- Joined
- Nov 14, 2014
- Messages
- 149
- Reaction score
- 53
- Location
- San José, Costa Rica
- VCDS Serial number
- C?ID=230356
I'd like to know if it is possible to tweak my car through VCDS to add the following.
1. Start-stop
2. Indirect TPMS
3. Change my DRLs to fog lights
4. Re-fill volume in the DIS (amount of liters of fuel consumed). I've seen instructions for a Skoda Octavia (MQB) which I followed, but it did not work.
5. Would it be possible to enable the alarm to close the windows if someone puts their hand inside the cabin?
6. Enable Drive-select like settings for the steering effort in MMI. Maybe even enable different throttle mapping?
7. Even with the "late" setting my headlamps turn on too early for my taste when in auto mode, can the light sensor sensitivity be altered?
I hope it is not too much to ask.
Here's my autoscan:
1. Start-stop
2. Indirect TPMS
Here's my autoscan:
Thursday,27,November,2014,18:12:27:29892
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: WAUZZZ8V2FA000583 License Plate: TBR043
Mileage: 9198km-5715mi Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WAUZZZ8V2FA000583 Mileage: 9198km-5715miles
Address 01: Engine (J623-CJZA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 B HW: 04E 907 309 A
Component: 1.2l R4 TSI H08 6387
Revision: WAH08---
Coding: 02110012230400082000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM12TFS01104E906016B 001008
ROD: EV_ECM12TFS01104E906016B.rod
VCID: 2149CBAF30BD2E29405-8074
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 606040000015FD
Coding: 10F16AA224200A6C017C060841C62508562450806082A4B2002100080608
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 7BF5D9C7F291A4F93A9-802E
Address 08: Auto HVAC (E87) Labels: 8V0-820-047.clb
Part No SW: 8V0 820 047 D HW: 8V0 820 047 D
Component: AC Manuell el H11 0052
Revision: 20021000 Serial number: 00000000054640
Coding: 00000004100000000000000000000000
ASAM Dataset: EV_AirCondiFrontManAU37X 008018
ROD: EV_AirCondiFrontManAU37X.rod
VCID: 377D05F78E3940999E1-8062
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AC HW: 5Q0 937 084 AC
Component: BCM MQBAB M H16 0124
Serial number: 00011406500433
Coding: 04040842C001027D03044004B30407000000000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 79F9C3CFF8AD96E9285-802C
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119
Component: WWS370 140225 041 0580
Serial number: 140227184035
Coding: 0A47F7
Subsystem 2 - Part No SW: 8U0 955 559 A HW: 8U0 955 559 A
Component: G397_RLS H06 0002
Serial number: 20143063
Coding: 06885D
Subsystem 3 - Part No SW: 8V0 941 531 Q HW: 8V0 941 531 Q
Component: E1 - LDS MQB H05 0032
Serial number: 29 11 2013 00001158
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY140231TB1
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000058976888
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R05LNY8
Coding: 98CCC000000000005C540000004800000065
VCID: 4B954907E2B1D479CA9-801E
Subsystem 1 - Part No SW: ----------- HW: 480 001 702 14
Serial number: 35767000000685500F0O
Subsystem 2 - Part No SW: ----------- HW: 480 001 702 14
Serial number: 35867000000885500F0R
Subsystem 3 - Part No SW: ----------- HW: 480 400 703 14
Serial number: 35165029F14D3E72E40M
Subsystem 4 - Part No SW: ----------- HW: 480 402 802 14
Serial number: 3526502C112F6291710.
Subsystem 5 - Part No SW: ----------- HW: 480 400 702 14
Serial number: 3556502C513013F3D10/
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 BM HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 07031404220752
Coding: 0408
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 0603B833B953E911557-8053
Part No SW: 8V0 920 860 E HW: 8V0 920 860 E
Component: KOMBI H02 2220
Coding: 07850200228000080500BA00100000
VCID: 3C771ADBB71F63C1733-8069
Address 19: CAN Gateway (J533) Labels: Redir Fail!
Part No SW: 5Q0 907 530 P HW: 5Q0 907 530 E
Component: GW MQB Mid 124 1164
Revision: -------- Serial number: 0001674704
Coding: 01010008200864005B000208000B00000001000000000000000000000000
ROD: EV_GatewLear.rod
VCID: 3E7310D3A10371D15D7-806B
Subsystem 2 - Part No SW: 8U0 951 528 HW: 8U0 951 528
Component: E221 - MFL H02 0014
Serial number: 20 02 2014 B1311502
Part No SW: 5Q0 959 393 B HW: 5Q0 959 393 B
Component: TSG FS 020 0025
Serial number: 22021403110883
Coding: 00100E20C100040100001002
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 0102
ROD: EV_SteerAssisMQB_AU37.rod
VCID: 41896B2FD0FD0E29205-8014
Part No SW: 5Q0 959 392 B HW: 5Q0 959 392 B
Component: TSG BFS 020 0025
Serial number: 04031403110700
Coding: 00100620CD00040100001002
VCID: 3D7117DFAC056AC944D-8068
Part No SW: 8V0 035 840 B HW: 8V0 035 840 B
Component: MU-S--ER 040 0420
Serial number: A3E00403140672
Coding: 01730000FF0A000021220001001A00002F0001440100010002
ASAM Dataset: EV_MUStd6C3PASE 002020
ROD: EV_MUStd6C3PASE.rod
VCID: 346732FB9F4FAB81BB3-8061
Seat Adjustment Driver Side:
Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0013
Serial number: AUZ8Z9DY301DHC
Sound System:
Subsystem 2 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000019021400010341
End-------------------------(Elapsed Time: 02:47)--------------------------
