   Subsystem 5 - Part No SW: -----------    HW: 454 801 802 18
   Serial number: 35500490A8513000000A
   Part No SW: 5Q0 953 521 KP    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0245
   Revision: FF035035    Serial number: 20180223500526
   Coding: 1414
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 8A5828142D899B1815-80DE
   Part No SW: 5E0 920 741 E    HW: 5E0 920 741 E
   Component: KOMBI         203 0310
   Coding: 07A40809A9800008018C6A013001000800000000
   VCID: A6007CA4D951DF7811-80F2
   Part No SW: 5Q0 963 272 J    HW: 5Q0 963 272 J
   Component: STH-MQB       008 0080
   Coding: 9309
   VCID: BD32B3C82CC77CA060-80E8
   Component: R64 D208L  004 0402
   Serial number: 00000000000000416837
   Part No SW: 3Q0 907 530 L    HW: 3Q0 907 530 C
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007559541
   Coding: 030100345F087300EB00024A1C0F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF.rod
   VCID: B83CA2DC03E55988B3-80EC
   Subsystem 2 - Part No SW: 3V0 919 719 C    HW: 3V0 919 719 C
   Component: E221__MFL-PR6  H02 0160
   Serial number: 000000000B0162270218
   Serial number: 758860000018030916BA
   Part No SW: 0CQ 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7084
   Serial number: HA1-00026.01.18
   Coding: 0001
   VCID: CCD4EE0C677DC528E7-8098
   Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
   Component: TSG FS        011 0032
   Serial number: 0000307392097
   Coding: 001C09208000040000001100
   VCID: C5C2DB284417346038-8090
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000005960785
   Coding: 010200
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 03170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: F3A655F05A03FAD046-80A6
Address 4B: Multifunc. Module (J745)       Labels:* Redir Fail!
   Part No SW: 3Q0 907 338     HW: 3Q0 907 338
   Component: FCM MQB Low   002 0286
   Serial number: 01031810522879
   Coding: 000000070100047200003D01010000000000000000000000000000000000
   VCID: F2A850F42519F3D84D-80A6
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Component: TSG BFS       011 0032
   Serial number: 0000306866628
   Coding: 001C01208000040000001100
   VCID: C4C4C62C4F2D0D682F-8090
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000019728819
   Coding: 190200
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 874 C    HW: 5Q0 035 874 C
   Component: MU-S-ND-ER    H41 0471
   Serial number: SKZAZ2U0470648
   Coding: 03734201FF00000041111201008802232F020AC401208500CE
   ROD: EV_MUStd4CTSAT_VW41.rod
   VCID: B42496EC1F8DBDE89F-80E0
   Subsystem 1 - Part No SW: 5E0 919 605 M    HW: 5E0 919 605 M
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: SKZ6ZHV0614296
   Subsystem 2 - Part No SW: 5L0 051 236 AD    HW: -----------
   Component: ECE1 2018  --- 0910
   Part No SW: 5Q0 907 383 L    HW: 5Q0 907 383 L
   Component: Anhaenger     H27 0260
   Revision: 8C001004    Serial number: 0472319270
   Coding: 0100000202000000
   VCID: C0CCCA3C5B3511480B-8094
   Part No SW: 5Q0 980 568 A    HW: 5Q0 980 568 A
   Component: RVC Compact+  H07 0180
   Coding: 0473020123002017000048
   ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 006008
   ROD: EV_CamSysRVRVCARPANAMQBAB_006_VW37.rod
   VCID: BB36BDD032D372905E-80EE
   Part No SW: 5E0 959 107 A    HW: 5E0 959 107
   Component: HDSG-Modul    H01 0746
   Revision: 42001001    Serial number: 048800523
   Coding: 1233074003
   ASAM Dataset: EV_HDSGSk462 301136
   ROD: EV_HDSGSk462_SK37.rod
   VCID: AA188894CD49FB1835-80FE
   Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
   Component: OCULowMQBLGE  H17 0718
   Revision: --------
   Coding: 03730201EA423A0D3B1CBE020045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004044
   ROD: EV_OCULowMQBLGE_004_VW25.rod
   VCID: BC34BECC37DD75A857-80E8
Address D6: Light Ctrl Left 2 (A31)       Labels: 7P5-941-591.clb
   Part No SW: 7P5 941 591 AD    HW: 7P5 941 591 A
   Component: LED1L         H06 0005
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   VCID: FEB074C46141A7B839-80AA
Address D7: Light Ctrl Right 2 (A27)       Labels: 7P5-941-591.clb
   Component: LED1R         H06 0005
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
End----------(Elapsed Time: 01:48, VBatt start/end: 12.2V/12.1V)-----------
