Maps 2019 Tiguan SE maps
Maps
iwalkbarefoot
Western Pennsylvania, USA
C?ID=371131
2019 Tiguan SE 4Motion Factory Settings
Auto-Scan
Saturday,01,June,2019,13:01:09:47965
VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
VIN: 3VV2B7AX8KM027763   License Plate:
Mileage: 1087km-675mi   Repair Order:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 17 19 22 2B 3C 42 44 52 5F 6C CA
VIN: 3VV2B7AX8KM027763   Mileage: 1087km-675miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
   Part No SW: 83A 907 115     HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H31 0003
   Revision: 1DH31000
   Coding: 012A00122426012F34000000000000000000000000000000
   Shop #: WSC 00066 790 00450
   ASAM Dataset: EV_ECM20TFS01183A907115 001005
   ROD: EV_ECM20TFS01183A907115.rod
   VCID: 6393AE6E9BDE0DCFB73-8036
Readiness: 1110 1101
   Part No SW: 09G 927 158 DT    HW: 09G 927 158
   Component: AISIN AQ8     206 3549
   Coding: 0002000100000000000000000000000000000000
   Shop #: WSC 00066 790 00405
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 084999C242B88E97821-805C
   Part No SW: 5Q0 614 517 DD    HW: 5Q0 614 517 AC
   Component: ESC           H25 0424
   Revision: 00000000    Serial number: 52178000001762
   Coding: 0BFA6BA454221B73C57E0306A2C649D0D62AD8A3C045927C10415058C28A420B002864121A1C230935351919323200
   Shop #: WSC 01383 790 50316
   VCID: 76B5E73A384C8867E0D-8022
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0490822431
   Coding: 132C0C0723
   VCID: 43D34EEE3B1E6DCF973-8016
   Part No SW: 5NN 907 044 F    HW: 5NN 907 044 F
   Component: AC Automat    H35 4401
   Revision: 20K03000    Serial number: 00000D00236867
   Coding: 0002002420011800100500001211140E
   ASAM Dataset: EV_ACClimaPrehVW37X 002025
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 4FFB72DEE75699AF03B-801A
   Part No SW: 5Q0 937 087 BB    HW: 5Q0 937 087 BB
   Revision: --------    Serial number: C864150918034K
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7CA1F5120660D237969-8028
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 180905  034 0373
   Serial number: 18090521000830
   Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
   Component: G355_FeuchteS  H07 0002
   Serial number: 72254557
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0300091020180C202331
   Coding: 3200008110FF8728749C8145004097
   Shop #: WSC 00066 790 00273
   VCID: 3E253F1A50FC0027F8D-806A
   Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
   Component: AirbagVW21    005 0338
   Serial number: 003NUM0BMWP$
   Coding: 8CCCFC00000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 055790F675AA93FFF97-8050
   Occupant Detection:
   Serial number: IBH00000000000AB9ARR
   Coding: 303351
   Subsystem 2 - Part No SW: -----------    HW: 480 002 707 18
   Serial number: 357000000009C45DC23W
   Subsystem 3 - Part No SW: -----------    HW: 480 002 807 18
   Serial number: 35800000000ADB78233U
   Subsystem 4 - Part No SW: -----------    HW: 480 400 907 18
   Component: SideSensor_Dr  004 6149
   Serial number: 35100012E2AEB0C2C36C
   Subsystem 5 - Part No SW: -----------    HW: 480 401 007 18
   Component: SideSensor_Pr  003 6149
   Serial number: 35200019F2A0CC7185CI
   Subsystem 6 - Part No SW: -----------    HW: 480 402 708 18
   Component: FrontSensor_D  004 6149
   Serial number: 3550001042B7DB96D34B
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 708 18
   Component: FrontSensor_P  004 6149
   Serial number: 3560001142B7DB935353
   Part No SW: 5NA 920 850 C    HW: 5NA 920 850 C
   Component: KOMBI         351 2500
   Coding: 0BA40C1AA388CF0502882B0954000000A0000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009065
   VCID: 3FDB421E57F6092FF3B-806A
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5344
   Serial number: 05101800840277
   Coding: 030500347F085900FB0322481E0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 3D2738165DFA1B3FE17-8068
   Component: 1-00-0d-00-04
   Subsystem 2 - Part No SW: 5NA 959 442 A    HW: 5NA 959 442 A
   Component: E221__MFL-TAT  H06 0025
   Serial number: 2551818550702148FE2B
   Coding: 280000
   Serial number: 0404246100
   Part No SW: 0CQ 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7084
   Serial number: HA1-00002.07.18
   Coding: 0101
   VCID: 4CC165D21640A2B7669-8018
   Serial number: 18000282802007
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 33331E2E6BBEDD4F073-8066
   Component: HRE_Master    H12 0081
   Serial number: 0490464291
   Coding: 01011103
   ROD: EV_HREntryHella_VW37.rod
   Component: HRE_Slave  H12 0081
   Serial number: 0490944198
   Coding: 010111
   Part No SW: 5Q4 959 393 M    HW: 5Q4 959 393 F
   Component: TSG FS        006 0247
   Serial number: 50038827901558
   Coding: 003013200000048000000000
   VCID: 4DC768D6ED5AABBF717-8018
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Serial number: 00000000000000926548
   Coding: 011000
   Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  173 1081
   Coding: 811F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 50F971A2FA6886571A1-8004
   Part No SW: 5Q4 959 392 M    HW: 5Q4 959 392 F
   Component: TSG BFS       006 0247
   Serial number: 54038827803313
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Serial number: 00000000000000946254
   Coding: 091000
   Part No SW: 3Q0 035 844 B    HW: 3Q0 035 844 B
   Component: MU-S-S-US     724 0890
   Coding: 02730600BE00000051220001001808001F0500C40120050002
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2E050F5A809CF0A768D-807A
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  252 8130
   Serial number: VWZ6ZMV2765492
   Coding: 0123060120002017300040
   VCID: 392F2C0649D2271FCDF-806C
   Coding: 00804073260C
End----------(Elapsed Time: 01:28, VBatt start/end: 12.8V/12.8V)-----------
01 Map
;SW:83A-907-115   HW:06L-907-309-B ---  Engine
;Component:R4 2.0l TFSI  H31 0003, Coding:012A00122426012F34000000000000000000000000000000
;EV_ECM20TFS01183A907115,001005,EV_ECM20TFS01183A907115.rod
;Saturday,01,June,2019,12:53:23:47965
;VCDS Version: Release 19.6.0 (x64)  Data version: 20190529 DS308.0
;VCID: 6393AE6E9BDE0DCFB73-8036
IDE01945-Engine run-in oil pressure,not active ,1
IDE02332-Deactivate production mode,00 00 00 ,3
IDE04158-Activation of start-stop function,active ,1
IDE04617-Protective function,OFF ,1
IDE06726-Timing deviation after chain replacement: intake bank 1,0.50 °,2
IDE06728-Timing deviation after chain replacement: exhaust bank 1,2.31 °,2
IDE06730-Timing deviation after other repairs: intake bank 1,0.00 °,2
IDE06732-Timing deviation after other repairs: exhaust bank 1,0.00 °,2
IDE06734-Timing deviation: current value intake bank 1,0.00 °,2
IDE06736-Timing deviation: current value exhaust bank 1,0.00 °,2
IDE06738-Chain elongation: no. of valid initial values: intake bank 1,1 ,1
IDE06740-Chain elongation: no. of valid initial values: exhaust bank 1,2 ,1
IDE06742-Chain elongation: initial values valid: intake bank 1,not active ,1
IDE06744-Chain elongation: initial values valid: exhaust bank 1,not active ,1
02 MAP
;SW:09G-927-158-DT   HW:09G-927-158 ---  Auto Trans
;Component:AISIN AQ8     206 3549, Coding:0002000100000000000000000000000000000000
;EV_TCMAQ450031,001001,EV_TCMAQ450031_VW37.rod
;Saturday,01,June,2019,12:53:28:47965
;VCID: 084999C242B88E97821-805C
IDE00001-Production mode,not activated ,3
IDE04159-Deactivation of start-stop function,not activated ,1
IDE07160-Control module switch-off: switch-off time,20 minute,1
IDE80050-Analysis 50,254 ,1
IDE80051-Analysis 51,65535 ,2
IDE80052-Analysis 52,65535 ,2
IDE80053-Analysis 53,255 ,1
IDE80054-Analysis 54,255 km/h,1
Elapsed Time: 00:02
2B Map
;SW:3Q0-905-861-B   HW:3Q0-905-861-B ---  Steer. Col. Lock
;Component:ELV-MQBB      H05 0020, Coding:0800000000000000
;EV_ELVMarqMQBA0,002002,EV_ELVMarqMQBA0_VW37.rod
;Saturday,01,June,2019,12:57:14:47965
;VCID: 33331E2E6BBEDD4F073-8066
IDE07566-Steering column lock unlocked,unlock ,1
ENG128823-functional_check_manufacturer,tested ,1
ENG128824-functional_check_steering_column_supplier,tested ,1
Elapsed Time: 00:01
03 Map
Elapsed Time: 00:01
3C Map
;SW:5Q0-907-686-C   HW:5Q0-907-686-C ---  Lane Change
;Component:HRE_Master    H12 0081, Coding:01011103
;EV_HREntryHella,001028,EV_HREntryHella_VW37.rod
;Saturday,01,June,2019,12:57:17:47965
;VCID: 3D2738165DFA1B3FE17-8068
IDE02332-Deactivate production mode,Deactivating ,3
IDE05397-Calibration mode,not activated ,1
IDE80001-Analysis 1,not activated ,1
IDE80004-Analysis 4,not activated ,1
Elapsed Time: 00:01
05 MAP
;SW:3Q0-959-435-L   HW:3Q0-959-435-L ---  Acc/Start Auth.
;Component:VWKESSYMQB    037 1204, Coding:132C0C0723
;EV_KessyHellaMQBAB,004046,EV_KessyHellaMQBAB_004_VW37.rod
;Saturday,01,June,2019,12:53:51:47965
;VCID: 43D34EEE3B1E6DCF973-8016
IDE00001-MAS12708-Production mode-Deactivation of automatic shutdowns of terminal 15,not active ,3
IDE00001-MAS12709-Production mode-Deactivation of automatic rear lid opening,not active ,3
IDE00001-MAS12710-Production mode-Deactivation of terminal 50 request,not active ,3
IDE03251-Stop release for start-stop function,According to function requirements ,1
IDE04159-Deactivation of start-stop function,not active ,1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
IDE10844-Control module rear lid opening: duration status query,4960 ms,1
IDE10845-Control module rear lid opening: vehicle type,FE ,1
ENG153713-ENG129122-Byte12_diverse-environment_scan_step1,not activated ,1
ENG153713-ENG126978-Byte12_diverse-environment_scan_step2,not activated ,1
ENG153713-ENG154598-Byte12_diverse-exeption_drivers_doors_interior_scan,activated ,1
ENG153713-ENG154691-Byte12_diverse-interior_scan_clamp_15_new_concept,activated ,1
ENG153713-ENG154710-Byte12_diverse-open_cabrio_canopy_interior_scan,not activated ,1
ENG153713-ENG154787-Byte12_diverse-suppression_access_detection_for_remotestart,not activated ,1
ENG244871-ENG245027-Byte13_vit_lf-lock_via_toggle_by_closed_vehicle_skin,not activated ,1
ENG244871-ENG245033-Byte13_vit_lf-toggle_active,not activated ,1
ENG244871-ENG245019-Byte13_vit_lf-toggle_at _open_door,not activated ,1
ENG244871-ENG129126-Byte13_vit_lf-vit_evaluate_inversbit,not activated ,1
ENG244871-ENG129125-Byte13_vit_lf-vit_exit,not activated ,1
ENG126956-ENG126976-Byte9_VIP-active_vip,not activated ,1
ENG126956-ENG154580-Byte9_VIP-Coding_easyclose_locking,not activated ,1
ENG126956-ENG154581-Byte9_VIP-Coding_kick and_close_function,not activated ,1
ENG126956-ENG248655-Byte9_VIP-ECL_Start_ueber_ViP,not activated ,1
ENG126956-ENG129121-Byte9_VIP-Hitch_trailer_installation,not activated ,1
ENG126956-ENG142121-Byte9_VIP-vip_activation_on_clamp15,not activated ,1
ENG126956-ENG126977-Byte9_VIP-vip_deactivation_on_running_engine,not activated ,1
ENG129011-CAN_signal_transmitting_delay_of_car_roll _away_warning,1.00 s,1
ENG126957-CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff,1.00 s,1
ENG129010-CAN_signal_transmitting_duration_of_comfort_switch_off,10.00 s,1
ENG105462-CAN-timeout service-key message,260 ms,1
ENG105634-Correction value LED dimming,1.0 ,1
ENG114301-Cycletime for voltage monitoring during sleepmode,100 ms,1
ENG120046-Cyclic interior scan during clamp 15 on,10 s,1
ENG126961-deactivation_time_vip_slidingdoor,15 s,1
ENG126960-Debounce_time_detection,500 ms,2
ENG126959-Debounce_time_driver_presence,200 ms,1
ENG126948-delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle,300 ms,1
ENG129004-delay_time_Terminal_15_S_Shut_down_by_BEM,60.00 s,1
ENG105791-Delta value LED dimming curve first point 40 percent dimming,30.0 %,1
ENG105792-Delta value LED dimming curve forth point 100 percent dimming,5.0 %,1
ENG105793-Delta value LED dimming curve second point 60 percent dimming,15.0 %,1
ENG105794-Delta value LED dimming curve third point 80 percent dimming,10.0 %,1
ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open,not activated ,1
ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open,not activated ,1
ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery,not activated ,1
ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go,activated ,1
ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start,activated ,1
ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted,not activated ,1
ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation,activated ,1
ENG123038-ENG129119-DeveloperCoding: Proximity Sensor-energized_doorhandles_at_stateKL15on_when_opening_door,activated ,1
ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive,activated ,1
ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection,not activated ,1
ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv",activated ,1
ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT,activated ,1
ENG123036-ENG99363-DeveloperCoding: Search lights-ZAT active during clamp 58t on,activated ,1
ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load,not activated ,1
ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt,not activated ,1
ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt,not activated ,1
ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible,not activated ,1
ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk,not activated ,1
ENG123037-ENG129114-DeveloperCoding: vehicle environment-reactivate_all_doorhandles,not activated ,1
ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel,left-hand drive ,1
ENG105825-Diagnostic: wait time after power on,500 ms,1
ENG126943-Display_duration_emergency_off,3000 ms,1
ENG126944-Display_duration_error_mode_2_SPN,10 s,1
ENG126941-Display_duration_please_engage_P,10 s,1
ENG105898-Doorknob contact sensor disconnecting time,5400 min,1
ENG244875-duration_A-CAN_wake_up_for_Engine_ECU_wake_up,2000 ms,1
ENG126955-duration_to_ZAT_continuous_actuation_detection,1000 ms,1
ENG129005-duration_to_ZAT_multi_actuation_detection,3000 ms,1
ENG126950-duration_ZAT_debounce,50 ms,1
ENG129029-ENG142128-Easy_close_alignment-max_threashold_reopen_EasyClose,10 %,9
ENG129029-ENG142127-Easy_close_alignment-Max_time_IDGeber_rear,2.00 s,9
ENG129029-ENG142129-Easy_close_alignment-max_time_reentry_EasyClose,7.00 s,9
ENG129029-ENG142130-Easy_close_alignment-min_rssi_values_hysteresis_EasyClose,20 ,9
ENG129029-ENG142126-Easy_close_alignment-Min_threashold_trunk,50 %,9
ENG129029-ENG129138-Easy_close_alignment-RSSI_ sample_rate,400 ms,9
ENG129029-ENG129139-Easy_close_alignment-Timeframe_scan_active,20.00 s,9
ENG129028-ENG142124-Easy_close_detection_areas-Easy_close_antenna_current_step,04 ,5
ENG129028-ENG142125-Easy_close_detection_areas-Easy_close_open_door_antenna_current_step,02 ,5
ENG129028-ENG142032-Easy_close_detection_areas-Value_area_4,220 mV/m,5
ENG129028-ENG142033-Easy_close_detection_areas-Value_area_leaving_area,40 mV/m,5
ENG126966-environment_scan_cyclic_step1,700 ms,1
ENG126967-environment_scan_cyclic_step2,2000 ms,1
ENG126965-environment_scan_duration_step1,300 min,1
ENG126971-environment_scan_duration_step2,24 H,1
ENG126969-environment_scan_level_bem,2 ,1
ENG126968-environment_scan_responselevel_reduction,500 ,1
ENG126970-environment_scan_startdelay_time,5 s,1
ENG126958-Ignition_For_Immobilizer,Default ,1
ENG129016-Initialization_diagnostics_switching_terminal,not activated ,4
ENG107050-Interior scan: deceleration after comfort closing,3200 ms,1
ENG107051-Interior scan: max. engine speed for standing engine,10 km/h,1
ENG107052-Interior scan: opening threshold sliding roof,1 %,1
ENG107053-Interior scan: opening threshold window lifter,5.0 %,1
ENG107054-Interior scan: Speed - threshold,20 km/h,1
ENG153724-Interior_scans_clamp15_break_at_active_message,5000 ms,1
ENG153725-Interior_scans_clamp15_retry_at_active_message,5 ,1
ENG98656-internal,0 B,1
ENG129022-ENG142120-internal_keyminder_byte1-aktivate_function_trigger_access_leaving_elv,not activated ,1
ENG129022-ENG129115-internal_keyminder_byte1-allowa_remotestart_to_disable_keys,not activated ,1
ENG129022-ENG120037-internal_keyminder_byte1-Cyclic interior scan during active warning message "Key not found",not activated ,1
ENG129022-ENG100928-internal_keyminder_byte1-Seat Memory: scan after driver door opening,activated ,1
ENG129022-ENG99649-internal_keyminder_byte1-Seat Memory: scan after driver door opening no KESSY unlocking,activated ,1
ENG129022-ENG99417-internal_keyminder_byte1-Softtouch mounted,installed ,1
ENG129023-ENG99123-internal_keyminder_byte2-Inhibit ID-transmitter for passive go,activated ,1
ENG129023-ENG102581-internal_keyminder_byte2-Lock prevention tailgate,activated ,1
ENG129023-ENG101018-internal_keyminder_byte2-No locking with ID-transmitter last used interior,activated ,1
ENG129023-ENG103451-internal_keyminder_byte2-Re-open after passive comfort closing,activated ,1
ENG129023-ENG99711-internal_keyminder_byte2-Re-open last handling,not activated ,1
ENG129023-ENG103237-internal_keyminder_byte2-Re-open tailgate,activated ,1
ENG129020-ENG121989-internal_passive_entry_exit_byte1-Impairment Entry / Exit key on low battery,not activated ,1
ENG129020-ENG125240-internal_passive_entry_exit_byte1-lf_crc,not activated ,1
ENG129020-ENG99763-internal_passive_entry_exit_byte1-Passive Exit: access door not open,activated ,1
ENG129020-ENG103722-internal_passive_entry_exit_byte1-Passive Exit: all doors not open,not activated ,1
ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock,not activated ,1
ENG129021-ENG155267-internal_passive_entry_exit_byte2-lf_shutdown,activated ,1
ENG129021-ENG155268-internal_passive_entry_exit_byte2-lf_shutdown_gotrigger,not activated ,1
ENG129021-ENG100246-internal_passive_entry_exit_byte2-Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed,activated ,1
ENG129021-ENG123039-internal_passive_entry_exit_byte2-Passive Entry Exit,activated ,1
ENG129021-ENG103289-internal_passive_entry_exit_byte2-Passive Entry Exit: control by pulling door handle during active DSL,activated ,1
ENG129021-ENG103620-internal_passive_entry_exit_byte2-Passive Entry Exit: retry with antennastep 1,not activated ,1
ENG129021-ENG103529-internal_passive_entry_exit_byte2-Passive Entry: second control concept,not activated ,1
ENG107211-Key Minder: delay reunlocking tailgate,500 ms,1
ENG107212-Key Minder: p_keyless_eventsearch_holding_time,10 s,1
ENG107213-Key Minder: p_keyless_eventsearch_retries,2 ,1
ENG107363-LED dimming curve first point 20 percent dimming,40.0 %,1
ENG153886-lf_shutdown_timeout_2nd_operation,5 s,1
ENG107592-MCTX Pause,1 B,1
ENG107593-MCTX pause for Go / Key Minder,20 ms,1
ENG107594-MCTX pause for Go authentification,14 B,1
ENG107595-MCTX settling phase,10 B,1
ENG129013-min_receptiontime_vit,0 ms,1
ENG126945-min_time_for_Terminal_50_request,200 ms,1
ENG244880-Minimum_holdtime_ak,500 ms,1
ENG129003-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,1
ENG126940-Number_of_ZAT_activations_to_DTC,10 ,1
ENG129015-Passive Entry Exit: control by pulling the door handle during active DSL_timeout,2.00 s,1
ENG108166-Passive Entry Exit: entry request e-sliding door active time,500 ms,1
ENG108167-Passive Entry Exit: minimum activity time locking sensor,140 ms,1
ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY,220 ms,1
ENG108169-Passive Entry Exit: T_ACT_OP_2,5000 ms,1
ENG108297-Proximity Sensor: Comfort Exit-Enlargement,200 ms,1
ENG108298-Proximity Sensor: duration of proximity Signal,10 s,1
ENG108299-Proximity Sensor: lower limit Impuls,2000 µs,1
ENG108300-Proximity Sensor: lower limit proximity-Impuls,12200 µs,1
ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle,10.0 km/h,1
ENG108302-Proximity Sensor: max. Impulslength,75 ms,1
ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls,20400 µs,1
ENG108304-Proximity Sensor: max. intermission-length Diagnostic,14 ms,1
ENG108305-Proximity Sensor: max. length of Diagnosticimpuls,71 ms,1
ENG108306-Proximity Sensor: max. length of Entryimpuls,10400 µs,1
ENG108307-Proximity Sensor: max. length of Exitimpuls,40400 µs,1
ENG108308-Proximity sensor: max. length of signal hall sensor,100 s,1
ENG108309-Proximity Sensor: max. signal-length,120 s,1
ENG108310-Proximity sensor: max. tolerance data bit length,200 µs,1
ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle,20.0 km/h,1
ENG108312-Proximity Sensor: min. enginespeed for a running engine,300 /min,1
ENG108313-Proximity Sensor: min. length of Diagnosticimpuls,42 ms,1
ENG108314-Proximity Sensor: min. length of Entryimpuls,6200 µs,1
ENG108315-Proximity Sensor: min. length of Exitimpuls,24200 µs,1
ENG108316-Proximity sensor: min. tolerance data bit length,120 µs,1
ENG108317-Proximity Sensor: SP_X2,10 min,1
ENG108318-Proximity Sensor: SP_X3,1 ,1
ENG108319-Proximity Sensor: SP_X4,80 ,1
ENG108320-Proximity Sensor: SP_X5,1 ,1
ENG108321-Proximity Sensor: SP_X6,30 min,1
ENG108322-Proximity Sensor: SP_X7,1 ,1
ENG108323-Proximity Sensor: Time Power On,1960 ms,1
ENG123035-Proximity Sensor: Timervalue for ExitReverseOption,0 ms,1
ENG108325-Proximity sensor: turn-off limit from battery-manager,2 ,1
ENG108326-Proximity Sensor: upper limit intermission-length,10 ms,1
ENG120045-Reduced current for transponder-ID request,0 Step,1
ENG126939-rpm_threshold_engine_runnning,100 /min,1
ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol,5 Step,1
ENG108576-Scan Procedure: cycle convenience coverage limiting,65 ms,1
ENG108577-Scan Procedure: Number of Repeats,1 ,1
ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause,100 ms,1
ENG108579-Scan Procedure: Timeout Authentification Result,150 ms,1
ENG129017-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go,190 ms,1
ENG129018-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi,700 ms,1
ENG108582-Scan Procedure: Timeout LF Repetition,100 ms,1
ENG108585-ScanProcedure: Timeout Entry Response,260 ms,1
ENG108586-ScanProcedure: Timeout Response,100 ms,1
ENG126963-settime_trigger_entry_vehicle,500 ms,1
ENG126962-settime_trigger_exit_vehicle,500 ms,1
ENG129024-ENG120039-Sonstiges_byte1-Backdoor TSG,not activated ,1
ENG129024-ENG103075-Sonstiges_byte1-Battery manager mounted,activated ,1
ENG129024-ENG102728-Sonstiges_byte1-Diagnostic: service 86 - response on event,not activated ,1
ENG129024-ENG98656-Sonstiges_byte1-internal,not activated ,1
ENG129024-ENG102591-Sonstiges_byte1-Response extension for scan procedure,not activated ,1
ENG129024-ENG99430-Sonstiges_byte1-Scan Procedure: Timeoutcontrol active,activated ,1
ENG129024-ENG104010-Sonstiges_byte1-Use default antenna data,not activated ,1
ENG129025-ENG129137-sonstiges_byte2-interiorscan_clamp15_reach_trashhold,not activated ,1
ENG129025-ENG142122-sonstiges_byte2-sad_existing,activated ,1
ENG129025-ENG142123-sonstiges_byte2-trunk_ecu_existing,not activated ,1
ENG244883-Speed_ threshold_for_start_request_plausibilisation,10 km/h,1
ENG129007-Speed_threshold_for_driving_cycle_detection,3.0 km/h,1
ENG129006-Speed_threshold_for_moving_vehicle_detection,1.0 km/h,1
ENG129008-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,1
ENG109053-Standard dimming value ZAT,80 %,1
ENG126938-Terminal_15_adaption_body_control_module,Default ,1
ENG126946-Terminal_S_Timeout,30 min,1
ENG102207-Time Sensor Power Off Group 2,3600 min,1
ENG129027-Time_frame_VIP_kick_forecast,5 ,1
ENG126942-time_to_drive_cycle_detection,1.00 s,1
ENG126947-time_to_ignore_ignition_trigger,35 s,1
ENG126954-time_to_ZAT_Open_circuit_detection,1000 ms,1
ENG126951-time_to_ZAT_Short_circuit_fault_detection,60 s,1
ENG126949-time_ZAT_actuation_detection,3000 ms,1
ENG126952-time_ZAT_lock_after emergency_shutoff,1000 ms,1
ENG126953-time_ZAT_lock_after_normal_shutoff,500 ms,1
ENG129009-Timeframe_request_immobilizer_terminal_approval,10000 ms,1
ENG129019-timeout_convenience_coverage_limiting,75 s,1
ENG129014-Timeout_trigger_terminal_deactivation_central_locking,1.00 s,1
ENG244884-Toggle_offtime_other_doorhandle,2.00 s,1
ENG244885-Toggle_offtime_same_doorhandle,2.00 s,1
ENG109974-Voltage monitoring: overvoltage Delta,500 mV,1
ENG109975-Voltage monitoring: overvoltage for KESSY ECU,16000 mV,1
ENG109976-Voltage monitoring: overvoltage for Keyless Go,27000 mV,1
ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta,0 mV,1
ENG109978-Voltage monitoring: undervoltage Delta,500 mV,1
ENG109979-Voltage monitoring: undervoltage for KESSY ECU,9000 mV,1
ENG109980-Voltage monitoring: undervoltage for Keyless Go,6000 mV,1
ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta,0 mV,1
ENG120047-ZAT init value,0 %,1
ENG110364-ZAT nominal voltage,13.0 V,1
ENG110365-ZAT post-carridge during clamp 15 off,10 min,1
ENG153750-ZAT_clamp58xt_signal_factor,0.200 ,1
ENG153751-ZAT_clamp58xt_signal_offset,3.0 ,1
ENG153752-ZAT_first_fall_time_high_low_state,900 ms,1
ENG153753-ZAT_first_rise_time_low_high_state,100 ms,1
ENG153754-ZAT_motor_signal_timer_1,3000 ms,1
ENG153755-ZAT_motor_signal_timer_2,3000 ms,1
ENG153756-ZAT_pwm_offset_1_lower_limit,5 %,1
ENG153757-ZAT_pwm_offset_2_lower_limit,10 %,1
ENG153758-ZAT_pwm_peak1_upper_limit,90 %,1
ENG153759-ZAT_pwm_peak2_upper_limit,100 %,1
ENG153760-ZAT_second_fall_time_high_low_state,2000 ms,1
Elapsed Time: 00:51
5F Map
;SW:3Q0-035-844-B   HW:3Q0-035-844-B ---  Information Electr.
;Component:MU-S-S-US     724 0890, Coding:02730600BE00000051220001001808001F0500C40120050002
;EV_MUStd4CDELP,001001,EV_MUStd4CDELP_VW37.rod
;Saturday,01,June,2019,12:57:43:47965
;VCID: 2E050F5A809CF0A768D-807A
IDE00346-Summertime-automatic,manual ,1
IDE00758-Base volume of telephone,50 %,1
IDE00769-Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02121-CD eject button,Enabled ,1
IDE02122-Developer mode,not activated ,1
IDE02330-Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,49
IDE02502-Confirmation of installation change,36 2D ,2
IDE02699-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE03471-ENG117847-Vehicle configuration-advanced_range_display,OFF ,30
IDE03471-ENG249824-Vehicle configuration-AliBox,OFF ,30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing,OFF ,30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
IDE03471-ENG263540-Vehicle configuration-correction_e_mileage,0 ,30
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call,On ,30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,OFF ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,OFF ,30
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,OFF ,30
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,OFF ,30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
IDE03471-ENG261211-Vehicle configuration-internet_over_WLAN_default_setting,OFF ,30
IDE03471-ENG125049-Vehicle configuration-Joker_button_1,Not Present ,30
IDE03471-ENG125050-Vehicle configuration-Joker_button_2,Not Present ,30
IDE03471-ENG127492-Vehicle configuration-LGI,OFF ,30
IDE03471-ENG130246-Vehicle configuration-LTE_modul,activated ,30
IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30
IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,On ,30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_NAR ,30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
IDE03471-ENG117843-Vehicle configuration-my_audi,OFF ,30
IDE03471-ENG117845-Vehicle configuration-online_dictation,OFF ,30
IDE03471-ENG127495-Vehicle configuration-online_media,OFF ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,OFF ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,OFF ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,OFF ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF ,30
IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF ,30
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit,OFF ,30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,Data & language service active ,30
IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF ,30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi,OFF ,30
IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo,OFF ,30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
IDE03471-ENG117846-Vehicle configuration-remote_HMI,OFF ,30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,activated ,30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
IDE03471-ENG126143-Vehicle configuration-RVC_video_input,FBAS ,30
IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation,no restriction ,30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,no_region ,30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch,Not Present ,30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi,activated ,30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0 ,30
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold,OFF ,30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,On ,30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On ,30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
IDE03471-ENG126994-Vehicle configuration-TPEG_availability,OFF ,30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,blocked ,30
IDE03471-ENG137647-Vehicle configuration-UOTA,OFF ,30
IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,OFF ,30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
IDE03471-ENG117836-Vehicle configuration-VZAPro,OFF ,30
IDE03471-ENG127494-Vehicle configuration-VZO,OFF ,30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,OFF ,30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,OFF ,30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
IDE03902-Automatic ring break diagnostic,No automatic start ,1
IDE04295-Bluetooth: Preferred connection profile for phone book data,PBAP ,1
IDE04521-Sporadic ring break detection,Visual ,1
IDE04550-Bluetooth: Sniff mode,OFF ,1
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128 ,40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,5 ,40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128 ,40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128 ,40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128 ,40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128 ,40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-3 ,40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128 ,40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128 ,40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,6 ,40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128 ,40
IDE10480-MAS10742-Interface for external media: activation-Connection 2,activated ,4
IDE10604-Menu entries for mobile online services,not activated ,1
IDE11122-Country identification: country of sale HMI,US ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,blocked ,21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,blocked ,21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,blocked ,21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,blocked ,21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,blocked ,21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,blocked ,21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,blocked ,21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,blocked ,21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,blocked ,21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,blocked ,21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,blocked ,21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,blocked ,21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,blocked ,21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,blocked ,21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,blocked ,21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,blocked ,21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,blocked ,21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,blocked ,21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,blocked ,21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,blocked ,21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,blocked ,21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,blocked ,21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,blocked ,21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,blocked ,21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,blocked ,21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,blocked ,21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,blocked ,21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,blocked ,21
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,21
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,21
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,blocked ,21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,blocked ,21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,blocked ,21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,blocked ,21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,blocked ,21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,blocked ,21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,blocked ,21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,blocked ,21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,blocked ,21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,blocked ,21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,blocked ,21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,blocked ,21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,blocked ,21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,blocked ,21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,blocked ,21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,blocked ,21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,blocked ,21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,blocked ,21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,blocked ,21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,blocked ,21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,blocked ,21
IDE11503-Satellite radio tuner: pre-activated subscription,05 ,1
IDE11524-ENG249835-Vehicle function list BAP 2nd generation: expansion-chassis_control_0x57,not activated ,192
IDE11524-ENG249836-Vehicle function list BAP 2nd generation: expansion-chassis_control_0x57_msg_bus,not activated ,192
IDE11524-ENG142156-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42,not activated ,192
IDE11524-ENG142157-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42_msg_bus,not activated ,192
IDE11524-ENG142158-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47,not activated ,192
IDE11524-ENG142159-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47_msg_bus,not activated ,192
IDE11524-ENG249837-Vehicle function list BAP 2nd generation: expansion-convertibleTop_0x6C,not activated ,192
IDE11524-ENG249838-Vehicle function list BAP 2nd generation: expansion-convertibleTop_0x6C_msg_bus,not activated ,192
IDE11524-ENG152529-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51,not activated ,192
IDE11524-ENG152530-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51_msg_bus,not activated ,192
IDE11524-ENG137043-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45,not activated ,192
IDE11524-ENG137044-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45_msg_bus,not activated ,192
IDE11524-ENG185772-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D,not activated ,192
IDE11524-ENG185773-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D_msg_bus,not activated ,192
IDE11524-ENG142168-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D,not activated ,192
IDE11524-ENG142169-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D_msg_bus,not activated ,192
IDE11524-ENG142154-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41,not activated ,192
IDE11524-ENG142155-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41_msg_bus,not activated ,192
IDE11524-ENG152535-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50,not activated ,192
IDE11524-ENG152536-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50_msg_bus,not activated ,192
IDE11524-ENG248719-Vehicle function list BAP 2nd generation: expansion-ITM_0x65,not activated ,192
IDE11524-ENG248720-Vehicle function list BAP 2nd generation: expansion-ITM_0x65_msg_bus,not activated ,192
IDE11524-ENG249902-Vehicle function list BAP 2nd generation: expansion-lift_0x64,not activated ,192
IDE11524-ENG249903-Vehicle function list BAP 2nd generation: expansion-lift_0x64_msg_bus,not activated ,192
IDE11524-ENG185787-Vehicle function list BAP 2nd generation: expansion-mascot_0x83,not activated ,192
IDE11524-ENG185788-Vehicle function list BAP 2nd generation: expansion-mascot_0x83_msg_bus,not activated ,192
IDE11524-ENG152569-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E,not activated ,192
IDE11524-ENG152570-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E_msg_bus,not activated ,192
IDE11524-ENG139202-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44,not activated ,192
IDE11524-ENG139203-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44_msg_bus,not activated ,192
IDE11524-ENG127678-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40,not activated ,192
IDE11524-ENG127679-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40_msg_bus,not activated ,192
IDE11524-ENG142162-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A,not activated ,192
IDE11524-ENG142163-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A_msg_bus,not activated ,192
IDE11524-ENG142164-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B,not activated ,192
IDE11524-ENG142165-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B_msg_bus,not activated ,192
IDE11524-ENG142166-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C,not activated ,192
IDE11524-ENG142167-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C_msg_bus,not activated ,192
IDE11524-ENG185817-Vehicle function list BAP 2nd generation: expansion-vas_0x54,not activated ,192
IDE11524-ENG185818-Vehicle function list BAP 2nd generation: expansion-vas_0x54_msg_bus,not activated ,192
IDE11524-ENG142160-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48,not activated ,192
IDE11524-ENG142161-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48_msg_bus,not activated ,192
IDE13183-Deactivation/activation of the pop-up for active tracking services,00 00 00 00 ,4
MAS00951-Bluetooth,On ,1
MAS01968-Fan,normal ,1
MAS03782-WLAN,On ,1
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated ,60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not activated ,60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not activated ,60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not activated ,60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not activated ,60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated ,60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not activated ,60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated ,60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated ,60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not activated ,60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated ,60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,activated ,60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated ,60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated ,60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,not activated ,60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated ,60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated ,60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated ,60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus extended ,64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Databus Infotainment ,64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not activated ,64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Databus drivetrain ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Databus Infotainment ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Suspension data bus ,64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,activated ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus Infotainment ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,activated ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated ,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not activated ,64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated ,64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,not activated ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain ,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended ,64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated ,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,not activated ,64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Databus Infotainment ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus ,64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus ,64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Databus Infotainment ,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,activated ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended ,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension data bus ,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus Infotainment ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Databus Infotainment ,64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available ,8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Databus Infotainment ,8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available ,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Databus Infotainment ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain ,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Not available ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,Not available ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort data bus ,8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,Not available ,8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Available ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,OFF ,10
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,OFF ,10
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,OFF ,10
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode,RLE ,10
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,resolution_1 ,10
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,OFF ,10
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon,0 ,10
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most,OFF ,10
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,RLE ,10
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,resolution_1 ,10
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,OFF ,10
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,OFF ,10
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1,0 ,6
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2,50 ,6
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3,100 ,6
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1,0 ,6
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2,50 ,6
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3,100 ,6
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,0 ,12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10 ,12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,253 ,12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,1 %,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 %,12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,100 %,12
ENG141636-ENG142049-Key_code_monitoring-monitoring_keycode_0x00_0x07,FF ,32
ENG141636-ENG142050-Key_code_monitoring-monitoring_keycode_0x08_0x0F,FF ,32
ENG141636-ENG142051-Key_code_monitoring-monitoring_keycode_0x10_0x17,FF ,32
ENG141636-ENG142052-Key_code_monitoring-monitoring_keycode_0x18_0x1F,FF ,32
ENG141636-ENG142053-Key_code_monitoring-monitoring_keycode_0x20_0x27,FF ,32
ENG141636-ENG142054-Key_code_monitoring-monitoring_keycode_0x28_0x2F,FF ,32
ENG141636-ENG142055-Key_code_monitoring-monitoring_keycode_0x30_0x37,FF ,32
ENG141636-ENG142056-Key_code_monitoring-monitoring_keycode_0x38_0x3F,FF ,32
ENG141636-ENG142057-Key_code_monitoring-monitoring_keycode_0x40_0x47,FF ,32
ENG141636-ENG142058-Key_code_monitoring-monitoring_keycode_0x48_0x4F,FF ,32
ENG141636-ENG142059-Key_code_monitoring-monitoring_keycode_0x50_0x57,FF ,32
ENG141636-ENG142060-Key_code_monitoring-monitoring_keycode_0x58_0x5F,FF ,32
ENG141636-ENG142061-Key_code_monitoring-monitoring_keycode_0x60_0x67,FF ,32
ENG141636-ENG142062-Key_code_monitoring-monitoring_keycode_0x68_0x6F,FF ,32
ENG141636-ENG142063-Key_code_monitoring-monitoring_keycode_0x70_0x77,FF ,32
ENG141636-ENG142064-Key_code_monitoring-monitoring_keycode_0x78_0x7F,FF ,32
ENG141636-ENG142065-Key_code_monitoring-monitoring_keycode_0x80_0x87,FF ,32
ENG141636-ENG142066-Key_code_monitoring-monitoring_keycode_0x88_0x8F,FF ,32
ENG141636-ENG142067-Key_code_monitoring-monitoring_keycode_0x90_0x97,FF ,32
ENG141636-ENG142068-Key_code_monitoring-monitoring_keycode_0x98_0x9F,FF ,32
ENG141636-ENG142069-Key_code_monitoring-monitoring_keycode_0xA0_0xA7,FF ,32
ENG141636-ENG142070-Key_code_monitoring-monitoring_keycode_0xA8_0xAF,FF ,32
ENG141636-ENG142071-Key_code_monitoring-monitoring_keycode_0xB0_0xB7,FF ,32
ENG141636-ENG142072-Key_code_monitoring-monitoring_keycode_0xB8_0xBF,FF ,32
ENG141636-ENG142073-Key_code_monitoring-monitoring_keycode_0xC0_0xC7,FF ,32
ENG141636-ENG142074-Key_code_monitoring-monitoring_keycode_0xC8_0xCF,FF ,32
ENG141636-ENG142075-Key_code_monitoring-monitoring_keycode_0xD0_0xD7,FF ,32
ENG141636-ENG142076-Key_code_monitoring-monitoring_keycode_0xD8_0xDF,FF ,32
ENG141636-ENG142077-Key_code_monitoring-monitoring_keycode_0xE0_0xE7,FF ,32
ENG141636-ENG142078-Key_code_monitoring-monitoring_keycode_0xE8_0xEF,FF ,32
ENG141636-ENG142079-Key_code_monitoring-monitoring_keycode_0xF0_0xF7,FF ,32
ENG141636-ENG142080-Key_code_monitoring-monitoring_keycode_0xF8_0xFF,FF ,32
ENG167428-ENG167502-nhtsa_properties-limitation_dependency,Speed_threshold ,5
ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length,activated ,5
ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration,activated ,5
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,activated ,5
ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback,activated ,5
ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input,not activated ,5
ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists,not activated ,5
ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists,not activated ,5
ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps,not activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,activated ,5
ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad,not activated ,5
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,01 01 3C 02 3C 02 3C 02 50 02 50 02 64 02 6E 02 78 02 3C 02 3C 02 3C 02 50 02 1E 02 1E 02 1E 02 1E 02 02 02 02 14 05 5C ,40
ENG117809-p_damping_Display,5 ms,1
ENG117808-p_HMI_Display,13 %,1
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
Elapsed Time: 00:36
6C Map
;SW:5Q0-980-556-B   HW:5Q0-980-556-B ---  Back-up Cam.
;Component:RVC Compact   H12 0231, Coding:0123060120002017300040
;EV_CamSysRVRVCPANAMQBAB,006009,EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
;Saturday,01,June,2019,12:58:21:47965
;VCDS Version: Release 19.6.0 (x64)  Data version: 20190529 DS308.0
;VCID: 392F2C0649D2271FCDF-806C
IDE02709-Actuator: PWM signal,100 %,1
IDE03531-Wheel/tire description,1950 mm,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
MAS02209-Image contrast,50 %,1
MAS02851-Brightness,50 %,1
ENG119212-camera_off,35.00 km/h,2
ENG119211-camera_on,30.00 km/h,2
ENG119200-color,50 %,1
ENG119218-debounce_time_for_reverse_gear,0 ms,2
ENG119215-display_position,0 px,1
ENG119216-engine_restart_timer,0 ms,2
ENG119209-Frequency_Swinging_Logo,100 Hz,2
ENG119221-FSG_control_state,On ,1
ENG119220-ENG119101-grafic_element_setting-setting_1_color_value,FF FF ,128
ENG119220-ENG119099-grafic_element_setting-setting_1_HMI_mode,FF ,128
ENG119220-ENG119100-grafic_element_setting-setting_1_pallet_ID,255 ,128
ENG119220-ENG119128-grafic_element_setting-setting_10_color_value,FF FF ,128
ENG119220-ENG119126-grafic_element_setting-setting_10_HMI_mode,FF ,128
ENG119220-ENG119127-grafic_element_setting-setting_10_pallet_ID,255 ,128
ENG119220-ENG119131-grafic_element_setting-setting_11_color_value,FF FF ,128
ENG119220-ENG119129-grafic_element_setting-setting_11_HMI_mode,FF ,128
ENG119220-ENG119130-grafic_element_setting-setting_11_pallet_ID,255 ,128
ENG119220-ENG119134-grafic_element_setting-setting_12_color_value,FF FF ,128
ENG119220-ENG119132-grafic_element_setting-setting_12_HMI_mode,FF ,128
ENG119220-ENG119133-grafic_element_setting-setting_12_pallet_ID,255 ,128
ENG119220-ENG119137-grafic_element_setting-setting_13_color_value,FF FF ,128
ENG119220-ENG119135-grafic_element_setting-setting_13_HMI_mode,FF ,128
ENG119220-ENG119136-grafic_element_setting-setting_13_pallet_ID,255 ,128
ENG119220-ENG119140-grafic_element_setting-setting_14_color_value,FF FF ,128
ENG119220-ENG119138-grafic_element_setting-setting_14_HMI_mode,FF ,128
ENG119220-ENG119139-grafic_element_setting-setting_14_pallet_ID,255 ,128
ENG119220-ENG119143-grafic_element_setting-setting_15_color_value,FF FF ,128
ENG119220-ENG119141-grafic_element_setting-setting_15_HMI_mode,FF ,128
ENG119220-ENG119142-grafic_element_setting-setting_15_pallet_ID,255 ,128
ENG119220-ENG119146-grafic_element_setting-setting_16_color_value,FF FF ,128
ENG119220-ENG119144-grafic_element_setting-setting_16_HMI_mode,FF ,128
ENG119220-ENG119145-grafic_element_setting-setting_16_pallet_ID,255 ,128
ENG119220-ENG119149-grafic_element_setting-setting_17_color_value,FF FF ,128
ENG119220-ENG119147-grafic_element_setting-setting_17_HMI_mode,FF ,128
ENG119220-ENG119148-grafic_element_setting-setting_17_pallet_ID,255 ,128
ENG119220-ENG119152-grafic_element_setting-setting_18_color_value,FF FF ,128
ENG119220-ENG119150-grafic_element_setting-setting_18_HMI_mode,FF ,128
ENG119220-ENG119151-grafic_element_setting-setting_18_pallet_ID,255 ,128
ENG119220-ENG119155-grafic_element_setting-setting_19_color_value,FF FF ,128
ENG119220-ENG119153-grafic_element_setting-setting_19_HMI_mode,FF ,128
ENG119220-ENG119154-grafic_element_setting-setting_19_pallet_ID,255 ,128
ENG119220-ENG119104-grafic_element_setting-setting_2_color_value,FF FF ,128
ENG119220-ENG119102-grafic_element_setting-setting_2_HMI_mode,FF ,128
ENG119220-ENG119103-grafic_element_setting-setting_2_pallet_ID,255 ,128
ENG119220-ENG119158-grafic_element_setting-setting_20_color_value,FF FF ,128
ENG119220-ENG119156-grafic_element_setting-setting_20_HMI_mode,FF ,128
ENG119220-ENG119157-grafic_element_setting-setting_20_pallet_ID,255 ,128
ENG119220-ENG119161-grafic_element_setting-setting_21_color_value,FF FF ,128
ENG119220-ENG119159-grafic_element_setting-setting_21_HMI_mode,FF ,128
ENG119220-ENG119160-grafic_element_setting-setting_21_pallet_ID,255 ,128
ENG119220-ENG119164-grafic_element_setting-setting_22_color_value,FF FF ,128
ENG119220-ENG119162-grafic_element_setting-setting_22_HMI_mode,FF ,128
ENG119220-ENG119163-grafic_element_setting-setting_22_pallet_ID,255 ,128
ENG119220-ENG119167-grafic_element_setting-setting_23_color_value,FF FF ,128
ENG119220-ENG119165-grafic_element_setting-setting_23_HMI_mode,FF ,128
ENG119220-ENG119166-grafic_element_setting-setting_23_pallet_ID,255 ,128
ENG119220-ENG119170-grafic_element_setting-setting_24_color_value,FF FF ,128
ENG119220-ENG119168-grafic_element_setting-setting_24_HMI_mode,FF ,128
ENG119220-ENG119169-grafic_element_setting-setting_24_pallet_ID,255 ,128
ENG119220-ENG119173-grafic_element_setting-setting_25_color_value,FF FF ,128
ENG119220-ENG119171-grafic_element_setting-setting_25_HMI_mode,FF ,128
ENG119220-ENG119172-grafic_element_setting-setting_25_pallet_ID,255 ,128
ENG119220-ENG119176-grafic_element_setting-setting_26_color_value,FF FF ,128
ENG119220-ENG119174-grafic_element_setting-setting_26_HMI_mode,FF ,128
ENG119220-ENG119175-grafic_element_setting-setting_26_pallet_ID,255 ,128
ENG119220-ENG119179-grafic_element_setting-setting_27_color_value,FF FF ,128
ENG119220-ENG119177-grafic_element_setting-setting_27_HMI_mode,FF ,128
ENG119220-ENG119178-grafic_element_setting-setting_27_pallet_ID,255 ,128
ENG119220-ENG119182-grafic_element_setting-setting_28_color_value,FF FF ,128
ENG119220-ENG119180-grafic_element_setting-setting_28_HMI_mode,FF ,128
ENG119220-ENG119181-grafic_element_setting-setting_28_pallet_ID,255 ,128
ENG119220-ENG119185-grafic_element_setting-setting_29_color_value,FF FF ,128
ENG119220-ENG119183-grafic_element_setting-setting_29_HMI_mode,FF ,128
ENG119220-ENG119184-grafic_element_setting-setting_29_pallet_ID,255 ,128
ENG119220-ENG119107-grafic_element_setting-setting_3_color_value,FF FF ,128
ENG119220-ENG119105-grafic_element_setting-setting_3_HMI_mode,FF ,128
ENG119220-ENG119106-grafic_element_setting-setting_3_pallet_ID,255 ,128
ENG119220-ENG119188-grafic_element_setting-setting_30_color_value,FF FF ,128
ENG119220-ENG119186-grafic_element_setting-setting_30_HMI_mode,FF ,128
ENG119220-ENG119187-grafic_element_setting-setting_30_pallet_ID,255 ,128
ENG119220-ENG119191-grafic_element_setting-setting_31_color_value,FF FF ,128
ENG119220-ENG119189-grafic_element_setting-setting_31_HMI_mode,FF ,128
ENG119220-ENG119190-grafic_element_setting-setting_31_pallet_ID,255 ,128
ENG119220-ENG119194-grafic_element_setting-setting_32_color_value,FF FF ,128
ENG119220-ENG119192-grafic_element_setting-setting_32_HMI_mode,FF ,128
ENG119220-ENG119193-grafic_element_setting-setting_32_pallet_ID,255 ,128
ENG119220-ENG119110-grafic_element_setting-setting_4_color_value,FF FF ,128
ENG119220-ENG119108-grafic_element_setting-setting_4_HMI_mode,FF ,128
ENG119220-ENG119109-grafic_element_setting-setting_4_pallet_ID,255 ,128
ENG119220-ENG119113-grafic_element_setting-setting_5_color_value,FF FF ,128
ENG119220-ENG119111-grafic_element_setting-setting_5_HMI_mode,FF ,128
ENG119220-ENG119112-grafic_element_setting-setting_5_pallet_ID,255 ,128
ENG119220-ENG119116-grafic_element_setting-setting_6_color_value,FF FF ,128
ENG119220-ENG119114-grafic_element_setting-setting_6_HMI_mode,FF ,128
ENG119220-ENG119115-grafic_element_setting-setting_6_pallet_ID,255 ,128
ENG119220-ENG119119-grafic_element_setting-setting_7_color_value,FF FF ,128
ENG119220-ENG119117-grafic_element_setting-setting_7_HMI_mode,FF ,128
ENG119220-ENG119118-grafic_element_setting-setting_7_pallet_ID,255 ,128
ENG119220-ENG119122-grafic_element_setting-setting_8_color_value,FF FF ,128
ENG119220-ENG119120-grafic_element_setting-setting_8_HMI_mode,FF ,128
ENG119220-ENG119121-grafic_element_setting-setting_8_pallet_ID,255 ,128
ENG119220-ENG119125-grafic_element_setting-setting_9_color_value,FF FF ,128
ENG119220-ENG119123-grafic_element_setting-setting_9_HMI_mode,FF ,128
ENG119220-ENG119124-grafic_element_setting-setting_9_pallet_ID,255 ,128
ENG119201-image_delay_timer,0.0 s,1
ENG119219-Minimal_time_to_stay_in_bus_sleep_before_ECU_off,20000 ms,2
ENG119214-rv_dark_off,10.00 km/h,2
ENG119213-rv_dark_on,15.00 km/h,2
ENG119203-RV_Last_Mode,90° parking spot ,1
ENG102898-RV_Start_Mode,90° parking spot ,1
ENG119205-Time_to_open_Swinging_Logo,750 ms,2
Elapsed Time: 00:07
08 Map
;SW:5NN-907-044-F   HW:5NN-907-044-F ---  Auto HVAC
;Component:AC Automat    H35 4401, Coding:0002002420011800100500001211140E
;EV_ACClimaPrehVW37X,002025,EV_ACClimaPrehVW37X.rod
;Saturday,01,June,2019,12:54:44:47965
;VCID: 4FFB72DEE75699AF03B-801A
IDE00001-Production mode,Deactivating ,3
IDE01067-Retention of driver's seat heater level,active for 10 minutes ,1
IDE01478-Ignore compressor switch-off by Engine Control Module,Do not ignore ,1
IDE01483-Blower voltage for voice operation,not activated ,1
IDE01488-Retrofitting of parking heater without CAN,not installed ,1
IDE01493-Air quality sensor sensitivity,Maximum ,1
IDE01503-Runtime for compressor run-in basic setting,60 s,1
IDE01536-Post-heating of parking heater,0 min,1
IDE02155-Reset all counters,not activated ,1
IDE03176-Duration of compressor run in,0 s,1
IDE03251-Stop release for start-stop function,According to function requirements ,1
IDE04159-Deactivation of start-stop function,not active ,1
IDE06097-Target temperature of A/C - heater function via remote control,22.0 °C,1
IDE07108-Climate modes,Matching coding ,1
IDE07302-Remote start function: interior climate control status,Remote start function with fixed rated temperature active ,1
IDE07304-Remote start function: activation of seat ventilation,activated ,1
IDE07305-Rem. start funct.: activat.temper. of seat heating,15 °C,1
IDE07306-Rem. start funct.: activat.temper. of seat ventilation,20 °C,1
IDE07307-Remote start function: activation stage of seat heating,level 2 ,1
IDE07308-Remote start function: activation stage of seat ventilation,level 2 ,1
IDE07398-Blower logic for manual adjustment,Matching coding ,1
IDE07865-Automatic Activation of front windshield heater at MAX-Defrost,not active ,1
IDE07948-Retention of frt.pass. seat heater level,not active ,1
IDE12229-Filtering of interior air: store,Service life-dependent store ,1
IDE13676-Remote start function: rear window defogger,not activated ,1
IDE13677-Remote start function: seat climate control takeover,not activated ,1
MAS06564-Window condensation exterior reduction at high humidity,Matching coding ,1
MAS14860-Remote start function: windshield defogger takeover,activated ,1
MAS14861-Remote start function: windshield defogger,activated ,1
MAS17226-Remote start function: windshield defogger can be activated,activated ,1
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
ENG122844-ENG99557-dimming_characteristic_1-X2,6 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,40 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,60 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,80 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,100 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,0 %,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 %,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,40 %,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,60 %,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 %,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 %,12
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,12
ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,12
ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,12
ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,12
ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,2 %,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,2 %,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,10 %,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,21 %,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,85 %,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 %,12
ENG122846-ENG101574-dimming_characteristic_3-X1,0 ,12
ENG122846-ENG99557-dimming_characteristic_3-X2,10 ,12
ENG122846-ENG102140-dimming_characteristic_3-X3,50 ,12
ENG122846-ENG102936-dimming_characteristic_3-X4,100 ,12
ENG122846-ENG103548-dimming_characteristic_3-X5,220 ,12
ENG122846-ENG113992-dimming_characteristic_3-X6,253 ,12
ENG122846-ENG99777-dimming_characteristic_3-Y1,2 %,12
ENG122846-ENG100480-dimming_characteristic_3-Y2,2 %,12
ENG122846-ENG100773-dimming_characteristic_3-Y3,5 %,12
ENG122846-ENG100631-dimming_characteristic_3-Y4,10 %,12
ENG122846-ENG102174-dimming_characteristic_3-Y5,85 %,12
ENG122846-ENG113993-dimming_characteristic_3-Y6,100 %,12
ENG122847-ENG101574-dimming_characteristic_4-X1,0 ,12
ENG122847-ENG99557-dimming_characteristic_4-X2,10 ,12
ENG122847-ENG102140-dimming_characteristic_4-X3,50 ,12
ENG122847-ENG102936-dimming_characteristic_4-X4,100 ,12
ENG122847-ENG103548-dimming_characteristic_4-X5,220 ,12
ENG122847-ENG113992-dimming_characteristic_4-X6,253 ,12
ENG122847-ENG99777-dimming_characteristic_4-Y1,2 %,12
ENG122847-ENG100480-dimming_characteristic_4-Y2,2 %,12
ENG122847-ENG100773-dimming_characteristic_4-Y3,5 %,12
ENG122847-ENG100631-dimming_characteristic_4-Y4,10 %,12
ENG122847-ENG102174-dimming_characteristic_4-Y5,85 %,12
ENG122847-ENG113993-dimming_characteristic_4-Y6,100 %,12
ENG122848-ENG101574-dimming_characteristic_5-X1,0 ,12
ENG122848-ENG99557-dimming_characteristic_5-X2,10 ,12
ENG122848-ENG102140-dimming_characteristic_5-X3,50 ,12
ENG122848-ENG102936-dimming_characteristic_5-X4,100 ,12
ENG122848-ENG103548-dimming_characteristic_5-X5,220 ,12
ENG122848-ENG113992-dimming_characteristic_5-X6,253 ,12
ENG122848-ENG99777-dimming_characteristic_5-Y1,2 %,12
ENG122848-ENG100480-dimming_characteristic_5-Y2,2 %,12
ENG122848-ENG100773-dimming_characteristic_5-Y3,5 %,12
ENG122848-ENG100631-dimming_characteristic_5-Y4,10 %,12
ENG122848-ENG102174-dimming_characteristic_5-Y5,85 %,12
ENG122848-ENG113993-dimming_characteristic_5-Y6,100 %,12
ENG153708-Remotestart_window_heating_temperature,4 ,1
Elapsed Time: 00:13
09 Map
;SW:5Q0-937-087-BB   HW:5Q0-937-087-BB ---  Cent. Elect.
;Component:BCM PQ37BOSCH 036 0265, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BodyContrModul1UDSBosc,019001,EV_BCMBOSCH_019_VW37.rod
;Saturday,01,June,2019,12:54:59:47965
;VCID: 7CA1F5120660D237969-8028
IDE01550-Service position,178.999822 °,2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,active ,10
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage,not installed ,11
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv,-2.0 °C,11
IDE04927-ENG141962-Window heater-Waschduesenheizung,installed ,11
IDE04927-ENG154810-Window heater-window heating front activation time pause,320 s,11
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,active ,8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,activ ,8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,Horn_verbaut ,8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,activ ,8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,8
IDE05145-Light configuration,0C 34 00 14 02 00 64 00 00 00 00 00 00 00 00 00 0C 3E 00 15 04 00 64 00 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 08 09 1A 12 06 9A 00 00 00 04 4C 00 4C 14 00 64 08 0A 1A 13 07 9A 00 00 00 01 3A 00 49 14 00 7F 06 00 80 08 09 7F 00 00 00 01 44 00 4B 14 00 7F 07 00 80 08 0A 7F 00 00 00 0B 36 00 1A 0B 00 64 00 00 00 00 00 00 00 00 00 0B 40 00 1B 0C 00 64 00 00 00 00 00 00 00 00 00 0A 37 00 1C 0D 0F 64 00 00 00 00 00 00 00 00 00 0A 41 00 1D 0E 0F 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,224
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler,0 ,30
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,Heizmatten am BCM ,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,21.00 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,20.00 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,21.00 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,20.00 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.50 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.50 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,49.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,48.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,49.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,48.00 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.7 V,30
IDE06507-MAS13132-Button in center console-Function of button 3,not coded/not installed ,8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
IDE07007-ENG246992-A/C heater function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
IDE07356-Position during interval mode,40.999959 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit ,6
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor,DISKRET ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,50 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,50 %,19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,50 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,50 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,50 %,19
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,not installed ,5
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
IDE10298-Alternating park position 1,19.999980 °,2
IDE10299-Alternating park position 2,34.999965 °,2
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.00 ,256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,0.40 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.00 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000  ,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,70 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,70 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,70 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,70 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,0 %,256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,70 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,0 %,256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,70 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,0 %,256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,70 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,0 %,256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,70 %,256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,0 %,256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,0 %,256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,70 %,256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,70 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,0 %,256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,70 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,0 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,70 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,70 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,0 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,0 %,256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,70 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,0 %,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.0 s,256
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,installed ,3
IDE11944-ENG141948-Keyless access and start authorization-Kessy,installed ,3
IDE11944-ENG246971-Keyless access and start authorization-Kessy BewegungsüberwachungIDGeber,not active ,3
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,not active ,3
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,3
IDE12302-SFT271873-Identification of sub-bus participant-Control Unit For Wiper Motor,Not available ,6
IDE12302-SFT271874-Identification of sub-bus participant-Rain Light Recognition Sensor,Not available ,6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch,Not available ,6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,Not available ,6
IDE12302-SFT271877-Identification of sub-bus participant-Garage Door Opener Operating Unit,Not available ,6
IDE12302-SFT271894-Identification of sub-bus participant-Sensor For Anti Theft Alarm System,Not available ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,Not available ,6
IDE12302-SFT271904-Identification of sub-bus participant-Sun Roof,Not available ,6
IDE12302-SFT271910-Identification of sub-bus participant-Ceiling Light Module,Not available ,6
IDE12302-SFT271928-Identification of sub-bus participant-Roof Blind,Not available ,6
IDE12302-SFT271947-Identification of sub-bus participant-Relative Air Humidity Interior Sender,Not available ,6
IDE12302-SFT271966-Identification of sub-bus participant-Neck Heating Left,Not available ,6
IDE12302-SFT271967-Identification of sub-bus participant-Neck Heating Right,Not available ,6
IDE12302-SFT272065-Identification of sub-bus participant-Seat Backrest Fan 1 Front Left,Not available ,6
IDE12302-SFT272067-Identification of sub-bus participant-Seat Cushion Fan 1 Front Left,Not available ,6
IDE12302-SFT272069-Identification of sub-bus participant-Seat Backrest Fan 1 Front Right,Not available ,6
IDE12302-SFT272071-Identification of sub-bus participant-Seat Cushion Fan 1 Front Right,Not available ,6
IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control,Not available ,6
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch,Not available ,6
MAS05055-lower turn position,42.999957 °,2
MAS05056-upper turn position,178.999822 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,2512 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 50 ,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4500 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,6000 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,2000 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active ,4
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,Panoramic roof ,30
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,not active ,10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,not active ,10
ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10,not active ,10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,not active ,10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,not active ,10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,not active ,10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,not active ,10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,not active ,10
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max,120 min,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,not active ,10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,not active ,10
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren,not active ,9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,active ,9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active ,9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,limitieren ,9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht,Yes ,5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,not active ,5
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,begrenzen auf Mindestverfügbarkeit ,18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,begrenzen auf Mindestverfügbarkeit ,18
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf,0 ms,18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,automatic ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,not active ,18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,true ,18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,No ,18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht,No ,18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,not installed ,18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,not active ,18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,not active ,18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,6 s,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Sollspannungsanforderung 13.5 ,18
ENG246955-ENG246967-digital_key-central_locking_digital_key_general,not installed ,3
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle,not active ,3
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle,not active ,3
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer,not active ,3
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,Basis ,6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,not active ,6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,Not deactivated ,6
ENG141645-MAS00214-HW_Verbau-Brake pad wear,not installed ,8
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,100.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,100.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,100.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,83.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,67.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,50.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,33.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,17.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,64.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,64.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,64.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,64.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,57.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,50.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,42.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,27.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,22.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,15.0 %,30
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Warnblinktaster_Suchbeleuchtung ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,0 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,00 ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,00 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,not active ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,not active ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,0 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,00 ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,00 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,not active ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,not active ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,48 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,47 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,0 ,16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,00 ,16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,00 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,not active ,16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,not active ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,0 ,16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,00 ,16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,00 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,not active ,16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,not active ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,minimize ,16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,13 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,3D ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,13 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,35 - kombinierte LED Blink-Bremsleuchten ,16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,Blinken links Hellphase ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Blinken links Dunkelphase ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,minimize ,16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,13 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3E ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,23 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,35 - kombinierte LED Blink-Bremsleuchten ,16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,Blinken rechts Hellphase ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Blinken rechts Dunkelphase ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,35 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W ,16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,only_if_closed ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,36 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W ,16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,only_if_closed ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,54 ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,00 ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,32 - allgemeine LED bis 12W ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,32 - allgemeine LED bis 12W ,16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,minimize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,26 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,26 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Nebellicht links ,16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,Blinken links aktiv (beide Phasen) ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,0 ,16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,not active ,16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,not active ,16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,minimize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,26 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,26 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,Parking light right ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Nebellicht rechts ,16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,Blinken rechts aktiv (beide Phasen) ,16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,minimize ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,127 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Blinken links aktiv (beide Phasen) ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,minimize ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,127 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Blinken rechts aktiv (beide Phasen) ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right ,16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,100 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,11 - Abblendlicht ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,not active ,16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,100 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,11 - Abblendlicht ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,not active ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,10 - allgemeine Scheinwerfer ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,10 - allgemeine Scheinwerfer ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23 13 00 3D 18 02 64 03 00 80 08 00 0D 00 00 00 23 23 00 3E 18 04 64 05 00 80 08 00 0D 00 00 00 2A 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 20 0A 00 35 08 00 FF 00 00 00 00 00 00 00 00 00 20 1A 00 36 08 00 FF 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 54 08 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 20 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,25 00 00 48 08 00 7F 00 00 00 00 00 00 00 00 00 25 00 00 47 08 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,100.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,0.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-101.5 ms,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,not installed ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,1.0 %,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,10.0 %/s,62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,1.00 s,62
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1,2.0 s,7
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang,10 s,7
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,7
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,7
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS,Nicht_verbaut ,7
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark,not active ,7
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze,100 m,7
ENG246957-ENG246981-Lichttaster-Lichttastermodul,lds ,7
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config,00000001  ,7
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle,30 km/h,7
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig,active ,7
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig,active ,7
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig,not active ,7
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,27
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,27
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,27
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,27
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,27
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,27
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,27
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,27
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,27
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.40 ,27
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,5 °C,27
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,18.0 %,27
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,27
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,27
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,27
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,27
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,34 °C,27
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,39 °C,27
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,44 °C,27
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,27
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,50 °C,27
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,0 ms,27
ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung,0 ms,27
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,27
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,27
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,27
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,30 s,27
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation,Always ,2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear Window Wiper,installed ,2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition key removal lock,not installed ,2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation,not installed ,2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,not installed ,2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,not installed ,2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,not installed ,2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2
ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation,not active ,2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,not installed ,2
ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button,not installed ,2
ENG122979-ENG141953-Networking-Getriebesteuergeraet,installed ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
ENG124714-ENG246970-OCU-IAA -Nutzer_management,not installed ,8
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 1.x) ,16
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,active ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2000 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,800 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,800 ms,10
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,0 ms,48
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,0 ms,48
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,0 ms,48
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 s,48
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,0 ,48
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,0 ms,48
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,0 ms,48
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,0 ms,48
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,0 ms,48
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,0 s,48
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,0.0 s,48
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,0 s,48
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG,not installed ,4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,not active ,5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by convenience operation via remote control key ,5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,not active ,5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,not active ,5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,not active ,5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,not active ,5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,not active ,5
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,1000 ms,10
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,20.0 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,3.0 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,2 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 %,21
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,10 lx,12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,100 lx,12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,500 lx,12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,20 ,12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,80 ,12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,180 ,12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,300 ,12
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,active ,4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,active ,4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,installed ,4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,installed ,4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,CAN ,4
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,active ,9
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar,not active ,9
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version,Version_1_2 ,9
ENG141651-ENG141957-ZV allgemein-Radio freq.,315MHz ,7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Einzeltuerentriegelung ,7
ENG141654-ENG116706-ZV Autolock-Autounlock NAR,active ,3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock,not active ,3
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,active ,4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels,not active ,7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,active ,7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,active ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,not active ,8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen,not active ,8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,not active ,8
ENG141681-ENG246991-ZV Komfort-pa_Two_Keys,not active ,8
Elapsed Time: 01:55
13 Map
;SW:2Q0-907-572-M   HW:2Q0-907-572-B ---  Auto Dist. Reg
;Component:ACCCONTIMQB   H02 0233, Coding:3200008110FF8728749C8145004097
;EV_ACCMRRCONTIVW376,002012,EV_ACCMRRCONTIVW376_002.rod
;Saturday,01,June,2019,12:56:56:47965
;VCDS Version: Release 19.6.0 (x64)  Data version: 20190529 DS308.0
;VCID: 3E253F1A50FC0027F8D-806A
IDE00001-Production mode,Deactivating ,3
IDE00820-ENG132029-Activating and deactivating all development messages-Development Message ECU specific,OFF ,1
IDE00820-ENG102778-Activating and deactivating all development messages-development message S100,OFF ,1
IDE00820-ENG101934-Activating and deactivating all development messages-development message S101,OFF ,1
IDE00820-ENG103391-Activating and deactivating all development messages-development message S102,OFF ,1
IDE00820-ENG132030-Activating and deactivating all development messages-XCP on FlexRay,OFF ,1
IDE01795-Heated lens,OFF ,1
IDE01949-Distance basic setting option,OFF ,1
IDE03642-Presentation mode,not active ,1
IDE05815-Sail function,Deactivating ,1
IDE08935-Expanded restart function,OFF ,1
IDE09564-Distance change via speed adjustment,OFF ,1
IDE09565-Prioritized target object display,OFF ,1
IDE10280-Constant delay after transfer request,No ,1
IDE13334-Reduced radar performance,38 ,1
Elapsed Time: 00:05
15 Map
;SW:5Q0-959-655-AG   HW:5Q0-959-655-AG ---  Airbags
;Component:AirbagVW21    005 0338, Coding:8CCCFC00000000005000001AC20800000065
;EV_AirbaVW20SMEVW37X,002160,EV_AirbaVW20SMEVW37X.rod
;Saturday,01,June,2019,12:57:03:47965
;VCID: 055790F675AA93FFF97-8050
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not active ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not active ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not active ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not active ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not active ,1
IDE06314-Calibration data: pre-crash,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,18
IDE12055-IDE12258-Adaptation airbag 2-Assistance system monitor,activated ,8
IDE12055-MAS00478-Adaptation airbag 2-Reserved,2 ,8
MAS00975-IDE01755-Airbag adaptations-Rollover protection system,not defined ,8
MAS00975-IDE02852-Airbag adaptations-Igniter for battery interrupt: high voltage battery,not defined ,8
MAS00975-MAS00001-Airbag adaptations-Driver airbag igniter,activated ,8
MAS00975-MAS00003-Airbag adaptations-Passenger airbag igniter,activated ,8
MAS00975-MAS00005-Airbag adaptations-Driver thorax airbag igniter,activated ,8
MAS00975-MAS00006-Airbag adaptations-Front passenger side airbag igniter,activated ,8
MAS00975-MAS00007-Airbag adaptations-Driver side rear thorax airbag igniter,not defined ,8
MAS00975-MAS00008-Airbag adaptations-Passenger side rear thorax airbag igniter,not defined ,8
MAS00975-MAS00009-Airbag adaptations-Driver head curtain airbag igniter,activated ,8
MAS00975-MAS00010-Airbag adaptations-Front passenger head curtain airbag igniter,activated ,8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,not defined ,8
MAS00975-MAS00012-Airbag adaptations-Front passenger knee airbag igniter,not defined ,8
MAS00975-MAS00013-Airbag adaptations-Driver side seat belt tension igniter,activated ,8
MAS00975-MAS00014-Airbag adaptations-Front passenger side seat belt tension igniter,activated ,8
MAS00975-MAS00019-Airbag adaptations-Driver side rear safety belt tension igniter,not defined ,8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear safety belt tension igniter,not defined ,8
MAS00975-MAS00022-Airbag adaptations-Igniter for battery interrupt,not defined ,8
MAS00975-MAS00030-Airbag adaptations-Seat occupied recognition,not defined ,8
MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch not parameterized ,8
MAS00975-MAS00478-Airbag adaptations-Reserved,2 ,8
MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter engine hood,not defined ,8
Elapsed Time: 00:03
17 Map
;SW:5NA-920-850-C   HW:5NA-920-850-C ---  Instruments
;Component:KOMBI         351 2500, Coding:0BA40C1AA388CF0502882B0954000000A0000000
;EV_DashBoardVDDMQBAB,009065,EV_DashBoardVDDMQBAB_009_VW37.rod
;Saturday,01,June,2019,12:52:21:47965
;VCID: 3FDB421E57F6092FF3B-806A
IDE00295-Oil temperature display,On ,1
IDE00301-Distance,1087 km,3
IDE00342-ESI: Resetting ESI,no warning ,1
IDE00343-Language version,US English ,1
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible ,3
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset ,3
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset ,3
IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection,MFA3-Reset ,3
IDE00499-Display correction of consumptions and operating range,100 %,1
IDE00500-Hour,12 H,1
IDE00501-Minute,51 min,1
IDE00502-Year,2019 yr,2
IDE00503-Month,6 mon,1
IDE00504-Day,1 d,1
IDE00510-ESI: distance driven from inspection,1030 km,3
IDE00511-ESI: time from inspection,30 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
IDE00514-ESI: maximum value of time between inspections,730 d,2
IDE00515-ESI: oil quality,poor oil quality ,1
IDE00517-ESI: soot entry,0 km,2
IDE00518-ESI: thermal load,1400 km,2
IDE00819-Day counter,228 d,2
IDE00827-ESI: minimum value of time between inspections,365 d,2
IDE01153-SIA: maximum value of distance to service,16000 km,2
IDE01154-SIA: maximum value of time to service,365 d,2
IDE02489-Display depiction,Version 1 ,1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l,5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l,5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,-12.8 l,5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l,5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l,5
IDE03329-Driving profiled for range remaining,7.9 l/100km,2
IDE03346-IDE00301-Units adjusted-Distance,miles ,3
IDE03346-MAS01230-Units adjusted-Date,mm_dd_yy ,3
IDE03346-MAS01456-Units adjusted-Speed,Miles per hour ,3
IDE03346-MAS02201-Units adjusted-Temperature,Degrees Fahrenheit ,3
IDE03346-MAS02957-Units adjusted-Time,12h AM_PM ,3
IDE03346-MAS03032-Units adjusted-Volume,gallons (US) ,3
IDE03346-MAS03034-Units adjusted-Pressure,psi ,3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3
IDE03346-MAS13665-Units adjusted-Trailer/support load ground,kilogram (kg) ,3
IDE03348-MAS01456-Speed warning-Speed,0 ,2
IDE03348-MAS01561-Speed warning-Unit,Miles per hour ,2
IDE03348-Speed warning-,not active ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,32100 km,2
IDE03350-FIX: Maximum time until next time-dependent inspection,730 d,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,1000 km,2
IDE03352-FIX: Time since last time-dependent inspection,30 d,2
IDE03372-Source for synchronization of time,GPS ,1
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On ,5
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5
IDE03867-Deactivate seat belt warning,No ,1
IDE05930-Service notification in days,30 d,1
IDE05931-FIX: Reset value for next mileage-dependent inspection,32100 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,730 d,2
IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1
IDE06588-Ignition active message: actuator,Driver door ,1
IDE06922-No-voltage display,Unknown (2),1
IDE07221-Cylinder shut-off,Display ,1
IDE11086-Service notification,30 d,1
IDE11932-MAS01877-Display of colour adjustment-Red,0 ,3
IDE11932-MAS01878-Display of colour adjustment-Green,0 ,3
IDE11932-MAS01879-Display of colour adjustment-Blue,0 ,3
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation,not active ,1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-CCS,active ,1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter,not active ,1
IDE14220-Vehicle speed warning for India-,No ,1
IDE14220-Vehicle speed warning for India-,0 s,1
MAS03685-Digital speedometer,Display ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
ENG119875-defuel_threshold,9 l,1
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1,00 ,12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,32 ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,66 ,12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC ,12
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD ,12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00 ,12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00 ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00 ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,05 ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,14 ,12
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64 ,12
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1,00 ,12
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2,0A ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,0E ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1E ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,32 ,12
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64 ,12
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00 ,12
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,0A ,12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,32 ,12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,64 ,12
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,DC ,12
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,FD ,12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,03 ,12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,03 ,12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,10 ,12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,1E ,12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,55 ,12
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,64 ,12
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00 ,12
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A ,12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,96 ,12
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD ,12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05 ,12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05 ,12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C ,12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17 ,12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32 ,12
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64 ,12
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00 ,20
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32 ,20
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64 ,20
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8 ,20
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4 ,20
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 0E ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 41 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD ,20
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00 ,12
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A ,12
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,96 ,12
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD ,12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01 ,12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01 ,12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,07 ,12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0E ,12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,1E ,12
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64 ,12
ENG119874-Gas_functionality,not active ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,parking_light ,1
ENG119882-init_fuel_algorithm,No ,1
ENG130585-Leaving_warning_delay,1.6 s,1
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0,15 s,16
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.0 km,16
ENG102605-ENG103631-outside_temperature-P_speed_threshold,20 km/h,16
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off,180 min,16
ENG102605-ENG104179-outside_temperature-p_tendency_damping,15 s,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C,16
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1,40 s,16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0 ,16
ENG119825-Picture_Upload_Download,not active ,1
ENG126396-Scale_switching_algorithm,lowbeam_foglight ,1
ENG119876-Service_Key_Clear_All_Counter,Yes ,1
ENG130584-Statistic_phev_mileage,5 km,1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,35 s,18
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF,300 ms,18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.40 s,18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.30 ,18
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
ENG112418-ENG99298-total_range_gas-State,not active ,4
Elapsed Time: 00:29
19 Map
;SW:3Q0-907-530-Q   HW:3Q0-907-530-C ---  CAN Gateway
;Component:GW MQB High   518 5344, Coding:030500347F085900FB0322481E0F00010001070000000000000000000000
;EV_GatewNF,013023,EV_GatewNF.rod
;Saturday,01,June,2019,12:52:53:47965
;VCID: 3D2738165DFA1B3FE17-8068
IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys,Deactivating ,3
IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation,Deactivating ,3
IDE00002-Transport mode,not active ,1
IDE01211-Static current measuring mode,not activated ,1
IDE01457-Energy management deactivation stage,Mode not active ,1
IDE01459-Energy management heat output control status,Mode not active ,1
IDE01844-Increase idle speed request,Mode not active ,1
IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time,-- ,3
IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation,Mode not active ,3
IDE01860-Generator specified voltage value variable,10.6 V,1
IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1,coded ,32
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,coded ,32
IDE01996-SFT00003-Installation list: specified installations-Brakes 1,coded ,32
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded ,32
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded ,32
IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded ,32
IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater,Not coded ,32
IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1,Not coded ,32
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,coded ,32
IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics,Not coded ,32
IDE01996-SFT00021-Installation list: specified installations-Airbag,coded ,32
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,Not coded ,32
IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded ,32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,Not coded ,32
IDE01996-SFT00025-Installation list: specified installations-Gateway,1 ,32
IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection,Not coded ,32
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded ,32
IDE01996-SFT00033-Installation list: specified installations-Battery Energy Control Module 2,Not coded ,32
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,coded ,32
IDE01996-SFT00035-Installation list: specified installations-Brake Boost,Not coded ,32
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded ,32
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,coded ,32
IDE01996-SFT00048-Installation list: specified installations-Special Function 2,Not coded ,32
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,Not coded ,32
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,Not coded ,32
IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant,coded ,32
IDE01996-SFT00061-Installation list: specified installations-Special Function,Not coded ,32
IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor,Not coded ,32
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,coded ,32
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded ,32
IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded ,32
IDE01996-SFT00075-Installation list: specified installations-Multifunction module,Not coded ,32
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,Not coded ,32
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,coded ,32
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,Not coded ,32
IDE01996-SFT00086-Installation list: specified installations-Radio,Not coded ,32
IDE01996-SFT00087-Installation list: specified installations-TV Tuner,Not coded ,32
IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1,coded ,32
IDE01996-SFT00096-Installation list: specified installations-Tachograph,Not coded ,32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,Not coded ,32
IDE01996-SFT00105-Installation list: specified installations-Trailer Function,Not coded ,32
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,coded ,32
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,Not coded ,32
IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit,Not coded ,32
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,Not coded ,32
IDE01996-SFT00128-Installation list: specified installations-Battery Regulation Auxiliary Accumulator 1,Not coded ,32
IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded ,32
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,Not coded ,32
IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System,Not coded ,32
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded ,32
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,Not coded ,32
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,coded ,32
IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side,Not coded ,32
IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side,Not coded ,32
IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management,Not coded ,32
IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left,Not coded ,32
IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right,Not coded ,32
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,Not coded ,32
IDE01996-SFT00197-Installation list: specified installations-Thermal management,Not coded ,32
IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module,Not coded ,32
IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof,coded ,32
IDE01996-SFT00204-Installation list: specified installations-Starter / Generator Control Module,Not coded ,32
IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2,Not coded ,32
IDE01996-ENG118226-Installation list: specified installations-Node_0x01,Not coded ,32
IDE01996-ENG118227-Installation list: specified installations-Node_0x02,Not coded ,32
IDE01996-ENG118228-Installation list: specified installations-Node_0x03,Not coded ,32
IDE01996-ENG118229-Installation list: specified installations-Node_0x04,Not coded ,32
IDE01996-ENG118230-Installation list: specified installations-Node_0x05,Not coded ,32
IDE01996-ENG118231-Installation list: specified installations-Node_0x06,Not coded ,32
IDE01996-ENG118232-Installation list: specified installations-Node_0x07,Not coded ,32
IDE01996-ENG118233-Installation list: specified installations-Node_0x08,Not coded ,32
IDE01996-ENG118235-Installation list: specified installations-Node_0x0D,Not coded ,32
IDE01996-ENG118236-Installation list: specified installations-Node_0x11,Not coded ,32
IDE01996-ENG118237-Installation list: specified installations-Node_0x16,Not coded ,32
IDE01996-ENG118238-Installation list: specified installations-Node_0x17,Not coded ,32
IDE01996-ENG118239-Installation list: specified installations-Node_0x1A,Not coded ,32
IDE01996-ENG118241-Installation list: specified installations-Node_0x1D,Not coded ,32
IDE01996-ENG118242-Installation list: specified installations-Node_0x1F,Not coded ,32
IDE01996-ENG118243-Installation list: specified installations-Node_0x20,Not coded ,32
IDE01996-ENG118244-Installation list: specified installations-Node_0x21,Not coded ,32
IDE01996-ENG118245-Installation list: specified installations-Node_0x22,Not coded ,32
IDE01996-ENG118246-Installation list: specified installations-Node_0x24,Not coded ,32
IDE01996-ENG118247-Installation list: specified installations-Node_0x25,Not coded ,32
IDE01996-ENG118248-Installation list: specified installations-Node_0x26,Not coded ,32
IDE01996-ENG118249-Installation list: specified installations-Node_0x27,Not coded ,32
IDE01996-ENG118250-Installation list: specified installations-Node_0x28,Not coded ,32
IDE01996-ENG118251-Installation list: specified installations-Node_0x29,Not coded ,32
IDE01996-ENG118252-Installation list: specified installations-Node_0x2A,Not coded ,32
IDE01996-ENG118253-Installation list: specified installations-Node_0x2E,Not coded ,32
IDE01996-ENG118254-Installation list: specified installations-Node_0x2F,Not coded ,32
IDE01996-ENG118255-Installation list: specified installations-Node_0x35,Not coded ,32
IDE01996-ENG118256-Installation list: specified installations-Node_0x36,Not coded ,32
IDE01996-ENG118257-Installation list: specified installations-Node_0x37,Not coded ,32
IDE01996-ENG118258-Installation list: specified installations-Node_0x38,Not coded ,32
IDE01996-ENG118259-Installation list: specified installations-Node_0x39,Not coded ,32
IDE01996-ENG118260-Installation list: specified installations-Node_0x3A,Not coded ,32
IDE01996-ENG118261-Installation list: specified installations-Node_0x3C,Not coded ,32
IDE01996-ENG118262-Installation list: specified installations-Node_0x3D,Not coded ,32
IDE01996-ENG118263-Installation list: specified installations-Node_0x40,Not coded ,32
IDE01996-ENG118264-Installation list: specified installations-Node_0x41,Not coded ,32
IDE01996-ENG118265-Installation list: specified installations-Node_0x43,Not coded ,32
IDE01996-ENG118266-Installation list: specified installations-Node_0x45,Not coded ,32
IDE01996-ENG118267-Installation list: specified installations-Node_0x48,Not coded ,32
IDE01996-ENG118268-Installation list: specified installations-Node_0x49,Not coded ,32
IDE01996-ENG118269-Installation list: specified installations-Node_0x51,Not coded ,32
IDE01996-ENG118270-Installation list: specified installations-Node_0x52,Not coded ,32
IDE01996-ENG118271-Installation list: specified installations-Node_0x53,Not coded ,32
IDE01996-ENG118272-Installation list: specified installations-Node_0x55,Not coded ,32
IDE01996-ENG118273-Installation list: specified installations-Node_0x56,Not coded ,32
IDE01996-ENG118274-Installation list: specified installations-Node_0x58,Not coded ,32
IDE01996-ENG118275-Installation list: specified installations-Node_0x59,Not coded ,32
IDE01996-ENG118276-Installation list: specified installations-Node_0x5A,Not coded ,32
IDE01996-ENG118277-Installation list: specified installations-Node_0x5B,Not coded ,32
IDE01996-ENG118278-Installation list: specified installations-Node_0x5C,Not coded ,32
IDE01996-ENG118279-Installation list: specified installations-Node_0x5D,Not coded ,32
IDE01996-ENG118280-Installation list: specified installations-Node_0x5E,Not coded ,32
IDE01996-ENG118281-Installation list: specified installations-Node_0x5F,Not coded ,32
IDE01996-ENG118282-Installation list: specified installations-Node_0x60,Not coded ,32
IDE01996-ENG118283-Installation list: specified installations-Node_0x61,Not coded ,32
IDE01996-ENG118284-Installation list: specified installations-Node_0x62,Not coded ,32
IDE01996-ENG118285-Installation list: specified installations-Node_0x66,Not coded ,32
IDE01996-ENG118286-Installation list: specified installations-Node_0x68,Not coded ,32
IDE01996-ENG118287-Installation list: specified installations-Node_0x6B,Not coded ,32
IDE01996-ENG118288-Installation list: specified installations-Node_0x6C,Not coded ,32
IDE01996-ENG118289-Installation list: specified installations-Node_0x6E,Not coded ,32
IDE01996-ENG118290-Installation list: specified installations-Node_0x74,Not coded ,32
IDE01996-ENG118291-Installation list: specified installations-Node_0x75,Not coded ,32
IDE01996-ENG118292-Installation list: specified installations-Node_0x78,Not coded ,32
IDE01996-ENG118293-Installation list: specified installations-Node_0x79,Not coded ,32
IDE01996-ENG118294-Installation list: specified installations-Node_0x7A,Not coded ,32
IDE01996-ENG118295-Installation list: specified installations-Node_0x7D,Not coded ,32
IDE01996-ENG118296-Installation list: specified installations-Node_0x7E,Not coded ,32
IDE01996-ENG118297-Installation list: specified installations-Node_0x7F,Not coded ,32
IDE01996-ENG118298-Installation list: specified installations-Node_0x80,Not coded ,32
IDE01996-ENG118299-Installation list: specified installations-Node_0x81,Not coded ,32
IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded ,32
IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded ,32
IDE01996-ENG118303-Installation list: specified installations-Node_0x86,Not coded ,32
IDE01996-ENG118304-Installation list: specified installations-Node_0x87,Not coded ,32
IDE01996-ENG118305-Installation list: specified installations-Node_0x88,Not coded ,32
IDE01996-ENG118306-Installation list: specified installations-Node_0x89,Not coded ,32
IDE01996-ENG118307-Installation list: specified installations-Node_0x8B,Not coded ,32
IDE01996-ENG118308-Installation list: specified installations-Node_0x8C,Not coded ,32
IDE01996-ENG118309-Installation list: specified installations-Node_0x8D,Not coded ,32
IDE01996-ENG118310-Installation list: specified installations-Node_0x8E,Not coded ,32
IDE01996-ENG118311-Installation list: specified installations-Node_0x8F,Not coded ,32
IDE01996-ENG118312-Installation list: specified installations-Node_0x90,Not coded ,32
IDE01996-ENG118313-Installation list: specified installations-Node_0x91,Not coded ,32
IDE01996-ENG118314-Installation list: specified installations-Node_0x92,Not coded ,32
IDE01996-ENG118315-Installation list: specified installations-Node_0x93,Not coded ,32
IDE01996-ENG118316-Installation list: specified installations-Node_0x94,Not coded ,32
IDE01996-ENG118317-Installation list: specified installations-Node_0x95,Not coded ,32
IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded ,32
IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded ,32
IDE01996-ENG118320-Installation list: specified installations-Node_0x98,Not coded ,32
IDE01996-ENG118321-Installation list: specified installations-Node_0x99,Not coded ,32
IDE01996-ENG118322-Installation list: specified installations-Node_0x9A,Not coded ,32
IDE01996-ENG118323-Installation list: specified installations-Node_0x9B,Not coded ,32
IDE01996-ENG118325-Installation list: specified installations-Node_0x9D,Not coded ,32
IDE01996-ENG118326-Installation list: specified installations-Node_0x9E,Not coded ,32
IDE01996-ENG118327-Installation list: specified installations-Node_0x9F,Not coded ,32
IDE01996-ENG118328-Installation list: specified installations-Node_0xA0,Not coded ,32
IDE01996-ENG118329-Installation list: specified installations-Node_0xA1,Not coded ,32
IDE01996-ENG118330-Installation list: specified installations-Node_0xA2,Not coded ,32
IDE01996-ENG118331-Installation list: specified installations-Node_0xA3,Not coded ,32
IDE01996-ENG118333-Installation list: specified installations-Node_0xA5,Not coded ,32
IDE01996-ENG118334-Installation list: specified installations-Node_0xA6,Not coded ,32
IDE01996-ENG118335-Installation list: specified installations-Node_0xA7,Not coded ,32
IDE01996-ENG118336-Installation list: specified installations-Node_0xA8,Not coded ,32
IDE01996-ENG118338-Installation list: specified installations-Node_0xAA,Not coded ,32
IDE01996-ENG118339-Installation list: specified installations-Node_0xAB,Not coded ,32
IDE01996-ENG118340-Installation list: specified installations-Node_0xAC,Not coded ,32
IDE01996-ENG118341-Installation list: specified installations-Node_0xAD,Not coded ,32
IDE01996-ENG118343-Installation list: specified installations-Node_0xAF,Not coded ,32
IDE01996-ENG118344-Installation list: specified installations-Node_0xB0,Not coded ,32
IDE01996-ENG118345-Installation list: specified installations-Node_0xB1,Not coded ,32
IDE01996-ENG118346-Installation list: specified installations-Node_0xB2,Not coded ,32
IDE01996-ENG118347-Installation list: specified installations-Node_0xB3,Not coded ,32
IDE01996-ENG118348-Installation list: specified installations-Node_0xB4,Not coded ,32
IDE01996-ENG118349-Installation list: specified installations-Node_0xB5,Not coded ,32
IDE01996-ENG118350-Installation list: specified installations-Node_0xB6,Not coded ,32
IDE01996-ENG118351-Installation list: specified installations-Node_0xB7,Not coded ,32
IDE01996-ENG118352-Installation list: specified installations-Node_0xB8,Not coded ,32
IDE01996-ENG118353-Installation list: specified installations-Node_0xB9,Not coded ,32
IDE01996-ENG118354-Installation list: specified installations-Node_0xBA,Not coded ,32
IDE01996-ENG118355-Installation list: specified installations-Node_0xBB,Not coded ,32
IDE01996-ENG118356-Installation list: specified installations-Node_0xBC,Not coded ,32
IDE01996-ENG118357-Installation list: specified installations-Node_0xBD,Not coded ,32
IDE01996-ENG118358-Installation list: specified installations-Node_0xBE,Not coded ,32
IDE01996-ENG118359-Installation list: specified installations-Node_0xBF,Not coded ,32
IDE01996-ENG118360-Installation list: specified installations-Node_0xC0,Not coded ,32
IDE01996-ENG118361-Installation list: specified installations-Node_0xC1,Not coded ,32
IDE01996-ENG118362-Installation list: specified installations-Node_0xC2,Not coded ,32
IDE01996-ENG118363-Installation list: specified installations-Node_0xC3,Not coded ,32
IDE01996-ENG118364-Installation list: specified installations-Node_0xC4,Not coded ,32
IDE01996-ENG118365-Installation list: specified installations-Node_0xC5,Not coded ,32
IDE01996-ENG118366-Installation list: specified installations-Node_0xC6,Not coded ,32
IDE01996-ENG118367-Installation list: specified installations-Node_0xC7,Not coded ,32
IDE01996-ENG118368-Installation list: specified installations-Node_0xC8,Not coded ,32
IDE01996-ENG118369-Installation list: specified installations-Node_0xC9,Not coded ,32
IDE01996-ENG118370-Installation list: specified installations-Node_0xCA,Not coded ,32
IDE01996-ENG118371-Installation list: specified installations-Node_0xCB,Not coded ,32
IDE01996-ENG118372-Installation list: specified installations-Node_0xCC,Not coded ,32
IDE01996-ENG118373-Installation list: specified installations-Node_0xCD,Not coded ,32
IDE01996-ENG118374-Installation list: specified installations-Node_0xCE,Not coded ,32
IDE01996-ENG118375-Installation list: specified installations-Node_0xCF,Not coded ,32
IDE01996-ENG118376-Installation list: specified installations-Node_0xD0,Not coded ,32
IDE01996-ENG118377-Installation list: specified installations-Node_0xD1,Not coded ,32
IDE01996-ENG118378-Installation list: specified installations-Node_0xD2,Not coded ,32
IDE01996-ENG118379-Installation list: specified installations-Node_0xD3,Not coded ,32
IDE01996-ENG118380-Installation list: specified installations-Node_0xD4,Not coded ,32
IDE01996-ENG118381-Installation list: specified installations-Node_0xD5,Not coded ,32
IDE01996-ENG118382-Installation list: specified installations-Node_0xD6,Not coded ,32
IDE01996-ENG118383-Installation list: specified installations-Node_0xD7,Not coded ,32
IDE01996-ENG118384-Installation list: specified installations-Node_0xD8,Not coded ,32
IDE01996-ENG118385-Installation list: specified installations-Node_0xD9,Not coded ,32
IDE01996-ENG118386-Installation list: specified installations-Node_0xDA,Not coded ,32
IDE01996-ENG118387-Installation list: specified installations-Node_0xDB,Not coded ,32
IDE01996-ENG118388-Installation list: specified installations-Node_0xDC,Not coded ,32
IDE01996-ENG118389-Installation list: specified installations-Node_0xDD,Not coded ,32
IDE01996-ENG118390-Installation list: specified installations-Node_0xDE,Not coded ,32
IDE01996-ENG118391-Installation list: specified installations-Node_0xDF,Not coded ,32
IDE01996-ENG118392-Installation list: specified installations-Node_0xE0,Not coded ,32
IDE01996-ENG118393-Installation list: specified installations-Node_0xE1,Not coded ,32
IDE01996-ENG118394-Installation list: specified installations-Node_0xE2,Not coded ,32
IDE01996-ENG118395-Installation list: specified installations-Node_0xE3,Not coded ,32
IDE01996-ENG118396-Installation list: specified installations-Node_0xE4,Not coded ,32
IDE01996-ENG118397-Installation list: specified installations-Node_0xE5,Not coded ,32
IDE01996-ENG118398-Installation list: specified installations-Node_0xE6,Not coded ,32
IDE01996-ENG118399-Installation list: specified installations-Node_0xE7,Not coded ,32
IDE01996-ENG118400-Installation list: specified installations-Node_0xE8,Not coded ,32
IDE01996-ENG118401-Installation list: specified installations-Node_0xE9,Not coded ,32
IDE01996-ENG118402-Installation list: specified installations-Node_0xEA,Not coded ,32
IDE01996-ENG118403-Installation list: specified installations-Node_0xEB,Not coded ,32
IDE01996-ENG118404-Installation list: specified installations-Node_0xEC,Not coded ,32
IDE01996-ENG118405-Installation list: specified installations-Node_0xED,Not coded ,32
IDE01996-ENG118406-Installation list: specified installations-Node_0xEE,Not coded ,32
IDE01996-ENG118407-Installation list: specified installations-Node_0xEF,Not coded ,32
IDE01996-ENG118408-Installation list: specified installations-Node_0xF0,Not coded ,32
IDE01996-ENG118409-Installation list: specified installations-Node_0xF1,Not coded ,32
IDE01996-ENG118410-Installation list: specified installations-Node_0xF2,Not coded ,32
IDE01996-ENG118411-Installation list: specified installations-Node_0xF3,Not coded ,32
IDE01996-ENG118412-Installation list: specified installations-Node_0xF4,Not coded ,32
IDE01996-ENG118413-Installation list: specified installations-Node_0xF5,Not coded ,32
IDE01996-ENG118414-Installation list: specified installations-Node_0xF6,Not coded ,32
IDE01996-ENG118415-Installation list: specified installations-Node_0xF7,Not coded ,32
IDE01996-ENG118416-Installation list: specified installations-Node_0xF8,Not coded ,32
IDE01996-ENG118417-Installation list: specified installations-Node_0xF9,Not coded ,32
IDE01996-ENG118418-Installation list: specified installations-Node_0xFA,Not coded ,32
IDE01996-ENG118419-Installation list: specified installations-Node_0xFB,Not coded ,32
IDE01996-ENG118420-Installation list: specified installations-Node_0xFC,Not coded ,32
IDE01996-ENG118421-Installation list: specified installations-Node_0xFD,Not coded ,32
IDE01996-ENG118422-Installation list: specified installations-Node_0xFE,Not coded ,32
IDE01996-ENG118423-Installation list: specified installations-Node_0xFF,Not coded ,32
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,69 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,EFB ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111111 ,15
IDE03903-Production process data 1,00 00 ,2
IDE04159-Deactivation of start-stop function,Mode not active ,1
IDE04186-Battery terminal recognition,connected ,1
IDE04330-Transfer of release code for a SWaP function,00 ,1
IDE06530-Distance left for deactivation of static current measuring mode,2 ,1
IDE06541-Distance left for deactivation of transport mode,50 ,1
IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof,activated ,4
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated ,4
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated ,4
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated ,4
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated ,4
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated ,4
IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof,activated ,4
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D,activated ,4
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated ,4
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated ,4
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated ,4
IDE06753-MAS06289-Efficiency program display-Comfort use A/C,activated ,4
IDE06753-MAS06290-Efficiency program display-Comfort use parking heater,activated ,4
IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater,activated ,4
IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater,activated ,4
IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation,activated ,4
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated ,4
IDE06753-MAS06295-Efficiency program display-Comfort use fog light,activated ,4
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,not activated ,4
IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission,activated ,4
IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater,activated ,4
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated ,4
IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater,activated ,4
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,activated ,4
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,activated ,4
IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection,ECO tips independent of driver profile selection ,4
IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumption,activated ,4
IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependency,Until temperature threshold: with after-run: with switch ,4
IDE07838-Counter for inconsistent states,7 ,2
IDE08348-Start/stop start voltage limit,7.8 V,1
IDE08624-MKE Check box,activated ,1
IDE10735-Number requests autonomous recharging,3 ,1
IDE10736-Cyclization limitation request battery service,0 ,1
IDE10748-MAS11262-Range gain-Range gain AC system,activated ,3
IDE10748-MAS11263-Range gain-Range gain auxiliary heater,activated ,3
IDE10748-MAS11264-Range gain-Range gain window defogger,activated ,3
IDE10748-MAS11265-Range gain-Range gain seat heater front,activated ,3
IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated ,3
IDE10748-MAS11267-Range gain-Range gain rear heater,activated ,3
IDE10748-MAS11268-Range gain-Range gain fog light,activated ,3
IDE10748-MAS11269-Range gain-Range gain rear fog light,not activated ,3
IDE10748-MAS11270-Range gain-Range gain windshield heating,activated ,3
IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated ,3
IDE10748-MAS11272-Range gain-Range gain mirror heater,activated ,3
IDE10748-MAS11273-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,not activated ,3
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,not activated ,3
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,not activated ,3
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,not activated ,3
IDE10748-MAS11279-Range gain-List at engine still stand,activated ,3
IDE10748-MAS12689-Range gain-Catalogue range display,activated ,3
IDE10748-MAS12690-Range gain-Loading condition catalogue range display,activated ,3
IDE10748-MAS13161-Range gain-List display absolute values ??with weighting,activated ,3
IDE10748-MAS19099-Range gain-Convenience consumption socket,activated ,3
IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumption,not activated ,3
IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heating,not activated ,3
IDE11689-48V-System: locking,regular operation ,1
MAS16372-Security version number,3 ,2
SFT271921-IDE02583-Multi Function Steering Wheel Control Module-Steering wheel Tiptronic switch,not installed ,3
SFT271921-MAS04733-Multi Function Steering Wheel Control Module-Two-stage,not active ,3
SFT271921-MAS06614-Multi Function Steering Wheel Control Module-Version,CCS ,3
SFT271921-MAS09758-Multi Function Steering Wheel Control Module-Temperature sensor,not installed ,3
SFT271921-MAS19102-Multi Function Steering Wheel Control Module-Dimming after-run,active ,3
SFT271921-MAS19103-Multi Function Steering Wheel Control Module-Local data bus: wake-up function,not active ,3
SFT271921-MAS19104-Multi Function Steering Wheel Control Module-Alarm horn wake-up function,not active ,3
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active ,12
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,100 ,12
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms,12
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms,12
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,3000 ms,12
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms,12
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,255000 ms,12
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,1500 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,500 ms,12
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,2500 ms,12
ENG137060-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen,Mode not active ,4
ENG137060-ENG98711-EM_energy_management_warning_displays-Charge level,Mode not active ,4
ENG137060-ENG113873-EM_energy_management_warning_displays-Generatormeldungen,Mode not active ,4
ENG137060-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen,Mode not active ,4
ENG137075-EM_heating_power_quota_adjustment,1000 W,1
ENG137061-EM_nominal_voltage_limitation_low_beams,12.1 V,1
ENG137064-EM_requirement_cyclic_time_voltage_measurement,0 s,1
ENG137063-EM_requirement_reduction_air_blowers,Mode not active ,1
ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1,Enabled ,32
ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module,Enabled ,32
ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1,not enabled ,32
ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side,Enabled ,32
ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning,Enabled ,32
ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics,Enabled ,32
ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,Enabled ,32
ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1,Enabled ,32
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control,Enabled ,32
ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics,Enabled ,32
ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not enabled ,32
ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics,Enabled ,32
ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board,Enabled ,32
ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater,Enabled ,32
ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway,Enabled ,32
ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,Enabled ,32
ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance,Enabled ,32
ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module 2,Enabled ,32
ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control,Enabled ,32
ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,Enabled ,32
ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control,Enabled ,32
ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking,Enabled ,32
ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,Enabled ,32
ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics,Enabled ,32
ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side,Enabled ,32
ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant,Enabled ,32
ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,Enabled ,32
ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor,Enabled ,32
ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side,Enabled ,32
ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance,Enabled ,32
ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,Enabled ,32
ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multifunction module,Enabled ,32
ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module,Enabled ,32
ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side,Enabled ,32
ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation,Enabled ,32
ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,Enabled ,32
ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,Enabled ,32
ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1,Enabled ,32
ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph,Enabled ,32
ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1,Enabled ,32
ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,Enabled ,32
ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View,Enabled ,32
ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit,Enabled ,32
ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit,Enabled ,32
ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance,Enabled ,32
ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery Regulation Auxiliary Accumulator 1,Enabled ,32
ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head Up Display,Enabled ,32
ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module,Enabled ,32
ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System,Enabled ,32
ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit,Enabled ,32
ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled ,32
ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface,Enabled ,32
ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side,Enabled ,32
ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side,Enabled ,32
ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management,Enabled ,32
ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left,Enabled ,32
ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right,Enabled ,32
ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,Enabled ,32
ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,Enabled ,32
ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module,Enabled ,32
ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof,Enabled ,32
ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter / Generator Control Module,Enabled ,32
ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Control Unit Lane Change Assistant 2,Enabled ,32
ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,Enabled ,32
ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,Enabled ,32
ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,Enabled ,32
ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,Enabled ,32
ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,Enabled ,32
ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,Enabled ,32
ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,Enabled ,32
ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,Enabled ,32
ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,Enabled ,32
ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,Enabled ,32
ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,Enabled ,32
ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,Enabled ,32
ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,Enabled ,32
ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,Enabled ,32
ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,Enabled ,32
ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,Enabled ,32
ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,Enabled ,32
ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,Enabled ,32
ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,Enabled ,32
ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,Enabled ,32
ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,Enabled ,32
ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,Enabled ,32
ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,Enabled ,32
ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,Enabled ,32
ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,Enabled ,32
ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,Enabled ,32
ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,Enabled ,32
ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,Enabled ,32
ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,Enabled ,32
ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,Enabled ,32
ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,Enabled ,32
ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,Enabled ,32
ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,Enabled ,32
ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,Enabled ,32
ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,Enabled ,32
ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,Enabled ,32
ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,Enabled ,32
ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,Enabled ,32
ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,Enabled ,32
ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,Enabled ,32
ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,Enabled ,32
ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,Enabled ,32
ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,Enabled ,32
ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,Enabled ,32
ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,Enabled ,32
ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,Enabled ,32
ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,Enabled ,32
ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,Enabled ,32
ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,Enabled ,32
ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,Enabled ,32
ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,Enabled ,32
ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,Enabled ,32
ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,Enabled ,32
ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,Enabled ,32
ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,Enabled ,32
ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,Enabled ,32
ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,Enabled ,32
ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,Enabled ,32
ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,Enabled ,32
ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,Enabled ,32
ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,Enabled ,32
ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,Enabled ,32
ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,Enabled ,32
ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,Enabled ,32
ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,Enabled ,32
ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,Enabled ,32
ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,Enabled ,32
ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,Enabled ,32
ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,Enabled ,32
ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,Enabled ,32
ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,Enabled ,32
ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,Enabled ,32
ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,Enabled ,32
ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,Enabled ,32
ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,Enabled ,32
ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,Enabled ,32
ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,Enabled ,32
ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,Enabled ,32
ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,Enabled ,32
ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,Enabled ,32
ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,Enabled ,32
ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,Enabled ,32
ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,Enabled ,32
ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,Enabled ,32
ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,Enabled ,32
ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,Enabled ,32
ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,Enabled ,32
ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,Enabled ,32
ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,Enabled ,32
ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,Enabled ,32
ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,Enabled ,32
ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,Enabled ,32
ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,Enabled ,32
ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,Enabled ,32
ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,Enabled ,32
ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,Enabled ,32
ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,Enabled ,32
ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,Enabled ,32
ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,Enabled ,32
ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,Enabled ,32
ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,Enabled ,32
ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,Enabled ,32
ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,Enabled ,32
ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,Enabled ,32
ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,Enabled ,32
ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,Enabled ,32
ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,Enabled ,32
ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,Enabled ,32
ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,Enabled ,32
ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,Enabled ,32
ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,Enabled ,32
ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,Enabled ,32
ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,Enabled ,32
ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,Enabled ,32
ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,Enabled ,32
ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,Enabled ,32
ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,Enabled ,32
ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,Enabled ,32
ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,Enabled ,32
ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,Enabled ,32
ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,Enabled ,32
ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,Enabled ,32
ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,Enabled ,32
ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,Enabled ,32
ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,Enabled ,32
ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,Enabled ,32
ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,Enabled ,32
ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,Enabled ,32
ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,Enabled ,32
ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,Enabled ,32
ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,Enabled ,32
ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,Enabled ,32
ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,Enabled ,32
ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,Enabled ,32
ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,Enabled ,32
ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,Enabled ,32
ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,Enabled ,32
ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,Enabled ,32
ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,Enabled ,32
ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,Enabled ,32
ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,Enabled ,32
ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,Enabled ,32
ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,Enabled ,32
ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,Enabled ,32
ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,Enabled ,32
ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,Enabled ,32
ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,Enabled ,32
ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,Enabled ,32
ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,Enabled ,32
ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,Enabled ,32
ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,Enabled ,32
ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,Enabled ,32
ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,Enabled ,32
ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,Enabled ,32
ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,Enabled ,32
ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,Enabled ,32
ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,Enabled ,32
ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,Enabled ,32
ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,Enabled ,32
ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,Enabled ,32
ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,Enabled ,32
ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,Enabled ,32
ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,Enabled ,32
ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,Enabled ,32
ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,Enabled ,32
ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,Enabled ,32
ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,Enabled ,32
ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,Enabled ,32
ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,Enabled ,32
ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,Enabled ,32
ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,Enabled ,32
ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,Enabled ,32
ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,Enabled ,32
ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,Enabled ,32
ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,Enabled ,32
ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,Enabled ,32
ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,Enabled ,32
ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,Enabled ,32
ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,Enabled ,32
ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,Enabled ,32
ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,Enabled ,32
ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,Enabled ,32
ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,Enabled ,32
ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,Enabled ,32
ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,Enabled ,32
ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,Enabled ,32
ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,Enabled ,32
ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,Enabled ,32
ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,Enabled ,32
ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,Enabled ,32
ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,Enabled ,32
ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,Enabled ,32
ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Databus drivetrain ,2
ENG137059-ENG118465-GW_mirror_mode-mirror_mode_typ,not active ,2
ENG152379-MV-EM_adaption_48V_zero_potential,regular operation ,1
ENG137850-MVK_Warning,regular operation ,1
ENG118774-ENG98345-WakeUpMonitor_Activation-Activation,activated ,1
ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,activated ,1
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,8
ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,20 ,8
ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,20 ,8
ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,45 min,8
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,8
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,8
Elapsed Time: 00:26
22 Map
;SW:0CQ-907-554-J   HW:0CQ-525-130 ---  AWD
;Component:Haldex4Motion H52 7084, Coding:0101
;EV_AllWheelContrHA1VW37X,004013,EV_AllWheelContrHA1VW37X_004.rod
;Saturday,01,June,2019,12:57:10:47965
;VCDS Version: Release 19.6.0 (x64)  Data version: 20190529 DS308.0
;VCID: 4CC165D21640A2B7669-8018
IDE07843-ENG142105-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_4,2000 ,8
IDE07843-ENG142107-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_5,2000 ,8
IDE07843-ENG142109-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_6,2000 ,8
IDE07843-ENG142111-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_7_plus,2000 ,8
IDE07843-ENG142104-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_4,1150 ,8
IDE07843-ENG142106-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_5,1150 ,8
IDE07843-ENG142108-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_6,1150 ,8
IDE07843-ENG142110-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_7_plus,1150 ,8
IDE07844-ENG142113-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_4,2200 ,8
IDE07844-ENG142115-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_5,2200 ,8
IDE07844-ENG142117-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_6,2200 ,8
IDE07844-ENG142119-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_7_plus,2200 ,8
IDE07844-ENG142112-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_4,1300 ,8
IDE07844-ENG142114-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_5,1300 ,8
IDE07844-ENG142116-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_6,1300 ,8
IDE07844-ENG142118-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_7_plus,1300 ,8
MAS06098-Acoustic measure: wiring logic,Standard ,1
Elapsed Time: 00:02
42 Map
;SW:5Q4-959-393-M   HW:5Q4-959-393-F ---  Door Elect, Driver
;Component:TSG FS        006 0247, Coding:003013200000048000000000
;EV_DCU2DriveSideMAXHCONT,001005,EV_DCU2DriveSideMAXHCONT_VW37.rod
;Saturday,01,June,2019,12:57:21:47965
;VCID: 4DC768D6ED5AABBF717-8018
IDE00001-MAS10864-Production mode-Reduce reverse threshold,Deactivating ,3
IDE00001-MAS10865-Production mode-Power windows operable with terminal 15 off,Deactivating ,3
IDE00001-MAS10866-Production mode-Reduce switch-on time of lighting,Deactivating ,3
IDE00001-MAS10867-Production mode-Deactivate speed control for power windows,Deactivating ,3
IDE00001-MAS10868-Production mode-Deactivate closing aid,Deactivating ,3
IDE00001-MAS10869-Production mode-Activate test mode for the fold-in mirror,Deactivating ,3
IDE00001-MAS10870-Production mode-Activate test mode for power windows,Deactivating ,3
IDE00001-MAS17286-Production mode-Deactivation of actuation of opening assistance motor: e-lock,Deactivating ,3
IDE00001-MAS17291-Production mode-Deactivation of CarWakeUp due to activation of seatbelt feeder,Deactivating ,3
ENG117304-ENG148862-Patch_Code_Driver_Side_Rear-Parameter_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4F 97 01 04 4F 0C 08 03 4D 15 20 3D 04 64 00 00 00 00 00 00 00 00 00 C2 32 04 ,128
ENG117304-ENG148865-Patch_Code_Driver_Side_Rear-Parameter_2,33 48 ,128
ENG117297-Reversing_Threshold_Driver_Side_Front,90 %,1
ENG117299-Reversing_Threshold_Driver_Side_Rear,90 %,1
ENG117302-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_1,66 4E 03 02 00 00 18 24 7F 7C 02 9A 15 0D 2A 7A 04 0F 1E 18 07 00 05 3E 23 03 00 14 28 AA 00 00 1E 5A AA 08 0A 05 05 00 00 00 23 64 1E 1E 0A 68 04 00 09 00 73 00 04 35 4C C0 05 0E 16 4C 54 64 96 14 96 8C 7D 7D 7D 7D A0 80 98 94 90 90 90 90 9A 32 02 06 08 0A 00 00 00 32 04 A4 0F F5 F5 1E 23 0C 1E 69 46 0A 50 96 00 00 96 96 05 00 00 00 01 01 4C 00 00 02 03 05 14 75 33 00 00 00 ,128
ENG117302-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_2,E6 58 ,128
ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear,14 04 60 03 48 1F 13 00 14 14 00 28 00 26 02 58 01 90 02 58 0A 7D 0C 1E 28 00 32 32 00 F0 00 00 00 00 00 00 00 E4 00 00 3F 05 9C 4E 20 4D 58 1D 0C 0C 4E 44 A7 4D 9F 32 0A 9C 1F 9C 00 00 00 00 00 00 00 00 00 FA 00 00 33 4B 30 31 03 00 00 00 00 00 00 00 00 00 6C 45 ,88
Elapsed Time: 00:07
44 Map
;SW:5QM-909-144-B   HW:5QM-909-144-B ---  Steering Assist
;Component:EPS_MQB_ZFLS  173 1081, Coding:811F0000
;EV_SteerAssisMQB,015157,EV_SteerAssisMQB_015.rod
;Saturday,01,June,2019,12:57:30:47965
;VCID: 50F971A2FA6886571A1-8004
IDE03724-Straight line running,active ,1
IDE03734-Support power,100% ,1
IDE04130-Characteristic curve of steering assistance,Driving profile selection button ,1
IDE04555-Activation of pwr steering asst without engine running,not active ,1
IDE05162-Software end stop,active ,1
IDE06419-Driving profile switchover,Incremental: controlled over time ,1
IDE07540-Download without rest bus,not active ,1
IDE09571-RPM monitoring,active ,1
MAS02080-XCP calibration protocol,not active ,1
Elapsed Time: 00:02
52 Map
;SW:5Q4-959-392-M   HW:5Q4-959-392-F ---  Door Elect, Pass.
;Component:TSG BFS       006 0247, Coding:003013200000048000000000
;EV_DCU2PasseSideMAXHCONT,001005,EV_DCU2PasseSideMAXHCONT_VW37.rod
;Saturday,01,June,2019,12:57:34:47965
ENG117308-ENG148862-Patch_Code_Passenger_Side_Rear-Parameter_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4F 97 01 04 4F 0C 08 03 4D 15 20 3D 04 64 00 00 00 00 00 00 00 00 00 C2 32 04 ,128
ENG117308-ENG148865-Patch_Code_Passenger_Side_Rear-Parameter_2,33 48 ,128
ENG117298-Reversing_Threshold_Passenger_Side_Front,90 %,1
ENG117300-Reversing_Threshold_Passenger_Side_Rear,90 %,1
ENG117306-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_1,6C 4E 03 02 00 00 18 24 7F 7C 02 9A 15 0D 2A 7A 04 0F 1E 18 07 00 05 3E 23 03 00 14 28 AA 00 00 1E 5A AA 08 0A 05 05 00 00 00 23 64 1E 1E 0A 68 04 00 09 00 73 00 04 35 4C C0 05 0E 16 4C 54 64 96 14 96 8C 7D 7D 7D 7D A0 80 98 94 90 90 90 90 9A 32 02 06 08 0A 00 00 00 32 04 A4 0F F5 F5 1E 23 0C 1E 69 46 0A 50 96 00 00 96 96 05 00 00 00 02 01 4C 00 00 02 03 05 14 75 33 00 00 00 ,128
ENG117306-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_2,C8 B5 ,128
ENG117305-Window_Regulator_VW_Settings_Passenger_Side_Rear,14 04 60 03 48 1F 13 00 14 14 00 28 00 26 02 58 01 90 02 58 0A 7D 0C 1E 28 00 32 32 00 F0 00 00 00 00 00 00 00 E4 00 00 3F 05 9C 4E 20 4D 58 1D 00 00 4E 44 A7 4D 9F 32 0A 9C 1F 9C 00 00 00 00 00 00 00 00 00 FA 00 00 33 4B 30 31 03 00 00 00 00 00 00 00 00 00 A9 85 ,88
Elapsed Time: 00:07
CA Map
;SW:4M0-907-594-J   HW:4M0-907-594 ---  Sunroof
;Component:SAD_STG_1     014 0005, Coding:00804073260C
;EV_SunRoofCONTIAU736,006008,EV_SunRoofCONTIAU736_006.rod
;Saturday,01,June,2019,12:58:30:47965
;VCID: 3D2738165DFA1B3FE17-8068
IDE00001-Production mode,not active ,3
IDE02104-IDE03633-Temperature dependent activation-Close sunroof,not active ,1
IDE02104-MAS09030-Temperature dependent activation-Open sun roof,active ,1
IDE02104-MAS09031-Temperature dependent activation-Open roof blind,active ,1
IDE02104-MAS09032-Temperature dependent activation-Close roof blind,active ,1
IDE09435-IDE03633-Speed dependent activation-Close sunroof,not active ,1
IDE09435-MAS09030-Speed dependent activation-Open sun roof,active ,1
IDE09435-MAS09031-Speed dependent activation-Open roof blind,not active ,1
IDE09435-MAS09032-Speed dependent activation-Close roof blind,not active ,1
IDE09439-MAS08884-Logic switch-over: controls-Sunroof button,not active ,1
IDE09439-MAS08932-Logic switch-over: controls-Sunroof shade button,not active ,1
IDE09439-MAS08992-Logic switch-over: controls-Button for sliding roof,not active ,1
IDE09439-MAS10443-Logic switch-over: controls-Button for sunroof/tilt roof: rear,not active ,1
IDE09439-MAS10444-Logic switch-over: controls-Sunroof shade button: rear,not active ,1
IDE09451-MAS08936-Travel path-Tilted position: max. opening width,not active ,1
IDE09451-MAS08937-Travel path-Sliding position: intermed. pos.,active ,1
IDE09451-MAS08991-Travel path-Sliding position: reduc. opening width,not active ,1
IDE09451-MAS10725-Travel path-Sunroof shade: interm. position open,not active ,1
IDE09451-MAS10726-Travel path-Sunroof shade: interm. position close,not active ,1
IDE11842-IDE09434-Comfort functions-Target position for comfort opening,Tilt out posi. ,1
IDE11842-MAS13329-Comfort functions-Comfort opening of roof shade,active ,1
IDE11842-MAS13330-Comfort functions-Comfort closing of roof shade,active ,1
IDE11842-MAS14142-Comfort functions-Private sphere mode,not active ,1
ENG146366-Applikationmode deactivate,Deactivating ,1
Elapsed Time: 00:02
