Q3 TPMS greyed out
robertmaccara
Canada
C?ID=138039
I’m trying to enable the TPMS on my 2015 Audi Q3.
VIN: WA1EFEFS7FR012638. I have the 1AT ABS unit
Here are the steps I’ve followed t enable TPMS:
[Hidden menu] [car] [cardevicelist] [RDK] Enable
[Hidden menu] [car] [carmenuoperation] [Tires Air Pressure Control] Set to 5
[03 - ABS Brakes]
[Security Access - 16] (probably with login code: 61378)  This code does not work
[Coding - 07] -> Long Coding Helper -> Byte 1
Bit 3 - Tire Pressure Monitoring (PR-7K6) active (1 = active)
The TPMS need to be enabled in the Instrument Cluster:
[17 - Instruments]
[Coding - 07] -> Long Coding Helper -> Byte 4
Bit 0 - Tire Pressure Monitoring (TPMS) installed (1 = active)
Reset MMI
After doing this, I still don’t get the option to set TPMS in the MMI and I’ve a warning light in the dash for TPMS Malfunction.
Would knowing the value for this control module help me get this resolved? The suggested Security Code of 61378 does not work.
Sunday,10,March,2019,15:13:20:06778
VCDS Version: 18.9.1.0 (x64)
VIN: WA1EFEFS7FR012638   License Plate: VE1 RTM
Mileage: 33000km-20505mi   Repair Order:
Chassis Type: FS-AU21 (8U0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 55 56 5F
          62 6C 6D 72
VIN: WA1EFEFS7FR012638   Mileage: 33000km-20505miles
6C-Back-up Cam. -- Status: Cannot be reached 1100
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 8U0 907 115 J    HW: 8U0 907 115 J
   Component: 2.0l R4/4V TFSI  06 0004
   Revision: PAH04---    Serial number:
   Coding: 0123010A190F01A0
   Shop #: WSC 00049 770 00117
   VCID: 3E792982696DCFBAEF-806A
   Part No SW: 09G 927 750 NL    HW: 09G 927 750 NL
   Component: AQ 250 6F           2696
   Revision: 00H97000    Serial number:
   Coding: 0000328
   Shop #: WSC 00049 770 00132
   VCID: 08158F5A7B29410A95-805C
Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
   Part No SW: 5N0 614 109 BA    HW: 5N0 614 109 BA
   Component: J104   C6 450M VD97 0160
   Revision: --H07---    Serial number: 00000007971252
   Coding: 0018094
   Shop #: WSC 00049 770 00153
   VCID: 6BDFD0D64A9F8A1218-803E
   Part No SW: 8U0 820 043 E    HW: 8U0 820 043 E
   Component: E87  Klimavoll      0100
   Revision: 00H04000    Serial number: 8U0820043E
   VCID: 336F08B6522F12D210-8066
Address 09: Cent. Elect. (J519)       Labels:. 8X0-907-063.clb
   Part No SW: 8X0 907 063 AC    HW: 8X0 907 063 AC
   Component: BCM PQ35  M   113 0817
   Revision: AB113817
   Coding: AF000A3BE80336C4241843C12104894D57FF84AA016F912BE40A4E8400C5
   Shop #: WSC 12345 123 61029
   VCID: 7DFBEE8EE4EB14A2B6-8028
   Subsystem 1 - Part No SW: 8U1 955 119     HW: 8U1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS316 150110  H37 0090
   Serial number:         150119084707
   Coding: 0047F7
   Serial number: 23686985
   Coding: 02006E
                    Reset counter: 177
                    Mileage: 32444 km
                    Date: 2019.02.20
                    Time: 07:33:55
                    Voltage: 8.40 V
                        Term 50 On
Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
   Part No SW: 8X0 919 475 AE    HW: 8X0 919 475
   Component: PARKHILFE 4K  H03 0080
   Revision: 11001001    Serial number: 37031502903960
   Coding: 080104
   ASAM Dataset: EV_EPHVA14AU21X0000 003007
   ROD: EV_EPHVA14AU21X0000_003.rod
   VCID: 09138A5EA82338028A-805C
Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
   Part No SW: 8U0 959 655 A    HW: 8U0 959 655 A
   Component: AirbagVW-AU10 H52 0723
   Serial number: 003LQD11BDRU
   Coding: 30383231323141313030554A304C38553053
   ASAM Dataset: EV_AirbaAU10SMEAU316 002001
   ROD: EV_AirbaAU10SMEAU316_002.rod
   VCID: 458B466EC4BB9C62AE-8010
   Component: S.Sens.Fahr.V
   Serial number: 3574MSME45272D4EZZZ3
   Component: S.Sens.Beif.V
   Serial number: 3584MSME3B302C4EZZZ2
   Serial number: 3516KSME34064A34ZZZN
   Serial number: 3526KSME21792935ZZZS
   Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3555USME606A5233ZZZ.
   Subsystem 6 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3565USME1C505233ZZZY
Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
   Part No SW: 8X0 953 501 D    HW: 5K0 953 569 AL
   Component: LENKS.MODUL   016 0162
   Revision: FF010018    Serial number: 20150207200792
   Coding: 1994204000
   VCID: 3B7F2096B27FDA92C8-806E
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 23 01 2015  E0069232
Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb-SRI1
   Part No SW: 8U0 920 940 D    HW: 8U0 920 940 D
   Component: KOMBI_COLOUR  H02 0240
   Coding: 324D01
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
   VCID: 39733A9EB843E882DA-806C
16776988 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 151
                    Mileage: 33007 km
                    Date: 2019.03.10
                    Time: 14:34:49
Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
   Part No SW: 8U0 907 468 AE    HW: 8U0 907 468 J
   Component: GAT 4CAN 2L M H13 0074
   Revision: 1R160041    Serial number: 4141R15120077D
   Coding: F3C60A5A050B05610253
   VCID: 050B866E8C3B5C62EE-8050
   Subsystem 1 - Part No SW: 8U0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS11.403  H03 0004
   Serial number: 0000FST0004ZDYE00000
   Coding: 101E00
   Subsystem 2 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0180
   Serial number: 42035C03211491482275
   Subsystem 3 - Part No SW: 8U0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS11.403  H03 0004
   Serial number: 0000FST0004ZDVB00000
   Coding: 001E00
            000 -  -  - Intermittent
                    Fault Frequency: 20
                    Reset counter: 185
                    Mileage: 30420 km
                    Date: 2018.12.11
                    Time: 01:02:01
                    Bin. Bits:    00000
                    Voltage: 12.00 V
                    Count: 19
                    Reset counter: 181
                    Mileage: 22510 km
                    Date: 2018.06.24
                    Time: 13:28:54
                    Bin. Bits:    10111
                    Voltage: 11.70 V
                    Count: 6
                    Bin. Bits:    00000
                    Time: 25.40 s
   Part No SW: 0AY 907 554 J    HW: 0AY 907 554 J
   Component: Haldex4Motion H52 7522
   Serial number: HA1-00021.01.15
   Coding: 0001
   VCID: 52A16D3205F53BDA3B-8006
   Component: IMMO          H02 0240
   Coding: 000002
   ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
   ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
   Part No SW: 8X0 959 793 K    HW: 8X0 959 793 K
   Component: TSG FA        H11 0415
   Coding: 011E03200000000000
   VCID: 55AB962E3C1B2CE2DE-8000
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.377 1401
   Revision: 1BH04841    Serial number: 00150210053601
   Coding: 0000258
   Shop #: WSC 59291 001 1048576
   VCID: 4183527E1893B04292-8014
Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
   Part No SW: 8X0 959 792 K    HW: 8X0 959 792 K
   Component: TSG BF        H11 0415
   Coding: 011E03200C00000000
   VCID: 54AD6B2A37E135EA29-8000
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000000513115
   Coding: 0025156
   VCID: 38753F9A4B49F18A25-806C
   Serial number: 150130-0002-125
   Coding: 1657A4101002A400
   ROD: EV_HeadlRegulBasic.rod
   VCID: 42815D72D595AB5A8B-8016
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156A20F8188583
   Coding: 020007020100000002
   VCID: 244DFBEA27C1856A99-8070
03405 - Bass Loudspeaker
                    Reset counter: 181
                    Voltage: 12.30 V
   Part No SW: 8U0 035 664 F    HW: 8U0 035 664 F
   Component: H-BN-NA       H42 0902
   Revision: --------    Serial number: 200BZ0F7531699
   Coding: 0E020006000AE0EB05000F2600000001F40000020000000200
   VCID: 3B7F2096BA7FDA92C8-806E
   Subsystem 1 - Part No: 8R0 060 884 CJ
   Component: NAR 2015  1102
   Subsystem 2 - Part No SW: 8U0 919 604 A    HW: 8U0 919 604 A
   Component: DU High AU316  H42 0018
   Serial number: AUZ8ZDFG900XNBN
   Subsystem 3 - Part No: 8R0 060 961 G
   Component: CD-Database  5950
                    Fault Frequency: 46
                    Reset counter: 151
                    Mileage: 33007 km
                    Date: 2019.03.10
                    Time: 14:31:03
                    Bin. Bits: 00001000 00000000
                    Bin. Bits: 00000000 00000000
   Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
   Component: TSG HL        H08 0415
   Coding: 010E03200000000000
   VCID: 4FA764461EC7563214-801A
Address 6C: Back-up Cam.
   Part No SW: 8U0 959 107     HW: 8U0 959 107
   Component: HDSG-Modul    H01 0549
   Revision: 15001001    Serial number: 033501344
   Coding: 183307C102
   ASAM Dataset: EV_HDSGAU316 001001
   ROD: EV_HDSGAU316.rod
   VCID: 7CFDE38AF7F11DAA81-8028
   Component: TSG HR        H08 0415
End-------------------------(Elapsed Time: 03:47)--------------------------
MasterTommy
Amsterdam
C?ID=295586
What are you trying to activate, indirect TPMS (wheel speed comparison) or direct TPMS (with a sensor in every wheel and a seperate control module)?
Are you sure the coding instructions you are following are for the type of TPMS youre trying to activate?
robertmaccara
Canada
C?ID=138039
I have the 1AT ABS unit and indirect TPMS. I've followed the instructions based on the model I've got.
It's the brake electronics security code that I need.
NEtech
C?ID=56995
Try this Coding: 0022190
robertmaccara
Canada
C?ID=138039
Sorry, that code didn't work either. :(
jasons6930
C?ID=304798
Although you may have done it now, when i did this on my VW Caddy, it threw a 'component protection' error for some reason.
robertmaccara
Canada
C?ID=138039
No, I never had that error. I've undone the VCDS changes I made until can get more details.
