Problems with rough idle, lambda control bank1 vs bank2 is way off
Znippie
Norway
C?ID=328489
Hey!
I got an issue with my 2.7 biturbo BES engine.
At idle my lambda values are waaay off. Even when im driving with some boost i can see that the lambda control bank1 and 2 is far away from eachother. I have not been able to log this yet.
As you can see from my screenshot below, under group 031, the specified voltage for bank1 is somehow similar to the actual voltage on bank2. And visa verca for the other bank.
Is it possible to connect the lambda to the wrong connector in the wiring harness? :confused:
My coils and spark plugs are brand new, installed them last week to hopefully eliminate the problem
No faultcodes on the ECU, and no misfires.
Any suggestions?
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Heh, it's been done before, seen here more than once. Switching them is an easy test, why not try it?
Trace the circuit's using WD and verifying sensor locations.
